[mapguide-commits] r8406 - trunk/MgDev
svn_mapguide at osgeo.org
Thu Oct 16 21:03:42 PDT 2014
Author: jng
Date: 2014-10-16 21:03:42 -0700 (Thu, 16 Oct 2014)
New Revision: 8406
Added:
trunk/MgDev/run_tests.sh
#2493: Add first cut of run_tests.sh to run server and web-tier tests within a single script on Linux
Added: trunk/MgDev/run_tests.sh
--- trunk/MgDev/run_tests.sh (rev 0)
+++ trunk/MgDev/run_tests.sh 2014-10-17 04:03:42 UTC (rev 8406)
@@ -0,0 +1,125 @@
+#!/bin/bash
+# run_tests.sh
+# Simple wrapper script to execute all applicable tests on Linux
+SERVER_SAFE_SUBSET=1
+MG_INST=/usr/local/mapguideopensource
+PHP_CMD=$MG_INST/webserverextensions/php/bin/php
+TEST_SERVER=0
+TEST_PHP=0
+TEST_JAVA=1
+LOG_PATH=~
+TEST_COMPONENT=
+MG_SERVER_PID=
+check_test()
+ error=$?
+ if [ $error -ne 0 ]; then
+ echo "[warning]: ${TEST_COMPONENT} - Test returned non-zero result ($error)"
+ echo "[warning]: ${TEST_COMPONENT} - Test returned non-zero result ($error)" >> $LOG_PATH/unit_test_status.log
+ fi
+start_mapguide_server()
+ pushd Server/src/Core > /dev/null
+ echo "[test]: Start mgserver (with 30s wait)"
+ ./mgserver run > $LOG_PATH/mapguide_server_run.log 2>&1 &
+ MG_SERVER_PID=$!
+ # Give some time for the mgserver to actually fully initialize
+ sleep 30
+ echo "[test]: mgserver started ($MG_SERVER_PID)"
+ popd > /dev/null
+stop_mapguide_server()
+ echo "[test]: Stop mgserver"
+ kill $MG_SERVER_PID
+ echo "[test]: mgserver stopped ($MG_SERVER_PID)"
+ MG_SERVER_PID=
+# Build server unit test suite (regardless of whether we're running
+# server tests or not)
+echo "[build]: Server unit tests"
+pushd Server/src/UnitTesting > /dev/null
+make libMgUnitTesting.la
+popd > /dev/null
+pushd Server/src/Core > /dev/null
+make unittest.sh
+popd > /dev/null
+if [ $TEST_SERVER -eq 1 ]; then
+ if [ $SERVER_FAST_SUBSET -eq 1 ]; then
+ for comp in FeatureService Geometry KmlService LogManager MappingService MdfModel Misc Performance RenderingService ServerAdminService ServerManager ServiceManager SiteManager SiteService ProfilingService TransformMesh
+ do
+ TEST_COMPONENT="MapGuide Server Test Suite ($comp)"
+ echo "[test]: $TEST_COMPONENT"
+ ./mgserver test $comp $LOG_PATH/UnitTestResult_${comp}.xml 2>&1 | tee $LOG_PATH/mapguide_${comp}_unit_test.log
+ check_test
+ done
+ else
+ TEST_COMPONENT="MapGuide Server Test Suite (all)"
+ ./mgserver test 2>&1 | tee $LOG_PATH/mapguide_test.log
+ check_test
+ fi
+else
+ echo "[test]: Skipping Server Test Suite"
+fi
+popd > /dev/null
+if [ $TEST_PHP -eq 1 ]; then
+ #clear out old dbs
+ pushd UnitTest/TestData > /dev/null
+ rm -rf Unicode/UnicodeTest.db
+ rm -rf WmsTest/WmsTest.db
+ rm -rf WebLayout/WebLayoutTest.db
+ rm -rf WfsTest/WfsTest.db
+ rm -rf MapLayer/MapLayerTest.db
+ rm -rf ServerAdmin/ServerAdminTest.db
+ rm -rf MappingService/MappingServiceTest.db
+ rm -rf SiteService/SiteServiceTest.db
+ rm -rf FeatureService/FeatureServiceTest.db
+ rm -rf DrawingService/DrawingServiceTest.db
+ rm -rf ResourceService/ResourceServiceTest.db
+ popd > /dev/null
+ pushd UnitTest\WebTier\Php > /dev/null
+ TEST_COMPONENT="PHP Web Tier Tests"
+ $PHP_CMD RunTests.php
+ check_test
+ popd > /dev/null
+fi
+if [ $TEST_JAVA -eq 1 ]; then
+ popd > /dev/null
+ start_mapguide_server
+ pushd UnitTest/WebTier/Java > /dev/null
+ TEST_COMPONENT="Java Web Tier Tests"
+ ant checkunix 2>&1 | tee $LOG_PATH/java_test_output.log
+ check_test
+ popd > /dev/null
+ stop_mapguide_server
+fi
Property changes on: trunk/MgDev/run_tests.sh
___________________________________________________________________
Added: svn:executable
More information about the mapguide-commits
