[mapguide-commits] r8958 - in branches/3.0/MgDev: . Doc/devguide/source
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu May 12 08:06:39 PDT 2016
Author: jng
Date: 2016-05-12 08:06:39 -0700 (Thu, 12 May 2016)
New Revision: 8958
   branches/3.0/MgDev/
   branches/3.0/MgDev/Doc/devguide/source/revision_history.rst
   branches/3.0/MgDev/Doc/devguide/source/supplemental_development.rst
Merged revision(s) 8956 from trunk/MgDev:
devguide: Fix malformed revision history table and add a section about mapguide-rest in supplemental_development.rst
Property changes on: branches/3.0/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/dwftk:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/rfc155:8874-8884
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
/trunk/MgDev:8595,8616-8618,8626,8682,8700,8728,8844
   + /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8595,8616-8618,8626,8682,8700,8728,8844,8956
Modified: branches/3.0/MgDev/Doc/devguide/source/revision_history.rst
--- branches/3.0/MgDev/Doc/devguide/source/revision_history.rst	2016-05-12 15:01:09 UTC (rev 8957)
+++ branches/3.0/MgDev/Doc/devguide/source/revision_history.rst	2016-05-12 15:06:39 UTC (rev 8958)
@@ -10,9 +10,12 @@
 | Version | Authors         | Date            | Summary of Changes                                           |
+| 2.0.2   | Jackie Ng       | May 2016        | Fix malformed revision history table and add section about   |
+|         |                 |                 | mapguide-rest in supplemental development options            |
 | 2.0.1   | Jackie Ng       | Jul 2014        | Updated code sample in section "Working with Feature Data"   |
 |         |                 |                 | to reflect the updated Sheboygan sample data set             |
 | 2.0     | Jackie Ng       |                 | First version of developer's guide in source form            |
 |         |                 |                 | Added .net and Java code samples to match PHP examples       |
Modified: branches/3.0/MgDev/Doc/devguide/source/supplemental_development.rst
--- branches/3.0/MgDev/Doc/devguide/source/supplemental_development.rst	2016-05-12 15:01:09 UTC (rev 8957)
+++ branches/3.0/MgDev/Doc/devguide/source/supplemental_development.rst	2016-05-12 15:06:39 UTC (rev 8958)
@@ -35,4 +35,21 @@
 This library is used by the MapGuide Maestro application, and can be used in your own applications.
-Visit `the Maestro project homepage <http://trac.osgeo.org/mapguide/wiki/maestro>`_ for more information
\ No newline at end of file
+Visit `the Maestro project homepage <http://trac.osgeo.org/mapguide/wiki/maestro>`_ for more information
+.. _mapguiderest:
+mapguide-rest
+mapguide-rest provides a REST API for MapGuide and includes a framework for easy publishing of spatial data.
+The REST API allows for any library capable of making HTTP request to work with MapGuide.
+mapguide-rest can be deployed on both Windows and Linux instances of MapGuide.
+Visit `the mapguide-rest homepage <https://github.com/jumpinjackie/mapguide-rest>`_ for more information
+.. note::
+    mapguide-rest requires a version of MapGuide that bundles PHP 5.3 or newer.
More information about the mapguide-commits mailing list
