[mapguide-commits] r8964 - in trunk/Tools/Vagrant: . centos6/test_x64 centos6/test_x86 scripts ubuntu12/test_x64 ubuntu12/test_x86 ubuntu14/test_x64 ubuntu14/test_x86
svn_mapguide at osgeo.org
Tue May 17 05:39:39 PDT 2016
Author: jng
Date: 2016-05-17 05:39:38 -0700 (Tue, 17 May 2016)
New Revision: 8964
Added:
trunk/Tools/Vagrant/scripts/test_provision_centos.sh
trunk/Tools/Vagrant/scripts/test_provision_ubuntu.sh
Removed:
trunk/Tools/Vagrant/centos6/test_x64/provision.sh
trunk/Tools/Vagrant/centos6/test_x86/provision.sh
trunk/Tools/Vagrant/ubuntu12/test_x64/provision.sh
trunk/Tools/Vagrant/ubuntu12/test_x86/provision.sh
trunk/Tools/Vagrant/ubuntu14/test_x64/provision.sh
trunk/Tools/Vagrant/ubuntu14/test_x86/provision.sh
trunk/Tools/Vagrant/centos6/test_x64/Vagrantfile
trunk/Tools/Vagrant/centos6/test_x86/Vagrantfile
trunk/Tools/Vagrant/ubuntu12/test_x64/Vagrantfile
trunk/Tools/Vagrant/ubuntu12/test_x86/Vagrantfile
trunk/Tools/Vagrant/ubuntu14/test_x64/Vagrantfile
trunk/Tools/Vagrant/ubuntu14/test_x86/Vagrantfile
trunk/Tools/Vagrant/verify.bat
Merged revision(s) 8963 from branches/3.1/vagrant:
Vagrant build environment changes:
- Change verify.bat to be like build_target.bat: Focused on a specific VM target and allows multiple instances to be run in parallel.
- Add parameterized test_provision_*.sh scripts that perform the installation and smoke testing.
- Update test vagrantfiles to use the new parameterized test_provision_*.sh scripts
- Fix wrong VM for Ubuntu14 test vagrantfiles
Property changes on: trunk/Tools/Vagrant
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/3.0/vagrant:8601-8606
+ /branches/3.0/vagrant:8601-8606
/branches/3.1/vagrant:8963
Modified: trunk/Tools/Vagrant/centos6/test_x64/Vagrantfile
--- trunk/Tools/Vagrant/centos6/test_x64/Vagrantfile 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/centos6/test_x64/Vagrantfile 2016-05-17 12:39:38 UTC (rev 8964)
@@ -118,6 +118,6 @@
config.vm.provision "shell",
privileged: false,
- path: "provision.sh",
- args: ["#{ENV['DOWNLOAD_HOST']}", "#{ENV['MG_DIST_DIR']}"]
+ path: "test_provision_centos.sh",
+ args: ["#{ENV['DOWNLOAD_HOST']}", "#{ENV['MG_DIST_DIR']}", "#{ENV['MG_TEST_TARGET']}"]
end
Deleted: trunk/Tools/Vagrant/centos6/test_x64/provision.sh
--- trunk/Tools/Vagrant/centos6/test_x64/provision.sh 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/centos6/test_x64/provision.sh 2016-05-17 12:39:38 UTC (rev 8964)
@@ -1,17 +0,0 @@
-#!/bin/bash
-DOWNLOAD_HOST=$1
-URI_PART=$2
-DIST_DIR="centos_x64"
-sudo yum install -y wget
-echo Download host is: $DOWNLOAD_HOST
-wget "http://$DOWNLOAD_HOST/$URI_PART/Sheboygan.mgp"
-wget "http://$DOWNLOAD_HOST/$URI_PART/smoke_test.sh"
-sudo mv Sheboygan.mgp /tmp/
-wget "http://$DOWNLOAD_HOST/$URI_PART/$DIST_DIR/mginstallcentos.sh"
-sed -i 's/URL="$URL_ROOT\/$URL_PART"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/'"$URI_PART"'\/'"$DIST_DIR"'"/g' mginstallcentos.sh
-chmod +x smoke_test.sh
-chmod +x mginstallcentos.sh
-sudo -E ./mginstallcentos.sh
-echo Wait 10s before running smoke test
-sleep 10s
-sudo -E ./smoke_test.sh
\ No newline at end of file
Modified: trunk/Tools/Vagrant/centos6/test_x86/Vagrantfile
--- trunk/Tools/Vagrant/centos6/test_x86/Vagrantfile 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/centos6/test_x86/Vagrantfile 2016-05-17 12:39:38 UTC (rev 8964)
@@ -118,6 +118,6 @@
privileged: false,
end
Deleted: trunk/Tools/Vagrant/centos6/test_x86/provision.sh
--- trunk/Tools/Vagrant/centos6/test_x86/provision.sh 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/centos6/test_x86/provision.sh 2016-05-17 12:39:38 UTC (rev 8964)
@@ -1,17 +0,0 @@
-#!/bin/bash
-DOWNLOAD_HOST=$1
-URI_PART=$2
-DIST_DIR="centos_x86"
-sleep 10s
Copied: trunk/Tools/Vagrant/scripts/test_provision_centos.sh (from rev 8963, branches/3.1/vagrant/scripts/test_provision_centos.sh)
--- trunk/Tools/Vagrant/scripts/test_provision_centos.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/test_provision_centos.sh 2016-05-17 12:39:38 UTC (rev 8964)
@@ -0,0 +1,22 @@
+#!/bin/bash
+DOWNLOAD_HOST=$1
+URI_PART=$2
+DIST_DIR=$3
+echo ***************************************************
+echo DOWNLOAD_HOST: ${DOWNLOAD_HOST}
+echo URI_PART: ${URI_PART}
+echo DIST_DIR: ${DIST_DIR}
+sudo yum install -y wget
+wget "http://$DOWNLOAD_HOST/$URI_PART/Sheboygan.mgp"
+sudo mv Sheboygan.mgp /tmp/
+wget "http://$DOWNLOAD_HOST/$URI_PART/$DIST_DIR/mginstallcentos.sh"
+REPLACE=URL="http://$DOWNLOAD_HOST/$URI_PART/$DIST_DIR"
+sed -i 's#URL="\$URL_ROOT\/\$URL_PART"#'"$REPLACE"'#g' mginstallcentos.sh
+cp /vagrant/smoke_test.sh .
+chmod +x smoke_test.sh
+chmod +x mginstallcentos.sh
+sudo -E ./mginstallcentos.sh
+echo Wait 10s before running smoke test
+sleep 10s
+sudo -E ./smoke_test.sh
Copied: trunk/Tools/Vagrant/scripts/test_provision_ubuntu.sh (from rev 8963, branches/3.1/vagrant/scripts/test_provision_ubuntu.sh)
--- trunk/Tools/Vagrant/scripts/test_provision_ubuntu.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/test_provision_ubuntu.sh 2016-05-17 12:39:38 UTC (rev 8964)
@@ -0,0 +1,21 @@
+#!/bin/bash
+DOWNLOAD_HOST=$1
+URI_PART=$2
+DIST_DIR=$3
+wget "http://$DOWNLOAD_HOST/$URI_PART/$DIST_DIR/mginstallubuntu.sh"
+sed -i 's#URL="\$URL_ROOT\/\$URL_PART"#'"$REPLACE"'#g' mginstallubuntu.sh
+chmod +x mginstallubuntu.sh
+sudo ./mginstallubuntu.sh --headless --with-sdf --with-shp --with-ogr --with-gdal --with-sqlite
+sleep 10s
+sudo ./smoke_test.sh
Modified: trunk/Tools/Vagrant/ubuntu12/test_x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu12/test_x64/Vagrantfile 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/ubuntu12/test_x64/Vagrantfile 2016-05-17 12:39:38 UTC (rev 8964)
@@ -118,6 +118,6 @@
privileged: false,
+ path: "test_provision_ubuntu.sh",
end
Deleted: trunk/Tools/Vagrant/ubuntu12/test_x64/provision.sh
--- trunk/Tools/Vagrant/ubuntu12/test_x64/provision.sh 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/ubuntu12/test_x64/provision.sh 2016-05-17 12:39:38 UTC (rev 8964)
@@ -1,16 +0,0 @@
-#!/bin/bash
-DOWNLOAD_HOST=$1
-URI_PART=$2
-DIST_DIR="ubuntu_x64"
-wget "http://$DOWNLOAD_HOST/$URI_PART/$DIST_DIR/mginstallubuntu.sh"
-sed -i 's/URL="$URL_ROOT\/$URL_PART"/URL="http:\/\/'"$DOWNLOAD_HOST"'\/'"$URI_PART"'\/'"$DIST_DIR"'"/g' mginstallubuntu.sh
-chmod +x mginstallubuntu.sh
-sudo ./mginstallubuntu.sh --headless --with-sdf --with-shp --with-ogr --with-gdal --with-sqlite
-sleep 10s
-sudo ./smoke_test.sh
Modified: trunk/Tools/Vagrant/ubuntu12/test_x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu12/test_x86/Vagrantfile 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/ubuntu12/test_x86/Vagrantfile 2016-05-17 12:39:38 UTC (rev 8964)
@@ -118,6 +118,6 @@
privileged: false,
end
Deleted: trunk/Tools/Vagrant/ubuntu12/test_x86/provision.sh
--- trunk/Tools/Vagrant/ubuntu12/test_x86/provision.sh 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/ubuntu12/test_x86/provision.sh 2016-05-17 12:39:38 UTC (rev 8964)
@@ -1,16 +0,0 @@
-#!/bin/bash
-DOWNLOAD_HOST=$1
-URI_PART=$2
-DIST_DIR="ubuntu_x86"
-sleep 10s
Modified: trunk/Tools/Vagrant/ubuntu14/test_x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu14/test_x64/Vagrantfile 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/ubuntu14/test_x64/Vagrantfile 2016-05-17 12:39:38 UTC (rev 8964)
@@ -10,7 +10,7 @@
# please see the online documentation at vagrantup.com.
# Every Vagrant virtual environment requires a box to build off of.
- config.vm.box = "ubuntu12-amd64"
+ config.vm.box = "ubuntu14-amd64"
# The url from where the 'config.vm.box' box will be fetched if it
# doesn't already exist on the user's system.
@@ -118,6 +118,6 @@
privileged: false,
end
Deleted: trunk/Tools/Vagrant/ubuntu14/test_x64/provision.sh
--- trunk/Tools/Vagrant/ubuntu14/test_x64/provision.sh 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/ubuntu14/test_x64/provision.sh 2016-05-17 12:39:38 UTC (rev 8964)
@@ -1,16 +0,0 @@
-#!/bin/bash
-DOWNLOAD_HOST=$1
-URI_PART=$2
-sleep 10s
Modified: trunk/Tools/Vagrant/ubuntu14/test_x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu14/test_x86/Vagrantfile 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/ubuntu14/test_x86/Vagrantfile 2016-05-17 12:39:38 UTC (rev 8964)
@@ -10,7 +10,7 @@
- config.vm.box = "ubuntu12-i386"
+ config.vm.box = "ubuntu14-i386"
@@ -118,6 +118,6 @@
privileged: false,
end
Deleted: trunk/Tools/Vagrant/ubuntu14/test_x86/provision.sh
--- trunk/Tools/Vagrant/ubuntu14/test_x86/provision.sh 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/ubuntu14/test_x86/provision.sh 2016-05-17 12:39:38 UTC (rev 8964)
@@ -1,16 +0,0 @@
-#!/bin/bash
-DOWNLOAD_HOST=$1
-URI_PART=$2
-sleep 10s
Modified: trunk/Tools/Vagrant/verify.bat
--- trunk/Tools/Vagrant/verify.bat 2016-05-15 15:21:14 UTC (rev 8963)
+++ trunk/Tools/Vagrant/verify.bat 2016-05-17 12:39:38 UTC (rev 8964)
@@ -1,95 +1,132 @@
@echo off
-rem build.bat
+rem ==================================================
+rem verify.bat
rem
-rem Performs basic smoke tests of CentOS and Ubuntu builds.
+rem Runs MapGuide/FDO verification in a specific
+rem vagrant VM
rem
-rem A basic web server is set up to serve files from the build artifact output directory
+rem Requires the tee and md5sum utilities, which is
+rem part of GNU on Windows
+rem
+rem https://github.com/bmatzelle/gow
rem
-rem With that set up, the following smoke tests are performed
-rem
-rem 1. CentOS/Ubuntu install scripts with sed'd URLs will properly download and install the required packages
-rem 2. The httpd and MapGuide Servers are verified to be running and operational by the basic smoke test shell script
-rem
-rem Requires the sed utility, which is part of GNU on Windows (https://github.com/bmatzelle/gow)
-IF "%DOWNLOAD_HOST%"=="" SET DOWNLOAD_HOST=192.168.0.6
-IF "%MG_DIST_DIR%"=="" SET MG_DIST_DIR=builds
-IF "%VERIFY_UBUNTU_32%"=="" SET VERIFY_UBUNTU_32=1
-IF "%VERIFY_UBUNTU_64%"=="" SET VERIFY_UBUNTU_64=1
-IF "%VERIFY_CENTOS_32%"=="" SET VERIFY_CENTOS_32=1
-IF "%VERIFY_CENTOS_64%"=="" SET VERIFY_CENTOS_64=1
+rem Parameter Handling
-echo **************** Verify Summary *********************
-echo Download Host is: %DOWNLOAD_HOST%
-echo Dist directory name: %MG_DIST_DIR%
-echo Verifying Ubuntu (32-bit): %VERIFY_UBUNTU_32%
-echo Verifying Ubuntu (64-bit): %VERIFY_UBUNTU_64%
-echo Verifying CentOS (32-bit): %VERIFY_CENTOS_32%
-echo Verifying CentOS (64-bit): %VERIFY_CENTOS_64%
-echo ****************************************************
-:check_centos_32
-echo [build]: Checking if we're verifying CentOS 32-bit
-if %VERIFY_CENTOS_32% == 1 goto test_centos_32
-goto check_ubuntu_32
-:test_centos_32
-pushd centos\test_x86
-SET COMPONENT=CentOS Build 32-bit
-echo [build]: MapGuide CentOS build 32-bit
-call vagrant up 2>&1 | tee smoke_test.log
+:study_params
+if (%1)==() goto start_build
+if "%1"=="-h" goto help_show
+if "%1"=="-distro" goto get_distro
+if "%1"=="-target" goto get_target
+if "%1"=="-teardown" goto get_teardown
+if "%1"=="-downloadhost" goto get_downloadhost
+if "%1"=="-distdir" goto get_distdir
+goto custom_error
+:next_param
+shift
+shift
+goto study_params
+:get_distro
+SET VM_DISTRO=%2
+goto next_param
+:get_downloadhost
+SET DOWNLOAD_HOST=%2
+goto next_param
+:get_distdir
+SET MG_DIST_DIR=%2
+goto next_param
+:get_target
+SET VM_TARGET=%2
+IF "%2"=="x86" goto next_param
+IF "%2"=="x64" goto next_param
+SET ERRORMSG=Unrecognised target: %2
+goto custom_error
+:get_teardown
+SET VM_TEARDOWN=%2
+IF "%2"=="1" goto next_param
+IF "%2"=="0" goto next_param
+SET ERRORMSG=Teardown flag must be 1 or 0. Got: %2
+goto custom_error
+:start_build
+IF "%VM_DISTRO%"=="" goto help_show
+IF "%VM_TARGET%"=="" goto help_show
+IF "%VM_TEARDOWN%"=="" goto help_show
+IF "%DOWNLOAD_HOST%"=="" goto help_show
+IF "%MG_DIST_DIR%"=="" goto help_show
+SET MG_TEST_TARGET=%VM_DISTRO%_%VM_TARGET%
+SET VAGRANTFILE_DIR=%VM_DISTRO%\test_%VM_TARGET%
+IF NOT EXIST %VAGRANTFILE_DIR% (
+ SET ERRORMSG=No vagrantfile exists at [%VAGRANTFILE_DIR%]
+ goto custom_error
+echo ***************** VM Build Summary *********************
+echo Distro: %VM_DISTRO%
+echo Target: %VM_TARGET%
+echo Teardown?: %VM_TEARDOWN%
+echo Testing Target: %MG_TEST_TARGET%
+echo Using vagrantfile from: %VAGRANTFILE_DIR%
+echo Download host: %DOWNLOAD_HOST%
+echo Dist part: %MG_DIST_DIR%
+echo ********************************************************
+rem Copy build/provisioning scripts to vagrantfile dir
+xcopy /S /Y /I scripts\test_provision* %VAGRANTFILE_DIR%
+xcopy /S /Y /I scripts\smoke_test.sh %VAGRANTFILE_DIR%
+:spin_up_vm
+echo [build]: Spin up VM at [%VAGRANTFILE_DIR%]
+pushd %VAGRANTFILE_DIR%
+call vagrant up 2>&1 | tee up.log
echo [build]: vagrant returned %errorlevel%
if "%errorlevel%"=="1" goto error
-:destroy_centos_32
-call vagrant destroy -f
-:centos_32_done
popd
-:check_ubuntu_32
-echo [build]: Checking if we're verifying Ubuntu 32-bit
-if %VERIFY_UBUNTU_32% == 1 goto test_ubuntu_32
-goto check_centos_64
-:test_ubuntu_32
-pushd ubuntu\test_x86
-SET COMPONENT=Ubuntu Build 32-bit
-echo [build]: MapGuide Ubuntu build 32-bit
-echo [build]: vagrant returned %errorlevel%
-if "%errorlevel%"=="1" goto error
-:destroy_ubuntu_32
-:ubuntu_32_done
-popd
-:check_centos_64
-echo [build]: Checking if we're verifying CentOS 64-bit
-if %VERIFY_CENTOS_64% == 1 goto test_centos_64
-goto check_ubuntu_64
-:test_centos_64
-pushd centos\test_x64
-SET COMPONENT=CentOS Build 64-bit
-echo [build]: MapGuide CentOS build 64-bit
-:destroy_centos_64
-:centos_64_done
-popd
-:check_ubuntu_64
-echo [build]: Checking if we're verifying Ubuntu 64-bit
-if %VERIFY_UBUNTU_64% == 1 goto test_ubuntu_64
+IF "%VM_TEARDOWN%"=="1" goto tear_down_vm
goto quit
-:test_ubuntu_64
-pushd ubuntu\test_x64
-SET COMPONENT=Ubuntu Build 64-bit
-echo [build]: MapGuide Ubuntu build 64-bit
-:destroy_ubuntu_64
+:tear_down_vm
+echo [build]: Tear down VM at [%VAGRANTFILE_DIR%]
-:ubuntu_64_done
popd
goto quit
:error
-echo [ERROR]: There was an error building the component %COMPONENT%
+echo [ERROR]: There was an error building the component
exit /B 1
+:custom_error
+echo [ERROR]: %ERRORMSG%
+SET ERRORMSG=
+:help_show
+echo Usage:
+echo ************************************************************************
+echo build.bat [-h]
+echo [-distro=Distro]
+echo [-target=TargetName]
+echo [-teardown=Teardown]
+echo [-downloadhost=DownloadHost]
+echo [-distdir=DistDir]
+echo Help: -h
+echo Distro: -distro=ubuntu12,
+echo ubuntu14
+echo centos6
+echo TargetName: -target=x86,
+echo x64
+echo Teardown: -teardown=1,
+echo 0
:quit
More information about the mapguide-commits
