[mapguide-commits] r8386 - in trunk/MgDev/UnitTest/WebTier/Java: . src/org/osgeo/mapguide/test src/org/osgeo/mapguide/test/common src/org/osgeo/mapguide/test/mapguide/operations/weblayout
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Oct 6 04:33:24 PDT 2014
Author: jng
Date: 2014-10-06 04:33:24 -0700 (Mon, 06 Oct 2014)
New Revision: 8386
Added:
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_BackDescription.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_BackTooltip.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ForwardDescription.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ForwardTooltip.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetCenter.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetInformationPaneWidth.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetInitialTaskUrl.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetMapDefinition.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetScale.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetTaskPaneWidth.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetTitle.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_HomeDescription.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_HomeTooltip.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowContextMenu.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowLegend.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowProperties.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowStatusbar.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowTaskbar.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowTaskpane.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowToolbar.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksDescription.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksName.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksTooltip.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TestUiItem.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WebLayoutOperationExecutor.java
   trunk/MgDev/UnitTest/WebTier/Java/build.xml
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTestExecutorCollection.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/CommonUtility.java
   trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestResult.java
#2307:
 - Wipe out any dumped binary files and log files as part of the "check" target before running the main jar.
 - Add web layout test operations. This brings up test suite parity with the .net runner.
Modified: trunk/MgDev/UnitTest/WebTier/Java/build.xml
--- trunk/MgDev/UnitTest/WebTier/Java/build.xml	2014-10-06 10:35:18 UTC (rev 8385)
+++ trunk/MgDev/UnitTest/WebTier/Java/build.xml	2014-10-06 11:33:24 UTC (rev 8386)
@@ -142,6 +142,11 @@
   </target>
   <target name="check" depends="dist">
+    <!-- Remove any log files and dumped binary files from previous run -->
+    <delete>
+      <fileset dir="${dist}" includes="**/*.bin"/>
+      <fileset dir="${dist}" includes="**/*.log"/>
+    </delete>
     <exec executable="java" dir="${dist}">
       <arg line="-jar MgUnitTest.jar ${mapguide.config} ${unittest.logpath}" />
       <env key="MENTOR_DICTIONARY_PATH" value="${mapguide.dictpath}" />
Modified: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTestExecutorCollection.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTestExecutorCollection.java	2014-10-06 10:35:18 UTC (rev 8385)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTestExecutorCollection.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -23,6 +23,7 @@
 import org.osgeo.mapguide.test.mapguide.operations.drawing.*;
 import org.osgeo.mapguide.test.mapguide.operations.admin.*;
 import org.osgeo.mapguide.test.mapguide.operations.site.*;
+import org.osgeo.mapguide.test.mapguide.operations.weblayout.*;
 public class MapGuideTestExecutorCollection extends TestExecutorCollectionBase
@@ -170,8 +171,6 @@
         _executors.put("UpdateServer".toUpperCase(), new UpdateServer(site, dbPath));
         _executors.put("RemoveServer".toUpperCase(), new RemoveServer(site, dbPath));
         //Web Layout
         _executors.put("WL_GetTitle".toUpperCase(), new WL_GetTitle(wlCreator, dbPath));
         _executors.put("WL_GetMapDefinition".toUpperCase(), new WL_GetMapDefinition(wlCreator, dbPath));
@@ -197,8 +196,6 @@
         _executors.put("WL_TasksName".toUpperCase(), new WL_TasksName(wlCreator, dbPath));
         _executors.put("WL_TasksTooltip".toUpperCase(), new WL_TasksTooltip(wlCreator, dbPath));
         _executors.put("WL_TasksDescription".toUpperCase(), new WL_TasksDescription(wlCreator, dbPath));
     class MgWebLayoutCreator implements IWebLayoutCreator
Modified: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/CommonUtility.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/CommonUtility.java	2014-10-06 10:35:18 UTC (rev 8385)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/CommonUtility.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -19,6 +19,14 @@
 public class CommonUtility
+    public static String DoubleToString(double d)
+        if(d == (long) d)
+            return String.format("%d",(long)d);
+        else
+            return String.format("%s",d);
     public static MgStringCollection StringToMgStringCollection(String str)
         try
Modified: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestResult.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestResult.java	2014-10-06 10:35:18 UTC (rev 8385)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/common/TestResult.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -1,6 +1,7 @@
 package org.osgeo.mapguide.test.common;
 import java.util.UUID;
+import java.text.DecimalFormat;
 import org.osgeo.mapguide.*;
 import org.osgeo.mapguide.test.*;
@@ -74,7 +75,14 @@
     public static TestResult Double(double value) {
-        return new TestResult((value + ""), "text/plain");
+        DecimalFormat format = new DecimalFormat("0.#");
+        if (value < 0.0)
+            return new TestResult("-" + format.format(Math.abs(value)), "text/plain");
+        else
+            return new TestResult(format.format(value), "text/plain");
+       return new TestResult(String.format("%g", value), "text/plain");
     public static TestResult Boolean(boolean value) {
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_BackDescription.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_BackDescription.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_BackDescription.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+package org.osgeo.mapguide.test.mapguide.operations.weblayout;
+import java.util.*;
+import com.almworks.sqlite4java.*;
+import org.osgeo.mapguide.*;
+import org.osgeo.mapguide.test.*;
+import org.osgeo.mapguide.test.common.*;
+import org.osgeo.mapguide.test.operations.*;
+public class WL_BackDescription extends WebLayoutOperationExecutor
+    public WL_BackDescription(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_BackDescription", layout, unitTestVm);
+    public TestResult Execute(int paramSetId)
+        try
+            CreateWebLayoutFromResource(paramSetId);
+            MgWebTaskPane tp = _wl.getTaskPane();
+            MgWebTaskBar tbar = tp.getTaskBar();
+            MgWebWidgetCollection tbuttons = tbar.getTaskButtons();
+            MgWebTaskBarWidget back = (MgWebTaskBarWidget)tbuttons.getWidget(MgWebTaskButtonType.Back);
+            return TestResult.String(back.getDescription());
+        catch (MgException ex)
+            return TestResult.FromMgException(ex);
\ No newline at end of file
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_BackTooltip.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_BackTooltip.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_BackTooltip.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+public class WL_BackTooltip extends WebLayoutOperationExecutor
+    public WL_BackTooltip(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_BackTooltip", layout, unitTestVm);
+        try
+            return TestResult.String(back.getTooltip());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ForwardDescription.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ForwardDescription.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ForwardDescription.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+public class WL_ForwardDescription extends WebLayoutOperationExecutor
+    public WL_ForwardDescription(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ForwardDescription", layout, unitTestVm);
+        try
+            MgWebTaskBarWidget fwd = (MgWebTaskBarWidget)tbuttons.getWidget(MgWebTaskButtonType.Forward);
+            return TestResult.String(fwd.getDescription());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ForwardTooltip.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ForwardTooltip.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ForwardTooltip.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+public class WL_ForwardTooltip extends WebLayoutOperationExecutor
+    public WL_ForwardTooltip(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ForwardTooltip", layout, unitTestVm);
+        try
+            return TestResult.String(fwd.getTooltip());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetCenter.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetCenter.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetCenter.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,38 @@
+public class WL_GetCenter extends WebLayoutOperationExecutor
+    public WL_GetCenter(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_GetCenter", layout, unitTestVm);
+        try
+            MgPoint center = _wl.getCenter();
+            if (center == null)
+                return TestResult.String("");
+            else
+                MgCoordinate coord = center.getCoordinate();
+                return TestResult.String(CommonUtility.DoubleToString(coord.getX()) + "/" + CommonUtility.DoubleToString(coord.getY()));
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetInformationPaneWidth.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetInformationPaneWidth.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetInformationPaneWidth.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_GetInformationPaneWidth extends WebLayoutOperationExecutor
+    public WL_GetInformationPaneWidth(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_GetInformationPaneWidth", layout, unitTestVm);
+        try
+            MgWebInformationPane ip = _wl.getInformationPane();
+            return TestResult.Integer(ip.getWidth());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetInitialTaskUrl.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetInitialTaskUrl.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetInitialTaskUrl.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_GetInitialTaskUrl extends WebLayoutOperationExecutor
+    public WL_GetInitialTaskUrl(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_GetInitialTaskUrl", layout, unitTestVm);
+        try
+            return TestResult.String(tp.getInitialTaskUrl());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetMapDefinition.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetMapDefinition.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetMapDefinition.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,29 @@
+public class WL_GetMapDefinition extends WebLayoutOperationExecutor
+    public WL_GetMapDefinition(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_GetMapDefinition", layout, unitTestVm);
+        try
+            return TestResult.String(_wl.getMapDefinition());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetScale.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetScale.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetScale.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,29 @@
+public class WL_GetScale extends WebLayoutOperationExecutor
+    public WL_GetScale(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_GetScale", layout, unitTestVm);
+        try
+            return TestResult.Double(_wl.getScale());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetTaskPaneWidth.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetTaskPaneWidth.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetTaskPaneWidth.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_GetTaskPaneWidth extends WebLayoutOperationExecutor
+    public WL_GetTaskPaneWidth(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_GetTaskPaneWidth", layout, unitTestVm);
+        try
+            return TestResult.Integer(tp.getWidth());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetTitle.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetTitle.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_GetTitle.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,29 @@
+public class WL_GetTitle extends WebLayoutOperationExecutor
+    public WL_GetTitle(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_GetTitle", layout, unitTestVm);
+        try
+            return TestResult.String(_wl.getTitle());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_HomeDescription.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_HomeDescription.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_HomeDescription.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+public class WL_HomeDescription extends WebLayoutOperationExecutor
+    public WL_HomeDescription(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_HomeDescription", layout, unitTestVm);
+        try
+            MgWebTaskBarWidget home = (MgWebTaskBarWidget)tbuttons.getWidget(MgWebTaskButtonType.Home);
+            return TestResult.String(home.getDescription());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_HomeTooltip.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_HomeTooltip.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_HomeTooltip.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+public class WL_HomeTooltip extends WebLayoutOperationExecutor
+    public WL_HomeTooltip(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_HomeTooltip", layout, unitTestVm);
+        try
+            return TestResult.String(home.getTooltip());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowContextMenu.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowContextMenu.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowContextMenu.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_ShowContextMenu extends WebLayoutOperationExecutor
+    public WL_ShowContextMenu(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ShowContextMenu", layout, unitTestVm);
+        try
+            MgWebContextMenu ctx = _wl.getContextMenu();
+            return TestResult.Boolean(ctx.isVisible());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowLegend.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowLegend.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowLegend.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_ShowLegend extends WebLayoutOperationExecutor
+    public WL_ShowLegend(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ShowLegend", layout, unitTestVm);
+        try
+            return TestResult.Boolean(ip.isLegendBandVisible());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowProperties.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowProperties.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowProperties.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_ShowProperties extends WebLayoutOperationExecutor
+    public WL_ShowProperties(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ShowProperties", layout, unitTestVm);
+        try
+            return TestResult.Boolean(ip.isPropertiesBandVisible());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowStatusbar.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowStatusbar.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowStatusbar.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_ShowStatusbar extends WebLayoutOperationExecutor
+    public WL_ShowStatusbar(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ShowStatusbar", layout, unitTestVm);
+        try
+            MgWebUiPane sb = _wl.getStatusBar();
+            return TestResult.Boolean(sb.isVisible());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowTaskbar.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowTaskbar.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowTaskbar.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,31 @@
+public class WL_ShowTaskbar extends WebLayoutOperationExecutor
+    public WL_ShowTaskbar(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ShowTaskbar", layout, unitTestVm);
+        try
+            MgWebTaskBar tb = tp.getTaskBar();
+            return TestResult.Boolean(tb.isVisible());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowTaskpane.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowTaskpane.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowTaskpane.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_ShowTaskpane extends WebLayoutOperationExecutor
+    public WL_ShowTaskpane(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ShowTaskpane", layout, unitTestVm);
+        try
+            return TestResult.Boolean(tp.isVisible());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowToolbar.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowToolbar.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_ShowToolbar.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,30 @@
+public class WL_ShowToolbar extends WebLayoutOperationExecutor
+    public WL_ShowToolbar(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_ShowToolbar", layout, unitTestVm);
+        try
+            MgWebToolBar tb = _wl.getToolBar();
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksDescription.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksDescription.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksDescription.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+public class WL_TasksDescription extends WebLayoutOperationExecutor
+    public WL_TasksDescription(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_TasksDescription", layout, unitTestVm);
+        try
+            MgWebTaskBarWidget tasks = (MgWebTaskBarWidget)tbuttons.getWidget(MgWebTaskButtonType.Tasks);
+            return TestResult.String(tasks.getDescription());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksName.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksName.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksName.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+public class WL_TasksName extends WebLayoutOperationExecutor
+    public WL_TasksName(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_TasksName", layout, unitTestVm);
+        try
+            return TestResult.String(tasks.getName());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksTooltip.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksTooltip.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TasksTooltip.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,33 @@
+public class WL_TasksTooltip extends WebLayoutOperationExecutor
+    public WL_TasksTooltip(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_TasksTooltip", layout, unitTestVm);
+        try
+            return TestResult.String(tasks.getTooltip());
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TestUiItem.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TestUiItem.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WL_TestUiItem.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,55 @@
+public class WL_TestUiItem extends WebLayoutOperationExecutor
+    public WL_TestUiItem(IWebLayoutCreator layout, String unitTestVm)
+        super("WL_TestUiItem", layout, unitTestVm);
+        try
+            MgWebWidgetCollection coll = null;
+            HashMap<String, String> param = new HashMap<String, String>();
+            ReadParameterValue(paramSetId, "CONTAINER", param);
+            ReadParameterValue(paramSetId, "INDEX", param);
+            switch (param.get("CONTAINER"))
+                case "toolbar":
+                    coll = tb.getWidgets();
+                    break;
+                case "tasklist":
+                    coll = tbar.getTaskList();
+                    break;
+                case "contextmenu":
+                    coll = _wl.getContextMenu();
+                    break;
+            MgWebWidget widget = coll.getWidget(Integer.parseInt(param.get("INDEX")));
+            if (widget == null)
+                return TestResult.String("Null widget");
+            else
+                return TestResult.String(FormatProperties(widget));
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WebLayoutOperationExecutor.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WebLayoutOperationExecutor.java	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/operations/weblayout/WebLayoutOperationExecutor.java	2014-10-06 11:33:24 UTC (rev 8386)
@@ -0,0 +1,91 @@
+public abstract class WebLayoutOperationExecutor extends PlatformApiTestExecutor
+    protected MgWebLayout _wl;
+    protected IWebLayoutCreator _creator;
+    protected WebLayoutOperationExecutor(String name, IWebLayoutCreator wl, String unitTestVm)
+        super(name, ApiTypes.Platform, unitTestVm);
+        _creator = wl;
+    protected void CreateWebLayoutFromResource(int paramSetId)
+        if (_wl != null)
+            return;
+        try {
+            SQLiteStatement stmt = _conn.prepare(String.format("Select ParamValue from Params WHERE ParamSet=%d AND ParamName=\"WEBLAYOUT\"", paramSetId));
+            String wlId = null;
+            if (stmt.step()) {
+                wlId = CommonUtility.GetStringFromStatement(stmt, "ParamValue");
+                if (CommonUtility.IsNullOrEmpty(wlId))
+                    wlId = "Library://UnitTest/layouts/Test.WebLayout";
+            } else {
+            MgResourceIdentifier resId = new MgResourceIdentifier(wlId);
+            _wl = _creator.CreateWebLayout(resId);
+        } catch (Exception ex) {
+            throw new RuntimeException(ex);
+    protected String FormatProperties(MgWebWidget it)
+        String name = "";
+        switch (it.getType())
+            case MgWebWidgetType.Separator:
+                name = "";
+                break;
+            case MgWebWidgetType.Command:
+                MgWebCommand cmd = ((MgWebCommandWidget)it).getCommand();
+                name = cmd.getLabel();
+                break;
+            case MgWebWidgetType.Flyout:
+                name = ((MgWebFlyoutWidget)it).getLabel();
+                break;
+        String str = "[" + name + "/" + it.getType();
+        if (it.getType() == MgWebWidgetType.Separator)
+            return str + "]";
+        else if (it.getType() == MgWebWidgetType.Command)
+            return str + "/" + cmd.getName() + "]";
+        else if (it.getType() == MgWebWidgetType.Flyout)
+            MgWebFlyoutWidget fly = ((MgWebFlyoutWidget)it);
+            str = str + "/" + fly.getIconUrl();
+            MgWebWidgetCollection coll = fly.getSubItems();
+            for (int i = 0; i < coll.getCount(); i++)
+                MgWebWidget widget = coll.getWidget(i);
+                str = str + "/" + FormatProperties(widget);
+            str = str + "]";
+        else
+            return "[** error **]";
+        return str;
More information about the mapguide-commits mailing list
