[mapguide-commits] r9262 - in sandbox/jng/cmake_v2: . Common Oem/DWFTK/develop/global/src Oem/DWFTK/develop/global/src/dwf Oem/DWFTK/develop/global/src/dwfcore
svn_mapguide at osgeo.org
Mon Dec 25 05:32:47 PST 2017
Author: jng
Date: 2017-12-25 05:32:47 -0800 (Mon, 25 Dec 2017)
New Revision: 9262
Added:
sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwf/config.h.in
sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwfcore/config.h.in
sandbox/jng/cmake_v2/CMakeLists.txt
sandbox/jng/cmake_v2/Common/CMakeLists.txt
sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/CMakeLists.txt
sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwf/CMakeLists.txt
sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt
Fix the atomic.h situation with DWFCore. Basically we need cmake to behave like a configure script so that it will generate a config.h header for dwfcore and dwftk. With this change, Renderers is now included in the CMake fold which builds and can properly link against dwfcore/dwftk
Modified: sandbox/jng/cmake_v2/CMakeLists.txt
--- sandbox/jng/cmake_v2/CMakeLists.txt 2017-12-25 01:12:07 UTC (rev 9261)
+++ sandbox/jng/cmake_v2/CMakeLists.txt 2017-12-25 13:32:47 UTC (rev 9262)
@@ -13,6 +13,11 @@
# Make CPack available to easy generate binary packages
include(CPack)
+include(CheckFunctionExists)
+include(CheckIncludeFile)
+include(CheckCXXSourceCompiles)
+include(CheckLibraryExists)
set(MG_VERSION_MAJOR 3)
set(MG_VERSION_MINOR 3)
set(MG_VERSION_RELEASE 0)
@@ -49,4 +54,4 @@
add_subdirectory(Oem)
add_subdirectory(Common)
#add_subdirectory(Server)
-#add_subdirectory(Web)
\ No newline at end of file
+#add_subdirectory(Web)
Modified: sandbox/jng/cmake_v2/Common/CMakeLists.txt
--- sandbox/jng/cmake_v2/Common/CMakeLists.txt 2017-12-25 01:12:07 UTC (rev 9261)
+++ sandbox/jng/cmake_v2/Common/CMakeLists.txt 2017-12-25 13:32:47 UTC (rev 9262)
@@ -15,6 +15,6 @@
add_subdirectory(MdfModel)
add_subdirectory(MdfParser)
#add_subdirectory(PlatformBase)
-#add_subdirectory(Renderers)
+add_subdirectory(Renderers)
add_subdirectory(Security)
-add_subdirectory(Stylization)
+add_subdirectory(Stylization)
Modified: sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/CMakeLists.txt
--- sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/CMakeLists.txt 2017-12-25 01:12:07 UTC (rev 9261)
+++ sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/CMakeLists.txt 2017-12-25 13:32:47 UTC (rev 9262)
@@ -1,7 +1,86 @@
project(dwftk)
-add_definitions(-DHAVE_MEMMOVE -DHAVE_ASM_ATOMIC_H -DDWFCORE_BUILD_ZLIB -DDWFCORE_BUILD_EXPAT -D_DWFCORE_USE_ASM_ATOMIC_H)
+add_definitions(-DDWFCORE_BUILD_ZLIB -DDWFCORE_BUILD_EXPAT)
+find_library(pthread REQUIRED)
+find_library(uuid REQUIRED)
+if (NOT uuid-NOTFOUND)
+ #add_definitions(-DHAVE_LIBUUID)
+ set (HAVE_LIBUUID 1)
+else (NOT uuid-NOTFOUND)
+ message(STATUS "Could not find libuuid")
+endif (NOT uuid-NOTFOUND)
+check_include_file(bits/stl_algobase.h HAVE_ALGOBASE_H)
+check_include_file(asm/atomic.h HAVE_ATOMIC_H)
+check_include_file(alsa/iatomic.h HAVE_IATOMIC_H)
+check_include_file(netinet/ether.h HAVE_NETINET_ETHER_H)
+#if (HAVE_NETINET_ETHER_H)
+# add_definitions(-DHAVE_NETINET_ETHER_H)
+#endif (HAVE_NETINET_ETHER_H)
+if (HAVE_ATOMIC_H)
+ check_cxx_source_compiles(
+ "#include <asm/atomic.h>
+ int main() {
+ int i = 0;
+ atomic_t tValue;
+ atomic_set( &tValue, i );
+ atomic_inc( &tValue );
+ atomic_dec( &tValue );
+ i = atomic_read( &tValue );
+ CAN_COMPILE_WITH_ATOMIC_H)
+ if (CAN_COMPILE_WITH_ATOMIC_H)
+ #add_definitions(-D_DWFCORE_USE_ASM_ATOMIC_H)
+ set (_DWFCORE_USE_ASM_ATOMIC_H 1)
+ else (CAN_COMPILE_WITH_ATOMIC_H)
+ message(WARNING "Found asm/atomic.h but could not compile with it")
+ endif (CAN_COMPILE_WITH_ATOMIC_H)
+endif (HAVE_ATOMIC_H)
+if (HAVE_IATOMIC_H)
+check_cxx_source_compiles(
+ "#include <alsa/iatomic.h>
+ int main() {
+ int i = 0;
+ atomic_t tValue;
+ CAN_COMPILE_WITH_IATOMIC_H)
+ if (CAN_COMPILE_WITH_IATOMIC_H)
+ #add_definitions(-D_DWFCORE_USE_ALSA_IATOMIC_H)
+ set (_DWFCORE_USE_ALSA_IATOMIC_H 1)
+ else (CAN_COMPILE_WITH_IATOMIC_H)
+ message(WARNING "Found alsa/atomic.h but could not compile with it")
+ endif (CAN_COMPILE_WITH_IATOMIC_H)
+endif (HAVE_IATOMIC_H)
+check_function_exists(max HAVE_MAX)
+check_function_exists(min HAVE_MIN)
+check_function_exists(memmove HAVE_MEMMOVE)
+#if (HAVE_MEMMOVE)
+# add_definitions(-DHAVE_MEMMOVE)
+#else (HAVE_MEMMOVE)
+# message(ERROR "Could not find required function memmove")
+#endif (HAVE_MEMMOVE)
+if (NOT HAVE_MEMMOVE)
+ message(ERROR "Could not find required function memmove")
+endif (NOT HAVE_MEMMOVE)
+# DWFCore's CMakeLists.txt will generate a config.h for us
+add_definitions(-DHAVE_CONFIG_H)
+# This is to ensure dwfcore/config.h will properly resolve not only for
+# DWFCore, but DWFToolkit and downstream dependencies
+include_directories(${CMAKE_CURRENT_BINARY_DIR})
set (DWF_VERSION_MAJOR 7)
set (DWF_VERSION_MINOR 7)
set (DWF_VERSION_REV 0)
Modified: sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwf/CMakeLists.txt
--- sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwf/CMakeLists.txt 2017-12-25 01:12:07 UTC (rev 9261)
+++ sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwf/CMakeLists.txt 2017-12-25 13:32:47 UTC (rev 9262)
@@ -151,4 +151,6 @@
add_library(dwftk STATIC ${dwftk_SRCS})
-target_link_libraries(dwftk dwfcore)
+target_link_libraries(dwftk dwfcore)
+configure_file(${CMAKE_CURRENT_SOURCE_DIR}/config.h.in ${CMAKE_CURRENT_BINARY_DIR}/config.h)
Added: sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwf/config.h.in
--- sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwf/config.h.in (rev 0)
+++ sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwf/config.h.in 2017-12-25 13:32:47 UTC (rev 9262)
@@ -0,0 +1,6 @@
+#ifndef DWF_CONFIG_H
+#define DWF_CONFIG_H
+// This is a config.h template used by CMake
+#endif
Modified: sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt
--- sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt 2017-12-25 01:12:07 UTC (rev 9261)
+++ sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwfcore/CMakeLists.txt 2017-12-25 13:32:47 UTC (rev 9262)
@@ -105,7 +105,18 @@
add_library(dwfcore STATIC ${dwfcore_SRCS})
-target_link_libraries(dwfcore
- dl
- pthread
+ target_link_libraries(dwfcore
+ dl
+ pthread
+ uuid
+ dl
+ pthread
Added: sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwfcore/config.h.in
--- sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwfcore/config.h.in (rev 0)
+++ sandbox/jng/cmake_v2/Oem/DWFTK/develop/global/src/dwfcore/config.h.in 2017-12-25 13:32:47 UTC (rev 9262)
@@ -0,0 +1,12 @@
+#ifndef DWFCORE_CONFIG_H
+#define DWFCORE_CONFIG_H
+#cmakedefine _DWFCORE_USE_ASM_ATOMIC_H @_DWFCORE_USE_ASM_ATOMIC_H@
+#cmakedefine _DWFCORE_USE_ALSA_IATOMIC_H @_DWFCORE_USE_ALSA_IATOMIC_H@
+#cmakedefine HAVE_MEMMOVE @HAVE_MEMMOVE@
+#cmakedefine HAVE_NETINET_ETHER_H @HAVE_NETINET_ETHER_H@
+#cmakedefine HAVE_LIBUUID @HAVE_LIBUUID@
+#endif
More information about the mapguide-commits
