[mapguide-commits] r8377 - in trunk/MgDev/UnitTest/WebTier: . Java Java/src Java/src/org Java/src/org/osgeo Java/src/org/osgeo/mapguide Java/src/org/osgeo/mapguide/test Java/src/org/osgeo/mapguide/test/common Java/src/org/osgeo/mapguide/test/operations Java/src/org/osgeo/mapguide/test/platform
svn_mapguide at osgeo.org
Thu Oct 2 11:33:49 PDT 2014
Author: jng
Date: 2014-10-02 11:33:49 -0700 (Thu, 02 Oct 2014)
New Revision: 8377
Added:
trunk/MgDev/UnitTest/WebTier/Java/
trunk/MgDev/UnitTest/WebTier/Java/build.xml
trunk/MgDev/UnitTest/WebTier/Java/src/
trunk/MgDev/UnitTest/WebTier/Java/src/org/
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/ApiTypes.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/CommonTests.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Console.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTestExecutorCollection.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTests.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/PlatformFactory.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Program.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/Assert.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/AssertException.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/CommonUtility.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/IExternalTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/IPlatformFactory.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestExecutor.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestExecutorCollection.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestLogger.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/MutableInteger.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/SqliteDb.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestExecutorCollectionBase.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestLoggerFile.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestResult.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/operations/
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/operations/IWebLayoutCreator.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/BatchPropertyCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderMemoryConstructorTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderStringConstructorTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderTestData.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ClassDefinitionCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CoordinateCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurvePolygonCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveRingCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveSegmentCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveStringCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/FeatureCommandCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/FeatureSchemaCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/GeomBuild.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/GeometryCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/IntCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LineStringCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LinearRingCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/MapCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/PropertyCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/PropertyDefinitionCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/StringCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/StringPropertyCollectionTest.java
#2307: Add first cut of Java test runner. This implements the platform external tests ported over from the .net runner.
Added: trunk/MgDev/UnitTest/WebTier/Java/build.xml
--- trunk/MgDev/UnitTest/WebTier/Java/build.xml (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/build.xml 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,144 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<project name="MgUnitTest" default="dist" basedir=".">
+ <description>MgUnitTest project file</description>
+ <taskdef resource="net/sf/antcontrib/antcontrib.properties"/>
+ <!-- set global properties for this build -->
+ <property name="src" location="src" />
+ <property name="build" location="build" />
+ <property name="dist" location="dist" />
+ <property name="classpath" location="lib" />
+ <property name="build.target" location="64" />
+ <property name="binsrc.web" location="../../../Web/bin/release64" />
+ <property name="jarsrc.web" location="../../../Web/src/WEB-INF/lib" />
+ <property name="mapguide.res.src" location="../../../Common/MapGuideCommon/Resources/mapguide_en.res" />
+ <property name="mapguide.config.src" location="../../../Web/src/webconfig.ini" />
+ <property name="mapguide.res" location="${dist}/Resources/mapguide_en.res" />
+ <property name="mapguide.config" location="${dist}/webconfig.ini" />
+ <property name="mapguide.dictpath" location="../../../Oem/CsMap/Dictionaries" />
+ <property name="unittest.logpath" location="${dist}/unittest.log" />
+ <path id="master-classpath">
+ <fileset dir="${classpath}">
+ <include name="*.jar" />
+ </fileset>
+ </path>
+ <target name="init">
+ <!-- Create the time stamp -->
+ <tstamp/>
+ <!-- Create the build directory structure used by compile -->
+ <mkdir dir="${build}"/>
+ <!-- Copy required jars and dlls -->
+ <copy todir="${classpath}">
+ <fileset dir="${jarsrc.web}">
+ <include name="**/MapGuideApiEx.jar" />
+ </fileset>
+ </copy>
+ <condition property="binsrc.web" value="../../../Web/bin/release">
+ <equals arg1="${build.target}" arg2="32" />
+ </condition>
+ <condition property="binsrc.web" value="../../../Web/bin/release64">
+ <equals arg1="${build.target}" arg2="64" />
+ </condition>
+ <echo message="Copying dlls from ${binsrc.web}" />
+ <fileset dir="${binsrc.web}">
+ <include name="**/Mg*.dll" />
+ <include name="**/ACE.dll" />
+ <include name="**/GEOS.dll" />
+ <include name="**/lib_json.dll" />
+ <include name="**/MapGuideJavaApiEx.dll" />
+ <include name="**/xerces-c_3_1mg.dll" />
+ </fileset>
+ </copy>
+ </target>
+ <target name="compile" depends="init"
+ description="compile the source " >
+ <!-- Compile the java code from ${src} into ${build} referencing our MapGuide API jar -->
+ <javac srcdir="${src}" destdir="${build}" includeantruntime="false">
+ <classpath>
+ <pathelement path="${classpath}" />
+ </fileset>
+ </classpath>
+ </javac>
+ </target>
+ <target name="dist" depends="compile"
+ description="generate the distribution" >
+ <!-- Create the distribution directory -->
+ <mkdir dir="${dist}"/>
+ <!-- Make the unit test jar ensuring the MapGuide API jar reference is intact -->
+ <jar jarfile="${dist}/MgUnitTest.jar">
+ <fileset dir="${build}" />
+ <manifest>
+ <attribute name="Main-Class" value="org.osgeo.mapguide.test.Program" />
+ <attribute name="Class-Path" value="MapGuideApiEx.jar" />
+ </manifest>
+ </jar>
+ <copy todir="${dist}">
+ <include name="**/*" />
+ </fileset>
+ </copy>
+ <copy file="${mapguide.res.src}" tofile="${mapguide.res}" />
+ <!-- write webconfig.ini -->
+ <inifile dest="${mapguide.config}">
+ <set section="GeneralProperties" property="DefaultMessageLocale" value="en" />
+ <set section="GeneralProperties" property="LogsPath" value="${dist}/Logs" />
+ <set section="GeneralProperties" property="MentorDictionaryPath" value="${mapguide.dictpath}" />
+ <set section="GeneralProperties" property="ResourcesPath" value="${dist}/Resources" />
+ <set section="GeneralProperties" property="TcpIpMtu" value="1460" />
+ <set section="GeneralProperties" property="TempPath" value="${dist}/Temp" />
+ <set section="GeneralProperties" property="FailoverRetryTime" value="1" />
+ <set section="AdministrativeConnectionProperties" property="MaxConnections" value="2" />
+ <set section="AdministrativeConnectionProperties" property="Port" value="2810" />
+ <set section="ClientConnectionProperties" property="MaxConnections" value="12" />
+ <set section="ClientConnectionProperties" property="Port" value="2811" />
+ <set section="SiteConnectionProperties" property="IpAddress" value="127.0.0.1" />
+ <set section="SiteConnectionProperties" property="MaxConnections" value="6" />
+ <set section="SiteConnectionProperties" property="Port" value="2812" />
+ <set section="AgentProperties" property="DebugPause" value="0" />
+ <set section="AgentProperties" property="DisableAuthoring" value="0" />
+ <set section="AgentProperties" property="DisableWfs" value="0" />
+ <set section="AgentProperties" property="DisableWms" value="0" />
+ <set section="AgentProperties" property="ErrorLogEnabled" value="0" />
+ <set section="AgentProperties" property="ErrorLogFilename" value="Error.log" />
+ <set section="AgentProperties" property="RequestLogEnabled" value="0" />
+ <set section="AgentProperties" property="RequestLogFilename" value="Request.log" />
+ <set section="OgcProperties" property="WfsPassword" value="wfs" />
+ <set section="OgcProperties" property="WmsPassword" value="wms" />
+ <set section="OgcProperties" property="CITEWfsEnabled" value="0" />
+ <set section="OgcProperties" property="CITEWmsEnabled" value="0" />
+ </inifile>
+ </target>
+ <target name="check" depends="dist">
+ <exec executable="java" dir="${dist}">
+ <arg line="-jar MgUnitTest.jar ${mapguide.config} ${unittest.logpath}" />
+ <env key="MENTOR_DICTIONARY_PATH" value="${mapguide.dictpath}" />
+ </exec>
+ </target>
+ <target name="clean"
+ description="clean up" >
+ <!-- Delete the ${build} and ${dist} directory trees -->
+ <delete dir="${build}"/>
+ <delete dir="${dist}"/>
+ <delete dir="${classpath}"/>
+ </target>
+</project>
\ No newline at end of file
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/ApiTypes.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/ApiTypes.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/ApiTypes.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,7 @@
+package org.osgeo.mapguide.test;
+public class ApiTypes
+ public static final String Platform = "Api";
+ public static final String Http = "Http";
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/CommonTests.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/CommonTests.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/CommonTests.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,66 @@
+import java.util.*;
+import org.osgeo.mapguide.test.common.*;
+import org.osgeo.mapguide.test.platform.*;
+public class CommonTests
+ public static int Execute(IPlatformFactory factory, ITestLogger logger, MutableInteger testsRun) {
+ int failures = 0;
+ Vector<IExternalTest> tests = new Vector<IExternalTest>();
+ //--------------- BEGIN Test Registration -----------------//
+ tests.add(new ByteReaderTest());
+ tests.add(new ByteReaderMemoryConstructorTest());
+ tests.add(new ByteReaderStringConstructorTest());
+ tests.add(new BatchPropertyCollectionTest());
+ tests.add(new ClassDefinitionCollectionTest());
+ tests.add(new CoordinateCollectionTest());
+ tests.add(new CurvePolygonCollectionTest());
+ tests.add(new CurveRingCollectionTest());
+ tests.add(new CurveSegmentCollectionTest());
+ tests.add(new CurveStringCollectionTest());
+ tests.add(new FeatureCommandCollectionTest());
+ tests.add(new FeatureSchemaCollectionTest());
+ tests.add(new GeometryCollectionTest());
+ tests.add(new IntCollectionTest());
+ tests.add(new LinearRingCollectionTest());
+ tests.add(new LineStringCollectionTest());
+ tests.add(new MapCollectionTest());
+ tests.add(new PropertyCollectionTest());
+ tests.add(new PropertyDefinitionCollectionTest());
+ tests.add(new StringCollectionTest());
+ tests.add(new StringPropertyCollectionTest());
+ //--------------- END Test Registration -------------------//
+ for (IExternalTest test : tests)
+ try
+ String clsName = CommonUtility.GetTypeName(test);
+ logger.WriteLine("****** Executing platform test: " + clsName + " *********");
+ Console.WriteLine("Executing external platform test: " + clsName);
+ test.Execute(factory, logger);
+ catch (AssertException ex)
+ logger.WriteLine("Assertion failure: " + ex.getMessage());
+ Console.WriteLine("Assertion failure: " + ex.getMessage());
+ failures++;
+ catch (Exception ex)
+ logger.WriteLine("General failure: " + CommonUtility.ExceptionToString(ex));
+ Console.WriteLine("General failure: " + CommonUtility.ExceptionToString(ex));
+ failures++;
+ finally
+ testsRun.increment();
+ return failures;
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Console.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Console.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Console.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,25 @@
+// .net console shim
+public class Console
+ public static void Write(String message)
+ System.out.print(message);
+ public static void Write(String format, Object ... args)
+ Write(String.format(format, args));
+ public static void WriteLine(String message)
+ System.out.println(message);
+ public static void WriteLine(String format, Object ... args)
+ WriteLine(String.format(format, args));
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTestExecutorCollection.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTestExecutorCollection.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTestExecutorCollection.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,445 @@
+import java.io.*;
+import org.osgeo.mapguide.*;
+import org.osgeo.mapguide.test.operations.*;
+public class MapGuideTestExecutorCollection extends TestExecutorCollectionBase
+ private HashMap<String, ITestExecutor> _executors;
+ private MgUserInformation _userInfo;
+ private MgSiteConnection _conn;
+ public MapGuideTestExecutorCollection(MgUserInformation userInfo, MgSiteConnection conn)
+ _userInfo = userInfo;
+ _conn = conn;
+ _executors = new HashMap<String, ITestExecutor>();
+ protected void SetupExecutors(String dbPath)
+ //NOTE: We can't share the SqliteVm instance among our executor Objects as this messes up query results
+ //we must be able to re-create a new SqliteVm for each executor, so we pass down the db path
+ MgResourceService resSvc = (MgResourceService)_conn.createService(MgServiceType.ResourceService);
+ MgFeatureService featSvc = (MgFeatureService)_conn.createService(MgServiceType.FeatureService);
+ MgDrawingService drawSvc = (MgDrawingService)_conn.createService(MgServiceType.DrawingService);
+ MgSite site = _conn.GetSite();
+ MgServerAdmin admin = new MgServerAdmin();
+ admin.Open(_userInfo);
+ MgWebLayoutCreator wlCreator = new MgWebLayoutCreator(resSvc);
+ MgMapCreator creator = new MgMapCreator(_conn, resSvc);
+ MgSessionCreator sessionCreator = new MgSessionCreator(_conn);
+ MgApplySession sessionApply = new MgApplySession(_userInfo);
+ MgSession session = new MgSession();
+ //Resource Service
+ _executors.put("ApplyResourcePackage".toUpperCase(), new ApplyResourcePackage(resSvc, dbPath));
+ _executors.put("ChangeResourceOwner".toUpperCase(), new ChangeResourceOwner(resSvc, dbPath));
+ _executors.put("CopyResource".toUpperCase(), new CopyResource(resSvc, dbPath));
+ _executors.put("DeleteResource".toUpperCase(), new DeleteResource(resSvc, dbPath));
+ _executors.put("DeleteResourceData".toUpperCase(), new DeleteResourceData(resSvc, dbPath));
+ _executors.put("EnumerateResourceData".toUpperCase(), new EnumerateResourceData(resSvc, dbPath));
+ _executors.put("EnumerateResourceReferences".toUpperCase(), new EnumerateResourceReferences(resSvc, dbPath));
+ _executors.put("EnumerateResources".toUpperCase(), new EnumerateResources(resSvc, dbPath));
+ _executors.put("GetRepositoryContent".toUpperCase(), new GetRepositoryContent(resSvc, dbPath));
+ _executors.put("GetRepositoryHeader".toUpperCase(), new GetRepositoryHeader(resSvc, dbPath));
+ _executors.put("GetResourceContent".toUpperCase(), new GetResourceContent(resSvc, dbPath));
+ _executors.put("GetResourceData".toUpperCase(), new GetResourceData(resSvc, dbPath));
+ _executors.put("GetResourceHeader".toUpperCase(), new GetResourceHeader(resSvc, dbPath));
+ _executors.put("InheritPermissionsFrom".toUpperCase(), new InheritPermissionsFrom(resSvc, dbPath));
+ _executors.put("MoveResource".toUpperCase(), new MoveResource(resSvc, dbPath));
+ _executors.put("RenameResourceData".toUpperCase(), new RenameResourceData(resSvc, dbPath));
+ _executors.put("SetResource".toUpperCase(), new SetResource(resSvc, dbPath));
+ _executors.put("SetResourceData".toUpperCase(), new SetResourceData(resSvc, dbPath));
+ _executors.put("UpdateRepository".toUpperCase(), new UpdateRepository(resSvc, dbPath));
+ //Feature Service
+ _executors.put("DescribeFeatureSchema".toUpperCase(), new DescribeFeatureSchema(featSvc, dbPath));
+ _executors.put("ExecuteSqlQuery".toUpperCase(), new ExecuteSqlQuery(featSvc, dbPath));
+ _executors.put("GetClasses".toUpperCase(), new GetClasses(featSvc, dbPath));
+ _executors.put("GetConnectionPropertyValues".toUpperCase(), new GetConnectionPropertyValues(featSvc, dbPath));
+ _executors.put("GetFeatureProviders".toUpperCase(), new GetFeatureProviders(featSvc, dbPath));
+ _executors.put("GetLongTransactions".toUpperCase(), new GetLongTransactions(featSvc, dbPath));
+ _executors.put("GetProviderCapabilities".toUpperCase(), new GetProviderCapabilities(featSvc, dbPath));
+ _executors.put("GetSchemas".toUpperCase(), new GetSchemas(featSvc, dbPath));
+ _executors.put("GetSpatialContexts".toUpperCase(), new GetSpatialContexts(featSvc, dbPath));
+ _executors.put("SelectAggregates".toUpperCase(), new SelectAggregates(featSvc, dbPath));
+ _executors.put("SelectFeatures".toUpperCase(), new SelectFeatures(featSvc, dbPath));
+ _executors.put("SetLongTransaction".toUpperCase(), new SetLongTransaction(featSvc, dbPath, sessionCreator, sessionApply));
+ _executors.put("TestConnection".toUpperCase(), new TestConnection(featSvc, dbPath));
+ //Map and Layers
+ _executors.put("AddLayerGroup".toUpperCase(), new AddLayerGroup(resSvc, dbPath, creator));
+ _executors.put("AddLayer".toUpperCase(), new AddLayer(resSvc, dbPath, creator));
+ _executors.put("GetCoordinateSystem".toUpperCase(), new GetCoordinateSystem(resSvc, dbPath, creator));
+ _executors.put("GetDataExtent".toUpperCase(), new GetDataExtent(resSvc, dbPath, creator));
+ _executors.put("GetDisplayInLegend".toUpperCase(), new GetDisplayInLegend(resSvc, dbPath, creator));
+ _executors.put("GetLayerFeatureClass".toUpperCase(), new GetLayerFeatureClass(resSvc, dbPath, creator));
+ _executors.put("GetLayerFeatureSource".toUpperCase(), new GetLayerFeatureSource(resSvc, dbPath, creator));
+ _executors.put("GetLayerDefinition".toUpperCase(), new GetLayerDefinition(resSvc, dbPath, creator));
+ _executors.put("GetGroups".toUpperCase(), new GetGroups(resSvc, dbPath, creator));
+ _executors.put("GetLayers".toUpperCase(), new GetLayers(resSvc, dbPath, creator));
+ _executors.put("GetLayerVisibility".toUpperCase(), new GetLayerVisibility(resSvc, dbPath, creator));
+ _executors.put("GetLegendLabel".toUpperCase(), new GetLegendLabel(resSvc, dbPath, creator));
+ _executors.put("GetMapExtent".toUpperCase(), new GetMapExtent(resSvc, dbPath, creator));
+ _executors.put("GetMapName".toUpperCase(), new GetMapName(resSvc, dbPath, creator));
+ _executors.put("GetViewCenter".toUpperCase(), new GetViewCenter(resSvc, dbPath, creator));
+ _executors.put("GetViewScale".toUpperCase(), new GetViewScale(resSvc, dbPath, creator));
+ _executors.put("HideGroup".toUpperCase(), new HideGroup(resSvc, dbPath, creator));
+ _executors.put("IsLayerVisible".toUpperCase(), new IsLayerVisible(resSvc, dbPath, creator));
+ _executors.put("LayerExists".toUpperCase(), new LayerExists(resSvc, dbPath, creator));
+ _executors.put("RemoveGroup".toUpperCase(), new RemoveGroup(resSvc, dbPath, creator));
+ _executors.put("ShowGroup".toUpperCase(), new ShowGroup(resSvc, dbPath, creator));
+ //Drawing Service
+ _executors.put("DescribeDrawing".toUpperCase(), new DescribeDrawing(drawSvc, dbPath));
+ _executors.put("GetDrawing".toUpperCase(), new GetDrawing(drawSvc, dbPath));
+ _executors.put("EnumerateDrawingLayers".toUpperCase(), new EnumerateDrawingLayers(drawSvc, dbPath));
+ _executors.put("GetDrawingLayer".toUpperCase(), new GetDrawingLayer(drawSvc, dbPath));
+ _executors.put("GetDrawingSection".toUpperCase(), new GetDrawingSection(drawSvc, dbPath));
+ _executors.put("EnumerateDrawingSections".toUpperCase(), new EnumerateDrawingSections(drawSvc, dbPath));
+ _executors.put("EnumerateDrawingSectionResources".toUpperCase(), new EnumerateDrawingSectionResources(drawSvc, dbPath));
+ _executors.put("GetDrawingSectionResource".toUpperCase(), new GetDrawingSectionResource(drawSvc, dbPath));
+ //Mapping Service
+ //Rendering Service
+ //Server Admin
+ _executors.put("Offline".toUpperCase(), new Offline(admin, dbPath));
+ _executors.put("Online".toUpperCase(), new Online(admin, dbPath));
+ _executors.put("GetLog".toUpperCase(), new GetLog(admin, dbPath));
+ _executors.put("GetLogByDate".toUpperCase(), new GetLogByDate(admin, dbPath));
+ _executors.put("ClearLog".toUpperCase(), new ClearLog(admin, dbPath));
+ _executors.put("DeleteLog".toUpperCase(), new DeleteLog(admin, dbPath));
+ _executors.put("RenameLog".toUpperCase(), new RenameLog(admin, dbPath));
+ _executors.put("EnumeratePackages".toUpperCase(), new EnumeratePackages(admin, dbPath));
+ _executors.put("DeletePackage".toUpperCase(), new DeletePackage(admin, dbPath));
+ _executors.put("LoadPackage".toUpperCase(), new LoadPackage(admin, dbPath));
+ _executors.put("GetPackageStatus".toUpperCase(), new GetPackageStatus(admin, dbPath));
+ _executors.put("GetPackageLog".toUpperCase(), new GetPackageLog(admin, dbPath));
+ //Site Service
+ _executors.put("CreateSession".toUpperCase(), new CreateSession(site, dbPath, session));
+ _executors.put("DestroySession".toUpperCase(), new DestroySession(site, dbPath));
+ _executors.put("GetUserForSession".toUpperCase(), new GetUserForSession(site, dbPath, session));
+ _executors.put("EnumerateUsers".toUpperCase(), new EnumerateUsers(site, dbPath));
+ _executors.put("AddUser".toUpperCase(), new AddUser(site, dbPath));
+ _executors.put("UpdateUser".toUpperCase(), new UpdateUser(site, dbPath));
+ _executors.put("DeleteUsers".toUpperCase(), new DeleteUsers(site, dbPath));
+ _executors.put("GrantRoleMembershipsToUsers".toUpperCase(), new GrantRoleMembershipsToUsers(site, dbPath));
+ _executors.put("RevokeRoleMembershipsFromUsers".toUpperCase(), new RevokeRoleMembershipsFromUsers(site, dbPath));
+ _executors.put("GrantGroupMembershipsToUsers".toUpperCase(), new GrantGroupMembershipsToUsers(site, dbPath));
+ _executors.put("RevokeGroupMembershipsFromUsers".toUpperCase(), new RevokeGroupMembershipsFromUsers(site, dbPath));
+ _executors.put("EnumerateGroups".toUpperCase(), new EnumerateGroups(site, dbPath));
+ _executors.put("EnumerateGroups2".toUpperCase(), new EnumerateGroups2(site, dbPath));
+ _executors.put("EnumerateRoles2".toUpperCase(), new EnumerateRoles2(site, dbPath));
+ _executors.put("AddGroup".toUpperCase(), new AddGroup(site, dbPath));
+ _executors.put("UpdateGroup".toUpperCase(), new UpdateGroup(site, dbPath));
+ _executors.put("DeleteGroups".toUpperCase(), new DeleteGroups(site, dbPath));
+ _executors.put("GrantRoleMembershipsToGroups".toUpperCase(), new GrantRoleMembershipsToGroups(site, dbPath));
+ _executors.put("RevokeRoleMembershipsFromGroups".toUpperCase(), new RevokeRoleMembershipsFromGroups(site, dbPath));
+ _executors.put("EnumerateRoles".toUpperCase(), new EnumerateRoles(site, dbPath));
+ _executors.put("EnumerateServers".toUpperCase(), new EnumerateServers(site, dbPath));
+ _executors.put("AddServer".toUpperCase(), new AddServer(site, dbPath));
+ _executors.put("UpdateServer".toUpperCase(), new UpdateServer(site, dbPath));
+ _executors.put("RemoveServer".toUpperCase(), new RemoveServer(site, dbPath));
+ //Web Layout
+ _executors.put("WL_GetTitle".toUpperCase(), new WL_GetTitle(wlCreator, dbPath));
+ _executors.put("WL_GetMapDefinition".toUpperCase(), new WL_GetMapDefinition(wlCreator, dbPath));
+ _executors.put("WL_GetScale".toUpperCase(), new WL_GetScale(wlCreator, dbPath));
+ _executors.put("WL_GetCenter".toUpperCase(), new WL_GetCenter(wlCreator, dbPath));
+ _executors.put("WL_ShowToolbar".toUpperCase(), new WL_ShowToolbar(wlCreator, dbPath));
+ _executors.put("WL_ShowStatusbar".toUpperCase(), new WL_ShowStatusbar(wlCreator, dbPath));
+ _executors.put("WL_ShowTaskpane".toUpperCase(), new WL_ShowTaskpane(wlCreator, dbPath));
+ _executors.put("WL_ShowTaskbar".toUpperCase(), new WL_ShowTaskbar(wlCreator, dbPath));
+ _executors.put("WL_ShowLegend".toUpperCase(), new WL_ShowLegend(wlCreator, dbPath));
+ _executors.put("WL_ShowProperties".toUpperCase(), new WL_ShowProperties(wlCreator, dbPath));
+ _executors.put("WL_GetTaskPaneWidth".toUpperCase(), new WL_GetTaskPaneWidth(wlCreator, dbPath));
+ _executors.put("WL_GetInformationPaneWidth".toUpperCase(), new WL_GetInformationPaneWidth(wlCreator, dbPath));
+ _executors.put("WL_GetInitialTaskUrl".toUpperCase(), new WL_GetInitialTaskUrl(wlCreator, dbPath));
+ _executors.put("WL_ShowContextMenu".toUpperCase(), new WL_ShowContextMenu(wlCreator, dbPath));
+ _executors.put("WL_TestUiItem".toUpperCase(), new WL_TestUiItem(wlCreator, dbPath));
+ _executors.put("WL_HomeTooltip".toUpperCase(), new WL_HomeTooltip(wlCreator, dbPath));
+ _executors.put("WL_HomeDescription".toUpperCase(), new WL_HomeDescription(wlCreator, dbPath));
+ _executors.put("WL_BackTooltip".toUpperCase(), new WL_BackTooltip(wlCreator, dbPath));
+ _executors.put("WL_BackDescription".toUpperCase(), new WL_BackDescription(wlCreator, dbPath));
+ _executors.put("WL_ForwardTooltip".toUpperCase(), new WL_ForwardTooltip(wlCreator, dbPath));
+ _executors.put("WL_ForwardDescription".toUpperCase(), new WL_ForwardDescription(wlCreator, dbPath));
+ _executors.put("WL_TasksName".toUpperCase(), new WL_TasksName(wlCreator, dbPath));
+ _executors.put("WL_TasksTooltip".toUpperCase(), new WL_TasksTooltip(wlCreator, dbPath));
+ _executors.put("WL_TasksDescription".toUpperCase(), new WL_TasksDescription(wlCreator, dbPath));
+ class MgWebLayoutCreator : IWebLayoutCreator
+ private MgResourceService _resSvc;
+ private MgWebLayout _wl;
+ public MgWebLayoutCreator(MgResourceService resSvc)
+ _resSvc = resSvc;
+ public MgWebLayout CreateWebLayout(MgResourceIdentifier resId)
+ if (_wl != null)
+ return _wl;
+ _wl = new MgWebLayout(_resSvc, resId);
+ return _wl;
+ class MgMapCreator : IMapCreator
+ private MgSiteConnection _siteConn;
+ private MgMap _map;
+ public MgMapCreator(MgSiteConnection siteConn, MgResourceService resSvc)
+ _siteConn = siteConn;
+ _resSvc = resSvc;
+ public MgMapBase CreateMap(MgResourceIdentifier resId)
+ //The test suite relies on the same map and not a new one
+ //re-created on each test of that particular test suite
+ if (_map != null)
+ return _map;
+ _map = new MgMap(_siteConn);
+ _map.Create(resId, resId.GetName());
+ return _map;
+ public MgLayerBase CreateLayer(MgResourceIdentifier resId)
+ return new MgLayer(resId, _resSvc);
+ class MgSessionCreator : ISessionCreator
+ public MgSessionCreator(MgSiteConnection siteConn)
+ public String CreateSession()
+ var site = _siteConn.GetSite();
+ return site.CreateSession();
+ class MgApplySession : IApplySession
+ public MgApplySession(MgUserInformation userInfo)
+ public void SetSessionId(String sessionId)
+ _userInfo.SetMgSessionId(sessionId);
+ class MgSession : IMapGuideSession
+ public String SessionID
+ get;
+ set;
+ public ITestExecutor GetTestExecutor(String opName)
+ if (_executors.containsKey(opName))
+ return _executors.get(opName);
+ throw new RuntimeException("Executor for " + opName + " not found");
+ public int ValidateRequest(SqliteDb db, String testName, int paramSetId, String operation, TestResult actualResult, ITestLogger logger)
+ int exitStatus = 0;
+ String outcome = "pass";
+ SqliteVm vm = new SqliteVm(db, false);
+ Object expectedResult = null;
+ //If we have an exception we need to remove the stack trace because different line numbers will fail the test
+ Object resultData = CommonUtility.RemoveStackTraceFromResult(actualResult.ResultData);
+ //Get the mime type based on the content type in the result
+ String mimeType = actualResult.ContentType;
+ //If we have exception message we need to remove any parts that may contain system dependent information
+ //Ex. file paths
+ resultData = CommonUtility.ProcessExceptionMessage(resultData);
+ //Get the file extension that will be used for a dump
+ String actualExtension = CommonUtility.GetExtensionFromMimeType(mimeType);
+ //If we have an ALWAYSPASS parameter defined for the operation then skip the whole validation process
+ //This parameter should only be used for clean up operations that are no related with the tests
+ if (vm.Execute("Select ParamValue from Params where ParamName=\"ALWAYSPASS\" and ParamSet={0}", paramSetId) != Sqlite.Row)
+ //TestName is Test_[ServiceType]
+ String type = testName.SubString(testName.IndexOf("_") + 1);
+ String filePath = CommonUtility.GetPath(String.Format("../../TestData/{0}/DumpFiles/{0}ApiTest", type));
+ String fileName = String.Format("{0}_{1}.{2}", filePath, paramSetId, actualExtension);
+ if (this.TestExecutionMode == "dump")
+ //File.WriteAllText(fileName, resultData);
+ throw new NotImplementedException("The .net test runner does not support dumping of test results. Please use the PHP test runner for this purpose");
+ else
+ //This section is special case handling for the operations that return different data after each call
+ resultData = CommonUtility.SpecialDataHandling(operation, resultData, mimeType);
+ if (this.TestExecutionMode == "validate" || this.TestExecutionMode == "show")
+ String resultContent = "";
+ //Get the sample result and the expected content type from the database
+ int status = vm.Execute("Select Result, ContentType from ApiTestResults where ParamSet={0}", paramSetId);
+ String expectedContentType = vm.GetString("ContentType");
+ String expectedExtension = CommonUtility.GetExtensionFromMimeType(expectedContentType);
+ SqliteGcBlob blob = vm.GetBlob("Result");
+ byte[] b = blob.Read();
+ if (b != null)
+ if (expectedExtension == "xml" || expectedExtension == "txt" || expectedExtension == "html")
+ expectedResult = Encoding.UTF8.GetString(b);
+ else
+ expectedResult = b;
+ else
+ expectedResult = String.Empty;
+ else
+ expectedResult = null;
+ String strExpectedResult = expectedResult as String;
+ //If we are validating from a file then get the contents of that file
+ //File names should be prefixed with "@@" to distinguish them from BLOB data
+ if (strExpectedResult != null && strExpectedResult.StartsWith("@@"))
+ String sampleDataFile = strExpectedResult.SubString(2);
+ sampleDataFile = CommonUtility.GetPath(sampleDataFile);
+ expectedResult = File.ReadAllText(sampleDataFile);
+ if (this.TestExecutionMode == "validate")
+ bool bEqual = false;
+ byte[] bExpected = expectedResult as byte[];
+ byte[] bActual = resultData as byte[];
+ String strResultData = resultData as String;
+ //FIXME: We're not processing DWF content properly to do this check properly. So just
+ //pass these for now
+ if (operation == "GETDRAWINGLAYER" || operation == "GETDRAWINGSECTION")
+ bEqual = true;
+ else
+ if (strExpectedResult != null && strResultData != null)
+ //Normalize line endings on LF before comparsion (in case the SQLite GUI recorded CRLFs)
+ String normStrResultData = strResultData.Replace("\r\n", "\n");
+ String normStrExpectedResult = strExpectedResult.Replace("\r\n", "\n");
+ bEqual = normStrResultData.Equals(normStrExpectedResult, StringComparison.InvariantCultureIgnoreCase);
+ else if (bExpected != null && bActual != null)
+ bEqual = CommonUtility.ByteArraysEqual(bExpected, bActual, operation, testName);
+ else
+ System.Diagnostics.Debug.WriteLine(String.Format("[MgTestRunner]: {0} - {1} - Encountered disparate data types between expected and actual results. Expecting test failure :(", testName, operation));
+ //If the results are different and special validation fails then the operation failed ->mark it red
+ if (!bEqual && !CommonUtility.SpecialValidation(operation, resultData, expectedResult))
+ outcome = "fail";
+ exitStatus = 1;
+ if (expectedExtension != "xml" && expectedExtension != "html" && expectedExtension != "txt")
+ expectedResult = "Unable to display binary data";
+ if (actualExtension != "xml" && actualExtension != "html" && actualExtension != "txt")
+ resultData = "Unable to display binary data";
+ else
+ throw new NotImplementedException("The .net test runner does not support the given test execution mode (" + this.TestExecutionMode + "). Please use the PHP test runner for this purpose");
+ if (outcome == "fail")
+ Console.WriteLine("****{0} {1} {2} failed.\n", testName, paramSetId, operation);
+ String str = String.Format("\n****ACTUAL RESULT****\n{0}\n****EXPECTED RESULT****\n{1}\n********\n\n\n", resultData, expectedResult);
+ //Console.WriteLine(str);
+ //Console.WriteLine("<FAIL>");
+ logger.Write(str);
+ vm.SqlFinalize();
+ vm = null;
+ return exitStatus;
+ public void Cleanup()
+ for (ITestExecutor exec : _executors.values())
+ try {
+ exec.close();
+ } catch (IOException ex) {
+ _executors.clear();
+ public String getApiType()
+ return ApiTypes.Platform;
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTests.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTests.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTests.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,40 @@
+public class MapGuideTests
+ int failures = 0;
+ try
+ logger.WriteLine("****** Executing MapGuide test: " + clsName + " *********");
+ Console.WriteLine("Executing external MapGuide test: " + clsName);
+ failures++;
+ failures++;
+ finally
+ return failures;
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/PlatformFactory.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/PlatformFactory.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/PlatformFactory.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,30 @@
+public class PlatformFactory implements IPlatformFactory
+ public PlatformFactory(MgSiteConnection siteConn)
+ public MgService createService(int serviceType)
+ return _siteConn.createService(serviceType);
+ public MgMapBase createMap()
+ return new MgMap(_siteConn);
+ public MgLayerBase createLayer(MgResourceIdentifier resId)
+ MgResourceService resSvc = (MgResourceService)_siteConn.createService(MgServiceType.ResourceService);
+ return new MgLayer(resId, resSvc);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Program.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Program.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Program.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,77 @@
+import java.io.*;
+public class Program
+ static MgUserInformation userInfo;
+ static MgSiteConnection siteConn;
+ public static void main(String[] args) {
+ try {
+ if (args.length >= 1 && args.length <= 2) {
+ String webConfigPath = args[0];
+ String logFile = "UnitTests.log";
+ if (args.length == 2)
+ logFile = args[1];
+ int failures = 0;
+ try (ITestLogger logger = new TestLoggerFile(logFile)) {
+ logger.WriteLine(String.format("Run started: %s", new Date().toString()));
+ MapGuideJavaApiEx.MgInitializeWebTier(webConfigPath);
+ Console.WriteLine("MapGuide Initialized. Running tests");
+ userInfo = new MgUserInformation("Administrator", "admin");
+ siteConn = new MgSiteConnection();
+ siteConn.open(userInfo);
+ IPlatformFactory factory = new PlatformFactory(siteConn);
+ MutableInteger testsRun = new MutableInteger(0);
+ boolean isEnterprise = false;
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/ResourceService/ResourceServiceTest.dump", testsRun, logger, isEnterprise);
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/DrawingService/DrawingServiceTest.dump", testsRun, logger, isEnterprise);
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/FeatureService/FeatureServiceTest.dump", testsRun, logger, isEnterprise);
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/SiteService/SiteServiceTest.dump", testsRun, logger, isEnterprise);
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/MappingService/MappingServiceTest.dump", testsRun, logger, isEnterprise);
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/ServerAdmin/ServerAdminTest.dump", testsRun, logger, isEnterprise);
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/MapLayer/MapLayerTest.dump", testsRun, logger, isEnterprise);
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/WebLayout/WebLayoutTest.dump", testsRun, logger, isEnterprise);
+ failures += ExecuteTest(ApiTypes.Platform, "../../TestData/Unicode/UnicodeTest.dump", testsRun, logger, isEnterprise);
+ //Run auxillary tests not part of the SQLite-defined suite
+ failures += CommonTests.Execute(factory, logger, testsRun);
+ failures += MapGuideTests.Execute(factory, logger, testsRun);
+ logger.WriteLine("\n\nTests failed/run: %d/%d", failures, testsRun.getValue());
+ Console.Write("\n\nTests failed/run: %d/%d\n", failures, testsRun.getValue());
+ logger.WriteLine(String.format("Run ended: %s", new Date().toString()));
+ System.exit(failures);
+ } else {
+ System.out.println("Usage: java -jar MgUnitTest.jar <webconfig.ini path> [test log path]");
+ System.exit(1);
+ } catch (Exception ex) {
+ System.err.println(CommonUtility.ExceptionToString(ex));
+ System.exit(1);
+ private static int ExecuteTest(String apiType, String dumpFile, MutableInteger testsRun, ITestLogger logger, boolean isEnterprise) {
+ ITestExecutorCollection exec = null;
+ if (apiType.equals(ApiTypes.Platform))
+ exec = new MapGuideTestExecutorCollection(userInfo, siteConn);
+ int ret = 0;
+ if (exec != null)
+ //"validate" is currently the only test execution mode supported
+ exec.Initialize("validate", dumpFile);
+ ret += exec.Execute(testsRun, logger, isEnterprise);
+ exec.Cleanup();
+ return ret;
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/Assert.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/Assert.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/Assert.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,91 @@
+package org.osgeo.mapguide.test.common;
+public class Assert
+ public static void AreBytesEqual(byte[] expected, byte[] actual)
+ byte[] a = expected;
+ byte[] b = actual;
+ if (a.length != b.length)
+ throw new AssertException("Expected byte array size of " + a.length + ", got size of: " + b.length);
+ for (int i = 0; i < a.length; i++)
+ if (a[i] != b[i])
+ throw new AssertException("Byte number " + (i + 1) + " in expected byte array does not match byte in actual byte array");
+ public static void AreEqual(long expected, long actual) {
+ if (expected != actual)
+ throw new AssertException("Expected: " + expected + ", got: " + actual);
+ public static void AreEqual(float expected, float actual) {
+ public static void AreEqual(double expected, double actual) {
+ public static void AreEqual(Object expected, Object actual)
+ if (expected instanceof byte[] && actual instanceof byte[])
+ AreBytesEqual((byte[])expected, (byte[])actual);
+ else if (!expected.equals(actual))
+ public static void Fail(String message) {
+ throw new AssertException(message);
+ public static void Greater(Comparable value, Comparable against)
+ if (value.compareTo(against) <= 0)
+ throw new AssertException(value + " is not greater than " + against);
+ public static void IsNull(Object obj)
+ if (obj != null)
+ throw new AssertException("Reference is not null");
+ public static void IsTrue(boolean condition)
+ if (!condition)
+ throw new AssertException("Condition evaluated to false. Expected: true");
+ public static void IsTrue(boolean condition, String message)
+ if (!condition)
+ public static void IsFalse(boolean condition)
+ if (condition)
+ throw new AssertException("Condition evaluated to true. Expected: false");
+ public static void IsNaN(double value)
+ if (!Double.isNaN(value))
+ throw new AssertException("Double is a number. Expected: NaN");
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/AssertException.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/AssertException.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/AssertException.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,8 @@
+public class AssertException extends RuntimeException
+ public AssertException(String message) {
+ super(message);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/CommonUtility.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/CommonUtility.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/CommonUtility.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,57 @@
+import java.io.*;
+import java.nio.file.*;
+public class CommonUtility
+ public static String GetTypeName(Object o) {
+ Class cls = o.getClass();
+ String name = cls.getName();
+ if (name.lastIndexOf('.') > 0) {
+ name = name.substring(name.lastIndexOf('.') + 1); // Map$Entry
+ name = name.replace('$', '.'); // Map.Entry
+ return name;
+ public static void DeleteFile(String path) {
+ try {
+ Files.deleteIfExists(Paths.get(path));
+ public static byte[] ReadAllBytes(String path) {
+ try {
+ return Files.readAllBytes(Paths.get(path));
+ return null;
+ public static String GetTempFileName() {
+ try {
+ Path p = Files.createTempFile(null, null);
+ return p.toString();
+ return null;
+ public static boolean IsNullOrEmpty(String str) {
+ return str == null || str.length() == 0;
+ public static String ExceptionToString(Exception ex) {
+ StringBuilder sb = new StringBuilder();
+ sb.append(ex.toString() + "\n");
+ sb.append(ex.getMessage() + "\n");
+ StackTraceElement[] items = ex.getStackTrace();
+ for (StackTraceElement item : items) {
+ sb.append("\t" + item.toString() + "\n");
+ return sb.toString();
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/IExternalTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/IExternalTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/IExternalTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,6 @@
+public interface IExternalTest
+ void Execute(IPlatformFactory factory, ITestLogger logger);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/IPlatformFactory.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/IPlatformFactory.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/IPlatformFactory.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,10 @@
+public interface IPlatformFactory
+ MgService createService(int serviceType);
+ MgMapBase createMap();
+ MgLayerBase createLayer(MgResourceIdentifier resId);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestExecutor.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestExecutor.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestExecutor.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,10 @@
+public interface ITestExecutor extends java.io.Closeable
+ String getApi();
+ String getOperationName();
+ TestResult Execute(int paramSetId);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestExecutorCollection.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestExecutorCollection.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestExecutorCollection.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,54 @@
+public interface ITestExecutorCollection
+ /// <summary>
+ /// Initializes this collection of test executors
+ /// </summary>
+ /// <param name="testExecutionMode"></param>
+ /// <param name="dumpFile"></param>
+ void Initialize(String testExecutionMode, String dumpFile);
+ /// <summary>
+ /// Gets the dump file path
+ /// </summary>
+ String getDumpFile();
+ /// <summary>
+ /// Gets the test execution mode
+ /// </summary>
+ String getTestExecutionMode();
+ /// <summary>
+ /// Gets the test executor of the specified operation name
+ /// </summary>
+ /// <param name="opName"></param>
+ /// <returns></returns>
+ ITestExecutor GetTestExecutor(String opName);
+ /// <summary>
+ /// Executes the test suite as defined in the dump file
+ /// </summary>
+ /// <param name="testsRun"></param>
+ /// <param name="logger"></param>
+ /// <param name="isEnterprise"></param>
+ int Execute(MutableInteger testsRun, ITestLogger logger, boolean isEnterprise);
+ /// <summary>
+ /// Validates a test execution result
+ /// </summary>
+ /// <param name="db"></param>
+ /// <param name="testName"></param>
+ /// <param name="paramSetId"></param>
+ /// <param name="operation"></param>
+ /// <param name="actualResult"></param>
+ int ValidateRequest(SqliteDb db, String testName, int paramSetId, String operation, TestResult actualResult, ITestLogger logger);
+ /// <summary>
+ /// Performs necessary cleanup
+ /// </summary>
+ void Cleanup();
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestLogger.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestLogger.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/ITestLogger.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,9 @@
+import java.io.*;
+public interface ITestLogger extends Closeable
+ void Write(String format, Object ... args);
+ void WriteLine(String format, Object ... args);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/MutableInteger.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/MutableInteger.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/MutableInteger.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,22 @@
+public class MutableInteger
+ private int _value;
+ public MutableInteger(int value) {
+ _value = value;
+ public int increment() {
+ _value++;
+ return _value;
+ public int decrement() {
+ _value--;
+ return _value;
+ public int getValue() { return _value; }
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/SqliteDb.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/SqliteDb.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/SqliteDb.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,6 @@
+public class SqliteDb
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestExecutorCollectionBase.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestExecutorCollectionBase.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestExecutorCollectionBase.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,74 @@
+public abstract class TestExecutorCollectionBase implements ITestExecutorCollection
+ public String TestExecutionMode;
+ public String DumpFile;
+ public String getTestExecutionMode() { return this.TestExecutionMode; }
+ public String getDumpFile() { return this.DumpFile; }
+ public abstract String getApiType();
+ public void Initialize(String testExecutionMode, String dumpFile)
+ this.TestExecutionMode = testExecutionMode;
+ this.DumpFile = dumpFile;
+ protected abstract void SetupExecutors(String dbPath);
+ public int Execute(MutableInteger testsRun, ITestLogger logger, boolean isEnterprise)
+ String dbPath = CommonUtility.GetDbPath(this.DumpFile);
+ String dbName = CommonUtility.GetPath(dbPath);
+ if (File.Exists(dbName))
+ var db = new SqliteDb();
+ db.Open(dbName);
+ var vm = new SqliteVm(db, true);
+ int status = vm.Execute("Select TestName, TestType from TestCase where TestType=\"{0}\" order by ExecuteSequence", this.ApiType);
+ //NOTE: We can't share the SqliteVm instance among our executor objects as this messes up query results
+ SetupExecutors(dbName);
+ while (status == Sqlite.Row)
+ String testName = vm.GetString("TestName");
+ String testType = vm.GetString("TestType");
+ Console.WriteLine("Executing {0} test: {1}", testType, testName);
+ using (var run = new TestExecutionRun(dbPath, this))
+ try
+ exitStatus += run.RunTests(testName, logger, ref testsRun);
+ Console.WriteLine(CommonUtility.ExceptionToString(ex));
+ exitStatus += 1;
+ status = vm.NextRow();
+ vm.SqlFinalize();
+ vm = null;
+ db = null;
+ public abstract ITestExecutor GetTestExecutor(String opName);
+ public abstract int ValidateRequest(SqliteDb db, String testName, int paramSetId, String operation, TestResult actualResult, ITestLogger logger);
+ public abstract void Cleanup();
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestLoggerFile.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestLoggerFile.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestLoggerFile.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,48 @@
+import java.io.*;
+public class TestLoggerFile implements ITestLogger
+ private Writer sw;
+ public TestLoggerFile(String file)
+ try {
+ sw = new PrintWriter(file, "UTF-8");
+ public void Write(String format, Object ... args)
+ try {
+ sw.write(String.format(format, args));
+ public void WriteLine(String format, Object ... args)
+ try {
+ sw.write(String.format(format, args) + "\n");
+ public void close()
+ if (sw != null)
+ try {
+ sw.close();
+ sw = null;
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestResult.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestResult.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestResult.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,102 @@
+import java.util.UUID;
+import org.osgeo.mapguide.test.*;
+public class TestResult
+ public Object ResultData;
+ public String ContentType;
+ public String HttpStatusCode;
+ public TestResult()
+ this.ResultData = "";
+ this.ContentType = "";
+ this.HttpStatusCode = "";
+ public TestResult(String resultData)
+ this.ResultData = resultData;
+ public TestResult(String resultData, String contentType)
+ this.ContentType = contentType;
+ public TestResult(String resultData, String contentType, String statusCode)
+ this.HttpStatusCode = statusCode;
+ public static TestResult FromByteReader(MgByteReader byteReader)
+ return FromByteReader(byteReader, "");
+ public static TestResult FromByteReader(MgByteReader byteReader, String operation)
+ try
+ TestResult res = new TestResult();
+ if (byteReader != null)
+ res.ContentType = byteReader.getMimeType();
+ if (res.ContentType.equals(MgMimeType.Html) ||
+ res.ContentType.equals(MgMimeType.Json) ||
+ res.ContentType.equals(MgMimeType.Kml) ||
+ res.ContentType.equals(MgMimeType.Text) ||
+ res.ContentType.equals(MgMimeType.Xml))
+ res.ResultData = byteReader.toString();
+ else
+ MgByteSink sink = new MgByteSink(byteReader);
+ String path = operation + UUID.randomUUID().toString() + "Result.bin";
+ if (CommonUtility.IsNullOrEmpty(operation))
+ path = CommonUtility.GetTempFileName();
+ sink.toFile(path);
+ res.ResultData = CommonUtility.ReadAllBytes(path);
+ CommonUtility.DeleteFile(path);
+ else
+ System.out.println(String.format("[MgUnitTest]: Check out %s if binary comparison results are strange", path));
+ byte[] bytes = new byte[byteReader.GetLength()];
+ byteReader.Read(bytes, bytes.Length);
+ res.ResultData = bytes;
+ return res;
+ catch (MgException ex)
+ return FromMgException(ex);
+ public static TestResult FromMgException(MgException ex)
+ //Need to be lowercase to satisfy a PHP-ism. Ugh!
+ return new TestResult(CommonUtility.GetTypeName(ex).toLowerCase(), "text/plain");
+ public static TestResult FromException(Exception ex)
+ return new TestResult(ex.getMessage(), "text/plain");
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/operations/IWebLayoutCreator.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/operations/IWebLayoutCreator.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/operations/IWebLayoutCreator.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,8 @@
+package org.osgeo.mapguide.test.operations;
+public interface IWebLayoutCreator
+ MgWebLayout CreateWebLayout(MgResourceIdentifier resId);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/BatchPropertyCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/BatchPropertyCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/BatchPropertyCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,42 @@
+package org.osgeo.mapguide.test.platform;
+import java.io.*;
+public class BatchPropertyCollectionTest implements IExternalTest
+ public void Execute(IPlatformFactory factory, ITestLogger logger)
+ MgPropertyCollection coll1 = new MgPropertyCollection();
+ MgDoubleProperty dblProp = new MgDoubleProperty("DoubleProp", 1.1111);
+ coll1.addItem(dblProp);
+ MgPropertyCollection coll2 = new MgPropertyCollection();
+ MgInt32Property intProp = new MgInt32Property("IntProp", 1);
+ coll2.addItem(intProp);
+ MgPropertyCollection coll3 = new MgPropertyCollection();
+ MgSingleProperty single = new MgSingleProperty("SingleProp", (float)2.2222);
+ coll3.addItem(single);
+ MgBatchPropertyCollection coll = new MgBatchPropertyCollection();
+ coll.addItem(coll1);
+ coll.addItem(coll2);
+ Assert.AreEqual(2, coll.getCount());
+ Assert.AreEqual(MgPropertyType.Double, coll.getItem(0).getItem(0).getPropertyType());
+ Assert.AreEqual(MgPropertyType.Int32, coll.getItem(1).getItem(0).getPropertyType());
+ coll.setItem(1, coll3);
+ String str = "";
+ //for (MgPropertyCollection c : coll)
+ for (int i = 0; i < coll.getCount(); i++)
+ MgPropertyCollection c = coll.getItem(i);
+ str = str + ".getItem(" + c.getItem(0).getName() + ")";
+ Assert.AreEqual(".getItem(DoubleProp).getItem(SingleProp)", str);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderMemoryConstructorTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderMemoryConstructorTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderMemoryConstructorTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,36 @@
+import java.io.*;
+public class ByteReaderMemoryConstructorTest implements IExternalTest
+ ByteReaderTestData.Init();
+ int nBytes = ByteReaderTestData.nBytes;
+ byte[] testBytes = ByteReaderTestData.testBytes;
+ String outfileName = ByteReaderTestData.outfileName;
+ byte[] buf = new byte[nBytes];
+ MgByteReader reader = new MgByteReader(testBytes, nBytes, "png");
+ Assert.AreEqual(nBytes, reader.getLength());
+ reader.read(buf, nBytes);
+ Assert.AreEqual(buf, testBytes);
+ Assert.AreEqual(0, reader.getLength());
+ reader.rewind();
+ reader.toFile(outfileName);
+ try {
+ FileInputStream fp = new FileInputStream(outfileName);
+ fp.read(buf, 0, nBytes);
+ fp.close();
+ Assert.Fail(CommonUtility.ExceptionToString(ex));
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderStringConstructorTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderStringConstructorTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderStringConstructorTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,21 @@
+import java.io.*;
+public class ByteReaderStringConstructorTest implements IExternalTest
+ String testString = ByteReaderTestData.testString;
+ MgByteReader reader = new MgByteReader(testString, "text/html");
+ Assert.AreEqual(testString.length(), reader.getLength());
+ String buf = reader.toString();
+ Assert.AreEqual(testString, buf);
+ reader.rewind();
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,42 @@
+import java.io.*;
+public class ByteReaderTest implements IExternalTest
+ int nBlocks = ByteReaderTestData.nBlocks;
+ String infileName = ByteReaderTestData.infileName;
+ MgByteReader reader = new MgByteReader(infileName, "png", false);
+ Assert.AreEqual(nBlocks * nBytes, reader.getLength());
+ Assert.AreEqual((nBlocks - 1) * nBytes, reader.getLength());
+ reader.rewind();
+ reader.rewind();
+ try {
+ byte[] buf2 = new byte[nBytes];
+ for (int j = 0; j < nBlocks; j++)
+ fp.read(buf2, 0, nBytes);
+ Assert.AreEqual(buf, buf2);
+ fp.close();
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderTestData.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderTestData.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ByteReaderTestData.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,42 @@
+import java.io.*;
+public class ByteReaderTestData
+ public static byte[] testBytes;
+ public static int nBytes = 32768;
+ public static int nBlocks = 256;
+ public static String testString = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789";
+ public static String infileName;
+ public static String outfileName;
+ private static boolean bFirstTime = true;
+ public static void Init()
+ if (bFirstTime)
+ infileName = CommonUtility.GetTempFileName();
+ outfileName = CommonUtility.GetTempFileName();
+ testBytes = new byte[nBytes];
+ for (int i = 0; i < nBytes; i++)
+ testBytes[i] = (byte)(i % 255);
+ try {
+ FileOutputStream fp = new FileOutputStream(infileName);
+ fp.write(testBytes, 0, nBytes);
+ fp.close();
+ bFirstTime = false;
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ClassDefinitionCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ClassDefinitionCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/ClassDefinitionCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,180 @@
+import java.io.*;
+public class ClassDefinitionCollectionTest implements IExternalTest
+ MgClassDefinition class1 = new MgClassDefinition();
+ class1.setName("class1");
+ MgClassDefinition class2 = new MgClassDefinition();
+ class2.setName("class2");
+ MgClassDefinition class3 = new MgClassDefinition();
+ class3.setName("class3");
+ MgClassDefinitionCollection coll = new MgClassDefinitionCollection();
+ coll.insert(0, class3);
+ coll.insert(0, class2);
+ coll.insert(0, class1);
+ Assert.AreEqual(3, coll.getCount());
+ Assert.AreEqual("class2", coll.getItem(1).getName());
+ MgClassDefinition tmp = coll.getItem(0);
+ coll.setItem(0, coll.getItem(1));
+ coll.setItem(1, coll.getItem(2));
+ coll.setItem(2, tmp);
+ String str = "";
+ for (MgClassDefinition def : coll)
+ str = str + ".getItem(" + def.getName() + ")";
+ Assert.AreEqual(".getItem(class2).getItem(class3).getItem(class1)", str);
+ MgFeatureSchema parent = new MgFeatureSchema("Parent", "");
+ MgClassDefinitionCollection items = parent.getClasses();
+ MgClassDefinition item1 = new MgClassDefinition(); item1.setName("Item1");
+ MgClassDefinition item2 = new MgClassDefinition(); item2.setName("Item2");
+ MgClassDefinition item3 = new MgClassDefinition(); item3.setName("Item3");
+ MgClassDefinition item4 = new MgClassDefinition(); item4.setName("Item4");
+ //Items inserted the MapGuide API way
+ items.addItem(item1);
+ items.addItem(item2);
+ items.addItem(item3);
+ Assert.IsTrue(items.getCount() == 3, "Expected 3 items");
+ Assert.IsTrue(!items.isEmpty(), "Expected non-empty item collection");
+ int i = 0;
+ //Looping the classic way
+ for (i = 0; i < items.getCount(); i++) {
+ switch (i){
+ case 0:
+ Assert.IsTrue(items.getItem(i).getName().equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
+ break;
+ case 1:
+ Assert.IsTrue(items.getItem(i).getName().equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
+ break;
+ case 2:
+ Assert.IsTrue(items.getItem(i).getName().equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
+ break;
+ //Looping the iterative way
+ i = 0;
+ for (MgClassDefinition item : items) {
+ String itemName = item.getName();
+ switch (i){
+ case 0:
+ Assert.IsTrue(itemName.equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
+ break;
+ case 1:
+ Assert.IsTrue(itemName.equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
+ break;
+ case 2:
+ Assert.IsTrue(itemName.equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
+ break;
+ i++;
+ items.clear();
+ Assert.IsTrue(items.getCount() == 0, "Expected empty item collection");
+ Assert.IsTrue(items.isEmpty(), "Expected empty item collection");
+ //Now test through java.util.Collection facade
+ Collection<MgClassDefinition> facade = items;
+ //add()
+ Assert.IsTrue(facade.add(item1), "Could not add item1 the java.util.Collection way");
+ Assert.IsTrue(facade.add(item2), "Could not add item2 the java.util.Collection way");
+ Assert.IsTrue(facade.add(item3), "Could not add item3 the java.util.Collection way");
+ Assert.IsTrue(facade.size() == 3, "Expected 3 items");
+ Assert.IsTrue(!facade.isEmpty(), "Expected non-empty item collection");
+ //contains()
+ Assert.IsTrue(facade.contains(item1), "item1 should exist");
+ Assert.IsTrue(facade.contains(item2), "item2 should exist");
+ Assert.IsTrue(facade.contains(item3), "item3 should exist");
+ ArrayList<MgClassDefinition> testCollection = new ArrayList<MgClassDefinition>();
+ testCollection.add(item1);
+ testCollection.add(item2);
+ testCollection.add(item3);
+ //containsAll()
+ Assert.IsTrue(facade.containsAll(testCollection), "All items in test collection should match");
+ testCollection.clear();
+ testCollection.add(item4);
+ Assert.IsTrue(!facade.containsAll(testCollection), "Should not have matched test collection");
+ facade.clear();
+ Assert.IsTrue(facade.size() == 0, "Expected 0 items");
+ Assert.IsTrue(facade.isEmpty(), "Expected empty item collection");
+ //addAll()
+ Assert.IsTrue(facade.addAll(testCollection), "Expected addAll() success");
+ //remove()
+ Assert.IsTrue(!facade.remove(item4), "Expected remove() of non-existent item to return false");
+ Assert.IsTrue(!facade.remove(new MgFeatureSchema()), "Expected remove() of different type to return false");
+ Assert.IsTrue(facade.remove(item2), "Expected remove() of item2 to return true");
+ //removeAll()
+ testCollection.remove(item2);
+ Assert.IsTrue(facade.removeAll(testCollection), "Expected removeAll() to succeed");
+ //retainAll()
+ Assert.IsTrue(facade.size() == 3, "Expected 3 schemas");
+ Assert.IsTrue(!facade.isEmpty(), "Expected non-empty schema collection");
+ Assert.IsTrue(facade.retainAll(testCollection), "Expected retainAll() to succeed");
+ Assert.IsTrue(facade.contains(item1), "Expected item1 to exist");
+ Assert.IsTrue(!facade.contains(item2), "Expected item2 to not exist");
+ Assert.IsTrue(facade.contains(item3), "Expected item3 to exist");
+ //toArray()
+ Object[] itemArray = facade.toArray();
+ Assert.IsTrue(itemArray != null, "Expected non-null item array");
+ Assert.IsTrue(itemArray.length == 2, "Expected 2 item array");
+ for (Object o : itemArray) {
+ Assert.IsTrue(o instanceof MgClassDefinition, "Expected item to be MgClassDefinition");
+ MgClassDefinition[] fitems = facade.toArray(new MgClassDefinition[0]);
+ Assert.IsTrue(fitems != null, "Expected non-null item array");
+ Assert.IsTrue(fitems.length == 2, "Expected 2 item array");
+ fitems = facade.toArray(new MgClassDefinition[1]);
+ fitems = facade.toArray(new MgClassDefinition[3]);
+ Assert.IsTrue(fitems.length == 3, "Expected 3 item array");
+ Assert.IsTrue(fitems[0] != null, "Expected non-null item #1");
+ Assert.IsTrue(fitems[1] != null, "Expected non-null item #2");
+ Assert.IsTrue(fitems[2] == null, "Expected null item #3");
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CoordinateCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CoordinateCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CoordinateCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class CoordinateCollectionTest implements IExternalTest
+ MgGeometryFactory gf = new MgGeometryFactory();
+ MgCoordinate c1 = gf.createCoordinateXY(1.0, 1.0);
+ MgCoordinate c2 = gf.createCoordinateXY(2.0, 2.0);
+ MgCoordinate c3 = gf.createCoordinateXY(3.0, 3.0);
+ MgCoordinate c4 = gf.createCoordinateXY(4.0, 4.0);
+ MgCoordinateCollection coll = new MgCoordinateCollection();
+ coll.add(c1);
+ coll.insert(1, c2);
+ coll.add(c3);
+ coll.add(c4);
+ Assert.AreEqual(4, coll.getCount());
+ Assert.AreEqual(1.0, coll.getItem(0).getX());
+ coll.setItem(3, coll.getItem(2));
+ Assert.AreEqual(3.0, coll.getItem(3).getX());
+ double sum = 0.0;
+ //for (MgCoordinate coord : coll)
+ MgCoordinate coord = coll.getItem(i);
+ sum += coord.getX();
+ Assert.AreEqual(9.0, sum);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurvePolygonCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurvePolygonCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurvePolygonCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class CurvePolygonCollectionTest implements IExternalTest
+ GeomBuild build = new GeomBuild();
+ MgCurvePolygon geom1 = build.createCurvePolygon(2.0, 5);
+ MgCurvePolygon geom2 = build.createCurvePolygon(12.0, 5);
+ MgCurvePolygon geom3 = build.createCurvePolygon(2.0, 5);
+ MgCurvePolygonCollection coll = new MgCurvePolygonCollection();
+ coll.add(geom1);
+ coll.add(geom2);
+ coll.add(geom3);
+ Assert.IsTrue(geom1.equals(coll.getItem(0)));
+ Assert.IsTrue(coll.getItem(0).equals(coll.getItem(2)));
+ Assert.IsFalse(coll.getItem(0).equals(coll.getItem(1)));
+ Assert.IsTrue(coll.getItem(0).equals(coll.getItem(1)));
+ double width = 0.0;
+ //for (MgCurvePolygon geom : coll)
+ MgCurvePolygon geom = coll.getItem(i);
+ width += geom.envelope().getWidth();
+ Assert.AreEqual(geom1.envelope().getWidth() * 3.0, width);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveRingCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveRingCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveRingCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class CurveRingCollectionTest implements IExternalTest
+ MgCurveRing geom1 = build.createCurveRing(2.0);
+ MgCurveRing geom2 = build.createCurveRing(12.0);
+ MgCurveRing geom3 = build.createCurveRing(2.0);
+ MgCurveRingCollection coll = new MgCurveRingCollection();
+ coll.add(geom1);
+ coll.add(geom2);
+ coll.add(geom3);
+ Assert.IsTrue(geom1.envelope().contains(coll.getItem(0).envelope()));
+ Assert.IsTrue(coll.getItem(0).envelope().contains(coll.getItem(2).envelope()));
+ Assert.IsFalse(coll.getItem(0).envelope().contains(coll.getItem(1).envelope()));
+ Assert.IsTrue(coll.getItem(0).envelope().contains(coll.getItem(1).envelope()));
+ //for (MgCurveRing geom : coll)
+ MgCurveRing geom = coll.getItem(i);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveSegmentCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveSegmentCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveSegmentCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class CurveSegmentCollectionTest implements IExternalTest
+ MgArcSegment geom1 = build.createArcSegment(2.0);
+ MgArcSegment geom2 = build.createArcSegment(12.0);
+ MgArcSegment geom3 = build.createArcSegment(2.0);
+ MgCurveSegmentCollection coll = new MgCurveSegmentCollection();
+ coll.add(geom1);
+ coll.add(geom2);
+ coll.add(geom3);
+ //for (MgCurveSegment geom : coll)
+ MgCurveSegment geom = coll.getItem(i);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveStringCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveStringCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/CurveStringCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class CurveStringCollectionTest implements IExternalTest
+ MgCurveString geom1 = build.createCurveString(2.0);
+ MgCurveString geom2 = build.createCurveString(12.0);
+ MgCurveString geom3 = build.createCurveString(2.0);
+ MgCurveStringCollection coll = new MgCurveStringCollection();
+ coll.add(geom1);
+ coll.add(geom2);
+ coll.add(geom3);
+ //for (MgCurveString geom : coll)
+ MgCurveString geom = coll.getItem(i);
\ No newline at end of file
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/FeatureCommandCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/FeatureCommandCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/FeatureCommandCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,36 @@
+import java.io.*;
+public class FeatureCommandCollectionTest implements IExternalTest
+ MgPropertyCollection propVals = new MgPropertyCollection();
+ MgInt32Property prop = new MgInt32Property("prop", 1);
+ propVals.addItem(prop);
+ MgUpdateFeatures update = new MgUpdateFeatures("class2", propVals, "where cat < dog");
+ MgInsertFeatures insert = new MgInsertFeatures("class3", propVals);
+ MgDeleteFeatures del = new MgDeleteFeatures("class1", "where cat > dog");
+ MgFeatureCommandCollection coll = new MgFeatureCommandCollection();
+ coll.add(update);
+ coll.add(insert);
+ coll.add(del);
+ Assert.AreEqual(MgFeatureCommandType.DeleteFeatures, coll.getItem(2).getCommandType());
+ String txt = "";
+ //for (MgFeatureCommand cmd : coll)
+ MgFeatureCommand cmd = coll.getItem(i);
+ txt += "[" + cmd.getCommandType() + "]";
+ Assert.AreEqual("[0][0][2]", txt);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/FeatureSchemaCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/FeatureSchemaCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/FeatureSchemaCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,170 @@
+import java.io.*;
+import java.util.*;
+import org.osgeo.mapguide.test.common.*;
+public class FeatureSchemaCollectionTest implements IExternalTest
+ MgFeatureSchema schema1 = new MgFeatureSchema("schema1", "desc1");
+ MgFeatureSchema schema2 = new MgFeatureSchema("schema2", "desc2");
+ MgFeatureSchema schema3 = new MgFeatureSchema("schema3", "desc3");
+ MgFeatureSchemaCollection coll = new MgFeatureSchemaCollection();
+ coll.add(schema1);
+ coll.add(schema2);
+ coll.add(schema3);
+ Assert.AreEqual("schema3", coll.getItem(2).getName());
+ coll.setItem(0, coll.getItem(2));
+ String txt = "";
+ for (MgFeatureSchema schema : coll)
+ txt += "[" + schema.getName() + "]";
+ Assert.AreEqual("[schema3][schema2][schema3]", txt);
+ MgFeatureSchemaCollection items = new MgFeatureSchemaCollection();
+ MgFeatureSchema item1 = new MgFeatureSchema("Item1", "");
+ MgFeatureSchema item2 = new MgFeatureSchema("Item2", "");
+ MgFeatureSchema item3 = new MgFeatureSchema("Item3", "");
+ MgFeatureSchema item4 = new MgFeatureSchema("Item4", "");
+ int i = 0;
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i = 0;
+ for (MgFeatureSchema item : items) {
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i++;
+ items.clear();
+ Collection<MgFeatureSchema> facade = items;
+ //add()
+ //contains()
+ ArrayList<MgFeatureSchema> testCollection = new ArrayList<MgFeatureSchema>();
+ //containsAll()
+ facade.clear();
+ //addAll()
+ //remove()
+ Assert.IsTrue(!facade.remove(new MgClassDefinition()), "Expected remove() of different type to return false");
+ //removeAll()
+ //retainAll()
+ //toArray()
+ Assert.IsTrue(o instanceof MgFeatureSchema, "Expected item to be MgFeatureSchema");
+ MgFeatureSchema[] fitems = facade.toArray(new MgFeatureSchema[0]);
+ fitems = facade.toArray(new MgFeatureSchema[1]);
+ fitems = facade.toArray(new MgFeatureSchema[3]);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/GeomBuild.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/GeomBuild.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/GeomBuild.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,336 @@
+import java.io.*;
+import org.osgeo.mapguide.*;
+public class GeomBuild
+ private MgGeometryFactory factory = new MgGeometryFactory();
+ public MgPoint createPoint()
+ MgCoordinate coord = factory.createCoordinateXYZ(5.0, 3.0, 2.0);
+ return factory.createPoint(coord);
+ public MgLineString createLineString(double offset)
+ MgCoordinateCollection coordCol = new MgCoordinateCollection();
+ MgCoordinate coord1 = factory.createCoordinateXY(offset + 0.0, 1.0);
+ MgCoordinate coord2 = factory.createCoordinateXY(offset + 2.0, 3.0);
+ MgCoordinate coord3 = factory.createCoordinateXY(offset + 4.0, 5.0);
+ coordCol.add(coord1);
+ coordCol.add(coord2);
+ coordCol.add(coord3);
+ return factory.createLineString(coordCol);
+ public MgLinearRing createLinearRing(double offset)
+ MgCoordinate oCoord1 = factory.createCoordinateXY(0.0, offset);
+ MgCoordinate oCoord2 = factory.createCoordinateXY(5.0, offset);
+ MgCoordinate oCoord3 = factory.createCoordinateXY(5.0, offset + 5.0);
+ MgCoordinate oCoord4 = factory.createCoordinateXY(0.0, offset + 5.0);
+ MgCoordinate oCoord5 = factory.createCoordinateXY(0.0, offset);
+ MgCoordinateCollection outerRingCoord = new MgCoordinateCollection();
+ outerRingCoord.add(oCoord1);
+ outerRingCoord.add(oCoord2);
+ outerRingCoord.add(oCoord3);
+ outerRingCoord.add(oCoord4);
+ outerRingCoord.add(oCoord5);
+ return factory.createLinearRing(outerRingCoord);
+ public MgPolygon createPolygon(double offset)
+ // OuterRing
+ MgCoordinate oCoord1 = factory.createCoordinateXY(offset + 0.0, 0.0);
+ MgCoordinate oCoord2 = factory.createCoordinateXY(offset + 5.0, 0.0);
+ MgCoordinate oCoord3 = factory.createCoordinateXY(offset + 5.0, 5.0);
+ MgCoordinate oCoord4 = factory.createCoordinateXY(offset + 0.0, 5.0);
+ MgCoordinate oCoord5 = factory.createCoordinateXY(offset + 0.0, 0.0);
+ // Inner Ring1
+ MgCoordinate i1Coord1 = factory.createCoordinateXY(offset + 1.0, 1.0);
+ MgCoordinate i1Coord2 = factory.createCoordinateXY(offset + 2.0, 1.0);
+ MgCoordinate i1Coord3 = factory.createCoordinateXY(offset + 2.0, 2.0);
+ MgCoordinate i1Coord4 = factory.createCoordinateXY(offset + 1.0, 1.0);
+ MgCoordinateCollection inner1RingCoord = new MgCoordinateCollection();
+ inner1RingCoord.add(i1Coord1);
+ inner1RingCoord.add(i1Coord2);
+ inner1RingCoord.add(i1Coord3);
+ inner1RingCoord.add(i1Coord4);
+ // Inner Ring2
+ MgCoordinate i2Coord1 = factory.createCoordinateXY(offset + 3.0, 3.0);
+ MgCoordinate i2Coord2 = factory.createCoordinateXY(offset + 4.0, 3.0);
+ MgCoordinate i2Coord3 = factory.createCoordinateXY(offset + 4.0, 4.0);
+ MgCoordinate i2Coord4 = factory.createCoordinateXY(offset + 3.0, 3.0);
+ MgCoordinateCollection inner2RingCoord = new MgCoordinateCollection();
+ inner2RingCoord.add(i2Coord1);
+ inner2RingCoord.add(i2Coord2);
+ inner2RingCoord.add(i2Coord3);
+ inner2RingCoord.add(i2Coord4);
+ MgLinearRing extRing = factory.createLinearRing(outerRingCoord);
+ MgLinearRing intRing1 = factory.createLinearRing(inner1RingCoord);
+ MgLinearRing intRing2 = factory.createLinearRing(inner2RingCoord);
+ MgLinearRingCollection intRings = new MgLinearRingCollection();
+ intRings.add(intRing1);
+ intRings.add(intRing2);
+ return factory.createPolygon(extRing, intRings);
+ public MgCurveString createCurveString(double offset)
+ // create and return a curvestring consisting of
+ // one circulararc segment and one linearstring segment
+ // arcseg = (0,0), (0,1), (1,2)
+ // lineseg = (1,2), (3,0), (3,2)
+ // ArcSegment
+ MgCoordinate startPos = factory.createCoordinateXY(offset + 0.0, offset + 0.0);
+ MgCoordinate midPos = factory.createCoordinateXY(offset + 0.0, offset + 1.0);
+ MgCoordinate endPos = factory.createCoordinateXY(offset + 1.0, offset + 2.0);
+ MgArcSegment arcSeg = factory.createArcSegment(startPos, endPos, midPos);
+ // Linear Segment
+ MgCoordinateCollection points = new MgCoordinateCollection();
+ MgCoordinate pt1 = factory.createCoordinateXY(offset + 1.0, offset + 2.0);
+ MgCoordinate pt2 = factory.createCoordinateXY(offset + 3.0, offset + 0.0);
+ MgCoordinate pt3 = factory.createCoordinateXY(offset + 3.0, offset + 2.0);
+ points.add(pt1);
+ points.add(pt2);
+ points.add(pt3);
+ MgLinearSegment lineSeg = factory.createLinearSegment(points);
+ // CurveSegment
+ MgCurveSegmentCollection curveSegs = new MgCurveSegmentCollection();
+ curveSegs.add(arcSeg);
+ curveSegs.add(lineSeg);
+ return factory.createCurveString(curveSegs);
+ public MgCurveRing createCurveRing(double offset)
+ // Ring is a closed entity.
+ // create and return a ring consisting of
+ // lineseg = (1,2), (0,0)
+ // ArcSegment
+ // Linear Segment
+ MgCoordinate fromPt = factory.createCoordinateXY(offset + 1.0, offset + 2.0);
+ MgCoordinate toPt = factory.createCoordinateXY(offset + 0.0, offset + 0.0);
+ points.add(fromPt);
+ points.add(toPt);
+ // Curve Segment
+ return factory.createCurveRing(curveSegs);
+ public MgCurvePolygon createCurvePolygon(double offset, int increment)
+ MgCurveRing extRing = createCurveRing(offset + increment);
+ MgCurveRingCollection intRings = new MgCurveRingCollection();
+ MgCurveRing ring1 = createCurveRing(offset + 2 * increment);
+ MgCurveRing ring2 = createCurveRing(offset + 3 * increment);
+ intRings.add(ring1);
+ intRings.add(ring2);
+ return factory.createCurvePolygon(extRing, intRings);
+ public MgMultiPoint createMultiPoint()
+ MgCoordinate coord1 = factory.createCoordinateXYZ(1.0, 2.0, 3.0);
+ MgPoint point1 = factory.createPoint(coord1);
+ MgCoordinate coord2 = factory.createCoordinateXYZ(4.0, 5.0, 6.0);
+ MgPoint point2 = factory.createPoint(coord2);
+ MgCoordinate coord3 = factory.createCoordinateXYZ(7.0, 8.0, 9.0);
+ MgPoint point3 = factory.createPoint(coord3);
+ MgPointCollection pnts = new MgPointCollection();
+ pnts.add(point1);
+ pnts.add(point2);
+ pnts.add(point3);
+ return factory.createMultiPoint(pnts);
+ public MgMultiLineString createMultiLineString()
+ MgCoordinate coord1 = factory.createCoordinateXYZ(0.0, 1.0, 2.0);
+ MgCoordinate coord2 = factory.createCoordinateXYZ(3.0, 4.0, 5.0);
+ MgCoordinate coord3 = factory.createCoordinateXYZ(6.0, 7.0, 8.0);
+ MgCoordinateCollection coordColA = new MgCoordinateCollection();
+ coordColA.add(coord1);
+ coordColA.add(coord2);
+ coordColA.add(coord3);
+ MgCoordinate coord4 = factory.createCoordinateXYZ(9.0, 10.0, 11.0);
+ MgCoordinate coord5 = factory.createCoordinateXYZ(12.0, 13.0, 14.0);
+ MgCoordinate coord6 = factory.createCoordinateXYZ(15.0, 16.0, 17.0);
+ MgCoordinateCollection coordColB = new MgCoordinateCollection();
+ coordColB.add(coord4);
+ coordColB.add(coord5);
+ coordColB.add(coord6);
+ MgLineString lineString1 = factory.createLineString(coordColA);
+ MgLineString lineString2 = factory.createLineString(coordColB);
+ MgLineStringCollection lineStrings = new MgLineStringCollection();
+ lineStrings.add(lineString1);
+ lineStrings.add(lineString2);
+ return factory.createMultiLineString(lineStrings);
+ public MgMultiPolygon createMultiPolygon()
+ MgPolygon polygon1 = createPolygon(0.0);
+ MgPolygon polygon2 = createPolygon(0.0);
+ MgPolygonCollection polygons = new MgPolygonCollection();
+ polygons.add(polygon1);
+ polygons.add(polygon2);
+ return factory.createMultiPolygon(polygons);
+ MgMultiCurveString createMultiCurveString()
+ MgCurveString curveString1 = createCurveString(100);
+ MgCurveString curveString2 = createCurveString(200);
+ MgCurveString curveString3 = createCurveString(300);
+ MgCurveStringCollection curveStrings = new MgCurveStringCollection();
+ curveStrings.add(curveString1);
+ curveStrings.add(curveString2);
+ curveStrings.add(curveString3);
+ return factory.createMultiCurveString(curveStrings);
+ public MgMultiCurvePolygon createMultiCurvePolygon(int numCurvePolys, double offset)
+ MgCurvePolygonCollection curvePolys = new MgCurvePolygonCollection();
+ for (int i = 0; i < numCurvePolys; i++)
+ MgCurvePolygon curvePoly = createCurvePolygon(i + offset, 1);
+ curvePolys.add(curvePoly);
+ return factory.createMultiCurvePolygon(curvePolys);
+ public MgMultiGeometry createMultiGeometry()
+ MgGeometryCollection geometries = new MgGeometryCollection();
+ MgGeometry geometry = null;
+ // CurvePolygon
+ geometry = (MgGeometry)createCurvePolygon(0, 1);
+ geometries.add(geometry);
+ // CurveString
+ // Not doing CurveString because of some unfixed defect.
+ // It may be the same one that sometimes affects MultiPolygon.
+ geometry = (MgGeometry)createCurveString(100);
+ // LineString
+ geometry = (MgGeometry)createLineString(1.0);
+ // Point
+ geometry = (MgGeometry)createPoint();
+ // Polygon
+ geometry = createPolygon(0.0);
+ // Make MultiGeometry from the many geometries collected above.
+ return factory.createMultiGeometry(geometries);
+ public MgArcSegment createArcSegment(double offset)
+ return factory.createArcSegment(startPos, endPos, midPos);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/GeometryCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/GeometryCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/GeometryCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class GeometryCollectionTest implements IExternalTest
+ MgWktReaderWriter wkt = new MgWktReaderWriter();
+ MgPoint geom1 = (MgPoint)wkt.read("POINT XY (1.0 1.0)");
+ MgPoint geom2 = (MgPoint)wkt.read("POINT XY (2.0 2.0)");
+ MgPoint geom3 = (MgPoint)wkt.read("POINT XY (1.0 1.0)");
+ MgGeometryCollection coll = new MgGeometryCollection();
+ coll.add(geom1);
+ coll.add(geom2);
+ coll.add(geom3);
+ double x = 0.0;
+ //for (MgGeometry geom : coll)
+ MgGeometry geom = coll.getItem(i);
+ x += ((MgPoint)geom).getCoordinate().getX();
+ Assert.AreEqual(5.0, x);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/IntCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/IntCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/IntCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,28 @@
+import java.io.*;
+public class IntCollectionTest implements IExternalTest
+ MgIntCollection coll = new MgIntCollection();
+ coll.addItem(10);
+ coll.addItem(20);
+ coll.addItem(30);
+ coll.addItem(40);
+ coll.addItem(50);
+ Assert.AreEqual(20, coll.getItem(1));
+ Assert.AreEqual(30, coll.getItem(2));
+ Assert.AreEqual(5, coll.getCount());
+ int j = 0;
+ j += coll.getItem(i);
+ Assert.AreEqual(150, j);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LineStringCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LineStringCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LineStringCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class LineStringCollectionTest implements IExternalTest
+ MgLineString geom1 = build.createLineString(5.0);
+ MgLineString geom2 = build.createLineString(11.0);
+ MgLineString geom3 = build.createLineString(5.0);
+ MgLineStringCollection coll = new MgLineStringCollection();
+ coll.add(geom1);
+ coll.add(geom2);
+ coll.add(geom3);
+ //for (MgLineString geom : coll)
+ MgLineString geom = coll.getItem(i);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LinearRingCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LinearRingCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LinearRingCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class LinearRingCollectionTest implements IExternalTest
+ MgLinearRing geom1 = build.createLinearRing(1.0);
+ MgLinearRing geom2 = build.createLinearRing(5.0);
+ MgLinearRing geom3 = build.createLinearRing(1.0);
+ MgLinearRingCollection coll = new MgLinearRingCollection();
+ coll.add(geom1);
+ coll.add(geom2);
+ coll.add(geom3);
+ //for (MgLinearRing geom : coll)
+ MgLinearRing geom = coll.getItem(i);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/MapCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/MapCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/MapCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,41 @@
+import java.io.*;
+public class MapCollectionTest implements IExternalTest
+ String coordsys = "GEOGCS[\"LL84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9108\"]],AXIS[\"Lat\",NORTH],AXIS[\"Long\",EAST],AUTHORITY[\"EPSG\",\"4326\"]]";
+ MgEnvelope env = new MgEnvelope(10, 10, 20, 20);
+ MgMapBase map1 = factory.createMap();
+ map1.create(coordsys, env, "map1");
+ MgMapBase map2 = factory.createMap();
+ map2.create(coordsys, env, "map2");
+ MgMapBase map3 = factory.createMap();
+ map3.create(coordsys, env, "map3");
+ MgMapBase map4 = factory.createMap();
+ map4.create(coordsys, env, "map4");
+ MgMapCollection coll = new MgMapCollection();
+ coll.add(map1);
+ coll.insert(1, map2);
+ coll.add(map3);
+ Assert.AreEqual(coll.getItem(2).getName(), "map3");
+ coll.setItem(1, map4);
+ String txt = "";
+ //for (MgMapBase map : coll)
+ MgMapBase map = coll.getItem(i);
+ txt += "[" + map.getName() + "]";
+ Assert.AreEqual("[map1][map4][map3]", txt);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/PropertyCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/PropertyCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/PropertyCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,191 @@
+import java.io.*;
+public class PropertyCollectionTest implements IExternalTest
+ MgPropertyCollection coll = new MgPropertyCollection();
+ MgDateTime dateTime = new MgDateTime((short)2006, (short)9, (short)21);
+ MgDateTimeProperty dateProp = new MgDateTimeProperty("DateProp", dateTime);
+ coll.add(dblProp);
+ coll.add(intProp);
+ coll.add(dateProp);
+ coll.setItem(2, single);
+ MgProperty prop1 = coll.getItem(0);
+ MgProperty prop2 = coll.getItem(1);
+ MgProperty prop3 = coll.getItem(2);
+ Assert.AreEqual(1.1111, ((MgDoubleProperty)prop1).getValue());
+ Assert.AreEqual(MgPropertyType.Double, prop1.getPropertyType());
+ Assert.AreEqual(MgPropertyType.Int32, prop2.getPropertyType());
+ Assert.AreEqual(MgPropertyType.Single, prop3.getPropertyType());
+ Assert.AreEqual((float)2.2222, ((MgSingleProperty)prop3).getValue());
+ String str = "";
+ for (MgProperty prop : coll)
+ str = str + "[" + prop.getName() + "]";
+ Assert.AreEqual("[DoubleProp][IntProp][SingleProp]", str);
+ MgPropertyCollection items = new MgPropertyCollection();
+ MgProperty item1 = new MgStringProperty("Item1", "Hello World");
+ MgProperty item2 = new MgInt32Property("Item2", 42);
+ MgProperty item3 = new MgBooleanProperty("Item3", false);
+ MgProperty item4 = new MgByteProperty("Item4", (short)4);
+ int i = 0;
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i = 0;
+ for (MgProperty item : items) {
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i++;
+ items.clear();
+ Collection<MgProperty> facade = items;
+ //add()
+ //contains()
+ ArrayList<MgProperty> testCollection = new ArrayList<MgProperty>();
+ //containsAll()
+ facade.clear();
+ //addAll()
+ //remove()
+ //removeAll()
+ //retainAll()
+ //toArray()
+ i = 0;
+ Assert.IsTrue(o instanceof MgProperty, "Expected item to be MgProperty");
+ switch(i) {
+ case 0:
+ Assert.IsTrue(o instanceof MgStringProperty, "Expected item to be MgStringProperty");
+ break;
+ case 1:
+ Assert.IsTrue(o instanceof MgBooleanProperty, "Expected item to be MgBooleanProperty");
+ break;
+ i++;
+ MgProperty[] fitems = facade.toArray(new MgProperty[0]);
+ fitems = facade.toArray(new MgProperty[1]);
+ fitems = facade.toArray(new MgProperty[3]);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/PropertyDefinitionCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/PropertyDefinitionCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/PropertyDefinitionCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,178 @@
+import java.io.*;
+public class PropertyDefinitionCollectionTest implements IExternalTest
+ MgDataPropertyDefinition def1 = new MgDataPropertyDefinition("def1");
+ MgDataPropertyDefinition def2 = new MgDataPropertyDefinition("def2");
+ MgDataPropertyDefinition def3 = new MgDataPropertyDefinition("def3");
+ MgDataPropertyDefinition def4 = new MgDataPropertyDefinition("def4");
+ MgPropertyDefinitionCollection coll = new MgPropertyDefinitionCollection();
+ coll.add(def1);
+ coll.add(def2);
+ coll.insert(2, def4);
+ coll.insert(2, def3);
+ Assert.AreEqual("def1", coll.getItem(0).getName());
+ MgPropertyDefinition tmp = coll.getItem(0);
+ coll.remove(def1);
+ coll.insert(0, tmp);
+ String txt = "";
+ for (MgPropertyDefinition def : coll)
+ txt += ".getItem(" + def.getName() + ")";
+ Assert.AreEqual(".getItem(def1).getItem(def2).getItem(def3).getItem(def4)", txt);
+ MgClassDefinition parent = new MgClassDefinition();
+ parent.setName("Parent");
+ MgPropertyDefinitionCollection items = parent.getProperties();
+ MgPropertyDefinition item1 = new MgDataPropertyDefinition("Item1");
+ MgPropertyDefinition item2 = new MgDataPropertyDefinition("Item2");
+ MgPropertyDefinition item3 = new MgDataPropertyDefinition("Item3");
+ MgPropertyDefinition item4 = new MgDataPropertyDefinition("Item4");
+ int i = 0;
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i = 0;
+ for (MgPropertyDefinition item : items) {
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i++;
+ items.clear();
+ Collection<MgPropertyDefinition> facade = items;
+ //add()
+ //contains()
+ ArrayList<MgPropertyDefinition> testCollection = new ArrayList<MgPropertyDefinition>();
+ //containsAll()
+ facade.clear();
+ //addAll()
+ //remove()
+ //removeAll()
+ //retainAll()
+ //toArray()
+ Assert.IsTrue(o instanceof MgPropertyDefinition, "Expected item to be MgPropertyDefinition");
+ MgPropertyDefinition[] fitems = facade.toArray(new MgPropertyDefinition[0]);
+ fitems = facade.toArray(new MgPropertyDefinition[1]);
+ fitems = facade.toArray(new MgPropertyDefinition[3]);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/StringCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/StringCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/StringCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,172 @@
+import java.io.*;
+public class StringCollectionTest implements IExternalTest
+ Vector<String> strColl = new Vector<String>();
+ strColl.add("string1");
+ strColl.add("string2");
+ strColl.add("string3");
+ MgStringCollection coll1 = new MgStringCollection();
+ coll1.add("Hello");
+ MgStringCollection coll2 = new MgStringCollection();
+ for (String str : strColl) {
+ coll2.add(str);
+ Assert.AreEqual(4, coll2.getCount());
+ MgStringCollection coll3 = coll2;
+ Assert.AreEqual(4, coll3.getCount());
+ for (int i = 0; i < 4; i++)
+ Assert.AreEqual(strColl.get(i), coll2.getItem(i));
+ Assert.AreEqual(strColl.get(i), coll3.getItem(i));
+ MgStringCollection items = new MgStringCollection();
+ String item1 = "Item1";
+ String item2 = "Item2";
+ String item3 = "Item3";
+ String item4 = "Item4";
+ int i = 0;
+ switch (i){
+ case 0:
+ Assert.IsTrue(items.getItem(i).equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
+ break;
+ case 1:
+ Assert.IsTrue(items.getItem(i).equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
+ break;
+ case 2:
+ Assert.IsTrue(items.getItem(i).equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
+ break;
+ i = 0;
+ for (String item : items) {
+ String itemName = item;
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i++;
+ items.clear();
+ Collection<String> facade = items;
+ //add()
+ //contains()
+ ArrayList<String> testCollection = new ArrayList<String>();
+ //containsAll()
+ facade.clear();
+ //addAll()
+ //remove()
+ //removeAll()
+ //retainAll()
+ //toArray()
+ Assert.IsTrue(o instanceof String, "Expected item to be String");
+ String[] fitems = facade.toArray(new String[0]);
+ fitems = facade.toArray(new String[1]);
+ fitems = facade.toArray(new String[3]);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/StringPropertyCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/StringPropertyCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/StringPropertyCollectionTest.java 2014-10-02 18:33:49 UTC (rev 8377)
@@ -0,0 +1,37 @@
+import java.io.*;
+public class StringPropertyCollectionTest implements IExternalTest
+ MgStringProperty prop1 = new MgStringProperty("prop1", "val1");
+ MgStringProperty prop2 = new MgStringProperty("prop2", "val2");
+ MgStringProperty prop3 = new MgStringProperty("prop3", "val3");
+ MgStringProperty prop4 = new MgStringProperty("prop4", "val4");
+ MgStringPropertyCollection coll = new MgStringPropertyCollection();
+ coll.add(prop1);
+ coll.add(prop2);
+ coll.remove(prop3);
+ coll.remove(coll.getItem(1));
+ Assert.AreEqual(1, coll.getCount());
+ coll.add(prop3);
+ coll.setItem(1, prop2);
+ coll.insert(2, prop3);
+ Assert.AreEqual(2, coll.indexOf(prop3));
+ coll.add(prop4);
+ String txt = "";
+ //for (MgStringProperty prop : coll)
+ MgStringProperty prop = coll.getItem(i);
+ txt += ".getItem(" + prop.getName() + ")";
+ Assert.AreEqual(".getItem(prop1).getItem(prop2).getItem(prop3).getItem(prop4)", txt);
More information about the mapguide-commits
