[mapguide-commits] r8553 - trunk/Tools/Vagrant/packer/scripts/mapguide
svn_mapguide at osgeo.org
Fri Feb 27 06:04:36 PST 2015
Author: jng
Date: 2015-02-27 06:04:36 -0800 (Fri, 27 Feb 2015)
New Revision: 8553
trunk/Tools/Vagrant/packer/scripts/mapguide/centos32.sh
trunk/Tools/Vagrant/packer/scripts/mapguide/centos64.sh
trunk/Tools/Vagrant/packer/scripts/mapguide/ubuntu32.sh
trunk/Tools/Vagrant/packer/scripts/mapguide/ubuntu64.sh
Ensure ant-contrib is installed in our packer-prepared build VMs
Modified: trunk/Tools/Vagrant/packer/scripts/mapguide/centos32.sh
--- trunk/Tools/Vagrant/packer/scripts/mapguide/centos32.sh 2015-02-27 14:03:31 UTC (rev 8552)
+++ trunk/Tools/Vagrant/packer/scripts/mapguide/centos32.sh 2015-02-27 14:04:36 UTC (rev 8553)
@@ -2,4 +2,6 @@
sudo yum install -y gcc make gcc-c++ gd-* automake bison byacc flex doxygen expat expat-devel libtool libjpeg-devel libpng libpng-devel libxml2 libxml2-devel openssl curl curl-devel libxslt libxslt-devel subversion java-1.7.0-openjdk java-1.7.0-openjdk-devel ant dos2unix openssh-server openldap-devel alsa-lib-devel pcre-devel unixODBC-devel libcom_err-devel krb5-devel openssl-devel mysql-devel postgresql-devel unixODBC
# For producing .tar.xz archives
sudo yum install -y xz-lzma-compat
+# To support Java test suite
+sudo yum install -y ant-contrib
echo "JAVA_HOME=/usr/lib/jvm/java-openjdk" | sudo tee --append /etc/environment
\ No newline at end of file
Modified: trunk/Tools/Vagrant/packer/scripts/mapguide/centos64.sh
--- trunk/Tools/Vagrant/packer/scripts/mapguide/centos64.sh 2015-02-27 14:03:31 UTC (rev 8552)
+++ trunk/Tools/Vagrant/packer/scripts/mapguide/centos64.sh 2015-02-27 14:04:36 UTC (rev 8553)
@@ -4,4 +4,6 @@
# For 32-bit swig binary in MapGuide source
sudo yum install -y libstdc++.i686 glibc.i686
Modified: trunk/Tools/Vagrant/packer/scripts/mapguide/ubuntu32.sh
--- trunk/Tools/Vagrant/packer/scripts/mapguide/ubuntu32.sh 2015-02-27 14:03:31 UTC (rev 8552)
+++ trunk/Tools/Vagrant/packer/scripts/mapguide/ubuntu32.sh 2015-02-27 14:04:36 UTC (rev 8553)
@@ -10,4 +10,6 @@
sudo apt-get install -y xz-utils
# For deb packaging
sudo apt-get install -y rsync
+sudo apt-get install -y ant-contrib
echo "JAVA_HOME=/usr/lib/jvm/java-1.7.0-openjdk-i386" | sudo tee --append /etc/environment
Modified: trunk/Tools/Vagrant/packer/scripts/mapguide/ubuntu64.sh
--- trunk/Tools/Vagrant/packer/scripts/mapguide/ubuntu64.sh 2015-02-27 14:03:31 UTC (rev 8552)
+++ trunk/Tools/Vagrant/packer/scripts/mapguide/ubuntu64.sh 2015-02-27 14:04:36 UTC (rev 8553)
@@ -12,4 +12,6 @@
sudo apt-get install -y g++-multilib
echo "JAVA_HOME=/usr/lib/jvm/java-1.7.0-openjdk-amd64" | sudo tee --append /etc/environment
More information about the mapguide-commits
