[mapguide-commits] r8797 - in trunk/MgDev/Oem/php: . Zend
svn_mapguide at osgeo.org
Tue Oct 27 00:34:59 PDT 2015
Author: christinebao
Date: 2015-10-27 00:34:59 -0700 (Tue, 27 Oct 2015)
New Revision: 8797
Added:
trunk/MgDev/Oem/php/Zend/
trunk/MgDev/Oem/php/Zend/zend_config.w32.h
Add modified zend_config.w32.h to Oem/php folder, it will be used to override official php-x.y.z before build.
Added: trunk/MgDev/Oem/php/Zend/zend_config.w32.h
--- trunk/MgDev/Oem/php/Zend/zend_config.w32.h (rev 0)
+++ trunk/MgDev/Oem/php/Zend/zend_config.w32.h 2015-10-27 07:34:59 UTC (rev 8797)
@@ -0,0 +1,107 @@
+ | Zend Engine |
+ | Copyright (c) 1998-2014 Zend Technologies Ltd. (http://www.zend.com) |
+ | This source file is subject to version 2.00 of the Zend license, |
+ | that is bundled with this package in the file LICENSE, and is |
+ | available through the world-wide-web at the following url: |
+ | http://www.zend.com/license/2_00.txt. |
+ | If you did not receive a copy of the Zend license and are unable to |
+ | obtain it through the world-wide-web, please send a note to |
+ | license at zend.com so we can mail you a copy immediately. |
+ | Authors: Andi Gutmans <andi at zend.com> |
+ | Zeev Suraski <zeev at zend.com> |
+/* $Id$ */
+#ifndef ZEND_CONFIG_W32_H
+#define ZEND_CONFIG_W32_H
+#include <../main/config.w32.h>
+#define _CRTDBG_MAP_ALLOC
+#include <malloc.h>
+#include <stdlib.h>
+#include <crtdbg.h>
+#include <string.h>
+#ifndef ZEND_INCLUDE_FULL_WINDOWS_HEADERS
+#define WIN32_LEAN_AND_MEAN
+#endif
+#include <winsock2.h>
+#include <windows.h>
+#include <float.h>
+typedef unsigned long ulong;
+typedef unsigned int uint;
+#define HAVE_STDIOSTR_H 1
+#define HAVE_CLASS_ISTDIOSTREAM
+#define istdiostream stdiostream
+#if _MSC_VER < 1900
+#define snprintf _snprintf
+#endif
+#if _MSC_VER < 1500
+#define vsnprintf _vsnprintf
+#endif
+#define strcasecmp(s1, s2) stricmp(s1, s2)
+#define strncasecmp(s1, s2, n) strnicmp(s1, s2, n)
+#define zend_isinf(a) ((_fpclass(a) == _FPCLASS_PINF) || (_fpclass(a) == _FPCLASS_NINF))
+#define zend_finite(x) _finite(x)
+#define zend_isnan(x) _isnan(x)
+#define zend_sprintf sprintf
+/* This will cause the compilation process to be MUCH longer, but will generate
+ * a much quicker PHP binary
+#ifdef ZEND_WIN32_FORCE_INLINE
+/* _ALLOW_KEYWORD_MACROS is only relevant for C++ */
+# if (_MSC_VER >= 1700) && !defined(_ALLOW_KEYWORD_MACROS)
+# define _ALLOW_KEYWORD_MACROS
+# endif
+# undef inline
+# define inline __forceinline
+#elif !defined(ZEND_WIN32_KEEP_INLINE)
+# undef inline
+# define inline
+#endif
+#ifdef LIBZEND_EXPORTS
+# define ZEND_API __declspec(dllexport)
+#else
+# define ZEND_API __declspec(dllimport)
+#endif
+#define ZEND_DLEXPORT __declspec(dllexport)
+#define ZEND_DLIMPORT __declspec(dllimport)
+/* 0x00200000L is MB_SERVICE_NOTIFICATION, which is only supported under Windows NT
+ * (and requires _WIN32_WINNT to be defined, which prevents the resulting executable
+ * from running under Windows 9x
+ * Windows 9x should silently ignore it, so it's being used here directly
+#ifndef MB_SERVICE_NOTIFICATION
+#define MB_SERVICE_NOTIFICATION 0x00200000L
+#endif
+#define ZEND_SERVICE_MB_STYLE (MB_TOPMOST|MB_SERVICE_NOTIFICATION)
+#endif /* ZEND_CONFIG_W32_H */
+ * Local variables:
+ * tab-width: 4
+ * c-basic-offset: 4
+ * indent-tabs-mode: t
+ * End:
More information about the mapguide-commits
