[mapguide-commits] r9024 - in branches/2.6/MgDev: . Common/Renderers
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Aug 23 05:42:47 PDT 2016
Author: jng
Date: 2016-08-23 05:42:46 -0700 (Tue, 23 Aug 2016)
New Revision: 9024
   branches/2.6/MgDev/
   branches/2.6/MgDev/Common/Renderers/AGGRenderer.cpp
Merged revision(s) 9021 from trunk/MgDev:
Merged revision(s) 9019-9020 from sandbox/adsk/3.1n:
#2736: Server crash when layer contains complicate symbols https://trac.osgeo.org/mapguide/ticket/2736
It is a heap corruption defect. The issue is at line 1792~1814, Common\Renderers\AGGRenderer.cpp. There are minx and maxx which are double. Then we convert them to int. But in some special cases, the converted imaxx will be less than iminx. It results in some memory are corrupted in next operations. To fix the issue, we need to add a check for the values.
Refine submission 9019.
Property changes on: branches/2.6/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/3.0/MgDev:8658,8958-8959
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625
/sandbox/adsk/3.1n:8871,8912,8921-8922,8942
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/php56x:8975-8985
/sandbox/jng/rfc155:8874-8884
/sandbox/rfc94:5099-5163
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392,8423,8433,8439,8443-8444,8518-8519,8567-8568,8571,8588-8589,8595,8616-8618,8626,8682,8728,8844,8956,8980,8996,9000,9004-9006
   + /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/adsk/3.1n:8871,8912,8921-8922,8942,9019-9020
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392,8423,8433,8439,8443-8444,8518-8519,8567-8568,8571,8588-8589,8595,8616-8618,8626,8682,8728,8844,8956,8980,8996,9000,9004-9006,9021
Modified: branches/2.6/MgDev/Common/Renderers/AGGRenderer.cpp
--- branches/2.6/MgDev/Common/Renderers/AGGRenderer.cpp	2016-08-23 12:34:28 UTC (rev 9023)
+++ branches/2.6/MgDev/Common/Renderers/AGGRenderer.cpp	2016-08-23 12:42:46 UTC (rev 9024)
@@ -1806,9 +1806,12 @@
         // clear the affected region of the alpha mask
         agg::gray8 cc(0);
-        unsigned width = (int)imaxx - (int)iminx + 1;
-        for (int y=iminy; y<=imaxy; ++y)
-            c()->mask_pixf->copy_hline(iminx, y, width, cc);
+        if (imaxx >= iminx)
+            unsigned width = (int)imaxx - (int)iminx + 1;
+            for (int y = iminy; y <= imaxy; ++y)
+                c()->mask_pixf->copy_hline(iminx, y, width, cc);
         // render the alpha mask polygon
         c()->mask_ren.color(agg::gray8(255));
More information about the mapguide-commits mailing list
