[mapguide-commits] r8877 - in sandbox/jng/rfc155_installer: .	Bootstrapper Installers/MapGuide Support/Web/x64 Support/Web/x86
    svn_mapguide at osgeo.org
    Mon Mar 14 03:59:58 PDT 2016
Author: jng
Date: 2016-03-14 03:59:58 -0700 (Mon, 14 Mar 2016)
New Revision: 8877
Added:
   sandbox/jng/rfc155_installer/Bootstrapper/vc_redist.x64.exe
   sandbox/jng/rfc155_installer/Bootstrapper/vc_redist.x86.exe
   sandbox/jng/rfc155_installer/Support/Web/x64/httpd-2.4.18-x64-VC11.zip
   sandbox/jng/rfc155_installer/Support/Web/x64/php-5.5.33-x64-VC11.zip
   sandbox/jng/rfc155_installer/Support/Web/x86/httpd-2.4.18-x86-VC11.zip
   sandbox/jng/rfc155_installer/Support/Web/x86/php-5.5.33-x86-VC11.zip
Removed:
   sandbox/jng/rfc155_installer/Support/Web/x64/httpd-2.4.10-x64-VC11.zip
   sandbox/jng/rfc155_installer/Support/Web/x64/php-5.5.17-x64-VC11.zip
   sandbox/jng/rfc155_installer/Support/Web/x86/httpd-2.4.10-x86-VC11.zip
   sandbox/jng/rfc155_installer/Support/Web/x86/php-5.5.17-x86-VC11.zip
   sandbox/jng/rfc155_installer/Bootstrapper/Setup.nsi
   sandbox/jng/rfc155_installer/Installers/MapGuide/MapGuide.wxs
   sandbox/jng/rfc155_installer/Support/Web/x64/mod_jk.so
   sandbox/jng/rfc155_installer/Support/Web/x86/mod_jk.so
   sandbox/jng/rfc155_installer/build.bat
Update windows installer binaries
 - PHP 5.5.17 -> 5.5.33
 - httpd 2.4.10 -> 2.4.18
 - mod_jk.so 1.2.40 -> 1.2.41
 - Include MSVC 2015 redist packages
Modified: sandbox/jng/rfc155_installer/Bootstrapper/Setup.nsi
--- sandbox/jng/rfc155_installer/Bootstrapper/Setup.nsi	2016-03-14 10:28:54 UTC (rev 8876)
+++ sandbox/jng/rfc155_installer/Bootstrapper/Setup.nsi	2016-03-14 10:59:58 UTC (rev 8877)
@@ -27,12 +27,12 @@
 Icon "${INSTALLER_ROOT}\Support\Graphics\OSGeo.ico"
 Function .onInit
-	System::Call 'kernel32::CreateMutexA(i 0, i 0, t "myMutex") i .r1 ?e'
-	Pop $R0
-	StrCmp $R0 0 +3
-		MessageBox MB_OK|MB_ICONEXCLAMATION "The installer is already running."
-		Abort
+    System::Call 'kernel32::CreateMutexA(i 0, i 0, t "myMutex") i .r1 ?e'
+    Pop $R0
+    StrCmp $R0 0 +3
+        MessageBox MB_OK|MB_ICONEXCLAMATION "The installer is already running."
+        Abort
 ; Only for 64-bit installers. Prevent installation on 32-bit windows for obvious reasons
 !if ${CPU} = "x64"
@@ -44,37 +44,51 @@
 FunctionEnd
 Section Main
-	SetOutPath $TEMP
-	SetOverwrite On
-	Push $R0
+    SetOutPath $TEMP
+    SetOverwrite On
+    Push $R0
     ClearErrors
 BeginInstall:
     ; Install VC 2012 redist. Not going to check here. I think we can trust the vcredist install to not trample over anything
     Banner::show /NOUNLOAD "Installing Visual C++ 2012 Redistributable"
-	Banner::getWindow /NOUNLOAD
+    Banner::getWindow /NOUNLOAD
 !if ${CPU} = "x64"
-	File /r "${INSTALLER_OUTPUT}\vcredist_2012_x64.exe"
-	ExecWait '"$OUTDIR\vcredist_2012_x64.exe" /install /quiet /norestart'
+    File /r "${INSTALLER_OUTPUT}\vcredist_2012_x64.exe"
+    ExecWait '"$OUTDIR\vcredist_2012_x64.exe" /install /quiet /norestart'
 !else
-	File /r "${INSTALLER_OUTPUT}\vcredist_2012_x86.exe"
-	ExecWait '"$OUTDIR\vcredist_2012_x86.exe" /install /quiet /norestart'
+    File /r "${INSTALLER_OUTPUT}\vcredist_2012_x86.exe"
+    ExecWait '"$OUTDIR\vcredist_2012_x86.exe" /install /quiet /norestart'
 !endif
-	Banner::destroy
+    Banner::destroy
+    ; Install VC 2015 redist. Not going to check here. I think we can trust the vcredist install to not trample over anything
+    Banner::show /NOUNLOAD "Installing Visual C++ 2015 Redistributable"
+!if ${CPU} = "x64"
+    File /r "${INSTALLER_OUTPUT}\vc_redist.x64.exe"
+    ExecWait '"$OUTDIR\vc_redist.x64.exe" /install /quiet /norestart'
+!else
+    File /r "${INSTALLER_OUTPUT}\vc_redist.x86.exe"
+    ExecWait '"$OUTDIR\vc_redist.x86.exe" /install /quiet /norestart'
+!endif
+    Banner::destroy
-	Banner::show /NOUNLOAD "Extracting files. Please Wait"
-	File "${INSTALLER_OUTPUT}\${OUTNAME}.msi"
-	Banner::destroy
-	; Run the MGOS installer
-	ExecWait '"msiexec" /i "$OUTDIR\${OUTNAME}.msi"'
-	; Delete the MGOS installer and any other extracted after completion
-	Delete "$OUTDIR\${OUTNAME}.msi"
+    Banner::show /NOUNLOAD "Extracting files. Please Wait"
+    File "${INSTALLER_OUTPUT}\${OUTNAME}.msi"
+    Banner::destroy
+    ; Run the MGOS installer
+    ExecWait '"msiexec" /i "$OUTDIR\${OUTNAME}.msi"'
+    ; Delete the MGOS installer and any other extracted after completion
+    Delete "$OUTDIR\${OUTNAME}.msi"
 !if ${CPU} = "x64"
     Delete "$OUTDIR\vcredist_2012_x64.exe"
+    Delete "$OUTDIR\vc_redist.x64.exe"
 !else
     Delete "$OUTDIR\vcredist_2012_x86.exe"
+    Delete "$OUTDIR\vc_redist.x86.exe"
 !endif
 SectionEnd
\ No newline at end of file
Added: sandbox/jng/rfc155_installer/Bootstrapper/vc_redist.x64.exe
(Binary files differ)
Property changes on: sandbox/jng/rfc155_installer/Bootstrapper/vc_redist.x64.exe
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: sandbox/jng/rfc155_installer/Bootstrapper/vc_redist.x86.exe
Property changes on: sandbox/jng/rfc155_installer/Bootstrapper/vc_redist.x86.exe
Modified: sandbox/jng/rfc155_installer/Installers/MapGuide/MapGuide.wxs
--- sandbox/jng/rfc155_installer/Installers/MapGuide/MapGuide.wxs	2016-03-14 10:28:54 UTC (rev 8876)
+++ sandbox/jng/rfc155_installer/Installers/MapGuide/MapGuide.wxs	2016-03-14 10:59:58 UTC (rev 8877)
@@ -46,8 +46,8 @@
         </Property>
         <Property Id="MGSERVER_IP" Secure="yes" Value="127.0.0.1" />
         <Property Id="APACHE_PORT" Secure="yes" Value="8008" />
-        <Property Id="APACHE_VERSION" Secure="yes" Value="2.4.10" />
-        <Property Id="PHP_VERSION" Secure="yes" Value="5.5.17" />
+        <Property Id="APACHE_VERSION" Secure="yes" Value="2.4.18" />
+        <Property Id="PHP_VERSION" Secure="yes" Value="5.5.33" />
         <Property Id="MG_VERSION_MAJOR_MINOR" Secure="yes" Value="3.0" />
         <Property Id="APP_POOL_NAME" Secure="yes" Value="MapGuide30AppPool">
             <RegistrySearch
Deleted: sandbox/jng/rfc155_installer/Support/Web/x64/httpd-2.4.10-x64-VC11.zip
Added: sandbox/jng/rfc155_installer/Support/Web/x64/httpd-2.4.18-x64-VC11.zip
Property changes on: sandbox/jng/rfc155_installer/Support/Web/x64/httpd-2.4.18-x64-VC11.zip
Modified: sandbox/jng/rfc155_installer/Support/Web/x64/mod_jk.so
Deleted: sandbox/jng/rfc155_installer/Support/Web/x64/php-5.5.17-x64-VC11.zip
Added: sandbox/jng/rfc155_installer/Support/Web/x64/php-5.5.33-x64-VC11.zip
Property changes on: sandbox/jng/rfc155_installer/Support/Web/x64/php-5.5.33-x64-VC11.zip
Deleted: sandbox/jng/rfc155_installer/Support/Web/x86/httpd-2.4.10-x86-VC11.zip
Added: sandbox/jng/rfc155_installer/Support/Web/x86/httpd-2.4.18-x86-VC11.zip
Property changes on: sandbox/jng/rfc155_installer/Support/Web/x86/httpd-2.4.18-x86-VC11.zip
Modified: sandbox/jng/rfc155_installer/Support/Web/x86/mod_jk.so
Deleted: sandbox/jng/rfc155_installer/Support/Web/x86/php-5.5.17-x86-VC11.zip
Added: sandbox/jng/rfc155_installer/Support/Web/x86/php-5.5.33-x86-VC11.zip
Property changes on: sandbox/jng/rfc155_installer/Support/Web/x86/php-5.5.33-x86-VC11.zip
Modified: sandbox/jng/rfc155_installer/build.bat
--- sandbox/jng/rfc155_installer/build.bat	2016-03-14 10:28:54 UTC (rev 8876)
+++ sandbox/jng/rfc155_installer/build.bat	2016-03-14 10:59:58 UTC (rev 8877)
@@ -80,9 +80,9 @@
 rem ==================================================
 rem Web dependencies
-SET HTTPD_VERSION=2.4.10
-SET PHP_VERSION=5.5.17
-SET TOMCAT_VERSION=7.0.56
+SET HTTPD_VERSION=2.4.18
+SET PHP_VERSION=5.5.33
+SET TOMCAT_VERSION=7.0.68
 SET HTTPD_PACKAGE=httpd-%HTTPD_VERSION%-%PLATFORM_CLR%-VC11.zip
 SET TOMCAT_PACKAGE_NAME=apache-tomcat-%TOMCAT_VERSION%
 SET TOMCAT_PACKAGE=%MG_OEM%\LinuxApt\%TOMCAT_PACKAGE_NAME%.tar.gz
More information about the mapguide-commits
