[mapguide-commits] r9008 - in branches/3.0/MgDev: . Web/src/mapviewerjava Web/src/mapviewernet Web/src/mapviewerphp
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jul 27 07:03:11 PDT 2016
Author: jng
Date: 2016-07-27 07:03:11 -0700 (Wed, 27 Jul 2016)
New Revision: 9008
   branches/3.0/MgDev/
   branches/3.0/MgDev/Web/src/mapviewerjava/buffer.jsp
   branches/3.0/MgDev/Web/src/mapviewerjava/common.jsp
   branches/3.0/MgDev/Web/src/mapviewerjava/search.jsp
   branches/3.0/MgDev/Web/src/mapviewerjava/selectwithin.jsp
   branches/3.0/MgDev/Web/src/mapviewernet/buffer.aspx
   branches/3.0/MgDev/Web/src/mapviewernet/common.aspx
   branches/3.0/MgDev/Web/src/mapviewernet/search.aspx
   branches/3.0/MgDev/Web/src/mapviewernet/selectwithin.aspx
   branches/3.0/MgDev/Web/src/mapviewerphp/buffer.php
   branches/3.0/MgDev/Web/src/mapviewerphp/common.php
   branches/3.0/MgDev/Web/src/mapviewerphp/search.php
   branches/3.0/MgDev/Web/src/mapviewerphp/selectwithin.php
Merged revision(s) 9004-9006 from trunk/MgDev:
#2732: Use explicit property lists where MgFeatureQueryOptions is used.
This is to ensure that a "select * from featureclass" query from relational FDO providers will have its column list bounded to what is recognized in the class definition returned by the provider. Some providers are known to produce "select * from table" queries that "leak" out column types that the provider does not know how to process. Using an explicit property list from its class definition will allow us to avoid such issues.
This is for the Java implementation of the AJAX viewer
This is for the PHP implementation of the AJAX viewer
This is for the ASP.net implementation of the AJAX viewer
Property changes on: branches/3.0/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
/sandbox/adsk/3.1n:8871,8912,8921-8922,8942
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/dwftk:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/php56x:8975-8985
/sandbox/jng/rfc155:8874-8884
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
/trunk/MgDev:8595,8616-8618,8626,8682,8700,8728,8844,8956,8969,8980-8981,8996,9000
   + /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8595,8616-8618,8626,8682,8700,8728,8844,8956,8969,8980-8981,8996,9000,9004-9006
Modified: branches/3.0/MgDev/Web/src/mapviewerjava/buffer.jsp
--- branches/3.0/MgDev/Web/src/mapviewerjava/buffer.jsp	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewerjava/buffer.jsp	2016-07-27 14:03:11 UTC (rev 9008)
@@ -274,7 +274,8 @@
             if(filter == null || filter.length() == 0)
                 continue;
-            MgFeatureQueryOptions query = new MgFeatureQueryOptions();
+            MgClassDefinition clsDef = selLayer.GetClassDefinition();
+            MgFeatureQueryOptions query = BuildFeatureQueryOptions(clsDef);
             query.SetFilter(filter);
             MgResourceIdentifier featureSource = new MgResourceIdentifier(selLayer.GetFeatureSourceId());
Modified: branches/3.0/MgDev/Web/src/mapviewerjava/common.jsp
--- branches/3.0/MgDev/Web/src/mapviewerjava/common.jsp	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewerjava/common.jsp	2016-07-27 14:03:11 UTC (rev 9008)
@@ -300,4 +300,54 @@
     return validColorString;
+MgFeatureQueryOptions BuildFeatureQueryOptions(MgClassDefinition classDef) throws MgException
+    MgFeatureQueryOptions query = new MgFeatureQueryOptions();
+    String geomPropName = classDef.GetDefaultGeometryPropertyName();
+    MgPropertyDefinitionCollection propertyList = classDef.GetProperties();
+    for (int i = 0; i < propertyList.GetCount(); i++)
+        MgPropertyDefinition propertyDef = propertyList.GetItem(i);
+        String property = propertyDef.GetName();
+        if ((!property.equals(geomPropName)) && (propertyDef.GetPropertyType() == MgFeaturePropertyType.DataProperty))
+            MgDataPropertyDefinition dp = (MgDataPropertyDefinition)propertyDef;
+            int propertyType = dp.GetDataType();
+            switch (propertyType) {
+                case MgPropertyType.Boolean:
+                    query.AddFeatureProperty(property);
+                    break;
+                case MgPropertyType.Byte:
+                    break;
+                case MgPropertyType.DateTime:
+                    break;
+                case MgPropertyType.Single:
+                    break;
+                case MgPropertyType.Double:
+                    break;
+                case MgPropertyType.Int16:
+                    break;
+                case MgPropertyType.Int32:
+                    break;
+                case MgPropertyType.Int64:
+                    break;
+                case MgPropertyType.String:
+                    break;
+        } else if (property.equals(geomPropName)) {
+    return query;
Modified: branches/3.0/MgDev/Web/src/mapviewerjava/search.jsp
--- branches/3.0/MgDev/Web/src/mapviewerjava/search.jsp	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewerjava/search.jsp	2016-07-27 14:03:11 UTC (rev 9008)
@@ -114,10 +114,11 @@
         boolean displayAll = (resProps.size() == 0);
         //query the features
-        MgFeatureQueryOptions opts = new MgFeatureQueryOptions();
+        MgClassDefinition clsDef = layer.GetClassDefinition();
+        MgFeatureQueryOptions opts = BuildFeatureQueryOptions(clsDef);
         opts.SetFilter(filter);
         String featureClassName = layer.GetFeatureClassName();
-        features = layer.SelectFeatures( opts);
+        features = layer.SelectFeatures(opts);
         boolean hasResult = features.ReadNext();
         if(hasResult)
Modified: branches/3.0/MgDev/Web/src/mapviewerjava/selectwithin.jsp
--- branches/3.0/MgDev/Web/src/mapviewerjava/selectwithin.jsp	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewerjava/selectwithin.jsp	2016-07-27 14:03:11 UTC (rev 9008)
@@ -116,7 +116,8 @@
         MgLayer layer = (MgLayer) selLayers.GetItem(i);
         String filter = sel.GenerateFilter(layer, layer.GetFeatureClassName());
         MgResourceIdentifier featureSource = new MgResourceIdentifier(layer.GetFeatureSourceId());
         MgFeatureReader features = featureSrvc.SelectFeatures(featureSource, layer.GetFeatureClassName(), query);
Modified: branches/3.0/MgDev/Web/src/mapviewernet/buffer.aspx
--- branches/3.0/MgDev/Web/src/mapviewernet/buffer.aspx	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewernet/buffer.aspx	2016-07-27 14:03:11 UTC (rev 9008)
@@ -254,7 +254,8 @@
             if (filter == null || filter.Length == 0)
                 continue;
Modified: branches/3.0/MgDev/Web/src/mapviewernet/common.aspx
--- branches/3.0/MgDev/Web/src/mapviewernet/common.aspx	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewernet/common.aspx	2016-07-27 14:03:11 UTC (rev 9008)
@@ -292,4 +292,54 @@
+        if ((property != geomPropName) && (propertyDef.GetPropertyType() == MgFeaturePropertyType.DataProperty))
+                    break;
+                    break;
+                    break;
+                    break;
+                    break;
+                    break;
+                    break;
+                    break;
+                    break;
+        } else if (property == geomPropName) {
+    return query;
 </script>
Modified: branches/3.0/MgDev/Web/src/mapviewernet/search.aspx
--- branches/3.0/MgDev/Web/src/mapviewernet/search.aspx	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewernet/search.aspx	2016-07-27 14:03:11 UTC (rev 9008)
@@ -103,7 +103,8 @@
             bool displayAll = (resProps.Count == 0);
Modified: branches/3.0/MgDev/Web/src/mapviewernet/selectwithin.aspx
--- branches/3.0/MgDev/Web/src/mapviewernet/selectwithin.aspx	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewernet/selectwithin.aspx	2016-07-27 14:03:11 UTC (rev 9008)
@@ -113,7 +113,8 @@
Modified: branches/3.0/MgDev/Web/src/mapviewerphp/buffer.php
--- branches/3.0/MgDev/Web/src/mapviewerphp/buffer.php	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewerphp/buffer.php	2016-07-27 14:03:11 UTC (rev 9008)
@@ -241,7 +241,8 @@
             if($filter == "")
                 continue;
-            $query = new MgFeatureQueryOptions();
+            $clsDef = $selLayer->GetClassDefinition();
+            $query = BuildFeatureQueryOptions($clsDef);
             $query->SetFilter($filter);
             $featureSource = new MgResourceIdentifier($selLayer->GetFeatureSourceId());
Modified: branches/3.0/MgDev/Web/src/mapviewerphp/common.php
--- branches/3.0/MgDev/Web/src/mapviewerphp/common.php	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewerphp/common.php	2016-07-27 14:03:11 UTC (rev 9008)
@@ -282,4 +282,54 @@
     return $paramValue;
+function BuildFeatureQueryOptions($classDef)
+    $query = new MgFeatureQueryOptions();
+    $geomPropName = $classDef->GetDefaultGeometryPropertyName();
+    $propertyList = $classDef->GetProperties();
+    for ($i = 0; $i < $propertyList->GetCount(); $i++)
+        $propertyDef = $propertyList->GetItem($i);
+        $property = $propertyList->GetItem($i)->GetName();
+        if (($property != $geomPropName) && ($propertyDef->GetPropertyType() == MgFeaturePropertyType::DataProperty))
+            $propertyType = $propertyList->GetItem($i)->GetDataType();
+            switch ($propertyType) {
+                case MgPropertyType::Boolean:
+                    $query->AddFeatureProperty($property);
+                    break;
+                case MgPropertyType::Byte:
+                    break;
+                case MgPropertyType::DateTime:
+                    break;
+                case MgPropertyType::Single:
+                    break;
+                case MgPropertyType::Double:
+                    break;
+                case MgPropertyType::Int16:
+                    break;
+                case MgPropertyType::Int32:
+                    break;
+                case MgPropertyType::Int64:
+                    break;
+                case MgPropertyType::String:
+                    break;
+        } else if ($property == $geomPropName){
+    return $query;
Modified: branches/3.0/MgDev/Web/src/mapviewerphp/search.php
--- branches/3.0/MgDev/Web/src/mapviewerphp/search.php	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewerphp/search.php	2016-07-27 14:03:11 UTC (rev 9008)
@@ -103,7 +103,8 @@
         $displayAll = (count($resProps) == 0);
-        $opts = new MgFeatureQueryOptions();
+        $clsDef = $layer->GetClassDefinition();
+        $opts = BuildFeatureQueryOptions($clsDef);
         $opts->SetFilter($filter);
         $featureClassName = $layer->GetFeatureClassName();
         $features = $layer->SelectFeatures($opts);
Modified: branches/3.0/MgDev/Web/src/mapviewerphp/selectwithin.php
--- branches/3.0/MgDev/Web/src/mapviewerphp/selectwithin.php	2016-07-27 14:02:51 UTC (rev 9007)
+++ branches/3.0/MgDev/Web/src/mapviewerphp/selectwithin.php	2016-07-27 14:03:11 UTC (rev 9008)
@@ -99,7 +99,8 @@
         $layer = $selLayers->GetItem($i);
         $filter = $sel->GenerateFilter($layer, $layer->GetFeatureClassName());
         $featureSource = new MgResourceIdentifier($layer->GetFeatureSourceId());
         $features = $featureSrvc->SelectFeatures($featureSource, $layer->GetFeatureClassName(), $query);
More information about the mapguide-commits mailing list
