[mapguide-commits] r8907 - in trunk/Tools/Maestro: Maestro Maestro.AddIn.ExtendedObjectModels Maestro.AddIn.FdoToolbox Maestro.AddIn.Local Maestro.AddIn.Rest Maestro.AddIn.Scripting Maestro.Base Maestro.Editors Maestro.LiveMapEditor Maestro.Login Maestro.MapViewer Maestro.Packaging MaestroAPITestRunner MaestroAPITests MaestroFsPreview MgCooker MgCooker.Cmd OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Local OSGeo.MapGuide.MaestroAPI.Native OSGeo.MapGuide.MaestroAPI.Tests RtMapInspector
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Apr 7 06:40:17 PDT 2016
Author: jng
Date: 2016-04-07 06:40:17 -0700 (Thu, 07 Apr 2016)
New Revision: 8907
   trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/app.config
   trunk/Tools/Maestro/Maestro.AddIn.FdoToolbox/app.config
   trunk/Tools/Maestro/Maestro.AddIn.Local/app.config
   trunk/Tools/Maestro/Maestro.AddIn.Rest/app.config
   trunk/Tools/Maestro/Maestro.AddIn.Scripting/app.config
   trunk/Tools/Maestro/Maestro.Base/app.config
   trunk/Tools/Maestro/Maestro.Editors/app.config
   trunk/Tools/Maestro/Maestro.LiveMapEditor/app.config
   trunk/Tools/Maestro/Maestro.Login/app.config
   trunk/Tools/Maestro/Maestro.MapViewer/app.config
   trunk/Tools/Maestro/Maestro.Packaging/app.config
   trunk/Tools/Maestro/Maestro/changelog.txt
   trunk/Tools/Maestro/MaestroAPITestRunner/App.config
   trunk/Tools/Maestro/MaestroAPITests/app.config
   trunk/Tools/Maestro/MaestroFsPreview/app.config
   trunk/Tools/Maestro/MgCooker.Cmd/app.config
   trunk/Tools/Maestro/MgCooker/app.config
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/app.config
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/app.config
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/app.config
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/app.config
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/app.config
   trunk/Tools/Maestro/RtMapInspector/app.config
- Update changelog.txt
- Fix GeoAPI version in binding redirects
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro/changelog.txt	2016-04-07 13:40:17 UTC (rev 8907)
@@ -1,5 +1,19 @@
-6.0m4
+6.0m5
+ - Fix: Missing NetTopologySuite.dll from installer, breaking various functionality
+ - Fix: Feature Source XML does not properly update when switching to unmanaged mode
+ - Fix: Cannot make v3.0.0 untiled Map Definitions
+ - MgCooker: Don't start a script generation or tiling run if no actual maps or tilesets have been selected
+ - ProviderTemplate: Update to use the Roslyn compiler
+ - Thirdparty library updates:
+   - GeoAPI 1.7.3.1
+   - NetTopologySuite 1.13.3.2
+   - Newtonsoft.Json 8.0.3
+   - RestSharp 105.2.3
+   - mg-desktop 3.0
+6.0m4
  - Updated to target .net Framework 4.5
  - New mapguide-rest add-in
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/app.config
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -8,7 +8,7 @@
             </dependentAssembly>
             <dependentAssembly>
                 <assemblyIdentity name="GeoAPI" publicKeyToken="a1a0da7def465678" culture="neutral" />
-                <bindingRedirect oldVersion="0.0.0.0-1.7.4.0" newVersion="1.7.4.0" />
+                <bindingRedirect oldVersion="0.0.0.0-1.7.3.0" newVersion="1.7.3.0" />
         </assemblyBinding>
     </runtime>
Modified: trunk/Tools/Maestro/Maestro.AddIn.FdoToolbox/app.config
--- trunk/Tools/Maestro/Maestro.AddIn.FdoToolbox/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.AddIn.FdoToolbox/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -8,7 +8,7 @@
             <dependentAssembly>
         </assemblyBinding>
     </runtime>
Modified: trunk/Tools/Maestro/Maestro.AddIn.Local/app.config
--- trunk/Tools/Maestro/Maestro.AddIn.Local/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.AddIn.Local/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -24,7 +24,7 @@
             <dependentAssembly>
         </assemblyBinding>
     </runtime>
Modified: trunk/Tools/Maestro/Maestro.AddIn.Rest/app.config
--- trunk/Tools/Maestro/Maestro.AddIn.Rest/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.AddIn.Rest/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
     <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/app.config
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -8,7 +8,7 @@
             <dependentAssembly>
         </assemblyBinding>
     </runtime>
Modified: trunk/Tools/Maestro/Maestro.Base/app.config
--- trunk/Tools/Maestro/Maestro.Base/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.Base/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -8,7 +8,7 @@
             <dependentAssembly>
         </assemblyBinding>
     </runtime>
Modified: trunk/Tools/Maestro/Maestro.Editors/app.config
--- trunk/Tools/Maestro/Maestro.Editors/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.Editors/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/Maestro.LiveMapEditor/app.config
--- trunk/Tools/Maestro/Maestro.LiveMapEditor/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.LiveMapEditor/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -17,7 +17,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/Maestro.Login/app.config
--- trunk/Tools/Maestro/Maestro.Login/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.Login/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/Maestro.MapViewer/app.config
--- trunk/Tools/Maestro/Maestro.MapViewer/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.MapViewer/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/Maestro.Packaging/app.config
--- trunk/Tools/Maestro/Maestro.Packaging/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/Maestro.Packaging/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/MaestroAPITestRunner/App.config
--- trunk/Tools/Maestro/MaestroAPITestRunner/App.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/MaestroAPITestRunner/App.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -11,7 +11,7 @@
             <dependentAssembly>
         </assemblyBinding>
     </runtime>
Modified: trunk/Tools/Maestro/MaestroAPITests/app.config
--- trunk/Tools/Maestro/MaestroAPITests/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/MaestroAPITests/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/MaestroFsPreview/app.config
--- trunk/Tools/Maestro/MaestroFsPreview/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/MaestroFsPreview/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -17,7 +17,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/MgCooker/app.config
--- trunk/Tools/Maestro/MgCooker/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/MgCooker/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -17,7 +17,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/MgCooker.Cmd/app.config
--- trunk/Tools/Maestro/MgCooker.Cmd/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/MgCooker.Cmd/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -7,7 +7,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/app.config
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/app.config
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/app.config
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/app.config
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/app.config
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -4,7 +4,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
Modified: trunk/Tools/Maestro/RtMapInspector/app.config
--- trunk/Tools/Maestro/RtMapInspector/app.config	2016-04-07 13:02:44 UTC (rev 8906)
+++ trunk/Tools/Maestro/RtMapInspector/app.config	2016-04-07 13:40:17 UTC (rev 8907)
@@ -17,7 +17,7 @@
       <dependentAssembly>
     </assemblyBinding>
   </runtime>
More information about the mapguide-commits mailing list
