[mapguide-commits] r8172 - in trunk/Tools/Maestro: Maestro Maestro.Editors Maestro.Editors/LayerDefinition/Vector/Scales Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors Maestro.Editors/Properties Maestro.Editors/Resources OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Tue May 27 04:53:02 PDT 2014
Author: jng
Date: 2014-05-27 04:53:02 -0700 (Tue, 27 May 2014)
New Revision: 8172
Added:
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.resx
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.resx
trunk/Tools/Maestro/Maestro.Editors/Resources/application-form.png
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
trunk/Tools/Maestro/Maestro/changelog.txt
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
Composite Symbolization dialog improvements:
- Change "Edit Value" button to become a dropdown button with 2 choices:
- Edit via Editor, which will try to present a specialized input dialog based on the type of the symbol parameter, if no specialized editor found, it will fallback to the Expression Editor
- Edit via Expression Editor, which is the current method
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2014-05-27 07:43:52 UTC (rev 8171)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2014-05-27 11:53:02 UTC (rev 8172)
@@ -6,6 +6,14 @@
- Added specialized builder support for LOOKUP() and RANGE() expression functions in Expression Editor
- Added support for customizing border colors when theming
- Improve the usability of the Composite Symbolization dialog
+ - Moved the inline Symbol Definition editor off to a separate dialog
+ - Symbol name now shown along side type for each component symbol in Symbolization Components list
+ - New button to show more information about a selected symbol parameter
+ - "Edit Instance Properties" button moved into Symbolization Components list toolbar
+ - Editing symbol parameter values can now be done via
+ - Editing the cell
+ - Using a specialized editor (that falls back to the Expression Editor if no specialized editor is found)
+ - Using the Expression Editor
- Fix: Negative index exception in grid-based editor when selecting row header
- Fix: XML diff false positives
- Fix: Wrong previews in Composite Symbolization dialog when multiple composite styles defined
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs 2014-05-27 07:43:52 UTC (rev 8171)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.Designer.cs 2014-05-27 11:53:02 UTC (rev 8172)
@@ -41,14 +41,15 @@
this.inlineSymbolToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.solidFillToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.lineToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
- this.inlineSimpleSymbolToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.pointToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.textLabelPointToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.textLabelLineToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.textLabelPolygonToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.pointToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
+ this.inlineSimpleSymbolToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.btnDelete = new System.Windows.Forms.ToolStripButton();
this.toolStripSeparator2 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnEditInstanceProperties = new System.Windows.Forms.ToolStripButton();
this.btnEditComponent = new System.Windows.Forms.ToolStripButton();
this.grpProperties = new System.Windows.Forms.GroupBox();
this.grdOverrides = new System.Windows.Forms.DataGridView();
@@ -56,14 +57,15 @@
this.btnAddProperty = new System.Windows.Forms.ToolStripDropDownButton();
this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
this.refreshToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
- this.btnEditProperty = new System.Windows.Forms.ToolStripButton();
+ this.btnEditProperty = new System.Windows.Forms.ToolStripDropDownButton();
+ this.viaEditorToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+ this.viaExpressionEditorToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
this.btnDeleteProperty = new System.Windows.Forms.ToolStripButton();
this.toolStripSeparator3 = new System.Windows.Forms.ToolStripSeparator();
this.btnPropertyInfo = new System.Windows.Forms.ToolStripButton();
this.grpPreview = new System.Windows.Forms.GroupBox();
this.lnkRefresh = new System.Windows.Forms.LinkLabel();
this.symPreview = new System.Windows.Forms.PictureBox();
- this.btnEditInstanceProperties = new System.Windows.Forms.Button();
this.btnEditAsXml = new System.Windows.Forms.Button();
this.grpComponents.SuspendLayout();
this.toolStrip1.SuspendLayout();
@@ -113,6 +115,7 @@
this.btnAdd,
this.btnDelete,
this.toolStripSeparator2,
+ this.btnEditInstanceProperties,
this.btnEditComponent});
resources.ApplyResources(this.toolStrip1, "toolStrip1");
this.toolStrip1.Name = "toolStrip1";
@@ -170,18 +173,13 @@
resources.ApplyResources(this.lineToolStripMenuItem, "lineToolStripMenuItem");
this.lineToolStripMenuItem.Click += new System.EventHandler(this.lineToolStripMenuItem_Click);
- // toolStripSeparator4
+ // pointToolStripMenuItem
- this.toolStripSeparator4.Name = "toolStripSeparator4";
- resources.ApplyResources(this.toolStripSeparator4, "toolStripSeparator4");
+ this.pointToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.layer_small;
+ this.pointToolStripMenuItem.Name = "pointToolStripMenuItem";
+ resources.ApplyResources(this.pointToolStripMenuItem, "pointToolStripMenuItem");
+ this.pointToolStripMenuItem.Click += new System.EventHandler(this.pointToolStripMenuItem_Click);
- // inlineSimpleSymbolToolStripMenuItem
- this.inlineSimpleSymbolToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.marker;
- this.inlineSimpleSymbolToolStripMenuItem.Name = "inlineSimpleSymbolToolStripMenuItem";
- resources.ApplyResources(this.inlineSimpleSymbolToolStripMenuItem, "inlineSimpleSymbolToolStripMenuItem");
- this.inlineSimpleSymbolToolStripMenuItem.Click += new System.EventHandler(this.inlineSimpleSymbolToolStripMenuItem_Click);
// textLabelPointToolStripMenuItem
this.textLabelPointToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.edit;
@@ -203,13 +201,18 @@
resources.ApplyResources(this.textLabelPolygonToolStripMenuItem, "textLabelPolygonToolStripMenuItem");
this.textLabelPolygonToolStripMenuItem.Click += new System.EventHandler(this.textLabelPolygonToolStripMenuItem_Click);
- // pointToolStripMenuItem
+ // toolStripSeparator4
- this.pointToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.layer_small;
- this.pointToolStripMenuItem.Name = "pointToolStripMenuItem";
- resources.ApplyResources(this.pointToolStripMenuItem, "pointToolStripMenuItem");
- this.pointToolStripMenuItem.Click += new System.EventHandler(this.pointToolStripMenuItem_Click);
+ this.toolStripSeparator4.Name = "toolStripSeparator4";
+ resources.ApplyResources(this.toolStripSeparator4, "toolStripSeparator4");
+ // inlineSimpleSymbolToolStripMenuItem
+ this.inlineSimpleSymbolToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.marker;
+ this.inlineSimpleSymbolToolStripMenuItem.Name = "inlineSimpleSymbolToolStripMenuItem";
+ resources.ApplyResources(this.inlineSimpleSymbolToolStripMenuItem, "inlineSimpleSymbolToolStripMenuItem");
+ this.inlineSimpleSymbolToolStripMenuItem.Click += new System.EventHandler(this.inlineSimpleSymbolToolStripMenuItem_Click);
// btnDelete
this.btnDelete.Image = global::Maestro.Editors.Properties.Resources.cross_script;
@@ -222,6 +225,13 @@
this.toolStripSeparator2.Name = "toolStripSeparator2";
resources.ApplyResources(this.toolStripSeparator2, "toolStripSeparator2");
+ // btnEditInstanceProperties
+ resources.ApplyResources(this.btnEditInstanceProperties, "btnEditInstanceProperties");
+ this.btnEditInstanceProperties.Image = global::Maestro.Editors.Properties.Resources.document__pencil;
+ this.btnEditInstanceProperties.Name = "btnEditInstanceProperties";
+ this.btnEditInstanceProperties.Click += new System.EventHandler(this.btnEditInstanceProperties_Click);
// btnEditComponent
resources.ApplyResources(this.btnEditComponent, "btnEditComponent");
@@ -243,6 +253,7 @@
this.grdOverrides.AllowUserToDeleteRows = false;
this.grdOverrides.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
resources.ApplyResources(this.grdOverrides, "grdOverrides");
+ this.grdOverrides.EditMode = System.Windows.Forms.DataGridViewEditMode.EditOnEnter;
this.grdOverrides.Name = "grdOverrides";
this.grdOverrides.SelectionChanged += new System.EventHandler(this.grdOverrides_SelectionChanged);
@@ -279,11 +290,27 @@
// btnEditProperty
+ this.btnEditProperty.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.viaEditorToolStripMenuItem,
+ this.viaExpressionEditorToolStripMenuItem});
resources.ApplyResources(this.btnEditProperty, "btnEditProperty");
this.btnEditProperty.Image = global::Maestro.Editors.Properties.Resources.document__pencil;
this.btnEditProperty.Name = "btnEditProperty";
- this.btnEditProperty.Click += new System.EventHandler(this.btnEdit_Click);
+ // viaEditorToolStripMenuItem
+ this.viaEditorToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.application_form;
+ this.viaEditorToolStripMenuItem.Name = "viaEditorToolStripMenuItem";
+ resources.ApplyResources(this.viaEditorToolStripMenuItem, "viaEditorToolStripMenuItem");
+ this.viaEditorToolStripMenuItem.Click += new System.EventHandler(this.viaEditorToolStripMenuItem_Click);
+ // viaExpressionEditorToolStripMenuItem
+ this.viaExpressionEditorToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.sum;
+ this.viaExpressionEditorToolStripMenuItem.Name = "viaExpressionEditorToolStripMenuItem";
+ resources.ApplyResources(this.viaExpressionEditorToolStripMenuItem, "viaExpressionEditorToolStripMenuItem");
+ this.viaExpressionEditorToolStripMenuItem.Click += new System.EventHandler(this.viaExpressionEditorToolStripMenuItem_Click);
// btnDeleteProperty
resources.ApplyResources(this.btnDeleteProperty, "btnDeleteProperty");
@@ -325,13 +352,6 @@
this.symPreview.TabStop = false;
this.symPreview.Paint += new System.Windows.Forms.PaintEventHandler(this.previewPicture_Paint);
- // btnEditInstanceProperties
- resources.ApplyResources(this.btnEditInstanceProperties, "btnEditInstanceProperties");
- this.btnEditInstanceProperties.Name = "btnEditInstanceProperties";
- this.btnEditInstanceProperties.UseVisualStyleBackColor = true;
- this.btnEditInstanceProperties.Click += new System.EventHandler(this.btnEditInstanceProperties_Click);
// btnEditAsXml
resources.ApplyResources(this.btnEditAsXml, "btnEditAsXml");
@@ -347,7 +367,6 @@
this.Controls.Add(this.grpProperties);
this.Controls.Add(this.grpPreview);
this.Controls.Add(this.btnEditAsXml);
- this.Controls.Add(this.btnEditInstanceProperties);
this.Controls.Add(this.grpComponents);
this.Controls.Add(this.btnClose);
this.Name = "SymbolInstancesDialog";
@@ -380,7 +399,6 @@
private System.Windows.Forms.ImageList imgPreviews;
private System.Windows.Forms.GroupBox grpPreview;
private System.Windows.Forms.PictureBox symPreview;
- private System.Windows.Forms.Button btnEditInstanceProperties;
private System.Windows.Forms.Button btnEditAsXml;
private System.Windows.Forms.LinkLabel lnkRefresh;
private System.Windows.Forms.GroupBox grpProperties;
@@ -389,7 +407,6 @@
private System.Windows.Forms.ToolStripDropDownButton btnAddProperty;
private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
private System.Windows.Forms.ToolStripMenuItem refreshToolStripMenuItem;
- private System.Windows.Forms.ToolStripButton btnEditProperty;
private System.Windows.Forms.ToolStripButton btnDeleteProperty;
private System.Windows.Forms.ToolStripSeparator toolStripSeparator2;
private System.Windows.Forms.ToolStripButton btnEditComponent;
@@ -404,5 +421,9 @@
private System.Windows.Forms.ToolStripMenuItem textLabelLineToolStripMenuItem;
private System.Windows.Forms.ToolStripMenuItem textLabelPolygonToolStripMenuItem;
private System.Windows.Forms.ToolStripMenuItem pointToolStripMenuItem;
+ private System.Windows.Forms.ToolStripButton btnEditInstanceProperties;
+ private System.Windows.Forms.ToolStripDropDownButton btnEditProperty;
+ private System.Windows.Forms.ToolStripMenuItem viaEditorToolStripMenuItem;
+ private System.Windows.Forms.ToolStripMenuItem viaExpressionEditorToolStripMenuItem;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs 2014-05-27 07:43:52 UTC (rev 8171)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.cs 2014-05-27 11:53:02 UTC (rev 8172)
@@ -36,6 +36,9 @@
using Maestro.Shared.UI;
using Maestro.Editors.Preview;
using System.IO;
+using Maestro.Editors.LayerDefinition.Vector.Scales.SymbolParamEditors;
+using System.Globalization;
+using Maestro.Editors.Common;
namespace Maestro.Editors.LayerDefinition.Vector.Scales
@@ -57,10 +60,13 @@
private IParameterOverride _ov;
private IParameter _pdef;
+ private string _name;
public ParameterModel(IParameterOverride ov, IParameter pdef)
_ov = ov;
_pdef = pdef;
+ _name = pdef.DisplayName.Replace("&", "");
[Browsable(false)]
@@ -69,7 +75,7 @@
[Browsable(false)]
public IParameter Definition { get { return _pdef; } }
- public string Name { get { return _pdef.DisplayName; } }
+ public string Name { get { return _name; } }
public string Type { get { return _pdef.DataType; } }
@@ -430,7 +436,7 @@
foreach (var p in sym.GetParameters())
var param = p;
- var btn = new ToolStripButton(p.Name, null, (s, e) =>
+ var btn = new ToolStripButton(p.DisplayName.Replace("&", "&"), null, (s, e) =>
AddParameterOverride(symRef, sym, param);
@@ -462,7 +468,7 @@
_edSvc.HasChanged();
- private void btnEdit_Click(object sender, EventArgs e)
+ private void viaExpressionEditorToolStripMenuItem_Click(object sender, EventArgs e)
if (grdOverrides.SelectedRows.Count == 1)
@@ -476,6 +482,154 @@
+ private void viaEditorToolStripMenuItem_Click(object sender, EventArgs e)
+ if (grdOverrides.SelectedRows.Count == 1 && lstInstances.SelectedItems.Count == 1)
+ var it = lstInstances.SelectedItems[0];
+ ISymbolInstance symRef = (ISymbolInstance)it.Tag;
+ var ov = (ParameterModel)grdOverrides.SelectedRows[0].DataBoundItem;
+ Func<string> editAction = GetParameterEditorAction(ov.Type, ov.Value);
+ if (editAction != null)
+ string expr = editAction();
+ if (expr != null)
+ ov.Value = expr;
+ _edSvc.HasChanged();
+ else //Fallback to Expression Editor
+ string expr = _edSvc.EditExpression(ov.Value, _cls, _provider, _featureSourceId, true);
+ if (expr != null)
+ ov.Value = expr;
+ private Func<string> GetParameterEditorAction(string paramType, string currentValue)
+ DataType2 dt2;
+ if (Enum.TryParse(paramType, out dt2))
+ switch (dt2)
+ case DataType2.Boolean:
+ case DataType2.Bold:
+ case DataType2.Italic:
+ case DataType2.Overlined:
+ case DataType2.Underlined:
+ return () =>
+ using (var ed = new BooleanEditor())
+ bool b = default(bool);
+ bool.TryParse(currentValue, out b);
+ ed.SetDataType(dt2, b);
+ if (ed.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ return ed.Result ? "true" : "false"; //NOXLATE
+ return null;
+ case DataType2.Integer:
+ case DataType2.Real:
+ case DataType2.Angle:
+ case DataType2.EndOffset:
+ case DataType2.FontHeight:
+ case DataType2.LineSpacing:
+ case DataType2.LineWeight:
+ case DataType2.ObliqueAngle:
+ case DataType2.RepeatX:
+ case DataType2.RepeatY:
+ case DataType2.TrackSpacing:
+ case DataType2.StartOffset:
+ return () =>
+ using (var ed = new NumberEditor())
+ decimal d = default(decimal);
+ decimal.TryParse(currentValue, out d);
+ ed.SetDataType(dt2, d);
+ decimal result = ed.Value;
+ if (dt2 == DataType2.Integer)
+ return Convert.ToInt32(result).ToString(CultureInfo.InvariantCulture);
+ else
+ return Convert.ToDouble(result).ToString(CultureInfo.InvariantCulture);
+ return null;
+ case DataType2.Color:
+ case DataType2.FillColor:
+ case DataType2.FrameFillColor:
+ case DataType2.FrameLineColor:
+ case DataType2.GhostColor:
+ case DataType2.LineColor:
+ case DataType2.TextColor:
+ return () =>
+ using (var picker = new ColorPickerDialog())
+ try
+ picker.SelectedColor = Utility.ParseHTMLColorARGB((currentValue ?? "").Replace("0x", ""));
+ catch { }
+ if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ return "0x" + Utility.SerializeHTMLColorARGB(picker.SelectedColor, true);
+ return null;
+ case DataType2.Justification:
+ var values = Enum.GetValues(typeof(OSGeo.MapGuide.ObjectModels.SymbolDefinition.Justification));
+ return GetEnumPicker(dt2, values);
+ case DataType2.HorizontalAlignment:
+ var values = Enum.GetValues(typeof(OSGeo.MapGuide.ObjectModels.SymbolDefinition.HorizontalAlignment));
+ case DataType2.VerticalAlignment:
+ var values = Enum.GetValues(typeof(OSGeo.MapGuide.ObjectModels.SymbolDefinition.VerticalAlignment));
+ return null;
+ private Func<string> GetEnumPicker(DataType2 dt2, Array values)
+ return () =>
+ var list = new List<string>();
+ foreach (object val in values)
+ list.Add(val.ToString());
+ var item = Maestro.Editors.Common.GenericItemSelectionDialog.SelectItem(null, dt2.ToString(), list.ToArray());
+ if (item != null)
+ return "'" + item + "'";
+ return null;
private void btnDeleteProperty_Click(object sender, EventArgs e)
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx 2014-05-27 07:43:52 UTC (rev 8171)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolInstancesDialog.resx 2014-05-27 11:53:02 UTC (rev 8172)
@@ -123,7 +123,7 @@
</data>
<assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="btnClose.Location" type="System.Drawing.Point, System.Drawing">
- <value>355, 527</value>
+ <value>368, 527</value>
</data>
<data name="btnClose.Size" type="System.Drawing.Size, System.Drawing">
<value>75, 23</value>
@@ -145,7 +145,7 @@
<value>$this</value>
</data>
<data name=">>btnClose.ZOrder" xml:space="preserve">
- <value>5</value>
+ <value>4</value>
</data>
<data name="grpComponents.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Left, Right</value>
@@ -163,7 +163,7 @@
<value>3, 41</value>
</data>
<data name="lstInstances.Size" type="System.Drawing.Size, System.Drawing">
- <value>412, 82</value>
+ <value>425, 82</value>
</data>
<data name="lstInstances.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -267,6 +267,18 @@
<data name="toolStripSeparator2.Size" type="System.Drawing.Size, System.Drawing">
<value>6, 25</value>
</data>
+ <data name="btnEditInstanceProperties.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name="btnEditInstanceProperties.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="btnEditInstanceProperties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>150, 22</value>
+ </data>
+ <data name="btnEditInstanceProperties.Text" xml:space="preserve">
+ <value>Edit Instance Properties</value>
+ </data>
<data name="btnEditComponent.Enabled" type="System.Boolean, mscorlib">
</data>
@@ -274,16 +286,16 @@
</data>
<data name="btnEditComponent.Size" type="System.Drawing.Size, System.Drawing">
- <value>114, 22</value>
+ <value>90, 22</value>
</data>
<data name="btnEditComponent.Text" xml:space="preserve">
- <value>Edit Component</value>
+ <value>Edit Symbol</value>
</data>
<data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
<value>3, 16</value>
</data>
<data name="toolStrip1.Size" type="System.Drawing.Size, System.Drawing">
- <value>412, 25</value>
+ <value>425, 25</value>
</data>
<data name="toolStrip1.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -307,7 +319,7 @@
<value>12, 12</value>
</data>
<data name="grpComponents.Size" type="System.Drawing.Size, System.Drawing">
- <value>418, 126</value>
+ <value>431, 126</value>
</data>
<data name="grpComponents.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -325,62 +337,11 @@
</data>
<data name=">>grpComponents.ZOrder" xml:space="preserve">
- <value>4</value>
+ <value>3</value>
</data>
- <metadata name="toolStrip2.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>242, 17</value>
- </metadata>
<data name="grpProperties.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
</data>
- <data name=">>grdOverrides.Name" xml:space="preserve">
- <value>grdOverrides</value>
- </data>
- <data name=">>grdOverrides.Type" xml:space="preserve">
- <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>grdOverrides.Parent" xml:space="preserve">
- <value>grpProperties</value>
- </data>
- <data name=">>grdOverrides.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
- <data name=">>toolStrip2.Name" xml:space="preserve">
- <value>toolStrip2</value>
- </data>
- <data name=">>toolStrip2.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>toolStrip2.Parent" xml:space="preserve">
- </data>
- <data name=">>toolStrip2.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name="grpProperties.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 141</value>
- </data>
- <data name="grpProperties.Size" type="System.Drawing.Size, System.Drawing">
- <value>418, 305</value>
- </data>
- <data name="grpProperties.TabIndex" type="System.Int32, mscorlib">
- <value>2</value>
- </data>
- <data name="grpProperties.Text" xml:space="preserve">
- <value>Symbolization Component Properties</value>
- </data>
- <data name=">>grpProperties.Name" xml:space="preserve">
- </data>
- <data name=">>grpProperties.Type" xml:space="preserve">
- <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>grpProperties.Parent" xml:space="preserve">
- <value>$this</value>
- </data>
- <data name=">>grpProperties.ZOrder" xml:space="preserve">
- <value>0</value>
- </data>
<data name="grdOverrides.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
@@ -388,7 +349,7 @@
</data>
<data name="grdOverrides.Size" type="System.Drawing.Size, System.Drawing">
- <value>412, 261</value>
+ <value>425, 261</value>
</data>
<data name="grdOverrides.TabIndex" type="System.Int32, mscorlib">
<value>1</value>
@@ -408,30 +369,15 @@
</metadata>
- <data name="toolStrip2.Location" type="System.Drawing.Point, System.Drawing">
- <value>3, 16</value>
+ <data name="toolStripSeparator1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>110, 6</value>
</data>
- <data name="toolStrip2.Size" type="System.Drawing.Size, System.Drawing">
+ <data name="refreshToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+ <value>113, 22</value>
</data>
- <data name="toolStrip2.TabIndex" type="System.Int32, mscorlib">
- <value>0</value>
+ <data name="refreshToolStripMenuItem.Text" xml:space="preserve">
+ <value>Refresh</value>
</data>
- <data name="toolStrip2.Text" xml:space="preserve">
- </data>
- </data>
- </data>
- </data>
- <value>1</value>
- </data>
<data name="btnAddProperty.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
</data>
@@ -441,15 +387,18 @@
<data name="btnAddProperty.Text" xml:space="preserve">
<value>Add</value>
</data>
- <data name="toolStripSeparator1.Size" type="System.Drawing.Size, System.Drawing">
- <value>110, 6</value>
+ <data name="viaEditorToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+ <value>181, 22</value>
</data>
- <data name="refreshToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
- <value>113, 22</value>
+ <data name="viaEditorToolStripMenuItem.Text" xml:space="preserve">
+ <value>via Editor</value>
</data>
- <data name="refreshToolStripMenuItem.Text" xml:space="preserve">
- <value>Refresh</value>
+ <data name="viaExpressionEditorToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
</data>
+ <data name="viaExpressionEditorToolStripMenuItem.Text" xml:space="preserve">
+ <value>via Expression Editor</value>
+ </data>
<data name="btnEditProperty.Enabled" type="System.Boolean, mscorlib">
</data>
@@ -457,7 +406,7 @@
</data>
<data name="btnEditProperty.Size" type="System.Drawing.Size, System.Drawing">
- <value>79, 22</value>
+ <value>88, 22</value>
</data>
<data name="btnEditProperty.Text" xml:space="preserve">
<value>Edit Value</value>
@@ -489,57 +438,57 @@
<data name="btnPropertyInfo.Text" xml:space="preserve">
<value>Property Info</value>
</data>
- <data name="grpPreview.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
- <value>Bottom, Left, Right</value>
+ <data name="toolStrip2.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 16</value>
</data>
- <data name=">>lnkRefresh.Name" xml:space="preserve">
- <value>lnkRefresh</value>
+ <data name="toolStrip2.Size" type="System.Drawing.Size, System.Drawing">
</data>
- <data name=">>lnkRefresh.Type" xml:space="preserve">
- <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>lnkRefresh.Parent" xml:space="preserve">
- <value>grpPreview</value>
- </data>
- <data name=">>lnkRefresh.ZOrder" xml:space="preserve">
+ <data name="toolStrip2.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
</data>
- <data name=">>symPreview.Name" xml:space="preserve">
- <value>symPreview</value>
+ <data name="toolStrip2.Text" xml:space="preserve">
+ <value>toolStrip2</value>
</data>
- <data name=">>symPreview.Type" xml:space="preserve">
- <value>System.Windows.Forms.PictureBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <data name=">>toolStrip2.Name" xml:space="preserve">
</data>
- <data name=">>symPreview.Parent" xml:space="preserve">
+ <data name=">>toolStrip2.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>symPreview.ZOrder" xml:space="preserve">
+ <data name=">>toolStrip2.Parent" xml:space="preserve">
+ <value>grpProperties</value>
+ </data>
+ <data name=">>toolStrip2.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <data name="grpPreview.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 452</value>
+ <data name="grpProperties.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 141</value>
</data>
- <data name="grpPreview.Size" type="System.Drawing.Size, System.Drawing">
- <value>418, 69</value>
+ <data name="grpProperties.Size" type="System.Drawing.Size, System.Drawing">
+ <value>431, 305</value>
</data>
- <data name="grpPreview.TabIndex" type="System.Int32, mscorlib">
- <value>1</value>
+ <data name="grpProperties.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
</data>
- <data name="grpPreview.Text" xml:space="preserve">
- <value>Preview</value>
+ <data name="grpProperties.Text" xml:space="preserve">
+ <value>Symbolization Component Properties</value>
</data>
- <data name=">>grpPreview.Name" xml:space="preserve">
+ <data name=">>grpProperties.Name" xml:space="preserve">
</data>
- <data name=">>grpPreview.Type" xml:space="preserve">
+ <data name=">>grpProperties.Type" xml:space="preserve">
</data>
- <data name=">>grpPreview.Parent" xml:space="preserve">
+ <data name=">>grpProperties.Parent" xml:space="preserve">
</data>
- <data name=">>grpPreview.ZOrder" xml:space="preserve">
- <value>1</value>
+ <data name=">>grpProperties.ZOrder" xml:space="preserve">
+ <value>0</value>
</data>
+ <data name="grpPreview.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Left, Right</value>
+ </data>
<data name="lnkRefresh.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -574,7 +523,7 @@
<value>19, 19</value>
</data>
<data name="symPreview.Size" type="System.Drawing.Size, System.Drawing">
- <value>380, 36</value>
+ <value>393, 36</value>
</data>
<data name="symPreview.TabIndex" type="System.Int32, mscorlib">
<value>0</value>
@@ -591,35 +540,32 @@
<value>1</value>
</data>
- <data name="btnEditInstanceProperties.Enabled" type="System.Boolean, mscorlib">
- <value>False</value>
+ <data name="grpPreview.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 452</value>
</data>
- <data name="btnEditInstanceProperties.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 527</value>
+ <data name="grpPreview.Size" type="System.Drawing.Size, System.Drawing">
+ <value>431, 69</value>
</data>
- <data name="btnEditInstanceProperties.Size" type="System.Drawing.Size, System.Drawing">
- <value>138, 23</value>
+ <data name="grpPreview.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
</data>
- <data name="btnEditInstanceProperties.TabIndex" type="System.Int32, mscorlib">
- <value>3</value>
+ <data name="grpPreview.Text" xml:space="preserve">
+ <value>Preview</value>
</data>
- <data name="btnEditInstanceProperties.Text" xml:space="preserve">
- <value>Edit Instance Properties</value>
+ <data name=">>grpPreview.Name" xml:space="preserve">
+ <value>grpPreview</value>
</data>
- <data name=">>btnEditInstanceProperties.Name" xml:space="preserve">
- <value>btnEditInstanceProperties</value>
+ <data name=">>grpPreview.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>btnEditInstanceProperties.Type" xml:space="preserve">
- <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>btnEditInstanceProperties.Parent" xml:space="preserve">
+ <data name=">>grpPreview.Parent" xml:space="preserve">
</data>
- <data name=">>btnEditInstanceProperties.ZOrder" xml:space="preserve">
- <value>3</value>
+ <data name=">>grpPreview.ZOrder" xml:space="preserve">
+ <value>1</value>
</data>
<data name="btnEditAsXml.Location" type="System.Drawing.Point, System.Drawing">
- <value>156, 527</value>
+ <value>12, 527</value>
</data>
<data name="btnEditAsXml.Size" type="System.Drawing.Size, System.Drawing">
<value>87, 23</value>
@@ -646,7 +592,7 @@
<value>True</value>
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
- <value>442, 562</value>
+ <value>455, 562</value>
</data>
<data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
<value>CenterParent</value>
@@ -696,16 +642,10 @@
<data name=">>lineToolStripMenuItem.Type" xml:space="preserve">
<value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
- <data name=">>toolStripSeparator4.Name" xml:space="preserve">
- <value>toolStripSeparator4</value>
+ <data name=">>pointToolStripMenuItem.Name" xml:space="preserve">
+ <value>pointToolStripMenuItem</value>
</data>
- <data name=">>toolStripSeparator4.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>inlineSimpleSymbolToolStripMenuItem.Name" xml:space="preserve">
- <value>inlineSimpleSymbolToolStripMenuItem</value>
- </data>
- <data name=">>inlineSimpleSymbolToolStripMenuItem.Type" xml:space="preserve">
+ <data name=">>pointToolStripMenuItem.Type" xml:space="preserve">
</data>
<data name=">>textLabelPointToolStripMenuItem.Name" xml:space="preserve">
@@ -726,10 +666,16 @@
<data name=">>textLabelPolygonToolStripMenuItem.Type" xml:space="preserve">
</data>
- <data name=">>pointToolStripMenuItem.Name" xml:space="preserve">
- <value>pointToolStripMenuItem</value>
+ <data name=">>toolStripSeparator4.Name" xml:space="preserve">
+ <value>toolStripSeparator4</value>
</data>
- <data name=">>pointToolStripMenuItem.Type" xml:space="preserve">
+ <data name=">>toolStripSeparator4.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>inlineSimpleSymbolToolStripMenuItem.Name" xml:space="preserve">
+ <value>inlineSimpleSymbolToolStripMenuItem</value>
+ </data>
+ <data name=">>inlineSimpleSymbolToolStripMenuItem.Type" xml:space="preserve">
</data>
<data name=">>btnDelete.Name" xml:space="preserve">
@@ -744,6 +690,12 @@
<data name=">>toolStripSeparator2.Type" xml:space="preserve">
</data>
+ <data name=">>btnEditInstanceProperties.Name" xml:space="preserve">
+ <value>btnEditInstanceProperties</value>
+ </data>
+ <data name=">>btnEditInstanceProperties.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
<data name=">>btnEditComponent.Name" xml:space="preserve">
<value>btnEditComponent</value>
</data>
@@ -772,8 +724,20 @@
<value>btnEditProperty</value>
</data>
<data name=">>btnEditProperty.Type" xml:space="preserve">
- <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.ToolStripDropDownButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
+ <data name=">>viaEditorToolStripMenuItem.Name" xml:space="preserve">
+ <value>viaEditorToolStripMenuItem</value>
+ </data>
+ <data name=">>viaEditorToolStripMenuItem.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>viaExpressionEditorToolStripMenuItem.Name" xml:space="preserve">
+ <value>viaExpressionEditorToolStripMenuItem</value>
+ </data>
+ <data name=">>viaExpressionEditorToolStripMenuItem.Type" xml:space="preserve">
+ </data>
<data name=">>btnDeleteProperty.Name" xml:space="preserve">
<value>btnDeleteProperty</value>
</data>
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.Designer.cs 2014-05-27 11:53:02 UTC (rev 8172)
@@ -0,0 +1,94 @@
+namespace Maestro.Editors.LayerDefinition.Vector.Scales.SymbolParamEditors
+ partial class BooleanEditor
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(BooleanEditor));
+ this.rdTrue = new System.Windows.Forms.RadioButton();
+ this.rdFalse = new System.Windows.Forms.RadioButton();
+ this.btnOK = new System.Windows.Forms.Button();
+ this.btnCancel = new System.Windows.Forms.Button();
+ this.SuspendLayout();
+ // rdTrue
+ resources.ApplyResources(this.rdTrue, "rdTrue");
+ this.rdTrue.Checked = true;
+ this.rdTrue.Name = "rdTrue";
+ this.rdTrue.TabStop = true;
+ this.rdTrue.UseVisualStyleBackColor = true;
+ this.rdTrue.CheckedChanged += new System.EventHandler(this.rdTrue_CheckedChanged);
+ // rdFalse
+ resources.ApplyResources(this.rdFalse, "rdFalse");
+ this.rdFalse.Name = "rdFalse";
+ this.rdFalse.UseVisualStyleBackColor = true;
+ this.rdFalse.CheckedChanged += new System.EventHandler(this.rdFalse_CheckedChanged);
+ // btnOK
+ resources.ApplyResources(this.btnOK, "btnOK");
+ this.btnOK.Name = "btnOK";
+ this.btnOK.UseVisualStyleBackColor = true;
+ this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+ // btnCancel
+ this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ resources.ApplyResources(this.btnCancel, "btnCancel");
+ this.btnCancel.Name = "btnCancel";
+ this.btnCancel.UseVisualStyleBackColor = true;
+ this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+ // BooleanEditor
+ this.AcceptButton = this.btnOK;
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ this.CancelButton = this.btnCancel;
+ resources.ApplyResources(this, "$this");
+ this.ControlBox = false;
+ this.Controls.Add(this.btnCancel);
+ this.Controls.Add(this.btnOK);
+ this.Controls.Add(this.rdFalse);
+ this.Controls.Add(this.rdTrue);
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog;
+ this.Name = "BooleanEditor";
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.RadioButton rdTrue;
+ private System.Windows.Forms.RadioButton rdFalse;
+ private System.Windows.Forms.Button btnOK;
+ private System.Windows.Forms.Button btnCancel;
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.cs 2014-05-27 11:53:02 UTC (rev 8172)
@@ -0,0 +1,88 @@
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using OSGeo.MapGuide.ObjectModels.SymbolDefinition;
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+ internal partial class BooleanEditor : Form
+ public BooleanEditor()
+ InitializeComponent();
+ public void SetDataType(DataType2 dt2, bool value)
+ this.Text = dt2.ToString();
+ if (value)
+ rdTrue.Checked = true;
+ else
+ rdFalse.Checked = true;
+ protected override void OnLoad(EventArgs e)
+ UpdateResult();
+ base.OnLoad(e);
+ public bool Result
+ get;
+ private set;
+ private void UpdateResult()
+ if (rdTrue.Checked)
+ this.Result = true;
+ else if (rdFalse.Checked)
+ this.Result = false;
+ private void rdTrue_CheckedChanged(object sender, EventArgs e)
+ UpdateResult();
+ private void rdFalse_CheckedChanged(object sender, EventArgs e)
+ UpdateResult();
+ private void btnOK_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
+ private void btnCancel_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/BooleanEditor.resx 2014-05-27 11:53:02 UTC (rev 8172)
@@ -0,0 +1,243 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="rdTrue.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="rdTrue.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 12</value>
+ </data>
+ <data name="rdTrue.Size" type="System.Drawing.Size, System.Drawing">
+ <value>43, 17</value>
+ </data>
+ <data name="rdTrue.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="rdTrue.Text" xml:space="preserve">
+ <value>true</value>
+ </data>
+ <data name=">>rdTrue.Name" xml:space="preserve">
+ <value>rdTrue</value>
+ </data>
+ <data name=">>rdTrue.Type" xml:space="preserve">
+ <value>System.Windows.Forms.RadioButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>rdTrue.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>rdTrue.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="rdFalse.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="rdFalse.Location" type="System.Drawing.Point, System.Drawing">
+ <value>61, 12</value>
+ </data>
+ <data name="rdFalse.Size" type="System.Drawing.Size, System.Drawing">
+ <value>47, 17</value>
+ </data>
+ <data name="rdFalse.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="rdFalse.Text" xml:space="preserve">
+ <value>false</value>
+ </data>
+ <data name=">>rdFalse.Name" xml:space="preserve">
+ <value>rdFalse</value>
+ </data>
+ <data name=">>rdFalse.Type" xml:space="preserve">
+ </data>
+ <data name=">>rdFalse.Parent" xml:space="preserve">
+ </data>
+ <data name=">>rdFalse.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="btnOK.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 51</value>
+ </data>
+ <data name="btnOK.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnOK.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="btnOK.Text" xml:space="preserve">
+ <value>OK</value>
+ </data>
+ <data name=">>btnOK.Name" xml:space="preserve">
+ <value>btnOK</value>
+ </data>
+ <data name=">>btnOK.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnOK.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnOK.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
+ <value>91, 51</value>
+ </data>
+ <data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnCancel.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="btnCancel.Text" xml:space="preserve">
+ <value>Cancel</value>
+ </data>
+ <data name=">>btnCancel.Name" xml:space="preserve">
+ <value>btnCancel</value>
+ </data>
+ <data name=">>btnCancel.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnCancel.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>178, 86</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Boolean Editor</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>BooleanEditor</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.Designer.cs 2014-05-27 11:53:02 UTC (rev 8172)
@@ -0,0 +1,90 @@
+ partial class NumberEditor
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(NumberEditor));
+ this.numericUpDown = new System.Windows.Forms.NumericUpDown();
+ this.label1 = new System.Windows.Forms.Label();
+ ((System.ComponentModel.ISupportInitialize)(this.numericUpDown)).BeginInit();
+ // numericUpDown1
+ resources.ApplyResources(this.numericUpDown, "numericUpDown1");
+ this.numericUpDown.Name = "numericUpDown1";
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // btnCancel
+ // btnOK
+ // NumberEditor
+ this.Controls.Add(this.label1);
+ this.Controls.Add(this.numericUpDown);
+ this.Name = "NumberEditor";
+ ((System.ComponentModel.ISupportInitialize)(this.numericUpDown)).EndInit();
+ #endregion
+ private System.Windows.Forms.NumericUpDown numericUpDown;
+ private System.Windows.Forms.Label label1;
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.cs 2014-05-27 11:53:02 UTC (rev 8172)
@@ -0,0 +1,92 @@
+#endregion
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+ public partial class NumberEditor : Form
+ public NumberEditor()
+ public void SetDataType(DataType2 dt, decimal value)
+ switch (dt)
+ numericUpDown.Minimum = int.MinValue;
+ numericUpDown.Maximum = int.MaxValue;
+ numericUpDown.Value = value;
+ this.Text = dt.ToString();
+ break;
+ numericUpDown.Minimum = decimal.MinValue;
+ numericUpDown.Maximum = decimal.MaxValue;
+ break;
+ numericUpDown.Minimum = Convert.ToDecimal(0.0);
+ numericUpDown.Maximum = Convert.ToDecimal(360.0);
+ break;
+ numericUpDown.Minimum = Convert.ToDecimal(-85.0);
+ numericUpDown.Maximum = Convert.ToDecimal(85.0);
+ break;
+ numericUpDown.Minimum = Convert.ToDecimal(0.75);
+ numericUpDown.Maximum = Convert.ToDecimal(10.0);
+ break;
+ public decimal Value
+ get { return numericUpDown.Value; }
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/SymbolParamEditors/NumberEditor.resx 2014-05-27 11:53:02 UTC (rev 8172)
@@ -0,0 +1,243 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="numericUpDown1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>55, 12</value>
+ </data>
+ <data name="numericUpDown1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>154, 20</value>
+ </data>
+ <data name="numericUpDown1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>numericUpDown1.Name" xml:space="preserve">
+ <value>numericUpDown1</value>
+ </data>
+ <data name=">>numericUpDown1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.NumericUpDown, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>numericUpDown1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>numericUpDown1.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ </data>
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 14</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>34, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Value</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="btnCancel.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ <value>NoControl</value>
+ </data>
+ <value>134, 46</value>
+ </data>
+ </data>
+ <value>5</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>0</value>
+ </data>
+ <data name="btnOK.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+ </data>
+ <value>55, 46</value>
+ </data>
+ </data>
+ <value>4</value>
+ </data>
+ <value>OK</value>
+ </data>
+ </data>
+ </data>
+ </data>
+ <value>1</value>
+ </data>
+ </metadata>
+ <value>221, 81</value>
+ </data>
+ </data>
+ <value>Number Editor</value>
+ </data>
+ <value>NumberEditor</value>
+ </data>
+ </data>
+</root>
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2014-05-27 07:43:52 UTC (rev 8171)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2014-05-27 11:53:02 UTC (rev 8172)
@@ -759,6 +759,18 @@
<Compile Include="LayerDefinition\Vector\Scales\SymbolInstancesDialog.Designer.cs">
<DependentUpon>SymbolInstancesDialog.cs</DependentUpon>
</Compile>
+ <Compile Include="LayerDefinition\Vector\Scales\SymbolParamEditors\BooleanEditor.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="LayerDefinition\Vector\Scales\SymbolParamEditors\BooleanEditor.Designer.cs">
+ <DependentUpon>BooleanEditor.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LayerDefinition\Vector\Scales\SymbolParamEditors\NumberEditor.cs">
+ </Compile>
+ <Compile Include="LayerDefinition\Vector\Scales\SymbolParamEditors\NumberEditor.Designer.cs">
+ <DependentUpon>NumberEditor.cs</DependentUpon>
+ </Compile>
<Compile Include="LayerDefinition\Vector\Scales\VectorScaleRangeCtrl.cs">
<SubType>UserControl</SubType>
</Compile>
@@ -1645,6 +1657,12 @@
<EmbeddedResource Include="LayerDefinition\Vector\Scales\SymbolInstancesDialog.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="LayerDefinition\Vector\Scales\SymbolParamEditors\BooleanEditor.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="LayerDefinition\Vector\Scales\SymbolParamEditors\NumberEditor.resx">
<EmbeddedResource Include="LayerDefinition\Vector\Scales\VectorScaleRangeCtrl.resx">
<DependentUpon>VectorScaleRangeCtrl.cs</DependentUpon>
</EmbeddedResource>
@@ -2394,6 +2412,7 @@
<Content Include="OdbcDriverMap.xml">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <None Include="Resources\application-form.png" />
<None Include="Resources\layer-small.png" />
<None Include="Resources\layer-select.png" />
<None Include="Resources\layer-shape.png" />
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2014-05-27 07:43:52 UTC (rev 8171)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.Designer.cs 2014-05-27 11:53:02 UTC (rev 8172)
@@ -113,6 +113,16 @@
/// <summary>
/// Looks up a localized resource of type System.Drawing.Bitmap.
/// </summary>
+ internal static System.Drawing.Bitmap application_form {
+ get {
+ object obj = ResourceManager.GetObject("application-form", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
+ /// <summary>
+ /// Looks up a localized resource of type System.Drawing.Bitmap.
+ /// </summary>
internal static System.Drawing.Bitmap application_import {
get {
object obj = ResourceManager.GetObject("application-import", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2014-05-27 07:43:52 UTC (rev 8171)
+++ trunk/Tools/Maestro/Maestro.Editors/Properties/Resources.resx 2014-05-27 11:53:02 UTC (rev 8172)
@@ -269,26 +269,15 @@
meT8RJx9c/QXPR3oL5YnjaBUK8UhAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_plotdwf_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="function" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIecAP7+/rW6x9PW48TD1uHg6ba6x////8HBxMTFyMC/wrK+y/r6+v39/cTD173JyMLG
- 0fT09/P09d3d5qGprPX3+MPFxtXW2dLT1vj4+JOjqcXFxujo6OLk5+Dl58TFyba7x8fIy7a6xuDi4+Li
- 4drb3cHG0Onp6cLP29vb3u7w8ODg6LG2utjc4IeSk+Tx6dTr5dLV4urq6palqp2ho6ezwL69vrTBz8TD
- 1ebu9rvI1Lq+vKSvvdzm89XY3r+/wtLV2PX3+dTX3tHQ3Ymbj+Lk6b/KxOvt8PD1+bS5xvz9/aGvvPX3
- 98LOzLa6yJ+suuvr66CsurzKyM7Q0OHf6NHT1uzu8sTGyb3KyMrKztLX5M3L2b2+wdbY3O3u8sTGyODg
- 6cbIyNrb4Le9v8rLzrq+y5GunKvMuNna3eHi5fDx8qayu7u7vpShq/Py9fX19ZKop8LU2Jmps+nq67TN
- x5eosPn6++/1+bO/zKCsu/T398XR36Goqp+rutbX2r/AwdHe6tPW5O3v787M2sfL1fz8/K22v/X199ze
- 4t3c5rW6xr/Dz/n5+c7Q0cnKzdze5MTGyoaSiJenndPW4o+ul+Df6MDAxL3BzcHDxcvX1Jyws8XD142g
- lv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACcACwAAAAAEAAQAAAI8QA5CRwoEJODKHcUMElBcOCCQA5c
- 2OFx4k0GDAMNCRkw4MqLIzj+5NgEaQUnQVoGAACwqMMcM3D0KJDRYganBitXMoBQZFKZTDTwsNlz8wkA
- AwAYAOAQaQgdJTvUiBGoKacBFQR0TIhTyIYTNwNvACBA4EsYDzU08IEih2AASlO4gNjiBwaYNX0GEioR
- 4MClClIESKKQ5wKZgQWojAEkQoCAJUDONDoQADGAQxayAEBBAkGCEAESDQzAAkAVNF6sPEIgIc0GLKN7
- dEnwIwAjRBGSmBBgaSCRD0Yq+QjQpE4MRUHaNFzwAEkBTiMGOWrIKSAAOw==
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABC0lEQVQ4T6XSPUpDQRiF4bkh
+ IsEgwb+gawg2pomFhUUs0gcLtbQSGwsrN5BKF2Bnp1gJAS0EUUil2LmFrOLmPZPvhmGYW5gMPJlvDsPJ
+ zY/L83whLsuylD6ejObUndKCNp5xiJbNqXulBed4xHqQJZUV3OIuypLiggGGkd1gPoHuNYtz6gk6eLNd
+ 5zPbj6Fc38sDukh+hEu8YjPIZB/vZpanCu5NnPfwCf1Cszwu0Lt+4CrIRP+DkTmyzIsLDvBtu9Niv7ZM
+ s/bTYJ4WBOsGv2j6k3MX+JuOfhVn6SkICzr4wos/la+68asoGJsf7GEDa2hgFSuoYRlLqKKCrCjYwTb0
+ 6Fv4X4Fe5pe7CSINtCR/xwMpAAAAAElFTkSuQmCC
</value>
</data>
<data name="icon_maptip_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -338,18 +327,6 @@
AElFTkSuQmCC
</value>
</data>
- <data name="icon_viewoptions_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIUAAAAAAP////39/vv7/Pr6+/n5+vj4+fb299DR1M/Q0+bn6eXm6OPk5n6Ejs3P0oyT
- nM7T2bG3vs/R087Q0vf4+fb3+PX29/T19vP09ebn6OXm5+Tl5uPl5vb4+PT29v3+/vz9/fr7+/n6+vj5
- +ff4+Pb3987Uz8/W0M7Vz4qgitHX0dDW0OLm4uTn5P7+/v39/fz8/Pv7+////wAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAyACwAAAAAEAAQ
- AAAItgBlCBxIsKCMCAgTKlyIEILDhxAhNojwoKLFixcnBgjgwsWHFzBCwhgQIkQBjR0/hhzAsqSIERNT
- tkgxsmQIAi9hRnCRYuaKAQgkCJWQYASJiQJUpPgZQ0GGpws0kOgwEeTPmwVGaB1BoUOFiSBGskiR1YDZ
- rhUsTISRYiyKERPiTnBQwoKHiQNOpHg7YgOHvwzsXpgYg4AJrRQqKE7r4cLgCASycu1wwILlxhcwTGzA
- ubPnzwEBADs=
-</value>
- </data>
<data name="icon_measure" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIQSAHFCCr2NKldCE9ajLmddJf7nWp3M3BJEd005EQGM5AGK4wGN4QEzZgGK5QE1ZwI0
@@ -374,18 +351,6 @@
GETC8uhhg6Fz5zOq2pgREAA7
</value>
</data>
- <data name="icon_invokescript" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIU6AEtypf///9bn92+wPq3D3hExZKq+r3ugdmupO1WHSD14K7fH3Jiymb7M37HMxlmP
- RFeLTVyTSVuQRY/SS6DfUZjYTl6fN1iORJ6xxny6Qn+og4jHR5vbTzJpMpvbUIjGR3Gad4/RS4nISHvB
- RIrOSXCzP5/eUaDeUJ7dUJPVTYfKSIbLSIDGRnWPsoLHR2WkOT95LD11Pp3cUJPVTIPCRZ6+rIPDRWak
- OZfYTnGzQAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA6ACwAAAAAEAAQ
- AAAIuAB1CNSBAYDBgwgxDNRhsEGAhxADNACwEMBEARgzYqQ4EEAAhCA5CvRIoKRJAgUWGjgQAwYEDQ4y
- ohzIQAKCATJEIIhQA+NMHQYkZBgQYAAFChkixPx5AMEJokVRmECgQcDPBB84QC3qYQMEqyl1KKiAY2vR
- CgoItAibgEaKrSFm2OhQoMACgQdeTICqgsSEGyAW3BVo4MEAoixcrBjwwMBCgQwuWMgxooSFCwweD1yZ
- QEGCA441BwQAOw==
-</value>
- </data>
<data name="database_share" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -448,17 +413,26 @@
kjRK4GmAAQ01mgxQ1SpWjA8jFuAK4edPhgQNHghQdoDbrxcF/oQbl+HVunjrBgQAOw==
</value>
</data>
- <data name="edit-indent" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_plotdwf_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABdklEQVQ4T5XS3ytDYRgH8Gc3
- bmdc2HYj2hQNs7RNoya2KTI/brCylpJbJbldUvwT7rjasF8k4viRH1Fyw5XIjaRcu3t9n7ft2I4dy1uf
- Oud9nvf7vKcOCSHIYDCwOCQgmbcF27ADKUhDFnKwBvJsccC/aQMqTaXOwJLk6lskZ++C/g24odBcMLv6
- qZpZ+aBo/O0noN4Zk+zuOVmILb8raBJ6uF4S0D19Inmnjig8/8DE6d2XLq5znxrgnjhkwjGc9nsmD6kr
- cqzwux6u80A1wB5KsBcQ/Nwa3qPmwfQvLUNZco7tyoElAbZgionG/oTfHsogLKPwuxbv20M5ahvZp47x
- g+Ib5KSmgRy1j16xst/O+/m6pAbU2iJStdlLjuAmrves9ERfhRbvOwIbZKzzEC81QPsfmKw+anAt/GKy
- +OTBwtIGKHACZ3AOF3AJ13ADt3CPc4/wVC6gIu1SA7CMaFgHvalJsOZZoAaqSgLADIWmvxQFCPoGzyRS
- PHSKlsAAAAAASUVORK5CYII=
+ R0lGODlhEAAQAIecAP7+/rW6x9PW48TD1uHg6ba6x////8HBxMTFyMC/wrK+y/r6+v39/cTD173JyMLG
+ 0fT09/P09d3d5qGprPX3+MPFxtXW2dLT1vj4+JOjqcXFxujo6OLk5+Dl58TFyba7x8fIy7a6xuDi4+Li
+ 4drb3cHG0Onp6cLP29vb3u7w8ODg6LG2utjc4IeSk+Tx6dTr5dLV4urq6palqp2ho6ezwL69vrTBz8TD
+ 1ebu9rvI1Lq+vKSvvdzm89XY3r+/wtLV2PX3+dTX3tHQ3Ymbj+Lk6b/KxOvt8PD1+bS5xvz9/aGvvPX3
+ 98LOzLa6yJ+suuvr66CsurzKyM7Q0OHf6NHT1uzu8sTGyb3KyMrKztLX5M3L2b2+wdbY3O3u8sTGyODg
+ 6cbIyNrb4Le9v8rLzrq+y5GunKvMuNna3eHi5fDx8qayu7u7vpShq/Py9fX19ZKop8LU2Jmps+nq67TN
+ x5eosPn6++/1+bO/zKCsu/T398XR36Goqp+rutbX2r/AwdHe6tPW5O3v787M2sfL1fz8/K22v/X199ze
+ 4t3c5rW6xr/Dz/n5+c7Q0cnKzdze5MTGyoaSiJenndPW4o+ul+Df6MDAxL3BzcHDxcvX1Jyws8XD142g
+ lv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAACcACwAAAAAEAAQAAAI8QA5CRwoEJODKHcUMElBcOCCQA5c
+ 2OFx4k0GDAMNCRkw4MqLIzj+5NgEaQUnQVoGAACwqMMcM3D0KJDRYganBitXMoBQZFKZTDTwsNlz8wkA
+ AwAYAOAQaQgdJTvUiBGoKacBFQR0TIhTyIYTNwNvACBA4EsYDzU08IEih2AASlO4gNjiBwaYNX0GEioR
+ 4MClClIESKKQ5wKZgQWojAEkQoCAJUDONDoQADGAQxayAEBBAkGCEAESDQzAAkAVNF6sPEIgIc0GLKN7
+ dEnwIwAjRBGSmBBgaSCRD0Yq+QjQpE4MRUHaNFzwAEkBTiMGOWrIKSAAOw==
</value>
</data>
<data name="gear--exclamation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -651,13 +625,6 @@
Ko4oag7oFQZF2z9oURxU7AxAbAPgy//sQfE9hAAAAABJRU5ErkJggg==
</value>
</data>
- <data name="icon_null" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIECANji87HH6f///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAACACwAAAAAEAAQ
- AAAIRAAFCBxIsKDBgwYDKFzIUCHBAAAiSpwY4OHEiwAqDoSIUaJGgRw7ZrQocuTGkiZBovwoIGRHli4x
- wlz5sKFNhDhzHgwIADs=
-</value>
- </data>
<data name="globe--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -737,6 +704,51 @@
XK5X/wO08BBR8wku3Xk930xtLAAAAABJRU5ErkJggg==
</value>
</data>
+ <data name="layers-stack-arrange-back" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC2klEQVQ4T4WQe0hTURzHzz/9
+ Jf0TFf3RA5KeSGFG0D8VZBGEJEh/ZEj5wgoxMR8Y9oAeGFSU5EBrganMudbcnM5NbZtzd65N5+Zybne7
+ 2+5ed083txVCcDpnlgyR+sGHw73n++B3wKHi16CgZTxDxdMQqHwWLql6HqEQ8D9QWLtuxpxpJUBpG00J
+ VfFlVzgtc4ZSY5uB77AGa7MD9iKuFDboYKfUbmofWprejLcjNoXEwAioYEpadNcM1wNONMuK5ebQ0AjB
+ QGcoHbIHkr6NOJiUX70UoV+KluQ2f1J8tnw6E5BpRgEs3NzYPQ9ZUkesY5QMZtM94WBkxiBtQ0GPuGbV
+ d09iOL9kFK436+xRM27WWiIQtf1EDem/kIHkD/VSONU5Zg8gI93ab1QaXXHhwUt8CPKbpGV4H/GsX2Ny
+ J7ySb344Ry2n9Y7YSjZW30r6hcASQEa6sceg1DuWBfsLeRAcvye5gfcRaL0EMtIiwge1ZCylsUUT2SzQ
+ idQTntmPwlx1bL0C/ePnXhBCcKxhtBzvw1W7CS0ZpfkqL5xaDCfHTcFliSEQE88GosOz/qjKEkk84Jj8
+ hDXqvNWlVUxZwvwjlychyKsXV+J9PimoaeVi2MmWuKFQ54t/nvFGsvlqDsVbeud9SENVvNMo0fklv0QP
+ wdE6UTXep2PUqkRGG2vYtdor9/ziaTzxQQyxxsRCMNnSawihZm89W2fo4DKR09dJChyuHapBaQOPuaZJ
+ /oyX/DDudnYI3atvBDTMhiNnYGm7AXaJQvBk9Rw8V+Fz5Z1nl4EDt/l3xuaZvocDRtnHSQfFJTwkR03b
+ NoLehMbN7AlSvPtmXxUAYBciB+TW8GplRob7SmTpud83J2/u0RNNWeBvTLfMurCnvF+8/SqrfuupGwVb
+ tu1DfjQ47b3MKpIamcGRuQBnM/Ad1vxpzkXkZMx4cBpO3XGN3fYvsCYnr+gisuxcc+IB4DeW/K1D9pQD
+ QwAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="sort-number" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABsUlEQVQ4T42TS0sCARSFJwMJ
+ QWoXCFJEtAhqE/4EN4E7V+rGELWmDJRwREH3bgV/hAu3bvwF4kaC1iIIvvCFIr5u99xyGIcChY/7OucM
+ w6CiaZqSSqX2yGQySjabvWbCqJjNGviISPkvAKYICwgVs1mjBySTySsefEzEyHa7pc1mQ6jmG+ODTwIS
+ iYS/3W5/rtdrMrJarXTMN+jhk4BYLPa8XC5psVgcDPTwSUA0Gn3BcjabUblcpmKxKL2RarUqe1TM0MMn
+ AcFgUJ3P5zSZTIR8Pq/35t2uQg+fBPj9/tfpdErD4VBIp9NSG42G3pdKJel3M/TwSYDX630bj8fU7/cF
+ VVX13kitVqN4PC499PBJgMfjiSG10+lQLpejQCAgFfOOQqFAoVCIKpWKzNDDJwFut/t9MBjg0xwM9PBJ
+ gMvleqrX61+9Xo+63a5Oq9XSMe6hgx4+CXA6nTcOhyPMfBgZjUbUbDYJ1XxjwvBJAA+KzWbbw2q13jIa
+ 3hUVs1ljt9t//gu/Pwtzylwwd8yDxWJ5ZDRUzMw9c8mcMcfMXsARc8LgeM44/gB73KHDAzmAlG9yoVrY
+ r1VqEQAAAABJRU5ErkJggg==
+</value>
+ </data>
+ <data name="icon_pan" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIUAAAAAALe7woCEiVNYYTtBSuHi5Keqr2hsc9HT1uzt7pSYnHB3g8fJyrG0t////19k
+ a97e342QlURKUqCjp7/Bw290en+Diaqvt5Sbp1lZWUxMTZCUnMzMzKOosri7vNbX13F1e+Xm55KWmWZq
+ cZyfolRUVL3AxIaKj660u76/wKastd7e5s/R08PFxnR5f5SUpdbW3sXOzn6FkpmcoKKlqJScrbS4v5SU
+ lIWLlf///wAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBBwA5ACwAAAAAEAAQ
+ AAAIyABzCBxIUCCAgggHZgCQIWHBhgcbJmhxAoQLBR4+5ADAsSOAAxVEFKCgYAaICQxKbMzR8IGDECwg
+ JHAAwQEIFhoYCnzQQqYDDgUcyHAwgcJBgQcEeGAQVAYLBwwckOAwMEQEAgZaPOUgMwGECg0IfiBw4cOH
+ EAnSJkgxQGCCEQ8GEPDAVW2CEG1zzJiRlkaFFi1g2M0r4YAIDyYSB7BRIK0BAgNTWCAwA8UFFR06INhA
+ gEVBFgRwYBi9YQEBjQhBS5BAoDUEggEBADs=
+</value>
+ </data>
<data name="tick-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -860,6 +872,23 @@
HibSZsqOLgH0HBEQAIkRg8AHBgQAOw==
</value>
</data>
+ <data name="gear--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeklEQVQ4T6WQX0hTcRzFr+kS
+ MUNfZv+UKEVCDdvAbfUwsMSai/z3EKHJoJCsnqSBURGCiCCUbWEQlFIZ1EuKEWQmqF1h98b+mprLlm0q
+ vkvky+l37tVSiF668Nn38P2ec7i7EoD/QvtxOByS0+mUqqurpZqaGm3W1dXZBE3r2Dbf6GWGbCmoqqo6
+ KgyXxNzLuba2htXVVWze0fPXgsrKymNut/vuysoKXC7XdWG6vLiYAKHmjjd66N1SUFFRQa7GYjEoig+J
+ RBxDQ0Nz8XgchDoajWo3euhdz+gFNptNstvt+2pra28FgwEEAn7Mz3/BwsI3DWrueKOHXmYsFoteYLVa
+ 7WLRQvr6eqORSBj9/c+mi4qK7hNq7njb8DHzu8BkMrlVVcHo6HtMTsoIhUIoLj7ckZycLBFq7nijh15m
+ BHpBYWFh68TEBIaHh8EZDn9CSYmpLSkpSSLU3G32MCPQC/Lz88vz8vJuEI/H+9Xvj2Bw8J3fbC69Sai5
+ 46302nPlSMPtl8wI9ILc3FwpJydnv8lk7pJlFSMj45idjWN5+YcGNXe8WTuVZUv357DFM18v/pheYDQa
+ SZssBzAw8BZjYyq83ocxny+C5scBHO9Sfjo9QZy88xGnvSH0JAARVovbA/VaQVZWFjlVVlb+VFFmUFBw
+ qDszM7NdlsM40TmJe9+B5imgIfiHlhngYOu4qhXwSUlJkdLS0hzp6ekdqampBzinp5dwsccHY2PfUnbT
+ q7A2L7yYs34AdjW/VndfeaO/AfOCbIH4rJKZGAyGRlHUSag39hlne6cyzj0J7qzvPy9K9G8gnm2CHQKj
+ YM+/2H7mwSODs9sltMhI0i+I3fKHiOg60AAAAABJRU5ErkJggg==
+</value>
+ </data>
<data name="icon_viewoptions" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIYAAAAAAP////7+//39/vv8/gkiTxAwYzhfl4KSqYGRqHuNpnyOp32Pp3+QqICRqLfC
@@ -875,18 +904,6 @@
sJgIoscTFB1OcKjBeciIIDQmeoCB+WwJG6iBhFgxY2KB17Bjyw4IADs=
</value>
</data>
- <data name="icon_invokeurl" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIU/AP///0typRExZG+wPtbn963D3maPxcyZALfH3FWHSGupO3ugdqq+r5iymaDfUY/S
- S1iORF6fN56xxmKWSj14K5jYTqqRCT95LHy6Ql6PT5Gzh4fKSIPCRY/RS2akOShXQp/eUZ7dUIrOSYLH
- R1V8IHvBRFmPRInISH+og0mCPpfYTp3cUJPVTIDGRojHR1eNRIPDRYjGR0dzh5vbT6DeUHCzP7jOsU+E
- SVuQRZvbUHGzQIbLSJPVTZq0sWWkOQAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA/ACwAAAAAEAAQ
- AAAIugB//JAQoKDBgwUlCAxgoKHDhgAMRBSwEKHFABR/BCDAsaNHjhk3AhhJsmSBjDJQZLiQQYOFAzAP
- ADj5o0EKBQNWnFAwwYZJAQxwYBgAYIADBxgmvJR5coECGkSLhgChQAPJkwlizIhaNIcLEjBnCqBQQQXX
- ohUuXBWQgAMPrh1YwLhRoG5THw+ibhDxwMMHAYABMzAxgGiLETsGvOiBoHHjmhAi6ChRIwKEBgIzZ2aw
- IAGFBAsYaM4cEAA7
-</value>
- </data>
<data name="icon_search_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIYAAAAAAP///+np6q+xtc3O0JeboqKlqqSnrKOmq5OXncXJz5SZn7q/xaOnrKSqsMLH
@@ -903,6 +920,21 @@
LMH9gFm+PAvzgAA7
</value>
</data>
+ <data name="databases-relation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACCElEQVQ4T42RvW8ScRjHb+B9
+ 0oSBl6EBQsIAcWRDBkdIWFicTAwa3xKGDmIqZ3uCfwBipAbja6MeXkptG5KzoVDeLNuZS2si1lOPVCrG
+ yfXrHaXx7oTGX/KZ7nm++TzfI+Lx+P9wTuLWJCYN/0MkErkwGAzQ6/XA8zxqtW2srbWwuclh4oIWOaDf
+ 76Pb7YJlWbx4uYwHxRJKzMYoYKKahKw9NWCxSINmWBBaJY77ClH8jWg0ejkWixHyc7vdoUQi8aZQKCCf
+ z4MkSaRSKVAUBUKr1Gjy+Cz8GgX4fD55/1T2TpZWdbD1DuX1Ktha52/AkdJWi8OeMBwFyMtUNkP/+DmE
+ 6oRXDO4/eo6l5RUQWqVcLodkMlnxer1n5zO36f3hAdIkWVUF0AzuPX6CZ2Vm3IFCqcvtYk8cgMxQ9LeD
+ 75gj01WPx3P++A4UShvtDj4IXyAM9nEjfbOq0+lOh0KhhKqDRhtMpYLV+ttxgEKJbTexI3zC9fTcaNnp
+ dBJ+v/+S6oTSa9x9WsTDlaXpHQSDwTNWq5UwmUyE3W6fVRu0UKqsolyvjDtQKDXeb2NX/IhwOHzR5XLJ
+ v3HGbDZfNRqN85LREZRer6cMBgN1eIJCab3DghN4BAKBKzabTQ44IWGXcExEq1TnmuDFHTgcjllp4KTE
+ 8U+rJN28YLFYFiTta9Jn9+HUtEcQfwDKxQygANp/PwAAAABJRU5ErkJggg==
+</value>
+ </data>
<data name="icon_plotdwf" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIe1AP///Vpuov7//f7//////7643ltsoVltoUt+spij2f7+/JGVoZKUo01/s11toLOx
@@ -1223,6 +1255,24 @@
1EDgYYYIIjMDlMlygoEMJ00gGCnw4AKFBajZNDgQoQKCMEJsuDhgQY1ChWgOkFmjMCAAOw==
</value>
</data>
+ <data name="cross-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACvElEQVQ4T22SXUiTYRTHHxIZ
+ azfKzDEpRIUFXqikIky24JXZUNyHU7tRU7ILZXThbpwM+7gQL6OMWiLTNxA/lpqGSGTOVk5r7XVrvZqb
+ m6iMZeBFN16envM0YUYHfryHc/6/h+eBlxiNRmIymUhjYyOxWCykqanpUnNzs5aCdTsFlhZ3mMEsOuim
+ HyChS43NZuvb2NgIHR8fQyKRYGDv8/lCvb29fZjB7L8HSMxmc4PL5RpH4dvkJKzbbLDCcQzsQ3R2dHQI
+ o6Oj45hFhx1gMBiQ63TBx+NxWOvsBEGvh5/0+7unh5Hs6IBAbS3bRaMRcDqdPDrokvr6eoXVanXs78fh
+ XXsb/LBYACvW0nIOrO8GA8vs7OxAd3e3A12i1+u51dX34Y8jL+BzTQ0LntVXnY6RXl6NBrzO57C4uBBG
+ l+h0ula81lJXF4hGI8wUFbHg6ekpJJNJiMViEIlEYG9vD0ays2GppIRl/f4vgC7hOM4qCAK8qqyEUF0d
+ LNPAmFwOgUAAgsEgiKJI3x0FF5V5ymx+Pst6vV5Al2i12rt+vx+mysths7oaZnNywE2D6fLBwQGbIa+V
+ Spb1eDyALlGr1Z2CsAWz7bdgrbgYlv8jn/0LuHujULCsx/MB0CVVVVU3pqfd228fP4X5wsJz8jwVEJRP
+ Tk4YM3l5sPxoGFwufhtdUlFRoTSbLYOBQBimDCbgc3OZvETFrRTYo8zT52Fmc3MLTCbzILqkrKyMlJaW
+ 6gcGHrqDwQi8rGuA4aws+ESlcArscYY7QdgFh+OBGx10iUKhIAUFBVKVStVqt9+fE8UjWHk2BvzNNhhS
+ 5jGwx5koHoLdfm8Os+igi3WBclEikVyWy+VtarXmycTEQnR39xekgzPcYYZmr6CTckkGRU5RUa5lZmZy
+ Uqn0jkwm66cMpejHGe4wQ7n61yEZfwCPJRsF7cBiYgAAAABJRU5ErkJggg==
+</value>
+ </data>
<data name="icon_restorecenter_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIUtAKq7y5+svcbS2MPQ1tTc4MvW29DZ3sTR17nH0tDZ3crV2tLa38fT2dHa3snU2tPb
@@ -1279,6 +1329,25 @@
A9WvWL82wW5UT/JvnmHsJ9lC3y9ayCOwAAAAAElFTkSuQmCC
</value>
</data>
+ <data name="icon_ctxarrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhBAAIAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
+ /wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBmAABmMwBmZgBm
+ mQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD/
+ /zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZ
+ MzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYA
+ mWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ
+ /2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkz
+ M5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnM
+ mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz
+ /8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/
+ M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9m
+ mf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP//
+ /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAABAAIAAAIFAABPBgIQOCDggIRKlR40KDBBwEB
+ ADs=
+</value>
+ </data>
<data name="icon_selectpolygon_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIMLAM3Jzs6lqZ+svcTM083Cx828wdbcyMvSxsTEy8LKxM3DxwAAAAAAAAAAAAAAAAAA
@@ -1303,21 +1372,6 @@
YII=
</value>
</data>
- <data name="icon_zoom_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZfAHaFlJ2Sh9HW3Ojt8uDPvuPp79Tg5fP19uzw9O3x9OLo7t3l7PP1956foLa2t52d
- nZ2dnM/R0tPU1ZKSk6SmqPX2987P0NHT1vDz9eDl6b29veTn6dzg5KqsreTo7KKkpsbZ26enqNba3e/y
- 9b+/wJubm7zEy4eHh7rH09Lc5tbY2tfg6M/OzvHz9sXHysvMzsrKypKTk9vd4LGwsKymoP///4KCgra8
- wvDy87q7vdTZ3cvO0MvT28XFxeDj5a2trczT2+zw8+jp6uPl5tTd5uTo683V3Le4ucjKzLa8wcLDw7q/
- w/T2983X4evt76GgoOTq7/n6+u/x9K2vsNjh6dTa4LSzs8vR2fHz9ba3uO3v8c/S1PH09szLy/L09QAA
- AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
- AABfACwAAAAAEAAQAAAIqwC/CGRh5cmMLgITAkj4pYcEGRxEvNDAcKFAJT60eDkgxYOOLF8AiBQJI8KB
- GlEYjAgCZQkJgRZ/DKngBAsGBAMUXHkAUyAEHEyKZEiQcwGREwy/hBDCgAvRAgaoAJlgYiSAHBZa4IQK
- IsWNDklVONgwoMCCJiiMfNiS9AsSBy6qrOCRhEKDtgIvHClhI8aUHQ0CEMDbVkAAwYSTGkacOOHiwY0F
- GqYR2bHAgAA7
-</value>
- </data>
<data name="image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1348,17 +1402,6 @@
gQ6z1Tqypb39kRFN7pbPJo85bjqz+ZNkAFjWAEPwe9vSE1Y8AAAAAElFTkSuQmCC
</value>
</data>
- <data name="function" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABC0lEQVQ4T6XSPUpDQRiF4bkh
- IsEgwb+gawg2pomFhUUs0gcLtbQSGwsrN5BKF2Bnp1gJAS0EUUil2LmFrOLmPZPvhmGYW5gMPJlvDsPJ
- zY/L83whLsuylD6ejObUndKCNp5xiJbNqXulBed4xHqQJZUV3OIuypLiggGGkd1gPoHuNYtz6gk6eLNd
- 5zPbj6Fc38sDukh+hEu8YjPIZB/vZpanCu5NnPfwCf1Cszwu0Lt+4CrIRP+DkTmyzIsLDvBtu9Niv7ZM
- s/bTYJ4WBOsGv2j6k3MX+JuOfhVn6SkICzr4wos/la+68asoGJsf7GEDa2hgFSuoYRlLqKKCrCjYwTb0
- 6Fv4X4Fe5pe7CSINtCR/xwMpAAAAAElFTkSuQmCC
-</value>
- </data>
<data name="folder--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1384,6 +1427,20 @@
rkJggg==
</value>
</data>
+ <data name="icon_clearselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIZXAAEBAYSChPn6+b2/vvrond3Th9bm63CrvN7Vh6+8mOCnnLK8mnJ+jOzNYuTfi627
+ nIeZk3l+jvX28+LaiamMOSE7NSwuLMfd47SVnNDi6O7sj2ZdZIBoKdfn67TA0O/swv3///vKwd+zDV+y
+ qu3Zh395RpiimK26xaiouLC9xcjd5JRCL7m/0sytJvP19vL09qyuq4GCmd/s7/Lv+s/i6HV+hHk/Odet
+ EXqChdjMhURNV/vok+nljbuRAamDAfz8+6+9os3h5zU7L/n6+ujjjJ6iorS8yOLdisDZ4J+dlnpaWa3B
+ xY53O/nonIiSmbO/yrqAfbTAy914aNuvDUBeXLePAclWRv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+ AABXACwAAAAAEAAQAAAIoACvCBxIcOCTBR8CXFHIcOHAEwl2NChIMcqDJjdaKATAkaPDFEAITKlCQSAA
+ DTwcABDowQQJET2YJNlI5AiClQxYzCjhg8MACSYnFMgBwAgKEEsOCIHxw2FHADowKIAwgkoRARQFxggh
+ ZUUFHEMGKrzSMQIUKzZquKAIQIaBIBY2KHHyouDGDjQurBybFUAGFUhWZnVI1iPhwYgJNlycNSAAOw==
+</value>
+ </data>
<data name="icon_zoomselect_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIZYAMDAwICAgK2km+vv8+/y9fb3+Ofs8fL19/X29/X2+K6vsNPa4MHCwtrl6ejt8sLH
@@ -1399,6 +1456,9 @@
S8YioKDlyZgdBwQAOw==
</value>
</data>
+ <data name="layer-small" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layer-small.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="plus-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1493,22 +1553,6 @@
MFZB4vF/BgC5xGorvamwnQAAAABJRU5ErkJggg==
</value>
</data>
- <data name="drive-download" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACR0lEQVQ4T42OX2hScRTHD0FF
- hEG3f9Aftv5ApVIPF0r2soU9BeIkDRnGKkhBYmOMoVu0BesWvSx6KrbwJXqwP2BYqY2l+ae0WcN2zZy5
- tfWQvqztYeUkPP2O7MpdsepePnDu+X6+hwuNruJK8K4v2CSkKk00/5bVgEPX3tc4fH0cGm7NSNhvf/p5
- pTO4INAs7cmRd6C+K1hjjzMMBy+PAj+QJR7cTC+mbd7ZNJvv044ycuSdZR8U7uuJwf5LcVD1v0v2v5nH
- E0MfkWbaUfbXA7sdL28wwb9E0h6eRfWdSaRZ2pMj78DO9uc1drQFLHsvhtMdqTKeTy4i71/ATe55bBz5
- jsbYD6xzhkRy5J1lB7Zf8AF37pFlW0dA1I1WcLOvgqseV1AdquCWdr9IGTnyDhxpFaocPXMVDlhdsPHs
- Q1hvvmvZYPOIDTHE+hFEhdUj0o4ycsiVeqDX66sYDAYwmUxw3GyHXacGYHXzkGVtq3t8DYNm2lFGDrlS
- 748DEsdOWkHV3FVH0CzPVjqgMBqNLQzbP2ght3ZAp9NJnI5EIhOpVAoTiTiGQi/Q53uGXq+X8YQRYATR
- 7X46Qa7UA57nQavVEm3lchlLpRLOzX3DQuErTk9/xnw+z5hkzGAymcFstoDkUoe61UelUoFGo+ksFovo
- 8XhQEATs6+vF7m4nOhxEL0NAK3vj8QySSx3pWcfYqlQqe9jvTuVyOcxkPuDY2Fsmv8ZoNMqIMRI4PPwK
- BwfvTZFLnaUucAy1QqEwcxwn/A/kUgcAuF+i7LTexweyfwAAAABJRU5ErkJggg==
-</value>
- </data>
<data name="cross-script" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1703,9 +1747,6 @@
HE7cl2HkyZUtSx6QWfOXzpZnsAkIADs=
</value>
</data>
- <data name="magnifier-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\magnifier-left.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="icon_zoomout" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIZ6AG1LJgE0ZkV2qN7s9bK8xuqvdtfk7LOcjH+AgLrK25i1019fX6OmqdDc41lZWV1d
@@ -1738,35 +1779,6 @@
BI8SEnFZTeEGAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_tasks_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIQAAAAAAP////39/vz8/fv7/Pr6+/n5+vj4+fb2936EjuDi5YyTnM7T2bG3vvf4+fb3
- +PX29/T19vP09fb4+PT29v3+/vz9/fr7+/n6+vj5+ff4+P7+/v39/fz8/Pv7+////yH/C05FVFNDQVBF
- Mi4wAwEBAAAh+QQBAAAfACwAAAAAEAAQAAAIogA/CBxIsKDABggTKlR4kEGDDBAzNGBAkWKCgwsaKNio
- YIHHjxc/NAjQYMOGChw6dCDQ4IKBkCNLLrzQAEMGmBsaoByw8kKBhzcP5uSgsACGhxpgCmigkoCHCzYb
- aJgAk2iHhRInPIBpoYHTAgYyHHDQ4AEEmFdpIjwwtQEECjBZGoU49UEDChFgelioMELeg2AhOpiA4K1f
- CTATKF7MePGHgAA7
-</value>
- </data>
- <data name="map--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC6UlEQVQ4T53RYUzUdRzH8e9s
- 5rKtXD4odWu59cThwLk2G+qSrdUDpa2UHrjl3E44PDxOILgLAU1UZHjKgsOuAcrtcBwM8QLJEwE1u4QO
- m8p1WtiB3EHEpJQTZCLvfj+ftmbzv7322/77vB/8/z9J2bs3WUl7DslbiopENhcWGnmOR3eKyMf5+elz
- 6kX9lQJaeg9ypb+S4EA9gYHzuG/2c6Angu1ylCxfFHNrFNPpKHqvO0XkI6vVNDs3x4muPDoG7PREnPSG
- nExMd/HL5G0aRmMU+aMUB6EgACZvFL3XnSKyMScnY+bJE5y+LNpCh+j6vRzfNTt/TJ5hfMrP1b+GKPsp
- TOmvsO8G7GodRu91p4h8aLGYp2dnqWzN4Jvz2bgu5uPtK6H7ejk3brnoud1OQyjEfv8ged1DWL4bQu91
- p4i8n5GRGXv8mGPN6TQE9uDtL8Z9aQ8/Dn9NeMLDvalOOoOdeEYfYL8zR3bHIHqvO0Vkg9G4+/7MDPZT
- abj9VhqvFVLdkcuFO8foG6lh5H4LfaEm9SmD1AzPYOsOo/e6U0TWGQzZE48ecbTWSN2lXOp7bFSdtXD2
- 1mEuhr8i+KeLQH8Nw7EAvvEx9l3+Db3XnSLy7rZtOePT05RXmSg7mcqRhlQc7WaOt++m9oKNxu/34w9W
- EbhZxybfp7x5JpHtvVnoThF5Z+vW3LGpKSrLzbi9Nuo6P+eIJxVPXwHe4AF1tUc5/cNBIn83k9C2hh0T
- uepMQnfLCtaIrEpJsY48fIijzIKnsRBXWx6H3QbcV600/VykrraEpMZ1xDXHk9CympTxNOJb3mO+Y0lE
- ql9zyork5PxILIajNJOKskzsFemU1hgorTdgbzJS8a2Zt6rfJmn0k38Rx6KAvJGY+OWY+qt3Jyf/02fn
- dhFft/aplXfXk+BazwvFi0fE/opTXlq+fOfLcXEl/8e8L14dXRqOQ5+6kw8WiH4WKq8rS59p54u1kjb/
- upjU+bQT+QeXzXtObOCHlAAAAABJRU5ErkJggg==
-</value>
- </data>
<data name="icon_popupscrollup" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
@@ -1795,9 +1807,6 @@
CFRK4WWAq1ivDlTqc+IHmF29wpTqdSrZshMDAgA7
</value>
</data>
- <data name="information" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\information.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
- </data>
<data name="icon_popupscrolldown" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1832,6 +1841,21 @@
7AkAYHHjwA0pW8acubIAzp3ngM5MZk9AADs=
</value>
</data>
+ <data name="arrow-curve-180-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEElEQVQ4T6XTXUiTYRQH8BMr
+ EUPnR9NmgRIjNuxr2hIaZNFFb3UXo5sS+7QgM7DANoI0IUhbn5DuIi2oFEQ0i6mBRSl1sWeDUltfkrCi
+ zUklRS1ZnP7PsLHRiEYP/HgOzznn/169xMz/JeFjMshQL2hV4xituTROZsc7KmsNKOBYd9VPkvGsN0rO
+ FTV4aOmJJ6SzDkfEB7T4FISIWbT6wuskAi6+URAiHO+Z5V1y7mXc8l8DVp4ZVdCMLDd5wyzrGC5wgh1z
+ pj8C9HUuBSGi2cdcc/8r2x5/41OeENe7Q1wnQnzS9Z1rh7/82HsnMLX2/OgIZq0ISIsGLKl9JC6//ckH
+ 736Ks7snyJZ2H29ufcUbW8Z4w5VnvKXtRdjU5B7HjrXw2AMqqBkkWnzknrKoekA0Pp/hyt6PfKB/mrcP
+ fOb1vVNs7g5yadckGzsnuagjwLobfjbc/BAusA2N5B/uN2kPOYmwTJr9PcqCfd2iSszwssEwy/o3TeVt
+ d25139OF1ode7WnPRM41/3RO80QQPTsQZZSWk3prA2XsbFfSd9wSxUPM8s7a1UnZe7pIXd4xF7JAD5vQ
+ s6dX9blxO4GiR5VnoJSy40qqpU1Iqlz9bCf+pCzfJudssTNzYB6kQabKWGFRmY9eR60DA6yAYiiJhRn5
+ +UKIBKhAhqTCfFBDNmggD7SQn0Bmwh8kGQkf/x3TL/u/9NmKeOePAAAAAElFTkSuQmCC
+</value>
+ </data>
<data name="gear--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1921,6 +1945,19 @@
Wf+K6sLEr7FSslqy9h9QvuyE+AlKt3w9YDzhwwAAAABJRU5ErkJggg==
</value>
</data>
+ <data name="control" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABhUlEQVQ4T6XOTSiEURQG4NuY
+ QZnFKMZPplAyhGQskFCUsqHZoG4ZKcqCBVEWxgolQqRRY2FmRZSf5LcpC4VLkQWlKCbMRpQsJh3nTK6+
+ W8rIrafvvrf3nD4GAP+ihHL3I6uYe3IhXjrrZ0XTt8w2dsXyhs6Z1XmkdCUl0BASX/ifF9AAEi4/AH2L
+ pm74nxZQGYnhiyDM3AHQ3TZ6ycNeQEUknMfv0L7xAuPXH0A5d/CMh7WASkj0HbxB89IT1HtuYEC8AL1l
+ 9h9ybVdSQnrvPhGt636omjyFyomTkM7dB6B3bVdSQkrHFhF1y/dQ6LoKcewEgN4sndu//4G5dYWI4rVn
+ sHgDULP3CpQT2lY5Ldd2JSWYmhaISNsMQqEvCHSPdSxyWhxvH1G6khJiGjxEZPgA6Gts9HJjtZMZknIY
+ HW1XUoI+u5ZF2t2CGMp6eIQ5KzQoj7YrqYGxaF1J17yuoKUb7/nIilJRIorSdr9nlMCYHplRMqKhOGRC
+ RqTXdr9nfnoMH7BPTYFtG3kcKMcAAAAASUVORK5CYII=
+</value>
+ </data>
<data name="icon_popupscrolldown_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -1969,6 +2006,18 @@
<data name="folder-tree" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\folder-tree.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="icon_invokeurl_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ R0lGODlhEAAQAIU4ANrf46y7zJ6rvLXLss/Z4cXQ2rPD1M3Fo8fR2rjHwK/BtbTJsb3TtcLXt8TOzsDL
+ ycTDpbrQtL7UtrnNs7DCtMHWt6m9rqm9rcHL1LHDtrDDtLPIsb7MxMDVtrLEtbHHsLbMs6u8xK/CtK++
+ q6y/ssDWtrrPtLjPtLrRtLzRtLvStb/VtqS1s7nJw8jSz63AtbzQtMDWt7bMsrvRtcHXt7zStcDMz7zR
+ tQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA4ACwAAAAAEAAQ
+ AAAIuQBx4MAQoKDBgwUxCAxgoKHDhgAMRBSwEKHFABRxBCDAsaNHjhk3AhhJsmSBjCFaZLCQgQOEAzAP
+ ADiJ4wGJBQMq3FjgwYVJihomDAAwoEGDCR5eyjyZYEGDoUQr0FjAgeRJBTBKQCUaI8UImDMFXOiwYivR
+ DhasClBgQsJWBhIivChAl+kGBlBn1GCwgYWAv38daBgwNAIKFQNE2EDAmHFNCh9AnJDxgcIDgZgxO0ig
+ 4IKCBA4yYw4IADs=
+</value>
+ </data>
<data name="icon_panright_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
@@ -2103,34 +2152,16 @@
iEmUMn62FGwxJMMJPTzUHKlQgwYShA/kaCFi4E4TCRgsRBzEBQGCOTbcwNk8iA2FHQ4MyAgIADs=
</value>
</data>
- <data name="document" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_tasks_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABnElEQVQ4T42SP0tCURjG31Xa
- HGpqELRBgoaGpCEhCLpQUWTg4OJgJSWhSKKlQksfoK9gH6DFD+BnqKEpCjQRqbz+vf47vc/lvkFQpw78
- hnt4nh/nvPdQqFCwOSgWt5nDP/Du5/O0l8vRbjZrQ9hwOOqOx+rdslSj11PVTke9tNvq2TRt7ioVhQzj
- +ybAh8NxezhUTS6+tlrqqdlUj/W6eqjV1H21qm7LZYWFHOP7EuxkMkK8w4K3bvdHyU2p9IXPMC4ZArSV
- TgsnvdFIffDxf5PgJLgOstKjzWRSOO3zDMx+XyuBAFnp0UYiISQGLOgMBloJBous9Gg9HhfOhpOJ6vEc
- dBL8HWSlR2uxmJAcsWDAc9BJGryHrPRoNRoVUuPpVFl8DZ0E7wRZ6dFKJCKkJyzAKXQSk/eQlR4th8PC
- +ZQfypgFOgkeG7LSI28wSEuhEMjgpU35FDpJl7+RRQdde80HArRgGBcQYOkkeGzIoiPLxczOBQJXTt9e
- uA5mgsFChF+Md2LxN7LoOF1yM4sujyc14/df/wdk0SEi9yfyP5Btd7QayAAAAABJRU5ErkJggg==
+ R0lGODlhEAAQAIQAAAAAAP////39/vz8/fv7/Pr6+/n5+vj4+fb2936EjuDi5YyTnM7T2bG3vvf4+fb3
+ +PX29/T19vP09fb4+PT29v3+/vz9/fr7+/n6+vj5+ff4+P7+/v39/fz8/Pv7+////yH/C05FVFNDQVBF
+ Mi4wAwEBAAAh+QQBAAAfACwAAAAAEAAQAAAIogA/CBxIsKDABggTKlR4kEGDDBAzNGBAkWKCgwsaKNio
+ YIHHjxc/NAjQYMOGChw6dCDQ4IKBkCNLLrzQAEMGmBsaoByw8kKBhzcP5uSgsACGhxpgCmigkoCHCzYb
+ aJgAk2iHhRInPIBpoYHTAgYyHHDQ4AEEmFdpIjwwtQEECjBZGoU49UEDChFgelioMELeg2AhOpiA4K1f
+ CTATKF7MePGHgAA7
</value>
</data>
- <data name="databases-relation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACCElEQVQ4T42RvW8ScRjHb+B9
- 0oSBl6EBQsIAcWRDBkdIWFicTAwa3xKGDmIqZ3uCfwBipAbja6MeXkptG5KzoVDeLNuZS2si1lOPVCrG
- yfXrHaXx7oTGX/KZ7nm++TzfI+Lx+P9wTuLWJCYN/0MkErkwGAzQ6/XA8zxqtW2srbWwuclh4oIWOaDf
- 76Pb7YJlWbx4uYwHxRJKzMYoYKKahKw9NWCxSINmWBBaJY77ClH8jWg0ejkWixHyc7vdoUQi8aZQKCCf
- z4MkSaRSKVAUBUKr1Gjy+Cz8GgX4fD55/1T2TpZWdbD1DuX1Ktha52/AkdJWi8OeMBwFyMtUNkP/+DmE
- 6oRXDO4/eo6l5RUQWqVcLodkMlnxer1n5zO36f3hAdIkWVUF0AzuPX6CZ2Vm3IFCqcvtYk8cgMxQ9LeD
- 75gj01WPx3P++A4UShvtDj4IXyAM9nEjfbOq0+lOh0KhhKqDRhtMpYLV+ttxgEKJbTexI3zC9fTcaNnp
- dBJ+v/+S6oTSa9x9WsTDlaXpHQSDwTNWq5UwmUyE3W6fVRu0UKqsolyvjDtQKDXeb2NX/IhwOHzR5XLJ
- v3HGbDZfNRqN85LREZRer6cMBgN1eIJCab3DghN4BAKBKzabTQ44IWGXcExEq1TnmuDFHTgcjllp4KTE
- 8U+rJN28YLFYFiTta9Jn9+HUtEcQfwDKxQygANp/PwAAAABJRU5ErkJggg==
-</value>
- </data>
<data name="icon_fitwindow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIZlAEJyokd1qBU2aPLyl/PzoPj4yvT0rJi2zPn9/O729/L4+PT1rLnS2eny8+fx87zV
@@ -2178,46 +2209,44 @@
QUKJRCCcJJAkDStIPIkly4kYFHkxHEyCNH+QQGhe/j+E38IC84Ag6BEDAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_invokeurl_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_invokeurl" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIU4ANrf46y7zJ6rvLXLss/Z4cXQ2rPD1M3Fo8fR2rjHwK/BtbTJsb3TtcLXt8TOzsDL
- ycTDpbrQtL7UtrnNs7DCtMHWt6m9rqm9rcHL1LHDtrDDtLPIsb7MxMDVtrLEtbHHsLbMs6u8xK/CtK++
- q6y/ssDWtrrPtLjPtLrRtLzRtLvStb/VtqS1s7nJw8jSz63AtbzQtMDWt7bMsrvRtcHXt7zStcDMz7zR
- tQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA4ACwAAAAAEAAQ
- AAAIuQBx4MAQoKDBgwUxCAxgoKHDhgAMRBSwEKHFABRxBCDAsaNHjhk3AhhJsmSBjCFaZLCQgQOEAzAP
- ADiJ4wGJBQMq3FjgwYVJihomDAAwoEGDCR5eyjyZYEGDoUQr0FjAgeRJBTBKQCUaI8UImDMFXOiwYivR
- DhasClBgQsJWBhIivChAl+kGBlBn1GCwgYWAv38daBgwNAIKFQNE2EDAmHFNCh9AnJDxgcIDgZgxO0ig
- 4IKCBA4yYw4IADs=
+ R0lGODlhEAAQAIU/AP///0typRExZG+wPtbn963D3maPxcyZALfH3FWHSGupO3ugdqq+r5iymaDfUY/S
+ S1iORF6fN56xxmKWSj14K5jYTqqRCT95LHy6Ql6PT5Gzh4fKSIPCRY/RS2akOShXQp/eUZ7dUIrOSYLH
+ R1V8IHvBRFmPRInISH+og0mCPpfYTp3cUJPVTIDGRojHR1eNRIPDRYjGR0dzh5vbT6DeUHCzP7jOsU+E
+ SVuQRZvbUHGzQIbLSJPVTZq0sWWkOQAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA/ACwAAAAAEAAQ
+ AAAIugB//JAQoKDBgwUlCAxgoKHDhgAMRBSwEKHFABR/BCDAsaNHjhk3AhhJsmSBjDJQZLiQQYOFAzAP
+ ADj5o0EKBQNWnFAwwYZJAQxwYBgAYIADBxgmvJR5coECGkSLhgChQAPJkwlizIhaNIcLEjBnCqBQQQXX
+ ohUuXBWQgAMPrh1YwLhRoG5THw+ibhDxwMMHAYABMzAxgGiLETsGvOiBoHHjmhAi6ChRIwKEBgIzZ2aw
+ IAGFBAsYaM4cEAA7
</value>
</data>
- <data name="control" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="edit-indent" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABhUlEQVQ4T6XOTSiEURQG4NuY
- QZnFKMZPplAyhGQskFCUsqHZoG4ZKcqCBVEWxgolQqRRY2FmRZSf5LcpC4VLkQWlKCbMRpQsJh3nTK6+
- W8rIrafvvrf3nD4GAP+ihHL3I6uYe3IhXjrrZ0XTt8w2dsXyhs6Z1XmkdCUl0BASX/ifF9AAEi4/AH2L
- pm74nxZQGYnhiyDM3AHQ3TZ6ycNeQEUknMfv0L7xAuPXH0A5d/CMh7WASkj0HbxB89IT1HtuYEC8AL1l
- 9h9ybVdSQnrvPhGt636omjyFyomTkM7dB6B3bVdSQkrHFhF1y/dQ6LoKcewEgN4sndu//4G5dYWI4rVn
- sHgDULP3CpQT2lY5Ldd2JSWYmhaISNsMQqEvCHSPdSxyWhxvH1G6khJiGjxEZPgA6Gts9HJjtZMZknIY
- HW1XUoI+u5ZF2t2CGMp6eIQ5KzQoj7YrqYGxaF1J17yuoKUb7/nIilJRIorSdr9nlMCYHplRMqKhOGRC
- RqTXdr9nfnoMH7BPTYFtG3kcKMcAAAAASUVORK5CYII=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABdklEQVQ4T5XS3ytDYRgH8Gc3
+ bmdc2HYj2hQNs7RNoya2KTI/brCylpJbJbldUvwT7rjasF8k4viRH1Fyw5XIjaRcu3t9n7ft2I4dy1uf
+ Oud9nvf7vKcOCSHIYDCwOCQgmbcF27ADKUhDFnKwBvJsccC/aQMqTaXOwJLk6lskZ++C/g24odBcMLv6
+ qZpZ+aBo/O0noN4Zk+zuOVmILb8raBJ6uF4S0D19Inmnjig8/8DE6d2XLq5znxrgnjhkwjGc9nsmD6kr
+ cqzwux6u80A1wB5KsBcQ/Nwa3qPmwfQvLUNZco7tyoElAbZgionG/oTfHsogLKPwuxbv20M5ahvZp47x
+ g+Ib5KSmgRy1j16xst/O+/m6pAbU2iJStdlLjuAmrves9ERfhRbvOwIbZKzzEC81QPsfmKw+anAt/GKy
+ +OTBwtIGKHACZ3AOF3AJ13ADt3CPc4/wVC6gIu1SA7CMaFgHvalJsOZZoAaqSgLADIWmvxQFCPoGzyRS
+ PHSKlsAAAAAASUVORK5CYII=
</value>
</data>
- <data name="clipboard-paste" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_panup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACbUlEQVQ4T43SS0iUURQH8LNJ
- aCdCBVGrcmzCwvGVD9LJohrBYMwcx7eljY05OJpjMIFFWhSJwSQVZQ/T3lkumqBNIIEtbmgPqCSEKGtR
- COXYzPj6d8+X301d9cHvm8v9zjmce+bSuUzSdJj/OWQxRuTl5eVKjjm5vDc/Rs+bX+CiJNgJEw11HXZ9
- HR7+CMZr3tO/c6wq4JOvOeJDx1701aZhYOA1BgffY2Tki4bXvMff3vnKwbF6Hp3drIg37cW4URaLS7a1
- uF6yHrf2xeFOVTy6yzfgSmEMeio24lVbIThWz6O2NEUMnbHj+dEcPGkway40WtHeZFfON1egs9WBlu3L
- 3tYVZZDLnk50OkURL0/l45l3p+LzluD3zAx+TU7iRyiE0UAAff39qLOlfrJ6vdE5Hg/RySRFvGix4qln
- q9LmKcDE1BTGJibwfXwcn8fG0OP3gx+Z7JQMdDyBdILbf+zO0PDAjjlzEJyexs9gUBXxdXcr0RbLEWqO
- I53gth8cSNYGebkgGo1lWQjLIwTC4QVFuJNRud5WU+MibyzphL8+E1eL1qHTbtA0lGZhShYIyhksLsIz
- yaiqclOTkXTiYU0KrhUbFXfJFszMziIsj7G4CA82pbS0geoNpBO9skCXbF/nKjJjVg5sWnaxuEhAruNt
- Ng/tXknkWqMRvc5N2mXRVeenaxPnItwJH4dnwoMNyd+Y7GyvvEpEu1YQOVb/LXC70qTUWuNRYDEtYM82
- Icm46lukydQalZhYyflLpeV7Ikk8Opiq/Qv3q5Nwz5Go3N2foOFrzTiWc+ZyKUqKTV5CN3dEkPgfHMs5
- RBT1B7y5F+bFJBNnAAAAAElFTkSuQmCC
+ R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
+ 2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
+ s9zPz9/T08/ExMzFxNbKydfOzdXJyqOuutjMy9zQz8fP1tvPz97R0dLLytfLysG2ttPQ08vEw6Ouucq9
+ vs/Dw6eyvuLW1eXX1+TY1+DW1sa8u+LV1vj09dTQ0NPHx8i/v9fKy+PX1pynsc3BwaSvu+fZ2tTIx+PX
+ 18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
+ yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
+ AABuACwAAAAAEAAQAAAIxADdCBxIcKCRgggHMgDAQOCLAARSgEE4AMAANz2gcIAgwIIWNQUBCKyxgACJ
+ BwLWnAlCUKSbEyYCCDDAQ8CWLm0GunTjA00VAhseCEkiIUbCGS0CKKFQIcECCSESjgmwpASFHzsCpCl4
+ JAqCGxMqIEigowgEGgRBPGnQAIcKGQZgGMjA5uJAD0NQTPDC4gsRIGIimClT0ImVAweYSLmgIQKWK1kQ
+ TsEQxoWCESIcrOCSUCCZAgWaUMlho7NAJAU+dFDgICAAOw==
</value>
</data>
<data name="TextWatermark" type="System.Resources.ResXFileRef, System.Windows.Forms">
@@ -2234,6 +2263,9 @@
CwkyVnWxgAUJAC8wFJCg1mHFhwI8nASKMYEAFWoZCkYYEAA7
</value>
</data>
+ <data name="layer-shape-polygon" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\layer-shape-polygon.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
<data name="icon_printablepage" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
R0lGODlhEAAQAIZ+ANbn9xExZEtypa3D3q+xyP///6irvlVgfLfH3E5Sb+/w9vz8/fb2+WBedoGPsO7x
@@ -2249,16 +2281,23 @@
ZOHTRoMQHTMDABEB5YWDGUmU6KHxQAwGBKj95EkRIw6LFVV6fEig5oJChVHMbOijMCAAOw==
</value>
</data>
- <data name="icon_pan" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="map--plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIUAAAAAALe7woCEiVNYYTtBSuHi5Keqr2hsc9HT1uzt7pSYnHB3g8fJyrG0t////19k
- a97e342QlURKUqCjp7/Bw290en+Diaqvt5Sbp1lZWUxMTZCUnMzMzKOosri7vNbX13F1e+Xm55KWmWZq
- cZyfolRUVL3AxIaKj660u76/wKastd7e5s/R08PFxnR5f5SUpdbW3sXOzn6FkpmcoKKlqJScrbS4v5SU
- lIWLlf///wAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBBwA5ACwAAAAAEAAQ
- AAAIyABzCBxIUCCAgggHZgCQIWHBhgcbJmhxAoQLBR4+5ADAsSOAAxVEFKCgYAaICQxKbMzR8IGDECwg
- JHAAwQEIFhoYCnzQQqYDDgUcyHAwgcJBgQcEeGAQVAYLBwwckOAwMEQEAgZaPOUgMwGECg0IfiBw4cOH
- EAnSJkgxQGCCEQ8GEPDAVW2CEG1zzJiRlkaFFi1g2M0r4YAIDyYSB7BRIK0BAgNTWCAwA8UFFR06INhA
- gEVBFgRwYBi9YQEBjQhBS5BAoDUEggEBADs=
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC6UlEQVQ4T53RYUzUdRzH8e9s
+ 5rKtXD4odWu59cThwLk2G+qSrdUDpa2UHrjl3E44PDxOILgLAU1UZHjKgsOuAcrtcBwM8QLJEwE1u4QO
+ m8p1WtiB3EHEpJQTZCLvfj+ftmbzv7322/77vB/8/z9J2bs3WUl7DslbiopENhcWGnmOR3eKyMf5+elz
+ 6kX9lQJaeg9ypb+S4EA9gYHzuG/2c6Angu1ylCxfFHNrFNPpKHqvO0XkI6vVNDs3x4muPDoG7PREnPSG
+ nExMd/HL5G0aRmMU+aMUB6EgACZvFL3XnSKyMScnY+bJE5y+LNpCh+j6vRzfNTt/TJ5hfMrP1b+GKPsp
+ TOmvsO8G7GodRu91p4h8aLGYp2dnqWzN4Jvz2bgu5uPtK6H7ejk3brnoud1OQyjEfv8ged1DWL4bQu91
+ p4i8n5GRGXv8mGPN6TQE9uDtL8Z9aQ8/Dn9NeMLDvalOOoOdeEYfYL8zR3bHIHqvO0Vkg9G4+/7MDPZT
+ abj9VhqvFVLdkcuFO8foG6lh5H4LfaEm9SmD1AzPYOsOo/e6U0TWGQzZE48ecbTWSN2lXOp7bFSdtXD2
+ 1mEuhr8i+KeLQH8Nw7EAvvEx9l3+Db3XnSLy7rZtOePT05RXmSg7mcqRhlQc7WaOt++m9oKNxu/34w9W
+ EbhZxybfp7x5JpHtvVnoThF5Z+vW3LGpKSrLzbi9Nuo6P+eIJxVPXwHe4AF1tUc5/cNBIn83k9C2hh0T
+ uepMQnfLCtaIrEpJsY48fIijzIKnsRBXWx6H3QbcV600/VykrraEpMZ1xDXHk9CympTxNOJb3mO+Y0lE
+ ql9zyork5PxILIajNJOKskzsFemU1hgorTdgbzJS8a2Zt6rfJmn0k38Rx6KAvJGY+OWY+qt3Jyf/02fn
+ dhFft/aplXfXk+BazwvFi0fE/opTXlq+fOfLcXEl/8e8L14dXRqOQ5+6kw8WiH4WKq8rS59p54u1kjb/
+ upjU+bQT+QeXzXtObOCHlAAAAABJRU5ErkJggg==
</value>
</data>
<data name="marker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2292,35 +2331,14 @@
rkJggg==
</value>
</data>
- <data name="icon_clearselect" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- R0lGODlhEAAQAIZXAAEBAYSChPn6+b2/vvrond3Th9bm63CrvN7Vh6+8mOCnnLK8mnJ+jOzNYuTfi627
- nIeZk3l+jvX28+LaiamMOSE7NSwuLMfd47SVnNDi6O7sj2ZdZIBoKdfn67TA0O/swv3///vKwd+zDV+y
- qu3Zh395RpiimK26xaiouLC9xcjd5JRCL7m/0sytJvP19vL09qyuq4GCmd/s7/Lv+s/i6HV+hHk/Odet
- EXqChdjMhURNV/vok+nljbuRAamDAfz8+6+9os3h5zU7L/n6+ujjjJ6iorS8yOLdisDZ4J+dlnpaWa3B
- xY53O/nonIiSmbO/yrqAfbTAy914aNuvDUBeXLePAclWRv///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AABXACwAAAAAEAAQAAAIoACvCBxIcOCTBR8CXFHIcOHAEwl2NChIMcqDJjdaKATAkaPDFEAITKlCQSAA
- DTwcABDowQQJET2YJNlI5AiClQxYzCjhg8MACSYnFMgBwAgKEEsOCIHxw2FHADowKIAwgkoRARQFxggh
- ZUUFHEMGKrzSMQIUKzZquKAIQIaBIBY2KHHyouDGDjQurBybFUAGFUhWZnVI1iPhwYgJNlycNSAAOw==
-</value>
+ <data name="information" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\information.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="gear--arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_null" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACeklEQVQ4T6WQX0hTcRzFr+kS
- MUNfZv+UKEVCDdvAbfUwsMSai/z3EKHJoJCsnqSBURGCiCCUbWEQlFIZ1EuKEWQmqF1h98b+mprLlm0q
- vkvky+l37tVSiF668Nn38P2ec7i7EoD/QvtxOByS0+mUqqurpZqaGm3W1dXZBE3r2Dbf6GWGbCmoqqo6
- KgyXxNzLuba2htXVVWze0fPXgsrKymNut/vuysoKXC7XdWG6vLiYAKHmjjd66N1SUFFRQa7GYjEoig+J
- RBxDQ0Nz8XgchDoajWo3euhdz+gFNptNstvt+2pra28FgwEEAn7Mz3/BwsI3DWrueKOHXmYsFoteYLVa
- 7WLRQvr6eqORSBj9/c+mi4qK7hNq7njb8DHzu8BkMrlVVcHo6HtMTsoIhUIoLj7ckZycLBFq7nijh15m
- BHpBYWFh68TEBIaHh8EZDn9CSYmpLSkpSSLU3G32MCPQC/Lz88vz8vJuEI/H+9Xvj2Bw8J3fbC69Sai5
- 46302nPlSMPtl8wI9ILc3FwpJydnv8lk7pJlFSMj45idjWN5+YcGNXe8WTuVZUv357DFM18v/pheYDQa
- SZssBzAw8BZjYyq83ocxny+C5scBHO9Sfjo9QZy88xGnvSH0JAARVovbA/VaQVZWFjlVVlb+VFFmUFBw
- qDszM7NdlsM40TmJe9+B5imgIfiHlhngYOu4qhXwSUlJkdLS0hzp6ekdqampBzinp5dwsccHY2PfUnbT
- q7A2L7yYs34AdjW/VndfeaO/AfOCbIH4rJKZGAyGRlHUSag39hlne6cyzj0J7qzvPy9K9G8gnm2CHQKj
- YM+/2H7mwSODs9sltMhI0i+I3fKHiOg60AAAAABJRU5ErkJggg==
+ R0lGODlhEAAQAIECANji87HH6f///wAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAACACwAAAAAEAAQ
+ AAAIRAAFCBxIsKDBgwYDKFzIUCHBAAAiSpwY4OHEiwAqDoSIUaJGgRw7ZrQocuTGkiZBovwoIGRHli4x
+ wlz5sKFNhDhzHgwIADs=
</value>
</data>
<data name="icon_pan_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2366,18 +2384,16 @@
<data name="plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\plus.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
- <data name="sort-number" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_viewoptions_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABsUlEQVQ4T42TS0sCARSFJwMJ
- QWoXCFJEtAhqE/4EN4E7V+rGELWmDJRwREH3bgV/hAu3bvwF4kaC1iIIvvCFIr5u99xyGIcChY/7OucM
- w6CiaZqSSqX2yGQySjabvWbCqJjNGviISPkvAKYICwgVs1mjBySTySsefEzEyHa7pc1mQ6jmG+ODTwIS
- iYS/3W5/rtdrMrJarXTMN+jhk4BYLPa8XC5psVgcDPTwSUA0Gn3BcjabUblcpmKxKL2RarUqe1TM0MMn
- AcFgUJ3P5zSZTIR8Pq/35t2uQg+fBPj9/tfpdErD4VBIp9NSG42G3pdKJel3M/TwSYDX630bj8fU7/cF
- VVX13kitVqN4PC499PBJgMfjiSG10+lQLpejQCAgFfOOQqFAoVCIKpWKzNDDJwFut/t9MBjg0xwM9PBJ
- gMvleqrX61+9Xo+63a5Oq9XSMe6hgx4+CXA6nTcOhyPMfBgZjUbUbDYJ1XxjwvBJAA+KzWbbw2q13jIa
- 3hUVs1ljt9t//gu/Pwtzylwwd8yDxWJ5ZDRUzMw9c8mcMcfMXsARc8LgeM44/gB73KHDAzmAlG9yoVrY
- r1VqEQAAAABJRU5ErkJggg==
+ R0lGODlhEAAQAIUAAAAAAP////39/vv7/Pr6+/n5+vj4+fb299DR1M/Q0+bn6eXm6OPk5n6Ejs3P0oyT
+ nM7T2bG3vs/R087Q0vf4+fb3+PX29/T19vP09ebn6OXm5+Tl5uPl5vb4+PT29v3+/vz9/fr7+/n6+vj5
+ +ff4+Pb3987Uz8/W0M7Vz4qgitHX0dDW0OLm4uTn5P7+/v39/fz8/Pv7+////wAAAAAAAAAAAAAAAAAA
+ AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAyACwAAAAAEAAQ
+ AAAItgBlCBxIsKCMCAgTKlyIEILDhxAhNojwoKLFixcnBgjgwsWHFzBCwhgQIkQBjR0/hhzAsqSIERNT
+ tkgxsmQIAi9hRnCRYuaKAQgkCJWQYASJiQJUpPgZQ0GGpws0kOgwEeTPmwVGaB1BoUOFiSBGskiR1YDZ
+ rhUsTISRYiyKERPiTnBQwoKHiQNOpHg7YgOHvwzsXpgYg4AJrRQqKE7r4cLgCASycu1wwILlxhcwTGzA
+ ubPnzwEBADs=
</value>
</data>
<data name="globe--pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2400,19 +2416,20 @@
sqyQRNffJTG6Zn6yO3tne0KYzfLM44+QMobCHt3/A5ZjeeoR8gsfww31jk5/egAAAABJRU5ErkJggg==
</value>
</data>
- <data name="arrow-curve-180-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="drive-download" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEElEQVQ4T6XTXUiTYRQH8BMr
- EUPnR9NmgRIjNuxr2hIaZNFFb3UXo5sS+7QgM7DANoI0IUhbn5DuIi2oFEQ0i6mBRSl1sWeDUltfkrCi
- zUklRS1ZnP7PsLHRiEYP/HgOzznn/169xMz/JeFjMshQL2hV4xituTROZsc7KmsNKOBYd9VPkvGsN0rO
- FTV4aOmJJ6SzDkfEB7T4FISIWbT6wuskAi6+URAiHO+Z5V1y7mXc8l8DVp4ZVdCMLDd5wyzrGC5wgh1z
- pj8C9HUuBSGi2cdcc/8r2x5/41OeENe7Q1wnQnzS9Z1rh7/82HsnMLX2/OgIZq0ISIsGLKl9JC6//ckH
- 736Ks7snyJZ2H29ufcUbW8Z4w5VnvKXtRdjU5B7HjrXw2AMqqBkkWnzknrKoekA0Pp/hyt6PfKB/mrcP
- fOb1vVNs7g5yadckGzsnuagjwLobfjbc/BAusA2N5B/uN2kPOYmwTJr9PcqCfd2iSszwssEwy/o3TeVt
- d25139OF1ode7WnPRM41/3RO80QQPTsQZZSWk3prA2XsbFfSd9wSxUPM8s7a1UnZe7pIXd4xF7JAD5vQ
- s6dX9blxO4GiR5VnoJSy40qqpU1Iqlz9bCf+pCzfJudssTNzYB6kQabKWGFRmY9eR60DA6yAYiiJhRn5
- +UKIBKhAhqTCfFBDNmggD7SQn0Bmwh8kGQkf/x3TL/u/9NmKeOePAAAAAElFTkSuQmCC
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACR0lEQVQ4T42OX2hScRTHD0FF
+ hEG3f9Aftv5ApVIPF0r2soU9BeIkDRnGKkhBYmOMoVu0BesWvSx6KrbwJXqwP2BYqY2l+ae0WcN2zZy5
+ tfWQvqztYeUkPP2O7MpdsepePnDu+X6+hwuNruJK8K4v2CSkKk00/5bVgEPX3tc4fH0cGm7NSNhvf/p5
+ pTO4INAs7cmRd6C+K1hjjzMMBy+PAj+QJR7cTC+mbd7ZNJvv044ycuSdZR8U7uuJwf5LcVD1v0v2v5nH
+ E0MfkWbaUfbXA7sdL28wwb9E0h6eRfWdSaRZ2pMj78DO9uc1drQFLHsvhtMdqTKeTy4i71/ATe55bBz5
+ jsbYD6xzhkRy5J1lB7Zf8AF37pFlW0dA1I1WcLOvgqseV1AdquCWdr9IGTnyDhxpFaocPXMVDlhdsPHs
+ Q1hvvmvZYPOIDTHE+hFEhdUj0o4ycsiVeqDX66sYDAYwmUxw3GyHXacGYHXzkGVtq3t8DYNm2lFGDrlS
+ 748DEsdOWkHV3FVH0CzPVjqgMBqNLQzbP2ght3ZAp9NJnI5EIhOpVAoTiTiGQi/Q53uGXq+X8YQRYATR
+ 7X46Qa7UA57nQavVEm3lchlLpRLOzX3DQuErTk9/xnw+z5hkzGAymcFstoDkUoe61UelUoFGo+ksFovo
+ 8XhQEATs6+vF7m4nOhxEL0NAK3vj8QySSx3pWcfYqlQqe9jvTuVyOcxkPuDY2Fsmv8ZoNMqIMRI4PPwK
+ BwfvTZFLnaUucAy1QqEwcxwn/A/kUgcAuF+i7LTexweyfwAAAABJRU5ErkJggg==
</value>
</data>
<data name="color" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2434,22 +2451,17 @@
AAAAAElFTkSuQmCC
</value>
</data>
- <data name="cross-circle-frame" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="document" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACvElEQVQ4T22SXUiTYRTHHxIZ
- azfKzDEpRIUFXqikIky24JXZUNyHU7tRU7ILZXThbpwM+7gQL6OMWiLTNxA/lpqGSGTOVk5r7XVrvZqb
- m6iMZeBFN16envM0YUYHfryHc/6/h+eBlxiNRmIymUhjYyOxWCykqanpUnNzs5aCdTsFlhZ3mMEsOuim
- HyChS43NZuvb2NgIHR8fQyKRYGDv8/lCvb29fZjB7L8HSMxmc4PL5RpH4dvkJKzbbLDCcQzsQ3R2dHQI
- o6Oj45hFhx1gMBiQ63TBx+NxWOvsBEGvh5/0+7unh5Hs6IBAbS3bRaMRcDqdPDrokvr6eoXVanXs78fh
- XXsb/LBYACvW0nIOrO8GA8vs7OxAd3e3A12i1+u51dX34Y8jL+BzTQ0LntVXnY6RXl6NBrzO57C4uBBG
- l+h0ula81lJXF4hGI8wUFbHg6ekpJJNJiMViEIlEYG9vD0ays2GppIRl/f4vgC7hOM4qCAK8qqyEUF0d
- LNPAmFwOgUAAgsEgiKJI3x0FF5V5ymx+Pst6vV5Al2i12rt+vx+mysths7oaZnNywE2D6fLBwQGbIa+V
- Spb1eDyALlGr1Z2CsAWz7bdgrbgYlv8jn/0LuHujULCsx/MB0CVVVVU3pqfd228fP4X5wsJz8jwVEJRP
- Tk4YM3l5sPxoGFwufhtdUlFRoTSbLYOBQBimDCbgc3OZvETFrRTYo8zT52Fmc3MLTCbzILqkrKyMlJaW
- 6gcGHrqDwQi8rGuA4aws+ESlcArscYY7QdgFh+OBGx10iUKhIAUFBVKVStVqt9+fE8UjWHk2BvzNNhhS
- 5jGwx5koHoLdfm8Os+igi3WBclEikVyWy+VtarXmycTEQnR39xekgzPcYYZmr6CTckkGRU5RUa5lZmZy
- Uqn0jkwm66cMpejHGe4wQ7n61yEZfwCPJRsF7cBiYgAAAABJRU5ErkJggg==
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABnElEQVQ4T42SP0tCURjG31Xa
+ HGpqELRBgoaGpCEhCLpQUWTg4OJgJSWhSKKlQksfoK9gH6DFD+BnqKEpCjQRqbz+vf47vc/lvkFQpw78
+ hnt4nh/nvPdQqFCwOSgWt5nDP/Du5/O0l8vRbjZrQ9hwOOqOx+rdslSj11PVTke9tNvq2TRt7ioVhQzj
+ +ybAh8NxezhUTS6+tlrqqdlUj/W6eqjV1H21qm7LZYWFHOP7EuxkMkK8w4K3bvdHyU2p9IXPMC4ZArSV
+ TgsnvdFIffDxf5PgJLgOstKjzWRSOO3zDMx+XyuBAFnp0UYiISQGLOgMBloJBous9Gg9HhfOhpOJ6vEc
+ dBL8HWSlR2uxmJAcsWDAc9BJGryHrPRoNRoVUuPpVFl8DZ0E7wRZ6dFKJCKkJyzAKXQSk/eQlR4th8PC
+ +ZQfypgFOgkeG7LSI28wSEuhEMjgpU35FDpJl7+RRQdde80HArRgGBcQYOkkeGzIoiPLxczOBQJXTt9e
+ uA5mgsFChF+Md2LxN7LoOF1yM4sujyc14/df/wdk0SEi9yfyP5Btd7QayAAAAABJRU5ErkJggg==
</value>
</data>
<data name="funnel" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2497,23 +2509,19 @@
RK5CYII=
</value>
</data>
- <data name="icon_ctxarrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_zoom_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhBAAIAIcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/AP//AAAA//8A/wD/////
- /wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
- AAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAzAAAzMwAzZgAzmQAzzAAz/wBmAABmMwBmZgBm
- mQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDMAADMMwDMZgDMmQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD/
- /zMAADMAMzMAZjMAmTMAzDMA/zMzADMzMzMzZjMzmTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZ
- MzOZZjOZmTOZzDOZ/zPMADPMMzPMZjPMmTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYA
- mWYAzGYA/2YzAGYzM2YzZmYzmWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ
- /2bMAGbMM2bMZmbMmWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kzAJkz
- M5kzZpkzmZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nMAJnMM5nMZpnM
- mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wzAMwzM8wzZswzmcwzzMwz
- /8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zMAMzMM8zMZszMmczMzMzM/8z/AMz/
- M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8zAP8zM/8zZv8zmf8zzP8z//9mAP9mM/9mZv9m
- mf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///MAP/MM//MZv/Mmf/MzP/M////AP//M///Zv//mf//zP//
- /yH/C05FVFNDQVBFMi4wAwEBAAAh+QQAAAAAACwAAAAABAAIAAAIFAABPBgIQOCDggIRKlR40KDBBwEB
- ADs=
+ R0lGODlhEAAQAIZfAHaFlJ2Sh9HW3Ojt8uDPvuPp79Tg5fP19uzw9O3x9OLo7t3l7PP1956foLa2t52d
+ nZ2dnM/R0tPU1ZKSk6SmqPX2987P0NHT1vDz9eDl6b29veTn6dzg5KqsreTo7KKkpsbZ26enqNba3e/y
+ 9b+/wJubm7zEy4eHh7rH09Lc5tbY2tfg6M/OzvHz9sXHysvMzsrKypKTk9vd4LGwsKymoP///4KCgra8
+ wvDy87q7vdTZ3cvO0MvT28XFxeDj5a2trczT2+zw8+jp6uPl5tTd5uTo683V3Le4ucjKzLa8wcLDw7q/
+ w/T2983X4evt76GgoOTq7/n6+u/x9K2vsNjh6dTa4LSzs8vR2fHz9ba3uO3v8c/S1PH09szLy/L09QAA
+ AABfACwAAAAAEAAQAAAIqwC/CGRh5cmMLgITAkj4pYcEGRxEvNDAcKFAJT60eDkgxYOOLF8AiBQJI8KB
+ GlEYjAgCZQkJgRZ/DKngBAsGBAMUXHkAUyAEHEyKZEiQcwGREwy/hBDCgAvRAgaoAJlgYiSAHBZa4IQK
+ IsWNDklVONgwoMCCJiiMfNiS9AsSBy6qrOCRhEKDtgIvHClhI8aUHQ0CEMDbVkAAwYSTGkacOOHiwY0F
+ GqYR2bHAgAA7
</value>
</data>
<data name="icon_selectwithin_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
@@ -2539,23 +2547,34 @@
uPYq3iQFR8gl8oX8pEC7K+QY2REcICfIGXKRwjlyihwieBdyv/eQHRy2xoTtAAAAAElFTkSuQmCC
</value>
</data>
- <data name="icon_panup_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <data name="icon_invokescript" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- R0lGODlhEAAQAIZuAJumsOTY2MS5uK+2vcW5uJumstrOzsi9vOHV1eHU1ZunsuXZ2dve4d7S0aaxvuTX
- 2ObZ2aaxvePY2NnNzODU0+HT1Ofb2sTJ0c7Jyfjz9J+rttvPztrPzpumsdbS0pqmsdfR0dbS0aSvupum
- s9zPz9/T08/ExMzFxNbKydfOzdXJyqOuutjMy9zQz8fP1tvPz97R0dLLytfLysG2ttPQ08vEw6Ouucq9
- vs/Dw6eyvuLW1eXX1+TY1+DW1sa8u+LV1vj09dTQ0NPHx8i/v9fKy+PX1pynsc3BwaSvu+fZ2tTIx+PX
- 18m9vJqlsNLMzMK4t8zAv9zQ0P///9TR0KGsuObY2Mu/v6CrtqSwu6mxu8m/vubZ2pqmst7T0tXKydXJ
- yc/Jyca9vcbL0si8u7e9xK+3v5+rt8zDw9PHxtjPztrX1+fa28/S2NTMzAAAAAAAAAAAAAAAAAAAAAAA
- AABuACwAAAAAEAAQAAAIxADdCBxIcKCRgggHMgDAQOCLAARSgEE4AMAANz2gcIAgwIIWNQUBCKyxgACJ
- BwLWnAlCUKSbEyYCCDDAQ8CWLm0GunTjA00VAhseCEkiIUbCGS0CKKFQIcECCSESjgmwpASFHzsCpCl4
- JAqCGxMqIEigowgEGgRBPGnQAIcKGQZgGMjA5uJAD0NQTPDC4gsRIGIimClT0ImVAweYSLmgIQKWK1kQ
- TsEQxoWCESIcrOCSUCCZAgWaUMlho7NAJAU+dFDgICAAOw==
+ R0lGODlhEAAQAIU6AEtypf///9bn92+wPq3D3hExZKq+r3ugdmupO1WHSD14K7fH3Jiymb7M37HMxlmP
+ RFeLTVyTSVuQRY/SS6DfUZjYTl6fN1iORJ6xxny6Qn+og4jHR5vbTzJpMpvbUIjGR3Gad4/RS4nISHvB
+ RIrOSXCzP5/eUaDeUJ7dUJPVTYfKSIbLSIDGRnWPsoLHR2WkOT95LD11Pp3cUJPVTIPCRZ6+rIPDRWak
+ OZfYTnGzQAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAA6ACwAAAAAEAAQ
+ AAAIuAB1CNSBAYDBgwgxDNRhsEGAhxADNACwEMBEARgzYqQ4EEAAhCA5CvRIoKRJAgUWGjgQAwYEDQ4y
+ ohzIQAKCATJEIIhQA+NMHQYkZBgQYAAFChkixPx5AMEJokVRmECgQcDPBB84QC3qYQMEqyl1KKiAY2vR
+ CgoItAibgEaKrSFm2OhQoMACgQdeTICqgsSEGyAW3BVo4MEAoixcrBjwwMBCgQwuWMgxooSFCwweD1yZ
+ QEGCA441BwQAOw==
</value>
</data>
- <data name="layer-shape-polygon" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\layer-shape-polygon.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="clipboard-paste" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACbUlEQVQ4T43SS0iUURQH8LNJ
+ aCdCBVGrcmzCwvGVD9LJohrBYMwcx7eljY05OJpjMIFFWhSJwSQVZQ/T3lkumqBNIIEtbmgPqCSEKGtR
+ COXYzPj6d8+X301d9cHvm8v9zjmce+bSuUzSdJj/OWQxRuTl5eVKjjm5vDc/Rs+bX+CiJNgJEw11HXZ9
+ HR7+CMZr3tO/c6wq4JOvOeJDx1701aZhYOA1BgffY2Tki4bXvMff3vnKwbF6Hp3drIg37cW4URaLS7a1
+ uF6yHrf2xeFOVTy6yzfgSmEMeio24lVbIThWz6O2NEUMnbHj+dEcPGkway40WtHeZFfON1egs9WBlu3L
+ 3tYVZZDLnk50OkURL0/l45l3p+LzluD3zAx+TU7iRyiE0UAAff39qLOlfrJ6vdE5Hg/RySRFvGix4qln
+ q9LmKcDE1BTGJibwfXwcn8fG0OP3gx+Z7JQMdDyBdILbf+zO0PDAjjlzEJyexs9gUBXxdXcr0RbLEWqO
+ I53gth8cSNYGebkgGo1lWQjLIwTC4QVFuJNRud5WU+MibyzphL8+E1eL1qHTbtA0lGZhShYIyhksLsIz
+ yaiqclOTkXTiYU0KrhUbFXfJFszMziIsj7G4CA82pbS0geoNpBO9skCXbF/nKjJjVg5sWnaxuEhAruNt
+ Ng/tXknkWqMRvc5N2mXRVeenaxPnItwJH4dnwoMNyd+Y7GyvvEpEu1YQOVb/LXC70qTUWuNRYDEtYM82
+ Icm46lukydQalZhYyflLpeV7Ikk8Opiq/Qv3q5Nwz5Go3N2foOFrzTiWc+ZyKUqKTV5CN3dEkPgfHMs5
+ RBT1B7y5F+bFJBNnAAAAAElFTkSuQmCC
+</value>
</data>
<data name="map" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -2575,24 +2594,8 @@
AAAAAElFTkSuQmCC
</value>
</data>
- <data name="layers-stack-arrange-back" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
- <value>
- YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC2klEQVQ4T4WQe0hTURzHzz/9
- Jf0TFf3RA5KeSGFG0D8VZBGEJEh/ZEj5wgoxMR8Y9oAeGFSU5EBrganMudbcnM5NbZtzd65N5+Zybne7
- 2+5ed083txVCcDpnlgyR+sGHw73n++B3wKHi16CgZTxDxdMQqHwWLql6HqEQ8D9QWLtuxpxpJUBpG00J
- VfFlVzgtc4ZSY5uB77AGa7MD9iKuFDboYKfUbmofWprejLcjNoXEwAioYEpadNcM1wNONMuK5ebQ0AjB
- QGcoHbIHkr6NOJiUX70UoV+KluQ2f1J8tnw6E5BpRgEs3NzYPQ9ZUkesY5QMZtM94WBkxiBtQ0GPuGbV
- d09iOL9kFK436+xRM27WWiIQtf1EDem/kIHkD/VSONU5Zg8gI93ab1QaXXHhwUt8CPKbpGV4H/GsX2Ny
- J7ySb344Ry2n9Y7YSjZW30r6hcASQEa6sceg1DuWBfsLeRAcvye5gfcRaL0EMtIiwge1ZCylsUUT2SzQ
- idQTntmPwlx1bL0C/ePnXhBCcKxhtBzvw1W7CS0ZpfkqL5xaDCfHTcFliSEQE88GosOz/qjKEkk84Jj8
- hDXqvNWlVUxZwvwjlychyKsXV+J9PimoaeVi2MmWuKFQ54t/nvFGsvlqDsVbeud9SENVvNMo0fklv0QP
- wdE6UTXep2PUqkRGG2vYtdor9/ziaTzxQQyxxsRCMNnSawihZm89W2fo4DKR09dJChyuHapBaQOPuaZJ
- /oyX/DDudnYI3atvBDTMhiNnYGm7AXaJQvBk9Rw8V+Fz5Z1nl4EDt/l3xuaZvocDRtnHSQfFJTwkR03b
- NoLehMbN7AlSvPtmXxUAYBciB+TW8GplRob7SmTpud83J2/u0RNNWeBvTLfMurCnvF+8/SqrfuupGwVb
- tu1DfjQ47b3MKpIamcGRuQBnM/Ad1vxpzkXkZMx4cBpO3XGN3fYvsCYnr+gisuxcc+IB4DeW/K1D9pQD
- QwAAAABJRU5ErkJggg==
-</value>
+ <data name="magnifier-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\magnifier-left.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="icon_copy_disabled" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
@@ -4460,7 +4463,7 @@
WRHmNwI5+469uwsj25aTaAHwF5D4p3XcStYrAAAAAElFTkSuQmCC
</value>
</data>
- <data name="layer-small" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\Resources\layer-small.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <data name="application-form" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\application-form.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/application-form.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/application-form.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2014-05-27 07:43:52 UTC (rev 8171)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2014-05-27 11:53:02 UTC (rev 8172)
@@ -181,6 +181,34 @@
/// <summary>
+ /// Parses a color in HTML notation (ea. #ffaabbff)
+ /// </summary>
+ /// <param name="color">The HTML representation of the color</param>
+ /// <returns>The .Net color structure that matches the color</returns>
+ public static Color ParseHTMLColorARGB(string color)
+ if (color.Length == 8)
+ int a = int.Parse(color.Substring(0, 2), System.Globalization.NumberStyles.HexNumber);
+ int r = int.Parse(color.Substring(2, 2), System.Globalization.NumberStyles.HexNumber);
+ int g = int.Parse(color.Substring(4, 2), System.Globalization.NumberStyles.HexNumber);
+ int b = int.Parse(color.Substring(6, 2), System.Globalization.NumberStyles.HexNumber);
+ return Color.FromArgb(a, r, g, b);
+ else if (color.Length == 6)
+ int r = int.Parse(color.Substring(0, 2), System.Globalization.NumberStyles.HexNumber);
+ int g = int.Parse(color.Substring(2, 2), System.Globalization.NumberStyles.HexNumber);
+ int b = int.Parse(color.Substring(4, 2), System.Globalization.NumberStyles.HexNumber);
+ return Color.FromArgb(r, g, b);
+ else
+ throw new Exception(string.Format(Strings.ErrorBadHtmlColor, color));
+ /// <summary>
/// Returns the HTML ARGB representation of an .Net color structure
/// </summary>
/// <param name="color">The color to encode</param>
@@ -215,6 +243,23 @@
/// <summary>
+ /// Returns the HTML ARGB representation of an .Net color structure
+ /// </summary>
+ /// <param name="color">The color to encode</param>
+ /// <param name="includeAlpha">A flag indicating if the color structures alpha value should be included</param>
+ /// <returns>The HTML representation of the color structure</returns>
+ public static string SerializeHTMLColorARGB(Color color, bool includeAlpha)
+ string res = string.Empty;
+ if (includeAlpha)
+ res += color.A.ToString("x02"); //NOXLATE
+ res += color.R.ToString("x02"); //NOXLATE
+ res += color.G.ToString("x02"); //NOXLATE
+ res += color.B.ToString("x02"); //NOXLATE
+ return res;
+ /// <summary>
/// Parses a string with a decimal value in EN-US format
/// </summary>
/// <param name="digit">The string value</param>
More information about the mapguide-commits
