[mapguide-commits] r8981 - in trunk/MgDev/UnitTest/TestData: FeatureService ResourceService
svn_mapguide at osgeo.org
Tue Jul 12 05:57:25 PDT 2016
Author: jng
Date: 2016-07-12 05:57:24 -0700 (Tue, 12 Jul 2016)
New Revision: 8981
trunk/MgDev/UnitTest/TestData/FeatureService/FeatureServiceTest.dump
trunk/MgDev/UnitTest/TestData/ResourceService/ResourceServiceTest.dump
Update web tier test data expected results
- Incorrect FDO provider version (TODO: we should really update the result normalization code to strip FDO version numbers from relevant results before comparison!)
- Incorrect exception type
Modified: trunk/MgDev/UnitTest/TestData/FeatureService/FeatureServiceTest.dump
--- trunk/MgDev/UnitTest/TestData/FeatureService/FeatureServiceTest.dump 2016-07-12 12:55:02 UTC (rev 8980)
+++ trunk/MgDev/UnitTest/TestData/FeatureService/FeatureServiceTest.dump 2016-07-12 12:57:24 UTC (rev 8981)
@@ -521,7 +521,7 @@
INSERT INTO "HttpTestResults" VALUES('GetSpatialContexts on a SDF resource', 8010, 'text/xml; charset=utf-8', '
<FdoSpatialContextList>
- <ProviderName>OSGeo.SDF.3.9</ProviderName>
+ <ProviderName>OSGeo.SDF.4.1</ProviderName>
<SpatialContext>
<CoordinateSystemName>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</CoordinateSystemName>
<CoordinateSystemWkt>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</CoordinateSystemWkt>
@@ -544,7 +544,7 @@
</FdoSpatialContextList>');
INSERT INTO "HttpTestResults" VALUES('GetSpatialContexts on a SDF resource', 8011, 'text/xml; charset=utf-8', '
<SpatialContext>
@@ -1851,7 +1851,7 @@
INSERT INTO "ApiTestResults" VALUES('GetSpatialContexts on a SDF resource when resource data is not set yet', 8009, 'text/plain', 'mgapplicationexception');
INSERT INTO "ApiTestResults" VALUES('GetSpatialContexts on a SDF resource', 8010, 'text/xml', '
<SpatialContext>
@@ -1874,7 +1874,7 @@
INSERT INTO "ApiTestResults" VALUES('GetSpatialContexts on a SDF resource', 8011, 'text/xml', '
<SpatialContext>
Modified: trunk/MgDev/UnitTest/TestData/ResourceService/ResourceServiceTest.dump
--- trunk/MgDev/UnitTest/TestData/ResourceService/ResourceServiceTest.dump 2016-07-12 12:55:02 UTC (rev 8980)
+++ trunk/MgDev/UnitTest/TestData/ResourceService/ResourceServiceTest.dump 2016-07-12 12:57:24 UTC (rev 8981)
@@ -936,7 +936,7 @@
INSERT INTO "ApiTestResults" VALUES('RenameResourceData when the old data name and new data name are the same. Expects InvalidArgument exception',15007,'text/plain',X'6D67696E76616C6964617267756D656E74657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('RenameResourceData using folder resource. Expects InvalidResourceType exception',15008,'text/plain',X'6D67696E76616C69647265736F7572636574797065657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('RenameResourceData using valid parameters',15009,'','');
-INSERT INTO "ApiTestResults" VALUES('SetRresource with empty content file',2005,'text/plain','mginvalidargumentexception');
+INSERT INTO "ApiTestResults" VALUES('SetResource with empty content file',2005,'text/plain','mginvalidargumentexception');
INSERT INTO "ApiTestResults" VALUES('SetResource when the resource is folder and the content file is not empty',2006,'text/plain',X'6D67696E76616C6964617267756D656E74657863657074696F6E');
INSERT INTO "ApiTestResults" VALUES('SetResource when the resouce is folder',2007,'','');
INSERT INTO "ApiTestResults" VALUES('SetResource when the resource is a duplicate folder.(Should work)',2008,'text/plain','An existing resource was detected: Library://Test/ResourceTest/');
@@ -1235,7 +1235,7 @@
INSERT INTO "HttpTestResults" VALUES('RenameResourceData when the old data name and new data name are the same. Expects InvalidArgument exception',15007,'text/plain',X'4D67496E76616C6964417267756D656E74457863657074696F6E0D0A');
INSERT INTO "HttpTestResults" VALUES('RenameResourceData using folder resource. Expects InvalidResourceType exception',15008,'text/plain',X'4D67496E76616C69645265736F7572636554797065457863657074696F6E0D0A');
INSERT INTO "HttpTestResults" VALUES('RenameResourceData using valid parameters',15009,'text/plain; charset=utf-8',X'');
-INSERT INTO "HttpTestResults" VALUES('AddRresource with empty content file',2005,'text/plain','MgInvalidArgumentException
+INSERT INTO "HttpTestResults" VALUES('AddResource with empty content file',2005,'text/plain','MgNullArgumentException
INSERT INTO "HttpTestResults" VALUES('AddResource when the resource is folder and the content file is not empty',2006,'text/plain',X'4D67496E76616C6964417267756D656E74457863657074696F6E0D0A');
INSERT INTO "HttpTestResults" VALUES('AddResource when the resouce is folder',2007,'text/plain; charset=utf-8',X'');
More information about the mapguide-commits
