[mapguide-commits] r9322 - in branches/3.1/MgDev: . Oem/LinuxApt
svn_mapguide at osgeo.org
Wed Feb 28 06:31:59 PST 2018
Author: jng
Date: 2018-02-28 06:31:57 -0800 (Wed, 28 Feb 2018)
New Revision: 9322
Added:
branches/3.1/MgDev/Oem/LinuxApt/apache-tomcat-7.0.82.tar.gz
branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29-deps.tar.bz2
branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29.tar.bz2
branches/3.1/MgDev/Oem/LinuxApt/php-5.6.33.tar.bz2
branches/3.1/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.42-src.tar.gz
Removed:
branches/3.1/MgDev/Oem/LinuxApt/apache-tomcat-7.0.68.tar.gz
branches/3.1/MgDev/Oem/LinuxApt/apr-1.5.2.tar.bz2
branches/3.1/MgDev/Oem/LinuxApt/apr-util-1.5.4.tar.bz2
branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.18.tar.bz2
branches/3.1/MgDev/Oem/LinuxApt/php-5.6.23.tar.bz2
branches/3.1/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.41-src.tar.gz
branches/3.1/MgDev/Oem/LinuxApt/build_apt.sh
branches/3.1/MgDev/configure.in
branches/3.1/MgDev/prepare_webtier_components.bat
#2774: Update LinuxApt tarballs
Deleted: branches/3.1/MgDev/Oem/LinuxApt/apache-tomcat-7.0.68.tar.gz
(Binary files differ)
Added: branches/3.1/MgDev/Oem/LinuxApt/apache-tomcat-7.0.82.tar.gz
Index: branches/3.1/MgDev/Oem/LinuxApt/apache-tomcat-7.0.82.tar.gz
--- branches/3.1/MgDev/Oem/LinuxApt/apache-tomcat-7.0.82.tar.gz 2018-02-17 06:31:59 UTC (rev 9321)
+++ branches/3.1/MgDev/Oem/LinuxApt/apache-tomcat-7.0.82.tar.gz 2018-02-28 14:31:57 UTC (rev 9322)
Property changes on: branches/3.1/MgDev/Oem/LinuxApt/apache-tomcat-7.0.82.tar.gz
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Deleted: branches/3.1/MgDev/Oem/LinuxApt/apr-1.5.2.tar.bz2
Deleted: branches/3.1/MgDev/Oem/LinuxApt/apr-util-1.5.4.tar.bz2
Modified: branches/3.1/MgDev/Oem/LinuxApt/build_apt.sh
--- branches/3.1/MgDev/Oem/LinuxApt/build_apt.sh 2018-02-17 06:31:59 UTC (rev 9321)
+++ branches/3.1/MgDev/Oem/LinuxApt/build_apt.sh 2018-02-28 14:31:57 UTC (rev 9322)
@@ -15,12 +15,10 @@
INSTALLDIR=/usr/local/mapguideopensource
-HTTPD_VER=2.4.18
-PHP_VER=5.6.23
-TOMCAT_VER=7.0.68
-CONNECTOR_VER=1.2.41
-APR_VER=1.5.2
-APR_UTIL_VER=1.5.4
+HTTPD_VER=2.4.29
+PHP_VER=5.6.33
+TOMCAT_VER=7.0.82
+CONNECTOR_VER=1.2.42
PORT=8008
TOMCAT=0
TOMCAT_PORT=8009
@@ -147,14 +145,7 @@
echo "Apache Httpd build started"
tar -jxf httpd-$HTTPD_VER.tar.bz2
-if [ ! -d "httpd-$HTTPD_VER/srclib/apr" ]; then
- tar -jxf apr-$APR_VER.tar.bz2
- mv apr-$APR_VER httpd-$HTTPD_VER/srclib/apr
-fi
-if [ ! -d "httpd-$HTTPD_VER/srclib/aprutil" ]; then
- tar -jxf apr-util-$APR_UTIL_VER.tar.bz2
- mv apr-util-$APR_UTIL_VER httpd-$HTTPD_VER/srclib/apr-util
-fi
+tar -jxf httpd-$HTTPD_VER-deps.tar.bz2
pushd httpd-$HTTPD_VER
./configure --prefix=$INSTALLWEB/apache2 --enable-mods-shared=all \
--with-included-apr --with-port=$PORT
Deleted: branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.18.tar.bz2
Added: branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29-deps.tar.bz2
Index: branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29-deps.tar.bz2
--- branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29-deps.tar.bz2 2018-02-17 06:31:59 UTC (rev 9321)
+++ branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29-deps.tar.bz2 2018-02-28 14:31:57 UTC (rev 9322)
Property changes on: branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29-deps.tar.bz2
## -0,0 +1 ##
Added: branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29.tar.bz2
Index: branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29.tar.bz2
--- branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29.tar.bz2 2018-02-17 06:31:59 UTC (rev 9321)
+++ branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29.tar.bz2 2018-02-28 14:31:57 UTC (rev 9322)
Property changes on: branches/3.1/MgDev/Oem/LinuxApt/httpd-2.4.29.tar.bz2
## -0,0 +1 ##
Deleted: branches/3.1/MgDev/Oem/LinuxApt/php-5.6.23.tar.bz2
Added: branches/3.1/MgDev/Oem/LinuxApt/php-5.6.33.tar.bz2
Index: branches/3.1/MgDev/Oem/LinuxApt/php-5.6.33.tar.bz2
--- branches/3.1/MgDev/Oem/LinuxApt/php-5.6.33.tar.bz2 2018-02-17 06:31:59 UTC (rev 9321)
+++ branches/3.1/MgDev/Oem/LinuxApt/php-5.6.33.tar.bz2 2018-02-28 14:31:57 UTC (rev 9322)
Property changes on: branches/3.1/MgDev/Oem/LinuxApt/php-5.6.33.tar.bz2
## -0,0 +1 ##
Deleted: branches/3.1/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.41-src.tar.gz
Added: branches/3.1/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.42-src.tar.gz
Index: branches/3.1/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.42-src.tar.gz
--- branches/3.1/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.42-src.tar.gz 2018-02-17 06:31:59 UTC (rev 9321)
+++ branches/3.1/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.42-src.tar.gz 2018-02-28 14:31:57 UTC (rev 9322)
Property changes on: branches/3.1/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.42-src.tar.gz
## -0,0 +1 ##
Modified: branches/3.1/MgDev/configure.in
--- branches/3.1/MgDev/configure.in 2018-02-17 06:31:59 UTC (rev 9321)
+++ branches/3.1/MgDev/configure.in 2018-02-28 14:31:57 UTC (rev 9322)
@@ -39,7 +39,7 @@
map_opt_oem_distsubdirs=""
dnl *******************************************************
-dnl PHP 5.6.23 Configuration
+dnl PHP 5.6.33 Configuration
AC_ARG_WITH([php],
MAP_HELP_STRING([--with-php],
@@ -48,8 +48,8 @@
[with_php=no])
if test $with_php = "no"; then
- AC_MSG_NOTICE([Using php 5.6.23 from included Oem Directory])
- php_src=`pwd`/Oem/LinuxApt/php-5.6.23
+ AC_MSG_NOTICE([Using php 5.6.33 from included Oem Directory])
+ php_src=`pwd`/Oem/LinuxApt/php-5.6.33
else
AC_MSG_NOTICE([Using custom PHP source directory])
php_src=$with_php
@@ -62,7 +62,7 @@
AC_SUBST(php_src)
-dnl httpd 2.4.18 Configuration
+dnl httpd 2.4.29 Configuration
AC_ARG_WITH([httpd],
MAP_HELP_STRING([--with-httpd],
@@ -71,8 +71,8 @@
[with_httpd=no])
if test $with_httpd = "no"; then
- AC_MSG_NOTICE([Using httpd 2.4.18 from included Oem Directory])
- httpd_src=`pwd`/Oem/LinuxApt/httpd-2.4.18
+ AC_MSG_NOTICE([Using httpd 2.4.29 from included Oem Directory])
+ httpd_src=`pwd`/Oem/LinuxApt/httpd-2.4.29
else
AC_MSG_NOTICE([Using custom httpd source directory])
httpd_src=$with_httpd
Modified: branches/3.1/MgDev/prepare_webtier_components.bat
--- branches/3.1/MgDev/prepare_webtier_components.bat 2018-02-17 06:31:59 UTC (rev 9321)
+++ branches/3.1/MgDev/prepare_webtier_components.bat 2018-02-28 14:31:57 UTC (rev 9322)
@@ -1,7 +1,7 @@
@echo off
SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
-SET HTTPD_VER=2.4.18
-SET PHP_VER=5.6.23
+SET HTTPD_VER=2.4.29
+SET PHP_VER=5.6.33
pushd Oem\LinuxApt
:check_httpd
if not exist httpd-%HTTPD_VER% goto unpack_httpd
More information about the mapguide-commits
