[mapguide-commits] r8936 - trunk/Tools/Vagrant/scripts
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 4 04:48:55 PDT 2016
Author: jng
Date: 2016-05-04 04:48:55 -0700 (Wed, 04 May 2016)
New Revision: 8936
   trunk/Tools/Vagrant/scripts/provision_centos.sh
   trunk/Tools/Vagrant/scripts/provision_ubuntu.sh
vagrant: Increase CoordinateSystem unit test timeout
Modified: trunk/Tools/Vagrant/scripts/provision_centos.sh
--- trunk/Tools/Vagrant/scripts/provision_centos.sh	2016-04-30 18:03:10 UTC (rev 8935)
+++ trunk/Tools/Vagrant/scripts/provision_centos.sh	2016-05-04 11:48:55 UTC (rev 8936)
@@ -318,7 +318,7 @@
     for comp in CoordinateSystem
     do
         BUILD_COMPONENT="Unit Test MapGuide Server ($comp)"
-        sudo -E timeout 20m ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee $MG_HOME/mapguide_${comp}_unit_test.log
+        sudo -E timeout 40m ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee $MG_HOME/mapguide_${comp}_unit_test.log
         check_server_test
         if [ -f UnitTestResults_${comp}.xml ]; then
             sudo mv UnitTestResults_${comp}.xml $MG_HOME/UnitTestResults_${comp}.xml
Modified: trunk/Tools/Vagrant/scripts/provision_ubuntu.sh
--- trunk/Tools/Vagrant/scripts/provision_ubuntu.sh	2016-04-30 18:03:10 UTC (rev 8935)
+++ trunk/Tools/Vagrant/scripts/provision_ubuntu.sh	2016-05-04 11:48:55 UTC (rev 8936)
@@ -328,7 +328,7 @@
     do
         check_server_test
More information about the mapguide-commits mailing list
