[mapguide-commits] r8416 - trunk/MgDev
svn_mapguide at osgeo.org
Sat Oct 18 04:10:40 PDT 2014
Author: jng
Date: 2014-10-18 04:10:40 -0700 (Sat, 18 Oct 2014)
New Revision: 8416
trunk/MgDev/run_tests.sh
#2493: Add support for controlling test run behaviour via supplying arguments
Modified: trunk/MgDev/run_tests.sh
--- trunk/MgDev/run_tests.sh 2014-10-18 09:54:52 UTC (rev 8415)
+++ trunk/MgDev/run_tests.sh 2014-10-18 11:10:40 UTC (rev 8416)
@@ -5,22 +5,116 @@
# Simple wrapper script to execute all applicable tests on Linux
-SERVER_FAST_SUBSET=1
-MG_INST=/usr/local/mapguideopensource-3.0.0
+# You can run this script after building the main MapGuide source (make && make install)
+# If set to 1, only a subset of the MapGuide Server test suite is run. In this mode,
+# the following test suites are skipped: CoordinateSystem, ResourceService, TileService
+SERVER_FAST_SUBSET=0
+# The location where MapGuide is installed
+MG_INST=/usr/local/mapguideopensource
PHP_CMD=$MG_INST/webserverextensions/php/bin/php
-USE_LOCAL_SERVER=1
-TEST_SERVER=1
-TEST_PHP=1
-TEST_JAVA=1
+# If set to 1, will try to use a locally-built mgserver (for the server tests) and
+# built-in PHP web server hosted mapagent for running the PHP and Java test suites.
+# Otherwise, it will use the installed Apache and MapGuide Server in the above
+# installation path
+USE_LOCAL_SERVER=0
+# Set to 1 to run the server test suite
+TEST_SERVER=0
+# Set to 1 to run the PHP test suite
+TEST_PHP=0
+# Set to 1 to run the Java test suite
+TEST_JAVA=0
+# The directory where various test/status log files will be written
LOG_PATH=~
TEST_COMPONENT=
MG_SERVER_PID=
MG_SERVER_WAIT=30
WEB_SERVER_PID=
WEB_SERVER_ADDR=localhost
-WEB_SERVER_PORT=8018
+WEB_SERVER_PORT=8008
WEB_SERVER_WAIT=15
+while [ $# -gt 0 ]; do # Until you run out of parameters...
+ case "$1" in
+ --prefix)
+ MG_INST="$2"
+ PHP_CMD=$MG_INST/webserverextensions/php/bin/php
+ shift
+ --logpath)
+ LOG_PATH="$2"
+ shift
+ --with-java)
+ TEST_JAVA=1
+ --with-php)
+ TEST_PHP=1
+ --with-server)
+ TEST_SERVER=1
+ --with-server-fast-subset)
+ TEST_SERVER=1
+ SERVER_FAST_SUBSET=1
+ --with-local-server)
+ USE_LOCAL_SERVER=1
+ --local-mgserver-wait)
+ MG_SERVER_WAIT=$2
+ shift
+ --local-webserver-wait)
+ WEB_SERVER_WAIT=$2
+ shift
+ --local-webserver-addr)
+ WEB_SERVER_ADDR="$2"
+ shift
+ --local-webserver-port)
+ WEB_SERVER_PORT=$2
+ shift
+ --help)
+ echo "Usage: $0 (options)"
+ echo "Options:"
+ echo " --prefix <value> [MapGuide install location]"
+ echo " --logpath <value> [Directory where logs will be written]"
+ echo " --with-java [Run Java Test Suite]"
+ echo " --with-php [Run PHP Test Suite]"
+ echo " --with-server [Run Server Test Suite]"
+ echo " --with-server-fast-subset [Run fast subset of Server Test Suite]"
+ echo " --with-local-server [Use local mgserver/PHP web server for tests]"
+ echo " --local-mgserver-wait <value> [Wait <value> seconds for local mgserver to start. No effect if not using local server]"
+ echo " --local-webserver-wait <value> [Wait <value> seconds for local webserver to start. No effect if not using local server]"
+ echo " --local-webserver-addr <value> [Start PHP web server on <value>. No effect if not using local server]"
+ echo " --local-webserver-port <value> [Start PHP web server to listen on port <value>. No effect if not using local server]"
+ echo " --help [Display this notice]"
+ exit
+ esac
+ shift # Check next set of parameters.
+done
+echo "*********************************************"
+echo "Variable Summary"
+echo "MG_INST: $MG_INST"
+echo "PHP_CMD: $PHP_CMD"
+echo "SERVER_FAST_SUBSET: $SERVER_FAST_SUBSET"
+echo "USE_LOCAL_SERVER: $USE_LOCAL_SERVER"
+echo "TEST_SERVER: $TEST_SERVER"
+echo "TEST_PHP: $TEST_PHP"
+echo "TEST_JAVA: $TEST_JAVA"
+echo "LOG_PATH: $LOG_PATH"
+echo "MG_SERVER_WAIT: $MG_SERVER_WAIT"
+echo "WEB_SERVER_ADDR: $WEB_SERVER_ADDR"
+echo "WEB_SERVER_PORT: $WEB_SERVER_PORT"
+echo "WEB_SERVER_WAIT: $WEB_SERVER_WAIT"
check_test()
error=$?
@@ -34,45 +128,80 @@
start_php_web_server()
- echo "[web server]: Starting (with ${WEB_SERVER_WAIT}s wait)"
- $PHP_CMD -d upload_max_filesize=20M -S "$WEB_SERVER_ADDR:$WEB_SERVER_PORT" -t UnitTest/WebTier/MapAgent/MapAgentForms UnitTest/WebTier/Php/MapAgentShim/index.php > $LOG_PATH/php_web_server.log 2>&1 &
- WEB_SERVER_PID=$!
- # Give some time for the mgserver to actually fully initialize
- sleep $WEB_SERVER_WAIT
- echo "[web server]: Started ($WEB_SERVER_PID)"
+ if [ $USE_LOCAL_SERVER -eq 1 ]; then
+ echo "[web server]: Starting (with ${WEB_SERVER_WAIT}s wait)"
+ $PHP_CMD -d upload_max_filesize=20M -S "$WEB_SERVER_ADDR:$WEB_SERVER_PORT" -t UnitTest/WebTier/MapAgent/MapAgentForms UnitTest/WebTier/Php/MapAgentShim/index.php > $LOG_PATH/php_web_server.log 2>&1 &
+ WEB_SERVER_PID=$!
+ # Give some time for the mgserver to actually fully initialize
+ sleep $WEB_SERVER_WAIT
+ echo "[web server]: Started ($WEB_SERVER_PID)"
+ else
+ pushd $MG_INST/webserverextensions/apache2/bin > /dev/null
+ echo "[web server]: Starting Apache"
+ ./apachectl restart
+ echo "[web server]: Started"
+ popd > /dev/null
+ fi
stop_php_web_server()
- echo "[web server]: Stopping"
- kill $WEB_SERVER_PID
- echo "[web server]: Stopped ($WEB_SERVER_PID)"
- WEB_SERVER_PID=
+ echo "[web server]: Stopping"
+ kill $WEB_SERVER_PID
+ echo "[web server]: Stopped ($WEB_SERVER_PID)"
+ WEB_SERVER_PID=
+ else
+ echo "[web server]: Stopping Apache"
+ ./apachectl stop
+ echo "[web server]: Stopped"
+ popd > /dev/null
+ fi
start_mapguide_server()
- pushd Server/src/Core > /dev/null
- echo "[mgserver]: Starting (with ${MG_SERVER_WAIT}s wait)"
- ./mgserver run > $LOG_PATH/mapguide_server_run.log 2>&1 &
- MG_SERVER_PID=$!
- sleep $MG_SERVER_WAIT
- echo "[mgserver]: Started ($MG_SERVER_PID)"
- popd > /dev/null
+ pushd Server/src/Core > /dev/null
+ echo "[mgserver]: Starting (with ${MG_SERVER_WAIT}s wait)"
+ ./mgserver run > $LOG_PATH/mapguide_server_run.log 2>&1 &
+ MG_SERVER_PID=$!
+ sleep $MG_SERVER_WAIT
+ echo "[mgserver]: Started ($MG_SERVER_PID)"
+ popd > /dev/null
+ else
+ pushd $MG_INST/server/bin > /dev/null
+ echo "[mgserver]: Starting mgserver"
+ ./mgserverd.sh
+ echo "[mgserver]: Started"
+ popd
+ fi
stop_mapguide_server()
- echo "[mgserver]: Stopping"
- kill $MG_SERVER_PID
- echo "[mgserver]: Stopped ($MG_SERVER_PID)"
- MG_SERVER_PID=
+ echo "[mgserver]: Stopping"
+ kill $MG_SERVER_PID
+ echo "[mgserver]: Stopped ($MG_SERVER_PID)"
+ MG_SERVER_PID=
+ else
+ pkill -f -u root "mgserer daemon"
+ echo "[mgserver]: Stopped"
+ fi
# Build server unit test suite (regardless of whether we're running
# server tests or not)
+echo "[build]: Sheboygan sample data set"
+pushd UnitTest/TestData/Samples/Sheboygan > /dev/null
+./build.sh 2>&1 > $LOG_PATH/make_package.log
+popd > /dev/null
echo "[build]: Server unit tests"
pushd Server/src/UnitTesting > /dev/null
make libMgUnitTesting.la 2>&1 > /dev/null
@@ -121,14 +250,12 @@
rm -rf DrawingService/DrawingServiceTest.db
rm -rf ResourceService/ResourceServiceTest.db
popd > /dev/null
- if [ $USE_LOCAL_SERVER -eq 1 ]; then
- start_mapguide_server
- start_php_web_server
- fi
+ start_mapguide_server
+ start_php_web_server
pushd UnitTest > /dev/null
TEST_COMPONENT="Prepare PHP test suite"
echo "[test]: $TEST_COMPONENT"
- $PHP_CMD prepare.php
+ $PHP_CMD prepare.php 2>&1 | tee $LOG_PATH/prepare.log
check_test
popd > /dev/null
pushd UnitTest/WebTier/Php > /dev/null
@@ -141,10 +268,8 @@
$PHP_CMD RunTests.php 2>&1 | tee $LOG_PATH/php_test.log
check_test
popd > /dev/null
- stop_mapguide_server
- stop_php_web_server
- fi
+ stop_mapguide_server
+ stop_php_web_server
fi
if [ $TEST_JAVA -eq 1 ]; then
@@ -162,18 +287,14 @@
popd > /dev/null
- fi
pushd UnitTest/WebTier/Java > /dev/null
TEST_COMPONENT="Java Web Tier Tests"
ant checkunix -l $LOG_PATH/java_test_output.log
check_test
popd > /dev/null
- fi
fi
if [ -f "$LOG_PATH/unit_test_status.log" ]; then
More information about the mapguide-commits
