[mapguide-commits] r9172 - in sandbox/jng/clean_json: . Server/src/Core
svn_mapguide at osgeo.org
Sat Apr 22 09:55:27 PDT 2017
Author: jng
Date: 2017-04-22 09:55:27 -0700 (Sat, 22 Apr 2017)
New Revision: 9172
sandbox/jng/clean_json/
sandbox/jng/clean_json/Server/src/Core/Makefile.am
sandbox/jng/clean_json/configure.in
Merged revision(s) 9162-9165 from trunk/MgDev:
Update configure.in to match new baseline version numbers
Update baseline FDO version
Property changes on: sandbox/jng/clean_json
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
/branches/3.0/MgDev:8658,8705,8710
/branches/3.1/MgDev:9026,9058-9059,9067-9068
/sandbox/VC140:8684-8759
/sandbox/adsk/2.6l:8727
/sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
/sandbox/adsk/3.1n:8871,8895,8901,8912-8913,8921-8922,8942,9019-9020
/sandbox/jng/convenience_apis:8262-8268,8271-8363
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/dwftk:8321-8324,8328-8329,8331,8352
/sandbox/jng/geos34x:8256-8259
/sandbox/jng/php56x:8975-8985
/sandbox/jng/rfc155:8872-8884
/sandbox/jng/simplify:8814-9141
/sandbox/jng/tiling:8174-8208
/sandbox/jng/v30:8212-8227
/sandbox/rfc94:5099-5163
/trunk/MgDev:8818-9153
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8818-9153,9162-9165
Modified: sandbox/jng/clean_json/Server/src/Core/Makefile.am
--- sandbox/jng/clean_json/Server/src/Core/Makefile.am 2017-04-22 16:27:24 UTC (rev 9171)
+++ sandbox/jng/clean_json/Server/src/Core/Makefile.am 2017-04-22 16:55:27 UTC (rev 9172)
@@ -98,7 +98,7 @@
-ldwfcore \
-ldwftk \
-lexpat \
- -lFDO-4.1.0 \
+ -lFDO-4.2.0 \
-lExpressionEngine \
-lxalanMsg \
-lxalan-c \
Modified: sandbox/jng/clean_json/configure.in
--- sandbox/jng/clean_json/configure.in 2017-04-22 16:27:24 UTC (rev 9171)
+++ sandbox/jng/clean_json/configure.in 2017-04-22 16:55:27 UTC (rev 9172)
@@ -4,7 +4,7 @@
# Variables
# Following are the makefile directories
-AC_INIT(mapguide,3.1.0,http://mapguide.osgeo.org)
+AC_INIT(mapguide,3.3.0,http://mapguide.osgeo.org)
AC_CONFIG_SRCDIR(configure.in)
AM_INIT_AUTOMAKE
AM_INIT_AUTOMAKE([1.9 tar-pax])
@@ -85,7 +85,7 @@
AC_SUBST(httpd_src)
dnl *******************************************************
-dnl FDO 4.1.0 Configuration
+dnl FDO 4.2.0 Configuration
dnl Include / lib paths
# custom Fdo path specification
@@ -96,9 +96,9 @@
[custom_inc=DEFAULT])
if test $custom_inc = "DEFAULT"; then
- map_fdo_include="/usr/local/fdo-4.1.0/include"
+ map_fdo_include="/usr/local/fdo-4.2.0/include"
if test -d $map_fdo_include; then
- AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-4.1.0/include])
+ AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-4.2.0/include])
else
AC_MSG_ERROR([the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option])
fi
@@ -118,9 +118,9 @@
[custom_lib=DEFAULT])
if test $custom_lib = "DEFAULT"; then
- map_fdo_lib="/usr/local/fdo-4.1.0/lib"
+ map_fdo_lib="/usr/local/fdo-4.2.0/lib"
if test -d $map_fdo_lib; then
- AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-4.1.0/lib])
+ AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-4.2.0/lib])
else
AC_MSG_ERROR([the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option])
fi
@@ -132,7 +132,7 @@
AC_MSG_ERROR([the specified FDO library path $custom_lib is not a valid directory])
fi
fi
-map_fdo_nls="/usr/local/fdo-4.1.0/nls/%N"
+map_fdo_nls="/usr/local/fdo-4.2.0/nls/%N"
AC_SUBST(map_fdo_include)
AC_SUBST(map_fdo_lib)
AC_SUBST(map_fdo_nls)
More information about the mapguide-commits
