[mapguide-commits] r9157 - in sandbox/jng/clean_json: Common/PlatformBase/Services UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Apr 19 09:00:47 PDT 2017
Author: jng
Date: 2017-04-19 09:00:47 -0700 (Wed, 19 Apr 2017)
New Revision: 9157
   sandbox/jng/clean_json/Common/PlatformBase/Services/ClassDefinition.cpp
   sandbox/jng/clean_json/Common/PlatformBase/Services/FeatureSchemaCollection.cpp
   sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/describeschemaform.html
   sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getclassdefinitionform.html
   sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeSchema.cpp
   sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeSchema.h
   sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetClassDefinition.cpp
   sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetClassDefinition.h
   sandbox/jng/clean_json/Web/src/HttpHandler/HttpResourceStrings.cpp
   sandbox/jng/clean_json/Web/src/HttpHandler/HttpResourceStrings.h
- Fix typo in simple class definition XML
- Fix IsIdentity not being written out to the simple XML
- Add missing XML prolog in Feature Schema Collection simple XML
- Update DESCRIBESCHEMA and GETCLASSDEFINITION operations to support a new SIMPLE flag that will instruct the operation to request the simplified XML of the requested schema or class definition instead of the normal verbose FDO schema XML
- Update respective test forms to include the new SIMPLE flag
Modified: sandbox/jng/clean_json/Common/PlatformBase/Services/ClassDefinition.cpp
--- sandbox/jng/clean_json/Common/PlatformBase/Services/ClassDefinition.cpp	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/Common/PlatformBase/Services/ClassDefinition.cpp	2017-04-19 16:00:47 UTC (rev 9157)
@@ -278,6 +278,7 @@
     xml.append(L"<Properties>");
     Ptr<MgPropertyDefinitionCollection> props = GetProperties();
+    Ptr<MgPropertyDefinitionCollection> idProps = GetIdentityProperties();
     INT32 pcount = props->GetCount();
     for (INT32 i = 0; i < pcount; i++)
@@ -307,6 +308,10 @@
             MgGeometricPropertyDefinition* gpd = dynamic_cast<MgGeometricPropertyDefinition*>(pdef.p);
             MgRasterPropertyDefinition* rpd = dynamic_cast<MgRasterPropertyDefinition*>(pdef.p);
+            xml.append(L"<IsIdentity>");
+            xml.append((idProps->IndexOf(pdef->GetName()) >= 0) ? L"true" : L"false");
+            xml.append(L"</IsIdentity>");
             if (NULL != dpd)
                 xml.append(L"<DataType>");
@@ -355,7 +360,7 @@
                 xml.append(gpd->GetReadOnly() ? L"true" : L"false");
                 xml.append(L"</ReadOnly>");
-                xml.append(L"<SpatialContextAssocation>");
+                xml.append(L"<SpatialContextAssociation>");
                 xml.append(gpd->GetSpatialContextAssociation());
                 xml.append(L"</SpatialContextAssociation>");
@@ -397,7 +402,7 @@
                 xml.append(rpd->GetReadOnly() ? L"true" : L"false");
                 xml.append(rpd->GetSpatialContextAssociation());
Modified: sandbox/jng/clean_json/Common/PlatformBase/Services/FeatureSchemaCollection.cpp
--- sandbox/jng/clean_json/Common/PlatformBase/Services/FeatureSchemaCollection.cpp	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/Common/PlatformBase/Services/FeatureSchemaCollection.cpp	2017-04-19 16:00:47 UTC (rev 9157)
@@ -202,7 +202,8 @@
 void MgFeatureSchemaCollection::ToSimpleXml(std::string & str)
-    str = "<FeatureSchemaCollection xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"FeatureSchemaCollection-3.3.0.xsd\">";
+    str = "<?xml version=\"1.0\" encoding=\"utf-8\"?>";
+    str.append("<FeatureSchemaCollection xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"FeatureSchemaCollection-3.3.0.xsd\">");
     INT32 fcount = GetCount();
     for (INT32 i = 0; i < fcount; i++)
Modified: sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/describeschemaform.html
--- sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/describeschemaform.html	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/describeschemaform.html	2017-04-19 16:00:47 UTC (rev 9157)
@@ -32,6 +32,8 @@
         <p>
             Clean JSON: <input type="text" name="CLEAN" value="0" ID="TextClean">
         <p>
+            Simple: <input type="text" name="SIMPLE" value="0" ID="TextSimple">
+        <p>
         <input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
         </form>
     </body>
Modified: sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getclassdefinitionform.html
--- sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getclassdefinitionform.html	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/UnitTest/WebTier/MapAgent/MapAgentForms/getclassdefinitionform.html	2017-04-19 16:00:47 UTC (rev 9157)
@@ -32,6 +32,8 @@
         <p>
         <p>
+        <p>
         </form>
     </body>
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeSchema.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeSchema.cpp	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeSchema.cpp	2017-04-19 16:00:47 UTC (rev 9157)
@@ -41,6 +41,14 @@
     m_schemaName = params->GetParameterValue(MgHttpResourceStrings::reqFeatSchema);
     m_classNames = MgStringCollection::ParseCollection(
         params->GetParameterValue(MgHttpResourceStrings::reqFeatClassNames), L".");
+    m_bSimple = false;
+    // Get simple flag (SIMPLE)
+    STRING simple = params->GetParameterValue(MgHttpResourceStrings::reqFeatSimple);
+    if (simple.length() > 0)
+        m_bSimple = (simple == L"1");
 /// <summary>
@@ -64,13 +72,24 @@
     // Create Proxy Feature Service instance
     Ptr<MgFeatureService> service = (MgFeatureService*)(CreateService(MgServiceType::FeatureService));
-    // Call the C++ API.
-    STRING xmlSchema = service->DescribeSchemaAsXml(m_resource, m_schemaName, m_classNames);
-    // Convert to multibyte
     string mbXmlSchema;
-    MgUtil::WideCharToMultiByte(xmlSchema, mbXmlSchema);
+    if (m_bSimple)
+        // Call the C++ API.
+        Ptr<MgFeatureSchemaCollection> schemas = service->DescribeSchema(m_resource, m_schemaName, m_classNames);
+        // Get the simple XML
+        schemas->ToSimpleXml(mbXmlSchema);
+    else
+        STRING xmlSchema = service->DescribeSchemaAsXml(m_resource, m_schemaName, m_classNames);
+        // Convert to multibyte
+        MgUtil::WideCharToMultiByte(xmlSchema, mbXmlSchema);
     // Create a byte reader.
     Ptr<MgByteReader> byteReader = MgUtil::GetByteReader(mbXmlSchema, (STRING*)&MgMimeType::Xml);
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeSchema.h
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeSchema.h	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpDescribeSchema.h	2017-04-19 16:00:47 UTC (rev 9157)
@@ -47,6 +47,7 @@
     Ptr<MgResourceIdentifier> m_resource;
     STRING m_schemaName;
     Ptr<MgStringCollection> m_classNames;
+    bool m_bSimple;
 #endif // HTTPDESCRIBESCHEMA_H_
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetClassDefinition.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetClassDefinition.cpp	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetClassDefinition.cpp	2017-04-19 16:00:47 UTC (rev 9157)
@@ -36,6 +36,14 @@
     Ptr<MgHttpRequestParam> params = hRequest->GetRequestParam();
     m_resId = params->GetParameterValue(MgHttpResourceStrings::reqFeatResourceId);
 /// <summary>
@@ -66,8 +74,16 @@
     // call the C++ APIs
     Ptr<MgClassDefinition> classDef = service->GetClassDefinition(&resId, schema, className);
     string xml;
-    classDef->ToXml(xml);
+    if (m_bSimple)
+        classDef->ToSimpleXml(xml, true);
+    else
+        classDef->ToXml(xml);
     Ptr<MgByteReader> byteReader = MgUtil::GetByteReader(xml, (STRING*)&MgMimeType::Xml);
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetClassDefinition.h
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetClassDefinition.h	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpGetClassDefinition.h	2017-04-19 16:00:47 UTC (rev 9157)
@@ -45,6 +45,7 @@
 private:
     STRING  m_resId;
+    bool m_bSimple;
 #endif  // _FS_GET_CLASS_DEFINITION_H
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpResourceStrings.cpp
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpResourceStrings.cpp	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpResourceStrings.cpp	2017-04-19 16:00:47 UTC (rev 9157)
@@ -153,6 +153,7 @@
 const STRING MgHttpResourceStrings::reqFeatActiveOnly = L"ACTIVEONLY";
 const STRING MgHttpResourceStrings::reqFeatComputedProperties = L"COMPUTED_PROPERTIES";
 const STRING MgHttpResourceStrings::reqFeatComputedAliases = L"COMPUTED_ALIASES";
+const STRING MgHttpResourceStrings::reqFeatSimple = L"SIMPLE";
 // Feature Service Operation Requests
 const STRING MgHttpResourceStrings::opGetFeatureProviders = L"GETFEATUREPROVIDERS";
Modified: sandbox/jng/clean_json/Web/src/HttpHandler/HttpResourceStrings.h
--- sandbox/jng/clean_json/Web/src/HttpHandler/HttpResourceStrings.h	2017-04-19 15:27:47 UTC (rev 9156)
+++ sandbox/jng/clean_json/Web/src/HttpHandler/HttpResourceStrings.h	2017-04-19 16:00:47 UTC (rev 9157)
@@ -128,6 +128,7 @@
     static const STRING reqFeatActiveOnly;
     static const STRING reqFeatComputedProperties;
     static const STRING reqFeatComputedAliases;
+    static const STRING reqFeatSimple;
     // PREDEFINED DRAWING REQUEST PARAMETERS
     static const STRING reqDrawingResourceId;
More information about the mapguide-commits mailing list
