[mapguide-commits] r8900 - trunk/Tools/Vagrant
svn_mapguide at osgeo.org
Thu Mar 31 04:31:48 PDT 2016
Author: jng
Date: 2016-03-31 04:31:48 -0700 (Thu, 31 Mar 2016)
New Revision: 8900
trunk/Tools/Vagrant/build.bat
Flip vagrant build flags back to default
Modified: trunk/Tools/Vagrant/build.bat
--- trunk/Tools/Vagrant/build.bat 2016-03-31 10:47:12 UTC (rev 8899)
+++ trunk/Tools/Vagrant/build.bat 2016-03-31 11:31:48 UTC (rev 8900)
@@ -9,15 +9,15 @@
rem
rem Requires the tee utility, which is part of GNU on Windows (https://github.com/bmatzelle/gow)
-IF "%MG_SVN_UPDATE_SOURCES%"=="" SET MG_SVN_UPDATE_SOURCES=0
-IF "%BUILD_UBUNTU_32%"=="" SET BUILD_UBUNTU_32=0
+IF "%MG_SVN_UPDATE_SOURCES%"=="" SET MG_SVN_UPDATE_SOURCES=1
+IF "%BUILD_UBUNTU_32%"=="" SET BUILD_UBUNTU_32=1
IF "%BUILD_UBUNTU_64%"=="" SET BUILD_UBUNTU_64=1
-IF "%BUILD_CENTOS_32%"=="" SET BUILD_CENTOS_32=0
-IF "%BUILD_CENTOS_64%"=="" SET BUILD_CENTOS_64=0
-IF "%TEARDOWN_UBUNTU_32%"=="" SET TEARDOWN_UBUNTU_32=0
+IF "%BUILD_CENTOS_32%"=="" SET BUILD_CENTOS_32=1
+IF "%BUILD_CENTOS_64%"=="" SET BUILD_CENTOS_64=1
+IF "%TEARDOWN_UBUNTU_32%"=="" SET TEARDOWN_UBUNTU_32=1
IF "%TEARDOWN_UBUNTU_64%"=="" SET TEARDOWN_UBUNTU_64=1
-IF "%TEARDOWN_CENTOS_32%"=="" SET TEARDOWN_CENTOS_32=0
-IF "%TEARDOWN_CENTOS_64%"=="" SET TEARDOWN_CENTOS_64=0
+IF "%TEARDOWN_CENTOS_32%"=="" SET TEARDOWN_CENTOS_32=1
+IF "%TEARDOWN_CENTOS_64%"=="" SET TEARDOWN_CENTOS_64=1
SET ROOT=%CD%
SET COMPONENT=
echo **************** Build Summary *********************
More information about the mapguide-commits
