[mapguide-commits] r9071 - in trunk/Tools/JenkinsCI: home/slave_win/jobs home/slave_win/jobs/FDO 4.1 x64 home/slave_win/jobs/FDO 4.1 x86 home/slave_win/jobs/FDO x64 home/slave_win/jobs/FDO x86 home/slave_win/jobs/Maestro trunk home/slave_win/jobs/MapGuide Open Source 2.6 x64 home/slave_win/jobs/MapGuide Open Source 2.6 x86 home/slave_win/jobs/MapGuide Open Source 3.0 x64 home/slave_win/jobs/MapGuide Open Source 3.0 x86 home/slave_win/jobs/MapGuide Open Source 3.1 x64 home/slave_win/jobs/MapGuide Open Source 3.1 x86 home/slave_win/jobs/MapGuide Open Source x64 home/slave_win/jobs/MapGuide Open Source x86 tools
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Oct 26 07:07:43 PDT 2016
Author: jng
Date: 2016-10-26 07:07:43 -0700 (Wed, 26 Oct 2016)
New Revision: 9071
Added:
   trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x64/
   trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x64/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x86/
   trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x86/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x64/
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x64/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x86/
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x86/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.0 x64/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.0 x86/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml
   trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml
   trunk/Tools/JenkinsCI/tools/setrevnums.bat
   trunk/Tools/JenkinsCI/tools/svnupdate.bat
This is the Jenkins config used to build MGOS 3.1
Added: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x64/config.xml	                        (rev 0)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x64/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -0,0 +1,182 @@
+<?xml version='1.0' encoding='UTF-8'?>
+<project>
+  <actions/>
+  <description></description>
+  <logRotator class="hudson.tasks.LogRotator">
+    <daysToKeep>-1</daysToKeep>
+    <numToKeep>1</numToKeep>
+    <artifactDaysToKeep>-1</artifactDaysToKeep>
+    <artifactNumToKeep>-1</artifactNumToKeep>
+  </logRotator>
+  <keepDependencies>false</keepDependencies>
+  <properties>
+    <hudson.model.ParametersDefinitionProperty>
+      <parameterDefinitions>
+        <hudson.model.StringParameterDefinition>
+          <name>FDO_BUILD_SRC64</name>
+          <description>FDO Source directory</description>
+          <defaultValue>C:\working\sources\fdo-4.1</defaultValue>
+        </hudson.model.StringParameterDefinition>
+          <name>FDO_VERSION64</name>
+          <description>FDO Version Number (major.minor.rev)</description>
+          <defaultValue>4.1.0</defaultValue>
+        <hudson.model.BooleanParameterDefinition>
+          <name>CLEAR_WORKING_AREA</name>
+          <defaultValue>true</defaultValue>
+        </hudson.model.BooleanParameterDefinition>
+          <name>FDO_STAMP_FILE_SOURCE64</name>
+          <defaultValue>C:\working\sources\fdo_41_revision.txt</defaultValue>
+          <name>FDO_RUN_UNIT_TESTS64</name>
+      </parameterDefinitions>
+    </hudson.model.ParametersDefinitionProperty>
+  </properties>
+  <scm class="hudson.scm.NullSCM"/>
+  <canRoam>true</canRoam>
+  <disabled>false</disabled>
+  <blockBuildWhenDownstreamBuilding>false</blockBuildWhenDownstreamBuilding>
+  <blockBuildWhenUpstreamBuilding>false</blockBuildWhenUpstreamBuilding>
+  <jdk>(Default)</jdk>
+  <triggers/>
+  <concurrentBuild>false</concurrentBuild>
+  <builders>
+    <hudson.tasks.BatchFile>
+      <command>@echo off&#xd;
+SET FDOMYSQL=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\mysql_x64&#xd;
+SET FDOORACLE=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\oracle_x64\instantclient\11.2\sdk&#xd;
+SET FDOPOSTGRESQL=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\pgsql&#xd;
+SET FDO_BUILD_OUTPUT64=%MG_BUILD_ARTIFACT_PATH%\fdo\%FDO_VERSION64%\x64&#xd;
+SET FDO_BIN_EXTRAS64=%MG_LIB_ROOT%\fdo_extras\%FDO_VERSION64%\x64&#xd;
+SET REVNUM_FILE64=%MG_TOOL_PATH%\revnum.pl&#xd;
+SET FDO_STAMP_FILE64=%MG_BUILD_ARTIFACT_PATH%\last_fdo_%FDO_VERSION64%_revision_x64.txt&#xd;
+SET FDO_WORKING_AREA64=%MG_BUILD_AREA%\FDO\%FDO_VERSION64%\x64&#xd;
+&#xd;
+echo ============ Env Vars for FDO Build =====================&#xd;
+echo FDOMYSQL           = %FDOMYSQL%&#xd;
+echo FDOORACLE          = %FDOORACLE%&#xd;
+echo FDOPOSTGRESQL      = %FDOPOSTGRESQL%&#xd;
+echo FDO_BUILD_OUTPUT64 = %FDO_BUILD_OUTPUT64%&#xd;
+echo FDO_BIN_EXTRAS64   = %FDO_BIN_EXTRAS64%&#xd;
+echo REVNUM_FILE64      = %REVNUM_FILE64%&#xd;
+echo FDO_STAMP_FILE64   = %FDO_STAMP_FILE64%&#xd;
+echo FDO_WORKING_AREA64 = %FDO_WORKING_AREA64%&#xd;
+echo =========================================================&#xd;
+&#xd;
+REM Pre-build checks, nuke artifact dir and working area&#xd;
+echo [prepare]: Clean out build area and build artifacts&#xd;
+if exist %FDO_BUILD_OUTPUT64% rd /S /Q %FDO_BUILD_OUTPUT64%&#xd;
+if "%CLEAR_WORKING_AREA%"=="false" (&#xd;
+    echo [prepare]: Skip cleaning build area&#xd;
+    goto build_fdo&#xd;
+)&#xd;
+if exist %FDO_WORKING_AREA64% rd /S /Q %FDO_WORKING_AREA64%&#xd;
+if not exist %FDO_WORKING_AREA64% mkdir %FDO_WORKING_AREA64%&#xd;
+&#xd;
+REM Need to supply --force otherwise it won't export into the dir we made&#xd;
+echo [prepare]: Exporting SVN working copy to build area&#xd;
+SET BUILD_ACTION=Exporting SVN working copy to build area&#xd;
+svn export %FDO_BUILD_SRC64% %FDO_WORKING_AREA64% --force -q&#xd;
+if "%errorlevel%"=="1" goto error&#xd;
+&#xd;
+REM Copy non-UAC UpdateVersion&#xd;
+echo [prepare]: Copy non UAC-gimped UpdateVersion&#xd;
+SET BUILD_ACTION=Copy non UAC-gimped UpdateVersion&#xd;
+copy /Y %MG_TOOL_PATH%\UpdateVersion.exe %FDO_WORKING_AREA64%\Thirdparty\util\UpdateVersion\bin&#xd;
+&#xd;
+:build_fdo&#xd;
+echo [prepare]: Noting SVN revision&#xd;
+set /p REVISION= < "%FDO_STAMP_FILE_SOURCE64%"&#xd;
+copy /Y "%FDO_STAMP_FILE_SOURCE64%" "%FDO_STAMP_FILE64%"&#xd;
+&#xd;
+REM Need to use x86_amd64 because the 64-bit compiler in VS 2012 express is a cross-compiler&#xd;
+pushd %FDO_WORKING_AREA64%&#xd;
+echo [build]: Set env vars&#xd;
+call setenvironment.bat x86_amd64&#xd;
+&#xd;
+echo [build]: build thirdparty&#xd;
+SET BUILD_ACTION=Build FDO Thirdparty&#xd;
+call build_thirdparty.bat -p=x64 -a=buildinstall -o=%FDO_BUILD_OUTPUT64%&#xd;
+&#xd;
+echo [build]: build core and providers&#xd;
+SET BUILD_ACTION=Build FDO core/providers&#xd;
+call build.bat -p=x64 -a=buildinstall -o=%FDO_BUILD_OUTPUT64%&#xd;
+&#xd;
+if not exist %FDO_BIN_EXTRAS64% goto pack&#xd;
+echo [build]: Overlaying FDO extras to build artifacts&#xd;
+pushd %FDO_BIN_EXTRAS64%&#xd;
+copy /Y *.* %FDO_BUILD_OUTPUT64%\Fdo\Bin&#xd;
+popd&#xd;
+:pack&#xd;
+echo [build]: Pack files&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=fdo -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=shp -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=sdf -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=wfs -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=wms -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=rdbms -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=mysql -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=odbc -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=sqlspatial -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=gdal -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=kingoracle -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=ogr -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=sqlite -b=%REVISION% -r=%FDO_VERSION_64%&#xd;
+popd&#xd;
+&#xd;
+if "%FDO_RUN_UNIT_TESTS64%"=="false" goto end&#xd;
+:fdo_unit_tests&#xd;
+pushd %FDO_WORKING_AREA64%\Fdo\Unmanaged\Bin\Win64\Release&#xd;
+UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\fdocore_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA64%\Providers\SHP\Src\UnitTest&#xd;
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\shp_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA64%\Providers\SDF\Src\UnitTest&#xd;
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\sdf_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA64%\Providers\SQLite\Src\UnitTest&#xd;
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\sqlite_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA64%\Providers\OGR\Src\UnitTest&#xd;
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\ogr_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA64%\Providers\GDAL\Src\UnitTest&#xd;
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\gdal_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA64%\Providers\WMS\Src\UnitTest&#xd;
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\wms_unittest.log&#xd;
+popd&#xd;
+goto end&#xd;
+&#xd;
+:error&#xd;
+echo An error occurred while building FDO: %BUILD_ACTION%&#xd;
+exit /b 1&#xd;
+:end&#xd;
+exit /b 0</command>
+    </hudson.tasks.BatchFile>
+  </builders>
+  <publishers>
+    <hudson.tasks.BuildTrigger>
+      <childProjects>MapGuide Open Source 3.1 x64</childProjects>
+      <threshold>
+        <name>SUCCESS</name>
+        <ordinal>0</ordinal>
+        <color>BLUE</color>
+        <completeBuild>true</completeBuild>
+      </threshold>
+    </hudson.tasks.BuildTrigger>
+  </publishers>
+  <buildWrappers/>
+</project>
\ No newline at end of file
Added: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x86/config.xml	                        (rev 0)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 4.1 x86/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -0,0 +1,183 @@
+<project>
+  <actions/>
+  </logRotator>
+  <properties>
+          <name>FDO_BUILD_SRC</name>
+          <name>FDO_VERSION</name>
+          <name>FDO_STAMP_FILE_SOURCE</name>
+          <name>FDO_RUN_UNIT_TESTS</name>
+  </properties>
+  <quietPeriod>2700</quietPeriod>
+  <triggers/>
+  <builders>
+SET FDOMYSQL=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\mysql&#xd;
+SET FDOORACLE=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\oracle\instantclient\11.2\sdk&#xd;
+SET FDO_BUILD_OUTPUT=%MG_BUILD_ARTIFACT_PATH%\fdo\%FDO_VERSION%\x86&#xd;
+SET FDO_BIN_EXTRAS=%MG_LIB_ROOT%\fdo_extras\%FDO_VERSION%\x86&#xd;
+SET REVNUM_FILE=%MG_TOOL_PATH%\revnum.pl&#xd;
+SET FDO_STAMP_FILE=%MG_BUILD_ARTIFACT_PATH%\last_fdo_%FDO_VERSION%_revision_x86.txt&#xd;
+SET FDO_WORKING_AREA=%MG_BUILD_AREA%\FDO\%FDO_VERSION%\x86&#xd;
+&#xd;
+echo FDO_BUILD_OUTPUT   = %FDO_BUILD_OUTPUT%&#xd;
+echo FDO_BIN_EXTRAS     = %FDO_BIN_EXTRAS%&#xd;
+echo REVNUM_FILE        = %REVNUM_FILE%&#xd;
+echo FDO_STAMP_FILE     = %FDO_STAMP_FILE%&#xd;
+echo FDO_WORKING_AREA   = %FDO_WORKING_AREA%&#xd;
+&#xd;
+if exist %FDO_BUILD_OUTPUT% rd /S /Q %FDO_BUILD_OUTPUT%&#xd;
+)&#xd;
+if exist %FDO_WORKING_AREA% rd /S /Q %FDO_WORKING_AREA%&#xd;
+if not exist %FDO_WORKING_AREA% mkdir %FDO_WORKING_AREA%&#xd;
+&#xd;
+svn export %FDO_BUILD_SRC% %FDO_WORKING_AREA% --force -q&#xd;
+&#xd;
+copy /Y %MG_TOOL_PATH%\UpdateVersion.exe %FDO_WORKING_AREA%\Thirdparty\util\UpdateVersion\bin&#xd;
+&#xd;
+:build_fdo&#xd;
+set /p REVISION= < "%FDO_STAMP_FILE_SOURCE%"&#xd;
+copy /Y "%FDO_STAMP_FILE_SOURCE%" "%FDO_STAMP_FILE%"&#xd;
+&#xd;
+pushd %FDO_WORKING_AREA%&#xd;
+call setenvironment.bat x86&#xd;
+&#xd;
+call build_thirdparty.bat -p=Win32 -a=buildinstall -o=%FDO_BUILD_OUTPUT%&#xd;
+&#xd;
+call build.bat -p=Win32 -a=buildinstall -o=%FDO_BUILD_OUTPUT%&#xd;
+&#xd;
+if not exist %FDO_BIN_EXTRAS% goto pack&#xd;
+pushd %FDO_BIN_EXTRAS%&#xd;
+copy /Y *.* %FDO_BUILD_OUTPUT%\Fdo\Bin&#xd;
+popd&#xd;
+&#xd;
+:pack&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=fdo -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=shp -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=sdf -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=wfs -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=wms -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=rdbms -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=mysql -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=odbc -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=sqlspatial -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=gdal -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=kingoracle -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=ogr -b=%REVISION% -r=%FDO_VERSION%&#xd;
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=sqlite -b=%REVISION% -r=%FDO_VERSION%&#xd;
+popd&#xd;
+&#xd;
+if "%FDO_RUN_UNIT_TESTS%"=="false" goto end&#xd;
+pushd %FDO_WORKING_AREA%\Fdo\Unmanaged\Bin\Win32\Release&#xd;
+UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\fdocore_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA%\Providers\SHP\Src\UnitTest&#xd;
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\shp_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA%\Providers\SDF\Src\UnitTest&#xd;
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\sdf_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA%\Providers\SQLite\Src\UnitTest&#xd;
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\sqlite_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA%\Providers\OGR\Src\UnitTest&#xd;
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\ogr_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA%\Providers\GDAL\Src\UnitTest&#xd;
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\gdal_unittest.log&#xd;
+popd&#xd;
+pushd %FDO_WORKING_AREA%\Providers\WMS\Src\UnitTest&#xd;
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\wms_unittest.log&#xd;
+popd&#xd;
+goto end&#xd;
+&#xd;
+:error&#xd;
+exit /b 1&#xd;
+:end&#xd;
+  </builders>
+  <publishers>
+      <childProjects>MapGuide Open Source 3.1 x86</childProjects>
+      <threshold>
+      </threshold>
+  </publishers>
+  <buildWrappers/>
+</project>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -20,7 +20,7 @@
-          <defaultValue>4.0.0</defaultValue>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -20,7 +20,7 @@
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -15,7 +15,7 @@
           <name>VersionLabel</name>
           <description>The release version label</description>
-          <defaultValue>6.0m4</defaultValue>
+          <defaultValue>6.0m5</defaultValue>
           <name>BASE_VERSION</name>
@@ -25,7 +25,7 @@
   </properties>
-  <scm class="hudson.scm.SubversionSCM" plugin="subversion at 2.5">
+  <scm class="hudson.scm.SubversionSCM" plugin="subversion at 2.5.3">
     <locations>
       <hudson.scm.SubversionSCM_-ModuleLocation>
         <remote>http://svn.osgeo.org/mapguide/trunk/Tools/Maestro</remote>
@@ -51,7 +51,7 @@
   <triggers>
     <hudson.triggers.SCMTrigger>
-      <spec>15 * * * *</spec>
+      <spec>H/15 * * * *</spec>
       <ignorePostCommitHooks>false</ignorePostCommitHooks>
     </hudson.triggers.SCMTrigger>
   </triggers>
@@ -67,10 +67,13 @@
 pushd "%WORKSPACE%\SDK"&#xd;
 rd /S /Q bin&#xd;
 popd&#xd;
-if not exist "%WORKSPACE%\TestResults" mkdir "%WORKSPACE%\TestResults"</command>
+if not exist "%WORKSPACE%\TestResults" mkdir "%WORKSPACE%\TestResults"&#xd;
+pushd "%WORKSPACE%\Maestro"&#xd;
+.nuget\nuget.exe restore Maestro_All.sln&#xd;
+popd</command>
     <hudson.plugins.msbuild.MsBuildBuilder plugin="msbuild at 1.24">
-      <msBuildName>MSBUILD 4.0 x86</msBuildName>
+      <msBuildName>MSBuild 14.0</msBuildName>
       <msBuildFile>Maestro\Maestro_All.sln</msBuildFile>
       <cmdLineArgs>/p:Configuration=Release</cmdLineArgs>
       <buildVariablesAsProperties>true</buildVariablesAsProperties>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -35,7 +35,7 @@
           <name>MG_VER_BUILD</name>
-          <defaultValue>1</defaultValue>
+          <defaultValue>2</defaultValue>
           <name>MG_BUILD_SRC64</name>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -35,7 +35,7 @@
           <name>MG_BUILD_SRC</name>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.0 x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.0 x64/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.0 x64/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -35,7 +35,7 @@
-          <defaultValue>0</defaultValue>
+          <defaultValue>1</defaultValue>
@@ -306,7 +306,7 @@
   </builders>
   <publishers>
-      <childProjects>Test MapGuide x64</childProjects>
+      <childProjects></childProjects>
       <threshold>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.0 x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.0 x86/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.0 x86/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -35,7 +35,7 @@
@@ -306,7 +306,7 @@
   </builders>
   <publishers>
-      <childProjects>Test MapGuide x86</childProjects>
       <threshold>
Added: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x64/config.xml	                        (rev 0)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x64/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -0,0 +1,319 @@
+<project>
+  <actions/>
+  </logRotator>
+  <properties>
+          <name>RELEASE_LABEL64</name>
+          <defaultValue>Final</defaultValue>
+          <name>WITH_ARCSDE</name>
+          <defaultValue>no</defaultValue>
+          <name>MG_VER_MAJOR</name>
+          <defaultValue>3</defaultValue>
+          <name>MG_VER_MINOR</name>
+          <name>MG_VER_BUILD</name>
+          <defaultValue>0</defaultValue>
+          <name>MG_BUILD_SRC64</name>
+          <defaultValue>C:\working\sources\mg-3.1</defaultValue>
+          <name>FDO_SRC64</name>
+          <defaultValue>C:\builds\fdo\4.1.0\x64\Fdo</defaultValue>
+          <name>INSTANT_SETUP_SRC</name>
+          <defaultValue>C:\working\sources\MgInstantSetup</defaultValue>
+          <name>MG_STAMP_FILE_SOURCE64</name>
+          <defaultValue>C:\working\sources\mapguide_31_revision.txt</defaultValue>
+  </properties>
+  <jdk>JDK6 64-bit</jdk>
+  <triggers/>
+  <builders>
+&#xd;
+SET BUILD_ACTION=Setting Visual Studio env vars&#xd;
+SET VCBEXTENSION=_vs14&#xd;
+SET VC_COMPILER=vc140&#xd;
+SET ACTIVENAMECHECK="Microsoft Visual Studio 14"&#xd;
+SET ACTIVEPATHCHECK="C:\Program Files\Microsoft Visual Studio 14.0\VC"&#xd;
+if exist %ACTIVEPATHCHECK% goto VSExist&#xd;
+SET ACTIVEPATHCHECK="C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC"&#xd;
+goto error&#xd;
+&#xd;
+REM Use x86_amd64 because 64-bit compiler in VS2012 express is a cross-compiler&#xd;
+:VSExist&#xd;
+call %ACTIVEPATHCHECK%\vcvarsall.bat x86_amd64&#xd;
+&#xd;
+REM Sigh! We can't seem to reference this from Jenkins&#xd;
+SET MSBUILD_NET40=C:\Windows\Microsoft.NET\Framework\v4.0.30319\msbuild.exe&#xd;
+&#xd;
+SET MG_VER_MAJOR_MINOR=%MG_VER_MAJOR%.%MG_VER_MINOR%&#xd;
+SET MG_VER_MAJOR_MINOR_BUILD=%MG_VER_MAJOR_MINOR%.%MG_VER_BUILD%&#xd;
+SET MG_BUILD_OUTPUT_ROOT64=%MG_BUILD_ARTIFACT_PATH%\mapguide&#xd;
+SET MG_BUILD_OUTPUT64=%MG_BUILD_OUTPUT_ROOT64%\%MG_VER_MAJOR_MINOR_BUILD%\x64\release&#xd;
+SET MG_BUILD_AREA64=%MG_BUILD_AREA%\mapguide\%MG_VER_MAJOR_MINOR_BUILD%\x64&#xd;
+SET MG_STAMP_FILE64=%MG_BUILD_ARTIFACT_PATH%\last_mapguide_%MG_VER_MAJOR_MINOR_BUILD%_revision_x64.txt&#xd;
+SET BUILD_ACTION=&#xd;
+&#xd;
+echo =================== Env Vars for MapGuide =============================&#xd;
+echo MG_VER_MAJOR_MINOR         = %MG_VER_MAJOR_MINOR%&#xd;
+echo MG_VER_MAJOR_MINOR_BUILD   = %MG_VER_MAJOR_MINOR_BUILD%&#xd;
+echo MG_BUILD_OUTPUT_ROOT64     = %MG_BUILD_OUTPUT_ROOT64%&#xd;
+echo MG_BUILD_OUTPUT64          = %MG_BUILD_OUTPUT64%&#xd;
+echo MG_BUILD_AREA64            = %MG_BUILD_AREA64%&#xd;
+echo MG_STAMP_FILE64            = %MG_STAMP_FILE64%&#xd;
+echo INSTANT_SETUP_SRC          = %INSTANT_SETUP_SRC%&#xd;
+echo JAVA_HOME                  = %JAVA_HOME%&#xd;
+echo ANT_HOME                   = %ANT_HOME%&#xd;
+echo =======================================================================&#xd;
+&#xd;
+echo [prepare]: Cleaning out build artifacts&#xd;
+if exist %MG_BUILD_OUTPUT64% rd /S /Q %MG_BUILD_OUTPUT64%&#xd;
+&#xd;
+set /p MG_REVISION64= < "%MG_STAMP_FILE_SOURCE64%"&#xd;
+copy /Y "%MG_STAMP_FILE_SOURCE64%" "%MG_STAMP_FILE64%"&#xd;
+&#xd;
+    goto build_mapguide&#xd;
+)&#xd;
+echo [prepare]: Cleaning out build area&#xd;
+if exist %MG_BUILD_AREA64% rd /S /Q %MG_BUILD_AREA64%&#xd;
+echo [prepare]: Re-creating output directories&#xd;
+if not exist %MG_BUILD_AREA64%\Installer mkdir %MG_BUILD_AREA64%\Installer&#xd;
+if not exist %MG_BUILD_AREA64%\MgDev mkdir %MG_BUILD_AREA64%\MgDev&#xd;
+if not exist %MG_BUILD_ARTIFACT_PATH%\mg-desktop mkdir %MG_BUILD_ARTIFACT_PATH%\mg-desktop&#xd;
+&#xd;
+echo [prepare]: Exporting SVN working copy to build area (Installer)&#xd;
+SET BUILD_ACTION=Exporting SVN working copy to build area (Installer)&#xd;
+svn export %MG_BUILD_SRC64%\Installer %MG_BUILD_AREA64%\Installer --force -q&#xd;
+&#xd;
+echo [prepare]: Copying SVN working copy to build area (MgDev)&#xd;
+SET BUILD_ACTION=Copying SVN working copy to build area (MgDev)&#xd;
+svn export %MG_BUILD_SRC64%\MgDev %MG_BUILD_AREA64%\MgDev --force -q&#xd;
+&#xd;
+echo [prepare]: Setup FDO in Oem&#xd;
+cd %MG_BUILD_AREA64%\MgDev\Oem\FDO&#xd;
+xcopy /S /Y /I %FDO_SRC64%\Inc Inc&#xd;
+xcopy /S /Y /I %FDO_SRC64%\Lib Lib64&#xd;
+xcopy /S /Y /I %FDO_SRC64%\Bin Bin\Release64&#xd;
+xcopy /S /Y /I %FDO_SRC64%\Bin\com\*.* Bin\Release64\com&#xd;
+REM For release we don't want pdbs and .net assemblies&#xd;
+cd %MG_BUILD_AREA64%\MgDev\Oem\FDO\Bin\Release64&#xd;
+del /Q OSGeo.FDO.*&#xd;
+del /Q *.pdb&#xd;
+&#xd;
+:build_mapguide&#xd;
+cd %MG_BUILD_AREA64%\MgDev&#xd;
+echo [build]: Stamp version numbers&#xd;
+SET BUILD_ACTION=Stamp version numbers&#xd;
+cscript updateversion.vbs /major:%MG_VER_MAJOR% /minor:%MG_VER_MINOR% /point:%MG_VER_BUILD% /build:%MG_REVISION64%&#xd;
+call stampassemblies.bat %MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%&#xd;
+&#xd;
+REM ========================================= MapGuide ====================================================&#xd;
+&#xd;
+call setenvironment64.bat&#xd;
+&#xd;
+echo [build]: build oem/server/web&#xd;
+SET BUILD_ACTION=build oem/server/web&#xd;
+call build.bat&#xd;
+&#xd;
+echo [build]: install files to build artifact directory&#xd;
+SET BUILD_ACTION=install files to build artifact directory&#xd;
+call build.bat -a=install -o=%MG_BUILD_OUTPUT64%&#xd;
+&#xd;
+REM Move fusion-selfbuild tools out of staging area&#xd;
+pushd %MG_BUILD_OUTPUT64%\fusion-selfbuild&#xd;
+move /Y fusion-%MG_VER_MAJOR_MINOR_BUILD%-buildtools.zip %MG_BUILD_OUTPUT_ROOT64%&#xd;
+popd&#xd;
+pushd %MG_BUILD_OUTPUT64%&#xd;
+rd /S /Q fusion-selfbuild&#xd;
+popd&#xd;
+&#xd;
+REM ========================================= mg-desktop ====================================================&#xd;
+:build_mgdesktop&#xd;
+REM HACK: mg-desktop batch files not aware of new output dir so set old one&#xd;
+SET MG_OUTPUT=%MG_BUILD_AREA64%\MgDev\Release64&#xd;
+pushd %MG_BUILD_AREA64%\MgDev&#xd;
+echo [build]: mg-desktop&#xd;
+SET BUILD_ACTION=Build mg-desktop&#xd;
+call build_desktop.bat x64&#xd;
+popd&#xd;
+&#xd;
+pushd %MG_BUILD_AREA64%\MgDev\nuget&#xd;
+echo [clean]: Nuget package temp files&#xd;
+call package_clean.bat&#xd;
+popd&#xd;
+&#xd;
+echo [build]: Nuget packages&#xd;
+call nuget_prepare.bat %MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64% x64&#xd;
+SET BUILD_ACTION=Nuget packages&#xd;
+call nuget_pack.bat x64&#xd;
+popd&#xd;
+&#xd;
+echo [build]: Copy mg-desktop build artifacts (NuGet packages)&#xd;
+set BUILD_ACTION=Copy mg-desktop build artifacts (NuGet packages)&#xd;
+move *.nupkg %MG_BUILD_ARTIFACT_PATH%\mg-desktop&#xd;
+popd&#xd;
+&#xd;
+pushd %MG_BUILD_AREA64%\MgDev\Release64&#xd;
+echo [build]: Copy mg-desktop build artifacts (zip dist)&#xd;
+SET BUILD_ACTION=Copy mg-desktop build artifacts (zip dist)&#xd;
+7z a -mx9 %MG_BUILD_ARTIFACT_PATH%\mg-desktop\mg-desktop-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-net40-vc11-x64.zip Desktop DesktopSamples&#xd;
+popd&#xd;
+&#xd;
+REM ========================================= Instant Setup =========================================================&#xd;
+pushd %MG_BUILD_AREA64%\Installer&#xd;
+echo [build]: Prepare artifact directory&#xd;
+SET BUILD_ACTION=Prepare artifact directory&#xd;
+call build.bat -a=prepare -source=%MG_BUILD_OUTPUT64%&#xd;
+popd&#xd;
+&#xd;
+if not exist %INSTANT_SETUP_SRC% goto checkout_instantsetup&#xd;
+goto update_instantsetup&#xd;
+:checkout_instantsetup&#xd;
+echo [build]: svn checkout MgInstantSetup&#xd;
+SET BUILD_ACTION=svn checkout MgInstantSetup&#xd;
+svn co %INSTANT_SETUP_SVN_URL% %INSTANT_SETUP_SRC%&#xd;
+goto build_instantsetup&#xd;
+&#xd;
+:update_instantsetup&#xd;
+REM We'll allow this to fail&#xd;
+echo [build]: svn update MgInstantSetup&#xd;
+pushd %INSTANT_SETUP_SRC%&#xd;
+svn update&#xd;
+popd&#xd;
+&#xd;
+:build_instantsetup&#xd;
+echo [build]: MgInstantSetup&#xd;
+SET BUILD_ACTION=Building MgInstantSetup&#xd;
+%MSBUILD_NET40% /p:Configuration=Release;Platform="Any CPU" MgInstantSetup.sln&#xd;
+popd&#xd;
+&#xd;
+:copy_instantsetup_build_artifacts&#xd;
+echo [build]: Copy MgInstantSetup build artifacts&#xd;
+if not exist %MG_BUILD_OUTPUT64%\Setup mkdir %MG_BUILD_OUTPUT64%\Setup&#xd;
+pushd %INSTANT_SETUP_SRC%\out\release&#xd;
+copy /Y *.exe %MG_BUILD_OUTPUT64%\Setup&#xd;
+copy /Y *.pdb %MG_BUILD_OUTPUT64%\Setup&#xd;
+copy /Y *.dll %MG_BUILD_OUTPUT64%\Setup&#xd;
+copy /Y *.config %MG_BUILD_OUTPUT64%\Setup&#xd;
+popd&#xd;
+&#xd;
+:zip_mginstantsetup&#xd;
+7z a %MG_BUILD_OUTPUT_ROOT64%\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-InstantSetup-x64.exe -mmt -mx5 -sfx7z.sfx CS-Map Server Web Setup&#xd;
+popd&#xd;
+&#xd;
+:zip_testpack&#xd;
+7z a %MG_BUILD_OUTPUT_ROOT64%\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-TestSuite-x64.exe -mmt -mx5 -sfx7z.sfx Test&#xd;
+popd&#xd;
+&#xd;
+REM ========================================= MapGuide Installer ====================================================&#xd;
+&#xd;
+:build_installer&#xd;
+echo [build]: Generate installer file listings&#xd;
+SET BUILD_ACTION=Generate installer file listings&#xd;
+call build.bat -a=generate -source=%MG_BUILD_OUTPUT64%&#xd;
+&#xd;
+echo [build]: Build the installer&#xd;
+SET BUILD_ACTION=Build the installer&#xd;
+call build.bat -source=%MG_BUILD_OUTPUT64% -version=%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64% -name=MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-%RELEASE_LABEL64%-x64 -title="MapGuide Open Source %MG_VER_MAJOR_MINOR_BUILD% %RELEASE_LABEL64%"&#xd;
+&#xd;
+move /Y Output\en-US\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-%RELEASE_LABEL64%-x64.exe %MG_BUILD_OUTPUT_ROOT64%&#xd;
+popd&#xd;
+&#xd;
+goto end&#xd;
+&#xd;
+:error&#xd;
+echo An error occurred while building MapGuide: %BUILD_ACTION%&#xd;
+exit /b 1&#xd;
+:end&#xd;
+  </builders>
+  <publishers>
+      <threshold>
+      </threshold>
+  </publishers>
+  <buildWrappers/>
+</project>
Added: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x86/config.xml	                        (rev 0)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 3.1 x86/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -0,0 +1,319 @@
+<project>
+  <actions/>
+  </logRotator>
+  <properties>
+          <name>RELEASE_LABEL</name>
+          <name>MG_BUILD_SRC</name>
+          <name>FDO_SRC</name>
+          <defaultValue>C:\builds\fdo\4.1.0\x86\Fdo</defaultValue>
+          <name>MG_STAMP_FILE_SOURCE</name>
+  </properties>
+  <jdk>JDK6 32-bit</jdk>
+  <triggers/>
+  <builders>
+&#xd;
+goto error&#xd;
+&#xd;
+:VSExist&#xd;
+call %ACTIVEPATHCHECK%\vcvarsall.bat x86&#xd;
+&#xd;
+&#xd;
+SET MG_BUILD_OUTPUT_ROOT=%MG_BUILD_ARTIFACT_PATH%\mapguide&#xd;
+SET MG_BUILD_OUTPUT=%MG_BUILD_OUTPUT_ROOT%\%MG_VER_MAJOR_MINOR_BUILD%\x86\release&#xd;
+SET MG_BUILD_AREA=%MG_BUILD_AREA%\mapguide\%MG_VER_MAJOR_MINOR_BUILD%\x86&#xd;
+SET MG_STAMP_FILE=%MG_BUILD_ARTIFACT_PATH%\last_mapguide_%MG_VER_MAJOR_MINOR_BUILD%_revision_x86.txt&#xd;
+&#xd;
+echo MG_BUILD_OUTPUT_ROOT       = %MG_BUILD_OUTPUT_ROOT%&#xd;
+echo MG_BUILD_OUTPUT            = %MG_BUILD_OUTPUT%&#xd;
+echo MG_BUILD_AREA              = %MG_BUILD_AREA%&#xd;
+echo MG_STAMP_FILE              = %MG_STAMP_FILE%&#xd;
+&#xd;
+if exist %MG_BUILD_OUTPUT% rd /S /Q %MG_BUILD_OUTPUT%&#xd;
+&#xd;
+set /p MG_REVISION= < "%MG_STAMP_FILE_SOURCE%"&#xd;
+copy /Y "%MG_STAMP_FILE_SOURCE%" "%MG_STAMP_FILE%"&#xd;
+&#xd;
+)&#xd;
+&#xd;
+if exist %MG_BUILD_AREA% rd /S /Q %MG_BUILD_AREA%&#xd;
+if not exist %MG_BUILD_AREA%\Installer mkdir %MG_BUILD_AREA%\Installer&#xd;
+if not exist %MG_BUILD_AREA%\MgDev mkdir %MG_BUILD_AREA%\MgDev&#xd;
+&#xd;
+svn export %MG_BUILD_SRC%\Installer %MG_BUILD_AREA%\Installer --force -q&#xd;
+&#xd;
+svn export %MG_BUILD_SRC%\MgDev %MG_BUILD_AREA%\MgDev --force -q&#xd;
+&#xd;
+cd %MG_BUILD_AREA%\MgDev\Oem\FDO&#xd;
+xcopy /S /Y /I %FDO_SRC%\Inc Inc&#xd;
+xcopy /S /Y /I %FDO_SRC%\Lib Lib&#xd;
+xcopy /S /Y /I %FDO_SRC%\Bin Bin\Release&#xd;
+xcopy /S /Y /I %FDO_SRC%\Bin\com\*.* Bin\Release\com&#xd;
+cd %MG_BUILD_AREA%\MgDev\Oem\FDO\Bin\Release&#xd;
+del /Q *.pdb&#xd;
+&#xd;
+cd %MG_BUILD_AREA%\MgDev&#xd;
+cscript updateversion.vbs /major:%MG_VER_MAJOR% /minor:%MG_VER_MINOR% /point:%MG_VER_BUILD% /build:%MG_REVISION%&#xd;
+call stampassemblies.bat %MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%&#xd;
+&#xd;
+&#xd;
+call setenvironment.bat&#xd;
+&#xd;
+&#xd;
+call build.bat -a=install -o=%MG_BUILD_OUTPUT%&#xd;
+&#xd;
+pushd %MG_BUILD_OUTPUT%\fusion-selfbuild&#xd;
+move /Y fusion-%MG_VER_MAJOR_MINOR_BUILD%-buildtools.zip %MG_BUILD_OUTPUT_ROOT%&#xd;
+popd&#xd;
+pushd %MG_BUILD_OUTPUT%&#xd;
+popd&#xd;
+&#xd;
+SET MG_OUTPUT=%MG_BUILD_AREA%\MgDev\Release&#xd;
+pushd %MG_BUILD_AREA%\MgDev&#xd;
+call build_desktop.bat x86&#xd;
+popd&#xd;
+&#xd;
+pushd %MG_BUILD_AREA%\MgDev\nuget&#xd;
+popd&#xd;
+&#xd;
+call nuget_prepare.bat %MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION% x86&#xd;
+call nuget_pack.bat x86&#xd;
+popd&#xd;
+&#xd;
+popd&#xd;
+&#xd;
+pushd %MG_BUILD_AREA%\MgDev\Release&#xd;
+7z a -mx9 %MG_BUILD_ARTIFACT_PATH%\mg-desktop\mg-desktop-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-net40-vc11-x86.zip Desktop DesktopSamples&#xd;
+popd&#xd;
+&#xd;
+pushd %MG_BUILD_AREA%\Installer&#xd;
+call build.bat -a=prepare -source=%MG_BUILD_OUTPUT%&#xd;
+popd&#xd;
+&#xd;
+&#xd;
+svn update&#xd;
+popd&#xd;
+&#xd;
+popd&#xd;
+&#xd;
+if not exist %MG_BUILD_OUTPUT%\Setup mkdir %MG_BUILD_OUTPUT%\Setup&#xd;
+copy /Y *.exe %MG_BUILD_OUTPUT%\Setup&#xd;
+copy /Y *.pdb %MG_BUILD_OUTPUT%\Setup&#xd;
+copy /Y *.dll %MG_BUILD_OUTPUT%\Setup&#xd;
+copy /Y *.config %MG_BUILD_OUTPUT%\Setup&#xd;
+popd&#xd;
+&#xd;
+7z a %MG_BUILD_OUTPUT_ROOT%\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-InstantSetup-x86.exe -mmt -mx5 -sfx7z.sfx CS-Map Server Web Setup&#xd;
+popd&#xd;
+&#xd;
+:zip_testpack&#xd;
+7z a %MG_BUILD_OUTPUT_ROOT%\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-TestSuite-x86.exe -mmt -mx5 -sfx7z.sfx Test&#xd;
+popd&#xd;
+&#xd;
+&#xd;
+call build.bat -a=generate -source=%MG_BUILD_OUTPUT%&#xd;
+&#xd;
+call build.bat -source=%MG_BUILD_OUTPUT% -version=%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION% -name=MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-%RELEASE_LABEL%-x86 -title="MapGuide Open Source %MG_VER_MAJOR_MINOR_BUILD% %RELEASE_LABEL%"&#xd;
+&#xd;
+move /Y Output\en-US\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-%RELEASE_LABEL%-x86.exe %MG_BUILD_OUTPUT_ROOT%&#xd;
+popd&#xd;
+&#xd;
+goto end&#xd;
+&#xd;
+:error&#xd;
+exit /b 1&#xd;
+:end&#xd;
+  </builders>
+  <publishers>
+      <threshold>
+      </threshold>
+  </publishers>
+  <buildWrappers/>
+</project>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -45,7 +45,7 @@
-          <defaultValue>C:\builds\fdo\4.0.0\x64\Fdo</defaultValue>
@@ -62,6 +62,11 @@
           <defaultValue>C:\working\sources\mapguide_trunk_revision.txt</defaultValue>
+          <name>MG_VS_SUFFIX64</name>
+          <description>The VS suffix used for naming the mg-desktop zip package</description>
+          <defaultValue>vc14</defaultValue>
   </properties>
@@ -222,7 +227,7 @@
-7z a -mx9 %MG_BUILD_ARTIFACT_PATH%\mg-desktop\mg-desktop-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-net40-vc11-x64.zip Desktop DesktopSamples&#xd;
+7z a -mx9 %MG_BUILD_ARTIFACT_PATH%\mg-desktop\mg-desktop-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-net40-%MG_VS_SUFFIX64%-x64.zip Desktop DesktopSamples&#xd;
 popd&#xd;
 &#xd;
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml	2016-10-26 14:07:43 UTC (rev 9071)
@@ -45,7 +45,7 @@
-          <defaultValue>C:\builds\fdo\4.0.0\x86\Fdo</defaultValue>
@@ -62,6 +62,11 @@
+          <name>MG_VS_SUFFIX</name>
+          <description>The VS suffix to use for naming mg-desktop zip packages</description>
   </properties>
@@ -222,7 +227,7 @@
-7z a -mx9 %MG_BUILD_ARTIFACT_PATH%\mg-desktop\mg-desktop-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-net40-vc11-x86.zip Desktop DesktopSamples&#xd;
+7z a -mx9 %MG_BUILD_ARTIFACT_PATH%\mg-desktop\mg-desktop-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-net40-%MG_VS_SUFFIX%-x86.zip Desktop DesktopSamples&#xd;
 popd&#xd;
 &#xd;
Modified: trunk/Tools/JenkinsCI/tools/setrevnums.bat
--- trunk/Tools/JenkinsCI/tools/setrevnums.bat	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/tools/setrevnums.bat	2016-10-26 14:07:43 UTC (rev 9071)
@@ -2,8 +2,9 @@
 SET MG_SOURCES_DIR=C:\working\sources
 svn info "%MG_SOURCES_DIR%\fdo-3.9" | perl revnum.pl > "%MG_SOURCES_DIR%\fdo_39_revision.txt"
 svn info "%MG_SOURCES_DIR%\fdo-4.0" | perl revnum.pl > "%MG_SOURCES_DIR%\fdo_40_revision.txt"
+svn info "%MG_SOURCES_DIR%\fdo-4.1" | perl revnum.pl > "%MG_SOURCES_DIR%\fdo_41_revision.txt"
 svn info "%MG_SOURCES_DIR%\fdo-trunk" | perl revnum.pl > "%MG_SOURCES_DIR%\fdo_trunk_revision.txt"
 svn info "%MG_SOURCES_DIR%\mg-2.6\MgDev" | perl revnum.pl > "%MG_SOURCES_DIR%\mapguide_26_revision.txt"
 svn info "%MG_SOURCES_DIR%\mg-3.0\MgDev" | perl revnum.pl > "%MG_SOURCES_DIR%\mapguide_30_revision.txt"
+svn info "%MG_SOURCES_DIR%\mg-3.1\MgDev" | perl revnum.pl > "%MG_SOURCES_DIR%\mapguide_31_revision.txt"
 svn info "%MG_SOURCES_DIR%\mg-trunk\MgDev" | perl revnum.pl > "%MG_SOURCES_DIR%\mapguide_trunk_revision.txt"
-svn info "%MG_SOURCES_DIR%\diet_mapguide\MgDev" | perl revnum.pl > "%MG_SOURCES_DIR%\mapguide_31_revision.txt"
Modified: trunk/Tools/JenkinsCI/tools/svnupdate.bat
--- trunk/Tools/JenkinsCI/tools/svnupdate.bat	2016-10-12 01:00:25 UTC (rev 9070)
+++ trunk/Tools/JenkinsCI/tools/svnupdate.bat	2016-10-26 14:07:43 UTC (rev 9071)
@@ -2,14 +2,14 @@
 svn update "%MG_SOURCES_DIR%\fdo-3.9"
 svn update "%MG_SOURCES_DIR%\fdo-4.0"
+svn update "%MG_SOURCES_DIR%\fdo-4.1"
 svn update "%MG_SOURCES_DIR%\fdo-trunk"
 svn update "%MG_SOURCES_DIR%\mg-2.6\Installer"
 svn update "%MG_SOURCES_DIR%\mg-2.6\MgDev"
 svn update "%MG_SOURCES_DIR%\mg-3.0\Installer"
 svn update "%MG_SOURCES_DIR%\mg-3.0\MgDev"
+svn update "%MG_SOURCES_DIR%\mg-3.1\Installer"
+svn update "%MG_SOURCES_DIR%\mg-3.1\MgDev"
 svn update "%MG_SOURCES_DIR%\mg-trunk\Installer"
 svn update "%MG_SOURCES_DIR%\mg-trunk\MgDev"
-svn update "%MG_SOURCES_DIR%\diet_mapguide\Installer"
-svn update "%MG_SOURCES_DIR%\diet_mapguide\MgDev"
-svn update "%MG_SOURCES_DIR%\diet_oem"
 svn update "%MG_SOURCES_DIR%\MgInstantSetup"
More information about the mapguide-commits mailing list
