[mapguide-commits] r8990 - in branches/3.1/MgDev: . Oem/LinuxApt Oem/php/Release_TS Oem/php/Zend Oem/php/main Oem/php/x64/Release_TS
svn_mapguide at osgeo.org
Tue Jul 26 04:56:51 PDT 2016
Author: jng
Date: 2016-07-26 04:56:51 -0700 (Tue, 26 Jul 2016)
New Revision: 8990
Added:
branches/3.1/MgDev/Oem/LinuxApt/php-5.6.23.tar.bz2
Removed:
branches/3.1/MgDev/Oem/LinuxApt/php-5.5.33.tar.bz2
branches/3.1/MgDev/
branches/3.1/MgDev/Oem/LinuxApt/build_apt.sh
branches/3.1/MgDev/Oem/php/Release_TS/php5ts.lib
branches/3.1/MgDev/Oem/php/Zend/zend_config.w32.h
branches/3.1/MgDev/Oem/php/main/win95nt.h
branches/3.1/MgDev/Oem/php/x64/Release_TS/php5ts.lib
branches/3.1/MgDev/configure.in
branches/3.1/MgDev/prepare_webtier_components.bat
branches/3.1/MgDev/setenvironment.bat
branches/3.1/MgDev/setenvironment64.bat
Merged revision(s) 8975-8985 from sandbox/jng/php56x:
PHP 5.6 updates
- Update tarball in LinuxApt?
- Update import libs
- Update PHP versions in
- build_apt.sh
- configure.in
- prepare_webtier_components.bat
- setenvironment[64].bat
Property changes on: branches/3.1/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/branches/3.0/MgDev:8658,8705,8710
/sandbox/VC140:8684-8759
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
/sandbox/adsk/3.1n:8871,8895,8901,8912-8913,8921-8922,8942
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/dwftk:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/rfc155:8872-8884
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
/trunk/MgDev:8955-8956,8969,8980-8981,8986
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/php56x:8975-8985
Property changes on: branches/3.1/MgDev/Oem/LinuxApt
Modified: svn:ignore
- httpd-2.4.9
php-5.5.11
*.tar
php-5.5.17
httpd-2.4.10
httpd-2.4.18
php-5.5.33
+ httpd-2.4.9
php-5.5.11
*.tar
php-5.5.17
httpd-2.4.10
httpd-2.4.18
php-5.5.33
php-5.6.23
Modified: branches/3.1/MgDev/Oem/LinuxApt/build_apt.sh
--- branches/3.1/MgDev/Oem/LinuxApt/build_apt.sh 2016-07-26 11:40:33 UTC (rev 8989)
+++ branches/3.1/MgDev/Oem/LinuxApt/build_apt.sh 2016-07-26 11:56:51 UTC (rev 8990)
@@ -16,7 +16,7 @@
INSTALLDIR=/usr/local/mapguideopensource
HTTPD_VER=2.4.18
-PHP_VER=5.5.33
+PHP_VER=5.6.23
TOMCAT_VER=7.0.68
CONNECTOR_VER=1.2.41
APR_VER=1.5.2
Deleted: branches/3.1/MgDev/Oem/LinuxApt/php-5.5.33.tar.bz2
(Binary files differ)
Copied: branches/3.1/MgDev/Oem/LinuxApt/php-5.6.23.tar.bz2 (from rev 8985, sandbox/jng/php56x/Oem/LinuxApt/php-5.6.23.tar.bz2)
Modified: branches/3.1/MgDev/Oem/php/Release_TS/php5ts.lib
Modified: branches/3.1/MgDev/Oem/php/Zend/zend_config.w32.h
--- branches/3.1/MgDev/Oem/php/Zend/zend_config.w32.h 2016-07-26 11:40:33 UTC (rev 8989)
+++ branches/3.1/MgDev/Oem/php/Zend/zend_config.w32.h 2016-07-26 11:56:51 UTC (rev 8990)
@@ -2,7 +2,7 @@
| Zend Engine |
- | Copyright (c) 1998-2014 Zend Technologies Ltd. (http://www.zend.com) |
+ | Copyright (c) 1998-2016 Zend Technologies Ltd. (http://www.zend.com) |
| This source file is subject to version 2.00 of the Zend license, |
| that is bundled with this package in the file LICENSE, and is |
@@ -15,6 +15,8 @@
| Authors: Andi Gutmans <andi at zend.com> |
| Zeev Suraski <zeev at zend.com> |
+ | MapGuide Changes: MSVC 2015 #ifdef guard for snprintf
/* $Id$ */
Modified: branches/3.1/MgDev/Oem/php/main/win95nt.h
--- branches/3.1/MgDev/Oem/php/main/win95nt.h 2016-07-26 11:40:33 UTC (rev 8989)
+++ branches/3.1/MgDev/Oem/php/main/win95nt.h 2016-07-26 11:56:51 UTC (rev 8990)
@@ -2,7 +2,7 @@
| PHP Version 5 |
- | Copyright (c) 1997-2013 The PHP Group |
+ | Copyright (c) 1997-2016 The PHP Group |
| This source file is subject to version 3.01 of the PHP license, |
Modified: branches/3.1/MgDev/Oem/php/x64/Release_TS/php5ts.lib
Modified: branches/3.1/MgDev/configure.in
--- branches/3.1/MgDev/configure.in 2016-07-26 11:40:33 UTC (rev 8989)
+++ branches/3.1/MgDev/configure.in 2016-07-26 11:56:51 UTC (rev 8990)
@@ -39,7 +39,7 @@
map_opt_oem_distsubdirs=""
dnl *******************************************************
-dnl PHP 5.5.33 Configuration
+dnl PHP 5.6.23 Configuration
AC_ARG_WITH([php],
MAP_HELP_STRING([--with-php],
@@ -48,8 +48,8 @@
[with_php=no])
if test $with_php = "no"; then
- AC_MSG_NOTICE([Using php 5.5.33 from included Oem Directory])
- php_src=`pwd`/Oem/LinuxApt/php-5.5.33
+ AC_MSG_NOTICE([Using php 5.6.23 from included Oem Directory])
+ php_src=`pwd`/Oem/LinuxApt/php-5.6.23
else
AC_MSG_NOTICE([Using custom PHP source directory])
php_src=$with_php
Modified: branches/3.1/MgDev/prepare_webtier_components.bat
--- branches/3.1/MgDev/prepare_webtier_components.bat 2016-07-26 11:40:33 UTC (rev 8989)
+++ branches/3.1/MgDev/prepare_webtier_components.bat 2016-07-26 11:56:51 UTC (rev 8990)
@@ -1,7 +1,7 @@
@echo off
SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
SET HTTPD_VER=2.4.18
-SET PHP_VER=5.5.33
+SET PHP_VER=5.6.23
pushd Oem\LinuxApt
:check_httpd
if not exist httpd-%HTTPD_VER% goto unpack_httpd
Modified: branches/3.1/MgDev/setenvironment.bat
--- branches/3.1/MgDev/setenvironment.bat 2016-07-26 11:40:33 UTC (rev 8989)
+++ branches/3.1/MgDev/setenvironment.bat 2016-07-26 11:56:51 UTC (rev 8990)
@@ -101,7 +101,7 @@
call prepare_webtier_components.bat
rem Set the env vars that VS will reference
-SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.5.33
+SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.6.23
SET PHP_LIB=%MG_OEM%\php\Release_TS
SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.18
SET HTTPD_LIB=%MG_OEM%\httpd\lib
Modified: branches/3.1/MgDev/setenvironment64.bat
--- branches/3.1/MgDev/setenvironment64.bat 2016-07-26 11:40:33 UTC (rev 8989)
+++ branches/3.1/MgDev/setenvironment64.bat 2016-07-26 11:56:51 UTC (rev 8990)
@@ -106,7 +106,7 @@
SET PHP_LIB=%MG_OEM%\php\x64\Release_TS
SET HTTPD_LIB=%MG_OEM%\httpd\lib64
More information about the mapguide-commits
