[mapguide-commits] r8174 - in sandbox/jng/tiling: Common/MapGuideCommon/Services Server/src/Services/Rendering Server/src/UnitTesting
svn_mapguide at osgeo.org
Thu May 29 09:06:16 PDT 2014
Author: jng
Date: 2014-05-29 09:06:16 -0700 (Thu, 29 May 2014)
New Revision: 8174
sandbox/jng/tiling/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
sandbox/jng/tiling/Common/MapGuideCommon/Services/ProxyRenderingService.h
sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingDefs.h
sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingService.h
sandbox/jng/tiling/Server/src/Services/Rendering/OpRenderTile.cpp
sandbox/jng/tiling/Server/src/Services/Rendering/RenderingOperationFactory.cpp
sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.cpp
sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.h
sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.vcxproj
sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.vcxproj.filters
sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingServiceBuild.cpp
sandbox/jng/tiling/Server/src/UnitTesting/TestRenderingService.cpp
sandbox/jng/tiling/Server/src/UnitTesting/TestRenderingService.h
Add new APIs to MgRenderingService:
- RenderTile overload that accepts tile width, tile height, tile dpi and tile image format.
- RenderTileXYZ, allows rendering of tiled maps as XYZ tiles similar to Google Maps, OSM and similar maps.
New unit tests added to exercise these APIs.
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Services/ProxyRenderingService.cpp
--- sandbox/jng/tiling/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Services/ProxyRenderingService.cpp 2014-05-29 16:06:16 UTC (rev 8174)
@@ -106,7 +106,92 @@
return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
+MgByteReader* MgProxyRenderingService::RenderTile(
+ MgMap* map,
+ CREFSTRING baseMapLayerGroupName,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ CREFSTRING tileImageFormat)
+ MgCommand cmd;
+ cmd.ExecuteCommand(m_connProp, // Connection
+ MgCommand::knObject, // Return type expected
+ MgRenderingServiceOpId::RenderTile2, // Command Code
+ 8, // No of arguments
+ Rendering_Service, // Service Id
+ BUILD_VERSION(3,0,0), // Operation version
+ MgCommand::knObject, map, // Argument#1
+ MgCommand::knString, &baseMapLayerGroupName, // Argument#2
+ MgCommand::knInt32, tileColumn, // Argument#3
+ MgCommand::knInt32, tileRow, // Argument#4
+ MgCommand::knInt32, tileWidth, // Argument#5
+ MgCommand::knInt32, tileHeight, // Argument#6
+ MgCommand::knInt32, tileDpi, // Argument#7
+ MgCommand::knString, &tileImageFormat, // Argument#8
+ MgCommand::knNone); // End of arguments
+ SetWarning(cmd.GetWarningObject());
+ return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
+MgByteReader* MgProxyRenderingService::RenderTileXYZ(MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z)
+ MgCommand cmd;
+ MgRenderingServiceOpId::RenderTileXYZ, // Command Code
+ 5, // No of arguments
+ MgCommand::knInt32, x, // Argument#3
+ MgCommand::knInt32, y, // Argument#4
+ MgCommand::knInt32, z, // Argument#5
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
+ MgCommand cmd;
+ MgRenderingServiceOpId::RenderTileXYZ2, // Command Code
+ 7, // No of arguments
+ MgCommand::knInt32, dpi, // Argument#6
+ MgCommand::knInt32, &tileImageFormat, // Argument#7
/// <summary>
/// Renders all dynamic layers in the specified MgMap to a dynamic overlay image
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Services/ProxyRenderingService.h
--- sandbox/jng/tiling/Common/MapGuideCommon/Services/ProxyRenderingService.h 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Services/ProxyRenderingService.h 2014-05-29 16:06:16 UTC (rev 8174)
@@ -58,6 +58,127 @@
/// \brief
+ /// Returns the specified base map tile for the given map.
+ /// \remarks
+ /// This method only renders the given tile. No tile caching is performed
+ /// by this method. To render and cache the tile, use the
+ /// \link MgTileService::GetTile GetTile \endlink method instead. However,
+ /// using that method will use default tile width/height/dpi/format specified
+ /// in your MapGuide Server configuration
+ /// \param map
+ /// Input
+ /// map object containing current state of map.
+ /// \param baseMapLayerGroupName
+ /// Input
+ /// Specifies the name of the baseMapLayerGroup for which to render the tile.
+ /// \param tileColumn
+ /// Input
+ /// Specifies the column index of the tile to return.
+ /// \param tileRow
+ /// Input
+ /// Specifies the row index of the tile to return.
+ /// \param tileWidth
+ /// Input
+ /// Specifies the width of the tile to return.
+ /// \param tileHeight
+ /// Input
+ /// Specifies the height of the tile to return.
+ /// \param tileDpi
+ /// Input
+ /// Specifies the dpi the tile to return.
+ /// \param tileImageFormat
+ /// Input
+ /// Specifies the image format of the tile. See \link MgImageFormats \endlink
+ /// \return
+ /// A byte reader containing the rendered tile image.
+ virtual MgByteReader* RenderTile(
+ MgMap* map,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ CREFSTRING tileImageFormat);
+ /// \brief
+ /// Returns the specified map tile for the given map. Tile structure is
+ /// based on the XYZ tiling scheme used by Google Maps, OpenStreetMap, and
+ /// others
+ /// \param map
+ /// Input
+ /// Input
+ /// \param x
+ /// Input
+ /// \param y
+ /// Input
+ /// \param z
+ /// Input
+ /// Specifies the zoom level of the tile to return.
+ /// \return
+ virtual MgByteReader* RenderTileXYZ(
+ MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z);
+ /// \brief
+ /// others
+ /// \param map
+ /// Input
+ /// Input
+ /// \param x
+ /// Input
+ /// \param y
+ /// Input
+ /// \param z
+ /// Input
+ /// \param dpi
+ /// Input
+ /// Specifies the dpi of the tile to return.
+ /// Input
+ /// Specifies the image format of the tile to return.
+ /// \return
+ MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
+ /// \brief
/// with a transparent background. The center, scale, size, and layers to be
/// rendered are defined by the specified map instance. The format parameter
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingDefs.h
--- sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingDefs.h 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingDefs.h 2014-05-29 16:06:16 UTC (rev 8174)
@@ -40,6 +40,9 @@
static const int RenderDynamicOverlay2 = 0x1111E90C;
static const int RenderMap5 = 0x1111E90D;
static const int QueryFeatureProperties2 = 0x1111E90E;
+ static const int RenderTile2 = 0x1111E90F;
+ static const int RenderTileXYZ = 0x1111E910;
+ static const int RenderTileXYZ2 = 0x1111E911;
/// \endcond
Modified: sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingService.h
--- sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingService.h 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Common/MapGuideCommon/Services/RenderingService.h 2014-05-29 16:06:16 UTC (rev 8174)
@@ -70,6 +70,127 @@
/// \brief
+ /// \remarks
+ /// \param map
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ CREFSTRING tileImageFormat) = 0;
+ /// \brief
+ /// others
+ /// \param map
+ /// Input
+ /// Input
+ /// \param x
+ /// Input
+ /// \param y
+ /// Input
+ /// \param z
+ /// Input
+ /// \return
+ MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z) = 0;
+ /// \brief
+ /// others
+ /// \param map
+ /// Input
+ /// Input
+ /// \param x
+ /// Input
+ /// \param y
+ /// Input
+ /// \param z
+ /// Input
+ /// \param dpi
+ /// Input
+ /// Input
+ /// \return
+ MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
+ /// \brief
Modified: sandbox/jng/tiling/Server/src/Services/Rendering/OpRenderTile.cpp
--- sandbox/jng/tiling/Server/src/Services/Rendering/OpRenderTile.cpp 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/Services/Rendering/OpRenderTile.cpp 2014-05-29 16:06:16 UTC (rev 8174)
@@ -94,6 +94,60 @@
EndExecution(byteReader);
+ else if (8 == m_packet.m_NumArguments)
+ Ptr<MgMap> map = (MgMap*)m_stream->GetObject();
+ Ptr<MgResourceIdentifier> resource = map->GetResourceId();
+ map->SetDelayedLoadResourceService(m_resourceService);
+ STRING baseMapLayerGroupName;
+ m_stream->GetString(baseMapLayerGroupName);
+ INT32 tileCol = 0;
+ m_stream->GetInt32(tileCol);
+ INT32 tileRow = 0;
+ m_stream->GetInt32(tileRow);
+ INT32 tileWidth = 0;
+ m_stream->GetInt32(tileWidth);
+ INT32 tileHeight = 0;
+ m_stream->GetInt32(tileHeight);
+ INT32 tileDpi = 0;
+ m_stream->GetInt32(tileDpi);
+ STRING tileImageFormat;
+ m_stream->GetString(tileImageFormat);
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resource) ? L"MgResourceIdentifier" : resource->ToString().c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(baseMapLayerGroupName.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileCol);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileRow);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileWidth);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileHeight);
+ MG_LOG_OPERATION_MESSAGE_ADD_INT32(tileDpi);
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(tileImageFormat.c_str());
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+ Validate();
+ Ptr<MgByteReader> byteReader =
+ m_service->RenderTile(map, baseMapLayerGroupName, tileCol, tileRow, tileWidth, tileHeight, tileDpi, tileImageFormat);
+ EndExecution(byteReader);
else
Modified: sandbox/jng/tiling/Server/src/Services/Rendering/RenderingOperationFactory.cpp
--- sandbox/jng/tiling/Server/src/Services/Rendering/RenderingOperationFactory.cpp 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/Services/Rendering/RenderingOperationFactory.cpp 2014-05-29 16:06:16 UTC (rev 8174)
@@ -73,6 +73,42 @@
break;
+ case MgRenderingServiceOpId::RenderTile2:
+ switch (VERSION_NO_PHASE(operationVersion))
+ case VERSION_SUPPORTED(3,0):
+ handler.reset(new MgOpRenderTile());
+ break;
+ default:
+ throw new MgInvalidOperationVersionException(
+ L"MgRenderingOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
+ break;
+ case MgRenderingServiceOpId::RenderTileXYZ:
+ handler.reset(new MgOpRenderTileXYZ());
+ break;
+ default:
+ break;
+ case MgRenderingServiceOpId::RenderTileXYZ2:
+ break;
+ default:
+ break;
case MgRenderingServiceOpId::RenderDynamicOverlay:
@@ -85,6 +121,7 @@
break;
case MgRenderingServiceOpId::RenderDynamicOverlay2:
Modified: sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.cpp
--- sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.cpp 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.cpp 2014-05-29 16:06:16 UTC (rev 8174)
@@ -29,12 +29,14 @@
#include "LegendPlotUtil.h"
#include "TransformCache.h"
#include "Box2D.h"
+#include <cmath>
// Profile
#include "ProfileRenderMapResult.h"
+#define XYZ_TILE_WIDTH 256
+#define XYZ_TILE_HEIGHT 256
// the maximum number of allowed pixels for rendered images
static const INT32 MAX_PIXELS = 16384*16384;
static const INT32 FILTER_VISIBLE = 1;
@@ -150,6 +152,33 @@
MG_TRY()
+ ret = RenderTile(map,
+ baseMapLayerGroupName,
+ tileColumn,
+ tileRow,
+ MgTileParameters::tileWidth,
+ MgTileParameters::tileHeight,
+ MgTileParameters::tileDPI,
+ MgTileParameters::tileFormat);
+ MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTile")
+ return ret.Detach();
+MgByteReader* MgServerRenderingService::RenderTile(MgMap* map,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ Ptr<MgByteReader> ret;
+ MG_TRY()
if (NULL == map || baseMapLayerGroupName.empty())
throw new MgNullArgumentException(L"MgServerRenderingService.RenderTile", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -178,7 +207,7 @@
scale = map->GetFiniteDisplayScaleAt(scaleIndex);
// ensure the tile DPI is set on the map
- map->SetDisplayDpi(MgTileParameters::tileDPI);
+ map->SetDisplayDpi(tileDpi);
// the upper left corner of tile (0,0) corresponds to the
@@ -194,9 +223,9 @@
double mapMaxY = rs_max(pt00->GetY(), pt11->GetY());
double metersPerUnit = map->GetMetersPerUnit();
- double metersPerPixel = METERS_PER_INCH / MgTileParameters::tileDPI;
- double tileWidthMCS = (double)MgTileParameters::tileWidth * metersPerPixel * scale / metersPerUnit;
- double tileHeightMCS = (double)MgTileParameters::tileHeight * metersPerPixel * scale / metersPerUnit;
+ double metersPerPixel = METERS_PER_INCH / tileDpi;
+ double tileWidthMCS = (double)tileWidth * metersPerPixel * scale / metersPerUnit;
+ double tileHeightMCS = (double)tileHeight * metersPerPixel * scale / metersPerUnit;
double tileMinX = mapMinX + (double)(tileColumn ) * tileWidthMCS; // left edge
double tileMaxX = mapMinX + (double)(tileColumn+1) * tileWidthMCS; // right edge
@@ -204,15 +233,153 @@
double tileMaxY = mapMaxY - (double)(tileRow ) * tileHeightMCS; // top edge
// make the call to render the tile
- ret = RenderTile(map, baseGroup, scaleIndex, MgTileParameters::tileWidth, MgTileParameters::tileHeight, scale,
- tileMinX, tileMaxX, tileMinY, tileMaxY, MgTileParameters::tileFormat);
+ ret = RenderTile(map, baseGroup, scaleIndex, tileWidth, tileHeight, scale,
+ tileMinX, tileMaxX, tileMinY, tileMaxY, tileImageFormat);
+MgByteReader* MgServerRenderingService::RenderTileXYZ(MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z)
+ MG_TRY()
+ ret = RenderTileXYZ(map, baseMapLayerGroupName, x, y, z, MgTileParameters::tileDPI, MgTileParameters::tileFormat);
+ MG_CATCH_AND_THROW(L"MgServerRenderingService.RenderTileXYZ")
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
+ MG_TRY()
+ if (NULL == map || baseMapLayerGroupName.empty())
+ throw new MgNullArgumentException(L"MgServerRenderingService.RenderTileXYZ", __LINE__, __WFILE__, NULL, L"", NULL);
+ // get the layer group associated with the name
+ Ptr<MgLayerGroupCollection> layerGroups = map->GetLayerGroups();
+ Ptr<MgLayerGroup> baseGroup = layerGroups->GetItem(baseMapLayerGroupName);
+ if (baseGroup == NULL)
+ MgStringCollection arguments;
+ arguments.Add(L"2");
+ arguments.Add(baseMapLayerGroupName);
+ throw new MgInvalidArgumentException(L"MgServerRenderingService.RenderTileXYZ",
+ __LINE__, __WFILE__, &arguments, L"MgMapLayerGroupNameNotFound", NULL);
+ //Set the dpi
+ map->SetDisplayDpi(dpi);
+ //XYZ to lat/lon math. From this we can convert to the bounds in the map's CS
+ //Source: http://wiki.openstreetmap.org/wiki/Slippy_map_tilenames
+ double nMin = M_PI - 2.0 * M_PI * y / pow(2.0, z);
+ double nMax = M_PI - 2.0 * M_PI * (y + 1) / pow(2.0, z);
+ double lonMin = x / pow(2.0, z) * 360.0 - 180;
+ double latMin = 180.0 / M_PI * atan(0.5 * (exp(nMin) - exp(-nMin)));
+ double lonMax = (x + 1) / pow(2.0, z) * 360.0 - 180;
+ double latMax = 180.0 / M_PI * atan(0.5 * (exp(nMax) - exp(-nMax)));
+ double mcsMinX = std::min(lonMin, lonMax);
+ double mcsMinY = std::min(latMin, latMax);
+ double mcsMaxX = std::max(lonMin, lonMax);
+ double mcsMaxY = std::max(latMin, latMax);
+ STRING mapCsWkt = map->GetMapSRS();
+ Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+ Ptr<MgCoordinateSystem> mapCs = csFactory->Create(mapCsWkt);
+ if (mapCs->GetCsCode() != L"LL84")
+ //Set up LL to map transform and transform the bounds into map space
+ Ptr<MgCoordinateSystem> llCs = csFactory->CreateFromCode(L"LL84");
+ Ptr<MgCoordinateSystemTransform> trans = csFactory->GetTransform(llCs, mapCs);
+ Ptr<MgCoordinate> ul = trans->Transform(lonMin, latMin);
+ Ptr<MgCoordinate> lr = trans->Transform(lonMax, latMax);
+ mcsMinX = std::min(lr->GetX(), ul->GetX());
+ mcsMinY = std::min(lr->GetY(), ul->GetY());
+ mcsMaxX = std::max(lr->GetX(), ul->GetX());
+ mcsMaxY = std::max(lr->GetY(), ul->GetY());
+ // Inlining same logic from RenderTile() overload below as we want the same logic, but we want to pass scale
+ // instead of scale index
+ double scale = 0.0;
+ double metersPerPixel = 0.0254 / dpi;
+ double mcsW = mcsMaxX - mcsMinX;
+ double mcsH = mcsMaxY - mcsMinY;
+ if (XYZ_TILE_HEIGHT * mcsW > XYZ_TILE_WIDTH * mcsH)
+ scale = mcsW * map->GetMetersPerUnit() / (XYZ_TILE_WIDTH * metersPerPixel); // width-limited
+ else
+ scale = mcsH * map->GetMetersPerUnit() / (XYZ_TILE_HEIGHT * metersPerPixel); // height-limited
+ // get map extent that corresponds to tile extent
+ RS_Bounds extent(mcsMinX, mcsMinY, mcsMaxX, mcsMaxY);
+ // use the map's background color, but always make it fully transparent
+ RS_Color bgColor;
+ StylizationUtil::ParseColor(map->GetBackgroundColor(), bgColor);
+ bgColor.alpha() = 0;
+ // the label renderer needs to know the tile extent offset parameter
+ double tileExtentOffset = 0.0;
+ MgConfiguration* pConf = MgConfiguration::GetInstance();
+ pConf->GetDoubleValue(MgConfigProperties::RenderingServicePropertiesSection,
+ MgConfigProperties::RenderingServicePropertyTileExtentOffset,
+ tileExtentOffset,
+ MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset);
+ if (tileExtentOffset < 0.0)
+ tileExtentOffset = MgConfigProperties::DefaultRenderingServicePropertyTileExtentOffset;
+ // initialize the renderer (set clipping to false so that we label
+ // the unclipped geometry)
+ auto_ptr<SE_Renderer> dr(CreateRenderer(XYZ_TILE_WIDTH, XYZ_TILE_HEIGHT, bgColor, false, true, tileExtentOffset));
+ // create a temporary collection containing all the layers for the base group
+ Ptr<MgLayerCollection> layers = map->GetLayers();
+ Ptr<MgReadOnlyLayerCollection> roLayers = new MgReadOnlyLayerCollection();
+ for (int i=0; i<layers->GetCount(); i++)
+ Ptr<MgLayerBase> layer = layers->GetItem(i);
+ Ptr<MgLayerGroup> parentGroup = layer->GetGroup();
+ if (parentGroup == baseGroup)
+ roLayers->Add(layer);
+ // of course the group has to also be visible
+ bool groupVisible = baseGroup->GetVisible();
+ baseGroup->SetVisible(true);
+ // call the internal helper API to do all the stylization overhead work
+ ret = RenderMapInternal(map, NULL, roLayers, dr.get(), XYZ_TILE_WIDTH, XYZ_TILE_HEIGHT, XYZ_TILE_WIDTH, XYZ_TILE_HEIGHT, tileImageFormat, scale, extent, true, true, false);
+ // restore the base group's visibility
/// render a map using all layers from the baseGroup
Modified: sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.h
--- sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.h 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.h 2014-05-29 16:06:16 UTC (rev 8174)
@@ -47,6 +47,29 @@
INT32 tileColumn,
INT32 tileRow);
+ virtual MgByteReader* RenderTile(MgMap* map,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 tileWidth,
+ INT32 tileHeight,
+ INT32 tileDpi,
+ virtual MgByteReader* RenderTileXYZ(MgMap* map,
+ INT32 x,
+ INT32 y,
+ INT32 z);
+ INT32 x,
+ INT32 y,
+ INT32 z,
+ INT32 dpi,
virtual MgByteReader* RenderDynamicOverlay(MgMap* map,
MgSelection* selection,
CREFSTRING format);
Modified: sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.vcxproj
--- sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.vcxproj 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.vcxproj 2014-05-29 16:06:16 UTC (rev 8174)
@@ -234,6 +234,12 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="OpRenderTileXYZ.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="RenderingOperation.cpp">
@@ -285,6 +291,7 @@
<ClInclude Include="OpRenderMap.h" />
<ClInclude Include="OpRenderMapLegend.h" />
<ClInclude Include="OpRenderTile.h" />
+ <ClInclude Include="OpRenderTileXYZ.h" />
<ClInclude Include="RenderingOperation.h" />
<ClInclude Include="RenderingOperationFactory.h" />
<ClInclude Include="FeatureInfoRenderer.h" />
Modified: sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.vcxproj.filters
--- sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.vcxproj.filters 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingService.vcxproj.filters 2014-05-29 16:06:16 UTC (rev 8174)
@@ -36,6 +36,9 @@
<ClCompile Include="RenderingServiceHandler.cpp" />
<ClCompile Include="ServerRenderingService.cpp" />
<ClCompile Include="ServerRenderingServiceBuild.cpp" />
+ <Filter>Ops</Filter>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="OpQueryFeatureProperties.h">
@@ -68,6 +71,9 @@
<ClInclude Include="ServerRenderingDllExport.h" />
<ClInclude Include="ServerRenderingService.h" />
<ClInclude Include="..\..\Common\stdafx.h" />
+ <ClInclude Include="OpRenderTileXYZ.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="ServerRenderingService.rc" />
Modified: sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingServiceBuild.cpp
--- sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingServiceBuild.cpp 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/Services/Rendering/ServerRenderingServiceBuild.cpp 2014-05-29 16:06:16 UTC (rev 8174)
@@ -24,6 +24,7 @@
#include "OpRenderMap.cpp"
#include "OpRenderMapLegend.cpp"
#include "OpRenderTile.cpp"
+#include "OpRenderTileXYZ.cpp"
#include "OpQueryFeatures.cpp"
#include "OpQueryFeatureProperties.cpp"
#include "RenderingOperation.cpp"
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestRenderingService.cpp
--- sandbox/jng/tiling/Server/src/UnitTesting/TestRenderingService.cpp 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestRenderingService.cpp 2014-05-29 16:06:16 UTC (rev 8174)
@@ -1597,6 +1597,87 @@
+void TestRenderingService::TestCase_RenderTileBaseline()
+ try
+ Ptr<MgMap> map = CreateTestTiledMap();
+ map->SetViewScale(12500.0);
+ Ptr<MgByteReader> tile4_6 = m_svcRendering->RenderTile(map, L"BaseLayers", 4, 6);
+ Ptr<MgByteReader> tile4_7 = m_svcRendering->RenderTile(map, L"BaseLayers", 4, 7);
+ Ptr<MgByteReader> tile5_6 = m_svcRendering->RenderTile(map, L"BaseLayers", 5, 6);
+ Ptr<MgByteReader> tile5_7 = m_svcRendering->RenderTile(map, L"BaseLayers", 5, 7);
+ tile4_6->ToFile(L"../UnitTestFiles/RenderTile_4_6_Baseline.png");
+ tile4_7->ToFile(L"../UnitTestFiles/RenderTile_4_7_Baseline.png");
+ tile5_6->ToFile(L"../UnitTestFiles/RenderTile_5_6_Baseline.png");
+ tile5_7->ToFile(L"../UnitTestFiles/RenderTile_5_7_Baseline.png");
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+void TestRenderingService::TestCase_RenderTile(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgByteReader> tile4_6 = m_svcRendering->RenderTile(map, L"BaseLayers", 4, 6, 300, 300, 96, imageFormat);
+ Ptr<MgByteReader> tile4_7 = m_svcRendering->RenderTile(map, L"BaseLayers", 4, 7, 300, 300, 96, imageFormat);
+ Ptr<MgByteReader> tile5_6 = m_svcRendering->RenderTile(map, L"BaseLayers", 5, 6, 300, 300, 96, imageFormat);
+ Ptr<MgByteReader> tile5_7 = m_svcRendering->RenderTile(map, L"BaseLayers", 5, 7, 300, 300, 96, imageFormat);
+ tile4_6->ToFile(GetPath(L"../UnitTestFiles/RenderTile_4_6_300x300 at 96", imageFormat, extension));
+ tile4_7->ToFile(GetPath(L"../UnitTestFiles/RenderTile_4_7_300x300 at 96", imageFormat, extension));
+ tile5_6->ToFile(GetPath(L"../UnitTestFiles/RenderTile_5_6_300x300 at 96", imageFormat, extension));
+ tile5_7->ToFile(GetPath(L"../UnitTestFiles/RenderTile_5_7_300x300 at 96", imageFormat, extension));
+ Ptr<MgByteReader> tile11_11 = m_svcRendering->RenderTile(map, L"BaseLayers", 11, 11, 256, 256, 96, imageFormat);
+ Ptr<MgByteReader> tile11_12 = m_svcRendering->RenderTile(map, L"BaseLayers", 11, 12, 256, 256, 96, imageFormat);
+ Ptr<MgByteReader> tile12_11 = m_svcRendering->RenderTile(map, L"BaseLayers", 12, 11, 256, 256, 96, imageFormat);
+ Ptr<MgByteReader> tile12_12 = m_svcRendering->RenderTile(map, L"BaseLayers", 12, 12, 256, 256, 96, imageFormat);
+ tile11_11->ToFile(GetPath(L"../UnitTestFiles/RenderTile_11_11_256x256 at 96", imageFormat, extension));
+ tile11_12->ToFile(GetPath(L"../UnitTestFiles/RenderTile_11_12_256x256 at 96", imageFormat, extension));
+ tile12_11->ToFile(GetPath(L"../UnitTestFiles/RenderTile_12_11_256x256 at 96", imageFormat, extension));
+ tile12_12->ToFile(GetPath(L"../UnitTestFiles/RenderTile_12_12_256x256 at 96", imageFormat, extension));
+ SAFE_RELEASE(e);
+void TestRenderingService::TestCase_RenderTileXYZ(CREFSTRING imageFormat, CREFSTRING extension)
+ try
+ Ptr<MgByteReader> tileTL = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 2099, 2985, 13, 96, imageFormat);
+ Ptr<MgByteReader> tileTR = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 2100, 2985, 13, 96, imageFormat);
+ Ptr<MgByteReader> tileBL = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 2099, 2986, 13, 96, imageFormat);
+ Ptr<MgByteReader> tileBR = m_svcRendering->RenderTileXYZ(map, L"BaseLayers", 2100, 2986, 13, 96, imageFormat);
+ tileTL->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_TopLeft", imageFormat, extension));
+ tileTR->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_TopRight", imageFormat, extension));
+ tileBL->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_BottomLeft", imageFormat, extension));
+ tileBR->ToFile(GetPath(L"../UnitTestFiles/RenderTileXYZ_BottomRight", imageFormat, extension));
+ SAFE_RELEASE(e);
STRING TestRenderingService::GetPath(CREFSTRING basePath, CREFSTRING imageFormat, CREFSTRING extension)
STRING ret;
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestRenderingService.h
--- sandbox/jng/tiling/Server/src/UnitTesting/TestRenderingService.h 2014-05-28 11:25:15 UTC (rev 8173)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestRenderingService.h 2014-05-29 16:06:16 UTC (rev 8174)
@@ -25,6 +25,8 @@
CPPUNIT_TEST_SUITE(TestRenderingService);
CPPUNIT_TEST(TestStart); // This must be the very first unit test
+ CPPUNIT_TEST(TestCase_RenderTileBaseline);
CPPUNIT_TEST(TestCase_StylizationFunctionsPNG);
CPPUNIT_TEST(TestCase_SymbologyPointsPNG);
@@ -50,6 +52,8 @@
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSPNG);
CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSPNG);
CPPUNIT_TEST(TestCase_LayerWatermarkPNG);
+ CPPUNIT_TEST(TestCase_RenderTilePNG);
+ CPPUNIT_TEST(TestCase_RenderTileXYZ_PNG);
CPPUNIT_TEST(TestCase_StylizationFunctionsPNG8);
@@ -76,6 +80,8 @@
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSPNG8);
CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSPNG8);
CPPUNIT_TEST(TestCase_LayerWatermarkPNG8);
+ CPPUNIT_TEST(TestCase_RenderTilePNG8);
+ CPPUNIT_TEST(TestCase_RenderTileXYZ_PNG8);
CPPUNIT_TEST(TestCase_StylizationFunctionsGIF);
@@ -102,6 +108,8 @@
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSGIF);
CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSGIF);
CPPUNIT_TEST(TestCase_LayerWatermarkGIF);
+ CPPUNIT_TEST(TestCase_RenderTileGIF);
+ CPPUNIT_TEST(TestCase_RenderTileXYZ_GIF);
CPPUNIT_TEST(TestCase_StylizationFunctionsJPG);
@@ -128,6 +136,8 @@
CPPUNIT_TEST(TestCase_RenderLegendMultiFTSSingleCTSJPG);
CPPUNIT_TEST(TestCase_RenderLegendSingleFTSMultiCTSJPG);
CPPUNIT_TEST(TestCase_LayerWatermarkJPG);
+ CPPUNIT_TEST(TestCase_RenderTileJPG);
+ CPPUNIT_TEST(TestCase_RenderTileXYZ_JPG);
CPPUNIT_TEST(TestCase_QueryFeatures);
@@ -146,6 +156,9 @@
void TestEnd();
void TestCase_QueryFeatures();
+ void TestCase_RenderTileBaseline();
+ void TestCase_RenderTile(CREFSTRING imageFormat, CREFSTRING extension);
+ void TestCase_RenderTileXYZ(CREFSTRING imageFormat, CREFSTRING extension);
//Parameterized versions that all format-specific tests call into
void TestCase_RenderDynamicOverlay(CREFSTRING imageFormat, CREFSTRING extension);
@@ -198,6 +211,8 @@
void TestCase_RenderLegendSingleFTSMultiCTSPNG() { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG", L"png"); }
void TestCase_StylizationFunctionsPNG() { TestCase_StylizationFunctions(L"PNG", L"png"); }
void TestCase_LayerWatermarkPNG() { TestCase_LayerWatermark(L"PNG", L"png"); }
+ void TestCase_RenderTilePNG() { TestCase_RenderTile(L"PNG", L"png"); }
+ void TestCase_RenderTileXYZ_PNG() { TestCase_RenderTileXYZ(L"PNG", L"png"); }
//PNG8 output tests
void TestCase_RenderDynamicOverlayPNG8() { TestCase_RenderDynamicOverlay(L"PNG8", L"png"); }
@@ -222,6 +237,8 @@
void TestCase_RenderLegendSingleFTSMultiCTSPNG8() { TestCase_RenderLegendSingleFTSMultiCTS(L"PNG8", L"png"); }
void TestCase_StylizationFunctionsPNG8() { TestCase_StylizationFunctions(L"PNG8", L"png"); }
void TestCase_LayerWatermarkPNG8() { TestCase_LayerWatermark(L"PNG8", L"png"); }
+ void TestCase_RenderTilePNG8() { TestCase_RenderTile(L"PNG8", L"png"); }
+ void TestCase_RenderTileXYZ_PNG8() { TestCase_RenderTileXYZ(L"PNG8", L"png"); }
//GIF output tests
void TestCase_RenderDynamicOverlayGIF() { TestCase_RenderDynamicOverlay(L"GIF", L"gif"); }
@@ -246,6 +263,8 @@
void TestCase_RenderLegendSingleFTSMultiCTSGIF() { TestCase_RenderLegendSingleFTSMultiCTS(L"GIF", L"gif"); }
void TestCase_StylizationFunctionsGIF() { TestCase_StylizationFunctions(L"GIF", L"gif"); }
void TestCase_LayerWatermarkGIF() { TestCase_LayerWatermark(L"GIF", L"gif"); }
+ void TestCase_RenderTileGIF() { TestCase_RenderTile(L"GIF", L"gif"); }
+ void TestCase_RenderTileXYZ_GIF() { TestCase_RenderTileXYZ(L"GIF", L"gif"); }
//JPG output tests
void TestCase_RenderDynamicOverlayJPG() { TestCase_RenderDynamicOverlay(L"JPG", L"jpg"); }
@@ -270,6 +289,8 @@
void TestCase_RenderLegendSingleFTSMultiCTSJPG() { TestCase_RenderLegendSingleFTSMultiCTS(L"JPG", L"jpg"); }
void TestCase_StylizationFunctionsJPG() { TestCase_StylizationFunctions(L"JPG", L"jpg"); }
void TestCase_LayerWatermarkJPG() { TestCase_LayerWatermark(L"JPG", L"jpg"); }
+ void TestCase_RenderTileJPG() { TestCase_RenderTile(L"JPG", L"jpg"); }
+ void TestCase_RenderTileXYZ_JPG() { TestCase_RenderTileXYZ(L"JPG", L"jpg"); }
//void TestCase_RendererPerformance();
More information about the mapguide-commits
