[mapguide-commits] r8915 - in branches/2.6/MgDev: . Oem/LinuxApt Oem/httpd/lib Oem/httpd/lib64 Oem/php/Release_TS Oem/php/x64/Release_TS nuget/MapGuideNuget nuget/MapGuideNuget/CoordSysEnumTest nuget/MapGuideNuget/DesktopConsoleTest nuget/MapGuideNuget/DesktopViewerTest
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Apr 13 06:08:57 PDT 2016
Author: jng
Date: 2016-04-13 06:08:57 -0700 (Wed, 13 Apr 2016)
New Revision: 8915
Added:
   branches/2.6/MgDev/Oem/LinuxApt/apache-tomcat-7.0.68.tar.gz
   branches/2.6/MgDev/Oem/LinuxApt/apr-1.5.2.tar.bz2
   branches/2.6/MgDev/Oem/LinuxApt/httpd-2.4.18.tar.bz2
   branches/2.6/MgDev/Oem/LinuxApt/php-5.5.33.tar.bz2
   branches/2.6/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.41-src.tar.gz
   branches/2.6/MgDev/
   branches/2.6/MgDev/Oem/LinuxApt/build_apt.sh
   branches/2.6/MgDev/Oem/httpd/lib/apr-1.lib
   branches/2.6/MgDev/Oem/httpd/lib/aprutil-1.lib
   branches/2.6/MgDev/Oem/httpd/lib/libapr-1.exp
   branches/2.6/MgDev/Oem/httpd/lib/libapr-1.lib
   branches/2.6/MgDev/Oem/httpd/lib/libapriconv-1.exp
   branches/2.6/MgDev/Oem/httpd/lib/libapriconv-1.lib
   branches/2.6/MgDev/Oem/httpd/lib/libaprutil-1.exp
   branches/2.6/MgDev/Oem/httpd/lib/libaprutil-1.lib
   branches/2.6/MgDev/Oem/httpd/lib/libhttpd.exp
   branches/2.6/MgDev/Oem/httpd/lib/libhttpd.lib
   branches/2.6/MgDev/Oem/httpd/lib/mod_dav.exp
   branches/2.6/MgDev/Oem/httpd/lib/mod_dav.lib
   branches/2.6/MgDev/Oem/httpd/lib/xml.lib
   branches/2.6/MgDev/Oem/httpd/lib64/apr-1.lib
   branches/2.6/MgDev/Oem/httpd/lib64/aprutil-1.lib
   branches/2.6/MgDev/Oem/httpd/lib64/libapr-1.exp
   branches/2.6/MgDev/Oem/httpd/lib64/libapr-1.lib
   branches/2.6/MgDev/Oem/httpd/lib64/libapriconv-1.exp
   branches/2.6/MgDev/Oem/httpd/lib64/libapriconv-1.lib
   branches/2.6/MgDev/Oem/httpd/lib64/libaprutil-1.exp
   branches/2.6/MgDev/Oem/httpd/lib64/libaprutil-1.lib
   branches/2.6/MgDev/Oem/httpd/lib64/libhttpd.exp
   branches/2.6/MgDev/Oem/httpd/lib64/libhttpd.lib
   branches/2.6/MgDev/Oem/httpd/lib64/mod_dav.exp
   branches/2.6/MgDev/Oem/httpd/lib64/mod_dav.lib
   branches/2.6/MgDev/Oem/httpd/lib64/xml.lib
   branches/2.6/MgDev/Oem/php/Release_TS/php5ts.lib
   branches/2.6/MgDev/Oem/php/x64/Release_TS/php5ts.lib
   branches/2.6/MgDev/configure.in
   branches/2.6/MgDev/csmap_excludes.txt
   branches/2.6/MgDev/nuget/MapGuideNuget/
   branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest/
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest/
   branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest/
   branches/2.6/MgDev/prepare_webtier_components.bat
   branches/2.6/MgDev/setenvironment.bat
   branches/2.6/MgDev/setenvironment64.bat
Merged revision(s) 8874-8884 from sandbox/jng/rfc155:
LinuxApt updates
 - PHP 5.5.11 -> 5.5.33
 - HTTPD 2.4.10 -> 2.4.18
 - Tomcat 7.0.56 -> 7.0.68
 - apr 1.5.1 -> 1.5.2
 - Tomcat Connectors 1.2.40 -> 1.2.41
- Windows .lib file updates for PHP and httpd
- Update version numbers in prepare_webtier_components.bat
Update configure.in
Update versions in setenvironment[64].bat
Merged revision(s) 8658 from branches/3.0/MgDev:
I am committing this updated CS-Map ignore list based on the theory that the big, compression-unfriendly USA grid files are not actually being used by the CS-MAP API surface that is exposed to MapGuide. Running our Coordinate System test suite with Process Monitor watching for any access operations to these specific files backs up this theory (no test failures and .
A discussion about reducing CS-Map installation footprint (http://osgeo-org.1560.x6.nabble.com/Slimming-down-the-CS-Map-distribution-td3853427.html) is what motivated this submission.
With this change, our buildpack archives that were weighing in at around 250MB has been reduced down to 75-95MB. I'm expecting similar size reductions in the installers that would be produced from this work.
Update prepare_webtier_components.bat to copy patched headers under \zend
Update ignore list
Restore lib_json.vcxproj to original state
Property changes on: branches/2.6/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625
/sandbox/jng/createruntimemap:7486-7555
/sandbox/rfc94:5099-5163
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392,8423,8433,8439,8443-8444,8518-8519,8567-8568,8571,8588-8589,8595,8616-8618,8626,8682,8728,8844
   + /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/3.0/MgDev:8658
/sandbox/jng/rfc155:8874-8884
Property changes on: branches/2.6/MgDev/Oem/LinuxApt
Modified: svn:ignore
   - httpd-2.4.9
php-5.5.11
*.tar
   + httpd-2.4.9
php-5.5.11
*.tar
php-5.5.17
httpd-2.4.10
httpd-2.4.18
php-5.5.33
Copied: branches/2.6/MgDev/Oem/LinuxApt/apache-tomcat-7.0.68.tar.gz (from rev 8884, sandbox/jng/rfc155/Oem/LinuxApt/apache-tomcat-7.0.68.tar.gz)
(Binary files differ)
Copied: branches/2.6/MgDev/Oem/LinuxApt/apr-1.5.2.tar.bz2 (from rev 8884, sandbox/jng/rfc155/Oem/LinuxApt/apr-1.5.2.tar.bz2)
Modified: branches/2.6/MgDev/Oem/LinuxApt/build_apt.sh
--- branches/2.6/MgDev/Oem/LinuxApt/build_apt.sh	2016-04-12 12:24:44 UTC (rev 8914)
+++ branches/2.6/MgDev/Oem/LinuxApt/build_apt.sh	2016-04-13 13:08:57 UTC (rev 8915)
@@ -15,8 +15,12 @@
 INSTALLDIR=/usr/local/mapguideopensource
-HTTPD_VER=2.4.9
-PHP_VER=5.5.11
+HTTPD_VER=2.4.18
+PHP_VER=5.5.33
+TOMCAT_VER=7.0.68
+CONNECTOR_VER=1.2.41
+APR_VER=1.5.2
+APR_UTIL_VER=1.5.4
 PORT=8008
 TOMCAT=0
 TOMCAT_PORT=8009
@@ -144,12 +148,12 @@
 echo "Apache Httpd build started"
 tar -jxf httpd-$HTTPD_VER.tar.bz2
 if [ ! -d "httpd-$HTTPD_VER/srclib/apr" ]; then
-	tar -jxf apr-1.4.8.tar.bz2
-	mv apr-1.4.8 httpd-$HTTPD_VER/srclib/apr
+	tar -jxf apr-$APR_VER.tar.bz2
+	mv apr-$APR_VER httpd-$HTTPD_VER/srclib/apr
 fi
 if [ ! -d "httpd-$HTTPD_VER/srclib/aprutil" ]; then
-	tar -jxf apr-util-1.5.2.tar.bz2
-	mv apr-util-1.5.2 httpd-$HTTPD_VER/srclib/apr-util
+	tar -jxf apr-util-$APR_UTIL_VER.tar.bz2
+	mv apr-util-$APR_UTIL_VER httpd-$HTTPD_VER/srclib/apr-util
 fi
 pushd httpd-$HTTPD_VER
 ./configure --prefix=$INSTALLWEB/apache2 --enable-mods-shared=all \
@@ -255,8 +259,8 @@
 if [ "$TOMCAT" = "1" ]; then
 echo "Tomcat connector build/install started"
-tar -zxf tomcat-connectors-1.2.37-src.tar.gz
-pushd tomcat-connectors-1.2.37-src/native
+tar -zxf tomcat-connectors-$CONNECTOR_VER-src.tar.gz
+pushd tomcat-connectors-$CONNECTOR_VER-src/native
 ./configure --with-apxs=$INSTALLWEB/apache2/bin/apxs
 check_tomcat_build
@@ -274,10 +278,10 @@
 echo "Tomcat install started"
-tar -zxf apache-tomcat-7.0.42.tar.gz -C $INSTALLWEB
+tar -zxf apache-tomcat-$TOMCAT_VER.tar.gz -C $INSTALLWEB
 check_tomcat_install
 pushd $INSTALLWEB
-mv apache-tomcat-7.0.42 tomcat
+mv apache-tomcat-$TOMCAT_VER tomcat
 popd
 echo "Tomcat install completed"
Copied: branches/2.6/MgDev/Oem/LinuxApt/httpd-2.4.18.tar.bz2 (from rev 8884, sandbox/jng/rfc155/Oem/LinuxApt/httpd-2.4.18.tar.bz2)
Copied: branches/2.6/MgDev/Oem/LinuxApt/php-5.5.33.tar.bz2 (from rev 8884, sandbox/jng/rfc155/Oem/LinuxApt/php-5.5.33.tar.bz2)
Copied: branches/2.6/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.41-src.tar.gz (from rev 8884, sandbox/jng/rfc155/Oem/LinuxApt/tomcat-connectors-1.2.41-src.tar.gz)
Modified: branches/2.6/MgDev/Oem/httpd/lib/apr-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib/aprutil-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib/libapr-1.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib/libapr-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib/libapriconv-1.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib/libapriconv-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib/libaprutil-1.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib/libaprutil-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib/libhttpd.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib/libhttpd.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib/mod_dav.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib/mod_dav.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib/xml.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib64/apr-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib64/aprutil-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib64/libapr-1.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib64/libapr-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib64/libapriconv-1.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib64/libapriconv-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib64/libaprutil-1.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib64/libaprutil-1.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib64/libhttpd.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib64/libhttpd.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib64/mod_dav.exp
Modified: branches/2.6/MgDev/Oem/httpd/lib64/mod_dav.lib
Modified: branches/2.6/MgDev/Oem/httpd/lib64/xml.lib
Modified: branches/2.6/MgDev/Oem/php/Release_TS/php5ts.lib
Modified: branches/2.6/MgDev/Oem/php/x64/Release_TS/php5ts.lib
Modified: branches/2.6/MgDev/configure.in
--- branches/2.6/MgDev/configure.in	2016-04-12 12:24:44 UTC (rev 8914)
+++ branches/2.6/MgDev/configure.in	2016-04-13 13:08:57 UTC (rev 8915)
@@ -39,7 +39,7 @@
 map_opt_oem_distsubdirs=""
 dnl *******************************************************
-dnl PHP 5.5.11 Configuration
+dnl PHP 5.5.33 Configuration
 AC_ARG_WITH([php],
         MAP_HELP_STRING([--with-php],
@@ -48,8 +48,8 @@
         [with_php=no])
 if test $with_php = "no"; then
-    AC_MSG_NOTICE([Using php 5.5.11 from included Oem Directory])
-	php_src=`pwd`/Oem/LinuxApt/php-5.5.11
+    AC_MSG_NOTICE([Using php 5.5.33 from included Oem Directory])
+	php_src=`pwd`/Oem/LinuxApt/php-5.5.33
 else
     AC_MSG_NOTICE([Using custom PHP source directory])
 	php_src=$with_php
@@ -62,7 +62,7 @@
 AC_SUBST(php_src)
-dnl httpd 2.4.9 Configuration
+dnl httpd 2.4.18 Configuration
 AC_ARG_WITH([httpd],
 		MAP_HELP_STRING([--with-httpd],
@@ -71,8 +71,8 @@
 		[with_httpd=no])
 if test $with_httpd = "no"; then
-    AC_MSG_NOTICE([Using httpd 2.4.9 from included Oem Directory])
-	httpd_src=`pwd`/Oem/LinuxApt/httpd-2.4.9
+    AC_MSG_NOTICE([Using httpd 2.4.18 from included Oem Directory])
+	httpd_src=`pwd`/Oem/LinuxApt/httpd-2.4.18
 else
     AC_MSG_NOTICE([Using custom httpd source directory])
 	httpd_src=$with_httpd
Modified: branches/2.6/MgDev/csmap_excludes.txt
--- branches/2.6/MgDev/csmap_excludes.txt	2016-04-12 12:24:44 UTC (rev 8914)
+++ branches/2.6/MgDev/csmap_excludes.txt	2016-04-13 13:08:57 UTC (rev 8915)
@@ -11,4 +11,10 @@
 JGD2011V100.par
 .MRT
 compiler.
-cs-map.
\ No newline at end of file
+cs-map.
+Usa\Geoid96
+Usa\Geoid99
+Usa\Geoid03
+Usa\NSRS2007
+Usa\NSRS2011
+WW15MGH.GRD
Property changes on: branches/2.6/MgDev/nuget/MapGuideNuget
Added: svn:ignore
   + packages
*.suo
Property changes on: branches/2.6/MgDev/nuget/MapGuideNuget/CoordSysEnumTest
Added: svn:ignore
   + bin
obj
Property changes on: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopConsoleTest
Added: svn:ignore
   + bin
obj
packages.config
Property changes on: branches/2.6/MgDev/nuget/MapGuideNuget/DesktopViewerTest
Added: svn:ignore
   + bin
obj
packages.config
Modified: branches/2.6/MgDev/prepare_webtier_components.bat
--- branches/2.6/MgDev/prepare_webtier_components.bat	2016-04-12 12:24:44 UTC (rev 8914)
+++ branches/2.6/MgDev/prepare_webtier_components.bat	2016-04-13 13:08:57 UTC (rev 8915)
@@ -1,7 +1,7 @@
 @echo off
 SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
-SET HTTPD_VER=2.4.9
-SET PHP_VER=5.5.11
+SET HTTPD_VER=2.4.18
+SET PHP_VER=5.5.33
 pushd Oem\LinuxApt
 :check_httpd
 if not exist httpd-%HTTPD_VER% goto unpack_httpd
@@ -49,6 +49,7 @@
 echo Patching PHP headers
 copy /Y ..\php\main\*.h php-%PHP_VER%\main\
 copy /Y ..\php\TSRM\*.h php-%PHP_VER%\TSRM\
+copy /Y ..\php\Zend\*.h php-%PHP_VER%\Zend\
 :patch_httpd_headers
 echo Patching HTTPD headers
 copy /Y ..\httpd\include\*.h httpd-%HTTPD_VER%\include\
Modified: branches/2.6/MgDev/setenvironment.bat
--- branches/2.6/MgDev/setenvironment.bat	2016-04-12 12:24:44 UTC (rev 8914)
+++ branches/2.6/MgDev/setenvironment.bat	2016-04-13 13:08:57 UTC (rev 8915)
@@ -99,9 +99,9 @@
 call prepare_webtier_components.bat
 rem Set the env vars that VS will reference
-SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.5.11
+SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.5.33
 SET PHP_LIB=%MG_OEM%\php\Release_TS
-SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.9
+SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.18
 SET HTTPD_LIB=%MG_OEM%\httpd\lib
 rem Sanity checks
 if not exist "%PHP_SRC%" echo Environment variable PHP_SRC does not point to a valid directory (%PHP_SRC%). Please edit setenvironment64.bat to ensure PHP_SRC points to a valid directory
Modified: branches/2.6/MgDev/setenvironment64.bat
--- branches/2.6/MgDev/setenvironment64.bat	2016-04-12 12:24:44 UTC (rev 8914)
+++ branches/2.6/MgDev/setenvironment64.bat	2016-04-13 13:08:57 UTC (rev 8915)
@@ -104,9 +104,9 @@
 SET PHP_LIB=%MG_OEM%\php\x64\Release_TS
 SET HTTPD_LIB=%MG_OEM%\httpd\lib64
 rem Sanity checks
More information about the mapguide-commits mailing list
