[mapguide-commits] r8413 - in trunk/MgDev/UnitTest: . WebTier/Php
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Oct 17 05:40:50 PDT 2014
Author: jng
Date: 2014-10-17 05:40:50 -0700 (Fri, 17 Oct 2014)
New Revision: 8413
   trunk/MgDev/UnitTest/WebTier/Php/DrawingServiceAPI.php
   trunk/MgDev/UnitTest/WebTier/Php/FeatureServiceAPI.php
   trunk/MgDev/UnitTest/WebTier/Php/MapLayerAPI.php
   trunk/MgDev/UnitTest/WebTier/Php/MappingServiceAPI.php
   trunk/MgDev/UnitTest/WebTier/Php/MappingServiceHttpRequests.php
   trunk/MgDev/UnitTest/WebTier/Php/ResourceServiceAPI.php
   trunk/MgDev/UnitTest/WebTier/Php/Utils.php
   trunk/MgDev/UnitTest/WebTier/Php/WebLayoutAPI.php
   trunk/MgDev/UnitTest/WebTier/Php/createSdf.php
   trunk/MgDev/UnitTest/WebTier/Php/createSdfUnicode.php
   trunk/MgDev/UnitTest/WebTier/Php/testAwSelection.php
   trunk/MgDev/UnitTest/prepare.php
#2494: PHP test runner fixes:
 - Fix constants.php include paths
 - Add linux rooted path check for Utils::GetPath()
Modified: trunk/MgDev/UnitTest/WebTier/Php/DrawingServiceAPI.php
--- trunk/MgDev/UnitTest/WebTier/Php/DrawingServiceAPI.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/DrawingServiceAPI.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -17,7 +17,7 @@
 //  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-require_once("../../../Web/src/PhpApi/Constants.php");
+require_once("../../../Web/src/PhpApi/constants.php");
 require_once("Result.php");
 require_once("Utils.php");
Modified: trunk/MgDev/UnitTest/WebTier/Php/FeatureServiceAPI.php
--- trunk/MgDev/UnitTest/WebTier/Php/FeatureServiceAPI.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/FeatureServiceAPI.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -17,7 +17,7 @@
Modified: trunk/MgDev/UnitTest/WebTier/Php/MapLayerAPI.php
--- trunk/MgDev/UnitTest/WebTier/Php/MapLayerAPI.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/MapLayerAPI.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -17,7 +17,7 @@
Modified: trunk/MgDev/UnitTest/WebTier/Php/MappingServiceAPI.php
--- trunk/MgDev/UnitTest/WebTier/Php/MappingServiceAPI.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/MappingServiceAPI.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -19,7 +19,7 @@
 //This file defines the operations that are currently supported for Mapping Service API by the unit test infrastructure.
 //There is one function per operation. Each function tries to retrieve the parameters that are required for its corresponding
Modified: trunk/MgDev/UnitTest/WebTier/Php/MappingServiceHttpRequests.php
--- trunk/MgDev/UnitTest/WebTier/Php/MappingServiceHttpRequests.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/MappingServiceHttpRequests.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -19,7 +19,7 @@
 require_once("HttpRequest.php");
 //This file defines the operations that are currently supported by the unit test infrastructure for Drawing Service methods exposed through Htpp.
Modified: trunk/MgDev/UnitTest/WebTier/Php/ResourceServiceAPI.php
--- trunk/MgDev/UnitTest/WebTier/Php/ResourceServiceAPI.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/ResourceServiceAPI.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -22,7 +22,7 @@
 //operation and executes the operation
 //Edit that file to add more operations for Resource Service API
Modified: trunk/MgDev/UnitTest/WebTier/Php/Utils.php
--- trunk/MgDev/UnitTest/WebTier/Php/Utils.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/Utils.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -81,9 +81,15 @@
     public static function GetPath($fileName)
+        if (strpos($fileName, "/") === 0)
+            //echo "Utils::GetPath($fileName) - $fileName\n";
+            return $fileName;
         $pos = strrpos($fileName, ':');
         if($pos)
             return $fileName;
@@ -98,13 +104,14 @@
         //Replace the back slashes in the path with forward slashes for Linux compatibility
         $relPath = str_replace("\\", "/", $relPath);
+        //echo "Utils::GetPath($fileName) - $relPath\n";
         return $relPath;
     public static function MapAgentInit($webConfigIniPath)
         $cfgFile = self::GetPath($webConfigIniPath);
+        //echo "Initializing from $cfgFile\n\n";
         MgInitializeWebTier($cfgFile);
Modified: trunk/MgDev/UnitTest/WebTier/Php/WebLayoutAPI.php
--- trunk/MgDev/UnitTest/WebTier/Php/WebLayoutAPI.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/WebLayoutAPI.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -17,7 +17,7 @@
Modified: trunk/MgDev/UnitTest/WebTier/Php/createSdf.php
--- trunk/MgDev/UnitTest/WebTier/Php/createSdf.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/createSdf.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -18,7 +18,7 @@
 try
Modified: trunk/MgDev/UnitTest/WebTier/Php/createSdfUnicode.php
--- trunk/MgDev/UnitTest/WebTier/Php/createSdfUnicode.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/createSdfUnicode.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -18,7 +18,7 @@
 try
Modified: trunk/MgDev/UnitTest/WebTier/Php/testAwSelection.php
--- trunk/MgDev/UnitTest/WebTier/Php/testAwSelection.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/WebTier/Php/testAwSelection.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -18,7 +18,7 @@
 interface FeatureClass
Modified: trunk/MgDev/UnitTest/prepare.php
--- trunk/MgDev/UnitTest/prepare.php	2014-10-17 11:23:23 UTC (rev 8412)
+++ trunk/MgDev/UnitTest/prepare.php	2014-10-17 12:40:50 UTC (rev 8413)
@@ -1,6 +1,6 @@
 <?php
-require_once dirname(__FILE__)."/../Web/src/mapadmin/constants.php";
+require_once dirname(__FILE__)."/../Web/src/PhpApi/constants.php";
 $file = dirname(__FILE__)."/webconfig.ini";
 $mgp = dirname(__FILE__)."/TestData/Samples/Sheboygan/Sheboygan.mgp";
More information about the mapguide-commits mailing list
