[mapguide-commits] r8977 - in sandbox/jng/php56x: . Oem/LinuxApt Oem/jsoncpp/src/lib_json Oem/php/Release_TS Oem/php/Zend Oem/php/main Oem/php/x64/Release_TS
svn_mapguide at osgeo.org
Mon Jul 11 10:07:34 PDT 2016
Author: jng
Date: 2016-07-11 10:07:34 -0700 (Mon, 11 Jul 2016)
New Revision: 8977
Added:
sandbox/jng/php56x/Oem/LinuxApt/php-5.6.23.tar.bz2
Removed:
sandbox/jng/php56x/Oem/LinuxApt/php-5.5.33.tar.bz2
sandbox/jng/php56x/Oem/LinuxApt/build_apt.sh
sandbox/jng/php56x/Oem/jsoncpp/src/lib_json/lib_json.vcxproj
sandbox/jng/php56x/Oem/php/Release_TS/php5ts.lib
sandbox/jng/php56x/Oem/php/Zend/zend_config.w32.h
sandbox/jng/php56x/Oem/php/main/win95nt.h
sandbox/jng/php56x/Oem/php/x64/Release_TS/php5ts.lib
sandbox/jng/php56x/configure.in
sandbox/jng/php56x/prepare_webtier_components.bat
sandbox/jng/php56x/setenvironment.bat
sandbox/jng/php56x/setenvironment64.bat
PHP 5.6 updates
- Update tarball in LinuxApt
- Update import libs
- Update PHP versions in
- build_apt.sh
- configure.in
- prepare_webtier_components.bat
- setenvironment[64].bat
Modified: sandbox/jng/php56x/Oem/LinuxApt/build_apt.sh
--- sandbox/jng/php56x/Oem/LinuxApt/build_apt.sh 2016-07-11 13:28:46 UTC (rev 8976)
+++ sandbox/jng/php56x/Oem/LinuxApt/build_apt.sh 2016-07-11 17:07:34 UTC (rev 8977)
@@ -16,7 +16,7 @@
INSTALLDIR=/usr/local/mapguideopensource
HTTPD_VER=2.4.18
-PHP_VER=5.5.33
+PHP_VER=5.6.23
TOMCAT_VER=7.0.68
CONNECTOR_VER=1.2.41
APR_VER=1.5.2
Deleted: sandbox/jng/php56x/Oem/LinuxApt/php-5.5.33.tar.bz2
(Binary files differ)
Added: sandbox/jng/php56x/Oem/LinuxApt/php-5.6.23.tar.bz2
Property changes on: sandbox/jng/php56x/Oem/LinuxApt/php-5.6.23.tar.bz2
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: sandbox/jng/php56x/Oem/jsoncpp/src/lib_json/lib_json.vcxproj
--- sandbox/jng/php56x/Oem/jsoncpp/src/lib_json/lib_json.vcxproj 2016-07-11 13:28:46 UTC (rev 8976)
+++ sandbox/jng/php56x/Oem/jsoncpp/src/lib_json/lib_json.vcxproj 2016-07-11 17:07:34 UTC (rev 8977)
@@ -187,7 +187,6 @@
<RuntimeTypeInfo>true</RuntimeTypeInfo>
<PrecompiledHeader>
</PrecompiledHeader>
- <AssemblerOutput>AssemblyAndSourceCode</AssemblerOutput>
<ProgramDataBaseFileName>$(IntDir)$(ProjectName).pdb</ProgramDataBaseFileName>
<WarningLevel>Level3</WarningLevel>
<DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
Modified: sandbox/jng/php56x/Oem/php/Release_TS/php5ts.lib
Modified: sandbox/jng/php56x/Oem/php/Zend/zend_config.w32.h
--- sandbox/jng/php56x/Oem/php/Zend/zend_config.w32.h 2016-07-11 13:28:46 UTC (rev 8976)
+++ sandbox/jng/php56x/Oem/php/Zend/zend_config.w32.h 2016-07-11 17:07:34 UTC (rev 8977)
@@ -2,7 +2,7 @@
| Zend Engine |
- | Copyright (c) 1998-2014 Zend Technologies Ltd. (http://www.zend.com) |
+ | Copyright (c) 1998-2016 Zend Technologies Ltd. (http://www.zend.com) |
| This source file is subject to version 2.00 of the Zend license, |
| that is bundled with this package in the file LICENSE, and is |
@@ -15,6 +15,8 @@
| Authors: Andi Gutmans <andi at zend.com> |
| Zeev Suraski <zeev at zend.com> |
+ | MapGuide Changes: MSVC 2015 #ifdef guard for snprintf
/* $Id$ */
Modified: sandbox/jng/php56x/Oem/php/main/win95nt.h
--- sandbox/jng/php56x/Oem/php/main/win95nt.h 2016-07-11 13:28:46 UTC (rev 8976)
+++ sandbox/jng/php56x/Oem/php/main/win95nt.h 2016-07-11 17:07:34 UTC (rev 8977)
@@ -2,7 +2,7 @@
| PHP Version 5 |
- | Copyright (c) 1997-2013 The PHP Group |
+ | Copyright (c) 1997-2016 The PHP Group |
| This source file is subject to version 3.01 of the PHP license, |
Modified: sandbox/jng/php56x/Oem/php/x64/Release_TS/php5ts.lib
Modified: sandbox/jng/php56x/configure.in
--- sandbox/jng/php56x/configure.in 2016-07-11 13:28:46 UTC (rev 8976)
+++ sandbox/jng/php56x/configure.in 2016-07-11 17:07:34 UTC (rev 8977)
@@ -39,7 +39,7 @@
map_opt_oem_distsubdirs=""
dnl *******************************************************
-dnl PHP 5.5.33 Configuration
+dnl PHP 5.6.23 Configuration
AC_ARG_WITH([php],
MAP_HELP_STRING([--with-php],
@@ -48,8 +48,8 @@
[with_php=no])
if test $with_php = "no"; then
- AC_MSG_NOTICE([Using php 5.5.33 from included Oem Directory])
- php_src=`pwd`/Oem/LinuxApt/php-5.5.33
+ AC_MSG_NOTICE([Using php 5.6.23 from included Oem Directory])
+ php_src=`pwd`/Oem/LinuxApt/php-5.6.23
else
AC_MSG_NOTICE([Using custom PHP source directory])
php_src=$with_php
Modified: sandbox/jng/php56x/prepare_webtier_components.bat
--- sandbox/jng/php56x/prepare_webtier_components.bat 2016-07-11 13:28:46 UTC (rev 8976)
+++ sandbox/jng/php56x/prepare_webtier_components.bat 2016-07-11 17:07:34 UTC (rev 8977)
@@ -1,7 +1,7 @@
@echo off
SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
SET HTTPD_VER=2.4.18
-SET PHP_VER=5.5.33
+SET PHP_VER=5.6.23
pushd Oem\LinuxApt
:check_httpd
if not exist httpd-%HTTPD_VER% goto unpack_httpd
Modified: sandbox/jng/php56x/setenvironment.bat
--- sandbox/jng/php56x/setenvironment.bat 2016-07-11 13:28:46 UTC (rev 8976)
+++ sandbox/jng/php56x/setenvironment.bat 2016-07-11 17:07:34 UTC (rev 8977)
@@ -101,7 +101,7 @@
call prepare_webtier_components.bat
rem Set the env vars that VS will reference
-SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.5.33
+SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.6.23
SET PHP_LIB=%MG_OEM%\php\Release_TS
SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.18
SET HTTPD_LIB=%MG_OEM%\httpd\lib
Modified: sandbox/jng/php56x/setenvironment64.bat
--- sandbox/jng/php56x/setenvironment64.bat 2016-07-11 13:28:46 UTC (rev 8976)
+++ sandbox/jng/php56x/setenvironment64.bat 2016-07-11 17:07:34 UTC (rev 8977)
@@ -106,7 +106,7 @@
SET PHP_LIB=%MG_OEM%\php\x64\Release_TS
SET HTTPD_LIB=%MG_OEM%\httpd\lib64
More information about the mapguide-commits
