[mapguide-commits] r9103 - sandbox/jng/diet_v2/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Nov 24 05:02:51 PST 2016
Author: jng
Date: 2016-11-24 05:02:51 -0800 (Thu, 24 Nov 2016)
New Revision: 9103
Added:
   sandbox/jng/diet_v2/MgDev/build_oem_buildpack.sh
Add a copy of build_oem.sh, this one is tailored for producing a pre-compiled build pack.
Currently, this is build_oem.sh that doesn't build agg, fusion and imake
Added: sandbox/jng/diet_v2/MgDev/build_oem_buildpack.sh
--- sandbox/jng/diet_v2/MgDev/build_oem_buildpack.sh	                        (rev 0)
+++ sandbox/jng/diet_v2/MgDev/build_oem_buildpack.sh	2016-11-24 13:02:51 UTC (rev 9103)
@@ -0,0 +1,635 @@
+#! /bin/bash
+# MapGuide Open Source build script.
+# Initialization
+echo "MapGuide Open Source build script for OEM components"
+INSTALLDIR=/usr/local/mapguideopensource
+CLEAN_FLAG=0
+BUILD_CPU=32
+BUILD_CONFIG=release
+while [ $# -gt 0 ]; do    # Until you run out of parameters...
+    case "$1" in
+        -prefix|--prefix)
+            INSTALLDIR="$2"
+            shift
+        -clean|--clean)
+            CLEAN_FLAG=1
+            shift
+        -build|--build)
+            BUILD_CPU=$2
+            shift
+        -config|--config)
+            BUILD_CONFIG=$2
+            shift
+        -help|--help)
+            echo "Usage: $0 (options)"
+            echo "Options:"
+            echo "  --prefix [installation directory]"
+            echo "  --clean [clean all objects and binaries in Oem]"
+            echo "  --build [32(default)|64]"
+            echo "  --config [release(default)|debug]"
+            echo "  --help [Display usage]"
+            exit
+    esac
+    shift   # Check next set of parameters.
+done
+echo "OEM Build Initialization ............................"
+echo "Oem Libraries will be installed at: ${INSTALLDIR}"
+LIB_NAME=""
+# Generic Functions
+check_build()
+    error=$?
+    if [ $error -ne 0 ]; then
+        echo "$LIB_NAME: Error build failed ($error)................."
+        exit $error
+    fi
+check_clean()
+    error=$?
+        echo "$LIB_NAME: Error clean failed ($error)................."
+        exit $error
+    fi
+# Build Apache/PHP
+# Notes: none
+init_linuxapt()
+    LIB_NAME="Apache/PHP/Tomcat"
+build_linuxapt()
+    pushd LinuxApt
+    ./build_apt.sh --prefix "${INSTALLDIR}" --with-tomcat
+    check_build
+    popd
+clean_linuxapt()
+    echo "Nothing to clean for LinuxApt"
+# Build ACE 6.2.6
+# Notes: none
+init_ace()
+    LIB_NAME="ACE 6.2.6"
+    ace_buildbits=32
+    ace_debug=0
+    ace_optimize=1
+    if [ $BUILD_CONFIG = "debug" ]; then
+        ace_debug=1
+        ace_optimize=0
+    chmod +x bin/*.sh
+    fi
+    if [ $BUILD_CPU -eq 64 ]; then
+        ace_buildbits=64
+    fi
+build_ace()
+    pushd ACE/ACE_wrappers
+    ACE_PATH="${PWD}"
+    pushd ace
+    env ACE_ROOT="${ACE_PATH}" make buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
+    check_build
+    popd
+    popd
+clean_ace()
+    ACE_PATH="${PWD}"
+    pushd ace
+    env ACE_ROOT="${ACE_PATH}" make clean buildbits=$ace_buildbits debug=$ace_debug optimize=$ace_optimize
+    check_clean
+    popd
+    popd
+# Build DWFCORE 1.0
+# Notes: none
+init_dwfcore()
+    LIB_NAME="DWFCORE 1.0"
+    pushd DWFTK/develop/global/build/gnu/dwfcore
+    if [ $CLEAN_FLAG -eq 0 ]; then
+    	sh ./build_setup.sh
+    fi
+    popd
+build_dwfcore()
+    pushd DWFTK/develop/global/src/dwfcore
+    aclocal
+    libtoolize --copy --force
+    automake --add-missing --copy
+    autoconf
+        sh ./configure --disable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
+    else
+        sh ./configure --enable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
+    fi
+    make
+    check_build
+    popd
+clean_dwfcore()
+    make clean
+    check_clean
+    popd
+# Build DWFTOOLKIT 7.7
+# Notes: none
+init_dwftk()
+    LIB_NAME="DWFTK 7.7"
+    pushd DWFTK/develop/global/build/gnu/dwftoolkit
+    fi
+    popd
+build_dwftk()
+    aclocal
+    autoconf
+    else
+    fi
+    make
+    check_build
+    popd
+clean_dwftk()
+    make clean
+    check_clean
+    popd
+# Build GEOS 3.4.2
+# Notes: none
+init_geos()
+    LIB_NAME="GEOS 3.4.2"
+build_geos()
+    pushd geos
+    # For this version of GEOS, don't run the aclocal/libtoolize/automake/autoconf quartet as we normally do, as it
+    # may produce an unusable configure script. Just run autoreconf to regenerate the configure script from configure.in
+    autoreconf
+        sh ./configure --with-pic --enable-silent-rules --prefix="${INSTALLDIR}"
+    else
+        sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}"
+    fi
+    make
+    # The check build is disabled as the build will fail with automake version < 2.59
+    check_build
+    popd
+clean_geos()
+    pushd geos
+    make clean
+    check_clean
+    popd
+# Build SWIGEx 1.0
+# Notes: none
+init_swigex()
+    LIB_NAME="SWIGEx 1.0"
+build_swigex()
+    pushd SWIGEx
+    mkdir -p Linux/obj/release
+    make
+    check_build
+    popd
+clean_swigex()
+    pushd SWIGEx
+    # Note: the qmake system is required to regenerate the Makefile.
+    #       This is disabled.
+    # make clean
+    # check_clean
+    popd
+# Build BDBXML
+# Notes: none
+init_bdbxml()
+    LIB_NAME="BDBXML"
+build_bdbxml()
+    # Need to force regen of the correct xerces config header before building dbxml proper
+    pushd dbxml/xerces-c-src
+    sh ./configure
+    popd
+    # Also need to check and set executable flag for s_paths
+    pushd dbxml/dbxml/dist
+    chmod +x s_paths
+    popd
+    pushd dbxml
+        sh ./buildall.sh --enable-debug
+    else
+        sh ./buildall.sh
+    fi
+    check_build
+    popd
+clean_bdbxml()
+    pushd dbxml
+    sh ./buildall.sh --clean
+    check_clean
+    popd
+# Build CPPUNIT 1.9.14
+# Notes: none
+init_cppunit()
+    LIB_NAME="CPPUNIT 1.9.14"
+build_cppunit()
+    pushd CppUnit-1.9.14
+    # Force regen of configure to cover our bases
+    aclocal -I config
+    autoconf
+    automake --add-missing --copy --force-missing
+    # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
+    sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
+    make
+    check_build
+    popd
+clean_cppunit()
+    make clean
+    check_clean
+    popd
+# Build ZLIB 1.2.3
+# Notes: none
+init_zlib()
+    LIB_NAME="ZLIB 1.2.3"
+build_zlib()
+    pushd gd/zlib
+    sh ./configure
+    make
+    check_build
+    popd
+clean_zlib()
+    pushd gd/zlib
+    make clean
+    check_clean
+    popd
+# Build LIBPNG 1.2.8
+# Notes: none
+init_libpng()
+    LIB_NAME="LIBPNG 1.2.8"
+build_libpng()
+    pushd gd/lpng
+    cp scripts/makefile.std makefile
+        #Inject -fPIC to CFLAGS for 64-bit
+        sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' makefile > makefile64
+        make -fmakefile64
+    else
+        make
+    fi
+    check_build
+    popd
+clean_libpng()
+    pushd gd/lpng
+    make clean
+    check_clean
+    popd
+# Build JPEG 6b
+# Notes: none
+init_jpeg()
+    LIB_NAME="JPEG 6b"
+build_jpeg()
+    pushd gd/jpeg
+    # A jconfig.h that is not modifed by ./configure will trip up make, so nuke it first
+    rm -f jconfig.h
+        sh ./configure --enable-static --disable-shared
+        #--with-pic does nothing (probably ancient configure script), so do some sed trickery
+        #to inject this flag. Know a better way? Enlighten us :)
+        sed 's/^CFLAGS=/CFLAGS= -fPIC -m64 /g' Makefile > Makefile64
+        make -fMakefile64
+    else
+        make
+    fi
+    check_build
+    popd
+clean_jpeg()
+    pushd gd/jpeg
+    make clean
+    check_clean
+    popd
+# Build FREETYPE 2.1.10
+# Notes: none
+init_freetype()
+    LIB_NAME="FREETYPE 2.1.10"
+build_freetype()
+    pushd gd/freetype
+        sh ./configure --enable-static --disable-shared --with-pic
+    else
+    fi
+    make
+    check_build
+    popd
+clean_freetype()
+    pushd gd/freetype
+    make clean
+    check_clean
+    popd
+# Build GD 2.0.33
+# Notes: none
+init_gd()
+    LIB_NAME="GD 2.0.33"
+build_gd()
+    pushd gd/gd
+        sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic
+    else
+    fi
+    make
+    check_build
+    popd
+clean_gd()
+    pushd gd/gd
+    make clean
+    check_clean
+    popd
+# Build JSON
+# Notes: none
+init_json()
+    LIB_NAME="JSON"
+build_json()
+    pushd jsoncpp
+    # Use system scons
+    scons platform=linux-gcc
+    popd
+clean_json()
+    pushd jsoncpp
+    rm -rf lib buildscons dist
+    popd
+# Build CSMAP
+# Notes: none
+init_csmap()
+    LIB_NAME="CSMAP"
+build_csmap()
+    pushd CsMap
+    mkdir -p .libs
+    pushd Source
+        make -fLibrary.mak PROCESSOR=x64
+    else
+        make -fLibrary.mak PROCESSOR=x86
+    fi
+    cp ../lib47/Linux$BUILD_CPU/CsMap.a ../.libs/libCsmap.a
+    popd
+    pushd Dictionaries
+        make -fCompiler.mak PROCESSOR=x64
+    else
+        make -fCompiler.mak PROCESSOR=x86
+    fi
+    popd
+    check_build
+    popd
+clean_csmap()
+    pushd CsMap/Source
+        make clean -fLibrary.mak PROCESSOR=x64
+    else
+        make clean -fLibrary.mak PROCESSOR=x86
+    fi
+    check_clean
+    popd
+# Build Fusion
+# Notes: requires Apache Ant
+init_fusion()
+    LIB_NAME="Fusion"
+build_fusion()
+    pushd fusion
+    ant prepare
+    ant compress
+    popd
+clean_fusion()
+    pushd fusion
+    ant clean
+    popd
+# Script loop
+pushd Oem
+for lib in linuxapt ace dwfcore dwftk geos bdbxml cppunit imake zlib libpng jpeg freetype gd json csmap;
+do
+    echo "$lib: Initialization..........................."
+    init_"$lib"
+    if test "$CLEAN_FLAG" = "1"; then
+        echo "$lib: Clean ....................................."
+        clean_"$lib"
+        echo "$lib: Clean Successful .........................."
+    else
+        echo "$lib: Configure/Build ..........................."
+        build_"$lib"
+        echo "$lib: Build Successful .........................."
+    fi
+done
+popd
More information about the mapguide-commits mailing list
