[mapguide-commits] r8622 - in trunk/Tools/Vagrant: . centos/src_update centos/test_x64 centos/test_x86 centos/x64 centos/x86 scripts ubuntu/test_x64 ubuntu/test_x86 ubuntu/x64 ubuntu/x86
svn_mapguide at osgeo.org
Fri Apr 10 05:02:54 PDT 2015
Author: jng
Date: 2015-04-10 05:02:54 -0700 (Fri, 10 Apr 2015)
New Revision: 8622
trunk/Tools/Vagrant/
trunk/Tools/Vagrant/build.bat
trunk/Tools/Vagrant/centos/src_update/Vagrantfile
trunk/Tools/Vagrant/centos/test_x64/Vagrantfile
trunk/Tools/Vagrant/centos/test_x64/provision.sh
trunk/Tools/Vagrant/centos/test_x86/Vagrantfile
trunk/Tools/Vagrant/centos/test_x86/provision.sh
trunk/Tools/Vagrant/centos/x64/Vagrantfile
trunk/Tools/Vagrant/centos/x86/Vagrantfile
trunk/Tools/Vagrant/make_boxes.bat
trunk/Tools/Vagrant/scripts/mginstallcentos.sh
trunk/Tools/Vagrant/scripts/mginstallubuntu.sh
trunk/Tools/Vagrant/ubuntu/test_x64/Vagrantfile
trunk/Tools/Vagrant/ubuntu/test_x64/provision.sh
trunk/Tools/Vagrant/ubuntu/test_x86/Vagrantfile
trunk/Tools/Vagrant/ubuntu/test_x86/provision.sh
trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile
trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile
trunk/Tools/Vagrant/verify.bat
Merged revision(s) 8601-8606 from branches/3.0/vagrant:
#2520: Allow easier URL component replacement by vagrant files
#2520: Set expected tarball names and build paths for 3.0
#2520: Set expected build paths for 3.0
#2520: tee and log packer output when building CentOS/Ubuntu base boxes
#2520: This submission contains the following changes:
- Fix FDO build paths for FDO 4.0
- Update smoke test vagrantfiles to allow for parameterized download host URLs, which is now specified in verify.bat
- Disable FDO and MapGuide unit tests in our main vagrantfiles. This should happen in separate vagrantfiles
This merge was manually modified to preserve the original trunk MapGuide and FDO build paths
Property changes on: trunk/Tools/Vagrant
___________________________________________________________________
Added: svn:mergeinfo
+ /branches/3.0/vagrant:8601-8606
Modified: trunk/Tools/Vagrant/build.bat
--- trunk/Tools/Vagrant/build.bat 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/build.bat 2015-04-10 12:02:54 UTC (rev 8622)
@@ -82,7 +82,8 @@
echo [build]: Generate MD5 hashes
pushd %ROOT%\builds\centos_x86
if exist md5sums.txt del md5sums.txt
-md5sum *.* | tee md5sums.txt
+md5sum *.sh > md5sums.txt
+md5sum *.tar.xz >> md5sums.txt
popd
if %TEARDOWN_CENTOS_32% == 1 (
echo [build]: Tearing down CentOS 32 VM
@@ -116,7 +117,8 @@
pushd %ROOT%\builds\ubuntu_x86
+md5sum *.deb >> md5sums.txt
popd
if %TEARDOWN_UBUNTU_32% == 1 (
echo [build]: Tearing down Ubuntu 32 VM
@@ -150,7 +152,8 @@
pushd %ROOT%\builds\centos_x64
popd
if %TEARDOWN_CENTOS_64% == 1 (
echo [build]: Tearing down CentOS 64 VM
@@ -184,7 +187,8 @@
pushd %ROOT%\builds\ubuntu_x64
popd
if %TEARDOWN_UBUNTU_64% == 1 (
echo [build]: Tearing down Ubuntu 64 VM
Modified: trunk/Tools/Vagrant/centos/src_update/Vagrantfile
--- trunk/Tools/Vagrant/centos/src_update/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/centos/src_update/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -140,12 +140,12 @@
FDO_VER_FULL=${FDO_VER_MM}.0
MG_VER_MM=3.0
MG_VER_FULL=${MG_VER_MM}.0
-FDO_SRC_DIR=trunk
+FDO_SRC_DIR=4.0
FDO_SRC=$FDO_SRC_ROOT/$FDO_SRC_DIR
-MG_SRC_ROOT=~/mapguide/trunk
+MG_SRC_ROOT=~/mapguide/branches/3.0
MG_SRC=$MG_SRC_ROOT/MgDev
-FDO_TARBALL=fdo-checkout.tar.gz
-MG_TARBALL=mapguide-checkout.tar.gz
+FDO_TARBALL=fdo-checkout-4.0.tar.gz
+MG_TARBALL=mapguide-checkout-3.0.tar.gz
FDO_INST_PATH=/usr/local/fdo-${FDO_VER_FULL}
MG_INST_PATH=/usr/local/mapguideopensource-${MG_VER_FULL}
if [ -d $FDO_SRC ];
Modified: trunk/Tools/Vagrant/centos/test_x64/Vagrantfile
--- trunk/Tools/Vagrant/centos/test_x64/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/centos/test_x64/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -119,5 +119,5 @@
config.vm.provision "shell",
privileged: false,
path: "provision.sh",
- args: "#{ENV['DOWNLOAD_HOST']}"
+ args: ["#{ENV['DOWNLOAD_HOST']}", "#{ENV['MG_DIST_DIR']}"]
end
Modified: trunk/Tools/Vagrant/centos/test_x64/provision.sh
--- trunk/Tools/Vagrant/centos/test_x64/provision.sh 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/centos/test_x64/provision.sh 2015-04-10 12:02:54 UTC (rev 8622)
@@ -1,13 +1,14 @@
#!/bin/bash
DOWNLOAD_HOST=$1
+URI_PART=$2
+DIST_DIR="centos_x64"
sudo yum install -y wget
echo Download host is: $DOWNLOAD_HOST
-wget "http://$DOWNLOAD_HOST/builds/Sheboygan.mgp"
-wget "http://$DOWNLOAD_HOST/builds/smoke_test.sh"
+wget "http://$DOWNLOAD_HOST/$URI_PART/Sheboygan.mgp"
+wget "http://$DOWNLOAD_HOST/$URI_PART/smoke_test.sh"
sudo mv Sheboygan.mgp /tmp/
-wget "http://$DOWNLOAD_HOST/builds/centos_x64/mginstallcentos.sh"
-sed -i 's/URL="http:\/\/download/URL_OLD="http:\/\/download/g' mginstallcentos.sh
-sed -i 's/#URL="http:\/\/192.168.0.4\/downloads"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/builds\/centos_x64"/g' mginstallcentos.sh
+wget "http://$DOWNLOAD_HOST/$URI_PART/$DIST_DIR/mginstallcentos.sh"
+sed -i 's/URL="$URL_ROOT\/$URL_PART"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/'"$URI_PART"'\/'"$DIST_DIR"'"/g' mginstallcentos.sh
chmod +x smoke_test.sh
chmod +x mginstallcentos.sh
sudo -E ./mginstallcentos.sh
Modified: trunk/Tools/Vagrant/centos/test_x86/Vagrantfile
--- trunk/Tools/Vagrant/centos/test_x86/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/centos/test_x86/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -119,5 +119,5 @@
privileged: false,
end
Modified: trunk/Tools/Vagrant/centos/test_x86/provision.sh
--- trunk/Tools/Vagrant/centos/test_x86/provision.sh 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/centos/test_x86/provision.sh 2015-04-10 12:02:54 UTC (rev 8622)
@@ -1,13 +1,14 @@
#!/bin/bash
DOWNLOAD_HOST=$1
+URI_PART=$2
+DIST_DIR="centos_x86"
-wget "http://$DOWNLOAD_HOST/builds/centos_x86/mginstallcentos.sh"
-sed -i 's/#URL="http:\/\/192.168.0.4\/downloads"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/builds\/centos_x86"/g' mginstallcentos.sh
Modified: trunk/Tools/Vagrant/centos/x64/Vagrantfile
--- trunk/Tools/Vagrant/centos/x64/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/centos/x64/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -147,8 +147,8 @@
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
-MG_UNIT_TEST=1
-FDO_UNIT_TEST=1
+MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
MAKE_FDO_SDK=0
SCRIPT_ROOT=~/scripts
FDO_SRC_ROOT=~/fdo
@@ -331,6 +331,7 @@
echo [provision]: Copy install/uninstall scripts to output dir
sudo cp /vagrant/mginstallcentos.sh /vagrant/build/mginstallcentos.sh
sudo cp /vagrant/mguninstallcentos.sh /vagrant/build/mguninstallcentos.sh
+sudo sed -i 's/URL_PART="centos"/URL_PART="centos_x64"/g' /vagrant/build/mginstallcentos.sh
sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' /vagrant/build/mginstallcentos.sh
sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' /vagrant/build/mginstallcentos.sh
sudo sed -i 's/FDO_ARCH=i386/FDO_ARCH=amd64/g' /vagrant/build/mginstallcentos.sh
Modified: trunk/Tools/Vagrant/centos/x86/Vagrantfile
--- trunk/Tools/Vagrant/centos/x86/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/centos/x86/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -147,8 +147,8 @@
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
-MG_UNIT_TEST=1
-FDO_UNIT_TEST=1
+MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
MAKE_FDO_SDK=0
FDO_SRC_ROOT=~/fdo
@@ -331,6 +331,7 @@
sudo mv ~/fdo_*_unit_test.log /vagrant/build
sudo mv ~/UnitTestResults_*.xml /vagrant/build
+sudo sed -i 's/URL_PART="centos"/URL_PART="centos_x86"/g' /vagrant/build/mginstallcentos.sh
Modified: trunk/Tools/Vagrant/make_boxes.bat
--- trunk/Tools/Vagrant/make_boxes.bat 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/make_boxes.bat 2015-04-10 12:02:54 UTC (rev 8622)
@@ -6,28 +6,28 @@
pushd packer
if "%BUILD_CENTOS_64%" == "1" (
echo [packer]: Build CentOS 64-bit base box
-packer build -force centos6-amd64.json
+packer build -force centos6-amd64.json | tee packer_centos64.log
echo [vagrant]: Export centos6-amd64 base box
rem call vagrant package --base "centos6-amd64" --output centos6-amd64.box
call vagrant box add "centos6-amd64" centos6-amd64.box --force
if "%BUILD_CENTOS_32%" == "1" (
echo [packer]: Build CentOS 32-bit base box
-packer build -force centos6-i386.json
+packer build -force centos6-i386.json | tee packer_centos32.log
echo [vagrant]: Export centos6-i386 base box
rem call vagrant package --base "centos6-i386" --output centos6-i386.box
call vagrant box add "centos6-i386" centos6-i386.box --force
if "%BUILD_UBUNTU_64%" == "1" (
echo [packer]: Build Ubuntu 64-bit base box
-packer build -force ubuntu12-amd64.json
+packer build -force ubuntu12-amd64.json | tee packer_ubuntu64.log
echo [vagrant]: Export ubuntu12-amd64 base box
rem call vagrant package --base "ubuntu12-amd64" --output ubuntu12-amd64.box
call vagrant box add "ubuntu12-amd64" ubuntu12-amd64.box --force
if "%BUILD_UBUNTU_32%" == "1" (
echo [packer]: Build Ubuntu 32-bit base box
-packer build -force ubuntu12-i386.json
+packer build -force ubuntu12-i386.json | tee packer_ubuntu32.log
echo [vagrant]: Export ubuntu12-i386 base box
rem call vagrant package --base "ubuntu12-i386" --output ubuntu12-i386.box
call vagrant box add "ubuntu12-i386" ubuntu12-i386.box --force
Modified: trunk/Tools/Vagrant/scripts/mginstallcentos.sh
--- trunk/Tools/Vagrant/scripts/mginstallcentos.sh 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/scripts/mginstallcentos.sh 2015-04-10 12:02:54 UTC (rev 8622)
@@ -1,5 +1,7 @@
#!/bin/bash
-URL="http://download.osgeo.org/mapguide/releases/3.0.0/Release"
+URL_ROOT="http://download.osgeo.org/mapguide/releases/3.0.0/Beta2"
+URL_PART="centos"
+URL="$URL_ROOT/$URL_PART"
#URL="http://192.168.0.4/downloads"
FDOVER_MAJOR_MINOR=4.0
FDOVER_POINT=0
Modified: trunk/Tools/Vagrant/scripts/mginstallubuntu.sh
--- trunk/Tools/Vagrant/scripts/mginstallubuntu.sh 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/scripts/mginstallubuntu.sh 2015-04-10 12:02:54 UTC (rev 8622)
@@ -1,6 +1,8 @@
#!/bin/bash
TEMPDIR=/tmp/build_mapguide
-URL="http://download.osgeo.org/mapguide/releases/3.0.0/Release/ubuntu12"
+URL_PART="ubuntu12"
#URL="http://192.168.0.5/downloads/ubuntu12"
FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.0
Modified: trunk/Tools/Vagrant/ubuntu/test_x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/test_x64/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/ubuntu/test_x64/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -119,5 +119,5 @@
privileged: false,
end
Modified: trunk/Tools/Vagrant/ubuntu/test_x64/provision.sh
--- trunk/Tools/Vagrant/ubuntu/test_x64/provision.sh 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/ubuntu/test_x64/provision.sh 2015-04-10 12:02:54 UTC (rev 8622)
@@ -1,12 +1,13 @@
#!/bin/bash
DOWNLOAD_HOST=$1
+URI_PART=$2
+DIST_DIR="ubuntu_x64"
-wget "http://$DOWNLOAD_HOST/builds/ubuntu_x64/mginstallubuntu.sh"
-sed -i 's/URL="http:\/\/download/URL_OLD="http:\/\/download/g' mginstallubuntu.sh
-sed -i 's/#URL="http:\/\/192.168.0.5\/downloads\/ubuntu12"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/builds\/ubuntu_x64"/g' mginstallubuntu.sh
+wget "http://$DOWNLOAD_HOST/$URI_PART/$DIST_DIR/mginstallubuntu.sh"
+sed -i 's/URL="$URL_ROOT\/$URL_PART"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/'"$URI_PART"'\/'"$DIST_DIR"'"/g' mginstallubuntu.sh
chmod +x mginstallubuntu.sh
sudo ./mginstallubuntu.sh --headless --with-sdf --with-shp --with-ogr --with-gdal --with-sqlite
Modified: trunk/Tools/Vagrant/ubuntu/test_x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/test_x86/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/ubuntu/test_x86/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -119,5 +119,5 @@
privileged: false,
end
Modified: trunk/Tools/Vagrant/ubuntu/test_x86/provision.sh
--- trunk/Tools/Vagrant/ubuntu/test_x86/provision.sh 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/ubuntu/test_x86/provision.sh 2015-04-10 12:02:54 UTC (rev 8622)
@@ -1,12 +1,13 @@
#!/bin/bash
DOWNLOAD_HOST=$1
+URI_PART=$2
+DIST_DIR="ubuntu_x86"
-wget "http://$DOWNLOAD_HOST/builds/ubuntu_x86/mginstallubuntu.sh"
-sed -i 's/#URL="http:\/\/192.168.0.5\/downloads\/ubuntu12"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/builds\/ubuntu_x86"/g' mginstallubuntu.sh
Modified: trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -140,8 +140,8 @@
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
-MG_UNIT_TEST=1
-FDO_UNIT_TEST=1
+MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
FDO_SRC_ROOT=~/fdo
FDO_VER_MM=4.0
@@ -363,6 +363,7 @@
sudo cp ~/UnitTestResults_*.xml /vagrant/build
sudo cp /vagrant/mginstallubuntu.sh /vagrant/build/mginstallubuntu.sh
sudo cp /vagrant/mguninstallubuntu.sh /vagrant/build/mguninstallubuntu.sh
+sudo sed -i 's/URL_PART="ubuntu12"/URL_PART="ubuntu12_x64"/g' /vagrant/build/mginstallubuntu.sh
sudo sed -i 's/FDOBUILD=0/FDOBUILD='"$FDO_REV"'/g' /vagrant/build/mginstallubuntu.sh
sudo sed -i 's/MGBUILD=0/MGBUILD='"$MG_REV"'/g' /vagrant/build/mginstallubuntu.sh
sudo sed -i 's/FDOARCH=i386/FDOARCH=amd64/g' /vagrant/build/mginstallubuntu.sh
Modified: trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile 2015-04-10 12:02:54 UTC (rev 8622)
@@ -140,8 +140,8 @@
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
-MG_UNIT_TEST=1
-FDO_UNIT_TEST=1
+MG_UNIT_TEST=0
+FDO_UNIT_TEST=0
FDO_SRC_ROOT=~/fdo
FDO_VER_MM=4.0
@@ -360,6 +360,7 @@
fi
sudo cp bin/*.deb /vagrant/build
+sudo sed -i 's/URL_PART="ubuntu12"/URL_PART="ubuntu12_x86"/g' /vagrant/build/mginstallubuntu.sh
Modified: trunk/Tools/Vagrant/verify.bat
--- trunk/Tools/Vagrant/verify.bat 2015-04-09 00:11:14 UTC (rev 8621)
+++ trunk/Tools/Vagrant/verify.bat 2015-04-10 12:02:54 UTC (rev 8622)
@@ -14,12 +14,15 @@
rem Requires the sed utility, which is part of GNU on Windows (https://github.com/bmatzelle/gow)
IF "%DOWNLOAD_HOST%"=="" SET DOWNLOAD_HOST=192.168.0.6
+IF "%MG_DIST_DIR%"=="" SET MG_DIST_DIR=builds
IF "%VERIFY_UBUNTU_32%"=="" SET VERIFY_UBUNTU_32=1
IF "%VERIFY_UBUNTU_64%"=="" SET VERIFY_UBUNTU_64=1
IF "%VERIFY_CENTOS_32%"=="" SET VERIFY_CENTOS_32=1
IF "%VERIFY_CENTOS_64%"=="" SET VERIFY_CENTOS_64=1
echo **************** Verify Summary *********************
+echo Download Host is: %DOWNLOAD_HOST%
+echo Dist directory name: %MG_DIST_DIR%
echo Verifying Ubuntu (32-bit): %VERIFY_UBUNTU_32%
echo Verifying Ubuntu (64-bit): %VERIFY_UBUNTU_64%
echo Verifying CentOS (32-bit): %VERIFY_CENTOS_32%
More information about the mapguide-commits
