[mapguide-commits] r8454 - in trunk/Tools/Maestro: Maestro.Base/Commands/SiteExplorer Maestro.Editors Maestro.Editors/Common Maestro.Editors/Preview OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Resource OSGeo.MapGuide.MaestroAPI/Resource/Preview OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Http/Resources
svn_mapguide at osgeo.org
Thu Nov 20 17:27:04 PST 2014
Author: jng
Date: 2014-11-20 17:27:04 -0800 (Thu, 20 Nov 2014)
New Revision: 8454
Added:
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpResourcePreviewUrlGenerator.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Resources/
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Resources/TextWatermark.txt
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/IResourcePreviewUrlGenerator.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/ResourcePreviewUrlGenerator.cs
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs
trunk/Tools/Maestro/Maestro.Editors/Common/EditorWindow.cs
trunk/Tools/Maestro/Maestro.Editors/Preview/DefaultResourcePreviewer.cs
trunk/Tools/Maestro/Maestro.Editors/Preview/LocalMapPreviewer.cs
trunk/Tools/Maestro/Maestro.Editors/Preview/ResourcePreviewEngine.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
#2506: Refactor the resource previewing mechanism so that each connection provider can implement its own URL generation
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -307,5 +307,10 @@
throw new NotImplementedException();
+ public OSGeo.MapGuide.MaestroAPI.Resource.Preview.IResourcePreviewUrlGenerator GetPreviewUrlGenerator()
+ throw new NotImplementedException();
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/EditorWindow.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/EditorWindow.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/EditorWindow.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -123,7 +123,8 @@
_svc = new DefaultResourceEditorService(resourceId, conn);
_svc.DirtyStateChanged += OnDirtyStateChanged;
_ed.Dock = DockStyle.Fill;
- btnPreview.Enabled = ResourcePreviewEngine.IsPreviewableType(ResourceIdentifier.GetResourceTypeAsString(resourceId));
+ var previewer = conn.GetPreviewUrlGenerator();
+ btnPreview.Enabled = (previewer != null && previewer.IsPreviewableType(ResourceIdentifier.GetResourceTypeAsString(resourceId)));
this.Controls.Add(_ed);
_ed.Bind(_svc);
_ed.ReadyForEditing();
Modified: trunk/Tools/Maestro/Maestro.Editors/Preview/DefaultResourcePreviewer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Preview/DefaultResourcePreviewer.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/Maestro.Editors/Preview/DefaultResourcePreviewer.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -103,7 +103,7 @@
else
//Now feed it to the preview engine
- var url = new ResourcePreviewEngine(mapguideRootUrl, edSvc).GeneratePreviewUrl(previewCopy, locale);
+ var url = new ResourcePreviewEngine(edSvc).GeneratePreviewUrl(previewCopy, locale);
return new UrlPreviewResult() { Url = url };
@@ -185,7 +185,8 @@
else
- bool bPreviewable = ResourcePreviewEngine.IsPreviewableType(rt);
+ var previewer = res.CurrentConnection.GetPreviewUrlGenerator();
+ bool bPreviewable = (previewer != null && previewer.IsPreviewableType(rt));
//A Map Definition can be saved directly and referenced by a Web Layout
//An Web Layout and Application Definition can be saved directly and
//passed straight to the AJAX/Fusion viewers.
Modified: trunk/Tools/Maestro/Maestro.Editors/Preview/LocalMapPreviewer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Preview/LocalMapPreviewer.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/Maestro.Editors/Preview/LocalMapPreviewer.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -129,7 +129,7 @@
break;
case "WatermarkDefinition":
- previewMdf = ResourcePreviewEngine.CreateWatermarkPreviewMapDefinition((IWatermarkDefinition)res);
+ previewMdf = Utility.CreateWatermarkPreviewMapDefinition((IWatermarkDefinition)res);
break;
case "MapDefinition":
Modified: trunk/Tools/Maestro/Maestro.Editors/Preview/ResourcePreviewEngine.cs
--- trunk/Tools/Maestro/Maestro.Editors/Preview/ResourcePreviewEngine.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/Maestro.Editors/Preview/ResourcePreviewEngine.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -19,6 +19,7 @@
#endregion
using OSGeo.MapGuide.MaestroAPI;
using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.MaestroAPI.Resource.Preview;
using OSGeo.MapGuide.MaestroAPI.Schema;
using OSGeo.MapGuide.ObjectModels;
using OSGeo.MapGuide.ObjectModels.ApplicationDefinition;
@@ -37,87 +38,36 @@
/// <summary>
/// Performs any necessary setup required to preview a given resource in a web browser
/// </summary>
- public class ResourcePreviewEngine
+ internal class ResourcePreviewEngine
- private string _rootUrl;
private IEditorService _edSvc;
/// <summary>
/// Initializes a new instance of the ResourcePreviewEngine class
/// </summary>
- /// <param name="rootUrl"></param>
/// <param name="edSvc"></param>
- public ResourcePreviewEngine(string rootUrl, IEditorService edSvc)
+ public ResourcePreviewEngine(IEditorService edSvc)
- _rootUrl = rootUrl;
_edSvc = edSvc;
- static string GetLocale(string locale)
+ /// <summary>
+ /// Generates the appropriate viewer URL to preview the given resource under the given locale
+ /// </summary>
+ /// <param name="res"></param>
+ /// <param name="locale"></param>
+ /// <returns></returns>
+ public string GeneratePreviewUrl(IResource res, string locale)
- return string.IsNullOrEmpty(locale) ? "en" : locale; //NOXLATE
- private string GenerateFeatureSourcePreviewUrl(IResource res, string locale)
- string url = _rootUrl;
- if (!url.EndsWith("/")) //NOXLATE
- url += "/"; //NOXLATE
- var resId = res.ResourceID;
- var sessionId = _edSvc.SessionID;
- url += "schemareport/describeschema.php?viewer=basic&schemaName=&className=&resId=" + resId + "&sessionId=" + sessionId + "&locale=" + GetLocale(locale); //NOXLATE
- return url;
- private string GenerateLayerPreviewUrl(IResource res, string locale)
- var ldf = (ILayerDefinition)res;
var conn = res.CurrentConnection;
- string layerName = string.Empty;
- //Use feature source as name/label if new and unsaved
- if (_edSvc.IsNew)
- layerName = ResourceIdentifier.GetName(ldf.SubLayer.ResourceId);
- else
- layerName = ResourceIdentifier.GetName(_edSvc.ResourceID);
- var mdf = CreateLayerPreviewMapDefinition(ldf, sessionId, layerName, conn);
- //if (PropertyService.Get(ConfigProperties.PreviewViewerType, "AJAX").Equals("AJAX")) //NOXLATE
- if (PreviewSettings.UseAjaxViewer)
- //Create temp web layout to house this map
- var wl = ObjectFactory.CreateWebLayout(_edSvc.GetEditedResource().CurrentConnection, new Version(1, 0, 0), mdf.ResourceID);
- //Add a custom zoom command (to assist previews of layers that aren't [0, infinity] scale)
- AttachPreviewCommands(wl);
- var resId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".WebLayout"; //NOXLATE
- conn.ResourceService.SaveResourceAs(wl, resId);
- url += "mapviewerajax/?WEBLAYOUT=" + resId + "&SESSION=" + sessionId + "&LOCALE=" + GetLocale(locale); //NOXLATE
- else
- throw new NotImplementedException();
- ////Create temp flex layout
- //var appDef = ObjectFactory.CreatePreviewFlexLayout(conn);
- //var resId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".ApplicationDefinition"; //NOXLATE
- //appDef.AddMapGroup("previewmap", true, mdfId); //NOXLATE
- //conn.ResourceService.SaveResourceAs(appDef, resId);
- //url += "fusion/templates/mapguide/preview/index.html?Session=" + sessionId + "&ApplicationDefinition=" + resId; //NOXLATE
- return url;
+ previewer.AddDebugWatermark = PreviewSettings.AddDebugWatermark;
+ previewer.UseAjaxViewer = PreviewSettings.UseAjaxViewer;
+ return previewer.GeneratePreviewUrl(res, locale, _edSvc.IsNew, _edSvc.SessionID);
+ #region Preview helper code
static string CreateDebugWatermark(IMapDefinition2 mdf, IServerConnection conn, string layerSc)
//Tidy up the CS WKT so that it can display nicely in a watermark
@@ -169,240 +119,20 @@
if (extent == null)
throw new ApplicationException(Strings.FailedToCalculateFeatureSourceExtents);
- string layerSc = GetLayerSpatialContext(ldf);
+ string layerSc = Utility.GetLayerSpatialContext(ldf);
//TODO: Based on the visible scales in this layer, size this extents accordingly
var mdf = ObjectFactory.CreateMapDefinition(conn, Strings.PreviewMap, csWkt, extent);
IMapDefinition2 mdf2 = mdf as IMapDefinition2;
if (mdf2 != null && PreviewSettings.AddDebugWatermark)
CreateDebugWatermark(mdf2, conn, layerSc);
var layer = mdf.AddLayer(null, layerName, ldf.ResourceID);
conn.ResourceService.SaveResourceAs(mdf, mdfId);
mdf.ResourceID = mdfId;
return mdf;
- private static string GetLayerSpatialContext(ILayerDefinition ldf)
- var conn = ldf.CurrentConnection;
- var rl = ldf.SubLayer as IRasterLayerDefinition;
- var vl = ldf.SubLayer as IVectorLayerDefinition;
- if (vl != null)
- var cls = conn.FeatureService.GetClassDefinition(vl.ResourceId, vl.FeatureName);
- var gp = cls.FindProperty(vl.Geometry) as GeometricPropertyDefinition;
- if (gp != null)
- return gp.SpatialContextAssociation;
- else if (rl != null)
- var cls = conn.FeatureService.GetClassDefinition(rl.ResourceId, rl.FeatureName);
- var rp = cls.FindProperty(rl.Geometry) as RasterPropertyDefinition;
- if (rp != null)
- return rp.SpatialContextAssociation;
- return null;
- private static void AttachPreviewCommands(IWebLayout wl)
- var cmd = wl.CreateInvokeScriptCommand();
- cmd.Name = "ZoomScale"; //NOXLATE
- cmd.Label = Strings.Label_ZoomToScale;
- cmd.Tooltip = Strings.Desc_ZoomToScale;
- cmd.Script = @"
- var map = parent.parent.GetMapFrame();
- var center = map.GetCenter();
- var scale = parseFloat(prompt('Enter the scale:'));
- map.ZoomToView(center.X, center.Y, scale, true);
- "; //NOXLATE
- cmd.TargetViewer = TargetViewerType.Ajax;
- cmd.ImageURL = "../stdicons/icon_zoom.gif"; //NOXLATE
- wl.CommandSet.AddCommand(cmd);
- var cmd2 = wl.CreateInvokeScriptCommand();
- cmd2.Name = "GetMapKml"; //NOXLATE
- cmd2.Label = Strings.Label_GetMapKml;
- cmd2.Description = Strings.Desc_GetMapKml;
- cmd2.Tooltip = Strings.Desc_GetMapKml;
- cmd2.Script = @"
- var url = ""../mapagent/mapagent.fcgi?OPERATION=GETMAPKML&VERSION=1.0.0&FORMAT=KML&DISPLAYDPI=96&MAPDEFINITION=" + wl.Map.ResourceId + @""";
- url += ""&SESSION="" + map.GetSessionId();
- window.open(url);"; //NOXLATE
- cmd2.TargetViewer = TargetViewerType.Ajax;
- cmd2.ImageURL = "../stdicons/icon_invokescript.gif"; //NOXLATE
- wl.CommandSet.AddCommand(cmd2);
- var cmd3 = wl.CreateInvokeScriptCommand();
- cmd3.Name = "GetExtents"; //NOXLATE
- cmd3.Label = Strings.Label_GetExtents;
- cmd3.Description = Strings.Desc_GetExtents;
- cmd3.Tooltip = Strings.Desc_GetExtents;
- cmd3.Script = @"
- alert('Map Extents\n\nLower Left: ' + map.extX1 + ', ' + map.extY2 + '\nUpper Right: ' + map.extX2 + ', ' + map.extY1);
- "; //NOXLATE
- cmd3.TargetViewer = TargetViewerType.Ajax;
- cmd3.ImageURL = "../stdicons/icon_invokescript.gif"; //NOXLATE
- wl.CommandSet.AddCommand(cmd3);
- var zoomScale = wl.CreateCommandItem(cmd.Name);
- var menu = wl.CreateFlyout(Strings.Label_Tools, Strings.Label_Tools, Strings.Label_ExtraTools, string.Empty, string.Empty,
- wl.CreateCommandItem("ZoomScale"), //NOXLATE
- wl.CreateCommandItem("GetMapKml"), //NOXLATE
- wl.CreateCommandItem("GetExtents") //NOXLATE
- wl.ToolBar.AddItem(menu);
- private string GenerateWatermarkPreviewUrl(IWatermarkDefinition wmd, string locale)
- //We demand a 2.3.0 Map Definition or higher
- if (wmd.CurrentConnection.SiteVersion < new Version(2, 3))
- throw new InvalidOperationException(Strings.SiteVersionDoesntSupportWatermarks);
- IMapDefinition2 map = CreateWatermarkPreviewMapDefinition(wmd);
- return GenerateMapPreviewUrl(map, locale);
- internal static IMapDefinition2 CreateWatermarkPreviewMapDefinition(IWatermarkDefinition wmd)
- IMapDefinition2 map = (IMapDefinition2)ObjectFactory.CreateMapDefinition(wmd.CurrentConnection, wmd.SupportedMapDefinitionVersion, "Watermark Definition Preview"); //NOXLATE
- map.CoordinateSystem = @"LOCAL_CS[""*XY-M*"", LOCAL_DATUM[""*X-Y*"", 10000], UNIT[""Meter"", 1], AXIS[""X"", EAST], AXIS[""Y"", NORTH]]"; //NOXLATE
- map.Extents = ObjectFactory.CreateEnvelope(-1000000, -1000000, 1000000, 1000000);
- map.AddWatermark(wmd);
- return map;
- private string GenerateMapPreviewUrl(IResource res, string locale)
- var mdfId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".MapDefinition"; //NOXLATE
- var conn = res.CurrentConnection;
- var mdf = res as IMapDefinition;
- if (mdf != null)
- IMapDefinition2 mdf2 = mdf as IMapDefinition2;
- if (mdf2 != null && PreviewSettings.AddDebugWatermark)
- CreateDebugWatermark(mdf2, conn, null);
- conn.ResourceService.SaveResourceAs(res, mdfId);
- var wl = ObjectFactory.CreateWebLayout(_edSvc.GetEditedResource().CurrentConnection, new Version(1, 0, 0), mdfId);
- else
- //var appDef = ObjectFactory.CreateFlexibleLayout(conn);
- return url;
- private string GenerateWebLayoutPreviewUrl(IResource res, string locale)
- conn.ResourceService.SaveResourceAs(res, resId);
- return url;
- private string GenerateFlexLayoutPreviewUrl(IResource res, string locale)
- //Create temp flex layout
- var appDef = (IApplicationDefinition)res;
- var conn = appDef.CurrentConnection;
- var resId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".ApplicationDefinition"; //NOXLATE
- conn.ResourceService.SaveResourceAs(appDef, resId);
- url += appDef.TemplateUrl + "?Session=" + sessionId + "&ApplicationDefinition=" + resId + "&locale=" + GetLocale(locale); //NOXLATE
- return url;
- /// <summary>
- /// Generates the appropriate viewer URL to preview the given resource under the given locale
- /// </summary>
- /// <param name="res"></param>
- /// <param name="locale"></param>
- /// <returns></returns>
- public string GeneratePreviewUrl(IResource res, string locale)
- switch (res.ResourceType)
- case "FeatureSource":
- return GenerateFeatureSourcePreviewUrl(res, locale);
- case "ApplicationDefinition":
- return GenerateFlexLayoutPreviewUrl(res, locale);
- case "LayerDefinition":
- return GenerateLayerPreviewUrl(res, locale);
- case "MapDefinition":
- return GenerateMapPreviewUrl(res, locale);
- case "WebLayout":
- return GenerateWebLayoutPreviewUrl(res, locale);
- case "WatermarkDefinition":
- return GenerateWatermarkPreviewUrl((IWatermarkDefinition)res, locale);
- default:
- throw new InvalidOperationException(Strings.UnpreviewableResourceType);
- private static string[] PREVIEWABLE_RESOURCE_TYPES = new string[]
- ResourceTypes.FeatureSource.ToString(),
- ResourceTypes.ApplicationDefinition.ToString(),
- ResourceTypes.LayerDefinition.ToString(),
- ResourceTypes.MapDefinition.ToString(),
- ResourceTypes.WebLayout.ToString(),
- ResourceTypes.WatermarkDefinition.ToString()
- internal static bool IsPreviewableType(string rt)
- return Array.IndexOf(PREVIEWABLE_RESOURCE_TYPES, rt) >= 0;
+ #endregion
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -511,33 +511,6 @@
/// <summary>
- /// Looks up a localized string similar to Displays the current map extents.
- /// </summary>
- internal static string Desc_GetExtents {
- get {
- return ResourceManager.GetString("Desc_GetExtents", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Gets the current map as a KML document.
- /// </summary>
- internal static string Desc_GetMapKml {
- get {
- return ResourceManager.GetString("Desc_GetMapKml", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Zoom to a specified scale.
- /// </summary>
- internal static string Desc_ZoomToScale {
- get {
- return ResourceManager.GetString("Desc_ZoomToScale", resourceCulture);
- /// <summary>
/// Looks up a localized string similar to Diverging.
/// </summary>
internal static string DivergingName {
@@ -1490,51 +1463,6 @@
/// <summary>
- /// Looks up a localized string similar to Extra Tools.
- /// </summary>
- internal static string Label_ExtraTools {
- get {
- return ResourceManager.GetString("Label_ExtraTools", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Get Extents.
- /// </summary>
- internal static string Label_GetExtents {
- get {
- return ResourceManager.GetString("Label_GetExtents", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Get KML.
- /// </summary>
- internal static string Label_GetMapKml {
- get {
- return ResourceManager.GetString("Label_GetMapKml", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Tools.
- /// </summary>
- internal static string Label_Tools {
- get {
- return ResourceManager.GetString("Label_Tools", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Zoom to Scale.
- /// </summary>
- internal static string Label_ZoomToScale {
- get {
- return ResourceManager.GetString("Label_ZoomToScale", resourceCulture);
- /// <summary>
/// Looks up a localized string similar to Last Updated: .
/// </summary>
internal static string LastUpdated {
@@ -2929,15 +2857,6 @@
/// <summary>
- /// Looks up a localized string similar to The resource type cannot be previewed.
- /// </summary>
- internal static string UnpreviewableResourceType {
- get {
- return ResourceManager.GetString("UnpreviewableResourceType", resourceCulture);
- /// <summary>
/// Looks up a localized string similar to Invoking MgCooker is not supported for this connection type: {0}.
/// </summary>
internal static string UnsupportedConnectionType {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2014-11-21 01:27:04 UTC (rev 8454)
@@ -1472,33 +1472,9 @@
<data name="LoadingFeatureClasses" xml:space="preserve">
<value>Loading Feature Classes</value>
</data>
- <data name="Desc_GetExtents" xml:space="preserve">
- <value>Displays the current map extents</value>
- </data>
- <data name="Desc_GetMapKml" xml:space="preserve">
- <value>Gets the current map as a KML document</value>
- </data>
- <data name="Desc_ZoomToScale" xml:space="preserve">
- <value>Zoom to a specified scale</value>
- </data>
<data name="FailedToCalculateFeatureSourceExtents" xml:space="preserve">
<value>Could not calculate the extents of the Feature Source. Preview is not possible</value>
</data>
- <data name="Label_ExtraTools" xml:space="preserve">
- <value>Extra Tools</value>
- </data>
- <data name="Label_GetExtents" xml:space="preserve">
- <value>Get Extents</value>
- </data>
- <data name="Label_GetMapKml" xml:space="preserve">
- <value>Get KML</value>
- </data>
- <data name="Label_Tools" xml:space="preserve">
- <value>Tools</value>
- </data>
- <data name="Label_ZoomToScale" xml:space="preserve">
- <value>Zoom to Scale</value>
- </data>
<data name="PreviewMap" xml:space="preserve">
<value>Preview Map</value>
</data>
@@ -1508,9 +1484,6 @@
<data name="SiteVersionDoesntSupportWatermarks" xml:space="preserve">
<value>The site version of this current connection is not known to support watermarks</value>
</data>
- <data name="UnpreviewableResourceType" xml:space="preserve">
- <value>The resource type cannot be previewed</value>
- </data>
<data name="NoRegisteredPreviewerForProvider" xml:space="preserve">
<value>No registered previewer for connection: {0}</value>
</data>
@@ -1562,12 +1535,6 @@
<data name="ThemePrimaryKeyPropertyNotSelected" xml:space="preserve">
<value>Property not selected. Please select the Property which connects to the selected Key Property in the external class</value>
</data>
- <data name="DebugWatermarkMessage" xml:space="preserve">
- <value>MapGuide Debugging Information\n==============================\n\nMap Extents Min: ({0}, {1})\nMap Extents Max: ({2}, {3})\nMap Coordinate System: \n{4}</value>
- </data>
- <data name="DebugWatermarkMessageLayer" xml:space="preserve">
- <value>MapGuide Debugging Information\n==============================\n\nMap Extents Min: ({0}, {1})\nMap Extents Max: ({2}, {3})\nMap Coordinate System: \n{4}\nLayer Spatial Context: {5}</value>
- </data>
<data name="UpdatingStylePreviews" xml:space="preserve">
<value>Updating Style Previews</value>
</data>
@@ -1637,4 +1604,10 @@
<data name="None" xml:space="preserve">
<value>None</value>
</data>
+ <data name="DebugWatermarkMessage" xml:space="preserve">
+ <value>MapGuide Debugging Information\n==============================\n\nMap Extents Min: ({0}, {1})\nMap Extents Max: ({2}, {3})\nMap Coordinate System: \n{4}</value>
+ </data>
+ <data name="DebugWatermarkMessageLayer" xml:space="preserve">
+ <value>MapGuide Debugging Information\n==============================\n\nMap Extents Min: ({0}, {1})\nMap Extents Max: ({2}, {3})\nMap Coordinate System: \n{4}\nLayer Spatial Context: {5}</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -57,6 +57,13 @@
public interface IServerConnection
/// <summary>
+ /// Gets the preview URL generator.
+ /// </summary>
+ /// <remarks>Each call will return a new instance</remarks>
+ /// <returns>The preview URL generator. Returns null if this connection does not support browser-based resource previews</returns>
+ Resource.Preview.IResourcePreviewUrlGenerator GetPreviewUrlGenerator();
+ /// <summary>
/// Gets the name of the provider of this implementation
/// </summary>
string ProviderName { get; }
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2014-11-21 01:27:04 UTC (rev 8454)
@@ -277,6 +277,8 @@
<Compile Include="Resource\Conversion\ImageSymbolConverter.cs" />
<Compile Include="Resource\Conversion\NsDoc.cs" />
<Compile Include="Resource\NsDoc.cs" />
+ <Compile Include="Resource\Preview\IResourcePreviewUrlGenerator.cs" />
+ <Compile Include="Resource\Preview\ResourcePreviewUrlGenerator.cs" />
<Compile Include="Resource\Validation\BaseMapDefinitionValidator.cs" />
<Compile Include="Resource\Validation\BaseSymbolDefinitionValidator.cs" />
<Compile Include="Resource\Validation\NsDoc.cs" />
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -243,6 +243,12 @@
#endregion
/// <summary>
+ /// </summary>
+ public virtual OSGeo.MapGuide.MaestroAPI.Resource.Preview.IResourcePreviewUrlGenerator GetPreviewUrlGenerator() { return null; }
+ /// <summary>
/// </summary>
public abstract string ProviderName { get; }
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/IResourcePreviewUrlGenerator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/IResourcePreviewUrlGenerator.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/IResourcePreviewUrlGenerator.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -0,0 +1,32 @@
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+namespace OSGeo.MapGuide.MaestroAPI.Resource.Preview
+ public interface IResourcePreviewUrlGenerator
+ bool UseAjaxViewer { get; set; }
+ bool AddDebugWatermark { get; set; }
+ string GeneratePreviewUrl(OSGeo.MapGuide.MaestroAPI.Resource.IResource res, string locale, bool isNew, string sessionID);
+ bool IsPreviewableType(string resourceType);
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/ResourcePreviewUrlGenerator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/ResourcePreviewUrlGenerator.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Resource/Preview/ResourcePreviewUrlGenerator.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -0,0 +1,94 @@
+#endregion
+using OSGeo.MapGuide.ObjectModels.WatermarkDefinition;
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+ public abstract class ResourcePreviewUrlGenerator : IResourcePreviewUrlGenerator
+ protected ResourcePreviewUrlGenerator()
+ this.AddDebugWatermark = true;
+ this.UseAjaxViewer = true;
+ protected static string GetLocale(string locale)
+ return string.IsNullOrEmpty(locale) ? "en" : locale; //NOXLATE
+ /// <summary>
+ /// </summary>
+ public string GeneratePreviewUrl(IResource res, string locale, bool isNew, string sessionID)
+ switch (res.ResourceType)
+ case "FeatureSource":
+ return GenerateFeatureSourcePreviewUrl(res, locale, isNew, sessionID);
+ case "ApplicationDefinition":
+ return GenerateFlexLayoutPreviewUrl(res, locale, isNew, sessionID);
+ case "LayerDefinition":
+ return GenerateLayerPreviewUrl(res, locale, isNew, sessionID);
+ case "MapDefinition":
+ return GenerateMapPreviewUrl(res, locale, isNew, sessionID);
+ case "WebLayout":
+ return GenerateWebLayoutPreviewUrl(res, locale, isNew, sessionID);
+ case "WatermarkDefinition":
+ return GenerateWatermarkPreviewUrl((IWatermarkDefinition)res, locale, isNew, sessionID);
+ default:
+ throw new InvalidOperationException(Strings.UnpreviewableResourceType);
+ protected abstract string GenerateWatermarkPreviewUrl(IWatermarkDefinition watermarkDefinition, string locale, bool isNew, string sessionID);
+ protected abstract string GenerateWebLayoutPreviewUrl(IResource res, string locale, bool isNew, string sessionID);
+ protected abstract string GenerateMapPreviewUrl(IResource res, string locale, bool isNew, string sessionID);
+ protected abstract string GenerateLayerPreviewUrl(IResource res, string locale, bool isNew, string sessionID);
+ protected abstract string GenerateFlexLayoutPreviewUrl(IResource res, string locale, bool isNew, string sessionID);
+ protected abstract string GenerateFeatureSourcePreviewUrl(IResource res, string locale, bool isNew, string sessionID);
+ public abstract bool IsPreviewableType(string resourceType);
+ public bool UseAjaxViewer
+ get;
+ set;
+ public bool AddDebugWatermark
+ get;
+ set;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:4.0.30319.18444
+// Runtime Version:4.0.30319.34209
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -2610,6 +2610,15 @@
/// <summary>
+ /// Looks up a localized string similar to The resource type cannot be previewed.
+ /// </summary>
+ public static string UnpreviewableResourceType {
+ get {
+ return ResourceManager.GetString("UnpreviewableResourceType", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Unsupported Load Procedure Type.
/// </summary>
public static string UnsupportedLoadProcedureType {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx 2014-11-21 01:27:04 UTC (rev 8454)
@@ -3435,4 +3435,7 @@
<data name="MDF_UnselectableLayer" xml:space="preserve">
<value>Layer {0} is marked as selectable but its feature class {1} in ({2}) has no identity properties. This layer will not be selectable.</value>
</data>
+ <data name="UnpreviewableResourceType" xml:space="preserve">
+ <value>The resource type cannot be previewed</value>
+ </data>
</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -36,6 +36,8 @@
using System.ComponentModel;
using System.Xml.Serialization;
using System.IO;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
@@ -1500,6 +1502,47 @@
/// <summary>
+ /// Gets the name of the active spatial context used by the given layer definition
+ /// </summary>
+ /// <param name="ldf"></param>
+ public static string GetLayerSpatialContext(ILayerDefinition ldf)
+ var conn = ldf.CurrentConnection;
+ var rl = ldf.SubLayer as IRasterLayerDefinition;
+ var vl = ldf.SubLayer as IVectorLayerDefinition;
+ if (vl != null)
+ var cls = conn.FeatureService.GetClassDefinition(vl.ResourceId, vl.FeatureName);
+ var gp = cls.FindProperty(vl.Geometry) as GeometricPropertyDefinition;
+ if (gp != null)
+ return gp.SpatialContextAssociation;
+ else if (rl != null)
+ var cls = conn.FeatureService.GetClassDefinition(rl.ResourceId, rl.FeatureName);
+ var rp = cls.FindProperty(rl.Geometry) as RasterPropertyDefinition;
+ if (rp != null)
+ return rp.SpatialContextAssociation;
+ return null;
+ /// <summary>
+ /// Creates a preview map definition for the given watermark
+ /// </summary>
+ /// <param name="wmd"></param>
+ public static IMapDefinition2 CreateWatermarkPreviewMapDefinition(IWatermarkDefinition wmd)
+ IMapDefinition2 map = (IMapDefinition2)ObjectFactory.CreateMapDefinition(wmd.CurrentConnection, wmd.SupportedMapDefinitionVersion, "Watermark Definition Preview"); //NOXLATE
+ map.CoordinateSystem = @"LOCAL_CS[""*XY-M*"", LOCAL_DATUM[""*X-Y*"", 10000], UNIT[""Meter"", 1], AXIS[""X"", EAST], AXIS[""Y"", NORTH]]"; //NOXLATE
+ map.Extents = ObjectFactory.CreateEnvelope(-1000000, -1000000, 1000000, 1000000);
+ map.AddWatermark(wmd);
+ return map;
+ /// <summary>
/// Replaces all references of the given resource id.
/// </summary>
/// <param name="doc">A resource document. Any replacements will modify the XmlDocument that is passed in</param>
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.Designer.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -0,0 +1,84 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace OSGeo.MapGuide.MaestroAPI.Http {
+ using System;
+ /// <summary>
+ /// A strongly-typed resource class, for looking up localized strings, etc.
+ /// </summary>
+ // This class was auto-generated by the StronglyTypedResourceBuilder
+ // class via a tool like ResGen or Visual Studio.
+ // To add or remove a member, edit your .ResX file then rerun ResGen
+ // with the /str option, or rebuild your VS project.
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")]
+ [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+ [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+ internal class Files {
+ private static global::System.Resources.ResourceManager resourceMan;
+ private static global::System.Globalization.CultureInfo resourceCulture;
+ [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+ internal Files() {
+ /// <summary>
+ /// Returns the cached ResourceManager instance used by this class.
+ /// </summary>
+ [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("OSGeo.MapGuide.MaestroAPI.Http.Files", typeof(Files).Assembly);
+ resourceMan = temp;
+ return resourceMan;
+ /// <summary>
+ /// Overrides the current thread's CurrentUICulture property for all
+ /// resource lookups using this strongly typed resource class.
+ /// </summary>
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
+ return resourceCulture;
+ set {
+ resourceCulture = value;
+ /// <summary>
+ /// Looks up a localized string similar to <?xml version="1.0"?>
+ ///<WatermarkDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="WatermarkDefinition-2.4.0.xsd">
+ /// <Content>
+ /// <SimpleSymbolDefinition>
+ /// <Name />
+ /// <Description />
+ /// <Graphics>
+ /// <Text>
+ /// <Content>'{0}'</Content>
+ /// <FontName>'Arial'</FontName>
+ /// <Height>3</Height>
+ /// <Justification>'Left'</Justification>
+ /// <TextCol [rest of string was truncated]";.
+ /// </summary>
+ internal static string TextWatermark {
+ get {
+ return ResourceManager.GetString("TextWatermark", resourceCulture);
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.resx (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Files.resx 2014-11-21 01:27:04 UTC (rev 8454)
@@ -0,0 +1,124 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="TextWatermark" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>Resources\TextWatermark.txt;System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
+</root>
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpResourcePreviewUrlGenerator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpResourcePreviewUrlGenerator.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpResourcePreviewUrlGenerator.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -0,0 +1,329 @@
+#endregion
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ObjectModels;
+using OSGeo.MapGuide.ObjectModels.ApplicationDefinition;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using OSGeo.MapGuide.ObjectModels.WebLayout;
+using System;
+using System.IO;
+using System.Linq;
+using System.Text;
+ class HttpResourcePreviewUrlGenerator : ResourcePreviewUrlGenerator
+ private string _rootUrl;
+ public HttpResourcePreviewUrlGenerator(string rootUrl)
+ _rootUrl = rootUrl;
+ protected override string GenerateWatermarkPreviewUrl(ObjectModels.WatermarkDefinition.IWatermarkDefinition wmd, string locale, bool isNew, string sessionID)
+ //We demand a 2.3.0 Map Definition or higher
+ if (wmd.CurrentConnection.SiteVersion < new Version(2, 3))
+ throw new InvalidOperationException(Strings.SiteVersionDoesntSupportWatermarks);
+ IMapDefinition2 map = Utility.CreateWatermarkPreviewMapDefinition(wmd);
+ return GenerateMapPreviewUrl(map, locale, isNew, sessionID);
+ protected string GetRootUrl()
+ string url = _rootUrl;
+ if (url.EndsWith("mapagent.fcgi"))
+ string[] tokens = url.Split('/');
+ url = string.Join("/", tokens.Take(tokens.Length - 2).ToArray());
+ if (!url.EndsWith("/")) //NOXLATE
+ url += "/"; //NOXLATE
+ return url;
+ protected override string GenerateWebLayoutPreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+ string url = GetRootUrl();
+ var resId = "Session:" + sessionID + "//" + Guid.NewGuid() + ".WebLayout"; //NOXLATE
+ var conn = res.CurrentConnection;
+ conn.ResourceService.SaveResourceAs(res, resId);
+ url += "mapviewerajax/?WEBLAYOUT=" + resId + "&SESSION=" + sessionID + "&LOCALE=" + GetLocale(locale); //NOXLATE
+ return url;
+ protected override string GenerateMapPreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+ var mdfId = "Session:" + sessionID + "//" + Guid.NewGuid() + ".MapDefinition"; //NOXLATE
+ var mdf = res as IMapDefinition;
+ if (mdf != null)
+ IMapDefinition2 mdf2 = mdf as IMapDefinition2;
+ if (mdf2 != null && this.AddDebugWatermark)
+ CreateDebugWatermark(mdf2, conn, null);
+ conn.ResourceService.SaveResourceAs(res, mdfId);
+ //if (PropertyService.Get(ConfigProperties.PreviewViewerType, "AJAX").Equals("AJAX")) //NOXLATE
+ if (this.UseAjaxViewer)
+ //Create temp web layout to house this map
+ var wl = ObjectFactory.CreateWebLayout(conn, new Version(1, 0, 0), mdfId);
+ //Add a custom zoom command (to assist previews of layers that aren't [0, infinity] scale)
+ AttachPreviewCommands(wl);
+ conn.ResourceService.SaveResourceAs(wl, resId);
+ else
+ ////Create temp flex layout
+ //var appDef = ObjectFactory.CreateFlexibleLayout(conn);
+ //var resId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".ApplicationDefinition"; //NOXLATE
+ //appDef.AddMapGroup("previewmap", true, mdfId); //NOXLATE
+ //conn.ResourceService.SaveResourceAs(appDef, resId);
+ //url += "fusion/templates/mapguide/preview/index.html?Session=" + sessionId + "&ApplicationDefinition=" + resId; //NOXLATE
+ return url;
+ private IMapDefinition CreateLayerPreviewMapDefinition(ILayerDefinition ldf, string sessionId, string layerName, IServerConnection conn)
+ //Create temp map definition to house our current layer
+ var mdfId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".MapDefinition"; //NOXLATE
+ string csWkt;
+ var extent = ldf.GetSpatialExtent(true, out csWkt);
+ if (extent == null)
+ throw new ApplicationException(Strings.FailedToCalculateFeatureSourceExtents);
+ //TODO: Based on the visible scales in this layer, size this extents accordingly
+ var mdf = ObjectFactory.CreateMapDefinition(conn, Strings.PreviewMap, csWkt, extent);
+ CreateDebugWatermark(mdf2, conn, layerSc);
+ var layer = mdf.AddLayer(null, layerName, ldf.ResourceID);
+ conn.ResourceService.SaveResourceAs(mdf, mdfId);
+ mdf.ResourceID = mdfId;
+ return mdf;
+ protected override string GenerateLayerPreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+ var ldf = (ILayerDefinition)res;
+ //Use feature source as name/label
+ string layerName = ResourceIdentifier.GetName(ldf.SubLayer.ResourceId);
+ var mdf = CreateLayerPreviewMapDefinition(ldf, sessionID, layerName, conn);
+ var wl = ObjectFactory.CreateWebLayout(conn, new Version(1, 0, 0), mdf.ResourceID);
+ else
+ //var appDef = ObjectFactory.CreatePreviewFlexLayout(conn);
+ return url;
+ protected override string GenerateFlexLayoutPreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+ //Create temp flex layout
+ var appDef = (IApplicationDefinition)res;
+ var conn = appDef.CurrentConnection;
+ var resId = "Session:" + sessionID + "//" + Guid.NewGuid() + ".ApplicationDefinition"; //NOXLATE
+ conn.ResourceService.SaveResourceAs(appDef, resId);
+ url += appDef.TemplateUrl + "?Session=" + sessionID + "&ApplicationDefinition=" + resId + "&locale=" + GetLocale(locale); //NOXLATE
+ return url;
+ protected override string GenerateFeatureSourcePreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+ var resId = res.ResourceID;
+ url += "schemareport/describeschema.php?viewer=basic&schemaName=&className=&resId=" + resId + "&sessionId=" + sessionID + "&locale=" + GetLocale(locale); //NOXLATE
+ return url;
+ private static string[] PREVIEWABLE_RESOURCE_TYPES = new string[]
+ ResourceTypes.FeatureSource.ToString(),
+ ResourceTypes.ApplicationDefinition.ToString(),
+ ResourceTypes.LayerDefinition.ToString(),
+ ResourceTypes.MapDefinition.ToString(),
+ ResourceTypes.WebLayout.ToString(),
+ ResourceTypes.WatermarkDefinition.ToString()
+ public override bool IsPreviewableType(string resourceType)
+ return Array.IndexOf(PREVIEWABLE_RESOURCE_TYPES, resourceType) >= 0;
+ static void AttachPreviewCommands(IWebLayout wl)
+ var cmd = wl.CreateInvokeScriptCommand();
+ cmd.Name = "ZoomScale"; //NOXLATE
+ cmd.Label = Strings.Label_ZoomToScale;
+ cmd.Tooltip = Strings.Desc_ZoomToScale;
+ cmd.Script = @"
+ var map = parent.parent.GetMapFrame();
+ var center = map.GetCenter();
+ var scale = parseFloat(prompt('Enter the scale:'));
+ map.ZoomToView(center.X, center.Y, scale, true);
+ "; //NOXLATE
+ cmd.TargetViewer = TargetViewerType.Ajax;
+ cmd.ImageURL = "../stdicons/icon_zoom.gif"; //NOXLATE
+ wl.CommandSet.AddCommand(cmd);
+ var cmd2 = wl.CreateInvokeScriptCommand();
+ cmd2.Name = "GetMapKml"; //NOXLATE
+ cmd2.Label = Strings.Label_GetMapKml;
+ cmd2.Description = Strings.Desc_GetMapKml;
+ cmd2.Tooltip = Strings.Desc_GetMapKml;
+ cmd2.Script = @"
+ var url = ""../mapagent/mapagent.fcgi?OPERATION=GETMAPKML&VERSION=1.0.0&FORMAT=KML&DISPLAYDPI=96&MAPDEFINITION=" + wl.Map.ResourceId + @""";
+ url += ""&SESSION="" + map.GetSessionId();
+ window.open(url);"; //NOXLATE
+ cmd2.TargetViewer = TargetViewerType.Ajax;
+ cmd2.ImageURL = "../stdicons/icon_invokescript.gif"; //NOXLATE
+ wl.CommandSet.AddCommand(cmd2);
+ var cmd3 = wl.CreateInvokeScriptCommand();
+ cmd3.Name = "GetExtents"; //NOXLATE
+ cmd3.Label = Strings.Label_GetExtents;
+ cmd3.Description = Strings.Desc_GetExtents;
+ cmd3.Tooltip = Strings.Desc_GetExtents;
+ cmd3.Script = @"
+ alert('Map Extents\n\nLower Left: ' + map.extX1 + ', ' + map.extY2 + '\nUpper Right: ' + map.extX2 + ', ' + map.extY1);
+ "; //NOXLATE
+ cmd3.TargetViewer = TargetViewerType.Ajax;
+ cmd3.ImageURL = "../stdicons/icon_invokescript.gif"; //NOXLATE
+ wl.CommandSet.AddCommand(cmd3);
+ var zoomScale = wl.CreateCommandItem(cmd.Name);
+ var menu = wl.CreateFlyout(Strings.Label_Tools, Strings.Label_Tools, Strings.Label_ExtraTools, string.Empty, string.Empty,
+ wl.CreateCommandItem("ZoomScale"), //NOXLATE
+ wl.CreateCommandItem("GetMapKml"), //NOXLATE
+ wl.CreateCommandItem("GetExtents") //NOXLATE
+ wl.ToolBar.AddItem(menu);
+ static string CreateDebugWatermark(IMapDefinition2 mdf, IServerConnection conn, string layerSc)
+ //Tidy up the CS WKT so that it can display nicely in a watermark
+ StringBuilder cleanCs = new StringBuilder(mdf.CoordinateSystem);
+ cleanCs.Replace("[", "[\n");
+ cleanCs.Replace("],", "],\n");
+ string message = null;
+ if (!string.IsNullOrEmpty(layerSc))
+ message = string.Format(Strings.DebugWatermarkMessageLayer,
+ mdf.Extents.MinX,
+ mdf.Extents.MinY,
+ mdf.Extents.MaxX,
+ mdf.Extents.MaxY,
+ cleanCs.ToString(),
+ layerSc);
+ else
+ message = string.Format(Strings.DebugWatermarkMessage,
+ mdf.Extents.MinX,
+ mdf.Extents.MinY,
+ mdf.Extents.MaxX,
+ mdf.Extents.MaxY,
+ cleanCs.ToString());
+ string watermarkXml = string.Format(Files.TextWatermark, message);
+ string resId = "Session:" + conn.SessionID + "//Debug.WatermarkDefinition";
+ using (var ms = new MemoryStream(Encoding.UTF8.GetBytes(watermarkXml)))
+ conn.ResourceService.SetResourceXmlData(resId, ms);
+ //Add watermark to Map Definition
+ var wmd = (IWatermarkDefinition)conn.ResourceService.GetResource(resId);
+ mdf.AddWatermark(wmd);
+ return resId;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -2006,5 +2006,10 @@
return info;
+ public override Resource.Preview.IResourcePreviewUrlGenerator GetPreviewUrlGenerator()
+ return new HttpResourcePreviewUrlGenerator(m_reqBuilder.HostURI);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj 2014-11-21 01:05:28 UTC (rev 8453)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/OSGeo.MapGuide.MaestroAPI.Http.csproj 2014-11-21 01:27:04 UTC (rev 8454)
@@ -77,14 +77,25 @@
<Compile Include="Commands\HttpCreateRuntimeMap.cs" />
<Compile Include="Commands\HttpDescribeRuntimeMap.cs" />
<Compile Include="Commands\HttpGetFdoCacheInfo.cs" />
+ <Compile Include="Files.Designer.cs">
+ <AutoGen>True</AutoGen>
+ <DesignTime>True</DesignTime>
+ <DependentUpon>Files.resx</DependentUpon>
+ </Compile>
<Compile Include="HttpCapabilities.cs" />
<Compile Include="HttpCoordinateSystem.cs" />
<Compile Include="HttpCoordinateSystemCatalog.cs" />
<Compile Include="HttpCoordinateSystemCategory.cs" />
+ <Compile Include="HttpResourcePreviewUrlGenerator.cs" />
<Compile Include="HttpServerConnection.cs" />
<Compile Include="Commands\HttpGetResourceContents.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="RequestBuilder.cs" />
+ <Compile Include="Strings.Designer.cs">
+ <DependentUpon>Strings.resx</DependentUpon>
+ </Compile>
<Compile Include="XmlDataReader.cs" />
<Compile Include="XmlFeatureReader.cs" />
<Compile Include="XmlReaderBase.cs" />
@@ -113,6 +124,19 @@
<Install>true</Install>
</BootstrapperPackage>
</ItemGroup>
+ <ItemGroup>
+ <EmbeddedResource Include="Files.resx">
+ <Generator>ResXFileCodeGenerator</Generator>
+ <LastGenOutput>Files.Designer.cs</LastGenOutput>
+ </EmbeddedResource>
+ <EmbeddedResource Include="Strings.resx">
+ <LastGenOutput>Strings.Designer.cs</LastGenOutput>
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\TextWatermark.txt" />
+ </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<!-- To modify your build process, add your task inside one of the targets below and uncomment it.
Other similar extension points exist, see Microsoft.Common.targets.
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Resources/TextWatermark.txt
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Resources/TextWatermark.txt (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Resources/TextWatermark.txt 2014-11-21 01:27:04 UTC (rev 8454)
@@ -0,0 +1,38 @@
+<?xml version="1.0"?>
+<WatermarkDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="WatermarkDefinition-2.4.0.xsd">
+ <Content>
+ <SimpleSymbolDefinition>
+ <Name />
+ <Description />
+ <Graphics>
+ <Text>
+ <Content>'{0}'</Content>
+ <FontName>'Arial'</FontName>
+ <Height>3</Height>
+ <Justification>'Left'</Justification>
+ <TextColor>FF000000</TextColor>
+ <Frame>
+ <FillColor>CCFFFFFF</FillColor>
+ </Frame>
+ </Text>
+ </Graphics>
+ <PointUsage />
+ <ParameterDefinition />
+ </SimpleSymbolDefinition>
+ </Content>
+ <Appearance />
+ <Position>
+ <XYPosition>
+ <XPosition>
+ <Offset>10</Offset>
+ <Unit>Points</Unit>
+ <Alignment>Left</Alignment>
+ </XPosition>
+ <YPosition>
+ <Alignment>Top</Alignment>
+ </YPosition>
+ </XYPosition>
+ </Position>
+</WatermarkDefinition>
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.Designer.cs 2014-11-21 01:27:04 UTC (rev 8454)
@@ -0,0 +1,180 @@
+ using System;
+ /// <summary>
+ /// </summary>
+ internal class Strings {
+ internal Strings() {
+ /// <summary>
+ /// </summary>
+ get {
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("OSGeo.MapGuide.MaestroAPI.Http.Strings", typeof(Strings).Assembly);
+ /// <summary>
+ /// </summary>
+ get {
+ set {
+ /// <summary>
+ /// Looks up a localized string similar to MapGuide Debugging Information\n==============================\n\nMap Extents Min: ({0}, {1})\nMap Extents Max: ({2}, {3})\nMap Coordinate System: \n{4}.
+ /// </summary>
+ internal static string DebugWatermarkMessage {
+ get {
+ return ResourceManager.GetString("DebugWatermarkMessage", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to MapGuide Debugging Information\n==============================\n\nMap Extents Min: ({0}, {1})\nMap Extents Max: ({2}, {3})\nMap Coordinate System: \n{4}\nLayer Spatial Context: {5}.
+ /// </summary>
+ internal static string DebugWatermarkMessageLayer {
+ get {
+ return ResourceManager.GetString("DebugWatermarkMessageLayer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Displays the current map extents.
+ /// </summary>
+ internal static string Desc_GetExtents {
+ get {
+ return ResourceManager.GetString("Desc_GetExtents", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Gets the current map as a KML document.
+ /// </summary>
+ internal static string Desc_GetMapKml {
+ get {
+ return ResourceManager.GetString("Desc_GetMapKml", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Zoom to a specified scale.
+ /// </summary>
+ internal static string Desc_ZoomToScale {
+ get {
+ return ResourceManager.GetString("Desc_ZoomToScale", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Could not calculate the extents of the Feature Source. Preview is not possible.
+ /// </summary>
+ internal static string FailedToCalculateFeatureSourceExtents {
+ get {
+ return ResourceManager.GetString("FailedToCalculateFeatureSourceExtents", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Extra Tools.
+ /// </summary>
+ internal static string Label_ExtraTools {
+ get {
+ return ResourceManager.GetString("Label_ExtraTools", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Get Extents.
+ /// </summary>
+ internal static string Label_GetExtents {
+ get {
+ return ResourceManager.GetString("Label_GetExtents", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Get KML.
+ /// </summary>
+ internal static string Label_GetMapKml {
+ get {
+ return ResourceManager.GetString("Label_GetMapKml", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Tools.
+ /// </summary>
+ internal static string Label_Tools {
+ get {
+ return ResourceManager.GetString("Label_Tools", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Zoom to Scale.
+ /// </summary>
+ internal static string Label_ZoomToScale {
+ get {
+ return ResourceManager.GetString("Label_ZoomToScale", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Preview Map.
+ /// </summary>
+ internal static string PreviewMap {
+ get {
+ return ResourceManager.GetString("PreviewMap", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The site version of this current connection is not known to support watermarks.
+ /// </summary>
+ internal static string SiteVersionDoesntSupportWatermarks {
+ get {
+ return ResourceManager.GetString("SiteVersionDoesntSupportWatermarks", resourceCulture);
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.resx (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/Strings.resx 2014-11-21 01:27:04 UTC (rev 8454)
@@ -0,0 +1,159 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ </data>
+ </data>
+ <data name="Desc_GetExtents" xml:space="preserve">
+ <value>Displays the current map extents</value>
+ </data>
+ <data name="Desc_GetMapKml" xml:space="preserve">
+ <value>Gets the current map as a KML document</value>
+ </data>
+ <data name="Desc_ZoomToScale" xml:space="preserve">
+ <value>Zoom to a specified scale</value>
+ </data>
+ <data name="FailedToCalculateFeatureSourceExtents" xml:space="preserve">
+ <value>Could not calculate the extents of the Feature Source. Preview is not possible</value>
+ </data>
+ <data name="Label_ExtraTools" xml:space="preserve">
+ <value>Extra Tools</value>
+ </data>
+ <data name="Label_GetExtents" xml:space="preserve">
+ <value>Get Extents</value>
+ </data>
+ <data name="Label_GetMapKml" xml:space="preserve">
+ <value>Get KML</value>
+ </data>
+ <data name="Label_Tools" xml:space="preserve">
+ <value>Tools</value>
+ </data>
+ <data name="Label_ZoomToScale" xml:space="preserve">
+ <value>Zoom to Scale</value>
+ </data>
+ <data name="PreviewMap" xml:space="preserve">
+ <value>Preview Map</value>
+ </data>
+ <data name="SiteVersionDoesntSupportWatermarks" xml:space="preserve">
+ <value>The site version of this current connection is not known to support watermarks</value>
+ </data>
+</root>
More information about the mapguide-commits
