[mapguide-commits] r9393 - in branches/3.1/MgDev: Common/Foundation Common/Foundation/Data Common/Foundation/System Common/MapGuideCommon Common/MapGuideCommon/Services Common/PlatformBase/MapLayer Oem/SQLite/src/SQLitePhpApi Oem/SWIGEx Oem/SWIGEx/Source/Modules Oem/SWIGEx/Win32 Oem/php Web/src/DotNetUnmanagedApi/Foundation Web/src/DotNetUnmanagedApi/Geometry Web/src/DotNetUnmanagedApi/MapGuideCommon Web/src/DotNetUnmanagedApi/PlatformBase Web/src/DotNetUnmanagedApi/Web Web/src/JavaApi Web/src/JavaApiEx Web/src/MapGuideApi Web/src/PhpApi Web/src/WebApp
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Jun 2 08:49:47 PDT 2018
Author: jng
Date: 2018-06-02 08:49:46 -0700 (Sat, 02 Jun 2018)
New Revision: 9393
Added:
   branches/3.1/MgDev/Oem/SWIGEx/SwigEx.vcxproj
   branches/3.1/MgDev/Oem/SWIGEx/SwigEx.vcxproj.filters
Removed:
   branches/3.1/MgDev/Oem/php/TSRM/
   branches/3.1/MgDev/Common/Foundation/Data/ByteSink.h
   branches/3.1/MgDev/Common/Foundation/Foundation.h
   branches/3.1/MgDev/Common/Foundation/System/GuardDisposable.h
   branches/3.1/MgDev/Common/MapGuideCommon/MapGuideCommon.h
   branches/3.1/MgDev/Common/MapGuideCommon/Services/SiteConnection.h
   branches/3.1/MgDev/Common/MapGuideCommon/Services/SiteManager.h
   branches/3.1/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
   branches/3.1/MgDev/Oem/SQLite/src/SQLitePhpApi/SQLitePhpApi.vcxproj
   branches/3.1/MgDev/Oem/SWIGEx/Source/Modules/csharp.cxx
   branches/3.1/MgDev/Oem/SWIGEx/SwigEx.sln
   branches/3.1/MgDev/Oem/SWIGEx/Win32/Swig.exe
   branches/3.1/MgDev/Oem/php/PROVENANCE.TXT
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApi.vcxproj
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApi.vcxproj
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApi.vcxproj
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApi.vcxproj
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApi.vcxproj
   branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
   branches/3.1/MgDev/Web/src/JavaApi/JavaApi.vcxproj
   branches/3.1/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj
   branches/3.1/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml
   branches/3.1/MgDev/Web/src/PhpApi/PhpApi.vcxproj
   branches/3.1/MgDev/Web/src/WebApp/WebApp.h
   branches/3.1/MgDev/Web/src/WebApp/WebLayout.h
Introduce a new preprocessor symbol SWIG_PUBLIC_API
With this symbol, we #ifdef out and forward-declare as much of ACE and xerces types and headers in our MapGuide common headers. The only ACE header that is leaked out now is the header for ACE_Recursive_Thread_Mutex as that is present as member of several classes in the public MapGuide API surface.
In our SWIG binding projects, SWIG_PUBLIC_API is defined. All other consuming projects do not define this symbol so they see the original set of ACE and xerces headers.
This change slightly breaks the SWIG C++ glue code for .net (which used un-qualified list), so our internal copy of SWIG is updated to use fully qualified list (std::list) and our various SWIG parameter files include the <list> header.
This change eliminates the need for us to maintain a patched copy of TSRM/readdir.h for PHP, so that is removed.
Fixes #2781
Modified: branches/3.1/MgDev/Common/Foundation/Data/ByteSink.h
--- branches/3.1/MgDev/Common/Foundation/Data/ByteSink.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Common/Foundation/Data/ByteSink.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -18,6 +18,8 @@
 #ifndef MG_BYTE_SINK_H
 #define MG_BYTE_SINK_H
+class ACE_SOCK_Stream;
 /// \defgroup MgByteSink MgByteSink
 /// \ingroup Common_Module
Modified: branches/3.1/MgDev/Common/Foundation/Foundation.h
--- branches/3.1/MgDev/Common/Foundation/Foundation.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Common/Foundation/Foundation.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -45,6 +45,16 @@
 // ignore warnings about using deprecated methods
 #pragma warning(disable: 4996)
+// Unfortunately, we must leak this header out in a SWIG generation context as ACE_Recursive_Thread_Mutex
+// is a private and public member of several classes thare are exported out to the public MapGuide API
+// surface area (MgGuardDisposable/MgSiteManager)
+// Every other ACE type/header however are internal implementation details that can be safely walled-off
+// with SWIG_PUBLIC_API or forward-declared away to reduce the ACE header surface area to this one single
+// header below
+#include "ace/Recursive_Thread_Mutex.h"
+#ifndef SWIG_PUBLIC_API
 #include "ace/Init_ACE.h"
 #include "ace/INET_Addr.h"
@@ -71,7 +81,7 @@
 #include "ace/Configuration_Import_Export.h"
 #include "ace/Process_Manager.h"
 #include "ace/Date_Time.h"
+#endif
 #undef GetObject
 #include "FoundationDefs.h"
 #include "System/FoundationClassId.h"
@@ -90,6 +100,7 @@
 #include "Data/ByteSource.h"
 #include "Data/ByteSink.h"
 #include "System/PacketStructure.h"
 #include "System/StreamData.h"
 #include "System/PacketParser.h"
@@ -101,6 +112,7 @@
 #include "System/StreamWriter.h"
 #include "System/Stream.h"
 #include "System/StreamParser.h"
+#endif
 #include "../MdfModel/UnicodeString.h"
 #include "Data/Collection.h"
@@ -118,12 +130,13 @@
 #include "System/FoundationConfigProperties.h"
 #include "System/FileUtil.h"
 #include "System/Util.h"
 #include "System/ConfigurationSection.h"
 #include "System/ConfigurationSectionCollection.h"
 #include "System/ConfigurationHeap.h"
 #include "System/Configuration.h"
 #include "System/Resources.h"
+#endif
 // Base exception classes and defines
 #include "Exception/ExceptionDefs.h"
@@ -181,6 +194,7 @@
 #include "Exception/XmlParserException.h"
 #include "System/ByteSourceFileImpl.h"
 #include "System/ByteSourceMemoryImpl.h"
@@ -227,4 +241,6 @@
     static const int MG_MSG_NOSIGNAL = MSG_NOSIGNAL;
 #endif
+#endif /* SWIG_PUBLIC_API */
 #endif
Modified: branches/3.1/MgDev/Common/Foundation/System/GuardDisposable.h
--- branches/3.1/MgDev/Common/Foundation/System/GuardDisposable.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Common/Foundation/System/GuardDisposable.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -18,7 +18,7 @@
 #ifndef _MGGUARDDISPOSABLE_H_
 #define _MGGUARDDISPOSABLE_H_
-#include "ace/Process_Manager.h"
+class ACE_Recursive_Thread_Mutex;
 /// \cond INTERNAL
Modified: branches/3.1/MgDev/Common/MapGuideCommon/MapGuideCommon.h
--- branches/3.1/MgDev/Common/MapGuideCommon/MapGuideCommon.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Common/MapGuideCommon/MapGuideCommon.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -53,10 +53,13 @@
 #include "System/MapGuideCommonClassId.h"
 #include "System/ConfigProperties.h"
 #include "System/UserInformation.h"
 #include "System/MapGuideStream.h"
 #include "System/CryptographyManager.h"
 #include "Util/IpUtil.h"
 #include "Util/TimerUtil.h"
+#endif
 #include "MapLayer/Layer.h"
 #include "MapLayer/Map.h"
@@ -121,8 +124,10 @@
 #include "Exception/UnsupportedProviderThreadModelException.h"
 #include "Exception/UriFormatException.h"
 #include "Net/IOperationHandler.h"
 #include "Services/Command.h"
+#endif
 #include "Services/Site.h"
 #include "Services/SiteInfo.h"
 #include "Services/SiteManager.h"
@@ -169,9 +174,11 @@
 #include "Services/ServerAdmin.h"
 #include "Services/ServerAdminDefs.h"
 #include "Services/ServerConnection.h"
 #include "Services/ServerConnectionImp.h"
 #include "Services/ServerConnectionPool.h"
 #include "Services/ServerConnectionStack.h"
+#endif
 #include "Services/ServerInformation.h"
 #include "Services/UnitType.h"
Modified: branches/3.1/MgDev/Common/MapGuideCommon/Services/SiteConnection.h
--- branches/3.1/MgDev/Common/MapGuideCommon/Services/SiteConnection.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Common/MapGuideCommon/Services/SiteConnection.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -21,6 +21,7 @@
 // Forward declare MgConfiguration to avoid ACE header dependency
 class MgConfiguration;
 class MG_MAPGUIDE_API MgSiteConnection;
+class MG_MAPGUIDE_API MgServerConnection;
 class MG_MAPGUIDE_API MgServerConnectionStack;
 #ifdef _WIN32
Modified: branches/3.1/MgDev/Common/MapGuideCommon/Services/SiteManager.h
--- branches/3.1/MgDev/Common/MapGuideCommon/Services/SiteManager.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Common/MapGuideCommon/Services/SiteManager.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -20,6 +20,7 @@
 class MgSiteInfo;
 typedef std::vector<MgSiteInfo*> MgSiteVector;
 /// \cond INTERNAL
 // Data structure which is passed to thread
Modified: branches/3.1/MgDev/Common/PlatformBase/MapLayer/LayerBase.h
--- branches/3.1/MgDev/Common/PlatformBase/MapLayer/LayerBase.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Common/PlatformBase/MapLayer/LayerBase.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -18,6 +18,8 @@
 #ifndef _MG_LAYER_BASE_H_
 #define _MG_LAYER_BASE_H_
+#include <list>
 BEGIN_NAMESPACE_MDFMODEL
 class LayerDefinition;
 END_NAMESPACE_MDFMODEL
Modified: branches/3.1/MgDev/Oem/SQLite/src/SQLitePhpApi/SQLitePhpApi.vcxproj
--- branches/3.1/MgDev/Oem/SQLite/src/SQLitePhpApi/SQLitePhpApi.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Oem/SQLite/src/SQLitePhpApi/SQLitePhpApi.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -101,7 +101,7 @@
     <ClCompile>
       <Optimization>Disabled</Optimization>
       <AdditionalIncludeDirectories>..\..\..\ACE\ACE_wrappers;$(PHP_SRC);$(PHP_SRC)\main;$(PHP_SRC)\Zend;$(PHP_SRC)\TSRM;$(PHP_SRC)\ext\w32api;..\..\..\..\Common\MdfModel;..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\Exceptions;..\SQLite3;..\SqliteVM;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
-      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;SQLITEPHPAPI_EXPORTS;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;_USE_32BIT_TIME_T;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;SQLITEPHPAPI_EXPORTS;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;_USE_32BIT_TIME_T;%(PreprocessorDefinitions)</PreprocessorDefinitions>
       <ExceptionHandling>Async</ExceptionHandling>
       <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
       <RuntimeLibrary>MultiThreadedDebugDLL</RuntimeLibrary>
@@ -138,7 +138,7 @@
     <ClCompile>
-      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;SQLITEPHPAPI_EXPORTS;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;SQLITEPHPAPI_EXPORTS;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -172,7 +172,7 @@
     <ClCompile>
       <Optimization>MaxSpeed</Optimization>
-      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;SQLITEPHPAPI_EXPORTS;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;_USE_32BIT_TIME_T;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;SQLITEPHPAPI_EXPORTS;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;_USE_32BIT_TIME_T;%(PreprocessorDefinitions)</PreprocessorDefinitions>
       <RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
       <PrecompiledHeader>
@@ -210,7 +210,7 @@
     <ClCompile>
-      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;SQLITEPHPAPI_EXPORTS;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;SQLITEPHPAPI_EXPORTS;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;%(PreprocessorDefinitions)</PreprocessorDefinitions>
       <PrecompiledHeader>
Modified: branches/3.1/MgDev/Oem/SWIGEx/Source/Modules/csharp.cxx
--- branches/3.1/MgDev/Oem/SWIGEx/Source/Modules/csharp.cxx	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Oem/SWIGEx/Source/Modules/csharp.cxx	2018-06-02 15:49:46 UTC (rev 9393)
@@ -717,7 +717,7 @@
       Printf(f, "\t\tstrcat(exName, multibyteExName);\n");
       Printf(f, "\t\tbool bFound = false;\n");
-      Printf(f, "\t\tfor(list<char*>::const_iterator iter = exNames.begin(); iter != exNames.end(); iter++) {\n");
+      Printf(f, "\t\tfor(std::list<char*>::const_iterator iter = exNames.begin(); iter != exNames.end(); iter++) {\n");
       Printf(f, "\t\t\tif (strcmp(*iter, exName) == 0) {\n");
       Printf(f, "\t\t\t\tdelete[] exName;\n");
       Printf(f, "\t\t\t\texName = *iter;\n");
@@ -742,7 +742,7 @@
 		Printf(f, "#endif\n\n");
 		Printf(f, "void ThrowDotNetExceptionWrapper(%s* e)\n{\n", baseException);
-		Printf(f, "\tstatic list<char*> exNames;\n");
+		Printf(f, "\tstatic std::list<char*> exNames;\n");
 		Printf(f, "\tchar* exName = NULL;\n");
         if(rethrowCode)
Modified: branches/3.1/MgDev/Oem/SWIGEx/SwigEx.sln
--- branches/3.1/MgDev/Oem/SWIGEx/SwigEx.sln	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Oem/SWIGEx/SwigEx.sln	2018-06-02 15:49:46 UTC (rev 9393)
@@ -1,6 +1,8 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SwigEx", "SwigEx.vcproj", "{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}"
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio 15
+VisualStudioVersion = 15.0.27703.2018
+MinimumVisualStudioVersion = 10.0.40219.1
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SwigEx", "SwigEx.vcxproj", "{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}"
 EndProject
 Global
 	GlobalSection(SolutionConfigurationPlatforms) = preSolution
@@ -16,4 +18,7 @@
 	GlobalSection(SolutionProperties) = preSolution
 		HideSolutionNode = FALSE
 	EndGlobalSection
+	GlobalSection(ExtensibilityGlobals) = postSolution
+		SolutionGuid = {79F6288B-D6E6-4D5B-AA8E-A3171117FEF2}
+	EndGlobalSection
 EndGlobal
Added: branches/3.1/MgDev/Oem/SWIGEx/SwigEx.vcxproj
--- branches/3.1/MgDev/Oem/SWIGEx/SwigEx.vcxproj	                        (rev 0)
+++ branches/3.1/MgDev/Oem/SWIGEx/SwigEx.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -0,0 +1,165 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="15.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <ItemGroup Label="ProjectConfigurations">
+    <ProjectConfiguration Include="Debug|Win32">
+      <Configuration>Debug</Configuration>
+      <Platform>Win32</Platform>
+    </ProjectConfiguration>
+    <ProjectConfiguration Include="Release|Win32">
+      <Configuration>Release</Configuration>
+  </ItemGroup>
+  <PropertyGroup Label="Globals">
+    <ProjectGuid>{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}</ProjectGuid>
+    <Keyword>Win32Proj</Keyword>
+  </PropertyGroup>
+  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+    <ConfigurationType>Application</ConfigurationType>
+    <PlatformToolset>v141</PlatformToolset>
+    <CharacterSet>MultiByte</CharacterSet>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+  </PropertyGroup>
+  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+  <ImportGroup Label="ExtensionSettings">
+  </ImportGroup>
+  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+    <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+  </ImportGroup>
+  <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+  </ImportGroup>
+  <PropertyGroup Label="UserMacros" />
+  <PropertyGroup>
+    <_ProjectFileVersion>15.0.27625.0</_ProjectFileVersion>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+    <OutDir>Win32\</OutDir>
+    <IntDir>Debug\</IntDir>
+    <LinkIncremental>true</LinkIncremental>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+    <IntDir>Release\</IntDir>
+    <LinkIncremental>false</LinkIncremental>
+  </PropertyGroup>
+  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+    <ClCompile>
+      <Optimization>Disabled</Optimization>
+      <AdditionalIncludeDirectories>Source\Swig;Source\DOH;Source\Include;Source\Preprocessor;Source\Modules;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+      <PreprocessorDefinitions>WIN32;_DEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <MinimalRebuild>true</MinimalRebuild>
+      <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
+      <RuntimeLibrary>MultiThreadedDebug</RuntimeLibrary>
+      <PrecompiledHeader />
+      <WarningLevel>Level3</WarningLevel>
+      <DebugInformationFormat>EditAndContinue</DebugInformationFormat>
+    </ClCompile>
+    <Link>
+      <OutputFile>$(OutDir)Swig.exe</OutputFile>
+      <GenerateDebugInformation>true</GenerateDebugInformation>
+      <ProgramDatabaseFile>$(OutDir)SwigEx.pdb</ProgramDatabaseFile>
+      <SubSystem>Console</SubSystem>
+      <RandomizedBaseAddress>false</RandomizedBaseAddress>
+      <DataExecutionPrevention />
+      <TargetMachine>MachineX86</TargetMachine>
+    </Link>
+  </ItemDefinitionGroup>
+  <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+    <ClCompile>
+      <PreprocessorDefinitions>WIN32;NDEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <RuntimeLibrary>MultiThreaded</RuntimeLibrary>
+      <DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
+    </ClCompile>
+    <Link>
+      <OptimizeReferences>true</OptimizeReferences>
+      <EnableCOMDATFolding>true</EnableCOMDATFolding>
+    </Link>
+  <ItemGroup>
+    <ClCompile Include="Source\CParse\cscanner.c" />
+    <ClCompile Include="Source\CParse\parser.c" />
+    <ClCompile Include="Source\CParse\templ.c" />
+    <ClCompile Include="Source\CParse\util.c" />
+    <ClCompile Include="Source\Doh\base.c" />
+    <ClCompile Include="Source\Doh\file.c" />
+    <ClCompile Include="Source\Doh\fio.c" />
+    <ClCompile Include="Source\Doh\hash.c" />
+    <ClCompile Include="Source\Doh\list.c" />
+    <ClCompile Include="Source\Doh\memory.c" />
+    <ClCompile Include="Source\Doh\string.c" />
+    <ClCompile Include="Source\Doh\void.c" />
+    <ClCompile Include="Source\Modules\allocate.cxx" />
+    <ClCompile Include="Source\Modules\browser.cxx" />
+    <ClCompile Include="Source\Modules\chicken.cxx" />
+    <ClCompile Include="Source\Modules\contract.cxx" />
+    <ClCompile Include="Source\Modules\csharp.cxx" />
+    <ClCompile Include="Source\Modules\directors.cxx" />
+    <ClCompile Include="Source\Modules\emit.cxx" />
+    <ClCompile Include="Source\Modules\guile.cxx" />
+    <ClCompile Include="Source\Modules\java.cxx" />
+    <ClCompile Include="Source\Modules\lang.cxx" />
+    <ClCompile Include="Source\Modules\main.cxx" />
+    <ClCompile Include="Source\Modules\module.cxx" />
+    <ClCompile Include="Source\Modules\mzscheme.cxx" />
+    <ClCompile Include="Source\Modules\ocaml.cxx" />
+    <ClCompile Include="Source\Modules\overload.cxx" />
+    <ClCompile Include="Source\Modules\perl5.cxx" />
+    <ClCompile Include="Source\Modules\php4.cxx" />
+    <ClCompile Include="Source\Modules\php5.cxx" />
+    <ClCompile Include="Source\Modules\pike.cxx" />
+    <ClCompile Include="Source\Modules\python.cxx" />
+    <ClCompile Include="Source\Modules\ruby.cxx" />
+    <ClCompile Include="Source\Modules\s-exp.cxx" />
+    <ClCompile Include="Source\Modules\swigmain.cxx" />
+    <ClCompile Include="Source\Modules\tcl8.cxx">
+      <PreprocessToFile Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">false</PreprocessToFile>
+      <PreprocessSuppressLineNumbers Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">false</PreprocessSuppressLineNumbers>
+    </ClCompile>
+    <ClCompile Include="Source\Modules\typepass.cxx" />
+    <ClCompile Include="Source\Modules\utils.cxx" />
+    <ClCompile Include="Source\Modules\xml.cxx" />
+    <ClCompile Include="Source\Preprocessor\cpp.c" />
+    <ClCompile Include="Source\Preprocessor\expr.c" />
+    <ClCompile Include="Source\Swig\cwrap.c" />
+    <ClCompile Include="Source\Swig\error.c" />
+    <ClCompile Include="Source\Swig\fragment.c" />
+    <ClCompile Include="Source\Swig\getopt.c" />
+    <ClCompile Include="Source\Swig\include.c" />
+    <ClCompile Include="Source\Swig\misc.c" />
+    <ClCompile Include="Source\Swig\naming.c" />
+    <ClCompile Include="Source\Swig\parms.c" />
+    <ClCompile Include="Source\Swig\scanner.c" />
+    <ClCompile Include="Source\Swig\stype.c" />
+    <ClCompile Include="Source\Swig\symbol.c" />
+    <ClCompile Include="Source\Swig\tree.c" />
+    <ClCompile Include="Source\Swig\typemap.c" />
+    <ClCompile Include="Source\Swig\typeobj.c" />
+    <ClCompile Include="Source\Swig\typesys.c" />
+    <ClCompile Include="Source\Swig\warn.c" />
+    <ClCompile Include="Source\Swig\wrapfunc.c" />
+  </ItemGroup>
+  <ItemGroup>
+    <ClInclude Include="Source\Doh\doh.h" />
+    <ClInclude Include="Source\Doh\dohint.h" />
+    <ClInclude Include="Source\Modules\ExceptionClass.h" />
+    <ClInclude Include="Source\Swig\swig.h" />
+  </ItemGroup>
+  <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+  <ImportGroup Label="ExtensionTargets">
+  </ImportGroup>
+</Project>
\ No newline at end of file
Added: branches/3.1/MgDev/Oem/SWIGEx/SwigEx.vcxproj.filters
--- branches/3.1/MgDev/Oem/SWIGEx/SwigEx.vcxproj.filters	                        (rev 0)
+++ branches/3.1/MgDev/Oem/SWIGEx/SwigEx.vcxproj.filters	2018-06-02 15:49:46 UTC (rev 9393)
@@ -0,0 +1,222 @@
+<Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <ItemGroup>
+    <Filter Include="Source Files">
+      <UniqueIdentifier>{4FC737F1-C7A5-4376-A066-2A32D752A2FF}</UniqueIdentifier>
+      <Extensions>cpp;c;cxx;def;odl;idl;hpj;bat;asm;asmx</Extensions>
+    </Filter>
+    <Filter Include="Source Files\CParse">
+      <UniqueIdentifier>{26f85adf-1e7c-4abb-a0eb-4ba5473a9ac9}</UniqueIdentifier>
+    </Filter>
+    <Filter Include="Source Files\DOH">
+      <UniqueIdentifier>{7d3d3221-b5ec-4883-a45a-b1c338fe32df}</UniqueIdentifier>
+    </Filter>
+    <Filter Include="Source Files\Swig">
+      <UniqueIdentifier>{2dc0d219-ed8c-4295-adbd-8230ff6b02a5}</UniqueIdentifier>
+    </Filter>
+    <Filter Include="Source Files\Modules">
+      <UniqueIdentifier>{167abe99-4a4e-4979-a563-fe03774745b4}</UniqueIdentifier>
+    </Filter>
+    <Filter Include="Source Files\Preprocessor">
+      <UniqueIdentifier>{cb2a8ae2-a720-4e59-b76c-ff2d2a5d1483}</UniqueIdentifier>
+    </Filter>
+    <Filter Include="Header Files">
+      <UniqueIdentifier>{93995380-89BD-4b04-88EB-625FBE52EBFB}</UniqueIdentifier>
+      <Extensions>h;hpp;hxx;hm;inl;inc;xsd</Extensions>
+    </Filter>
+    <Filter Include="Resource Files">
+      <UniqueIdentifier>{67DA6AB6-F800-4c08-8B7A-83BB121AAD01}</UniqueIdentifier>
+      <Extensions>rc;ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe;resx</Extensions>
+    </Filter>
+  </ItemGroup>
+  <ItemGroup>
+    <ClCompile Include="Source\CParse\cscanner.c">
+      <Filter>Source Files\CParse</Filter>
+    </ClCompile>
+    <ClCompile Include="Source\CParse\parser.c">
+    </ClCompile>
+    <ClCompile Include="Source\CParse\templ.c">
+    </ClCompile>
+    <ClCompile Include="Source\CParse\util.c">
+    </ClCompile>
+    <ClCompile Include="Source\Doh\base.c">
+      <Filter>Source Files\DOH</Filter>
+    </ClCompile>
+    <ClCompile Include="Source\Doh\file.c">
+    </ClCompile>
+    <ClCompile Include="Source\Doh\fio.c">
+    </ClCompile>
+    <ClCompile Include="Source\Doh\hash.c">
+    </ClCompile>
+    <ClCompile Include="Source\Doh\list.c">
+    </ClCompile>
+    <ClCompile Include="Source\Doh\memory.c">
+    </ClCompile>
+    <ClCompile Include="Source\Doh\string.c">
+    </ClCompile>
+    <ClCompile Include="Source\Doh\void.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\cwrap.c">
+      <Filter>Source Files\Swig</Filter>
+    </ClCompile>
+    <ClCompile Include="Source\Swig\error.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\fragment.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\getopt.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\include.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\misc.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\naming.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\parms.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\scanner.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\stype.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\symbol.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\tree.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\typemap.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\typeobj.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\typesys.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\warn.c">
+    </ClCompile>
+    <ClCompile Include="Source\Swig\wrapfunc.c">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\allocate.cxx">
+      <Filter>Source Files\Modules</Filter>
+    </ClCompile>
+    <ClCompile Include="Source\Modules\browser.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\chicken.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\contract.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\csharp.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\directors.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\emit.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\guile.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\java.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\lang.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\main.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\module.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\mzscheme.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\ocaml.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\overload.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\perl5.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\php4.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\php5.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\pike.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\python.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\ruby.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\s-exp.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\swigmain.cxx">
+    </ClCompile>
+    </ClCompile>
+    <ClCompile Include="Source\Modules\typepass.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\utils.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Modules\xml.cxx">
+    </ClCompile>
+    <ClCompile Include="Source\Preprocessor\cpp.c">
+      <Filter>Source Files\Preprocessor</Filter>
+    </ClCompile>
+    <ClCompile Include="Source\Preprocessor\expr.c">
+    </ClCompile>
+  </ItemGroup>
+  <ItemGroup>
+    <ClInclude Include="Source\Doh\doh.h">
+    </ClInclude>
+    <ClInclude Include="Source\Doh\dohint.h">
+    </ClInclude>
+    <ClInclude Include="Source\Swig\swig.h">
+    </ClInclude>
+    <ClInclude Include="Source\Modules\ExceptionClass.h">
+    </ClInclude>
+  </ItemGroup>
+</Project>
Modified: branches/3.1/MgDev/Oem/SWIGEx/Win32/Swig.exe
(Binary files differ)
Modified: branches/3.1/MgDev/Oem/php/PROVENANCE.TXT
--- branches/3.1/MgDev/Oem/php/PROVENANCE.TXT	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Oem/php/PROVENANCE.TXT	2018-06-02 15:49:46 UTC (rev 9393)
@@ -12,9 +12,3 @@
 	Extracted from official PHP 5.5.3 source tarball (http://www.php.net/downloads.php)
 	Patched for compatibility with ACE
-TSRM\readdir.h
-	Extracted from official PHP 5.5.3 source tarball (http://www.php.net/downloads.php)
-	Patched for compatibility with ACE
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApi.vcxproj
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApi.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApi.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -103,7 +103,7 @@
     <ClCompile>
       <AdditionalIncludeDirectories>..\..\..\..\Common\Foundation;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\dbxml\xerces-c-src\src;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
-      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -140,7 +140,7 @@
     <ClCompile>
@@ -177,7 +177,7 @@
     <ClCompile>
-      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -215,7 +215,7 @@
     <ClCompile>
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml	2018-06-02 15:49:46 UTC (rev 9393)
@@ -26,6 +26,7 @@
 #include <string>
 #include <map>
+#include <list>
 #include "Foundation.h"
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApi.vcxproj
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApi.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApi.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -103,7 +103,7 @@
     <ClCompile>
       <AdditionalIncludeDirectories>..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\dbxml\xerces-c-src\src;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
@@ -140,7 +140,7 @@
     <ClCompile>
@@ -177,7 +177,7 @@
     <ClCompile>
@@ -215,7 +215,7 @@
     <ClCompile>
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml	2018-06-02 15:49:46 UTC (rev 9393)
@@ -26,6 +26,7 @@
 #include <string>
 #include <map>
+#include <list>
 #include "GeometryCommon.h"
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApi.vcxproj
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApi.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApi.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -103,7 +103,7 @@
     <ClCompile>
       <AdditionalIncludeDirectories>..\..\..\..\Common\MdfModel;..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\dbxml\xerces-c-src\src;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
@@ -140,7 +140,7 @@
     <ClCompile>
@@ -177,7 +177,7 @@
     <ClCompile>
@@ -215,7 +215,7 @@
     <ClCompile>
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml	2018-06-02 15:49:46 UTC (rev 9393)
@@ -26,6 +26,7 @@
 #include <string>
 #include <map>
+#include <list>
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApi.vcxproj
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApi.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApi.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -103,7 +103,7 @@
     <ClCompile>
       <AdditionalIncludeDirectories>..\..\..\..\Common\MdfModel;..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\dbxml\xerces-c-src\src;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
@@ -140,7 +140,7 @@
     <ClCompile>
@@ -177,7 +177,7 @@
     <ClCompile>
@@ -215,7 +215,7 @@
     <ClCompile>
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml	2018-06-02 15:49:46 UTC (rev 9393)
@@ -26,6 +26,7 @@
 #include <string>
 #include <map>
+#include <list>
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApi.vcxproj
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApi.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApi.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -103,7 +103,7 @@
     <ClCompile>
       <AdditionalIncludeDirectories>..\..\..\..\Common\MdfModel;..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Web\src\WebApp;..\..\..\..\Web\src\WebSupport;..\..\..\..\Web\src\HttpHandler;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\dbxml\xerces-c-src\src;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
@@ -140,7 +140,7 @@
     <ClCompile>
@@ -177,7 +177,7 @@
     <ClCompile>
@@ -215,7 +215,7 @@
     <ClCompile>
Modified: branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
--- branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml	2018-06-02 15:49:46 UTC (rev 9393)
@@ -26,6 +26,7 @@
 #include <string>
 #include <map>
+#include <list>
 #include "MapGuideCommon.h"
 #include "WebApp.h"
Modified: branches/3.1/MgDev/Web/src/JavaApi/JavaApi.vcxproj
--- branches/3.1/MgDev/Web/src/JavaApi/JavaApi.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/JavaApi/JavaApi.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -109,7 +109,7 @@
     <ClCompile>
       <AdditionalIncludeDirectories>..\HttpHandler;..\WebApp;..\WebSupport;..\..\..\Common\MdfModel;..\..\..\Common\Foundation;..\..\..\Common\PlatformBase;..\..\..\Common\Geometry;..\..\..\Common\MapGuideCommon;..\..\..\Oem\ACE\ACE_wrappers;..\..\..\Oem\dbxml\xerces-c-src\src;$(JAVA_HOME)\include;$(JAVA_HOME)\include\win32;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
-      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;JAVA;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;JAVA;SWIG_PUBLIC_API;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -149,7 +149,7 @@
     <ClCompile>
@@ -189,7 +189,7 @@
     <ClCompile>
-      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;JAVA;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;JAVA;SWIG_PUBLIC_API;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -230,7 +230,7 @@
     <ClCompile>
Modified: branches/3.1/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj
--- branches/3.1/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -109,7 +109,7 @@
     <ClCompile>
@@ -149,7 +149,7 @@
     <ClCompile>
@@ -190,7 +190,7 @@
     <ClCompile>
@@ -231,7 +231,7 @@
     <ClCompile>
Modified: branches/3.1/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml
--- branches/3.1/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/MapGuideApi/MapGuideApiGen.xml	2018-06-02 15:49:46 UTC (rev 9393)
@@ -17,6 +17,15 @@
 <CppInline>
 #ifdef _WIN32
 #pragma warning(disable: 4251)
+//These will be set as a result of pulling windows headers somewhere in the dependency chain.
+//These have to be unset as we have class methods of the same name which the windows headers
+//will erroneously try to rewrite to CreateServiceW/GetClassNameW/GetUserNameW on our class methods.
+#undef CreateService
+#undef GetClassName
+#undef GetUserName
 #endif
 #include <string>
Modified: branches/3.1/MgDev/Web/src/PhpApi/PhpApi.vcxproj
--- branches/3.1/MgDev/Web/src/PhpApi/PhpApi.vcxproj	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/PhpApi/PhpApi.vcxproj	2018-06-02 15:49:46 UTC (rev 9393)
@@ -104,7 +104,7 @@
     <ClCompile>
       <AdditionalIncludeDirectories>..\HttpHandler;..\WebApp;..\WebSupport;..\..\..\Common\MdfModel;..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Common\PlatformBase;..\..\..\Common\MapGuideCommon;..\..\..\Oem\ACE\ACE_wrappers;..\..\..\Oem\dbxml\xerces-c-src\src;$(PHP_SRC);$(PHP_SRC)\main;$(PHP_SRC)\TSRM;$(PHP_SRC)\Zend;$(PHP_SRC)\ext\w32api;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
-      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;_USE_32BIT_TIME_T;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;_USE_32BIT_TIME_T;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -139,7 +139,7 @@
     <ClCompile>
-      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -174,7 +174,7 @@
     <ClCompile>
-      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;_USE_32BIT_TIME_T;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;_USE_32BIT_TIME_T;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -210,7 +210,7 @@
     <ClCompile>
-      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+      <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;SWIG_PUBLIC_API;PHPPROXYAPI_EXPORTS;ZEND_WIN32;PHP_WIN32;ZEND_DEBUG=0;ZTS=1;PHP;_WIN64;%(PreprocessorDefinitions)</PreprocessorDefinitions>
Modified: branches/3.1/MgDev/Web/src/WebApp/WebApp.h
--- branches/3.1/MgDev/Web/src/WebApp/WebApp.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/WebApp/WebApp.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -20,9 +20,10 @@
 #include "System/XmlDefs.h"
 #include "System/XmlUtil.h"
+#endif
 #include "WebAppExport.h"
 #include "WebAppClassId.h"
Modified: branches/3.1/MgDev/Web/src/WebApp/WebLayout.h
--- branches/3.1/MgDev/Web/src/WebApp/WebLayout.h	2018-05-22 08:03:08 UTC (rev 9392)
+++ branches/3.1/MgDev/Web/src/WebApp/WebLayout.h	2018-06-02 15:49:46 UTC (rev 9393)
@@ -25,6 +25,11 @@
 typedef map<MgWebCommandWidget*, STRING>    CMD_WIDGET_MAP;
 class MgResourceIdentifier;
+namespace XERCES_CPP_NAMESPACE
+    class DOMNode;
+    class DOMElement;
 class MG_WEBAPP_API MgWebLayout : public MgGuardDisposable
@@ -293,37 +298,37 @@
     // parse basic command specific elements
-    void ParseBuiltInCommand(DOMNode* node, MgWebCommand* cmd);
+    void ParseBuiltInCommand(XERCES_CPP_NAMESPACE::DOMNode* node, MgWebCommand* cmd);
     // parse invoke url representing an action command
-    void ParseInvokeUrlCommand(DOMNode* node, MgWebInvokeUrlCommand* cmd);
+    void ParseInvokeUrlCommand(XERCES_CPP_NAMESPACE::DOMNode* node, MgWebInvokeUrlCommand* cmd);
     // parse search specific elements
-    void ParseSearchCommand(DOMNode* node, MgWebSearchCommand* cmd);
+    void ParseSearchCommand(XERCES_CPP_NAMESPACE::DOMNode* node, MgWebSearchCommand* cmd);
     // parse invoke script specific elements
-    void ParseInvokeScriptCommand(DOMNode* node, MgWebInvokeScriptCommand* cmd);
+    void ParseInvokeScriptCommand(XERCES_CPP_NAMESPACE::DOMNode* node, MgWebInvokeScriptCommand* cmd);
     // parse print specific elements
-    void ParsePrintCommand(DOMNode* node, MgWebPrintCommand* cmd);
+    void ParsePrintCommand(XERCES_CPP_NAMESPACE::DOMNode* node, MgWebPrintCommand* cmd);
     // parse help specific elements
-    void ParseHelpCommand(DOMNode* node, MgWebHelpCommand* cmd);
+    void ParseHelpCommand(XERCES_CPP_NAMESPACE::DOMNode* node, MgWebHelpCommand* cmd);
     // parse ui target specific elements
-    void ParseUiTargetCommand(DOMNode*, MgWebUiTargetCommand* cmd);
+    void ParseUiTargetCommand(XERCES_CPP_NAMESPACE::DOMNode*, MgWebUiTargetCommand* cmd);
     // parse a UIItem element and returns an MgWebWidget object
@@ -333,12 +338,12 @@
     // parse a command widget
-    void ParseCommandWidget(DOMNode* node, MgWebCommandWidget* widget);
+    void ParseCommandWidget(XERCES_CPP_NAMESPACE::DOMNode* node, MgWebCommandWidget* widget);
     // parse a flyout widget
-    void ParseFlyoutWidget(DOMNode* node, MgWebFlyoutWidget* widget);
+    void ParseFlyoutWidget(XERCES_CPP_NAMESPACE::DOMNode* node, MgWebFlyoutWidget* widget);
     // parse the Map element
More information about the mapguide-commits mailing list
