[mapguide-commits] r8780 - sandbox/jng/diet_vs2015/Oem
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Oct 14 06:55:02 PDT 2015
Author: jng
Date: 2015-10-14 06:55:02 -0700 (Wed, 14 Oct 2015)
New Revision: 8780
   sandbox/jng/diet_vs2015/Oem/build_oem.sh
Remove agg from top-level build_oem.sh as that is taken care of by the new MgDev/prebuild.sh script
Modified: sandbox/jng/diet_vs2015/Oem/build_oem.sh
--- sandbox/jng/diet_vs2015/Oem/build_oem.sh	2015-10-14 13:53:08 UTC (rev 8779)
+++ sandbox/jng/diet_vs2015/Oem/build_oem.sh	2015-10-14 13:55:02 UTC (rev 8780)
@@ -543,36 +543,6 @@
-# Build AGG 2.4
-# Notes: none
-init_agg()
-    LIB_NAME="AGG 2.4"
-build_agg()
-    pushd agg-2.4
-    if [ $BUILD_CPU -eq 64 ]; then
-        make EXTRACXXFLAGS="-fPIC -m64"
-    else
-        make
-    fi
-    check_build
-    popd
-clean_agg()
-    pushd agg-2.4
-    make clean
-    check_clean
-    popd
 # Build JSON
 # Notes: none
@@ -673,7 +643,7 @@
 pushd Oem
-for lib in linuxapt fusion ace dwfcore dwftk geos bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
+for lib in linuxapt fusion ace dwfcore dwftk geos bdbxml cppunit imake zlib libpng jpeg freetype gd json csmap;
 do
     echo "$lib: Initialization..........................."
     init_"$lib"
More information about the mapguide-commits mailing list
