[mapguide-commits] r8859 - in sandbox/jng/webtier-vs2015/Oem/SWIGEx: . Lib Lib/php7 Source/Modules Win32
svn_mapguide at osgeo.org
Tue Dec 8 04:09:33 PST 2015
Author: jng
Date: 2015-12-08 04:09:33 -0800 (Tue, 08 Dec 2015)
New Revision: 8859
Added:
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7.swg
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7kw.swg
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7run.swg
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/precommon.swg
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_common.i
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_map.i
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_pair.i
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_string.i
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_vector.i
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/typemaps.i
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/utils.i
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Source/Modules/php7.cxx
sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.vcxproj
sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.vcxproj.filters
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Makefile
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Source/Modules/swigmain.cxx
sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.sln
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Win32/
sandbox/jng/webtier-vs2015/Oem/SWIGEx/Win32/Swig.exe
First attempt at PHP7 support. This is currently just a verbatim copy of the PHP5 module.
Property changes on: sandbox/jng/webtier-vs2015/Oem/SWIGEx
___________________________________________________________________
Added: svn:ignore
+ .vs
SwigEx.sdf
SwigEx.VC.opendb
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7.swg
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7.swg (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7.swg 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,503 @@
+ * php7.swg
+ * PHP 7 configuration file
+%runtime "precommon.swg"
+%runtime "common.swg" // common type checking code
+%runtime "php7run.swg" // Php7 runtime functions
+%include "utils.i" // building blocks
+/* Typemaps for input parameters by value */
+%typemap(in) int, unsigned int, unsigned short, short, unsigned short, long, unsigned long, signed char, unsigned char, enum SWIGTYPE %{
+ aw_convert_to_long($input);
+ $1 = ($1_ltype) Z_LVAL_PP($input);
+%typemap(in) bool %{
+ convert_to_boolean_ex($input);
+%typemap(in) char %{
+ convert_to_string_ex($input);
+ $1 = ($1_ltype) *Z_STRVAL_PP($input);
+%typemap(in) float,double %{
+ aw_convert_to_double($input);
+ $1 = ($1_ltype) Z_DVAL_PP($input);
+// char * is input only normally
+%typemap(in) char * %{
+ $1 = ($1_ltype) Z_STRVAL_PP($input);
+// char array can be in/out, though the passed string may not be big enough...
+// so we have to size it
+strarray_inout(char [ANY])
+%typemap(in) SWIGTYPE *, SWIGTYPE [], SWIGTYPE & %{
+ if(SWIG_ConvertPtr(*$input, (void **) &$1, $1_descriptor) < 0) {
+ zend_error(E_ERROR, "Type error in argument %d of $symname. Expected %s", $argnum-argbase, $1_descriptor->name);
+%typemap(in) void * %{
+ if(SWIG_ConvertPtr(*$input, (void **) &$1, 0) < 0) {
+ /* Allow NULL from php for void* */
+ if ((*$input)->type==IS_NULL) $1=0;
+ else zend_error(E_ERROR, "Type error in argument %d of $symname. Expected %s", $argnum-argbase, $1_descriptor->name);
+/* Special case when void* is passed by reference so it can be made to point
+ to opaque api structs */
+%typemap(in) void ** ($*1_ltype ptr, int force), void *& ($*1_ltype ptr, int force) %{
+ /* If they pass NULL by reference, make it into a void*
+ This bit should go in arginit if arginit support init-ing scripting args */
+ /* So... we didn't get a ref or ptr, but we'll accept NULL by reference */
+ if ((*$input)->type==IS_NULL && PZVAL_IS_REF(*$input)) {
+#if __cplusplus
+ ptr=new $*1_ltype;
+#else
+ ptr=($*1_ltype) calloc(1,sizeof($*1_ltype));
+#endif
+ $1=&ptr;
+ /* have to passback arg$arg too */
+ force=1;
+ } else { /* wasn't a pre/ref/thing, OR anything like an int thing */
+ force=0;
+ zend_error(E_ERROR, "Type error in argument %d of $symname. Expected %s or %s or at least NULL passed by reference", $argnum-argbase, $1_descriptor->name,$*1_descriptor->name);
+ } else force=0;
+%typemap(argout) void **, void *& %{
+ if (force$argnum) { /* pass back arg$argnum through params ($arg) if we can */
+ if(! PZVAL_IS_REF(*$arg)) {
+ zend_error(E_WARNING, "Parameter %d of $symname wasn't passed by reference: [argout void**, void*&]",$argnum-argbase);
+ } else {
+ SWIG_SetPointerZval(*$arg, (void *) ptr$argnum, $*1_descriptor, 1);
+/* Object passed by value. Convert to a pointer */
+%typemap(in) SWIGTYPE {
+ $&1_ltype argp;
+ if(SWIG_ConvertPtr(*$input, (void **) &argp, $&1_descriptor) < 0) {
+ zend_error(E_ERROR, "Type error in argument %d of $symname. Expected %s", $argnum-argbase, $&1_descriptor->name);
+ $1 = *argp;
+/* Typemap for output values */
+%typemap(out) int, unsigned int, short, unsigned short, long, unsigned long, signed char, unsigned char, bool, enum SWIGTYPE %{
+ ZVAL_LONG(return_value,$1);
+%typemap(out) bool %{
+ ZVAL_BOOL(return_value,($1)?1:0);
+%typemap(out) float, double %{
+ ZVAL_DOUBLE(return_value,$1);
+%typemap(out) char %{
+ // out char
+ ZVAL_STRINGL(return_value,$1, 1, 1);
+%typemap(out) char * %{
+ ZVAL_STRING(return_value,$1, 1);
+%typemap(out) SWIGTYPE *, SWIGTYPE [], SWIGTYPE & %{
+ SWIG_SetPointerZval(return_value, (void *)$1, $1_descriptor, $owner);
+%typemap(out) SWIGTYPE *DYNAMIC, SWIGTYPE &DYNAMIC {
+ swig_type_info *ty = SWIG_TypeDynamicCast($1_descriptor, (void **) &$1);
+ SWIG_SetPointerZval(return_value, (void *)$1, ty, $owner);
+#ifdef __cplusplus
+ $&1_ltype resultobj = new $1_ltype(($1_ltype &) $1);
+ SWIG_SetPointerZval(return_value, (void *)resultobj, $&1_descriptor, $owner);
+#else
+ $&1_ltype resultobj = ($&1_ltype) emalloc(sizeof($1_type));
+ memmove(resultobj, &$1, sizeof($1_type));
+#endif
+%typemap(out) void "";
+/* Typemap for character array returns */
+%typemap(out) char [ANY] {
+ // out char any
+ ZVAL_STRINGL(return_value,$1, $1_dim0, 1);
+/* Typemap for in/argout references
+ NOTE: we don't choose to use these for arrays yet, maybe later */
+%typemap_inout_ord(bool,convert_to_bool_ex,ZVAL_BOOL)
+%typemap_inout_ord(int,convert_to_long_ex,ZVAL_LONG)
+%typemap_inout_ord(unsigned int,convert_to_long_ex,ZVAL_LONG)
+%typemap_inout_ord(short,convert_to_long_ex,ZVAL_LONG)
+%typemap_inout_ord(unsigned short,convert_to_long_ex,ZVAL_LONG)
+%typemap_inout_ord(long,convert_to_long_ex,ZVAL_LONG)
+%typemap_inout_ord(unsigned long,convert_to_long_ex,ZVAL_LONG)
+%typemap_inout_ord(signed char,convert_to_long_ex,ZVAL_LONG)
+%typemap_inout_ord(unsigned char,convert_to_long_ex,ZVAL_LONG)
+%typemap_inout_ord(enum SWIGTYPE,convert_to_long_ex,ZVAL_LONG)
+/* Global variables - add the variable to PHP */
+%typemap(varinit) char *
+ zval *z_var;
+ MAKE_STD_ZVAL(z_var);
+ z_var->type = IS_STRING;
+ if($1) {
+ z_var->value.str.val = estrdup($1);
+ z_var->value.str.len = strlen($1);
+ } else {
+ z_var->value.str.val = 0;
+ z_var->value.str.len = 0;
+ zend_hash_add(&EG(symbol_table), "$1", strlen("$1")+1, (void *)&z_var, sizeof(zval *), NULL);
+%typemap(varinit) int, unsigned int, unsigned short, short, unsigned short, long, unsigned long, signed char, unsigned char, bool, enum SWIGTYPE
+ zval *z_var;
+ z_var->type = IS_LONG;
+ z_var->value.lval = $1;
+%typemap(varinit) bool
+ zval *z_var;
+ z_var->type = IS_BOOL;
+ z_var->value.lval = ($1)?1:0;
+%typemap(varinit) float, double
+ zval *z_var;
+ z_var->type = IS_DOUBLE;
+ z_var->value.dval = $1;
+ sizeof(zval *), NULL);
+ zval *z_var;
+ char c[2];
+ c[0] = $1;
+ c[1] = 0;
+ z_var->value.str.val = estrdup(c);
+ z_var->value.str.len = 2;
+%typemap(varinit) SWIGTYPE *, SWIGTYPE &, SWIGTYPE []
+ zval *z_var;
+ SWIG_SetPointerZval(z_var, (void*)$1, $1_descriptor, $owner);
+ $&1_ltype argp;
+ zval *z_var;
+ SWIG_SetPointerZval(z_var, (void*)&$1, $&1_descriptor, $owner);
+ zend_hash_add(&EG(symbol_table), "$1", strlen("$1")+1, (void*)&z_var,
+%typemap(varinit) char [ANY]
+ zval *z_var;
+ if($1) {
+ // varinit char [ANY]
+ ZVAL_STRINGL(z_var,$1, $1_dim0, 1);
+%typemap(varin) int, unsigned int, unsigned short, short, unsigned short, long, unsigned long, signed char, unsigned char, enum SWIGTYPE
+ zval **z_var;
+ zend_hash_find(&EG(symbol_table), "$1",strlen("$1")+1, (void**)&z_var);
+ convert_to_long_ex(z_var);
+ if($1 != ($1_ltype)((*z_var)->value.lval)) {
+ $1 = Z_LVAL_PP(z_var);
+%typemap(varin) bool
+ zval **z_var;
+ convert_to_boolean_ex(z_var);
+%typemap(varin) double,float
+ zval **z_var;
+ zend_hash_find(&EG(symbol_table), "$1", strlen("$1")+1, (void**)&z_var);
+ convert_to_double_ex(z_var);
+ if($1 != ($1_ltype)((*z_var)->value.dval)) {
+ $1 = Z_DVAL_PP(z_var);
+%typemap(varin) char
+ zval **z_var;
+ convert_to_string_ex(z_var);
+ if($1 != *((*z_var)->value.str.val)) {
+ $1 = *((*z_var)->value.str.val);
+%typemap(varin) char *
+ zval **z_var;
+ char *s1;
+ s1 = Z_STRVAL_PP(z_var);
+ if((s1 == NULL) || ($1 == NULL) || zend_binary_strcmp(s1, strlen(s1), $1, strlen($1))) {
+ if(s1)
+ $1 = estrdup(s1);
+ else
+ $1 = NULL;
+%typemap(varin) SWIGTYPE []
+ zval **z_var;
+ if($1) {
+ SWIG_SetPointerZval(*z_var, (void*)$1, $1_descriptor, $owner);
+%typemap(varin) char [ANY]
+ zval **z_var;
+ char *s1;
+ if(s1)
+ strncpy($1, s1, $1_dim0);
+ zval **z_var;
+ $&1_ltype _temp;
+ if (SWIG_ConvertPtr(*z_var, (void**)&_temp, $&1_descriptor) < 0) {
+ zend_error(E_ERROR, "Type error in value of $symname. Expected %s", $&1_descriptor->name);
+ $1 = *($&1_ltype)_temp;
+%typemap(varin) SWIGTYPE *, SWIGTYPE &
+ zval **z_var;
+ $1_ltype _temp;
+ if (SWIG_ConvertPtr(*z_var, (void **)&_temp, $1_descriptor) < 0) {
+ zend_error(E_ERROR, "Type error in value of $symname. Expected %s", $1_descriptor->name);
+ $1 = ($1_ltype)_temp;
+%typemap(varout) int, unsigned int, unsigned short, short, unsigned short, long, unsigned long, signed char, unsigned char, enum SWIGTYPE
+ zval **z_var;
+ (*z_var)->value.lval = (long)$1;
+//SAMFIX need to cast zval->type, what if zend-hash_find fails? etc?
+%typemap(varout) bool
+ zval **z_var;
+%typemap(varout) double, float
+ zval **z_var;
+ (*z_var)->value.dval = (double)$1;
+%typemap(varout) char
+ zval **z_var;
+ char c[2];
+ efree((*z_var)->value.str.val);
+ c[0] = $1;
+ c[1] = 0;
+ (*z_var)->value.str.val = estrdup(c);
+%typemap(varout) char *
+ zval **z_var;
+ char *s1;
+ if((s1 == NULL) || ($1 == NULL) || zend_binary_strcmp(s1, strlen(s1), $1, strlen($1) )) {
+ if(s1)
+ efree(s1);
+ if($1) {
+ (*z_var)->value.str.val = estrdup($1);
+ (*z_var)->value.str.len = strlen($1) +1;
+ } else {
+ (*z_var)->value.str.val = 0;
+ (*z_var)->value.str.len = 0;
+%typemap(varout) SWIGTYPE
+ zval **z_var;
+ SWIG_SetPointerZval(*z_var, (void*)&$1, $&1_descriptor, $owner);
+%typemap(varout) SWIGTYPE []
+ zval **z_var;
+ if($1)
+%typemap(varout) char [ANY]
+ zval **z_var;
+ char *s1;
+deliberate error cos this code looks bogus to me
+ zend_hash_find(&EG(symbol_table), "$1" ,strlen("$1")+1, (void**)&z_var);
+ if((s1 == NULL) || zend_binary_strcmp(s1, strlen(s1), $1, strlen($1))) {
+ if($1) {
+ (*z_var)->value.str.len = strlen($1)+1;
+ } else {
+%typemap(varout) SWIGTYPE *, SWIGTYPE &
+ zval **z_var;
+/* Typemaps for constants */
+%typemap(consttab) int, unsigned int, short, unsigned short, long, unsigned long, unsigned char, signed char, bool, enum SWIGTYPE
+ "REGISTER_LONG_CONSTANT( \"$symname\", $value, CONST_CS | CONST_PERSISTENT);";
+%typemap(consttab) float, double
+ "REGISTER_DOUBLE_CONSTANT(\"$symname\", $value, CONST_CS | CONST_PERSISTENT);";
+%typemap(consttab) char, char *
+ "REGISTER_STRING_CONSTANT(\"$symname\", \"$value\", CONST_CS | CONST_PERSISTENT);";
+%typemap(consttab) SWIGTYPE *, SWIGTYPE &, SWIGTYPE [] {
+ char *cp;
+ SWIG_SetPointerChar(&cp, (void*)$value, $1_descriptor);
+ REGISTER_STRING_CONSTANT("$symname", cp, CONST_CS | CONST_PERSISTENT);
+/* Some ANSI C typemaps */
+%apply long { size_t };
+/* php kewords */
+/* please test and activate */
+//%include "phpkw.swg"
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7kw.swg
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7kw.swg (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7kw.swg 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,92 @@
+#ifndef __php_phpkw_swg__
+#define __php_phpkw_swg__
+/* Warnings for Php keywords */
+#define PHPKW(x) %namewarn("314:" #x " is a php keyword") #x
+ from
+ http://aspn.activestate.com/ASPN/docs/PHP/reserved.html
+PHPKW(and);
+PHPKW($argc);
+PHPKW($argv);
+PHPKW(as);
+PHPKW(break);
+PHPKW(case);
+PHPKW(cfunction);
+PHPKW(class);
+PHPKW(continue);
+PHPKW(declare);
+PHPKW(default);
+PHPKW(die);
+PHPKW(do);
+PHPKW(E_ALL);
+PHPKW(echo);
+PHPKW(E_ERROR);
+PHPKW(else);
+PHPKW(elseif);
+PHPKW(enddeclare);
+PHPKW(endfor);
+PHPKW(endforeach);
+PHPKW(endif);
+PHPKW(endswitch);
+PHPKW(endwhile);
+PHPKW(E_PARSE);
+PHPKW(eval);
+PHPKW(E_WARNING);
+PHPKW(exit);
+PHPKW(extends);
+PHPKW(FALSE);
+PHPKW(__FILE__);
+PHPKW(for);
+PHPKW(foreach);
+PHPKW(function);
+PHPKW(global);
+PHPKW($HTTP_COOKIE_VARS);
+PHPKW($HTTP_ENV_VARS);
+PHPKW($HTTP_GET_VARS);
+PHPKW($HTTP_POST_FILES);
+PHPKW($HTTP_POST_VARS);
+PHPKW($HTTP_SERVER_VARS);
+PHPKW(if);
+PHPKW(include);
+PHPKW(include_once);
+PHPKW(__LINE__);
+PHPKW(list);
+PHPKW(new);
+PHPKW(not);
+PHPKW(NULL);
+PHPKW(old_function);
+PHPKW(or);
+PHPKW(parent);
+PHPKW(PHP_OS);
+PHPKW($PHP_SELF);
+PHPKW(PHP_VERSION);
+PHPKW(print);
+PHPKW(require);
+PHPKW(require_once);
+PHPKW(return);
+PHPKW(__sleep);
+PHPKW(static);
+PHPKW(stdClass);
+PHPKW(switch);
+PHPKW($this);
+PHPKW(TRUE);
+PHPKW(var);
+PHPKW(virtual);
+PHPKW(__wakeup);
+PHPKW(while);
+PHPKW(xor);
+// This is conflicting with _std_deque.i!.
+PHPKW(empty);
+#undef PHPKW
+#endif //__php_phpkw_swg__
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7run.swg
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7run.swg (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/php7run.swg 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,288 @@
+ * php7.swg
+ * PHP7 runtime library
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "zend.h"
+#include "zend_API.h"
+#include "php.h"
+#include "zend_exceptions.h"
+#ifdef _WIN32
+#include <typeinfo.h>
+#else
+#include <typeinfo>
+#endif
+/* These TSRMLS_ stuff should already be defined now, but with older php under
+ redhat are not... */
+#ifndef TSRMLS_D
+#define TSRMLS_D
+#endif
+#ifndef TSRMLS_DC
+#define TSRMLS_DC
+#endif
+#ifndef TSRMLS_C
+#define TSRMLS_C
+#endif
+#ifndef TSRMLS_CC
+#define TSRMLS_CC
+#endif
+#ifdef __cplusplus
+#endif
+/* used to wrap returned objects in so we know whether they are newobject
+ and need freeing, or not */
+typedef struct _swig_object_wrapper {
+ void * ptr;
+ int newobject;
+} swig_object_wrapper;
+/* local scope self_constructors are set to 1 inside function wrappers
+ which are also class constructors, so that the php7.swg output typemaps
+ know whether or not to wrap returned objects in this_ptr or a new object */
+int self_constructor=0;
+/* empty zend destructor for types without one */
+static ZEND_RSRC_DTOR_FUNC(SWIG_landfill) {};
+/* This one makes old swig style string pointers but the php module doesn't
+ use these any more. This is just left here for old times sake and may go */
+SWIGRUNTIME(void)
+SWIG_MakePtr(char *c, void *ptr, swig_type_info *ty) {
+ static char hex[17] = "0123456789abcdef";
+ unsigned long p, s;
+ char data[32], *r;
+ r = data;
+ p = (unsigned long) ptr;
+ if (p > 0) {
+ while (p > 0) {
+ s = p & 0xf;
+ *(r++) = hex[s];
+ p = p >> 4;
+ *r = '_';
+ while (r >= data) {
+ *(c++) = *(r--);
+ strcpy (c, ty->name);
+ } else {
+ strcpy (c, "NULL");
+SWIGRUNTIME(void)
+SWIG_SetPointerChar(char **c, void *ptr, swig_type_info *type) {
+ char data[512];
+ SWIG_MakePtr(data, ptr, type);
+ *c = estrdup(data);
+#define SWIG_SetPointerZval(a,b,c,d) SWIG_ZTS_SetPointerZval(a,b,c,d, SWIG_module_entry TSRMLS_CC)
+SWIGRUNTIME(void)
+SWIG_ZTS_SetPointerZval(zval *z, void *ptr, swig_type_info *type, int newobject, zend_module_entry* module_entry TSRMLS_DC) {
+ swig_object_wrapper *value=NULL;
+ /* No need to call SWIG_MakePtr here! */
+ if (type->clientdata) {
+ if (! (*(int *)(type->clientdata))) zend_error(E_ERROR, "Type: %s failed to register with zend",type->name);
+ value=(swig_object_wrapper *)emalloc(sizeof(swig_object_wrapper));
+ value->ptr=ptr;
+ value->newobject=newobject;
+ ZEND_REGISTER_RESOURCE(z, value, *(int *)(type->clientdata));
+ return;
+ } else { /* have to deal with old fashioned string pointer?
+ but this should not get this far */
+ zend_error(E_ERROR, "Type: %s not registered with zend",type->name);
+/* This old-style routine converts an old string-pointer c into a real pointer
+ ptr calling making appropriate casting functions according to ty
+ We don't use this any more */
+SWIGRUNTIME(int)
+SWIG_ConvertPtr_(char *c, void **ptr, swig_type_info *ty) {
+ register int d;
+ unsigned long p;
+ swig_type_info *tc;
+ if(c == NULL) {
+ *ptr = 0;
+ return 0;
+ p = 0;
+ if (*c != '_') {
+ *ptr = (void *) 0;
+ if (strcmp(c,"NULL") == 0) {
+ return 0;
+ } else {
+ goto type_error;
+ c++;
+ /* Extract hex value from pointer */
+ while ((d = *c)) {
+ if ((d >= '0') && (d <= '9'))
+ p = (p << 4) + (d - '0');
+ else if ((d >= 'a') && (d <= 'f'))
+ p = (p << 4) + (d - ('a'-10));
+ else
+ break;
+ c++;
+ *ptr = (void *) p;
+ if(ty) {
+ tc = SWIG_TypeCheck(c,ty);
+ if(!tc) goto type_error;
+ *ptr = SWIG_TypeCast(tc, (void*)p);
+ return 0;
+type_error:
+ return -1;
+/* This is a new pointer conversion routine
+ Taking the native pointer p (which would have been converted from the old
+ string pointer) and it's php type id, and it's type name (which also would
+ have come from the old string pointer) it converts it to ptr calling
+ appropriate casting functions according to ty
+ Sadly PHP has no API to find a type name from a type id, only from an instance
+ of a resource of the type id, so we have to pass type_name as well.
+ The two functions which might call this are:
+ SWIG_ZTS_ConvertResourcePtr which gets the type name from the resource
+ and the registered zend destructors for which we have one per type each
+ with the type name hard wired in. */
+SWIGRUNTIME(int)
+SWIG_ZTS_ConvertResourceData(void * p, int type, const char *type_name, void **ptr, swig_type_info *ty TSRMLS_DC) {
+ if (ty) {
+ if (! type_name) {
+ /* can't convert p to ptr type ty if we don't know what type p is */
+ return -1;
+ } else {
+ /* convert and cast p from type_name to ptr as ty
+ Need to sort out const-ness, can SWIG_TypeCast really not take a const? */
+ tc = SWIG_TypeCheck((char *)type_name,ty);
+ if (!tc) return -1;
+ } else {
+ /* They don't care about the target type, so just pass on the pointer! */
+ return 0;
+/* This function fills ptr with a pointer of type ty by extracting the pointer
+ and type info from the resource in z. z must be a resource
+ It uses SWIG_ZTS_ConvertResourceData to do the real work. */
+SWIGRUNTIME(int)
+SWIG_ZTS_ConvertResourcePtr(zval *z, void **ptr, swig_type_info *ty TSRMLS_DC) {
+ swig_object_wrapper *value;
+ void *p;
+ int type;
+ value = (swig_object_wrapper *) zend_list_find(z->value.lval,&type);
+ p = value->ptr;
+ if (type==-1) return -1;
+ const char* type_name=zend_rsrc_list_get_rsrc_type(z->value.lval TSRMLS_CC);
+ return SWIG_ZTS_ConvertResourceData(p,type,type_name,ptr,ty TSRMLS_CC);
+/* But in fact SWIG_ConvertPtr is the native interface for getting typed
+ pointer values out of zvals. We need the TSRMLS_ macros for when we
+ make PHP type calls later as we handle php resources */
+#define SWIG_ConvertPtr(a,b,c) SWIG_ZTS_ConvertPtr(a,b,c TSRMLS_CC)
+/* We allow passing of a STRING or RESOURCE pointing to the object
+ or an OBJECT whose _cPtr is a string or resource pointing to the object
+ STRING pointers are very depracated */
+SWIGRUNTIME(int)
+SWIG_ZTS_ConvertPtr(zval *z, void **ptr, swig_type_info *ty TSRMLS_DC) {
+ char *c;
+ zval *val;
+ if(z == NULL || z->type == IS_NULL) {
+ *ptr = 0;
+ return 0;
+ if (z->type==IS_OBJECT) {
+ zval ** _cPtr;
+ if (zend_hash_find(HASH_OF(z),"_cPtr",sizeof("_cPtr"),(void**)&_cPtr)==SUCCESS) {
+ /* Don't co-erce to string if it isn't */
+ if ((*_cPtr)->type==IS_STRING) c = Z_STRVAL_PP(_cPtr);
+ else if ((*_cPtr)->type==IS_RESOURCE) {
+ return SWIG_ZTS_ConvertResourcePtr(*_cPtr,ptr,ty TSRMLS_CC);
+ } else goto type_error; /* _cPtr was not string or resource property */
+ } else goto type_error; /* can't find property _cPtr */
+ } else if (z->type==IS_RESOURCE) {
+ return SWIG_ZTS_ConvertResourcePtr(z,ptr,ty TSRMLS_CC);
+ } else if (z->type==IS_STRING) {
+ c = Z_STRVAL_P(z);
+ return SWIG_ConvertPtr_(c,ptr,ty);
+type_error:
+ return -1;
+void aw_convert_to_long(zval **op)
+ if((*op)->type != IS_STRING)
+ if((*op)->type == IS_OBJECT)
+ zend_error(E_ERROR, "No suitable conversion from object to integer value");
+ else if((*op)->type == IS_NULL)
+ zend_error(E_ERROR, "No suitable conversion from null reference to integer value");
+ convert_to_long_ex(op);
+ return;
+ char* strval = (*op)->value.str.val;
+ char* endptr;
+ (*op)->type = IS_LONG;
+ (*op)->value.lval = strtol(strval, &endptr, 10);
+ if(*endptr)
+ zend_error(E_ERROR, "'%s' is an invalid integer value", strval);
+ STR_FREE(strval);
+void aw_convert_to_double(zval **op)
+ zend_error(E_ERROR, "No suitable conversion from object to floating point value");
+ zend_error(E_ERROR, "No suitable conversion from null reference to floating point value");
+ convert_to_double_ex(op);
+ return;
+ char* endptr;
+ (*op)->value.dval = strtod(strval, &endptr);
+ (*op)->type = IS_DOUBLE;
+ if(*endptr)
+ zend_error(E_ERROR, "'%s' is an invalid floating point value", strval);
+ STR_FREE(strval);
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/precommon.swg
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/precommon.swg (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/precommon.swg 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,18 @@
+/*************************************************************** -*- c -*-
+ * php5/precommon.swg
+ * Rename all exported symbols from common.swg, to avoid symbol
+ * clashes if multiple interpreters are included
+#define SWIG_TypeRegister SWIG_PHP5_TypeRegister
+#define SWIG_TypeCheck SWIG_PHP5_TypeCheck
+#define SWIG_TypeCast SWIG_PHP5_TypeCast
+#define SWIG_TypeDynamicCast SWIG_PHP5_TypeDynamicCast
+#define SWIG_TypeName SWIG_PHP5_TypeName
+#define SWIG_TypeQuery SWIG_PHP5_TypeQuery
+#define SWIG_TypeClientData SWIG_PHP5_TypeClientData
+#define SWIG_PackData SWIG_PHP5_PackData
+#define SWIG_UnpackData SWIG_PHP5_UnpackData
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_common.i
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_common.i (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_common.i 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,9 @@
+// SWIG typemaps for STL - common utilities
+// Luigi Ballabio
+// Aug 17, 2003
+// PHP implementation
+%apply size_t { std::size_t };
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_map.i
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_map.i (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_map.i 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,190 @@
+// SWIG typemaps for std::map
+// Luigi Ballabio
+// Jan. 2003
+// Common implementation
+%include std_common.i
+%include exception.i
+%exception std::map::get {
+ try {
+ $action
+ } catch (std::out_of_range& e) {
+ SWIG_exception(SWIG_IndexError,const_cast<char*>(e.what()));
+%exception std::map::del {
+ try {
+ $action
+// std::map
+#include <map>
+#include <algorithm>
+#include <stdexcept>
+// exported class
+namespace std {
+ template<class K, class T> class map {
+ // add typemaps here
+ public:
+ map();
+ map(const map<K,T> &);
+ unsigned int size() const;
+ bool empty() const;
+ void clear();
+ %extend {
+ T& get(const K& key) {
+ std::map<K,T >::iterator i = self->find(key);
+ if (i != self->end())
+ return i->second;
+ else
+ throw std::out_of_range("key not found");
+ void set(const K& key, const T& x) {
+ (*self)[key] = x;
+ void del(const K& key) {
+ self->erase(i);
+ else
+ bool has_key(const K& key) {
+ return i != self->end();
+ // specializations for built-ins
+ %define specialize_std_map_on_key(K,CHECK,CONVERT_FROM,CONVERT_TO)
+ template<class T> class map<K,T> {
+ public:
+ map();
+ void clear();
+ %extend {
+ T& get(K key) {
+ return i->second;
+ else
+ void set(K key, const T& x) {
+ (*self)[key] = x;
+ void del(K key) {
+ self->erase(i);
+ else
+ bool has_key(K key) {
+ %enddef
+ %define specialize_std_map_on_value(T,CHECK,CONVERT_FROM,CONVERT_TO)
+ template<class K> class map<K,T> {
+ public:
+ map();
+ void clear();
+ %extend {
+ T get(const K& key) {
+ return i->second;
+ else
+ void set(const K& key, T x) {
+ (*self)[key] = x;
+ self->erase(i);
+ else
+ %enddef
+ %define specialize_std_map_on_both(K,CHECK_K,CONVERT_K_FROM,CONVERT_K_TO,
+ T,CHECK_T,CONVERT_T_FROM,CONVERT_T_TO)
+ template<> class map<K,T> {
+ public:
+ map();
+ void clear();
+ %extend {
+ T get(K key) {
+ return i->second;
+ else
+ void set(K key, T x) {
+ (*self)[key] = x;
+ void del(K key) {
+ self->erase(i);
+ else
+ %enddef
+ // add specializations here
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_pair.i
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_pair.i (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_pair.i 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,31 @@
+// SWIG typemaps for std::pair
+// Luigi Ballabio
+// July 2003
+// std::pair
+#include <utility>
+// exported class
+namespace std {
+ template<class T, class U> struct pair {
+ T first;
+ U second;
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_string.i
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_string.i (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_string.i 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,45 @@
+// SWIG typemaps for std::string types
+// Luigi Ballabio
+// May 7, 2002
+// std::string is typemapped by value
+// This can prevent exporting methods which return a string
+// in order for the user to modify it.
+// However, I think I'll wait until someone asks for it...
+#include <string>
+namespace std {
+ class string;
+ %typemap(in) string {
+ $1 = std::string(Z_STRVAL_PP($input));
+ %typemap(in) const string & (std::string temp) {
+ temp = std::string(Z_STRVAL_PP($input));
+ $1 = &temp;
+ %typemap(out) string {
+ ZVAL_STRINGL($result,const_cast<char*>($1.c_str()),$1.length(),1);
+ %typemap(out) const string & {
+ ZVAL_STRINGL($result,const_cast<char*>($1->c_str()),$1->length(),1);
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_vector.i
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_vector.i (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/std_vector.i 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,158 @@
+// SWIG typemaps for std::vector types
+// Luigi Ballabio
+// May 7, 2002
+// containers
+// methods which can raise are caused to throw an IndexError
+%exception std::vector::get {
+ try {
+ $action
+%exception std::vector::set {
+ try {
+ $action
+%exception std::vector::pop {
+ try {
+ $action
+// std::vector
+// The aim of all that follows would be to integrate std::vector with
+// PHP as much as possible, namely, to allow the user to pass and
+// be returned PHP lists.
+// const declarations are used to guess the intent of the function being
+// exported; therefore, the following rationale is applied:
+// -- f(std::vector<T>), f(const std::vector<T>&), f(const std::vector<T>*):
+// the parameter being read-only, either a PHP sequence or a
+// previously wrapped std::vector<T> can be passed.
+// -- f(std::vector<T>&), f(std::vector<T>*):
+// the parameter must be modified; therefore, only a wrapped std::vector
+// can be passed.
+// -- std::vector<T> f():
+// the vector is returned by copy; therefore, a PHP sequence of T:s
+// is returned which is most easily used in other PHP functions
+// -- std::vector<T>& f(), std::vector<T>* f(), const std::vector<T>& f(),
+// const std::vector<T>* f():
+// the vector is returned by reference; therefore, a wrapped std::vector
+// is returned
+#include <vector>
+// exported class
+namespace std {
+ template<class T> class vector {
+ // add generic typemaps here
+ public:
+ vector(unsigned int size = 0);
+ void clear();
+ %rename(push) push_back;
+ void push_back(const T& x);
+ %extend {
+ T pop() {
+ if (self->size() == 0)
+ throw std::out_of_range("pop from empty vector");
+ T x = self->back();
+ self->pop_back();
+ return x;
+ T& get(int i) {
+ int size = int(self->size());
+ if (i>=0 && i<size)
+ return (*self)[i];
+ else
+ throw std::out_of_range("vector index out of range");
+ void set(int i, const T& x) {
+ (*self)[i] = x;
+ else
+ %define specialize_std_vector(T)
+ template<> class vector<T> {
+ // add specialized typemaps here
+ public:
+ void clear();
+ void push_back(T x);
+ %extend {
+ T pop() {
+ self->pop_back();
+ return x;
+ T get(int i) {
+ else
+ void set(int i, T x) {
+ (*self)[i] = x;
+ else
+ %enddef
+ specialize_std_vector(bool);
+ specialize_std_vector(char);
+ specialize_std_vector(int);
+ specialize_std_vector(short);
+ specialize_std_vector(long);
+ specialize_std_vector(unsigned char);
+ specialize_std_vector(unsigned int);
+ specialize_std_vector(unsigned short);
+ specialize_std_vector(unsigned long);
+ specialize_std_vector(float);
+ specialize_std_vector(double);
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/typemaps.i
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/typemaps.i (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/typemaps.i 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,234 @@
+// SWIG Typemap library
+// Richard Palmer
+// Oct 3, 2001
+// PHP4 implementation
+// This library provides standard typemaps for modifying SWIG's behavior.
+// With enough entries in this file, I hope that very few people actually
+// ever need to write a typemap.
+%typemap(in) double *INPUT(double temp)
+ temp = (double) Z_DVAL_PP($input);
+ $1 = &temp;
+%typemap(in) float *INPUT(float temp)
+ temp = (float) Z_DVAL_PP($input);
+ $1 = &temp;
+%typemap(in) int *INPUT(int temp)
+ temp = (int) Z_LVAL_PP($input);
+ $1 = &temp;
+%typemap(in) short *INPUT(short temp)
+ temp = (short) Z_LVAL_PP($input);
+ $1 = &temp;
+%typemap(in) long *INPUT(long temp)
+ temp = (long) Z_LVAL_PP($input);
+ $1 = &temp;
+%typemap(in) unsigned int *INPUT(unsigned int temp)
+ temp = (unsigned int) Z_LVAL_PP($input);
+ $1 = &temp;
+%typemap(in) unsigned short *INPUT(unsigned short temp)
+ temp = (unsigned short) Z_LVAL_PP($input);
+ $1 = &temp;
+%typemap(in) unsigned long *INPUT(unsigned long temp)
+ temp = (unsigned long) Z_LVAL_PP($input);
+ $1 = &temp;
+%typemap(in) unsigned char *INPUT(unsigned char temp)
+ temp = (unsigned char) Z_LVAL_PP($input);
+ $1 = &temp;
+%typemap(in,numinputs=0) int *OUTPUT(int temp),
+ short *OUTPUT(short temp),
+ long *OUTPUT(long temp),
+ unsigned int *OUTPUT(unsigned int temp),
+ unsigned short *OUTPUT(unsigned short temp),
+ unsigned long *OUTPUT(unsigned long temp),
+ unsigned char *OUTPUT(unsigned char temp),
+ float *OUTPUT(float temp),
+ double *OUTPUT(double temp)
+ $1 = &temp;
+%typemap(argout) int *OUTPUT,
+ short *OUTPUT,
+ long *OUTPUT,
+ unsigned int *OUTPUT,
+ unsigned short *OUTPUT,
+ unsigned long *OUTPUT,
+ ZVAL_LONG($result,*($input));
+%typemap(argout) float *OUTPUT,
+ double *OUTPUT
+ ZVAL_DOUBLE($result,*($input));
+%typemap(in) int *INOUT = int *INPUT;
+%typemap(in) short *INOUT = short *INPUT;
+%typemap(in) long *INOUT = long *INPUT;
+%typemap(in) unsigned *INOUT = unsigned *INPUT;
+%typemap(in) unsigned short *INOUT = unsigned short *INPUT;
+%typemap(in) unsigned long *INOUT = unsigned long *INPUT;
+%typemap(in) unsigned char *INOUT = unsigned char *INPUT;
+%typemap(in) float *INOUT = float *INPUT;
+%typemap(in) double *INOUT = double *INPUT;
+%typemap(argout) int *INOUT = int *OUTPUT;
+%typemap(argout) short *INOUT = short *OUTPUT;
+%typemap(argout) long *INOUT= long *OUTPUT;
+%typemap(argout) unsigned short *INOUT= unsigned short *OUTPUT;
+%typemap(argout) unsigned long *INOUT = unsigned long *OUTPUT;
+%typemap(argout) unsigned char *INOUT = unsigned char *OUTPUT;
+%typemap(argout) float *INOUT = float *OUTPUT;
+%typemap(argout) double *INOUT= double *OUTPUT;
+// REFERENCE
+// Accept Php references as pointers
+%typemap(in) double *REFERENCE (double dvalue)
+ if(!ParameterPassedByReference(ht, argvi))
+ zend_error(E_WARNING, "Parameter wasn't passed by reference");
+ RETURN_NULL();
+ dvalue = (double) (*$input)->value.dval;
+ $1 = &dvalue;
+%typemap(in) float *REFERENCE (float dvalue)
+ RETURN_NULL();
+ dvalue = (float) (*$input)->value.dval;
+ $1 = &dvalue;
+%typemap(in) int *REFERENCE (int dvalue)
+ RETURN_NULL();
+ dvalue = (int) (*$input)->value.lval;
+ $1 = &dvalue;
+%typemap(in) short *REFERENCE (short dvalue)
+ RETURN_NULL();
+ dvalue = (short) (*$input)->value.lval;
+ $1 = &dvalue;
+%typemap(in) long *REFERENCE (long dvalue)
+ RETURN_NULL();
+ dvalue = (long) (*$input)->value.lval;
+ $1 = &dvalue;
+%typemap(in) unsigned int *REFERENCE (unsigned int dvalue)
+ RETURN_NULL();
+ dvalue = (unsigned int) (*$input)->value.lval;
+ $1 = &dvalue;
+%typemap(in) unsigned short *REFERENCE (unsigned short dvalue)
+ RETURN_NULL();
+ dvalue = (unsigned short) $input->value.lval;
+ $1 = &dvalue;
+%typemap(in) unsigned long *REFERENCE (unsigned long dvalue)
+ RETURN_NULL();
+ dvalue = (unsigned long) $input->value.lval;
+ $1 = &dvalue;
+%typemap(argout) double *REFERENCE,
+ float *REFERENCE
+ $1->value.dval = (double)(*$arg);
+ $1->type = IS_DOUBLE;
+%typemap(argout) int *REFERENCE,
+ short *REFERENCE,
+ long *REFERENCE,
+ unsigned int *REFERENCE,
+ unsigned short *REFERENCE,
+ unsigned long *REFERENCE
+ (*$arg)->value.lval = (long)(*$input);
+ (*$arg)->type = IS_LONG;
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/utils.i
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/utils.i (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Lib/php7/utils.i 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,145 @@
+// Contains operations useful in php typemaps
+// typemaps don't support "subroutine" typemaps where one typemap can
+// include another, so we define useful bodies here to include inother places
+// _strbuf_out is designed to be included as part of an argout typemap
+// and _strbuf_in which should be part of the in typemap for the same argument
+// They share knowledge of the "force" temporary variable.
+// You probably don't want to make direct use of _strbuf_out or _strbuf_in but
+// you may want strbufsize_inout which uses these
+%define _strbuf_out(BUFFER,SIZE)
+ zend_error(E_WARNING, "Parameter %d of $symname wasn't passed by reference [argout TYPES *, TYPES &]",$argnum-argbase);
+ } else {
+ #if SIZE
+ // SIZE
+ ZVAL_STRINGL(*$arg,BUFFER$argnum, SIZE, 1);
+ #else
+ // Measure length
+ ZVAL_STRING(*$arg,BUFFER$argnum, 1);
+ #endif
+%enddef
+%define
+_strbuf_in(BUFFER)
+ // _strbuf_in
+ if(! SWIG_ConvertPtr(*$input, (void **) &$1, $1_descriptor) < 0) {
+ /* Using a _p_ SWIG pointer, so they will have to manage size themselves */
+ force=0;
+ } else if ((*$input)->type==IS_STRING ||
+ (*$input)->type==IS_LONG ||
+ /* Null passed by reference means we want a value back */
+ (*$input)->type==IS_NULL ||
+ (*$input)->type==IS_BOOL ||
+ (*$input)->type==IS_DOUBLE) {
+ // Only pass back if we can...
+ if (PZVAL_IS_REF(*$input)) force=1;
+ else force=0;
+ // Init temp buffer
+ strncpy((char *)temp,Z_STRVAL_PP($input),sizeof(BUFFER));
+ $1=temp;
+ } else {
+ force=0;
+ $1=NULL;
+ zend_error(E_ERROR, "Type error in argument %d of $symname. Expected %s or at least something looking vaguely like a string hopefully passed by reference", $argnum-argbase, $1_descriptor->name);
+%enddef
+// strbufsize_inout defines a typemap which
+// Example: strbufsize_inout(UCHAR FAR * szErrorMsg, SWORD cbErrorMsgMax,1024)
+// defines a typeemap for UCHAR FAR * szErrorMsg, SWORD cbErrorMsgMax with a
+// max buffer size of 1024
+%define strbufsize_inout(BUFFER,SIZE,MAXSIZE)
+%typemap(in) (BUFFER, SIZE) ($*1_ltype temp[MAXSIZE], int force) {
+ _strbuf_in(temp)
+ $2=sizeof(temp);
+%typemap(argout) (BUFFER, SIZE) {
+ _strbuf_out((char *)temp,strlen(temp))
+%enddef
+// e.g. Do: strarray_inout(char [ANY])
+%define strarray_inout(TYPE)
+%typemap(in) TYPE ($*1_ltype temp[$1_dim0], int force) %{
+ _strbuf_in(temp)
+%typemap(argout) TYPE %{
+ _strbuf_out((char *)temp,$1_dim0);
+%enddef
+%define strarraysize_inout(TYPE,SIZE)
+%typemap(in) TYPE ($*1_ltype temp[SIZE], int force) %{
+ _strbuf_in(temp)
+ _strbuf_out((char *)temp,SIZE);
+%enddef
+%define strbuf_inout(BUFFER,MAXSIZE)
+%typemap(in) (BUFFER) ($*1_ltype temp[MAXSIZE], int force) {
+ _strbuf_in(temp)
+%typemap(argout) (BUFFER) {
+ _strbuf_out(temp,strlen(temp))
+%enddef
+%define outLONG(ZVALARG,CARG)
+ ZVAL_LONG(*$arg,intr$argnum);
+%enddef
+// Defines an on/argout typemap for ordinal types
+//Usage: %typemap_inout_ord(bool,convert_to_bool_ex,ZVAL_BOOL)
+%define %typemap_inout_ord(TYPES,TYPE_IN,TYPE_OUT)
+%typemap(in) TYPES * ($*1_ltype intr, int force),
+ TYPES & ($*1_ltype intr, int force) %{
+ /* inout typemap for TYPES using TYPE_IN and TYPE_OUT */
+ /* So... we didn't get a ref or ptr, but can it be reasonably
+ co-erced into what we were looking for a ref of or ptr to? */
+ if (!PZVAL_IS_REF(*$input) && (*$input)->type==IS_NULL) {
+ // null passed not by reference means pass NULL
+ $1 = NULL;
+ force=0;
+ } else if (PZVAL_IS_REF(*$input) &&
+ ((*$input)->type==IS_STRING ||
+ (*$input)->type==IS_DOUBLE)) {
+ TYPE_IN($input);
+ intr = ($*1_ltype) (*$input)->value.lval;
+ $1 = &intr;
+ force=1;
+ force=0;
+ zend_error(E_ERROR, "Type error in argument %d of $symname. Expected %s or at least something looking vaguely like a number hopefully passed by reference", $argnum-argbase, $1_descriptor->name);
+ } else force=0;
+%typemap(argout) TYPES *, TYPES & %{
+ } else {
+ TYPE_OUT(*$arg,intr$argnum);
+%enddef
Modified: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Makefile
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Makefile 2015-12-08 11:25:13 UTC (rev 8858)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Makefile 2015-12-08 12:09:33 UTC (rev 8859)
@@ -83,6 +83,7 @@
Source/Modules/perl5.cxx \
Source/Modules/php4.cxx \
Source/Modules/php5.cxx \
+ Source/Modules/php7.cxx \
Source/Modules/pike.cxx \
Source/Modules/python.cxx \
Source/Modules/ruby.cxx \
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Source/Modules/php7.cxx
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Source/Modules/php7.cxx (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Source/Modules/php7.cxx 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,2556 @@
+ * PHP7 Support
+ * Jackie Ng
+ * Dec 2015
+ * Based on the PHP5 module
+#include "swigmod.h"
+#ifndef MACSWIG
+#include "swigconfig.h"
+#endif
+#include "ExceptionClass.h"
+#include <ctype.h>
+#include <map>
+#include <list>
+#include <vector>
+#include <string>
+#define IS_NULL 0
+#define IS_LONG 1
+#define IS_DOUBLE 2
+#define IS_STRING 3
+#define IS_OBJECT 5
+#define IS_BOOL 6
+using namespace std;
+static const char *usage = (char*)"\
+PHP7 Options (available with -php)\n\
+ -ldflags - Print runtime libraries to link with\n\
+ -cppext - cpp file extension (default to .cpp)\n\
+ -noproxy - Don't generate proxy classes.\n\
+ -dlname <name> - Set module prefix to <name>\n\
+ -make - Create simple makefile\n\
+ -phpfull - Create full make files\n\
+ -withincs <libs>- With -phpfull writes needed incs in config.m4\n\
+ -withlibs <libs>- With -phpfull writes needed libs in config.m4\n\
+ -withc <libs> - With -phpfull makes extra c files in Makefile.in\n\
+ -withcxx <libs> - With -phpfull makes extra c++ files in Makefile.in\n\
+\n";
+static int constructors=0;
+static String *NOTCLASS=NewString("Not a class");
+static Node *classnode=0;
+static String *module = 0;
+static String *cap_module = 0;
+static String *dlname = 0;
+static String *withlibs = 0;
+static String *withincs = 0;
+static String *withc = 0;
+static String *withcxx = 0;
+static bool emitedThrowFunction = false;
+//static char *package = 0; // Name of the package
+static char *shadow_classname;
+static Wrapper *f_php;
+static int gen_extra = 0;
+static int gen_make = 0;
+static File *f_runtime = 0;
+static File *f_h = 0;
+static File *f_phpcode = 0;
+static String *phpfilename =0;
+static String *s_header;
+static String *s_wrappers;
+static String *s_init;
+static String *s_vinit;
+static String *s_vdecl;
+static String *s_cinit;
+static String *s_oinit;
+static String *s_entry;
+static String *cs_entry;
+static String *all_cs_entry;
+static String *pragma_incl;
+static String *pragma_code;
+static String *pragma_phpinfo;
+/* Variables for using PHP classes */
+static String *class_name = 0;
+static String *realpackage = 0;
+static String *package = 0;
+static Hash *shadow_get_vars;
+static Hash *shadow_set_vars;
+static String *shadow_classdef;
+static String *shadow_code;
+static int have_default_constructor = 0;
+#define NATIVE_CONSTRUCTOR 1
+#define ALTERNATIVE_CONSTRUCTOR 2
+static int native_constructor=0;
+static int destructor=0;
+static int enum_flag = 0; // Set to 1 when wrapping an enum
+static int static_flag = 0; // Set to 1 when wrapping a static functions or member variables
+static int const_flag = 0; // Set to 1 when wrapping a const member variables
+static int variable_wrapper_flag = 0; // Set to 1 when wrapping a member variable/enum/const
+static int wrapping_member = 0;
+static Hash *zend_types = 0;
+static String *shadow_enum_code = 0;
+static String *php_enum_code = 0;
+static String *all_shadow_extra_code = 0;
+ //Extra code for all shadow classes from %pragma
+static String *this_shadow_extra_code = 0;
+ //Extra Code for current single shadow class freom %pragma
+static String *all_shadow_import = 0;
+ //import for all shadow classes from %pragma
+static String *this_shadow_import = 0;
+ //import for current shadow classes from %pragma
+static String *module_baseclass = 0;
+ //inheritance for module class from %pragma
+static String *all_shadow_baseclass = 0;
+ //inheritence for all shadow classes from %pragma
+static String *this_shadow_baseclass = 0;
+ //inheritance for shadow class from %pragma and cpp_inherit
+static String *this_shadow_multinherit = 0;
+static int shadow = 1;
+static map<string, bool> wrapped;
+static map<string, bool> methodEntries;
+extern map<string, int> clsIds;
+extern "C" bool enableRuntimeTypeChecking;
+extern ExceptionClass* rootException;
+extern String* baseException;
+extern String* disposeCode;
+extern String* rethrowCode;
+class Parameter
+public:
+ Parameter(int type, string typeStr)
+ this->type = type;
+ this->typeStr = typeStr;
+ int type;
+ string typeStr;
+class OverloadedFunc7
+public:
+ OverloadedFunc7(string mangledName, int argcount, vector<Parameter*>* parms)
+ this->mangledName = mangledName; this->argcount = argcount; this->parms = parms;
+ this->done = false;
+ string mangledName;
+ int argcount;
+ vector<Parameter*>* parms;
+ bool done;
+map<string, vector<OverloadedFunc7*>*> overloads;
+extern "C" {
+static void (*r_prevtracefunc)(SwigType *t, String *mangled, String *clientdata) = 0;
+static const char *php_header =
+"\n +---------------------------------------------------------------------- +"
+"\n | PHP Version 7 |"
+"\n | Copyright(c) 1997 - 2015 The PHP Group |"
+"\n | This source file is subject to version 3.01 of the PHP license, |"
+"\n | that is bundled with this package in the file LICENSE, and is |"
+"\n | available through the world - wide - web at the following url : |"
+"\n | http://www.php.net/license/3_01.txt |"
+"\n | If you did not receive a copy of the PHP license and are unable to |"
+"\n | obtain it through the world - wide - web, please send a note to |"
+"\n | license at php.net so we can mail you a copy immediately. |"
+"\n | Author: |"
+"\n */\n";
+void emitThrowFunctionPrototype7()
+ if(baseException != NULL)
+ Printf(s_header, "void ThrowPHPExceptionWrapper(%s* e TSRMLS_DC);\n\n", baseException);
+void
+SwigPHP7_emit_resource_registrations() {
+ DOH *key;
+ Iterator ki;
+ String *destructor=0;
+ String *classname=0;
+ String *shadow_classname=0;
+ if (!zend_types) return;
+ //emit the throw function
+ emitThrowFunctionPrototype7();
+ ki = First(zend_types);
+ if (ki.key) Printf(s_oinit,"\n/* Register resource destructors for pointer types */\n");
+ while (ki.key) if (1 /* is pointer type*/) {
+ key = ki.key;
+ Node *class_node;
+ if ((class_node=Getattr(zend_types,key))) {
+ // Write out destructor function header
+ Printf(s_wrappers,"/* NEW Destructor style */\nstatic ZEND_RSRC_DTOR_FUNC(_wrap_destroy%s) {\n",key);
+ // write out body
+ if ((class_node!=NOTCLASS)) {
+ classname = Getattr(class_node,"name");
+ if (! (shadow_classname = Getattr(class_node,"sym:name"))) shadow_classname=classname;
+ // Do we have a known destructor for this type?
+ if ((destructor = Getattr(class_node,"destructor"))) {
+ Printf(s_wrappers,"/* has destructor: %s */\n",destructor);
+ Printf(s_wrappers,"%s(rsrc, SWIGTYPE%s->name TSRMLS_CC);\n",destructor,key);
+ } else {
+ Printf(s_wrappers,"/* bah! No destructor for this wrapped class!! */\n");
+ } else {
+ Printf(s_wrappers,"/* bah! No destructor for this simple type!! */\n");
+ // close function
+ Printf(s_wrappers,"}\n");
+ // declare le_swig_<mangled> to store php registration
+ Printf(s_vdecl,"static int le_swig_%s=0; /* handle for %s */\n", key, shadow_classname);
+ // register with php
+ Printf(s_oinit,"le_swig_%s=zend_register_list_destructors_ex"
+ "(_wrap_destroy%s,NULL,(char *)(SWIGTYPE%s->name),module_number);\n",
+ key,key,key);
+ // store php type in class struct
+ Printf(s_oinit,"SWIG_TypeClientData(SWIGTYPE%s,&le_swig_%s);\n",
+ key,key);
+ ki = Next(ki);
+class PHP7 : public Language {
+public:
+ PHP7()
+ this->emitExCount = 0;
+ /* Test to see if a type corresponds to something wrapped with a shadow class. */
+ String *is_shadow(SwigType *t) {
+ String *r = 0;
+ Node *n = classLookup(t);
+ if (n) {
+ r = Getattr(n,"php:proxy"); // Set by classDeclaration()
+ if (!r) {
+ r = Getattr(n,"sym:name"); // Not seen by classDeclaration yet, but this is the name
+ return r;
+ void emitThrowFunctionDefinition()
+ if(baseException == NULL)
+ return;
+ Printf(s_wrappers, "\n\nvoid ThrowPHPExceptionWrapper(%s* e TSRMLS_DC)\n", baseException);
+ Printf(s_wrappers, "{\n");
+ if(rethrowCode)
+ Printf(s_wrappers, "\ttry\n");
+ Printf(s_wrappers, "\t{\n");
+ Printf(s_wrappers, "\t\t%s\n", rethrowCode);
+ Printf(s_wrappers, "\t}\n");
+ emitCatchSequence(rootException);
+ else
+ Printf(s_wrappers, "}\n\n");
+ void emitCatchSequence(ExceptionClass* e)
+ if(e->derivedClasses.size() > 0)
+ list<ExceptionClass*>::const_iterator iter = e->derivedClasses.begin();
+ while(iter != e->derivedClasses.end())
+ emitCatchSequence(*iter);
+ iter++;
+ if(rethrowCode)
+ Printf(s_wrappers, "\tcatch(%s* e)\n", e->name.c_str());
+ else
+ if(this->emitExCount++ == 0)
+ Printf(s_wrappers, "\tif(typeid(*e) == typeid(%s))\n", e->name.c_str());
+ else
+ Printf(s_wrappers, "\telse if(typeid(*e) == typeid(%s))\n", e->name.c_str());
+ Printf(s_wrappers, "\t\tzval *obj, *_cPtr;\n");
+ Printf(s_wrappers, "\t\tMAKE_STD_ZVAL(obj);\n");
+ Printf(s_wrappers, "\t\tMAKE_STD_ZVAL(_cPtr);\n");
+ Printf(s_wrappers, "\t\tSWIG_SetPointerZval(_cPtr, (void *)e, SWIGTYPE_p_%s, 1);\n", e->name.c_str());
+ Printf(s_wrappers, "\t\tobject_init_ex(obj,ptr_ce_swig_%s);\n", e->name.c_str());
+ Printf(s_wrappers, "\t\tadd_property_zval(obj,\"_cPtr\",_cPtr);\n");
+ Printf(s_wrappers, "\t\tEG(exception) = obj;\n");
+ Printf(s_wrappers, "\t\tzend_throw_exception_object(EG(exception) TSRMLS_CC);\n");
+ bool isException(ExceptionClass* ex, string name)
+ if(!ex)
+ return false;
+ if(ex->name == name)
+ return true;
+ for(list<ExceptionClass*>::const_iterator it = ex->derivedClasses.begin(); it != ex->derivedClasses.end(); it++)
+ if(isException(*it, name))
+ return true;
+ return false;
+ * get_pointer()
+ void
+ get_pointer(char *iname, char *srcname, char *src, char *dest,
+ SwigType *t, String *f, char *ret) {
+ SwigType_remember(t);
+ SwigType *lt = SwigType_ltype(t);
+ Printv(f, "if (SWIG_ConvertPtr(", src, ",(void **) ", dest, ",", NIL);
+ /* If we're passing a void pointer, we give the pointer conversion a NULL
+ pointer, otherwise pass in the expected type. */
+ if (Cmp(lt,"p.void") == 0) {
+ Printf(f, " 0 ) < 0) {\n");
+ } else {
+ Printv(f, "SWIGTYPE", SwigType_manglestr(t), ") < 0) {\n",NIL);
+ Printv(f,
+ "zend_error(E_ERROR, \"Type error in ", srcname, " of ", iname,
+ " Expected %s\", SWIGTYPE", SwigType_manglestr(t), "->name);\n", ret,
+ ";\n",
+ "}\n",
+ NIL);
+ Delete(lt);
+ * main()
+ virtual void main(int argc, char *argv[]) {
+ int i;
+ SWIG_library_directory("php7");
+ SWIG_config_cppext("cpp");
+ for(i = 1; i < argc; i++) {
+ if (argv[i]) {
+ if(strcmp(argv[i], "-phpfull") == 0) {
+ gen_extra = 1;
+ Swig_mark_arg(i);
+ } else if(strcmp(argv[i], "-dlname") == 0) {
+ if (argv[i+1]) {
+ dlname = NewString(argv[i+1]);
+ Swig_mark_arg(i);
+ Swig_mark_arg(i+1);
+ i++;
+ } else {
+ Swig_arg_error();
+ } else if(strcmp(argv[i], "-baseexception") == 0) {
+ if (argv[i+1]) {
+ baseException = NewString(argv[i+1]);
+ Swig_mark_arg(i);
+ i++;
+ } else {
+ Swig_arg_error();
+ } else if(strcmp(argv[i], "-withlibs") == 0) {
+ if (argv[i+1]) {
+ withlibs = NewString(argv[i+1]);
+ Swig_mark_arg(i);
+ i++;
+ } else {
+ Swig_arg_error();
+ } else if(strcmp(argv[i], "-withincs") == 0) {
+ if (argv[i+1]) {
+ withincs = NewString(argv[i+1]);
+ Swig_mark_arg(i);
+ i++;
+ } else {
+ Swig_arg_error();
+ } else if(strcmp(argv[i], "-withc") == 0) {
+ if (argv[i+1]) {
+ withc = NewString(argv[i+1]);
+ Swig_mark_arg(i);
+ i++;
+ } else {
+ Swig_arg_error();
+ } else if(strcmp(argv[i], "-withcxx") == 0) {
+ if (argv[i+1]) {
+ withcxx = NewString(argv[i+1]);
+ Swig_mark_arg(i);
+ i++;
+ } else {
+ Swig_arg_error();
+ } else if(strcmp(argv[i], "-cppext") == 0) {
+ if (argv[i+1]) {
+ SWIG_config_cppext(argv[i+1]);
+ Swig_mark_arg(i);
+ i++;
+ } else {
+ Swig_arg_error();
+ } else if((strcmp(argv[i], "-noshadow") == 0) || (strcmp(argv[i],"-noproxy") == 0)) {
+ shadow = 0;
+ Swig_mark_arg(i);
+ } else if(strcmp(argv[i], "-make") == 0) {
+ gen_make = 1;
+ Swig_mark_arg(i);
+ } else if(strcmp(argv[i], "-help") == 0) {
+ fputs(usage, stderr);
+ } else if (strcmp (argv[i], "-ldflags") == 0) {
+ printf("%s\n", SWIG_PHP_RUNTIME);
+ SWIG_exit (EXIT_SUCCESS);
+ Preprocessor_define((void *) "SWIGPHP 1", 0);
+ Preprocessor_define((void *) "SWIGPHP7 1", 0);
+ Preprocessor_define ("SWIG_NO_OVERLOAD 1", 0);
+ SWIG_typemap_lang("php7");
+ /* DB: Suggest using a language configuration file */
+ SWIG_config_file("php7.swg");
+ allow_overloading();
+ void create_simple_make(void) {
+ File *f_make;
+ f_make = NewFile((void *)"makefile", "w");
+ if(CPlusPlus)
+ Printf(f_make, "CC=g++\n");
+ else
+ Printf(f_make, "CC=gcc\n");
+ Printf(f_make,
+ "OBJS=%s_wrap.o\n"
+ "PROG=lib%s.so\n"
+ "CFLAGS=-fpic\n"
+ "LDFLAGS=-shared\n"
+ "PHP_INC=`php-config --includes`\n"
+ "EXTRA_INC=\n"
+ "EXTRA_LIB=\n\n",
+ module, module);
+ Printf(f_make,
+ "$(PROG): $(OBJS)\n"
+ "\t$(CC) $(LDFLAGS) $(OBJS) -o $(PROG) $(EXTRA_LIB)\n\n"
+ "%%.o: %%.%s\n"
+ "\t$(CC) $(EXTRA_INC) $(PHP_INC) $(CFLAGS) -c $<\n",
+ (CPlusPlus?"cpp":"c"));
+ Close(f_make);
+ void create_extra_files(String *outfile) {
+ File *f_extra;
+ static String *configm4=0;
+ static String *makefilein=0;
+ static String *credits=0;
+ configm4=NewString("");
+ Printv(configm4, SWIG_output_directory(), "config.m4", NIL);
+ makefilein=NewString("");
+ Printv(makefilein, SWIG_output_directory(), "Makefile.in", NIL);
+ credits=NewString("");
+ Printv(credits, SWIG_output_directory(), "CREDITS", NIL);
+ // are we a --with- or --enable-
+ int with=(withincs || withlibs)?1:0;
+ // Note makefile.in only copes with one source file
+ // also withincs and withlibs only take one name each now
+ // the code they generate should be adapted to take multiple lines
+ if(gen_extra) {
+ /* Write out Makefile.in */
+ f_extra = NewFile(makefilein, "w");
+ if (!f_extra) {
+ Printf(stderr,"Unable to open %s\n",makefilein);
+ SWIG_exit(EXIT_FAILURE);
+ Printf(f_extra,
+ "# $Id: php7.cxx $\n\n"
+ "LTLIBRARY_NAME = php_%s.la\n",
+ module);
+ // CPP has more and different entires to C in Makefile.in
+ if (! CPlusPlus) Printf(f_extra,"LTLIBRARY_SOURCES = %s %s\n"
+ "LTLIBRARY_SOURCES_CPP = %s\n",Swig_file_filename(outfile),withc,withcxx);
+ else Printf(f_extra,"LTLIBRARY_SOURCES = %s\n"
+ "LTLIBRARY_SOURCES_CPP = %s %s\n"
+ "LTLIBRARY_OBJECTS_X = $(LTLIBRARY_SOURCES_CPP:.cpp=.lo) $(LTLIBRARY_SOURCES_CPP:.cxx=.lo)\n"
+ ,withc,Swig_file_filename(outfile),withcxx);
+ Printf(f_extra,"LTLIBRARY_SHARED_NAME = php_%s.la\n"
+ "LTLIBRARY_SHARED_LIBADD = $(%(upper)s_SHARED_LIBADD)\n\n"
+ "include $(top_srcdir)/build/dynlib.mk\n",
+ module,module);
+ Printf(f_extra,"\n# patch in .cxx support to php build system to work like .cpp\n"
+ ".SUFFIXES: .cxx\n\n"
+ ".cxx.o:\n"
+ " $(CXX_COMPILE) -c $<\n\n"
+ ".cxx.lo:\n"
+ " $(CXX_PHP_COMPILE)\n\n"
+ ".cxx.slo:\n"
+ " $(CXX_SHARED_COMPILE)\n\n");
+ Printf(f_extra,"\n# make it easy to test module\n"
+ "testmodule:\n"
+ " php -q -d extension_dir=modules %s\n\n",Swig_file_filename(phpfilename));
+ Close(f_extra);
+ /* Now config.m4 */
+ // Note: # comments are OK in config.m4 if you don't mind them
+ // appearing in the final ./configure file
+ // (which can help with ./configure debugging)
+ // NOTE2: phpize really ought to be able to write out a sample
+ // config.m4 based on some simple data, I'll take this up with
+ // the php folk!
+ f_extra = NewFile(configm4, "w");
+ if (!f_extra) {
+ Printf(stderr, "Unable to open %s\n",configm4);
+ Printf(f_extra,
+ "dnl $Id: php7.cxx $\n"
+ "dnl ***********************************************************************\n"
+ "dnl ** THIS config.m4 is provided for PHPIZE and PHP's consumption NOT\n"
+ "dnl ** for any part of the rest of the %s build system\n"
+ "dnl ***********************************************************************\n\n"
+ ,module);
+ if (! with) { // must be enable then
+ Printf(f_extra,
+ "PHP_ARG_ENABLE(%s, whether to enable %s support,\n"
+ "[ --enable-%s Enable %s support])\n\n",
+ module,module,module,module);
+ } else {
+ Printf(f_extra,
+ "PHP_ARG_WITH(%s, for %s support,\n"
+ "[ --with-%s[=DIR] Include %s support.])\n\n",
+ // These tests try and file the library we need
+ Printf(f_extra,"dnl THESE TESTS try and find the library and header files\n"
+ "dnl your new php module needs. YOU MAY NEED TO EDIT THEM\n"
+ "dnl as written they assume your header files are all in the same place\n\n");
+ Printf(f_extra,"dnl ** are we looking for %s_lib.h or something else?\n",module);
+ if (withincs) Printf(f_extra,"HNAMES=\"%s\"\n\n",withincs);
+ else Printf(f_extra,"HNAMES=\"\"; # %s_lib.h ?\n\n",module);
+ Printf(f_extra,"dnl ** Are we looking for lib%s.a or lib%s.so or something else?\n",module,module);
+ if (withlibs) Printf(f_extra,"LIBNAMES=\"%s\"\n\n",withlibs);
+ else Printf(f_extra,"LIBNAMES=\"\"; # lib_%s.so ?\n\n",withlibs);
+ Printf(f_extra,"dnl IF YOU KNOW one of the symbols in the library and you\n"
+ "dnl specify it below then we can have a link test to see if it works\n"
+ "LIBSYMBOL=\"\"\n\n");
+ // Now write out tests to find thing.. they may need to extend tests
+ Printf(f_extra,"if test \"$PHP_%(upper)s\" != \"no\"; then\n\n",module);
+ // Ready for when we add libraries as we find them
+ Printf(f_extra," PHP_SUBST(%(upper)s_SHARED_LIBADD)\n\n",module);
+ if (withlibs) { // find more than one library
+ Printf(f_extra," for LIBNAME in $LIBNAMES ; do\n");
+ Printf(f_extra," LIBDIR=\"\"\n");
+ // For each path element to try...
+ Printf(f_extra," for i in $PHP_%(upper)s $PHP_%(upper)s/lib /usr/lib /usr/local/lib ; do\n",module,module);
+ Printf(f_extra," if test -r $i/lib$LIBNAME.a -o -r $i/lib$LIBNAME.so ; then\n"
+ " LIBDIR=\"$i\"\n"
+ " break\n"
+ " fi\n"
+ " done\n\n");
+ Printf(f_extra," dnl ** and $LIBDIR should be the library path\n"
+ " if test \"$LIBNAME\" != \"\" -a -z \"$LIBDIR\" ; then\n"
+ " AC_MSG_RESULT(Library files $LIBNAME not found)\n"
+ " AC_MSG_ERROR(Is the %s distribution installed properly?)\n"
+ " else\n"
+ " AC_MSG_RESULT(Library files $LIBNAME found in $LIBDIR)\n"
+ " PHP_ADD_LIBRARY_WITH_PATH($LIBNAME, $LIBDIR, %(upper)s_SHARED_LIBADD)\n"
+ " fi\n",module,module);
+ Printf(f_extra," done\n\n");
+ if (withincs) { // Find more than once include
+ Printf(f_extra," for HNAME in $HNAMES ; do\n");
+ Printf(f_extra," INCDIR=\"\"\n");
+ Printf(f_extra," for i in $PHP_%(upper)s $PHP_%(upper)s/include $PHP_%(upper)s/includes $PHP_%(upper)s/inc $PHP_%(upper)s/incs /usr/local/include /usr/include; do\n",module,module,module,module,module);
+ // Try and find header files
+ Printf(f_extra," if test \"$HNAME\" != \"\" -a -r $i/$HNAME ; then\n"
+ " INCDIR=\"$i\"\n"
+ " break\n"
+ " fi\n"
+ " done\n\n");
+ Printf(f_extra,
+ " dnl ** Now $INCDIR should be the include file path\n"
+ " if test \"$HNAME\" != \"\" -a -z \"$INCDIR\" ; then\n"
+ " AC_MSG_RESULT(Include files $HNAME not found)\n"
+ " else\n"
+ " AC_MSG_RESULT(Include files $HNAME found in $INCDIR)\n"
+ " PHP_ADD_INCLUDE($INCDIR)\n"
+ " fi\n\n",module);
+ if (CPlusPlus) Printf(f_extra,
+ " # As this is a C++ module..\n"
+ " PHP_REQUIRE_CXX\n"
+ " AC_CHECK_LIB(stdc++, cin)\n");
+ if (with) {
+ Printf(f_extra," if test \"$LIBSYMBOL\" != \"\" ; then\n"
+ " old_LIBS=\"$LIBS\"\n"
+ " LIBS=\"$LIBS -L$TEST_DIR/lib -lm -ldl\"\n"
+ " AC_CHECK_LIB($LIBNAME, $LIBSYMBOL, [AC_DEFINE(HAVE_TESTLIB,1, [ ])],\n"
+ " [AC_MSG_ERROR(wrong test lib version or lib not found)])\n"
+ " LIBS=\"$old_LIBS\"\n"
+ " fi\n\n");
+ Printf(f_extra," AC_DEFINE(HAVE_%(upper)s, 1, [ ])\n",module);
+ Printf(f_extra,"dnl AC_DEFINE_UNQUOTED(PHP_%(upper)s_DIR, \"$%(upper)s_DIR\", [ ])\n",module,module);
+ Printf(f_extra," PHP_EXTENSION(%s, $ext_shared)\n",module);
+ // and thats all!
+ Printf(f_extra,"fi\n");
+ Close(f_extra);
+ /* CREDITS */
+ f_extra = NewFile(credits, "w");
+ if (!f_extra) {
+ Printf(stderr,"Unable to open %s\n",credits);
+ Printf(f_extra, "%s\n", module);
+ Close(f_extra);
+ * top()
+ virtual int top(Node *n) {
+ String *filen;
+ String *s_type;
+#if 0 // TODO: move to main
+ if(!buildExceptionGraph(n))
+ return SWIG_ERROR;
+#endif
+ /* Initialize all of the output files */
+ String *outfile = Getattr(n,"outfile");
+ /* main output file */
+ f_runtime = NewFile(outfile,"w");
+ if (!f_runtime) {
+ Printf(stderr,"*** Can't open '%s'\n", outfile);
+ Swig_banner(f_runtime);
+ /* sections of the output file */
+ s_init = NewString("/* init section */\n");
+ s_header = NewString("/* header section */\n");
+ s_wrappers = NewString("/* wrapper section */\n");
+ s_type = NewString("");
+ /* subsections of the init section */
+ s_vinit = NewString("/* vinit subsection */\n");
+ s_vdecl = NewString("/* vdecl subsection */\n");
+ s_cinit = NewString("/* cinit subsection */\n");
+ s_oinit = NewString("/* oinit subsection */\n");
+ pragma_phpinfo = NewString("");
+ /* Register file targets with the SWIG file handler */
+ Swig_register_filebyname("runtime",f_runtime);
+ Swig_register_filebyname("init",s_init);
+ Swig_register_filebyname("header",s_header);
+ Swig_register_filebyname("wrapper",s_wrappers);
+ shadow_classdef = NewString("");
+ shadow_code = NewString("");
+ php_enum_code = NewString("");
+ module_baseclass = NewString("");
+ all_shadow_extra_code = NewString("");
+ all_shadow_import = NewString("");
+ all_shadow_baseclass = NewString("");
+ /* Set the module name */
+ module = Copy(Getattr(n,"name"));
+ cap_module = NewStringf("%(upper)s",module);
+ if(shadow) {
+ realpackage = module;
+ package = NewStringf("%sc", module);
+ /* Set the dlname */
+ if (!dlname) {
+#if defined(_WIN32) || defined(__WIN32__)
+ dlname = NewStringf("%s.dll", module);
+#else
+ dlname = NewStringf("%s.so", module);
+#endif
+ /* PHP module file */
+ filen = NewString("");
+ Printv(filen, SWIG_output_directory(), module, ".php", NIL);
+ phpfilename = NewString(filen);
+ f_phpcode = NewFile(filen, "w");
+ if (!f_phpcode) {
+ Printf(stderr, "*** Can't open '%s'\n", filen);
+ Printf(f_phpcode, "<?php\n\n");
+ Swig_banner(f_phpcode);
+ Printf(f_phpcode,
+ "global $%s_LOADED__;\n"
+ "if ($%s_LOADED__) return;\n"
+ "$%s_LOADED__ = true;\n\n"
+ "/* if our extension has not been loaded, do what we can */\n"
+ "if (!extension_loaded(\"php_%s\")) {\n"
+ " if (!dl(\"php_%s\")) return;\n"
+ "}\n\n", cap_module, cap_module, cap_module, module, dlname);
+ /* sub-sections of the php file */
+ pragma_code = NewString("");
+ pragma_incl = NewString("");
+ /* Initialize the rest of the module */
+ f_php = NewWrapper();// wots this used for now?
+ /* start the header section */
+ Printf(s_header, php_header);
+ Printf(s_header,
+ "#define SWIG_init init%s\n\n"
+ "#define SWIG_name \"%s\"\n"
+ /* "#ifdef HAVE_CONFIG_H\n"
+ "#include \"config.h\"\n"
+ "#endif\n\n"
+ "#ifdef __cplusplus\n"
+ "extern \"C\" {\n"
+ "#endif\n"
+ "#include \"php.h\"\n"
+ "#include \"php_ini.h\"\n"
+ "#include \"ext/standard/info.h\"\n"
+ "#include \"php_%s.h\"\n"
+ "}\n"
+ "#endif\n\n",
+ module, module, module);
+ /* Create the .h file too */
+ Printv(filen, SWIG_output_directory(), "php_", module, ".h", NIL);
+ f_h = NewFile(filen, "w");
+ if (!f_h) {
+ Printf(stderr,"Unable to open %s\n", filen);
+ Swig_banner(f_h);
+ Printf(f_h, php_header);
+ Printf(f_h, "\n\n"
+ "#ifndef PHP_%s_H\n"
+ "#define PHP_%s_H\n\n"
+ "extern zend_module_entry %s_module_entry;\n"
+ "#define phpext_%s_ptr &%s_module_entry\n\n"
+ "#ifdef PHP_WIN32\n"
+ "# define PHP_%s_API __declspec(dllexport)\n"
+ "#else\n"
+ "# define PHP_%s_API\n"
+ "#endif\n\n"
+ "PHP_MINIT_FUNCTION(%s);\n"
+ "PHP_MSHUTDOWN_FUNCTION(%s);\n"
+ "PHP_RINIT_FUNCTION(%s);\n"
+ "PHP_RSHUTDOWN_FUNCTION(%s);\n"
+ "PHP_MINFO_FUNCTION(%s);\n\n",
+ cap_module, cap_module, module, module, module, cap_module, cap_module,
+ module, module, module, module, module);
+ /* start the function entry section */
+ s_entry = NewString("/* entry subsection */\n");
+ /* holds all the per-class function entry sections */
+ all_cs_entry = NewString("/* class entry subsection */\n");
+ cs_entry = NULL;
+ Printf(s_entry,"/* Every non-class user visible function must have an entry here */\n");
+ //PHP 5.4+ changed this to zend_function_entry
+ Printf(s_entry,"zend_function_entry %s_functions[] = {\n", module);
+ /* start the init section */
+ if (gen_extra)
+ Printf(s_init,"#ifdef COMPILE_DL_%s\n", cap_module);
+ Printf(s_init,
+ "#endif\n"
+ "ZEND_GET_MODULE(%s)\n"
+ "}\n"
+ "#endif\n\n",
+ module);
+ if (gen_extra)
+ Printf(s_init,"#endif\n\n");
+ Printf(s_init,
+ "PHP_MSHUTDOWN_FUNCTION(%s)\n{\n"
+ " return SUCCESS;\n"
+ "}\n",
+ module);
+ /* We have to register the constants before they are (possibly) used
+ * by the pointer typemaps. This all needs re-arranging really as
+ * things are being called in the wrong order
+ Printf(s_init,"PHP_MINIT_FUNCTION(%s)\n{\n", module);
+ Printf(s_init,
+ " int i;\n"
+ " for (i = 0; swig_types_initial[i]; i++) {\n"
+ " swig_types[i] = SWIG_TypeRegister(swig_types_initial[i]);\n"
+ " }\n");
+ /* Emit all of the code */
+ Language::top(n);
+ SwigPHP7_emit_resource_registrations();
+// Printv(s_init,s_resourcetypes,NIL);
+ /* We need this after all classes written out by ::top */
+ Printf(s_oinit, "CG(active_class_entry) = NULL;\n");
+ Printf(s_oinit, "/* end oinit subsection */\n");
+ Printf(s_init, "%s\n", s_oinit);
+ /* Constants generated during top call */
+ // But save them for RINIT
+ Printf(s_cinit, "/* end cinit subsection */\n");
+ /* finish our init section which will have been used by class wrappers */
+ Printf(s_vinit, "/* end vinit subsection */\n");
+ Printf(s_init, " return SUCCESS;\n");
+ Printf(s_init,"}\n");
+ // Now do REQUEST init which holds cinit and vinit
+ Printf(s_init,
+ "PHP_RINIT_FUNCTION(%s)\n{\n",
+ module);
+ Printf(s_init, "%s\n", s_cinit);
+ Clear(s_cinit);
+ Printf(s_init, "%s\n", s_vinit);
+ Clear(s_vinit);
+ Printf(s_init,
+ "}\n");
+ Delete(s_cinit);
+ Delete(s_vinit);
+ Printf(s_init,
+ "PHP_RSHUTDOWN_FUNCTION(%s)\n{\n"
+ "}\n",
+ module);
+ Printf(s_init,
+ "PHP_MINFO_FUNCTION(%s)\n{\n"
+ "%s"
+ "}\n"
+ "/* end init section */\n",
+ module, pragma_phpinfo);
+ /* Complete header file */
+ Printf(f_h,
+ "/*If you declare any globals in php_%s.h uncomment this:\n"
+ "ZEND_BEGIN_MODULE_GLOBALS(%s)\n"
+ "ZEND_END_MODULE_GLOBALS(%s)\n"
+ "*/\n",
+ Printf(f_h,
+ "#ifdef ZTS\n"
+ "#define %s_D zend_%s_globals *%s_globals\n"
+ "#define %s_DC , %s_D\n"
+ "#define %s_C %s_globals\n"
+ "#define %s_CC , %s_C\n"
+ "#define %s_SG(v) (%s_globals->v)\n"
+ "#define %s_FETCH() zend_%s_globals *%s_globals "
+ "= ts_resource(%s_globals_id)\n"
+ "#else\n"
+ "#define %s_D\n"
+ "#define %s_DC\n"
+ "#define %s_C\n"
+ "#define %s_CC\n"
+ "#define %s_SG(v) (%s_globals.v)\n"
+ "#define %s_FETCH()\n"
+ "#endif\n\n"
+ "#endif /* PHP_%s_H */\n",
+ cap_module, module, module, cap_module, cap_module, cap_module, module,
+ cap_module, cap_module, cap_module, module, cap_module, module, module,
+ module, cap_module, cap_module, cap_module, cap_module, cap_module, module,
+ cap_module, cap_module);
+ Close(f_h);
+ Printf(s_header, "%s\n\n",all_cs_entry);
+ Printf(s_header,
+ "%s"
+ " {NULL, NULL, NULL}\n};\n\n"
+ "zend_module_entry %s_module_entry = {\n"
+ "#if ZEND_MODULE_API_NO > 20010900\n"
+ " STANDARD_MODULE_HEADER,\n"
+ "#endif\n"
+ " \"%s\",\n"
+ " %s_functions,\n"
+ " PHP_MINIT(%s),\n"
+ " PHP_MSHUTDOWN(%s),\n"
+ " PHP_RINIT(%s),\n"
+ " PHP_RSHUTDOWN(%s),\n"
+ " PHP_MINFO(%s),\n"
+ " NO_VERSION_YET,\n"
+ "#endif\n"
+ " STANDARD_MODULE_PROPERTIES\n"
+ "};\nzend_module_entry* SWIG_module_entry = &%s_module_entry;\n\n",
+ s_entry, module, module, module, module, module, module, module,module,module);
+ String *type_table = NewString("");
+ SwigType_emit_type_table(f_runtime,type_table);
+ Printf(s_header,"%s",type_table);
+ Delete(type_table);
+ /* Oh dear, more things being called in the wrong order. This whole
+ * function really needs totally redoing.
+ Printv(f_runtime, s_header, NIL);
+ // Wrapper_print(f_c, s_wrappers);
+ Wrapper_print(f_php, s_wrappers);
+ Printf(s_header, "/* end header section */\n");
+ Printf(s_wrappers, "/* end wrapper section */\n");
+ Printf(s_vdecl, "/* end vdecl subsection */\n");
+ extern String* getIdFilename, *catchAllCodeFilename;
+ if(getIdFilename)
+ Swig_insert_file(getIdFilename, s_vdecl);
+ if(catchAllCodeFilename)
+ Swig_insert_file(catchAllCodeFilename, s_vdecl);
+ emitThrowFunctionDefinition();
+ Printv(f_runtime, s_vdecl, s_wrappers, s_init, NIL);
+ Delete(s_header);
+ Delete(s_wrappers);
+ Delete(s_init);
+ Delete(s_vdecl);
+ Close(f_runtime);
+ Printf(f_phpcode, "%s\n%s\n?>\n", pragma_incl, pragma_code);
+ Close(f_phpcode);
+ create_extra_files(outfile);
+ if(!gen_extra && gen_make)
+ create_simple_make();
+ return SWIG_OK;
+/* Just need to append function names to function table to register with
+ PHP
+ void create_command(char *cname, char *iname) {
+// char *lower_cname = strdup(cname);
+// char *c;
+// for(c = lower_cname; *c != '\0'; c++) {
+// if(*c >= 'A' && *c <= 'Z')
+// *c = *c + 32;
+ Printf(f_h, "ZEND_NAMED_FUNCTION(%s);\n", iname);
+ // This is for the single main function_entry record
+ if (! cs_entry)
+ //now that we allow overloading, avoid more than one entry with the same name
+ string wrapName = string(iname);
+ if(methodEntries.find(wrapName) == methodEntries.end())
+ Printf(s_entry,
+ " ZEND_NAMED_FE(%(lower)s,\n"
+ " %s, NULL)\n", cname,iname);
+ methodEntries[wrapName] = true;
+// free(lower_cname);
+ * functionWrapper()
+virtual int functionWrapper(Node *n) {
+// virtual int wrapMethod(Node *n, char* methodName) {
+ char *name = GetChar(n,"name");
+ char *iname = GetChar(n,"sym:name");
+ SwigType *d = Getattr(n,"type");
+ ParmList *l = Getattr(n,"parms");
+ int newobject = (Getattr(n,"feature:new"))?1:0;
+ Parm *p;
+ char source[256],target[256],temp[256],argnum[32],args[32];
+ int i,numopt;
+ String *tm;
+ Wrapper *f;
+ int num_saved = (Getattr(n,"feature:new"))?1:0;
+ String *cleanup, *outarg;
+ bool mvr=(shadow && variable_wrapper_flag && !enum_flag);
+ bool mvrset=0;
+// if (!addSymbol(iname,n)) return SWIG_ERROR;
+ mvrset=(mvr && (strcmp(iname, Char(Swig_name_set(Swig_name_member(shadow_classname, name)))) == 0));
+ // if shadow and variable wrapper we want to snag the main contents
+ // of this function to stick in to the property handler....
+ if (mvr) { //shadow && variable_wrapper_flag && !enum_flag) {
+ String *member_function_name = NewString("");
+ String *php_function_name = NewString(iname);
+ if(strcmp(iname, Char(Swig_name_set(Swig_name_member(shadow_classname, name)))) == 0) {
+ Setattr(shadow_set_vars, php_function_name, name);
+ if(strcmp(iname, Char(Swig_name_get(Swig_name_member(shadow_classname, name)))) == 0) {
+ Setattr(shadow_get_vars, php_function_name, name);
+ Putc(toupper((int )*iname), member_function_name);
+ Printf(member_function_name, "%s", iname+1);
+ cpp_func(Char(member_function_name), d, l, php_function_name);
+ Delete(php_function_name);
+ Delete(member_function_name);
+ outarg = cleanup = NULL;
+ f = NewWrapper();
+ numopt = 0;
+ outarg = NewString("");
+ cleanup = NewString("");
+ // Special action for shadowing destructors under php.
+ // The real destructor is the resource list destructor, this is
+ // merely the thing that actually knows how to destroy...
+ if (destructor) {
+ String *destructorname=NewString("");
+ Printf(destructorname,"_%s",Swig_name_wrapper(iname));
+ Setattr(classnode,"destructor",destructorname);
+ Wrapper *df = NewWrapper();
+ Printf(df->def,"/* This function is designed to be called by the zend list destructors to typecast and do the actual destruction */\n"
+ "void %s(zend_rsrc_list_entry *rsrc, const char *type_name TSRMLS_DC) {\n",destructorname);
+ Wrapper_add_localv(df, "value", "swig_object_wrapper *value=(swig_object_wrapper *) rsrc->ptr", NIL);
+ Wrapper_add_localv(df, "ptr", "void *ptr=value->ptr", NIL);
+ Wrapper_add_localv(df, "newobject", "int newobject=value->newobject", NIL);
+ // Magic spell nicked from further down.
+ emit_args(d, l, df);
+ emit_attach_parmmaps(l,f);
+ // Get type of first arg, thing to be destructed
+ // Skip ignored arguments
+ p=l;
+ //while (Getattr(p,"tmap:ignore")) {p = Getattr(p,"tmap:ignore:next");}
+ while (checkAttribute(p,"tmap:in:numinputs","0")) {
+ p = Getattr(p,"tmap:in:next");
+ SwigType *pt = Getattr(p,"type");
+ Printf(df->code,
+ " efree(value);\n"
+ " if (! newobject) return; /* can't delete it! */\n"
+ " SWIG_ZTS_ConvertResourceData(ptr,rsrc->type,type_name,(void **) &arg1,SWIGTYPE%s TSRMLS_CC);\n"
+ " if (! arg1) zend_error(E_ERROR, \"%s resource already free'd\");\n"
+ ,SwigType_manglestr(pt), shadow_classname);
+ emit_action(n,df);
+ if(disposeCode)
+ Replaceall(df->code, "delete arg1", disposeCode);
+ Printf(df->code,"}\n");
+ Wrapper_print(df,s_wrappers);
+ if (mvr) { // do prop[gs]et header
+ if (mvrset) Printf(f->def, "static int _wrap_%s(zend_property_reference *property_reference, pval *value) {\n",iname);
+ else Printf(f->def, "static pval _wrap_%s(zend_property_reference *property_reference) {\n",iname);
+ } else { // regular header
+ string methodname = string(iname);
+ if(Getattr(n,"sym:overloaded"))
+ vector<Parameter*>* parms = new vector<Parameter*>;
+ int argcount = 0;
+ for(Parm* pm = l; pm != NULL; pm = nextSibling(pm))
+ String* typeStr = Getattr(pm, "type");
+ int type = SwigType_type(typeStr);
+ String* pname = Getattr(pm, "name");
+ if(pname != NULL && !Strcmp(pname, "self"))
+ continue;
+ parms->push_back(new Parameter(type, string(Char(typeStr))));
+ argcount++;
+ string qualifiedName = Char(Swig_name_wrapper(iname));
+ map<string, vector<OverloadedFunc7*>*>::const_iterator it = overloads.find(qualifiedName);
+ vector<OverloadedFunc7*>* lstOver = it != overloads.end()? it->second: NULL;
+ if(lstOver == NULL)
+ lstOver = new vector<OverloadedFunc7*>;
+ overloads[qualifiedName] = lstOver;
+ char idx[10];
+ sprintf(idx, "%d", lstOver->size() + 1);
+ string mangledName = string(Char(Swig_name_wrapper(iname))) + "_" + idx;
+ OverloadedFunc7* fi = new OverloadedFunc7(mangledName, argcount, parms);
+ lstOver->push_back(fi);
+ methodname = mangledName;
+ else
+ methodname = string(Char(Swig_name_wrapper(iname)));
+ create_command(iname, Char(Swig_name_wrapper(iname)));
+ //Printv(f->def, "ZEND_NAMED_FUNCTION(" , Swig_name_wrapper(methodName), ") {\n", NIL);
+ Printv(f->def, "ZEND_NAMED_FUNCTION(" , methodname.c_str(), ") {\n", NIL);
+ emit_args(d, l, f);
+ /* Attach standard typemaps */
+ int num_arguments = emit_num_arguments(l);
+ int num_required = emit_num_required(l);
+ numopt = num_arguments - num_required;
+ // we do +1 because we are going to push in this_ptr as arg0 if present
+ // or do we need to?
+ sprintf(args, "%s[%d]", "zval **args", num_arguments+1);
+ Wrapper_add_local(f, "args",args);
+ Wrapper_add_localv(f, "argbase", "int argbase=0", NIL);
+ // This generated code may be called
+ // 1) as an object method, or
+ // 2) as a class-method/function (without a "this_ptr")
+ // Option (1) has "this_ptr" for "this", option (2) needs it as
+ // first parameter
+ // NOTE: possible we ignore this_ptr as a param for native constructor
+ if (native_constructor) {
+ if (native_constructor==NATIVE_CONSTRUCTOR) Printf(f->code, "/* NATIVE Constructor */\nint self_constructor=1;\n");
+ else Printf(f->code, "/* ALTERNATIVE Constructor */\n");
+ if (mvr && ! mvrset) {
+ Wrapper_add_local(f, "_return_value", "zval _return_value");
+ Wrapper_add_local(f, "return_value", "zval *return_value=&_return_value");
+ // only let this_ptr count as arg[-1] if we are not a constructor
+ // if we are a constructor and this_ptr is null we are called as a class
+ // method and can make one of us
+ if (! mvr && native_constructor==0) Printf(f->code,
+ "if (this_ptr && this_ptr->type==IS_OBJECT) {\n"
+ " /* fake this_ptr as first arg (till we can work out how to do it better */\n"
+ " argbase++;\n"
+ "}\n");
+ // I'd like to write out:
+ //" //args[argbase++]=&this_ptr;\n"
+ // but zend_get_parameters_array_ex can't then be told to leave
+ // the first slot alone, so we have to check whether or not to access
+ // this_ptr explicitly in each case where we normally just read args[]
+ if(numopt > 0) { // membervariable wrappers do not have optional args
+ Wrapper_add_local(f, "arg_count", "int arg_count");
+ Printf(f->code,
+ "arg_count = ZEND_NUM_ARGS();\n"
+ "if(arg_count<(%d-argbase) || arg_count>(%d-argbase))\n"
+ "\tWRONG_PARAM_COUNT;\n\n",
+ num_required, num_arguments);
+ /* Verified args, retrieve them... */
+ Printf(f->code,
+ "if(zend_get_parameters_array_ex(arg_count-argbase,args)!=SUCCESS)"
+ "\n\t\tWRONG_PARAM_COUNT;\n\n");
+ } else if (!mvr) {
+ Printf(f->code,
+ "if(((ZEND_NUM_ARGS() + argbase )!= %d) || (zend_get_parameters_array_ex(%d-argbase, args)"
+ "!= SUCCESS)) {\n"
+ "WRONG_PARAM_COUNT;\n}\n\n",
+ num_arguments, num_arguments);
+ /* Now convert from php to C variables */
+ // At this point, argcount if used is the number of deliberatly passed args
+ // not including this_ptr even if it is used.
+ // It means error messages may be out by argbase with error
+ // reports. We can either take argbase into account when raising
+ // errors, or find a better way of dealing with _thisptr
+ // I would like, if objects are wrapped, to assume _thisptr is always
+ // _this and the and not the first argument
+ // This may mean looking at Lang::memberfunctionhandler
+ for (i = 0, p = l; i < num_arguments; i++) {
+ /* Skip ignored arguments */
+ //while (Getattr(p,"tmap:ignore")) { p = Getattr(p,"tmap:ignore:next");}
+ if (mvr) { // do we assert that numargs=2, that i<2
+ if (i==0) sprintf(source,"&(property_reference->object)");
+ else sprintf(source,"&value");
+ } else {
+ // Do we fake this_ptr as arg0, or just possibly shift other args by 1 if we did fake?
+ if (i==0) sprintf(source, "((%d<argbase)?(&this_ptr):(args[%d-argbase]))", i, i);
+ else sprintf(source, "args[%d-argbase]", i); }
+ sprintf(target, "%s", Char(Getattr(p,"lname")));
+ sprintf(argnum, "%d", i+1);
+ /* Check if optional */
+ if(i>= (num_required))
+ Printf(f->code,"\tif(arg_count > %d) {\n", i);
+ Setattr(p,"emit:input", source);
+ if ((tm = Getattr(p,"tmap:in"))) {
+ Replaceall(tm,"$target",target);
+ Replaceall(tm,"$source",source);
+ Replaceall(tm,"$input", source);
+ Printf(f->code,"%s\n",tm);
+ if (i >= num_required) {
+ Printf(f->code,"}\n");
+ continue;
+ } else {
+ Printf(stderr,"%s : Line %d, Unable to use type %s as a function argument.\n", input_file, line_number, SwigType_str(pt,0));
+ if (i>= num_required)
+ Printf(f->code,"\t}\n");
+ /* Insert constraint checking code */
+ for (p = l; p;) {
+ if ((tm = Getattr(p,"tmap:check"))) {
+ Replaceall(tm,"$target",Getattr(p,"lname"));
+ Printv(f->code,tm,"\n",NIL);
+ p = Getattr(p,"tmap:check:next");
+ } else {
+ p = nextSibling(p);
+ /* Insert cleanup code */
+ for (i = 0, p = l; p; i++) {
+ if ((tm = Getattr(p,"tmap:freearg"))) {
+ Replaceall(tm,"$source",Getattr(p,"lname"));
+ Printv(cleanup,tm,"\n",NIL);
+ p = Getattr(p,"tmap:freearg:next");
+ } else {
+ /* Insert argument output code */
+ num_saved = 0;
+ for (i=0,p = l; p;i++) {
+ if ((tm = Getattr(p,"tmap:argout"))) {
+ Replaceall(tm,"$input",Getattr(p,"lname"));
+ Replaceall(tm,"$target","return_value");
+ Replaceall(tm,"$result","return_value");
+ String *in = Getattr(p,"emit:input");
+ if (in) {
+ sprintf(temp,"_saved[%d]", num_saved);
+ Replaceall(tm,"$arg",temp);
+ Printf(f->code,"_saved[%d] = %s;\n", num_saved, in);
+ num_saved++;
+ Printv(outarg,tm,"\n",NIL);
+ p = Getattr(p,"tmap:argout:next");
+ } else {
+ // These are saved for argout again...
+ if(num_saved) {
+ sprintf(temp, "_saved[%d]",num_saved);
+ // Used to be zval *, perhaps above we should use * %s
+ Wrapper_add_localv(f,"_saved","zval **",temp,NIL);
+ Printf(f->code, "try\n");
+ Printf(f->code, "{\n");
+ /* emit function call*/
+ if (destructor) {
+ // If it is a registered resource (and it always should be)
+ // then destroy it the resource way
+ Printf(f->code,
+ "if (this_ptr->type==IS_OBJECT) {\n"
+ "zval ** _cPtr;\n"
+ "if (zend_hash_find(HASH_OF(this_ptr),\"_cPtr\",sizeof(\"_cPtr\"),(void**)&_cPtr)==SUCCESS) {\n"
+ "if ((*_cPtr)->type==IS_RESOURCE) {\n"
+ "zend_list_delete(Z_LVAL_PP(_cPtr));\n"
+ "} } }\n",name,name);
+ // but leave the old way in for as long as we accept strings as swig objects
+ emit_action(n,f);
+ // Never delete directly. Always let the resource destruction mechanism
+ // do this. Do not emit any code but put a placeholder here just in case
+ // this change breaks something else.
+ if(disposeCode)
+ Replaceall(f->code, "delete arg1", "/* delete arg1; //Resource destructor should handle this*/" /*disposeCode*/);
+ Printf(f->code,"/*}*/\n");
+ } else {
+ emit_action(n,f);
+ if((tm = Swig_typemap_lookup((char*)"out",d,iname,(char*)"result",(char*)"result",(char*)"return_value",0))) {
+ Replaceall(tm, "$input", "result");
+ Replaceall(tm, "$source", "result");
+ Replaceall(tm, "$target", "return_value");
+ Replaceall(tm, "$result", "return_value");
+ Replaceall(tm,"$owner", newobject ? "1" : "0");
+ bool returnObject = is_shadow(d) && SwigType_type(d) != T_ARRAY && native_constructor!= NATIVE_CONSTRUCTOR;
+ if(returnObject && enableRuntimeTypeChecking)
+ //TODO see if we can check if this base class has derived class. If no derived class
+ // we could generate the usual code (currently in tm) without trying to instantiate a derived class wrapper
+ String *tpname = NewString("");
+ SwigToPhpType(d, iname, tpname, shadow);
+ Printf(f->code, "ClsInfo* clsInfo=NULL;if(result!=NULL){clsInfo=classMap[getClassId(result)];\n");
+ Printf(f->code, "if(clsInfo == NULL)\nzend_error(E_ERROR,\"The class %s (or one of its derived classes) has no runtime type id\");\n", tpname);
+ // All classes are "new" as far as PHP is concerned and require eventual destruction
+ Printf(f->code, "else SWIG_SetPointerZval(return_value, (void *)result, clsInfo->pTypeInfo, 1);} else{ZVAL_LONG(return_value,0); return;} \n");
+ else
+ Printf(f->code, "%s\n", tm);
+ // are we returning a wrapable object?
+ // I don't know if this test is comlete, I nicked it
+ if(is_shadow(d) && (SwigType_type(d) != T_ARRAY)) {
+ Printf(f->code,"/* Wrap this return value */\n");
+ if (native_constructor==NATIVE_CONSTRUCTOR) {
+ Printf(f->code, "if (this_ptr) {\n/* NATIVE Constructor, use this_ptr */\n");
+ Printf(f->code,"zval *_cPtr; MAKE_STD_ZVAL(_cPtr);\n"
+ "*_cPtr = *return_value;\n"
+ "INIT_ZVAL(*return_value);\n"
+ "add_property_zval(this_ptr,\"_cPtr\",_cPtr);\n"
+ "} else if (! this_ptr) ",shadow_classname);
+ { // THIS CODE only really needs writing out if the object to be returned
+ // Is being shadow-wrap-thingied
+ Printf(f->code, "{\n/* ALTERNATIVE Constructor, make an object wrapper */\n");
+ // Make object
+ String *shadowrettype = NewString("");
+ SwigToPhpType(d, iname, shadowrettype, shadow);
+ Printf(f->code,
+ "zval *obj, *_cPtr;\n"
+ "MAKE_STD_ZVAL(obj);\n"
+ "MAKE_STD_ZVAL(_cPtr);\n"
+ "INIT_ZVAL(*return_value);\n");
+ if (! shadow) {
+ Printf(f->code,
+ "*return_value=*_cPtr;\n");
+ } else {
+ Printf(f->code,
+ "object_init_ex(obj,clsInfo? clsInfo->pCls: ptr_ce_swig_%s);\n"
+ "add_property_zval(obj,\"_cPtr\",_cPtr);\n"
+ "*return_value=*obj;\n",
+ shadowrettype);
+ else
+ Printf(f->code,
+ "object_init_ex(obj,ptr_ce_swig_%s);\n"
+ shadowrettype);
+ Printf(f->code, "}\n");
+ } // end of if-shadow lark
+ } else {
+ Printf(stderr,"%s: Line %d, Unable to use return type %s in function %s.\n", input_file, line_number, SwigType_str(d,0), name);
+ if(outarg)
+ Printv(f->code,outarg,NIL);
+ if(cleanup)
+ Printv(f->code,cleanup,NIL);
+ // Whats this bit for?
+ if((tm = Swig_typemap_lookup((char*)"ret",d,iname,(char *)"result", (char*)"result",(char*)"",0))) {
+ Printf(f->code,"%s\n", tm);
+ Replaceall(f->code,"$cleanup",cleanup);
+ Replaceall(f->code,"$symname",iname);
+ Printf(f->code, "catch(%s *e)\n", baseException);
+ Printf(f->code, "\tThrowPHPExceptionWrapper(e TSRMLS_CC);\n");
+ Printf(f->code, "} catch(...) { onCatchAll(\"%s\" TSRMLS_CC); }\n", iname);
+ if (mvr) {
+ if (! mvrset) Printf(f->code,"return _return_value;\n");
+ else Printf(f->code,"return SUCCESS;\n");
+ Wrapper_print(f,s_wrappers);
+ return SWIG_OK;
+ * variableWrapper()
+ virtual int OLDvariableWrapper(Node *n) {
+ SwigType *t = Getattr(n,"type");
+ String *tm;
+ if (!addSymbol(iname,n)) return SWIG_ERROR;
+ /* First link C variables to PHP */
+ tm = Swig_typemap_lookup_new("varinit", n, name, 0);
+ if(tm) {
+ Replaceall(tm, "$target", name);
+ Printf(s_vinit, "%s\n", tm);
+ } else {
+ Printf(stderr,"%s: Line %d, Unable to link with type %s\n",
+ input_file, line_number, SwigType_str(t,0), name);
+ /* Now generate PHP -> C sync blocks */
+ tm = Swig_typemap_lookup_new("varin", n, name, 0);
+ if(tm) {
+ Replaceall(tm, "$symname", iname);
+ Printf(f_c->code, "%s\n", tm);
+ } else {
+ input_file, line_number, SwigType_str(t, 0), name);
+ /* Now generate C -> PHP sync blocks */
+ if(!Getattr(n,"feature:immutable")) {
+ tm = Swig_typemap_lookup_new("varout", n, name, 0);
+ if(tm) {
+ Printf(f_php->code, "%s\n", tm);
+ } else {
+ return SWIG_OK;
+ * constantWrapper()
+ virtual int constantWrapper(Node *n) {
+ SwigType *type = Getattr(n,"type");
+ char *value = GetChar(n,"value");
+ String *rval;
+ String *tm;
+ SwigType_remember(type);
+ switch(SwigType_type(type)) {
+ case T_STRING:
+ rval = NewStringf("\"%s\"", value);
+ break;
+ case T_CHAR:
+ rval = NewStringf("\'%s\'", value);
+ break;
+ default:
+ rval = NewString(value);
+ if((tm = Swig_typemap_lookup_new("consttab", n, name, 0))) {
+ Replaceall(tm, "$source", value);
+ Replaceall(tm, "$value", value);
+ Printf(s_oinit, "%s\n", tm);
+ return SWIG_OK;
+ * PHP7::pragma()
+ * Pragma directive.
+ * %pragma(php7) code="String" # Includes a string in the .php file
+ * %pragma(php7) include="file.pl" # Includes a file in the .php file
+ virtual int pragmaDirective(Node *n) {
+ if (!ImportMode) {
+ String *lang = Getattr(n,"lang");
+ String *type = Getattr(n,"name");
+ String *value = Getattr(n,"value");
+ if (Strcmp(lang,"php") == 0) {
+ if (Strcmp(type, "code") == 0) {
+ if (value)
+ Printf(pragma_code, "%s\n", value);
+ } else if (Strcmp(type, "include") == 0) {
+ if (value)
+ Printf(pragma_incl, "include \"%s\";\n", value);
+ } else if (Strcmp(type, "phpinfo") == 0) {
+ if (value)
+ Printf(pragma_phpinfo, "%s\n", value);
+ } else {
+ Printf(stderr, "%s : Line %d. Unrecognized pragma.\n",
+ input_file, line_number);
+ return Language::pragmaDirective(n);
+ * classDeclaration()
+ virtual int classDeclaration(Node *n) {
+ String *symname = Getattr(n,"sym:name");
+ Setattr(n,"php:proxy",symname);
+ return Language::classDeclaration(n);
+ int typeToPhpType(int type)
+ switch(type)
+ case T_BOOL:
+ return IS_BOOL;
+ case T_CHAR:
+ case T_SCHAR:
+ case T_UCHAR:
+ case T_SHORT:
+ case T_USHORT:
+ case T_INT:
+ case T_UINT:
+ case T_LONG:
+ case T_ULONG:
+ case T_LONGLONG:
+ case T_ULONGLONG:
+ return IS_LONG;
+ case T_FLOAT:
+ case T_DOUBLE:
+ return IS_DOUBLE;
+ case T_STRING:
+ return IS_STRING;
+ case T_USER:
+ case T_POINTER:
+ return IS_OBJECT;
+ default:
+ return IS_NULL;
+ string getClassNameFromType(string& type)
+ const char* sep = strrchr(type.c_str(), '.');
+ if(sep == NULL)
+ return string("");
+ return string(sep + 1);
+ string getZendClassNameFromType(string& type)
+ string retVal = getClassNameFromType(type);
+ for (int i = 0; i < retVal.size(); i++)
+ retVal[i] = ::tolower(retVal[i]);
+ return retVal;
+ * classHandler()
+ virtual int classHandler(Node *n) {
+ constructors=0;
+ //SwigType *t = Getattr(n, "classtype");
+ if(class_name) free(class_name);
+ class_name = Swig_copy_string(GetChar(n, "name"));
+ // String *use_class_name=SwigType_manglestr(SwigType_ltype(t));
+ List *baselist = Getattr(n, "bases");
+ Iterator base;
+ overloads.clear();
+ if(shadow) {
+ char *rename = GetChar(n, "sym:name");
+ if (!addSymbol(rename,n)) return SWIG_ERROR;
+ shadow_classname = Swig_copy_string(rename);
+ cs_entry = NewString("");
+ Printf(cs_entry,"/* Function entries for %s */\n"
+ "static zend_function_entry %s_functions[] = {\n"
+ ,shadow_classname, shadow_classname);
+ if(Strcmp(shadow_classname, module) == 0) {
+ Printf(stderr, "class name cannot be equal to module name: %s\n", shadow_classname);
+ SWIG_exit(1);
+ Clear(shadow_classdef);
+ Clear(shadow_code);
+ have_default_constructor = 0;
+ shadow_enum_code = NewString("");
+ this_shadow_baseclass = NewString("");
+ this_shadow_multinherit = NewString("");
+ this_shadow_extra_code = NewString("");
+ this_shadow_import = NewString("");
+ shadow_get_vars = NewHash();
+ shadow_set_vars = NewHash();
+ /* Deal with inheritance */
+ if(baselist) {
+ int class_count = 0;
+ Iterator base = First(baselist);
+ while(base.item && Getattr(base.item,"feature:ignore")) base = Next(base);
+ if (base.item && is_shadow(Getattr(base.item, "name"))) {
+ class_count++;
+ Printf(this_shadow_baseclass, "%s", Getattr(base.item, "name"));
+ if (base.item) for(base = Next(base); base.item; base = Next(base)) {
+ if (Getattr(base.item,"feature:ignore")) continue;
+ if(is_shadow(Getattr(base.item, "name"))) {
+ class_count++;
+ Printf(this_shadow_multinherit, "%s ", Getattr(base.item, "name"));
+ if(class_count > 1) Printf(stderr, "Error: %s inherits from multiple base classes(%s %s). SWIG doesn;t support multiple inheritance.\n", shadow_classname, base.item, this_shadow_multinherit);
+ /* Write out class init code */
+ Printf(s_vdecl,"static zend_class_entry ce_swig_%s;\n",shadow_classname);
+ Printf(s_vdecl,"static zend_class_entry* ptr_ce_swig_%s=NULL;\n",shadow_classname);
+ classnode=n;
+ Language::classHandler(n);
+ classnode=0;
+ for(map<string, vector<OverloadedFunc7*>*>::const_iterator it = overloads.begin(); it != overloads.end(); it++)
+ string qualifiedName = it->first;
+ vector<OverloadedFunc7*>* listOver = it->second;
+ Printv(s_wrappers, "ZEND_NAMED_FUNCTION(", qualifiedName.c_str(), ")\n{\n", NIL);
+ Printf(s_wrappers, "\tint numArgs = ZEND_NUM_ARGS();\n");
+ map<int, vector<OverloadedFunc7*>*> identicalArgCount;
+ list<OverloadedFunc7*> simpleFuncs;
+ bool isIdenticalCount = false;
+ int maxArgs = -1;
+ int count1 = listOver->size();
+ for(vector<OverloadedFunc7*>::const_iterator it1 = listOver->begin(); it1 != listOver->end(); it1++)
+ OverloadedFunc7* of = *it1;
+ if(of->argcount > maxArgs)
+ maxArgs = of->argcount;
+ bool uniqueNumber = true;
+ for(vector<OverloadedFunc7*>::const_iterator it2 = listOver->begin(); it2 != listOver->end(); it2++)
+ OverloadedFunc7* of2 = *it2;
+ if(of2 != of && of->argcount == of2->argcount)
+ vector<OverloadedFunc7*>* sameArgs = identicalArgCount[of->argcount];
+ if(sameArgs == NULL)
+ sameArgs = new vector<OverloadedFunc7*>;
+ identicalArgCount[of->argcount] = sameArgs;
+ else
+ isIdenticalCount = true;
+ sameArgs->push_back(of);
+ uniqueNumber = false;
+ break;
+ if(uniqueNumber)
+ simpleFuncs.push_back(of);
+ if(isIdenticalCount)
+ Printf(s_wrappers, "\tzval **args[%d];\n", maxArgs);
+ Printf(s_wrappers, "\tif(zend_get_parameters_array_ex(numArgs, args)!= SUCCESS)\n");
+ Printf(s_wrappers, "\t\tWRONG_PARAM_COUNT;\n\n");
+ Printf(s_wrappers, "\tswitch(numArgs)\n\t{\n");
+ //first the simple functions
+ for(list<OverloadedFunc7*>::const_iterator it = simpleFuncs.begin(); it != simpleFuncs.end(); it++)
+ OverloadedFunc7* of = *it;
+ Printf(s_wrappers, "\tcase %d:\n\t\t%s(INTERNAL_FUNCTION_PARAM_PASSTHRU);\n\t\tbreak;\n", of->argcount, of->mangledName.c_str());
+ //go through methods with the same number of arguments, by groups
+ for(map<int, vector<OverloadedFunc7*>*>::const_iterator it = identicalArgCount.begin(); it != identicalArgCount.end(); it++)
+ int argcount = it->first;
+ vector<OverloadedFunc7*>* overloads = it->second;
+ Printf(s_wrappers, "\tcase %d:\n\t{\n", argcount);
+ if(argcount == 0)
+ Printf(stderr, "Two overloads with no parameters (%s)", (*overloads->begin())->mangledName.c_str());
+ for(int arg = 0; arg < argcount; arg ++)
+ vector<OverloadedFunc7*> objectArgsFunc;
+ for(vector<OverloadedFunc7*>::const_iterator it1 = overloads->begin(); it1 != overloads->end(); it1++)
+ OverloadedFunc7* m = *it1;
+ if(m->done)
+ continue;
+ Parameter* p = m->parms->at(arg);
+ int type = p->type;
+ int phpType = typeToPhpType(type);
+ bool sameType = false;
+ int count = 0;
+ bool multipleObjectParam = false;
+ map<OverloadedFunc7*, bool> done;
+ for(vector<OverloadedFunc7*>::const_iterator it2 = overloads->begin(); it2 != overloads->end(); it2++, count ++)
+ OverloadedFunc7* m2 = *it2;
+ if(m != m2)
+ Parameter* p2 = m2->parms->at(arg);
+ int type2 = p2->type;
+ int phpType2 = typeToPhpType(type2);
+ if(phpType == phpType2)
+ if(phpType == IS_OBJECT)
+ //type are the same if classes are the same
+ if(getClassNameFromType(p->typeStr) == getClassNameFromType(p2->typeStr))
+ sameType = true;
+ multipleObjectParam = true;
+ else
+ sameType = true;
+ break;
+ if(!sameType)
+ switch(phpType)
+ case IS_NULL:
+ Printf(stderr, "Unknown overloaded type for argument %d (%s)", arg, (*overloads->begin())->mangledName.c_str());
+ case IS_LONG:
+ Printf(s_wrappers, "\t\tif((*args[%d])->type == IS_LONG)\n\t\t{\n\t\t\t%s(INTERNAL_FUNCTION_PARAM_PASSTHRU);\n\t\t\treturn;\n\t\t}\n", arg, m->mangledName.c_str());
+ break;
+ case IS_DOUBLE:
+ Printf(s_wrappers, "\t\tif((*args[%d])->type == IS_DOUBLE)\n\t\t{\n\t\t\t%s(INTERNAL_FUNCTION_PARAM_PASSTHRU);\n\t\t\treturn;\n\t\t}\n", arg, m->mangledName.c_str());
+ break;
+ case IS_STRING:
+ Printf(s_wrappers, "\t\tif((*args[%d])->type == IS_STRING)\n\t\t{\n\t\t\t%s(INTERNAL_FUNCTION_PARAM_PASSTHRU);\n\t\t\treturn;\n\t\t}\n", arg, m->mangledName.c_str());
+ break;
+ case IS_OBJECT:
+ if(!multipleObjectParam)
+ Printf(s_wrappers, "\t\tif((*args[%d])->type == IS_OBJECT)\n\t\t{\n\t\t\t%s(INTERNAL_FUNCTION_PARAM_PASSTHRU);\n\t\t\treturn;\n\t\t}\n", arg, m->mangledName.c_str());
+ else
+ objectArgsFunc.push_back(m);
+ break;
+ case IS_BOOL:
+ Printf(s_wrappers, "\t\tif((*args[%d])->type == IS_BOOL)\n\t\t{\n\t\t\t%s(INTERNAL_FUNCTION_PARAM_PASSTHRU);\n\t\t\treturn;\n\t\t}\n", arg, m->mangledName.c_str());
+ break;
+ m->done = true;
+ else
+ if(arg == argcount - 1)
+ Printf(stderr, "Couldn't distinguish between to overloads based on type of parameters (%s)", qualifiedName.c_str());
+ for(int idx = 0; idx < (int)overloads->size(); )
+ if(overloads->at(idx)->done)
+ overloads->erase(overloads->begin() + idx);
+ else
+ ++idx;
+ if(objectArgsFunc.size())
+ Printf(s_wrappers, "\t\tif((*args[%d])->type == IS_OBJECT)\n", arg);
+ Printf(s_wrappers, "\t\t{\n");
+ Printf(s_wrappers, "\t\t\tzval ** _cPtr;\n");
+ Printf(s_wrappers, "\t\t\tif (zend_hash_find(HASH_OF(*args[%d]),\"_cPtr\",sizeof(\"_cPtr\"),(void**)&_cPtr)!=SUCCESS)\n", arg);
+ Printf(s_wrappers, "\t\t\t\tzend_error(E_ERROR, \"Error in getting C++ pointer (%s)\");\n", qualifiedName.c_str());
+ Printf(s_wrappers, "\t\t\tvoid *p;\n");
+ Printf(s_wrappers, "\t\t\tint type;\n");
+ Printf(s_wrappers, "\t\t\tswig_object_wrapper *value = (swig_object_wrapper *) zend_list_find((*_cPtr)->value.lval,&type);\n");
+ Printf(s_wrappers, "\t\t\tp = value->ptr;\n");
+ Printf(s_wrappers, "\t\t\tint clsId = getClassId(p);\n");
+ Printf(s_wrappers, "\t\t\tClsInfo* clsInfo = classMap[getClassId(p)];\n");
+ Printf(s_wrappers, "\t\t\tif(clsInfo == NULL)\n");
+ Printf(s_wrappers, "\t\t\t\tzend_error(E_ERROR, \"Unknown C++ pointer type (passed to %s)\");\n", qualifiedName.c_str());
+ Printf(s_wrappers, "\t\t\telse\n");
+ Printf(s_wrappers, "\t\t\t{\n");
+ bool first = false;
+ for(vector<OverloadedFunc7*>::const_iterator it = objectArgsFunc.begin(); it != objectArgsFunc.end(); it++)
+ OverloadedFunc7* m = *it;
+ Printf(s_wrappers, "\t\t\t\tif(!strcmp(clsInfo->pTypeInfo->name, \"_p_%s\"))\n", getClassNameFromType(m->parms->at(arg)->typeStr).c_str());
+ Printf(s_wrappers, "\t\t\t\t{\n");
+ Printf(s_wrappers, "\t\t\t\t\t%s(INTERNAL_FUNCTION_PARAM_PASSTHRU);\n", m->mangledName.c_str());
+ Printf(s_wrappers, "\t\t\t\t\treturn;\n");
+ Printf(s_wrappers, "\t\t\t\t}\n");
+ Printf(s_wrappers, "\t\t\t\telse if(clsInfo->pCls->parent && !strcmp(clsInfo->pCls->parent->name, \"%s\"))\n", getZendClassNameFromType(m->parms->at(arg)->typeStr).c_str());
+ Printf(s_wrappers, "\t\t\t}\n");
+ Printf(s_wrappers, "\t\t}\n");
+ Printf(s_wrappers, "\t\tzend_error(E_ERROR, \"Arguments passed did not match any overload for method %s\");\n", qualifiedName.c_str());
+ Printf(s_wrappers, "\t\tbreak;\n\t}\n");
+ //default case, the number of argument does not match any overloaded methods
+ Printf(s_wrappers, "\tdefault:\n\t\tzend_error(E_ERROR, \"No overload of %s take %%d arguments)\", numArgs);\n\t\tbreak;\n", qualifiedName.c_str());
+ Printf(s_wrappers, "\t}\n"); //end of switch
+ Printf(s_wrappers, "}\n\n"); //end of function
+ if(shadow) {
+ String *s_propget=NewString("");
+ String *s_propset=NewString("");
+ // If no constructor was generated (abstract class) we had better
+ // generate a constructor that raises an error about instantiating
+ // abstract classes
+ if (! constructors || Getattr(n,"abstract")) {
+ // have to write out fake constructor which raises an error when called
+ abstractConstructorHandler(n);
+ Printf(s_oinit,"/* Define class %s */\n"
+ "INIT_OVERLOADED_CLASS_ENTRY(ce_swig_%s,\"%(lower)s\",%s_functions,"
+ "NULL,NULL,NULL);\n",
+ shadow_classname,shadow_classname,shadow_classname,
+ shadow_classname);
+ // Save class in class table
+ if (baselist) base=First(baselist);
+ else base.item=NULL;
+ if (base.item) {
+ Printf(s_oinit,"if (! (ptr_ce_swig_%s=zend_register_internal_class_ex(&ce_swig_%s,ptr_ce_swig_%s,NULL TSRMLS_CC))) zend_error(E_ERROR,\"Error registering wrapper for class %s\");\n",
+ shadow_classname,shadow_classname,GetChar(base.item, "sym:name"), shadow_classname);
+ } else {
+ Printf(s_oinit,"if (! (ptr_ce_swig_%s=zend_register_internal_class_ex(&ce_swig_%s,zend_exception_get_default(TSRMLS_C),NULL TSRMLS_CC))) zend_error(E_ERROR,\"Error registering wrapper for class %s\");\n",
+ shadow_classname,shadow_classname, shadow_classname);
+ if(enableRuntimeTypeChecking)
+ map<string, int>::const_iterator iter = clsIds.find(Char(class_name));
+ if(iter != clsIds.end())
+ Printf(s_oinit,"classMap[%d] = new ClsInfo(SWIGTYPE_p_%s, ptr_ce_swig_%s);\n", iter->second, class_name, class_name);
+ Printf(s_oinit,"\n");
+ // Write the enum initialisation code in a static block
+ // These are all the enums defined withing the c++ class.
+ // PHP Needs to handle shadow enums properly still
+ if(strlen(Char(shadow_enum_code)) != 0 ) Printv(f_phpcode, "{\n /* enum */\n", shadow_enum_code, " }\n", NIL);
+ free(shadow_classname);
+ shadow_classname = NULL;
+ Delete(shadow_enum_code); shadow_enum_code = NULL;
+ Delete(this_shadow_baseclass); this_shadow_baseclass = NULL;
+ Delete(this_shadow_extra_code); this_shadow_extra_code = NULL;
+ Delete(this_shadow_import); this_shadow_import = NULL;
+ Delete(shadow_set_vars); shadow_set_vars = NULL;
+ Delete(shadow_get_vars); shadow_get_vars = NULL;
+ Delete(this_shadow_multinherit); this_shadow_multinherit = NULL;
+ Printf(all_cs_entry,"%s { NULL, NULL, NULL}\n};\n",cs_entry);
+ //??delete cs_entry;
+ cs_entry=NULL;
+ return SWIG_OK;
+ * memberfunctionHandler()
+ virtual int memberfunctionHandler(Node *n) {
+ char *name = GetChar(n, "name");
+ char *iname = GetChar(n, "sym:name");
+ SwigType *t = Getattr(n, "type");
+ ParmList *l = Getattr(n, "parms");
+ this->Language::memberfunctionHandler(n);
+ if(shadow) {
+ char *realname = iname ? iname : name;
+ String *php_function_name = Swig_name_member(shadow_classname, realname);
+ cpp_func(iname, t, l, realname, php_function_name);
+ return SWIG_OK;
+ * membervariableHandler()
+ virtual int membervariableHandler(Node *n) {
+ wrapping_member = 1;
+ variable_wrapper_flag = 1;
+ Language::membervariableHandler(n);
+ wrapping_member = 0;
+ variable_wrapper_flag = 0;
+ return SWIG_OK;
+ * staticmemberfunctionHandler()
+ virtual int staticmemberfunctionHandler(Node *n) {
+ Language::staticmemberfunctionHandler(n);
+ if(shadow) {
+ String *symname = Getattr(n, "sym:name");
+ static_flag = 1;
+ cpp_func(Char(symname), Getattr(n, "type"), Getattr(n, "parms"), symname, php_function_name);
+ static_flag = 0;
+ return SWIG_OK;
+ * staticmembervariableHandler()
+ virtual int staticmembervariableHandler(Node *n) {
+ SwigType *d = Getattr(n, "type");
+ String *static_name = NewStringf("%s::%s", class_name, name);
+// String *use_class_name=SwigType_manglestr(SwigType_ltype(t));
+ Wrapper *f;
+ /* A temporary(!) hack for static member variables.
+ * Php currently supports class functions, but not class variables.
+ * Until it does, we convert a class variable to a class function
+ * that returns the current value of the variable. E.g.
+ * class Example {
+ * public:
+ * static int ncount;
+ * would be available in php as Example::ncount()
+ static_flag = 1;
+ if(Getattr(n,"feature:immutable")) {
+ const_flag = 1;
+ cpp_func(iname, d, 0, iname);
+ static_flag = 0;
+ f = NewWrapper();
+ Printv(f->def, "ZEND_NAMED_FUNCTION(", Swig_name_wrapper(iname), ") {\n", NIL);
+ /* If a argument is given we set the variable. Then we return
+ * the current value
+ Printf(f->code,
+ "zval **args[1];\n"
+ "int argcount;\n\n"
+ "argcount = ZEND_NUM_ARGS();\n"
+ "if(argcount > %d) WRONG_PARAM_COUNT;\n\n", (const_flag? 0 : 1));
+ if(!const_flag) {
+ Printf(f->code, "if(argcount) {\n");
+ Printf(f->code, "if(zend_get_parameters_array_ex(argcount, args) != SUCCESS) WRONG_PARAM_COUNT;\n");
+ switch(SwigType_type(d)) {
+ case T_BOOL:
+ case T_INT:
+ case T_SHORT:
+ case T_LONG:
+ case T_SCHAR:
+ case T_UINT:
+ case T_USHORT:
+ case T_ULONG:
+ case T_UCHAR:
+ Printf(f->code,
+ "convert_to_long_ex(args[0]);\n"
+ "%s = Z_LVAL_PP(args[0]);\n", static_name);
+ break;
+ case T_CHAR:
+ Printf(f->code,
+ "convert_to_string_ex(args[0]);\n"
+ "%s = estrdup(Z_STRVAL(args[0]));\n", static_name);
+ break;
+ case T_DOUBLE:
+ case T_FLOAT:
+ Printf(f->code,
+ "convert_to_double_ex(args[0]);\n"
+ "%s = Z_DVAL_PP(args[0]);\n",
+ static_name);
+ break;
+ case T_VOID:
+ break;
+ case T_USER:
+ Printf(f->code, "convert_to_string_ex(args[0]);\n");
+ get_pointer(Char(iname), (char*)"variable", (char*)"args[0]", Char(static_name), d, f->code, (char *)"RETURN_FALSE");
+ break;
+ case T_POINTER:
+ case T_ARRAY:
+ case T_REFERENCE:
+ get_pointer(Char(iname), (char*)"variable", (char*)"args[0]", Char(static_name), d, f->code, (char*)"RETURN_FALSE");
+ break;
+ default:
+ Printf(stderr,"%s : Line %d, Unable to use type %s as a class variable.\n", input_file, line_number, SwigType_str(d,0));
+ break;
+ Printf(f->code, "}\n\n");
+ } /* end of const_flag */
+ case T_BOOL:
+ case T_INT:
+ case T_SHORT:
+ case T_LONG:
+ case T_SCHAR:
+ case T_UINT:
+ case T_USHORT:
+ case T_ULONG:
+ case T_UCHAR:
+ Printf(f->code,
+ "RETURN_LONG(%s);\n", static_name);
+ break;
+ case T_DOUBLE:
+ case T_FLOAT:
+ Printf(f->code,
+ "RETURN_DOUBLE(%s);\n", static_name);
+ break;
+ case T_CHAR:
+ Printf(f->code,
+ "{\nchar ctemp[2];\n"
+ "ctemp[0] = %s;\n"
+ "ctemp[1] = 0;\n"
+ "RETURN_STRING(ctemp, 1);\n}\n",
+ static_name);
+ break;
+ case T_USER:
+ case T_POINTER:
+ Printf(f->code,
+ "SWIG_SetPointerZval(return_value, (void *)%s, "
+ "SWIGTYPE%s);\n", static_name, SwigType_manglestr(d));
+ break;
+ case T_STRING:
+ Printf(f->code, "RETURN_STRING(%s, 1);\n", static_name);
+ break;
+ const_flag = 0;
+ Wrapper_print(f, s_wrappers);
+ return SWIG_OK;
+ void SwigToPhpType(SwigType *t, String_or_char *pname, String* php_type, int shadow_flag) {
+ char *ptype = 0;
+ if(shadow_flag)
+ ptype = PhpTypeFromTypemap((char*)"pstype", t, pname,(char*)"");
+ if(!ptype)
+ ptype = PhpTypeFromTypemap((char*)"ptype",t,pname,(char*)"");
+ if(ptype) {
+ Printf(php_type, ptype);
+ free(ptype);
+ else {
+ /* Map type here */
+ switch(SwigType_type(t)) {
+ case T_CHAR:
+ case T_SCHAR:
+ case T_UCHAR:
+ case T_SHORT:
+ case T_USHORT:
+ case T_INT:
+ case T_UINT:
+ case T_LONG:
+ case T_ULONG:
+ case T_FLOAT:
+ case T_DOUBLE:
+ case T_BOOL:
+ case T_STRING:
+ case T_VOID:
+ Printf(php_type, "");
+ break;
+ case T_POINTER:
+ case T_REFERENCE:
+ case T_USER:
+ if(shadow_flag && is_shadow(t))
+ Printf(php_type, Char(is_shadow(t)));
+ else
+ break;
+ case T_ARRAY:
+ /* TODO */
+ break;
+ default:
+ Printf(stderr, "SwigToPhpType: unhandled data type: %s\n", SwigType_str(t,0));
+ break;
+ char *PhpTypeFromTypemap(char *op, SwigType *t, String_or_char *pname, String_or_char *lname) {
+ String *tms;
+ char bigbuf[1024];
+ char *tm;
+ char *c = bigbuf;
+ if(!(tms = Swig_typemap_lookup(op, t, pname, lname, (char*)"", (char*)"", NULL))) return NULL;
+ tm = Char(tms);
+ while(*tm && (isspace(*tm) || *tm == '{')) tm++;
+ while(*tm && *tm != '}') *c++ = *tm++;
+ *c='\0';
+ return Swig_copy_string(bigbuf);
+ int abstractConstructorHandler(Node *n) {
+ if (shadow) {
+ Wrapper *f;
+ f = NewWrapper();
+ // constructor header
+ if (cs_entry) Printf(cs_entry,
+ " _wrap_new_%s, NULL)\n", iname,iname);
+ // now constructor body
+ Printf(f_h, "ZEND_NAMED_FUNCTION(_wrap_new_%s);\n",iname);
+ Printf(f->def, "ZEND_NAMED_FUNCTION(_wrap_new_%s) {\n"
+ "zend_error(E_ERROR,\"Cannot create swig object type: %s as the underlying object is abstract\");\n"
+ "}\n\n", iname, iname);
+ DelWrapper(f);
+ return SWIG_OK;
+ * constructorHandler()
+ virtual int constructorHandler(Node *n) {
+ if (shadow) native_constructor = (strcmp(iname, shadow_classname) == 0)?\
+ NATIVE_CONSTRUCTOR:ALTERNATIVE_CONSTRUCTOR;
+ else native_constructor=0;
+ constructors++;
+ Language::constructorHandler(n);
+ if(shadow) {
+ // But we also need one per wrapped-class
+ native_constructor = 0;
+ return SWIG_OK;
+ * destructorHandler()
+ virtual int destructorHandler(Node *n) {
+ destructor=1;
+ Language::destructorHandler(n);
+ destructor=0;
+ // Users should never access destructors. PHP's reference
+ // counting mechanism will automatically call this code once
+ // the object is no longer referenced. This is a bit of a risk since
+ // we do expose __destruct. If we do not document it, we should be ok.
+ // Create a __destruct for the class which removes the resource.
+ // Destruction is two phase. _wrap_delete removes the resource
+ // from the internally managed list and __wrap_delete is called by Zend
+ // when it removes the resource. __wrap_delete in turn decrements
+ // the C++ reference count. This mechanism is refcount based. Our exposed
+ // objects will be deleted as soon as they are no longer referenced.
+ // PHP does not wait to "garbage collect"
+ // Eventually, we may be able to replace the object+resource reference
+ // mechanism to use just objects. However, that will require a signficant
+ // amount of rework to the pre-existing resource based infrastructure.
+ if(shadow) {
+ " ZEND_NAMED_FE(__destruct,\n"
+ " _wrap_delete_%s, NULL)\n", iname,iname);
+ return SWIG_OK;
+ * memberconstantHandler()
+ virtual int memberconstantHandler(Node *n) {
+ Language::memberconstantHandler(n);
+ return SWIG_OK;
+ // This method is quite stale and ought to be factored out
+ void cpp_func(char *iname, SwigType *t, ParmList *l, String *php_function_name, String *handler_name = NULL) {
+ if(!shadow) return;
+ // if they didn't provide a handler name, use the realname
+ if (! handler_name) handler_name=php_function_name;
+ if(l) {
+ if(SwigType_type(Getattr(l, "type")) == T_VOID) {
+ l = nextSibling(l);
+ // Printf(f_h, "x ZEND_NAMED_FUNCTION(%s);\n", Swig_name_wrapper(handler_name));
+ if (cs_entry && !(variable_wrapper_flag && shadow))
+ string wrapName = string(Char(Swig_name_wrapper(handler_name)));
+ Printf(cs_entry,
+ " %s, NULL)\n", php_function_name,wrapName.c_str());
+ if(variable_wrapper_flag) { return; }
+ /* Workaround to overcome Getignore(p) not working - p does not always
+ * have the Getignore attribute set. Noticeable when cpp_func is called
+ * from cpp_member_func()
+ Wrapper *f = NewWrapper();
+ emit_args(NULL, l, f);
+ DelWrapper(f);
+ /*Workaround end */
+ int emitExCount;
+}; /* class PHP7 */
+ * swig_php() - Instantiate module
+static PHP7 *maininstance=0;
+// We use this function to be able to write out zend_register_list_destructor_ex
+// lines for most things in the type table
+// NOTE: it's a function NOT A PHP7::METHOD
+extern "C"
+void typetrace7(SwigType *ty, String *mangled, String *clientdata) {
+ Node *class_node;
+ if (!zend_types) {
+ zend_types=NewHash();
+ // we want to know if the type which reduced to this has a constructor
+ if ((class_node=maininstance->classLookup(ty))) {
+ if (! Getattr(zend_types,mangled)) {
+ // OK it may have been set before by a different SwigType but it would
+ // have had the same underlying class node I think
+ // - it is certainly required not to have different originating class
+ // nodes for the same SwigType
+ Setattr(zend_types,mangled,class_node);
+ } else { // a non-class pointer
+ Setattr(zend_types,mangled,NOTCLASS);
+ if (r_prevtracefunc) (*r_prevtracefunc)(ty, mangled, (String *) clientdata);
+extern "C" Language *
+swig_php7(void) {
+ maininstance=new PHP7();
+ if (! r_prevtracefunc) {
+ r_prevtracefunc=SwigType_remember_trace(typetrace7);
+ } else {
+ Printf(stderr,"php7 Typetrace vector already saved!\n");
+ assert(0);
+ return maininstance;
Modified: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Source/Modules/swigmain.cxx
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/Source/Modules/swigmain.cxx 2015-12-08 11:25:13 UTC (rev 8858)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/Source/Modules/swigmain.cxx 2015-12-08 12:09:33 UTC (rev 8859)
@@ -44,6 +44,7 @@
Language *swig_java(void);
Language *swig_php(void);
Language *swig_php5(void);
+ Language *swig_php7(void);
Language *swig_ocaml(void);
Language *swig_pike(void);
Language *swig_sexp(void);
@@ -72,6 +73,7 @@
{"-perl", swig_perl5, "Perl"},
{"-perl5", swig_perl5, 0},
{"-php", swig_php5, "PHP"},
+ {"-php7", swig_php7, "PHP7" },
{"-php4", swig_php, 0},
{"-pike", swig_pike, "Pike"},
{"-python", swig_python, "Python"},
Modified: sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.sln
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.sln 2015-12-08 11:25:13 UTC (rev 8858)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.sln 2015-12-08 12:09:33 UTC (rev 8859)
@@ -1,6 +1,8 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SwigEx", "SwigEx.vcproj", "{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}"
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio 14
+VisualStudioVersion = 14.0.24720.0
+MinimumVisualStudioVersion = 10.0.40219.1
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SwigEx", "SwigEx.vcxproj", "{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}"
EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.vcxproj
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.vcxproj (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.vcxproj 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,172 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="14.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup Label="ProjectConfigurations">
+ <ProjectConfiguration Include="Debug|Win32">
+ <Configuration>Debug</Configuration>
+ <Platform>Win32</Platform>
+ </ProjectConfiguration>
+ <ProjectConfiguration Include="Release|Win32">
+ <Configuration>Release</Configuration>
+ </ItemGroup>
+ <PropertyGroup Label="Globals">
+ <ProjectGuid>{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}</ProjectGuid>
+ <Keyword>Win32Proj</Keyword>
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+ <ConfigurationType>Application</ConfigurationType>
+ <PlatformToolset>v140</PlatformToolset>
+ <CharacterSet>MultiByte</CharacterSet>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+ <ImportGroup Label="ExtensionSettings">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+ <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+ </ImportGroup>
+ <PropertyGroup Label="UserMacros" />
+ <PropertyGroup>
+ <_ProjectFileVersion>14.0.24720.0</_ProjectFileVersion>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <OutDir>Win32\</OutDir>
+ <IntDir>Debug\</IntDir>
+ <LinkIncremental>true</LinkIncremental>
+ <CodeAnalysisRuleSet>MinimumRecommendedRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules />
+ <CodeAnalysisRuleAssemblies />
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <IntDir>Release\</IntDir>
+ <LinkIncremental>false</LinkIncremental>
+ </PropertyGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <ClCompile>
+ <Optimization>Disabled</Optimization>
+ <AdditionalIncludeDirectories>Source\Swig;Source\DOH;Source\Include;Source\Preprocessor;Source\Modules;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <PreprocessorDefinitions>WIN32;_DEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <MinimalRebuild>true</MinimalRebuild>
+ <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
+ <RuntimeLibrary>MultiThreadedDebug</RuntimeLibrary>
+ <PrecompiledHeader />
+ <WarningLevel>Level3</WarningLevel>
+ <DebugInformationFormat>EditAndContinue</DebugInformationFormat>
+ </ClCompile>
+ <Link>
+ <OutputFile>$(OutDir)Swig.exe</OutputFile>
+ <GenerateDebugInformation>true</GenerateDebugInformation>
+ <ProgramDatabaseFile>$(OutDir)SwigEx.pdb</ProgramDatabaseFile>
+ <SubSystem>Console</SubSystem>
+ <RandomizedBaseAddress>false</RandomizedBaseAddress>
+ <DataExecutionPrevention />
+ <TargetMachine>MachineX86</TargetMachine>
+ </Link>
+ </ItemDefinitionGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <ClCompile>
+ <PreprocessorDefinitions>WIN32;NDEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <RuntimeLibrary>MultiThreaded</RuntimeLibrary>
+ <DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
+ </ClCompile>
+ <Link>
+ <OptimizeReferences>true</OptimizeReferences>
+ <EnableCOMDATFolding>true</EnableCOMDATFolding>
+ </Link>
+ <ItemGroup>
+ <ClCompile Include="Source\CParse\cscanner.c" />
+ <ClCompile Include="Source\CParse\parser.c" />
+ <ClCompile Include="Source\CParse\templ.c" />
+ <ClCompile Include="Source\CParse\util.c" />
+ <ClCompile Include="Source\Doh\base.c" />
+ <ClCompile Include="Source\Doh\file.c" />
+ <ClCompile Include="Source\Doh\fio.c" />
+ <ClCompile Include="Source\Doh\hash.c" />
+ <ClCompile Include="Source\Doh\list.c" />
+ <ClCompile Include="Source\Doh\memory.c" />
+ <ClCompile Include="Source\Doh\string.c" />
+ <ClCompile Include="Source\Doh\void.c" />
+ <ClCompile Include="Source\Modules\allocate.cxx" />
+ <ClCompile Include="Source\Modules\browser.cxx" />
+ <ClCompile Include="Source\Modules\chicken.cxx" />
+ <ClCompile Include="Source\Modules\contract.cxx" />
+ <ClCompile Include="Source\Modules\csharp.cxx" />
+ <ClCompile Include="Source\Modules\directors.cxx" />
+ <ClCompile Include="Source\Modules\emit.cxx" />
+ <ClCompile Include="Source\Modules\guile.cxx" />
+ <ClCompile Include="Source\Modules\java.cxx" />
+ <ClCompile Include="Source\Modules\lang.cxx" />
+ <ClCompile Include="Source\Modules\main.cxx" />
+ <ClCompile Include="Source\Modules\module.cxx" />
+ <ClCompile Include="Source\Modules\mzscheme.cxx" />
+ <ClCompile Include="Source\Modules\ocaml.cxx" />
+ <ClCompile Include="Source\Modules\overload.cxx" />
+ <ClCompile Include="Source\Modules\perl5.cxx" />
+ <ClCompile Include="Source\Modules\php4.cxx" />
+ <ClCompile Include="Source\Modules\php5.cxx" />
+ <ClCompile Include="Source\Modules\php7.cxx" />
+ <ClCompile Include="Source\Modules\pike.cxx" />
+ <ClCompile Include="Source\Modules\python.cxx" />
+ <ClCompile Include="Source\Modules\ruby.cxx" />
+ <ClCompile Include="Source\Modules\s-exp.cxx" />
+ <ClCompile Include="Source\Modules\swigmain.cxx" />
+ <ClCompile Include="Source\Modules\tcl8.cxx">
+ <PreprocessToFile Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">false</PreprocessToFile>
+ <PreprocessSuppressLineNumbers Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">false</PreprocessSuppressLineNumbers>
+ </ClCompile>
+ <ClCompile Include="Source\Modules\typepass.cxx" />
+ <ClCompile Include="Source\Modules\utils.cxx" />
+ <ClCompile Include="Source\Modules\xml.cxx" />
+ <ClCompile Include="Source\Preprocessor\cpp.c" />
+ <ClCompile Include="Source\Preprocessor\expr.c" />
+ <ClCompile Include="Source\Swig\cwrap.c" />
+ <ClCompile Include="Source\Swig\error.c" />
+ <ClCompile Include="Source\Swig\fragment.c" />
+ <ClCompile Include="Source\Swig\getopt.c" />
+ <ClCompile Include="Source\Swig\include.c" />
+ <ClCompile Include="Source\Swig\misc.c" />
+ <ClCompile Include="Source\Swig\naming.c" />
+ <ClCompile Include="Source\Swig\parms.c" />
+ <ClCompile Include="Source\Swig\scanner.c" />
+ <ClCompile Include="Source\Swig\stype.c" />
+ <ClCompile Include="Source\Swig\symbol.c" />
+ <ClCompile Include="Source\Swig\tree.c" />
+ <ClCompile Include="Source\Swig\typemap.c" />
+ <ClCompile Include="Source\Swig\typeobj.c" />
+ <ClCompile Include="Source\Swig\typesys.c" />
+ <ClCompile Include="Source\Swig\warn.c" />
+ <ClCompile Include="Source\Swig\wrapfunc.c" />
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="Source\Doh\doh.h" />
+ <ClInclude Include="Source\Doh\dohint.h" />
+ <ClInclude Include="Source\Modules\ExceptionClass.h" />
+ <ClInclude Include="Source\Swig\swig.h" />
+ </ItemGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+ <ImportGroup Label="ExtensionTargets">
+ </ImportGroup>
+</Project>
\ No newline at end of file
Added: sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.vcxproj.filters
--- sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.vcxproj.filters (rev 0)
+++ sandbox/jng/webtier-vs2015/Oem/SWIGEx/SwigEx.vcxproj.filters 2015-12-08 12:09:33 UTC (rev 8859)
@@ -0,0 +1,225 @@
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup>
+ <Filter Include="Source Files">
+ <UniqueIdentifier>{4FC737F1-C7A5-4376-A066-2A32D752A2FF}</UniqueIdentifier>
+ <Extensions>cpp;c;cxx;def;odl;idl;hpj;bat;asm;asmx</Extensions>
+ </Filter>
+ <Filter Include="Source Files\CParse">
+ <UniqueIdentifier>{4d726bf9-c242-4617-adcf-7ecdf27a1728}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="Source Files\DOH">
+ <UniqueIdentifier>{e775b635-736a-41fa-9647-62f9c2f84660}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="Source Files\Swig">
+ <UniqueIdentifier>{9775770b-cb93-457c-9068-eed43fb38fc8}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="Source Files\Modules">
+ <UniqueIdentifier>{6f5ffb03-a638-4ae6-990e-0662ec1b8f32}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="Source Files\Preprocessor">
+ <UniqueIdentifier>{638560d8-5a27-4442-9a86-aa235ab106ad}</UniqueIdentifier>
+ </Filter>
+ <Filter Include="Header Files">
+ <UniqueIdentifier>{93995380-89BD-4b04-88EB-625FBE52EBFB}</UniqueIdentifier>
+ <Extensions>h;hpp;hxx;hm;inl;inc;xsd</Extensions>
+ </Filter>
+ <Filter Include="Resource Files">
+ <UniqueIdentifier>{67DA6AB6-F800-4c08-8B7A-83BB121AAD01}</UniqueIdentifier>
+ <Extensions>rc;ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe;resx</Extensions>
+ </Filter>
+ </ItemGroup>
+ <ItemGroup>
+ <ClCompile Include="Source\CParse\cscanner.c">
+ <Filter>Source Files\CParse</Filter>
+ </ClCompile>
+ <ClCompile Include="Source\CParse\parser.c">
+ </ClCompile>
+ <ClCompile Include="Source\CParse\templ.c">
+ </ClCompile>
+ <ClCompile Include="Source\CParse\util.c">
+ </ClCompile>
+ <ClCompile Include="Source\Doh\base.c">
+ <Filter>Source Files\DOH</Filter>
+ </ClCompile>
+ <ClCompile Include="Source\Doh\file.c">
+ </ClCompile>
+ <ClCompile Include="Source\Doh\fio.c">
+ </ClCompile>
+ <ClCompile Include="Source\Doh\hash.c">
+ </ClCompile>
+ <ClCompile Include="Source\Doh\list.c">
+ </ClCompile>
+ <ClCompile Include="Source\Doh\memory.c">
+ </ClCompile>
+ <ClCompile Include="Source\Doh\string.c">
+ </ClCompile>
+ <ClCompile Include="Source\Doh\void.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\cwrap.c">
+ <Filter>Source Files\Swig</Filter>
+ </ClCompile>
+ <ClCompile Include="Source\Swig\error.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\fragment.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\getopt.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\include.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\misc.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\naming.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\parms.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\scanner.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\stype.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\symbol.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\tree.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\typemap.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\typeobj.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\typesys.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\warn.c">
+ </ClCompile>
+ <ClCompile Include="Source\Swig\wrapfunc.c">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\allocate.cxx">
+ <Filter>Source Files\Modules</Filter>
+ </ClCompile>
+ <ClCompile Include="Source\Modules\browser.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\chicken.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\contract.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\csharp.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\directors.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\emit.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\guile.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\java.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\lang.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\main.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\module.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\mzscheme.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\ocaml.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\overload.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\perl5.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\php4.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\php5.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\pike.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\python.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\ruby.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\s-exp.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\swigmain.cxx">
+ </ClCompile>
+ </ClCompile>
+ <ClCompile Include="Source\Modules\typepass.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\utils.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\xml.cxx">
+ </ClCompile>
+ <ClCompile Include="Source\Preprocessor\cpp.c">
+ <Filter>Source Files\Preprocessor</Filter>
+ </ClCompile>
+ <ClCompile Include="Source\Preprocessor\expr.c">
+ </ClCompile>
+ <ClCompile Include="Source\Modules\php7.cxx">
+ </ClCompile>
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="Source\Doh\doh.h">
+ </ClInclude>
+ <ClInclude Include="Source\Doh\dohint.h">
+ </ClInclude>
+ <ClInclude Include="Source\Swig\swig.h">
+ </ClInclude>
+ <ClInclude Include="Source\Modules\ExceptionClass.h">
+ </ClInclude>
+ </ItemGroup>
+</Project>
Property changes on: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Win32
___________________________________________________________________
Added: svn:ignore
+ Swig.ilk
SwigEx.pdb
Modified: sandbox/jng/webtier-vs2015/Oem/SWIGEx/Win32/Swig.exe
(Binary files differ)
More information about the mapguide-commits
