[mapguide-commits] r8956 - trunk/MgDev/Doc/devguide/source
svn_mapguide at osgeo.org
Thu May 12 07:57:37 PDT 2016
Author: jng
Date: 2016-05-12 07:57:37 -0700 (Thu, 12 May 2016)
New Revision: 8956
trunk/MgDev/Doc/devguide/source/revision_history.rst
trunk/MgDev/Doc/devguide/source/supplemental_development.rst
devguide: Fix malformed revision history table and add a section about mapguide-rest in supplemental_development.rst
Modified: trunk/MgDev/Doc/devguide/source/revision_history.rst
--- trunk/MgDev/Doc/devguide/source/revision_history.rst 2016-05-12 14:42:00 UTC (rev 8955)
+++ trunk/MgDev/Doc/devguide/source/revision_history.rst 2016-05-12 14:57:37 UTC (rev 8956)
@@ -10,9 +10,12 @@
| Version | Authors | Date | Summary of Changes |
+| 2.0.2 | Jackie Ng | May 2016 | Fix malformed revision history table and add section about |
+| | | | mapguide-rest in supplemental development options |
| 2.0.1 | Jackie Ng | Jul 2014 | Updated code sample in section "Working with Feature Data" |
| | | | to reflect the updated Sheboygan sample data set |
| 2.0 | Jackie Ng | | First version of developer's guide in source form |
| | | | Added .net and Java code samples to match PHP examples |
Modified: trunk/MgDev/Doc/devguide/source/supplemental_development.rst
--- trunk/MgDev/Doc/devguide/source/supplemental_development.rst 2016-05-12 14:42:00 UTC (rev 8955)
+++ trunk/MgDev/Doc/devguide/source/supplemental_development.rst 2016-05-12 14:57:37 UTC (rev 8956)
@@ -35,4 +35,21 @@
This library is used by the MapGuide Maestro application, and can be used in your own applications.
-Visit `the Maestro project homepage <http://trac.osgeo.org/mapguide/wiki/maestro>`_ for more information
\ No newline at end of file
+Visit `the Maestro project homepage <http://trac.osgeo.org/mapguide/wiki/maestro>`_ for more information
+.. _mapguiderest:
+mapguide-rest
+mapguide-rest provides a REST API for MapGuide and includes a framework for easy publishing of spatial data.
+The REST API allows for any library capable of making HTTP request to work with MapGuide.
+mapguide-rest can be deployed on both Windows and Linux instances of MapGuide.
+Visit `the mapguide-rest homepage <https://github.com/jumpinjackie/mapguide-rest>`_ for more information
+.. note::
+ mapguide-rest requires a version of MapGuide that bundles PHP 5.3 or newer.
More information about the mapguide-commits
