[mapguide-commits] r8762 - in trunk/Tools/Maestro: OSGeo.MapGuide.MaestroAPI.Native ProviderTemplate
svn_mapguide at osgeo.org
Wed Sep 23 03:54:16 PDT 2015
Author: jng
Date: 2015-09-23 03:54:16 -0700 (Wed, 23 Sep 2015)
New Revision: 8762
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
trunk/Tools/Maestro/ProviderTemplate/Form1.cs
#2571: Fix use of APIs that have been removed in MGOS 3.0
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2015-09-22 15:52:57 UTC (rev 8761)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2015-09-23 10:54:16 UTC (rev 8762)
@@ -565,8 +565,8 @@
GetByteReaderMethod fetch = () =>
- MgMap m = new MgMap();
- m.Open(res, mapname);
+ MgMap m = new MgMap(m_con);
+ m.Open(mapname);
MgSelection sel = new MgSelection(m);
//The color accepted by MgColor has alpha as the last value, but the returned has alpha first
MgColor color = new MgColor(Utility.ParseHTMLColor(m.GetBackgroundColor()));
@@ -590,8 +590,8 @@
+ m.Open(mapname);
@@ -608,8 +608,8 @@
MgRenderingService rnd = this.Connection.CreateService(MgServiceType.RenderingService) as MgRenderingService;
MgResourceService res = this.Connection.CreateService(MgServiceType.ResourceService) as MgResourceService;
- MgMap mmap = new MgMap();
- mmap.Open(res, map.Name);
+ MgMap mmap = new MgMap(m_con);
+ mmap.Open(map.Name);
MgSelection sel = new MgSelection(mmap);
if (selection != null)
sel.FromXml(selection.ToXml());
@@ -631,8 +631,8 @@
@@ -650,8 +650,8 @@
MgColor color = new MgColor(backgroundColor);
return rnd.RenderMapLegend(mmap, width, height, color, format);
@@ -1318,9 +1318,9 @@
string runtimeMapName = rtMap.Name;
MgRenderingService rs = this.Connection.CreateService(MgServiceType.RenderingService) as MgRenderingService;
- MgMap map = new MgMap();
+ MgMap map = new MgMap(m_con);
string mapname = runtimeMapName.IndexOf(":") > 0 ? new ResourceIdentifier(runtimeMapName).Path : runtimeMapName;
- map.Open(res, mapname);
+ map.Open(mapname);
MgWktReaderWriter r = new MgWktReaderWriter();
MgStringCollection layerNames = null;
Modified: trunk/Tools/Maestro/ProviderTemplate/Form1.cs
--- trunk/Tools/Maestro/ProviderTemplate/Form1.cs 2015-09-22 15:52:57 UTC (rev 8761)
+++ trunk/Tools/Maestro/ProviderTemplate/Form1.cs 2015-09-23 10:54:16 UTC (rev 8762)
@@ -2,6 +2,7 @@
using Microsoft.CodeAnalysis.CSharp;
using System;
using System.Collections.Generic;
+using System.Collections.Immutable;
using System.ComponentModel;
using System.Diagnostics;
using System.IO;
@@ -82,7 +83,7 @@
outputKind: OutputKind.DynamicallyLinkedLibrary,
platform: Platform.AnyCpu,
optimizationLevel: ba.DebugMode ? OptimizationLevel.Debug : OptimizationLevel.Release,
- cryptoKeyFile: keyFile
+ strongNameProvider: new DesktopStrongNameProvider(ImmutableArray.Create(keyFile))
var comp = CSharpCompilation.Create(ba.AssemblyNameWithExtension, files, references, options);
using (var fs = File.OpenWrite(Path.Combine(outputDir, ba.AssemblyNameWithExtension)))
@@ -297,8 +298,11 @@
using (var fp = new SaveFileDialog())
- File.WriteAllText(fp.FileName, txtMessages.Text);
- MessageBox.Show($"Messages saved to {fp.FileName}");
+ if (fp.ShowDialog() == DialogResult.OK)
+ File.WriteAllText(fp.FileName, txtMessages.Text);
+ MessageBox.Show($"Messages saved to {fp.FileName}");
More information about the mapguide-commits
