[mapguide-commits] r8535 - in trunk/MgDev/Common: Foundation/Data Foundation/System MapGuideCommon/Resources
svn_mapguide at osgeo.org
Thu Feb 5 14:36:16 PST 2015
Author: jng
Date: 2015-02-05 14:36:16 -0800 (Thu, 05 Feb 2015)
New Revision: 8535
trunk/MgDev/Common/Foundation/Data/ByteSink.cpp
trunk/MgDev/Common/Foundation/System/ByteSourceFileImpl.cpp
trunk/MgDev/Common/Foundation/System/FileUtil.cpp
trunk/MgDev/Common/Foundation/System/StreamReader.cpp
trunk/MgDev/Common/Foundation/System/Util.h
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
#2534: Include errno and its string description in cases where it is the cause of the MgFileIoException being thrown
Modified: trunk/MgDev/Common/Foundation/Data/ByteSink.cpp
--- trunk/MgDev/Common/Foundation/Data/ByteSink.cpp 2015-02-05 11:46:41 UTC (rev 8534)
+++ trunk/MgDev/Common/Foundation/Data/ByteSink.cpp 2015-02-05 22:36:16 UTC (rev 8535)
@@ -202,16 +202,17 @@
MgStringCollection arguments;
arguments.Add(filename);
if (errno == EEXIST)
+ MG_FILE_IO_EXCEPTION_ADD_ERRNO();
throw new MgFileNotFoundException(L"MgByteSink.ToFile",
- __LINE__, __WFILE__, &arguments, L"", NULL);
+ __LINE__, __WFILE__, &arguments, L"MgFileIoErrNo", &errNoArgs);
else
throw new MgFileIoException(L"MgByteSink.ToFile",
Modified: trunk/MgDev/Common/Foundation/System/ByteSourceFileImpl.cpp
--- trunk/MgDev/Common/Foundation/System/ByteSourceFileImpl.cpp 2015-02-05 11:46:41 UTC (rev 8534)
+++ trunk/MgDev/Common/Foundation/System/ByteSourceFileImpl.cpp 2015-02-05 22:36:16 UTC (rev 8535)
@@ -122,13 +122,15 @@
if(errno == ENOENT)
throw new MgFileNotFoundException(L"ByteSourceFileImpl.LoadFile",
else
throw new MgFileIoException(L"ByteSourceFileImpl.LoadFile",
Modified: trunk/MgDev/Common/Foundation/System/FileUtil.cpp
--- trunk/MgDev/Common/Foundation/System/FileUtil.cpp 2015-02-05 11:46:41 UTC (rev 8534)
+++ trunk/MgDev/Common/Foundation/System/FileUtil.cpp 2015-02-05 22:36:16 UTC (rev 8535)
@@ -449,8 +449,9 @@
case ENOENT:
case EACCES:
default:
throw new MgFileIoException(L"MgFileUtil.MkDir",
break;
@@ -495,8 +496,9 @@
case ENOTEMPTY:
case EACCES:
default:
throw new MgFileIoException(L"MgFileUtil.DeleteDirectory",
break;
@@ -789,8 +791,9 @@
case ENOENT: // PathnameExists is more reliable. It gets called above, so this error should not be detected.
case EACCES:
default:
throw new MgFileIoException(L"MgFileUtil.DeleteFile",
break;
@@ -970,8 +973,9 @@
// different path.
default:
arguments.Add(newPathname);
throw new MgFileIoException(L"MgFileUtil.RenameFile",
break;
Modified: trunk/MgDev/Common/Foundation/System/StreamReader.cpp
--- trunk/MgDev/Common/Foundation/System/StreamReader.cpp 2015-02-05 11:46:41 UTC (rev 8534)
+++ trunk/MgDev/Common/Foundation/System/StreamReader.cpp 2015-02-05 22:36:16 UTC (rev 8535)
@@ -414,13 +414,15 @@
throw new MgFileNotFoundException(L"MgStreamReader.GetStream",
else
throw new MgFileIoException(L"MgStreamReader.GetStream",
Modified: trunk/MgDev/Common/Foundation/System/Util.h
--- trunk/MgDev/Common/Foundation/System/Util.h 2015-02-05 11:46:41 UTC (rev 8534)
+++ trunk/MgDev/Common/Foundation/System/Util.h 2015-02-05 22:36:16 UTC (rev 8535)
@@ -638,6 +638,17 @@
+#define MG_FILE_IO_EXCEPTION_ADD_ERRNO() \
+ MgStringCollection errNoArgs; \
+ std::string mbErrNoDesc; \
+ mbErrNoDesc += ACE_OS::strerror(errno); \
+ STRING wErrNoDesc; \
+ MgUtil::MultiByteToWideChar(mbErrNoDesc, wErrNoDesc); \
+ STRING wErrNo; \
+ MgUtil::Int32ToString(errno, wErrNo); \
+ errNoArgs.Add(wErrNo); \
+ errNoArgs.Add(wErrNoDesc)
#ifdef _WIN32
#define MG_TCHAR_TO_WCHAR(x) ((wstring)x).c_str()
#define MG_TCHAR_TO_CHAR(x) MgUtil::WideCharToMultiByte((wstring)x).c_str()
Modified: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2015-02-05 11:46:41 UTC (rev 8534)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2015-02-05 22:36:16 UTC (rev 8535)
@@ -235,6 +235,7 @@
MgFeatureSourceFormatInnerExceptionMessage = Error occurred in Feature Source (%1): %2 (Cause: %3, Root Cause: %4)
MgFeatureReaderIdNotFound = The feature reader ID was not found.
MgFilenamesIdentical = The filenames cannot be the same.
+MgFileIoErrNo = errno: %1 (%2)
MgFormatAllExceptionDetail = - %1(%2)
MgFormatAllExceptionStackTrace = - %1(%2) line %3 file %4
MgFormatFdoExceptionMessage = %1 (Cause: %2, Root Cause: %3)
More information about the mapguide-commits
