[mapguide-commits] r8429 - in trunk/Installer: . Support/Web/x64 Support/Web/x64/configs/Apache2/conf Support/Web/x86 Support/Web/x86/configs/Apache2/conf
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Oct 21 08:09:59 PDT 2014
Author: jng
Date: 2014-10-21 08:09:59 -0700 (Tue, 21 Oct 2014)
New Revision: 8429
Added:
   trunk/Installer/Support/Web/x64/httpd-2.4.10-x64-VC11.zip
   trunk/Installer/Support/Web/x64/php-5.5.17-x64-VC11.zip
   trunk/Installer/Support/Web/x86/httpd-2.4.10-x86-VC11.zip
   trunk/Installer/Support/Web/x86/php-5.5.17-x86-VC11.zip
Removed:
   trunk/Installer/Support/Web/x64/httpd-2.4.9-x64-VC11.zip
   trunk/Installer/Support/Web/x64/php-5.5.11-x64-VC11.zip
   trunk/Installer/Support/Web/x86/httpd-2.4.9-x86-VC11.zip
   trunk/Installer/Support/Web/x86/php-5.5.11-x86-VC11.zip
   trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf
   trunk/Installer/Support/Web/x64/mod_jk.so
   trunk/Installer/Support/Web/x86/configs/Apache2/conf/httpd.conf
   trunk/Installer/Support/Web/x86/mod_jk.so
   trunk/Installer/build.bat
RFC 147: Update binary distributions for installer. For this release, httpd somehow won't pick up libssh2.dll under current configuration (unless PHP directory is in the PATH environment variable). We fix that by pre-loading this dll in httpd.conf
Modified: trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf	2014-10-20 06:07:33 UTC (rev 8428)
+++ trunk/Installer/Support/Web/x64/configs/Apache2/conf/httpd.conf	2014-10-21 15:09:59 UTC (rev 8429)
@@ -121,6 +121,7 @@
 Listen %MG_WEB_PORT%
 LoadFile "%MG_WEB_PHP%/php5ts.dll"
+LoadFile "%MG_WEB_PHP%/libssh2.dll"
 LoadFile "%MG_WEB_PHP%/ACE.dll"
 LoadFile "%MG_WEB_PHP%/MgHttpHandler.dll"
 LoadFile "%MG_WEB_PHP%/MgFoundation.dll"
Added: trunk/Installer/Support/Web/x64/httpd-2.4.10-x64-VC11.zip
(Binary files differ)
Property changes on: trunk/Installer/Support/Web/x64/httpd-2.4.10-x64-VC11.zip
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Deleted: trunk/Installer/Support/Web/x64/httpd-2.4.9-x64-VC11.zip
Modified: trunk/Installer/Support/Web/x64/mod_jk.so
Deleted: trunk/Installer/Support/Web/x64/php-5.5.11-x64-VC11.zip
Added: trunk/Installer/Support/Web/x64/php-5.5.17-x64-VC11.zip
Property changes on: trunk/Installer/Support/Web/x64/php-5.5.17-x64-VC11.zip
Modified: trunk/Installer/Support/Web/x86/configs/Apache2/conf/httpd.conf
--- trunk/Installer/Support/Web/x86/configs/Apache2/conf/httpd.conf	2014-10-20 06:07:33 UTC (rev 8428)
+++ trunk/Installer/Support/Web/x86/configs/Apache2/conf/httpd.conf	2014-10-21 15:09:59 UTC (rev 8429)
@@ -121,6 +121,7 @@
Added: trunk/Installer/Support/Web/x86/httpd-2.4.10-x86-VC11.zip
Property changes on: trunk/Installer/Support/Web/x86/httpd-2.4.10-x86-VC11.zip
Deleted: trunk/Installer/Support/Web/x86/httpd-2.4.9-x86-VC11.zip
Modified: trunk/Installer/Support/Web/x86/mod_jk.so
Deleted: trunk/Installer/Support/Web/x86/php-5.5.11-x86-VC11.zip
Added: trunk/Installer/Support/Web/x86/php-5.5.17-x86-VC11.zip
Property changes on: trunk/Installer/Support/Web/x86/php-5.5.17-x86-VC11.zip
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat	2014-10-20 06:07:33 UTC (rev 8428)
+++ trunk/Installer/build.bat	2014-10-21 15:09:59 UTC (rev 8429)
@@ -80,9 +80,9 @@
 rem ==================================================
 rem Web dependencies
-SET HTTPD_VERSION=2.4.9
-SET PHP_VERSION=5.5.11
-SET TOMCAT_VERSION=7.0.42
+SET HTTPD_VERSION=2.4.10
+SET PHP_VERSION=5.5.17
+SET TOMCAT_VERSION=7.0.56
 SET HTTPD_PACKAGE=httpd-%HTTPD_VERSION%-%PLATFORM_CLR%-VC11.zip
 SET TOMCAT_PACKAGE_NAME=apache-tomcat-%TOMCAT_VERSION%
 SET TOMCAT_PACKAGE=%MG_OEM%\LinuxApt\%TOMCAT_PACKAGE_NAME%.tar.gz
More information about the mapguide-commits mailing list
