[mapguide-commits] r8456 - in trunk/Tools/Maestro: Maestro.Base/Commands Maestro.Editors/Fusion Maestro.Editors/Preview OSGeo.MapGuide.MaestroAPI/ObjectModels OSGeo.MapGuide.MaestroAPI.Rest
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Nov 20 18:27:41 PST 2014
Author: jng
Date: 2014-11-20 18:27:41 -0800 (Thu, 20 Nov 2014)
New Revision: 8456
Added:
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/RestResourcePreviewUrlGenerator.cs
   trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs
   trunk/Tools/Maestro/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/Fusion/MapSettingsCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/Preview/DefaultResourcePreviewer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/OSGeo.MapGuide.MaestroAPI.Rest.csproj
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/RestConnection.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs
#2506: Add resource preview support
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs	2014-11-21 01:30:19 UTC (rev 8455)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/StartupCommand.cs	2014-11-21 02:27:41 UTC (rev 8456)
@@ -49,6 +49,7 @@
                 var urlLauncher = ServiceRegistry.GetService<UrlLauncherService>();
                 ResourcePreviewerFactory.RegisterPreviewer("Maestro.Http", new LocalMapPreviewer(new DefaultResourcePreviewer(urlLauncher), urlLauncher)); //NOXLATE
+                ResourcePreviewerFactory.RegisterPreviewer("Maestro.Rest", new LocalMapPreviewer(new DefaultResourcePreviewer(urlLauncher), urlLauncher)); //NOXLATE
                 //A stub previewer does nothing, but will use local map previews for applicable resources if the configuration
                 //property is set
                 ResourcePreviewerFactory.RegisterPreviewer("Maestro.LocalNative", new LocalMapPreviewer(new StubPreviewer(), urlLauncher)); //NOXLATE
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.cs	2014-11-21 01:30:19 UTC (rev 8455)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.cs	2014-11-21 02:27:41 UTC (rev 8456)
@@ -56,10 +56,13 @@
             try
                 _fsvc = (IFusionService)_edsvc.GetService((int)ServiceType.Fusion);
-                _baseUrl = service.GetCustomProperty("BaseUrl").ToString(); //NOXLATE
+                if (service.CurrentConnection.ProviderName.ToUpper() == "MAESTRO.HTTP")
+                    _baseUrl = service.GetCustomProperty("BaseUrl").ToString(); //NOXLATE
-                if (!_baseUrl.EndsWith("/")) //NOXLATE
-                    _baseUrl += "/"; //NOXLATE
+                    if (!_baseUrl.EndsWith("/")) //NOXLATE
+                        _baseUrl += "/"; //NOXLATE
             catch
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/MapSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/MapSettingsCtrl.cs	2014-11-21 01:30:19 UTC (rev 8455)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/MapSettingsCtrl.cs	2014-11-21 02:27:41 UTC (rev 8456)
@@ -53,10 +53,13 @@
             try
                 _fsvc = (IFusionService)service.GetService((int)ServiceType.Fusion);
             catch
Modified: trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs	2014-11-21 01:30:19 UTC (rev 8455)
+++ trunk/Tools/Maestro/Maestro.Editors/Fusion/WidgetSettingsCtrl.cs	2014-11-21 02:27:41 UTC (rev 8456)
@@ -58,10 +58,13 @@
                 _edsvc = service;
                 _context = new FlexibleLayoutEditorContext(_fsvc);
             catch
Modified: trunk/Tools/Maestro/Maestro.Editors/Preview/DefaultResourcePreviewer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Preview/DefaultResourcePreviewer.cs	2014-11-21 01:30:19 UTC (rev 8455)
+++ trunk/Tools/Maestro/Maestro.Editors/Preview/DefaultResourcePreviewer.cs	2014-11-21 02:27:41 UTC (rev 8456)
@@ -87,7 +87,6 @@
             IServerConnection conn = res.CurrentConnection;
             BusyWaitDelegate worker = () =>
-                string mapguideRootUrl = (string)conn.GetCustomProperty("BaseUrl"); //NOXLATE
                 //Save the current resource to another session copy
                 string resId = "Session:" + edSvc.SessionID + "//" + res.ResourceType.ToString() + "Preview" + Guid.NewGuid() + "." + res.ResourceType.ToString(); //NOXLATE
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs	2014-11-21 01:30:19 UTC (rev 8455)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinitionInterfaces.cs	2014-11-21 02:27:41 UTC (rev 8456)
@@ -584,6 +584,18 @@
     public static class ExtensionMethods
         /// <summary>
+        /// Gets the name of the fusion template
+        /// </summary>
+        /// <param name="appDef"></param>
+        /// <returns></returns>
+        public static string GetTemplateName(this IApplicationDefinition appDef)
+            string[] tokens = appDef.TemplateUrl.Split('/');
+            // fusion/templates/mapguide/{templateName}/index.html
+            return tokens[tokens.Length - 2];
+        /// <summary>
         /// Gets whether a widget with the specified name already exists
         /// </summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/OSGeo.MapGuide.MaestroAPI.Rest.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/OSGeo.MapGuide.MaestroAPI.Rest.csproj	2014-11-21 01:30:19 UTC (rev 8455)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/OSGeo.MapGuide.MaestroAPI.Rest.csproj	2014-11-21 02:27:41 UTC (rev 8456)
@@ -49,6 +49,7 @@
     <Compile Include="RestCoordinateSystemCategory.cs" />
     <Compile Include="RestCoordinateSystemDefinition.cs" />
     <Compile Include="RestException.cs" />
+    <Compile Include="RestResourcePreviewUrlGenerator.cs" />
     <Compile Include="Strings.Designer.cs">
       <AutoGen>True</AutoGen>
       <DesignTime>True</DesignTime>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/RestConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/RestConnection.cs	2014-11-21 01:30:19 UTC (rev 8455)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/RestConnection.cs	2014-11-21 02:27:41 UTC (rev 8456)
@@ -39,7 +39,9 @@
     public class RestConnection : MgServerConnectionBase,
                                   IServerConnection,
                                   IFeatureService,
-                                  IResourceService
+                                  IResourceService,
+                                  IMappingService,
+                                  IFusionService
         public const string PARAM_URL = "Url";
         public const string PARAM_USERNAME = "Username";
@@ -47,6 +49,8 @@
         private string _restRootUrl;
+        internal string RestRootUrl { get { return _restRootUrl; } }
         internal RestClient MakeClient()
             return new RestClient(_restRootUrl);
@@ -1034,6 +1038,17 @@
+        public Stream RenderMapLegend(Mapping.RuntimeMap map, int width, int height, System.Drawing.Color backgroundColor, string format)
+            return FetchRuntimeMapRepresentationAsStream(map, "/legendimage.{type}", (req) =>
+                req.AddUrlSegment("type", format.ToLower());
+                req.AddParameter("width", width);
+                req.AddParameter("height", height);
         public override Stream GetTile(string mapdefinition, string baselayergroup, int col, int row, int scaleindex, string format)
             return FetchResourceRepresentationAsStream(mapdefinition, "/tile.{type}/{groupName}/{scale}/{col}/{row}", (req) =>
@@ -1055,6 +1070,10 @@
                     return this;
                 case ServiceType.Resource:
                     return this;
+                case ServiceType.Mapping:
+                    return this;
+                case ServiceType.Fusion:
+                    return this;
                 default:
                     throw new ArgumentException(string.Format(Strings.InvalidOrUnsupportedServiceType, serviceType), "serviceType");
@@ -1072,5 +1091,37 @@
                 return _restRootUrl + " (v" + this.SiteVersion.ToString() + ")";
+        public override Resource.Preview.IResourcePreviewUrlGenerator GetPreviewUrlGenerator()
+            return new RestResourcePreviewUrlGenerator(this);
+        public ObjectModels.ApplicationDefinition.IApplicationDefinitionTemplateInfoSet GetApplicationTemplates()
+            var client = MakeClient();
+            var req = MakeRequest("services/fusiontemplates.xml");
+            var resp = ExecuteRequest<OSGeo.MapGuide.ObjectModels.ApplicationDefinition_1_0_0.ApplicationDefinitionTemplateInfoSet>(client, req);
+            ValidateResponse(resp);
+            return GetData(resp);
+        public ObjectModels.ApplicationDefinition.IApplicationDefinitionWidgetInfoSet GetApplicationWidgets()
+            var req = MakeRequest("services/fusionwidgets.xml");
+            var resp = ExecuteRequest<OSGeo.MapGuide.ObjectModels.ApplicationDefinition_1_0_0.ApplicationDefinitionWidgetInfoSet>(client, req);
+        public ObjectModels.ApplicationDefinition.IApplicationDefinitionContainerInfoSet GetApplicationContainers()
+            var req = MakeRequest("services/fusioncontainers.xml");
+            var resp = ExecuteRequest<OSGeo.MapGuide.ObjectModels.ApplicationDefinition_1_0_0.ApplicationDefinitionContainerInfoSet>(client, req);
Added: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/RestResourcePreviewUrlGenerator.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/RestResourcePreviewUrlGenerator.cs	                        (rev 0)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Rest/RestResourcePreviewUrlGenerator.cs	2014-11-21 02:27:41 UTC (rev 8456)
@@ -0,0 +1,104 @@
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.MaestroAPI.Resource.Preview;
+using OSGeo.MapGuide.ObjectModels.ApplicationDefinition;
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI.Rest
+    class RestResourcePreviewUrlGenerator : ResourcePreviewUrlGenerator
+        private RestConnection _conn;
+        public RestResourcePreviewUrlGenerator(RestConnection conn)
+            _conn = conn;
+        private string GetSuffix(string resourceID, string sessionID)
+            ResourceIdentifier ri = new ResourceIdentifier(resourceID);
+            if (ri.IsInLibrary)
+                return "/library/" + ri.Path + "." + ri.ResourceType;
+            else
+                return "/session/" + sessionID + "/" + ri.Path + "." + ri.ResourceType;
+        protected override string GenerateWatermarkPreviewUrl(ObjectModels.WatermarkDefinition.IWatermarkDefinition res, string locale, bool isNew, string sessionID)
+            var url = _conn.RestRootUrl + GetSuffix(res.ResourceID, sessionID) + "/preview";
+            return url;
+        protected override string GenerateWebLayoutPreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+            return url;
+        protected override string GenerateMapPreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+            return url;
+        protected override string GenerateLayerPreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+            var url = _conn.RestRootUrl + GetSuffix(res.ResourceID, sessionID) + "/viewer";
+            return url;
+        protected override string GenerateFlexLayoutPreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+            var flexLayout = (IApplicationDefinition)res;
+            var url = _conn.RestRootUrl + GetSuffix(res.ResourceID, sessionID) + "/viewer/" + flexLayout.GetTemplateName();
+            return url;
+        protected override string GenerateFeatureSourcePreviewUrl(Resource.IResource res, string locale, bool isNew, string sessionID)
+            return url;
+        private static string[] PREVIEWABLE_RESOURCE_TYPES = new string[]
+            ResourceTypes.FeatureSource.ToString(),
+            ResourceTypes.ApplicationDefinition.ToString(),
+            ResourceTypes.LayerDefinition.ToString(),
+            ResourceTypes.MapDefinition.ToString(),
+            ResourceTypes.WebLayout.ToString(),
+            ResourceTypes.WatermarkDefinition.ToString()
+        public override bool IsPreviewableType(string resourceType)
+            return Array.IndexOf(PREVIEWABLE_RESOURCE_TYPES, resourceType) >= 0;
More information about the mapguide-commits mailing list
