[mapguide-commits] r9319 - trunk/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Jan 30 04:48:41 PST 2018
Author: jng
Date: 2018-01-30 04:48:40 -0800 (Tue, 30 Jan 2018)
New Revision: 9319
   trunk/MgDev/CMake_README.txt
   trunk/MgDev/cmake_bootstrap.sh
   trunk/MgDev/cmake_build.sh
Consistency: Use hyphens instead of underscores for all cmake build script parameters
Modified: trunk/MgDev/CMake_README.txt
--- trunk/MgDev/CMake_README.txt	2018-01-24 12:38:11 UTC (rev 9318)
+++ trunk/MgDev/CMake_README.txt	2018-01-30 12:48:40 UTC (rev 9319)
@@ -36,7 +36,7 @@
 2. Build the internal thirdparty components specifying the directory where thirdparty components will be built in
-    sudo ./cmake_bootstrap.sh --oem_working_dir ~/mapguide_oem_build
+    sudo ./cmake_bootstrap.sh --oem-working_dir ~/mapguide_oem_build
    This will copy the DBXML, httpd, PHP and the Tomcat connector sources to your specified directory and build it from there.
    Once completed, an env_vars.sh script will be written to this directory that the following step will use.
@@ -46,10 +46,10 @@
 3. Start the main CMake build
-    ./cmake_build.sh --oem_working_dir ~/mapguide_oem_build --cmake_build_dir ~/mapguide_build_area
+    ./cmake_build.sh --oem-working-dir ~/mapguide_oem_build --cmake-build-dir ~/mapguide_build_area
    This will set up the CMake build using the generated env_vars.sh script and set up a CMake build tree in the directory specified
-   by --cmake_build_dir
+   by --cmake-build-dir
 4. Install the MapGuide binaries. This will generally require elevation (with sudo) as well.
Modified: trunk/MgDev/cmake_bootstrap.sh
--- trunk/MgDev/cmake_bootstrap.sh	2018-01-24 12:38:11 UTC (rev 9318)
+++ trunk/MgDev/cmake_bootstrap.sh	2018-01-30 12:48:40 UTC (rev 9319)
@@ -14,7 +14,7 @@
             MG_INST_PREFIX="$2"
             shift
-        --oem_working_dir)
+        --oem-working-dir)
             OEM_WORK_DIR="$2"
             shift
@@ -33,7 +33,7 @@
             echo "Usage: $0 (options)"
             echo "Options:"
             echo "  --prefix [install prefix]"
-            echo "  --oem_working_dir [installation directory]"
+            echo "  --oem-working-dir [installation directory]"
             echo "  --build [32(default)|64]"
             echo "  --config [Release(default)|Debug]"
             echo "  --have-system-xerces [Use system-installed xerces]"
Modified: trunk/MgDev/cmake_build.sh
--- trunk/MgDev/cmake_build.sh	2018-01-24 12:38:11 UTC (rev 9318)
+++ trunk/MgDev/cmake_build.sh	2018-01-30 12:48:40 UTC (rev 9319)
@@ -11,11 +11,11 @@
 USE_ASAN=OFF
 while [ $# -gt 0 ]; do    # Until you run out of parameters...
     case "$1" in
-        --cmake_build_dir)
+        --cmake-build-dir)
             CMAKE_BUILD_DIR="$2"
             shift
             OEM_WORK_DIR="$2"
             shift
@@ -28,8 +28,8 @@
         --help)
             echo "Options:"
-            echo "  --cmake_build_dir [CMake build directory]"
+            echo "  --cmake-build-dir [CMake build directory]"
             echo "  --with-asan [build with ASAN]"
             echo "  --ninja [Use ninja build system]"
             echo "  --help [Display usage]"
More information about the mapguide-commits mailing list
