[mapguide-commits] r9334 - trunk/MgDev
svn_mapguide at osgeo.org
Sat Mar 3 04:11:48 PST 2018
Author: jng
Date: 2018-03-03 04:11:48 -0800 (Sat, 03 Mar 2018)
New Revision: 9334
Removed:
trunk/MgDev/setenvironment.bat
#2773: Remove 32-bit build environment init script
Deleted: trunk/MgDev/setenvironment.bat
--- trunk/MgDev/setenvironment.bat 2018-03-03 12:10:12 UTC (rev 9333)
+++ trunk/MgDev/setenvironment.bat 2018-03-03 12:11:48 UTC (rev 9334)
@@ -1,165 +0,0 @@
- at echo off
-rem ==================================================
-rem setenvironment.bat
-rem
-rem Sets the required environment variables for the
-rem build.bat script
-rem
-rem This script must be run from the VS2012 command prompt
-rem Top-level vars
-SET OLDPATH=%PATH%
-SET TYPEACTION=build
-SET TYPECOMPONENT=all
-SET TYPEBUILD=unknown
-SET CONFIGURATION=unknown
-SET PLATFORM=unknown
-SET PLATFORM_CLR=unknown
-SET PCONF=release
-if not "%1" == "" set PCONF=%1
-if "%PCONF%"=="debug" (
-SET TYPEBUILD=Debug
-SET CONFIGURATION=Debug
-SET PLATFORM=Win32
-SET PLATFORM_CLR=x86
-IF "%PCONF%"=="release" (
-SET TYPEBUILD=Release
-SET CONFIGURATION=Release
-SET PLATFORM=Win32
-if "%TYPEBUILD%"=="unknown" (
- echo Unknown configuration: %PCONF%
- goto help_show
-rem MapGuide vars
-SET MG_DEV=%CD%
-SET MG_OEM=%MG_DEV%\Oem
-SET MG_OEM_DBXML=dbxml
-SET MG_OEM_DB=db-4.8.26
-SET MG_FDO_BIN=%MG_OEM%\FDO\Bin\%TYPEBUILD%
-SET MG_FDO_INC=%MG_OEM%\FDO\Inc
-SET MG_FDO_LIB=%MG_OEM%\FDO\Lib
-SET MG_COMMON=%MG_DEV%\Common
-SET MG_SERVER=%MG_DEV%\Server
-SET MG_WEB=%MG_DEV%\Web
-SET MG_WEB_SRC=%MG_WEB%\src
-SET MG_WEB_BIN=%MG_WEB%\bin
-SET MG_UNIT_TEST=%MG_DEV%\UnitTest
-SET MG_FUSION=%MG_OEM%\Fusion
-SET MG_DOC=%MG_DEV%\Doc
-SET MG_DOC_OUTPUT=%MG_DOC%\MgOpensource_WebAPIReference
-SET MG_DOC_DEVGUIDE_SAMPLES=%MG_DOC%\samples
-SET MG_BUILD_TEMP=%MG_DEV%\BuildTemp
-rem === Intermediate build vars ===
-SET MG_BUILD_DBXML_EXE_PATH=%MG_OEM%\%MG_OEM_DBXML%\bin\%CONFIGURATION%
-SET MG_BUILD_SQLITE_PHP_API=%MG_OEM%\SQLite\bin\%TYPEBUILD%\php_SQLitePhpApi.dll
-SET MG_BUILD_SQLITE_DOTNET_API=%MG_OEM%\SQLite\bin\%TYPEBUILD%\SQLiteDotNet.dll
-SET MG_BUILD_MAPAGENT_PATH=%MG_WEB_SRC%\mapagent
-SET MG_BUILD_MAPAGENT=%MG_BUILD_MAPAGENT_PATH%\mod_mgmapagent.so
-SET MG_OUTPUT=%MG_DEV%\%TYPEBUILD%
-SET MG_OUTPUT_SERVER=%MG_OUTPUT%\Server
-SET MG_OUTPUT_WEB=%MG_OUTPUT%\Web
-SET MG_OUTPUT_CSMAP=%MG_OUTPUT%\CS-Map
-SET MG_OUTPUT_TEST=%MG_OUTPUT%\Test
-SET MG_BUILD_COMPONENT=
-SET MG_DEFAULT_INSTALLDIR=C:\Program Files\MapGuideOpenSource2.0
-SET MG_ERROR=0
-rem Extra tool paths
-rem
-rem Your paths may be different, adjust accordingly or
-rem set the appropriate environment variables before
-rem running
-IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files (x86)\Java\jdk1.7.0_80
-IF "%DOXYGEN%" == "" SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
-IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files (x86)\GnuWin32\bin
-IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
-IF "%ANT_HOME%" == "" SET ANT_HOME=C:\apache-ant
-SET PATH=%PATH%;%DOXYGEN%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin
-rem PHP/httpd env vars for Visual Studio
-rem Comment out this line if you intend to build against a different version of PHP/httpd
-rem Be sure to change the paths below as well if that's the case
-call prepare_webtier_components.bat
-rem Set the env vars that VS will reference
-SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.6.23
-SET PHP_LIB=%MG_OEM%\php\Release_TS
-SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.18
-SET HTTPD_LIB=%MG_OEM%\httpd\lib
-rem Sanity checks
-if not exist "%PHP_SRC%" echo Environment variable PHP_SRC does not point to a valid directory (%PHP_SRC%). Please edit setenvironment64.bat to ensure PHP_SRC points to a valid directory
-if not exist "%PHP_LIB%\php5ts.lib" echo Environment variable PHP_LIB does not point to a valid directory (%PHP_LIB%). Could not find php5ts.lib in this directory. Please edit setenvironment64.bat to ensure PHP_LIB points to a valid directory
-if not exist "%HTTPD_SRC%" echo Environment variable HTTPD_SRC does not point to a valid directory (%HTTPD_SRC%). Please edit setenvironment64.bat to ensure HTTPD_SRC points to a valid directory
-if not exist "%HTTPD_LIB%\libhttpd.lib" echo Environment variable HTTPD_LIB does not point to a valid directory (%HTTPD_LIB%). Could not find libhttpd.lib in this directory. Please edit setenvironment64.bat to ensure HTTPD_LIB points to a valid directory
-if not exist "%HTTPD_LIB%\libapr-1.lib" echo Environment variable HTTPD_LIB does not point to a valid directory (%HTTPD_LIB%). Could not find libapr-1.lib in this directory. Please edit setenvironment64.bat to ensure HTTPD_LIB points to a valid directory
-if not exist "%HTTPD_LIB%\libaprutil-1.lib" echo Environment variable HTTPD_LIB does not point to a valid directory (%HTTPD_LIB%). Could not find libaprutil-1.lib in this directory. Please edit setenvironment64.bat to ensure HTTPD_LIB points to a valid directory
-rem MSBuild Settings
-rem If the NUMBER_OF_PROCESSORS environment variable is wrong for any reason. Change this value.
-SET CPU_CORES=%NUMBER_OF_PROCESSORS%
-rem Uncomment the line below to enable msbuild logging
-rem SET MSBUILD_LOG=/l:FileLogger,Microsoft.Build.Engine;logfile=Build.log;verbosity=diagnostic
-SET MSBUILD_VERBOSITY=/v:n
-rem Command aliases
-SET XCOPY=xcopy /E /Y /I /Q /H
-SET XCOPY_SINGLE=xcopy /Y /I /Q
-SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
-SET MSBUILD_CLR=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM_CLR% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
-SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% /t:Clean %MSBUILD_VERBOSITY%
-SET MSBUILD_CLEAN_CLR=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM_CLR% /t:Clean %MSBUILD_VERBOSITY%
-SET ANT=ant
-echo ======== Environment Variable Summary =============
-echo PHP_SRC = %PHP_SRC%
-echo PHP_LIB = %PHP_LIB%
-echo HTTPD_SRC = %HTTPD_SRC%
-echo HTTPD_LIB = %HTTPD_LIB%
-echo Configuration is [%TYPEBUILD%, "%CONFIGURATION%|%PLATFORM%"]
-echo Deployment Directory for Server: %MG_OUTPUT_SERVER%
-echo Deployment Directory for Web: %MG_OUTPUT_WEB%
-echo CPU cores: %CPU_CORES%
-echo =================== FDO ===========================
-echo Binaries: %MG_FDO_BIN%
-echo Headers: %MG_FDO_INC%
-echo Libs: %MG_FDO_LIB%
-echo =================== Oem ===========================
-echo DBXML executables: %MG_BUILD_DBXML_EXE_PATH%
-echo SQLite PHP API: %MG_BUILD_SQLITE_PHP_API%
-echo mod_mgmapagent.so: %MG_BUILD_MAPAGENT%
-echo ===================================================
-echo Type build.bat to build MapGuide
-goto done
-:help_show
-echo ************************************************************************
-echo Usage: setenvironment.bat [debug|release]
-echo If unspecified, configuration will default to release
-:done
\ No newline at end of file
More information about the mapguide-commits
