[mapguide-commits] r8450 - trunk/MgDev/Desktop/MgDesktop/Services
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Nov 16 23:00:07 PST 2014
Author: jng
Date: 2014-11-16 23:00:06 -0800 (Sun, 16 Nov 2014)
New Revision: 8450
   trunk/MgDev/Desktop/MgDesktop/Services/DrawingService.h
   trunk/MgDev/Desktop/MgDesktop/Services/MappingService.h
   trunk/MgDev/Desktop/MgDesktop/Services/RenderingService.h
mg-desktop: API doc cleanup
Modified: trunk/MgDev/Desktop/MgDesktop/Services/DrawingService.h
--- trunk/MgDev/Desktop/MgDesktop/Services/DrawingService.h	2014-11-17 06:24:02 UTC (rev 8449)
+++ trunk/MgDev/Desktop/MgDesktop/Services/DrawingService.h	2014-11-17 07:00:06 UTC (rev 8450)
@@ -5,6 +5,38 @@
 /// \ingroup Desktop_Service_Module
+/// \brief
+/// Allows low level access to \link DWF DWF™ \endlink
+/// (Design Web Format™) data stored in a resource repository as
+/// part of a drawing source.
+/// \remarks
+/// The Drawing Service contains one class: MgDrawingService.
+/// \n
+/// DWF files contain:
+/// <ol>
+///   <li>An XML file, manifest.xml, listing information about the
+///      DWF.</li>
+///   <li>One or more <i>resources</i>. These are typically design
+///      data in various formats (such as W2D, JPG, PNG, AVI, and
+///      XML).</li>
+/// </ol>
+/// Typically the contents are organized into <i>sections</i>,
+/// each of which represents a logical component being published,
+/// such as a mechanical part or a page of a multi-page diagram.
+/// Each section may have a descriptor.xml file containing
+/// section-specific metadata, and each section may contain
+/// drawing <i>layers</i>. Sections are sometimes also referred
+/// to as <i>sheets.</i>
+/// \n
+/// The Drawing Service allows you to enumerate parts of the DWF,
+/// such as layers, sections, and resources, and to get the
+/// binary data from drawings, layers, and a resources. It also
+/// provides access to the coordinate space assigned to the DWF
+/// in the DrawingSource resource.
 class MG_DESKTOP_API MgdDrawingService : public MgService
     DECLARE_CLASSNAME(MgdDrawingService)
@@ -23,229 +55,317 @@
     MgdDrawingService();
 PUBLISHED_API:
-    /// <summary>
-    /// GetDrawing() returns the DWF stream for a drawing specified by resource identifier.
-    /// </summary>
-    /// <param name="resource">Input
-    /// MgResourceIdentifier object identifying the DWF resource
-    /// </param>
-    /// <returns>
-    /// Returns DWF stream.
-    /// </returns>
-    /// EXCEPTIONS:
-    /// - MgServiceNotAvailableException if the underlying resource service cannot be obtained to access the drawing in the resource repository.
-    /// - MgXmlParserException if there are problems parsing the resource content specified by the resource identifier.
-    /// - See MgResourceService for additional exceptions.
+    /// \brief
+    /// Returns the DWF stream for a drawing specified by resource
+    /// identifier.
+    /// \param resource (MgResourceIdentifier)
+    /// Resource identifier specifying the drawing
+    /// source which has the DWF resource data.
+    /// \return
+    /// Returns an MgByteReader object containing the DWF.
+    /// \exception MgServiceNotAvailableException if the underlying resource
+    /// service cannot be obtained to access the drawing in the
+    /// resource repository.
+    /// \exception MgXmlParserException if there are problems parsing the resource content
+    /// specified by the resource identifier.
+    /// \note
+    /// See MgResourceService for additional exceptions.
     MgByteReader* GetDrawing(MgResourceIdentifier* resource);
-    /// <summary>
-    /// DescribeDrawing() returns manifest.xml document located in the DWF.
-    /// Refer to the DWF Format Specification at http://viewers/web/Olema/pdf/DWF%206%20Corporate%20Publishing%20Format.pdf for more information on the manifest.
-    /// </summary>
-    /// </param>
-    /// <returns>
-    /// Returns the byte stream containing XML (manifest.xml).
-    /// </returns>
-    /// EXCEPTIONS:
-    /// - MgInvalidCastException if there are problems reading the DWF into memory.
-    /// - MgdInvalidDwfPackageException if the DWF specified by the resource identifier is not a DWF of version 6.0 or greater.
-    /// - MgdDwfException if the DWF component encounters errors.
+    /// \brief
+    /// Gets the <c>manifest.xml</c> document which describes the
+    /// supported document interfaces, the document properties, the
+    /// sections and their contents, and section dependencies.
+    /// \return
+    /// Returns an MgByteReader object containing the manifest.xml
+    /// file.
+    /// \exception MgInvalidCastException if there are problems reading the
+    /// DWF into memory.
+    ///  resource content specified by the resource identifier.
+    /// \exception MgInvalidDwfPackageException if the DWF specified by the
+    ///  resource identifier is not a DWF of version 6.0 or greater.
+    /// \exception MgDwfException if the DWF component encounters errors.
+    /// \note
     MgByteReader* DescribeDrawing(MgResourceIdentifier* resource);
-    /// <summary>
-    /// GetSection() returns a DWF containing only the requested section.  The section is specified by resource identifier (to get the DWF from the repository),
-    /// and the section name.  The section names can be retrieved via call to MgdDrawingService::EnumerateSections() or from manifest.xml via call to MgdDrawingService::DescribeDrawing().
-    /// </summary>
-    /// </param>
-    /// <param name="sectionName">Input
-    /// sectionName specifies the unique name of the section in the DWF resource.  Section names can be retrieved via call to MgdDrawingService::EnumerateSections() or from manifest.xml via call to MgdDrawingService::DescribeDrawing().
-    /// </param>
-    /// <returns>
-    /// Returns DWF stream containing the specified section.
-    /// </returns>
-    /// EXCEPTIONS:
-    /// - MgdDwfSectionNotFoundException if the requested section does not exist in the DWF package.
-    /// - MgdInvalidDwfSectionException if the 2d graphics resource for the DWF section cannot be found.
-    /// - MgNullReferenceException no data could be read from the DWF resource.
-    /// - MgOutOfMemoryException if there is insufficient memory to complete the operation.
-    /// - MgTemporaryFileNotAvailableException if a temporary file need to complete the operation cannot be generated or accessed.
+    /// \brief
+    /// Gets a DWF containing only the requested section (sometimes
+    /// called a sheet).
+    /// Resource identifier specifying the drawing source
+    /// which has the DWF resource data.
+    /// \param sectionName (String/string)
+    /// Name of the section. Section names can be
+    /// retrieved via EnumerateSections or from the <c>manifest.xml</c>
+    /// file via DescribeDrawing.
+    /// \return
+    /// Returns an MgByteReader object containing the DWF for the
+    /// specified section.
+    /// \exception  MgDwfSectionNotFoundException if the requested section
+    ///  does not exist in the DWF package.
+    /// \exception  MgInvalidDwfSectionException if the 2d graphics resource
+    ///  for the DWF section cannot be found.
+    /// \exception  MgNullReferenceException no data could be read from the
+    ///  DWF resource.
+    /// \exception  MgOutOfMemoryException if there is insufficient memory to
+    ///  complete the operation.
+    /// \exception  MgTemporaryFileNotAvailableException if a temporary file needed
+    ///  to complete the operation cannot be generated or accessed.
+    /// \note
     MgByteReader* GetSection(MgResourceIdentifier* resource, CREFSTRING sectionName);
-    /// <summary>
-    /// GetSectionResource() extracts a specific resource from the DWF package.
-    /// It is specified by the resource identifier (to get the DWF from the repository)
-    /// and the resource name (to get the DWF resource from the DWF package).
-    /// A list of resource names can be retrieved via call to MgdDrawingServices::EnumerateSectionResources(),
-    /// or from the manifest.xml via call to MgdDrawingServices::DescribeDrawing().
-    /// Refer to the DWF Format Specification at http://viewers/web/Olema/pdf/DWF%206%20Corporate%20Publishing%20Format.pdf for more information resource files associated with a particular section.
+    /// \brief
+    /// Gets a specific resource from the DWF.
-    /// </summary>
-    /// </param>
-    /// <param name="resourceName">Input
-    /// Unique resource name of an item in the DWF.
-    /// The item's name can be retrieved from call to MgdDrawingServices::EnumerateDrawingServices(),
-    /// </param>
-    /// <returns>
-    /// Returns byte stream for the item.
-    /// Content type will be same as what is specified in manifest.xml for
-    /// the specified item e.g. image/png or text/xml etc.
-    /// </returns>
-    /// EXCEPTIONS:
-    /// - MgInvalidArgumentException if the requested resourceName does not specify a section name.
-    /// - MgdDwfSectionResourceNotFoundException if the requested section resource does not exist in the DWF package.
+    /// \param resourceName (String/string)
+    /// Name of the resource. Resource names can be
+    /// retrieved via EnumerateSectionResources or from
+    /// the <c>manifest.xml</c> file via DescribeDrawing.
+    /// \return
+    /// Returns an MgByteReader object containing the resource. The
+    /// MIME type will be what is specified in manifest.xml for the
+    /// specified resource (for example, image/png or text/xml).
+    /// \exception MgInvalidArgumentException if the requested resourceName
+    ///  does not specify a section name.
+    /// \exception MgDwfSectionResourceNotFoundException if the requested
+    ///  section resource does not exist in the DWF package.
+    /// \note
     MgByteReader* GetSectionResource(MgResourceIdentifier* resource, CREFSTRING resourceName);
-    /// <summary>
-    /// EnumerateLayers() returns the layer names in a DWF ePlot section.  An ePlot section is also known as a "sheet" in DWF viewers.
-    /// The ePlot section is specified by resource identifier (to get the DWF from the repository), and section name.
-    /// A list of all sections in a DWF can be retrieved from call to MgdDrawingServices::EnumerateSections(),
-    //  Refer to the DWF Format Specification at http://viewers/web/Olema/pdf/DWF%206%20Corporate%20Publishing%20Format.pdf for more information on the manifest and sections.
-    /// </summary>
-    /// </param>
-    /// </param>
-    /// <returns>
-    /// Returns the pointer to a StringCollection of layer names.
-    /// </returns>
-    /// EXCEPTIONS:
+    /// \brief
+    /// Gets the names of the layers in a DWF section.
+    /// \return
+    /// Returns a collection of layer names.
+    ///  DWF resource.
+    /// \note
     MgStringCollection* EnumerateLayers(MgResourceIdentifier* resource, CREFSTRING sectionName);
-    /// <summary>
-    /// GetLayer() extracts a layer from a particular ePlot section of a DWF.
-    /// </summary>
-    /// </param>
-    /// </param>
-    /// <param name="layerName">Input
-    /// layerName specifies the name of the layer to retrieve from a particular section.  A list of layer names can can be retrieved via call to MgdDrawingService::EnumerateLayers().
-    /// </param>
-    /// <returns>
-    /// Returns DWF stream containing the specified layer (in a section)
-    /// </returns>
-    /// EXCEPTIONS:
-    /// - MgNullReferenceException if data could not be read from the DWF resource.
-    /// - MgLayerNotFoundException if the requested layer does not exist in the requested section of the DWF package.
+    /// \brief
+    /// Gets a layer from a particular section of a DWF.
+    /// retrieved via EnumerateSections or from the the <c>manifest.xml</c>
+    /// file file via DescribeDrawing.
+    /// \param layerName (String/string)
+    /// Name of the layer. Layer names can can be
+    /// retrieved via EnumerateLayers.
+    /// \return
+    /// Returns DWF stream containing the specified layer in the
+    /// \exception MgNullReferenceException if data could not be read from
+    ///  the DWF resource.
+    /// \exception MgLayerNotFoundException if the requested layer does not
+    ///  exist in the requested section of the DWF package.
+    /// \note See MgResourceService for additional exceptions.
     MgByteReader* GetLayer( MgResourceIdentifier* resource,
                             CREFSTRING sectionName,
                             CREFSTRING layerName );
-    /// <summary>
-    /// EnumerateSections() enumerates only the ePlot sections in a DWF.  The returned sections are in ascending order based on its plotOrder attribute.
-    /// The DWF is identified by it's resource identifier.
-    /// </summary>
-    /// </param>
-    /// <returns>
-    /// Returns MgByteReader object representing the ePlot sections in a DWF sorted in ascending order based on plotOrder attribute.
+    /// \brief
+    /// Enumerates only the \link ePlot ePlot \endlink sections (sheets) in
+    /// a DWF.
-    /// </returns>
-    /// EXCEPTIONS:
+    /// \return
+    /// Returns an MgByteReader object containing the list of
+    /// sections in XML format using the \link DrawingSectionList_schema DrawingSectionList \endlink
+    /// schema. The sections are sorted in ascending order based on
+    /// their <c>plotOrder</c> attribute.
+    ///  DWF resource.
+    /// \note
     MgByteReader* EnumerateSections(MgResourceIdentifier* resource);
-    /// <summary>
-    /// EnumerateSectionResources() enumerates the resources of a DWF section.  The DWF is identified by it's
-    /// resource identifier and the section is identified by name.  The section name
-    /// will be retrieved from manifest.xml or from MgdDrawingServices::EnumerateSections() API.
-    /// </summary>
-    /// </param>
-    /// </param>
-    /// <returns>
-    /// Returns MgByteReader object representing resources in a DWF section.
+    /// \brief
+    /// Enumerates the resources of a DWF section (sometimes called a
+    /// sheet).
-    /// </returns>
-    /// EXCEPTIONS:
+    /// \return
+    /// resources in XML format using the \link DrawingSectionResourceList_schema DrawingSectionResourceList \endlink
+    /// schema.
+    ///  DWF resource.
+    /// \note
     MgByteReader* EnumerateSectionResources(MgResourceIdentifier* resource, CREFSTRING sectionName);
-    /// <summary>
-    /// GetCoordinateSpace() returns the coordinate system assigned to the DWF drawing.
-    /// The coordinate system will be retrieved from the drawing source content document.
-    /// If no coordinate system is specified, the default will be LL84.
-    /// </summary>
-    /// </param>
-    /// <returns>
-    /// Returns the STRING representing the coordinate system in AWKT format.
-    /// </returns>
-    /// EXCEPTIONS:
-    /// - MgServiceNotAvailableException if the underlying resource service cannot be obtained to access the drawing resource in the repository.
+    /// \brief
+    /// Gets the coordinate system assigned to the DWF drawing.
+    /// \remarks
+    /// If no coordinate system is specified for the DWF, the default
+    /// is <c>GEOGCS["LL84",DATUM["WGS_1984",SPHEROID["WGS
+    /// 84",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",1]]</c>
+    /// \return
+    /// Returns a string representing the coordinate system in OGC \link WKT WKT \endlink
+    /// format.
+    ///  service cannot be obtained to access the drawing resource in
+    ///  the repository.
+    /// \note
     virtual STRING GetCoordinateSpace(MgResourceIdentifier* resource);
 CLASS_ID:
Modified: trunk/MgDev/Desktop/MgDesktop/Services/MappingService.h
--- trunk/MgDev/Desktop/MgDesktop/Services/MappingService.h	2014-11-17 06:24:02 UTC (rev 8449)
+++ trunk/MgDev/Desktop/MgDesktop/Services/MappingService.h	2014-11-17 07:00:06 UTC (rev 8450)
@@ -16,6 +16,12 @@
+/// \brief
+/// Performs map related operations such as getting an eMap DWF
+/// representing a map or updates to a map, or querying features
+/// from maps or layers of a map.
 class MG_DESKTOP_API MgdMappingService : public MgService
     DECLARE_CLASSNAME(MgdMappingService)
@@ -34,6 +40,45 @@
     MgdMappingService();
 PUBLISHED_API:
+    /// \brief
+    /// GenerateLegendImage() returns the legend image for the specified layer.
+    /// Input
+    /// MgResourceIdentifier object identifying the layer definition resource.
+    /// \param scale (double)
+    /// Input
+    /// The scale at which the symbolization is requested.
+    /// \param width (int)
+    /// Input
+    /// The requested image width in pixels.
+    /// \param height (int)
+    /// Input
+    /// The requested image height in pixels.
+    /// \param format (String/string)
+    /// Input
+    /// Image format, from MgImageFormats. Example: PNG, JPG, PNG8, etc
+    /// \param geomType (int)
+    /// Input
+    /// The type of symbolization required: 1=Point, 2=Line, 3=Area, 4=Composite
+    /// \param themeCategory (int)
+    /// Input
+    /// The value indicating which theme category swatch to return.
+    /// Used when there is a theme defined at this scale. An exception will be
+    /// thrown if a requested them category doesn't exist.
+    /// \return
+    /// Returns a stream representing the legend image.
+    /// The default returned image format will be PNG8 unless a different supported
+    /// format is requested. An exception will be thrown if an unsupported image
+    /// \exception MgArgumentOutOfRangeException
+    /// \exception MgInvalidResourceTypeException
+    /// \exception MgNullArgumentException
+    /// \exception MgInvalidImageFormatException
     virtual MgByteReader* GenerateLegendImage(MgResourceIdentifier* resource,
                                                double scale,
                                                INT32 width,
@@ -42,11 +87,59 @@
                                                INT32 geomType,
                                                INT32 themeCategory);
+    /// \brief
+    /// Plot The map to an EPlot DWF using the center and scale from the map.  The
+    /// extents will be computed to fill the space within the page margins.  If the
+    /// layout paramter is null, no adornments will be added to the page.
+    /// \param map (MgdMap)
+    /// Map object describing current state of map.
+    /// \param plotSpec (MgdPlotSpecification)
+    /// Plotting specifications for the generated plot.
+    /// \param layout (MgdLayout)
+    /// Layout specifications to use for the generated plot.
+    /// \param dwfVersion (MgdDwfVersion)
+    /// DWF version required by the client. This
+    /// determines the schema and file versions used to
+    /// generate the DWFs sent back to the client.
+    /// \return
+    /// Returns an MgByteReader object containing a DWF in ePlot format.
     virtual MgByteReader* GeneratePlot(MgdMap* map,
                                        MgdPlotSpecification* plotSpec,
                                        MgdLayout* layout,
                                        MgdDwfVersion* dwfVersion);
+    /// \brief
+    /// Plot the map to an EPlot DWF using the specified center and scale.  The extents
+    /// will be computed to fill the space within the page margins.  If the layout
+    /// paramter is null, no adornments will be added to the page.
+    /// \param center (MgCoordinate)
+    /// The coordinates of the center of the map for the plot.
+    /// The scale to use for the plot.
+    /// \return
                                        MgCoordinate* center,
                                        double scale,
@@ -54,6 +147,35 @@
                                        MgdLayout* layout,
+    /// \brief
+    /// Plot the map to an EPlot DWF using the extent specified in the mapping
+    /// coordinate space.  The center and scale will be computed based on the extent
+    /// specified.  If expandToFit is true, then the extent specified will be expanded
+    /// in the X or Y direction to fill the space within the page margins.  If the
+    /// \param extents (MgEnvelope)
+    /// The extents of the map to be plotted..
+    /// \param expandToFit (boolean/bool)
+    /// Flag indicating whether the extents should be expanded to
+    /// fill the space withing the page margins.
+    /// \return
                                        MgEnvelope* extents,
                                        bool expandToFit,
@@ -61,6 +183,25 @@
                                        MgdLayout* layout,
+    /// \brief
+    /// Generates an \link ePlot ePlot \endlink containing one sheet per
+    /// specified map.
+    /// \param mapPlots (MgdMapPlotCollection)
+    /// A collection of MapPlot objects.
+    /// DWF specification required by the client. This
+    /// \return
+    /// in ePlot format with multiple sheets, one for each
+    /// map.
     virtual MgByteReader* GenerateMultiPlot(MgdMapPlotCollection* mapPlots, MgdDwfVersion* dwfVersion);
 private:
Modified: trunk/MgDev/Desktop/MgDesktop/Services/RenderingService.h
--- trunk/MgDev/Desktop/MgDesktop/Services/RenderingService.h	2014-11-17 06:24:02 UTC (rev 8449)
+++ trunk/MgDev/Desktop/MgDesktop/Services/RenderingService.h	2014-11-17 07:00:06 UTC (rev 8450)
@@ -22,6 +22,9 @@
+/// \brief
+/// This class provides services to render a map into an image
 class MG_DESKTOP_API MgdRenderingService : public MgService
     DECLARE_CLASSNAME(MgdRenderingService)
@@ -35,52 +38,286 @@
     //void SetConnectionProperties(MgConnectionProperties* connProp);
 PUBLISHED_API:
+    /// \brief
+    /// Returns the specified base map tile for the given map.
+    /// \remarks
+    /// This method only renders the given tile. No tile caching is performed
+    /// by this method. To render and cache the tile, use the
+    /// \link MgdTileService::GetTile GetTile \endlink method instead
+    /// \param map
+    /// Input
+    /// map object containing current state of map.
+    /// \param baseMapLayerGroupName
+    /// Input
+    /// Specifies the name of the baseMapLayerGroup for which to render the tile.
+    /// \param tileColumn
+    /// Input
+    /// Specifies the column index of the tile to return.
+    /// \param tileRow
+    /// Input
+    /// Specifies the row index of the tile to return.
+    /// \return
+    /// A byte reader containing the rendered tile image.
     virtual MgByteReader* RenderTile(MgdMap* map,
                                      CREFSTRING baseMapLayerGroupName,
                                      INT32 tileColumn,
                                      INT32 tileRow);
+    /// \brief
+    /// Renders all dynamic layers in the specified MgdMap to a dynamic overlay image
+    /// with a transparent background. The center, scale, size, and layers to be
+    /// rendered are defined by the specified map instance.  The format parameter
+    /// must be set to an image format that supports transparency.
+    /// \param map
+    /// Input
+    /// \param selection
+    /// Input
+    /// map feature selection. Specifies the selected features on the map
+    /// \param format
+    /// Input
+    /// image format. Defines the format of the resulting image
+    /// \return
+    /// A byte reader containing the rendered image
     virtual MgByteReader* RenderDynamicOverlay(MgdMap* map,
                                                MgdSelection* selection,
                                                CREFSTRING format);
+    /// \brief
+    /// \param map
+    /// Input
+    /// Input
+    /// \param format
+    /// Input
+    /// \param bKeepSelection
+    /// Input
+    /// true if you want to keep the selection
+    /// \return
                                                CREFSTRING format,
                                                bool bKeepSelection);
+    /// \brief
+    /// \param map
+    /// Input
+    /// Input
+    /// \param options
+    /// Input
+    /// rendering options
+    /// \return
                                                MgdRenderingOptions* options);
+    /// \brief
+    /// Renders the specified MgdMap to the requested image format.
+    /// \param map
+    /// Input
+    /// Input
+    /// \param format
+    /// Input
+    /// \return
     virtual MgByteReader* RenderMap(MgdMap* map,
                                     CREFSTRING format);
+    /// \brief
+    /// \param map
+    /// Input
+    /// Input
+    /// \param format
+    /// Input
+    /// Input
+    /// \return
                                     CREFSTRING format,
+    /// \brief
+    /// \param map
+    /// Input
+    /// Input
+    /// \param format
+    /// Input
+    /// Input
+    /// \param bClip
+    /// Input
+    /// true if you want to clip feature geometry
+    /// \return
                                     CREFSTRING format,
                                     bool bKeepSelection,
                                     bool bClip);
+    /// \brief
+    /// Renders the legend for the specified MgdMap to the requested size and format
+    /// \param map
+    /// Input
+    /// \param width
+    /// Input
+    /// width of legend image in pixels
+    /// \param height
+    /// Input
+    /// height of legend image in pixels
+    /// \param backgroundColor
+    /// Input
+    /// background color. Specifies the map legend background color
+    /// \param format
+    /// Input
+    /// \return
     virtual MgByteReader* RenderMapLegend(MgdMap* map,
                                           INT32 width,
                                           INT32 height,
                                           MgColor* backgroundColor,
                                           CREFSTRING format);
+    /// \brief
+    /// The QueryFeatures operation identifies those features that
+    /// meet the specified spatial selection criteria. This operation
+    /// is used to implement server-side selection. In addition to
+    /// a selection set, this operation returns attribute information
+    /// in case only one feature is selected
+    /// \param map
+    /// Input
+    /// \param layerNames
+    /// Input
+    /// Active layer names for which to query features
+    /// \param filterGeometry
+    /// Input
+    /// geometry object specifying the selection area
+    /// \param selectionVariant
+    /// Input
+    /// selection criterion - integer value corresponding to one of
+    /// the MgFeatureSpatialOperations values
+    /// \param maxFeatures
+    /// Input
+    /// the maximum number of features to return
+    /// \return
+    /// An MgSelection instance identifying the features that meet the
+    /// selection criteria. Returns null if no features are identified.
     virtual MgdFeatureInformation* QueryFeatures(MgdMap* map,
                                                  MgStringCollection* layerNames,
                                                  MgGeometry* filterGeometry,
                                                  INT32 selectionVariant,
                                                  INT32 maxFeatures);
+    /// \brief
+    /// \param map
+    /// Input
+    /// Input
+    /// Input
+    /// Input
+    /// \param featureFilter
+    /// Input
+    /// an XML selection string containing the required feature IDs
+    /// Input
+    /// \param layerAttributeFilter
+    /// Input
+    /// bitmask values - 1=Visible, 2=Selectable, 4=HasTooltips
+    /// \return
More information about the mapguide-commits mailing list
