[mapguide-commits] r9233 - in sandbox/jng/coordsys_mapagent: Common/MapGuideCommon/Services Common/PlatformBase/Services Server/src/Services/Feature UnitTest/WebTier/MapAgent/MapAgentForms Web/src/HttpHandler
svn_mapguide at osgeo.org
Tue Sep 12 06:55:04 PDT 2017
Author: jng
Date: 2017-09-12 06:55:03 -0700 (Tue, 12 Sep 2017)
New Revision: 9233
sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyDataReader.cpp
sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyDataReader.h
sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp
sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyFeatureReader.h
sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp
sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h
sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp
sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxySqlDataReader.h
sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/GeometryProperty.cpp
sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/GeometryProperty.h
sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/Reader.h
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerDataReader.cpp
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerDataReader.h
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerFeatureReader.cpp
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerFeatureReader.h
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerGwsFeatureReader.cpp
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerGwsFeatureReader.h
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerSqlDataReader.cpp
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerSqlDataReader.h
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/TransformedGeometryFeatureReader.cpp
sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/TransformedGeometryFeatureReader.h
sandbox/jng/coordsys_mapagent/UnitTest/WebTier/MapAgent/MapAgentForms/selectaggregatesform.html
sandbox/jng/coordsys_mapagent/UnitTest/WebTier/MapAgent/MapAgentForms/selectfeaturesform.html
sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeatures.cpp
sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeatures.h
sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp
sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeaturesSpatially.h
sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpUtil.cpp
sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpUtil.h
sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/ReaderByteSourceImpl.cpp
sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/ReaderByteSourceImpl.h
Add support for TRANSFORMTO for the following mapagent operations:
- SELECTFEATURES
- SELECTAGGREGATES
TRANSFORMTO is a CS-Map code for a coordinate system to transform any geometry data returned by any of the above operations to.
Modified: sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyDataReader.cpp
--- sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyDataReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyDataReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -687,7 +687,7 @@
BodyStartUtf8(str);
while ( this->ReadNext() )
- CurrentToStringUtf8(str);
+ CurrentToStringUtf8(str, NULL);
BodyEndUtf8(str);
ResponseEndUtf8(str);
@@ -740,7 +740,7 @@
-void MgProxyDataReader::CurrentToStringUtf8(string& str)
+void MgProxyDataReader::CurrentToStringUtf8(string& str, MgTransform* xform)
if (NULL != (MgBatchPropertyCollection*)m_set)
@@ -748,6 +748,19 @@
INT32 cnt = propCol->GetCount();
if (propCol != NULL && cnt > 0)
+ //If xform given, attach it to any geometry properties
+ if (NULL != xform)
+ for (INT32 i = 0; i < cnt; i++)
+ Ptr<MgProperty> prop = propCol->GetItem(i);
+ if (prop->GetPropertyType() == MgPropertyType::Geometry)
+ MgGeometryProperty* geomProp = static_cast<MgGeometryProperty*>(prop.p);
+ geomProp->AttachTransform(xform);
str += "<PropertyCollection>";
propCol->ToXml(str, false);
str += "</PropertyCollection>";
Modified: sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyDataReader.h
--- sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyDataReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyDataReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -593,7 +593,7 @@
/// \param str
/// Destination string.
- void CurrentToStringUtf8(string& str);
+ void CurrentToStringUtf8(string& str, MgTransform* xform);
/// \brief
Modified: sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp
--- sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -838,7 +838,7 @@
BodyStartUtf8(str);
BodyEndUtf8(str);
@@ -893,7 +893,7 @@
-void MgProxyFeatureReader::CurrentToStringUtf8(string& str)
+void MgProxyFeatureReader::CurrentToStringUtf8(string& str, MgTransform* xform)
if (NULL != (MgFeatureSet*)m_set)
@@ -901,6 +901,19 @@
propCol->ToFeature(str);
Modified: sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyFeatureReader.h
--- sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyFeatureReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyFeatureReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -566,7 +566,7 @@
/// \param str
/// \brief
Modified: sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp
--- sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -773,7 +773,7 @@
BodyStartUtf8(str);
BodyEndUtf8(str);
@@ -828,7 +828,7 @@
-void MgProxyGwsFeatureReader::CurrentToStringUtf8(string& str)
+void MgProxyGwsFeatureReader::CurrentToStringUtf8(string& str, MgTransform* xform)
@@ -836,6 +836,19 @@
Modified: sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h
--- sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -540,7 +540,7 @@
/// \param str
/// \brief
Modified: sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp
--- sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -685,7 +685,7 @@
BodyStartUtf8(str);
BodyEndUtf8(str);
@@ -738,7 +738,7 @@
-void MgProxySqlDataReader::CurrentToStringUtf8(string& str)
+void MgProxySqlDataReader::CurrentToStringUtf8(string& str, MgTransform* xform)
@@ -746,6 +746,19 @@
propCol->ToRow(str);
Modified: sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxySqlDataReader.h
--- sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxySqlDataReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/MapGuideCommon/Services/ProxySqlDataReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -563,7 +563,7 @@
/// \param str
/// \brief
Modified: sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/GeometryProperty.cpp
--- sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/GeometryProperty.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/GeometryProperty.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -47,6 +47,7 @@
MgGeometryProperty::MgGeometryProperty()
m_value = NULL;
+ m_xform = NULL;
@@ -133,7 +134,7 @@
if (byteReader != NULL)
MgAgfReaderWriter agfReader;
- Ptr<MgGeometry> geom = agfReader.Read(byteReader);
+ Ptr<MgGeometry> geom = agfReader.Read(byteReader, m_xform);
// geom->ToXml(str); // TODO: we need this method
STRING awktStr = L"";
@@ -195,3 +196,8 @@
m_value = stream->GetStream();
+void MgGeometryProperty::AttachTransform(MgTransform* xform)
+ m_xform = SAFE_ADDREF(xform);
\ No newline at end of file
Modified: sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/GeometryProperty.h
--- sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/GeometryProperty.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/GeometryProperty.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -170,6 +170,15 @@
virtual void Deserialize(MgStream* stream);
+ /// \brief
+ /// Attaches the given transform.
+ /// \param xform
+ /// Transform
+ void AttachTransform(MgTransform* xform);
protected:
@@ -200,6 +209,7 @@
private:
Ptr<MgByteReader> m_value;
+ Ptr<MgTransform> m_xform;
CLASS_ID:
static const INT32 m_cls_id = PlatformBase_FeatureService_GeometryProperty;
Modified: sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/Reader.h
--- sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/Reader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Common/PlatformBase/Services/Reader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -1216,7 +1216,7 @@
/// \param str
- virtual void CurrentToStringUtf8(string& str) = 0;
+ virtual void CurrentToStringUtf8(string& str, MgTransform* xform) = 0;
/// \brief
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerDataReader.cpp
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerDataReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerDataReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -1554,7 +1554,7 @@
__LINE__, __WFILE__, NULL, L"", NULL);
-void MgServerDataReader::CurrentToStringUtf8(string& str)
+void MgServerDataReader::CurrentToStringUtf8(string& str, MgTransform* xform)
throw new MgInvalidOperationException(L"MgServerDataReader.CurrentToStringUtf8",
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerDataReader.h
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerDataReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerDataReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -514,7 +514,7 @@
/// \param str
/// <summary>
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerFeatureReader.cpp
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerFeatureReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerFeatureReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -974,7 +974,7 @@
-void MgServerFeatureReader::CurrentToStringUtf8(string& str)
+void MgServerFeatureReader::CurrentToStringUtf8(string& str, MgTransform* xform)
throw new MgInvalidOperationException(L"MgServerFeatureReader.CurrentToStringUtf8",
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerFeatureReader.h
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerFeatureReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerFeatureReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -479,7 +479,7 @@
/// \param str
/// <summary>
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerGwsFeatureReader.cpp
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerGwsFeatureReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerGwsFeatureReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -1276,7 +1276,7 @@
-void MgServerGwsFeatureReader::CurrentToStringUtf8(string& str)
+void MgServerGwsFeatureReader::CurrentToStringUtf8(string& str, MgTransform* xform)
throw new MgInvalidOperationException(L"MgServerGwsFeatureReader.CurrentToStringUtf8",
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerGwsFeatureReader.h
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerGwsFeatureReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerGwsFeatureReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -471,7 +471,7 @@
/// \param str
/// <summary>
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerSqlDataReader.cpp
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerSqlDataReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerSqlDataReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -1394,7 +1394,7 @@
-void MgServerSqlDataReader::CurrentToStringUtf8(string& str)
+void MgServerSqlDataReader::CurrentToStringUtf8(string& str, MgTransform* xform)
throw new MgInvalidOperationException(L"MgServerSqlDataReader.CurrentToStringUtf8",
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerSqlDataReader.h
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerSqlDataReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/ServerSqlDataReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -489,7 +489,7 @@
/// \param str
/// <summary>
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/TransformedGeometryFeatureReader.cpp
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/TransformedGeometryFeatureReader.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/TransformedGeometryFeatureReader.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -378,9 +378,9 @@
m_innerReader->BodyEndUtf8(str);
-void MgTransformedGeometryFeatureReader::CurrentToStringUtf8(string& str)
+void MgTransformedGeometryFeatureReader::CurrentToStringUtf8(string& str, MgTransform* xform)
- m_innerReader->CurrentToStringUtf8(str);
+ m_innerReader->CurrentToStringUtf8(str, xform);
void MgTransformedGeometryFeatureReader::HeaderToStringUtf8(string& str)
Modified: sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/TransformedGeometryFeatureReader.h
--- sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/TransformedGeometryFeatureReader.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Server/src/Services/Feature/TransformedGeometryFeatureReader.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -439,7 +439,7 @@
/// \param str
/// <summary>
Modified: sandbox/jng/coordsys_mapagent/UnitTest/WebTier/MapAgent/MapAgentForms/selectaggregatesform.html
--- sandbox/jng/coordsys_mapagent/UnitTest/WebTier/MapAgent/MapAgentForms/selectaggregatesform.html 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/UnitTest/WebTier/MapAgent/MapAgentForms/selectaggregatesform.html 2017-09-12 13:55:03 UTC (rev 9233)
@@ -39,6 +39,8 @@
Clean JSON: <input type="text" name="CLEAN" value="0" ID="TextClean">
<p> Coordinate Precision (if requesting clean JSON):
<input type="text" name="PRECISION" value="7" size="10">
+ <p> Transform to (CS-Map code):
+ <input type="text" name="TRANSFORMTO">
<p>
<input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
</form>
Modified: sandbox/jng/coordsys_mapagent/UnitTest/WebTier/MapAgent/MapAgentForms/selectfeaturesform.html
--- sandbox/jng/coordsys_mapagent/UnitTest/WebTier/MapAgent/MapAgentForms/selectfeaturesform.html 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/UnitTest/WebTier/MapAgent/MapAgentForms/selectfeaturesform.html 2017-09-12 13:55:03 UTC (rev 9233)
@@ -39,6 +39,8 @@
<p>
</form>
Modified: sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeatures.cpp
--- sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeatures.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeatures.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -55,6 +55,11 @@
m_bEnablePrecision = true;
+ // Get transform flag (TRANSFORMTO). Only recognize this flag for 3.3.0 and above
+ if (m_userInfo->GetApiVersion() >= MG_API_VERSION(3, 3, 0))
+ m_transformTo = params->GetParameterValue(MgHttpResourceStrings::reqGeoTransformTo);
/// <summary>
@@ -123,8 +128,17 @@
Ptr<MgFeatureReader> featureReader = service->SelectFeatures(&resId, m_className, qryOptions);
//MgByteSource owns this and will clean it up when done
- ByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(featureReader, m_responseFormat, m_bCleanJson, m_bEnablePrecision, m_precision);
+ Ptr<MgTransform> xform;
+ if (!m_transformTo.empty())
+ STRING schemaName;
+ STRING className;
+ MgUtil::ParseQualifiedClassName(m_className, schemaName, className);
+ xform = MgHttpUtil::GetTransform(service, &resId, schemaName, className, m_transformTo);
+ ByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(featureReader, m_responseFormat, m_bCleanJson, m_bEnablePrecision, m_precision, xform);
Ptr<MgByteSource> byteSource = new MgByteSource(bsImpl);
byteSource->SetMimeType(m_responseFormat);
Ptr<MgByteReader> byteReader = byteSource->GetReader();
Modified: sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeatures.h
--- sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeatures.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeatures.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -48,6 +48,7 @@
STRING m_className;
INT32 m_precision;
bool m_bEnablePrecision;
+ STRING m_transformTo;
#endif // _FS_SELECT_FEATURES_H
Modified: sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp
--- sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeaturesSpatially.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -65,6 +65,12 @@
/// <summary>
@@ -133,8 +139,17 @@
Ptr<MgDataReader> dataReader = service->SelectAggregate(&resId, m_className, qryOptions);
- ByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(dataReader, m_responseFormat, m_bCleanJson, m_bEnablePrecision, m_precision);
+ STRING className;
+ ByteSourceImpl* bsImpl = new MgReaderByteSourceImpl(dataReader, m_responseFormat, m_bCleanJson, m_bEnablePrecision, m_precision, xform);
Modified: sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeaturesSpatially.h
--- sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeaturesSpatially.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpSelectFeaturesSpatially.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -51,6 +51,7 @@
INT32 m_operation;
INT32 m_precision;
#endif // _FS_SELECT_FEATURES_SPATIALLY_H
Modified: sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpUtil.cpp
--- sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpUtil.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpUtil.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -86,3 +86,48 @@
+MgTransform* MgHttpUtil::GetTransform(MgFeatureService* featSvc, MgResourceIdentifier* resId, CREFSTRING schemaName, CREFSTRING className, CREFSTRING transformTo)
+ Ptr<MgTransform> transform;
+ MG_HTTP_HANDLER_TRY()
+ Ptr<MgCoordinateSystemFactory> factory = new MgCoordinateSystemFactory();
+ STRING targetWkt = factory->ConvertCoordinateSystemCodeToWkt(transformTo);
+ Ptr<MgClassDefinition> clsDef = featSvc->GetClassDefinition(resId, schemaName, className);
+ //Has a designated geometry property, use it's spatial context
+ if (!clsDef->GetDefaultGeometryPropertyName().empty())
+ Ptr<MgPropertyDefinitionCollection> props = clsDef->GetProperties();
+ INT32 idx = props->IndexOf(clsDef->GetDefaultGeometryPropertyName());
+ if (idx >= 0)
+ Ptr<MgPropertyDefinition> pd = props->GetItem(idx);
+ if (pd->GetPropertyType() == MgFeaturePropertyType::GeometricProperty)
+ MgGeometricPropertyDefinition* geomProp = static_cast<MgGeometricPropertyDefinition*>(pd.p);
+ STRING scName = geomProp->GetSpatialContextAssociation();
+ Ptr<MgSpatialContextReader> scReader = featSvc->GetSpatialContexts(resId, false);
+ while (scReader->ReadNext())
+ if (scReader->GetName() == scName)
+ if (scReader->GetCoordinateSystemWkt() != targetWkt)
+ Ptr<MgCoordinateSystem> targetCs = factory->CreateFromCode(transformTo);
+ Ptr<MgCoordinateSystem> sourceCs = factory->Create(scReader->GetCoordinateSystemWkt());
+ transform = factory->GetTransform(sourceCs, targetCs);
+ break;
+ scReader->Close();
+ MG_HTTP_HANDLER_CATCH_AND_THROW(L"MgHttpUtil::GetTransform")
+ return transform.Detach();
Modified: sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpUtil.h
--- sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpUtil.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/HttpUtil.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -73,6 +73,8 @@
~MgHttpUtil();
static void LogException(MgException* exception);
+ static MgTransform* GetTransform(MgFeatureService* featSvc, MgResourceIdentifier* resId, CREFSTRING schemaName, CREFSTRING className, CREFSTRING transformTo);
#endif
Modified: sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/ReaderByteSourceImpl.cpp
--- sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/ReaderByteSourceImpl.cpp 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/ReaderByteSourceImpl.cpp 2017-09-12 13:55:03 UTC (rev 9233)
@@ -17,7 +17,7 @@
#include "ReaderByteSourceImpl.h"
#include "PlatformBase.h"
-MgReaderByteSourceImpl::MgReaderByteSourceImpl(MgReader* reader, CREFSTRING format, bool bCleanJson, bool bEnablePrecision, INT32 precision)
+MgReaderByteSourceImpl::MgReaderByteSourceImpl(MgReader* reader, CREFSTRING format, bool bCleanJson, bool bEnablePrecision, INT32 precision, MgTransform* xform)
m_reader = SAFE_ADDREF(reader);
m_format = format;
@@ -29,6 +29,7 @@
m_bCleanJson = bCleanJson;
m_bEnablePrecision = bEnablePrecision;
m_precision = precision;
MgReaderByteSourceImpl::~MgReaderByteSourceImpl()
@@ -38,6 +39,7 @@
m_reader->Close();
MG_CATCH_AND_RELEASE()
m_reader = NULL;
+ m_xform = NULL;
@@ -175,11 +177,11 @@
if (m_reader->GetReaderType() == MgReaderType::FeatureReader)
MgFeatureReader* fr = static_cast<MgFeatureReader*>(m_reader.p);
- sGeoJson = geoJsonWriter.FeatureToGeoJson(fr, NULL);
+ sGeoJson = geoJsonWriter.FeatureToGeoJson(fr, m_xform);
else
- sGeoJson = geoJsonWriter.FeatureToGeoJson(m_reader, NULL, L"", L"");
+ sGeoJson = geoJsonWriter.FeatureToGeoJson(m_reader, m_xform, L"", L"");
if (!m_bFirstRecord)
@@ -194,7 +196,7 @@
else
- m_reader->CurrentToStringUtf8(buf);
+ m_reader->CurrentToStringUtf8(buf, m_xform);
//The body is a valid full XML element, so no need for gymnastics like its
//surrounding elements
MgXmlJsonConvert convert;
@@ -230,7 +232,7 @@
#ifdef _DEBUG
m_buf += "<!-- BEGIN RECORD -->\n";
#endif
- m_reader->CurrentToStringUtf8(m_buf);
+ m_reader->CurrentToStringUtf8(m_buf, m_xform);
#ifdef _DEBUG
m_buf += "<!-- END RECORD -->\n";
#endif
Modified: sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/ReaderByteSourceImpl.h
--- sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/ReaderByteSourceImpl.h 2017-08-21 07:14:10 UTC (rev 9232)
+++ sandbox/jng/coordsys_mapagent/Web/src/HttpHandler/ReaderByteSourceImpl.h 2017-09-12 13:55:03 UTC (rev 9233)
@@ -29,7 +29,7 @@
DECLARE_CLASSNAME(MgReaderByteSourceImpl)
public:
- MgReaderByteSourceImpl(MgReader* reader, CREFSTRING format, bool bCleanJson, bool bEnablePrecision, INT32 precision);
+ MgReaderByteSourceImpl(MgReader* reader, CREFSTRING format, bool bCleanJson, bool bEnablePrecision, INT32 precision, MgTransform* xform);
virtual ~MgReaderByteSourceImpl();
@@ -84,6 +84,7 @@
INT32 ReadInternalBuffer(BYTE_ARRAY_OUT buffer, INT32 fromIndex, INT32 length);
Ptr<MgReader> m_reader;
STRING m_format;
bool m_bCleanJson;
bool m_bReadHeader;
More information about the mapguide-commits
