[mapguide-commits] r9120 - trunk/Tools/Maestro/Maestro
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jan 20 03:23:01 PST 2017
Author: jng
Date: 2017-01-20 03:23:01 -0800 (Fri, 20 Jan 2017)
New Revision: 9120
   trunk/Tools/Maestro/Maestro/changelog.txt
Update changelog.txt
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt	2017-01-20 11:15:58 UTC (rev 9119)
+++ trunk/Tools/Maestro/Maestro/changelog.txt	2017-01-20 11:23:01 UTC (rev 9120)
@@ -3,6 +3,14 @@
  - Fix: MgCooker - InvalidCastException when editing override coordinates for a selected TileSetDefinition
  - Fix: API - Infinite recursive call in CreateMapLayer
+ - Fix: Upgrading WebLayout to >= 2.4 schema does not add MapTip command
+ - Fix: NRE adding or opening MapGroups beyond the first in Fusion editor
+ - Fix: FDO stylization functions falsely reported by expression validator as unsupported
+ - Fix: XML editor opens with trailing null characters, causing bogus content validation errors when saving
+ - Fix: Dirty state not triggered when editing most properties in a Symbol Definition
+ - Fix: Editing Fusion widget XML does not trigger dirty state
+ - Local Map Previews are now non-modal
+ - Added DockPanel themes
  - Package updates:
   - IronPython 2.7.7
   - DockPanel 2.12
More information about the mapguide-commits mailing list
