[mapguide-commits] r8574 - in trunk/Tools/Maestro: MgCooker OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Tile
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Mar 14 10:07:19 PDT 2015
Author: jng
Date: 2015-03-14 10:07:19 -0700 (Sat, 14 Mar 2015)
New Revision: 8574
   trunk/Tools/Maestro/MgCooker/Program.cs
   trunk/Tools/Maestro/MgCooker/SetupRun.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Tile/BatchSettings.cs
#2515: Add TileSetDefinition support to MgCooker and backend classes
Modified: trunk/Tools/Maestro/MgCooker/Program.cs
--- trunk/Tools/Maestro/MgCooker/Program.cs	2015-03-14 15:06:41 UTC (rev 8573)
+++ trunk/Tools/Maestro/MgCooker/Program.cs	2015-03-14 17:07:19 UTC (rev 8574)
@@ -305,8 +305,8 @@
                 Console.Clear();
             Console.WriteLine(string.Format(Strings.ConsoleUpdateTime.Replace("\\t", "\t"), DateTime.Now));
             Console.WriteLine(string.Format(Strings.ConsoleCurrentMap.Replace("\\t", "\t"), map.ResourceId, mapCount, map.Parent.Maps.Count));
-            Console.WriteLine(string.Format(Strings.ConsoleCurrentGroup.Replace("\\t", "\t"), group, groupCount, map.MapDefinition.BaseMap.GroupCount));
-            Console.WriteLine(string.Format(Strings.ConsoleCurrentScale.Replace("\\t", "\t"), map.MapDefinition.BaseMap.GetScaleAt(Array.IndexOf<int>(map.ScaleIndexMap, scaleindex)), Array.IndexOf<int>(map.ScaleIndexMap, scaleindex) + 1, map.MapDefinition.BaseMap.ScaleCount));
+            Console.WriteLine(string.Format(Strings.ConsoleCurrentGroup.Replace("\\t", "\t"), group, groupCount, map.TileSet.GroupCount));
+            Console.WriteLine(string.Format(Strings.ConsoleCurrentScale.Replace("\\t", "\t"), map.TileSet.GetScaleAt(Array.IndexOf<int>(map.ScaleIndexMap, scaleindex)), Array.IndexOf<int>(map.ScaleIndexMap, scaleindex) + 1, map.TileSet.ScaleCount));
             Console.WriteLine(string.Format(Strings.ConsoleCurrentTile.Replace("\\t", "\t"), tileCount, totalTiles));
             Console.WriteLine();
             Console.WriteLine(string.Format(Strings.ConsoleGroupDuration.Replace("\\t", "\t"), DateTime.Now - beginGroup));
@@ -379,14 +379,14 @@
             TimeSpan duration = DateTime.Now - beginScale;
             if (m_loggableProgress)
-                Console.WriteLine(string.Format(Strings.ConsoleOperationFinishScale, DateTime.Now, map.MapDefinition.BaseMap.GetScaleAt(scaleindex), duration));
+                Console.WriteLine(string.Format(Strings.ConsoleOperationFinishScale, DateTime.Now, map.TileSet.GetScaleAt(scaleindex), duration));
         private static void bx_BeginRenderingScale(CallbackStates state, MapTilingConfiguration map, string group, int scaleindex, int row, int column, ref bool cancel)
             beginScale = DateTime.Now;
-                Console.WriteLine(string.Format(Strings.ConsoleOperationBeginScale, beginMap, map.MapDefinition.BaseMap.GetScaleAt(scaleindex), scaleindex, map.Resolutions));
+                Console.WriteLine(string.Format(Strings.ConsoleOperationBeginScale, beginMap, map.TileSet.GetScaleAt(scaleindex), scaleindex, map.Resolutions));
         private static void bx_FinishRenderingMap(CallbackStates state, MapTilingConfiguration map, string group, int scaleindex, int row, int column, ref bool cancel)
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.cs	2015-03-14 15:06:41 UTC (rev 8573)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.cs	2015-03-14 17:07:19 UTC (rev 8574)
@@ -147,6 +147,8 @@
                 List<string> tmp = new List<string>();
                 foreach (ResourceListResourceDocument doc in m_connection.ResourceService.GetRepositoryResources(StringConstants.RootIdentifier, ResourceTypes.MapDefinition.ToString()).Items)
                     tmp.Add(doc.ResourceId);
+                foreach (ResourceListResourceDocument doc in m_connection.ResourceService.GetRepositoryResources(StringConstants.RootIdentifier, ResourceTypes.TileSetDefinition.ToString()).Items)
+                    tmp.Add(doc.ResourceId);
                 maps = tmp.ToArray();
@@ -170,20 +172,33 @@
             MapTree.Nodes.Clear();
             foreach (string m in maps)
-                IMapDefinition mdef = m_connection.ResourceService.GetResource(m) as IMapDefinition;
-                if (mdef == null) //Skip unknown Map Definition version (which would be returned as UntypedResource objects)
+                ITileSetAbstract tileSet = null;
+                IResource res = m_connection.ResourceService.GetResource(m);
+                IMapDefinition mdef = res as IMapDefinition;
+                ITileSetDefinition tsd = res as ITileSetDefinition;
+                if (mdef != null)
+                    tileSet = mdef.BaseMap;
+                else if (tsd != null && tsd.SupportsCustomFiniteDisplayScales)
+                    tileSet = tsd;
+                if (tileSet == null)
                     continue;
-                IBaseMapDefinition baseMap = mdef.BaseMap;
-                if (baseMap != null &&
-                    baseMap.ScaleCount > 0 &&
-                    baseMap.HasGroups())
+                bool bValidTileSet = (tileSet != null &&
+                    tileSet.ScaleCount > 0 &&
+                    tileSet.HasGroups());
+                if (bValidTileSet)
                     TreeNode mn = MapTree.Nodes.Add(m);
                     mn.ImageIndex = mn.SelectedImageIndex = 0;
                     mn.Tag = mdef;
-                    foreach (var g in baseMap.BaseMapLayerGroups)
+                    foreach (var g in tileSet.BaseMapLayerGroups)
                         TreeNode gn = mn.Nodes.Add(g.Name);
                         gn.Tag = g;
@@ -200,7 +215,7 @@
                         gn.ImageIndex = gn.SelectedImageIndex = 1;
                         int counter = 0;
-                        foreach (double d in baseMap.FiniteDisplayScale)
+                        foreach (double d in tileSet.FiniteDisplayScale)
                             TreeNode sn = gn.Nodes.Add(d.ToString(System.Globalization.CultureInfo.CurrentUICulture));
                             if (gn.Checked && scalesSelected.Contains(counter))
@@ -274,16 +289,19 @@
                 if (mn.Checked)
                     foreach (TreeNode gn in mn.Nodes)
                         if (gn.Checked)
                             List<int> ix = new List<int>();
                             foreach (TreeNode sn in gn.Nodes)
                                 if (sn.Checked)
                                     ix.Add(sn.Index);
                             if (ix.Count > 0)
                                 lst.Add(new Config(mn.Text, gn.Text, ix.ToArray(), (m_coordinateOverrides.ContainsKey(mn.Text) ? m_coordinateOverrides[mn.Text] : null)));
@@ -597,7 +615,7 @@
                 var currentPath = Path.GetDirectoryName(new Uri(Assembly.GetExecutingAssembly().CodeBase).LocalPath);
                 var mpuCalc = Path.Combine(currentPath, "AddIns/Local/MpuCalc.exe");
-                if (!File.Exists(mpuCalc))
+                if (!File.Exists(mpuCalc) && mapDef.EndsWith(ResourceTypes.MapDefinition.ToString()))
                     int[] cmdTypes = m_connection.Capabilities.SupportedCommands;
                     if (Array.IndexOf(cmdTypes, (int)OSGeo.MapGuide.MaestroAPI.Commands.CommandType.CreateRuntimeMap) < 0)
@@ -625,27 +643,40 @@
                 else
-                    IMapDefinition mdf = (IMapDefinition)m_connection.ResourceService.GetResource(mapDef);
-                    var proc = new Process
+                    IResource res = m_connection.ResourceService.GetResource(mapDef);
+                    IMapDefinition mdf = res as IMapDefinition;
+                    string coordSys = null;
+                    if (mdf != null)
+                        coordSys = mdf.CoordinateSystem;
+                    else if (tsd != null)
+                        coordSys = tsd.GetDefaultCoordinateSystem();
+                    string output = string.Empty;
+                    if (coordSys != null)
-                        StartInfo = new ProcessStartInfo
+                        var proc = new Process
-                            FileName = mpuCalc,
-                            Arguments = mdf.CoordinateSystem,
-                            UseShellExecute = false,
-                            RedirectStandardOutput = true,
-                            CreateNoWindow = true
+                            StartInfo = new ProcessStartInfo
+                                FileName = mpuCalc,
+                                Arguments = coordSys,
+                                UseShellExecute = false,
+                                RedirectStandardOutput = true,
+                                CreateNoWindow = true
+                        proc.Start();
+                        StringBuilder sb = new StringBuilder();
+                        while (!proc.StandardOutput.EndOfStream)
+                            string line = proc.StandardOutput.ReadLine();
+                            // do something with line
+                            sb.AppendLine(line);
-                    proc.Start();
-                    StringBuilder sb = new StringBuilder();
-                    while (!proc.StandardOutput.EndOfStream)
-                        string line = proc.StandardOutput.ReadLine();
-                        // do something with line
-                        sb.AppendLine(line);
+                        output = sb.ToString();
-                    string output = sb.ToString();
                     double mpu;
                     if (double.TryParse(output, out mpu))
                         return new MpuCalcResult() { Method = MpuMethod.MpuCalcExe, Result = Convert.ToDecimal(mpu) };
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs	2015-03-14 15:06:41 UTC (rev 8573)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs	2015-03-14 17:07:19 UTC (rev 8574)
@@ -2293,6 +2293,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to The given Map Definition or Tile Set Definition cannot be seeded.
+        /// </summary>
+        public static string UnseedableTileSet {
+            get {
+                return ResourceManager.GetString("UnseedableTileSet", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Unsupported Load Procedure Type.
         /// </summary>
         public static string UnsupportedLoadProcedureType {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx	2015-03-14 15:06:41 UTC (rev 8573)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx	2015-03-14 17:07:19 UTC (rev 8574)
@@ -891,4 +891,7 @@
   <data name="ErrorWriteClassXmlNeedToBeAttachedToParent" xml:space="preserve">
     <value>Cannot write XML for a Class Definition that is not attached to a parent schema</value>
   </data>
+  <data name="UnseedableTileSet" xml:space="preserve">
+    <value>The given Map Definition or Tile Set Definition cannot be seeded</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Tile/BatchSettings.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Tile/BatchSettings.cs	2015-03-14 15:06:41 UTC (rev 8573)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Tile/BatchSettings.cs	2015-03-14 17:07:19 UTC (rev 8574)
@@ -412,9 +412,19 @@
         private TilingRunCollection m_parent;
         /// <summary>
+        /// The resource ID of the tile set or map definition
+        /// </summary>
+        private string m_tileSetResourceID;
+        /// <summary>
+        /// The tile set extents
+        /// </summary>
+        private IEnvelope m_tileSetExtents;
+        /// <summary>
         /// The map read from MapGuide
         /// </summary>
-        private IMapDefinition m_mapdefinition;
+        private ITileSetAbstract m_tileset;
         /// <summary>
         /// The max extent of the map
@@ -464,9 +474,28 @@
         public MapTilingConfiguration(TilingRunCollection parent, string map)
             m_parent = parent;
-            m_mapdefinition = (IMapDefinition)parent.Connection.ResourceService.GetResource(map);
-            var baseMap = m_mapdefinition.BaseMap;
+            IResource res = parent.Connection.ResourceService.GetResource(map);
+            if (mdf != null)
+                m_tileSetResourceID = mdf.ResourceID;
+                m_tileSetExtents = mdf.Extents.Clone();
+                m_tileset = mdf.BaseMap;
+                m_tileSetResourceID = tsd.ResourceID;
+                m_tileSetExtents = tsd.Extents.Clone();
+                m_tileset = tsd;
+            if (m_tileset == null)
+                throw new InvalidOperationException(OSGeo.MapGuide.MaestroAPI.Strings.UnseedableTileSet);
+            var baseMap = m_tileset;
                 baseMap.ScaleCount > 0)
@@ -481,7 +510,7 @@
         internal void CalculateDimensions()
-            int[] tmp = new int[this.MapDefinition.BaseMap.ScaleCount];
+            int[] tmp = new int[this.TileSet.ScaleCount];
             for (int i = 0; i < tmp.Length; i++)
                 tmp[i] = i;
@@ -490,14 +519,14 @@
         internal void CalculateDimensionsInternal()
-            if (m_mapdefinition.BaseMap.ScaleCount == 0)
+            if (m_tileset.ScaleCount == 0)
                 m_scaleindexmap = new int[0];
                 m_dimensions = new long[0][];
                 return;
-            IEnvelope extents = this.MaxExtent ?? m_mapdefinition.Extents;
+            IEnvelope extents = this.MaxExtent ?? m_tileSetExtents;
             double maxscale = m_maxscale;
             m_dimensions = new long[this.Resolutions][];
@@ -510,7 +539,7 @@
             for (int i = this.Resolutions - 1; i >= 0; i--)
                 long rows, cols, rowTileOffset = 0, colTileOffset = 0;
-                double scale = m_mapdefinition.BaseMap.GetScaleAt(i);
+                double scale = m_tileset.GetScaleAt(i);
                 // This is the official method, and the only one MgCooker will ever use
@@ -542,13 +571,13 @@
                 if (m_maxExtent != null)
                     //The extent is overridden, so we need to adjust the start offsets
-                    double offsetX = MaxExtent.MinX - m_mapdefinition.Extents.MinX;
-                    double offsetY = m_mapdefinition.Extents.MaxY - MaxExtent.MaxY;
+                    double offsetX = MaxExtent.MinX - m_tileSetExtents.MinX;
+                    double offsetY = m_tileSetExtents.MaxY - MaxExtent.MaxY;
                     rowTileOffset = (int)Math.Floor(offsetY / tileHeight);
                     colTileOffset = (int)Math.Floor(offsetX / tileWidth);
-                    double offsetMaxX = MaxExtent.MaxX - m_mapdefinition.Extents.MinX;
-                    double offsetMinY = m_mapdefinition.Extents.MaxY - MaxExtent.MinY;
+                    double offsetMaxX = MaxExtent.MaxX - m_tileSetExtents.MinX;
+                    double offsetMinY = m_tileSetExtents.MaxY - MaxExtent.MinY;
                     int rowMinTileOffset = (int)Math.Floor(offsetMinY / tileHeight);
                     int colMaxTileOffset = (int)Math.Floor(offsetMaxX / tileWidth);
@@ -602,9 +631,9 @@
             List<int> keys = new List<int>(s.Keys);
             keys.Reverse();
-            for (int i = m_mapdefinition.BaseMap.ScaleCount - 1; i >= 0; i--)
+            for (int i = m_tileset.ScaleCount - 1; i >= 0; i--)
                 if (!keys.Contains(i))
-                    m_mapdefinition.BaseMap.RemoveScaleAt(i);
+                    m_tileset.RemoveScaleAt(i);
             CalculateDimensionsInternal();
@@ -649,10 +678,10 @@
             get
-                if (m_mapdefinition.BaseMap == null || m_mapdefinition.BaseMap.ScaleCount == 0)
+                if (m_tileset == null || m_tileset.ScaleCount == 0)
                     return 0;
                 else
-                    return m_mapdefinition.BaseMap.ScaleCount;
+                    return m_tileset.ScaleCount;
@@ -674,7 +703,7 @@
                 //If the MaxExtents are different from the actual bounds, we need a start offset offset
-                RenderThreads settings = new RenderThreads(this, m_parent, m_scaleindexmap[scaleindex], group, m_mapdefinition.ResourceID, rows, cols, rowTileOffset, colTileOffset, m_parent.Config.RandomizeTileSequence);
+                RenderThreads settings = new RenderThreads(this, m_parent, m_scaleindexmap[scaleindex], group, m_tileSetResourceID, rows, cols, rowTileOffset, colTileOffset, m_parent.Config.RandomizeTileSequence);
                 settings.RunAndWait();
@@ -741,12 +770,12 @@
         /// <summary>
         /// Gets the resourceId for the map
         /// </summary>
-        public string ResourceId { get { return m_mapdefinition.ResourceID; } }
+        public string ResourceId { get { return m_tileSetResourceID; } }
         /// <summary>
         /// Gets the MapDefintion
         /// </summary>
-        public IMapDefinition MapDefinition { get { return m_mapdefinition; } }
+        public ITileSetAbstract TileSet { get { return m_tileset; } }
         /// <summary>
         /// Gets a reference to the parent tiling run collection
More information about the mapguide-commits mailing list
