[mapguide-commits] r8811 - in sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi: . Custom
svn_mapguide at osgeo.org
Thu Nov 5 03:13:35 PST 2015
Author: jng
Date: 2015-11-05 03:13:35 -0800 (Thu, 05 Nov 2015)
New Revision: 8811
Added:
sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/Custom/EntryPoint.cs
sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/dotnetcore.i
sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/Custom/DnxCoreShims.cs
sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/DotNetCoreApi.vcxproj
Remove the proxy class that contains the MgInitializeWebTier() method. We've replaced this with our own entry point class, as I suspect some DNX native library tricks will have to be employed before it's safe to call MgInitializeWebTier() proper.
Modified: sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/Custom/DnxCoreShims.cs
--- sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/Custom/DnxCoreShims.cs 2015-11-05 10:45:59 UTC (rev 8810)
+++ sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/Custom/DnxCoreShims.cs 2015-11-05 11:13:35 UTC (rev 8811)
@@ -1,3 +1,20 @@
+// Copyright (C) 2004-2015 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
namespace System
#if DNXCORE50
Added: sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/Custom/EntryPoint.cs
--- sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/Custom/EntryPoint.cs (rev 0)
+++ sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/Custom/EntryPoint.cs 2015-11-05 11:13:35 UTC (rev 8811)
@@ -0,0 +1,35 @@
+namespace OSGeo.MapGuide
+ /// <summary>
+ /// This is the entry point of the MapGuide API
+ /// </summary>
+ public class MapGuideApi
+ /// <summary>
+ /// Initializes the MapGuide Web Tier APIs. You must call this method before using any other class or method
+ /// in the MapGuide API
+ /// </summary>
+ /// <param name="configFile">The path to the web tier configuration file</param>
+ /// <remarks>Subsequent calls do nothing and return immediately</remarks>
+ public static void MgInitializeWebTier(string configFile) {
+ MapGuideDotNetCoreUnmanagedApiPINVOKE.MgInitializeWebTier(configFile);
\ No newline at end of file
Modified: sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/DotNetCoreApi.vcxproj
--- sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/DotNetCoreApi.vcxproj 2015-11-05 10:45:59 UTC (rev 8810)
+++ sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/DotNetCoreApi.vcxproj 2015-11-05 11:13:35 UTC (rev 8811)
@@ -96,9 +96,10 @@
<Command>del /Q .\Custom\*prop
del /Q *.cs
..\..\..\BuildTools\WebTools\IMake\Win32\IMake.exe ..\MapGuideApi\Constants.xml C# ./Constants.cs
-copy ..\DotNetUnmanagedApi\dotnet.i .\language.i
+copy .\dotnetcore.i .\language.i
..\..\..\BuildTools\WebTools\IMake\Win32\IMake.exe ..\MapGuideApi\MapGuideApiGen.xml C#
..\..\..\Oem\SwigEx\Win32\swig -c++ -csharp -dllname MapGuideDotNetCoreUnmanagedApid -namespace OSGeo.MapGuide -proxydir .\Custom -baseexception MgException -clsidcode ..\getclassid.code -clsiddata m_cls_id -catchallcode ..\catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise()%3b" -nodefault -noconstants -module MapGuideDotNetCoreUnmanagedApi -o MgApi_wrap.cpp -lib ..\..\..\Oem\SWIGEx\Lib MapGuideApi.i
+del /Q MapGuideDotNetCoreUnmanagedApi.cs
</Command>
</PreBuildEvent>
<ClCompile>
@@ -131,9 +132,10 @@
del /Q *.cs
</Command>
</PreBuildEvent>
<ClCompile>
@@ -166,9 +168,10 @@
del /Q *.cs
..\..\..\Oem\SwigEx\Win32\swig -c++ -csharp -dllname MapGuideDotNetCoreUnmanagedApi -namespace OSGeo.MapGuide -proxydir .\Custom -baseexception MgException -clsidcode ..\getclassid.code -clsiddata m_cls_id -catchallcode ..\catchall.code -dispose "((MgDisposable*)arg1)->Release()" -rethrow "e->Raise()%3b" -nodefault -noconstants -module MapGuideDotNetCoreUnmanagedApi -o MgApi_wrap.cpp -lib ..\..\..\Oem\SWIGEx\Lib MapGuideApi.i
</Command>
</PreBuildEvent>
<ClCompile>
@@ -202,9 +205,10 @@
del /Q *.cs
</Command>
</PreBuildEvent>
<ClCompile>
Added: sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/dotnetcore.i
--- sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/dotnetcore.i (rev 0)
+++ sandbox/jng/aspnet50/Web/src/MapGuideDotNetCoreApi/dotnetcore.i 2015-11-05 11:13:35 UTC (rev 8811)
@@ -0,0 +1,58 @@
+// Copyright (C) 2004-2011 by Autodesk, Inc.
+// STRINGPARAM "in" typemap
+// Marshal a C++ style string to a wstring
+// Allocate temporary memory only when required, otherwise
+// use a buffer on the stack
+%typemap(in) STRINGPARAM
+ $1 = (STRINGPARAM) $input;
+// STRING "out" typemap
+// Marshal a string returned by C++ to CSharp
+%typemap(out) STRING
+ $result = SWIG_csharp_string_callback((int)(result.length()+1)*sizeof(wchar_t));
+ wcscpy((wchar_t*)$result, result.c_str());
+// BYTE_ARRAY_OUT "cstype" typemap
+// Type substitution in .NET and proxy code
+%typemap(cstype) BYTE_ARRAY_OUT "Byte[]"
+%typemap(imtype) BYTE_ARRAY_OUT "Byte[]"
+%typemap(ctype) BYTE_ARRAY_OUT "unsigned char*"
+// BYTE_ARRAY_IN "cstype" typemap
+%typemap(cstype) BYTE_ARRAY_IN "Byte[]"
+%typemap(imtype) BYTE_ARRAY_IN "Byte[]"
+%typemap(ctype) BYTE_ARRAY_IN "unsigned char*"
+// Global functions
+void MgInitializeWebTier(STRINGPARAM configFile);
More information about the mapguide-commits
