[mapguide-commits] r9345 - trunk/MgDev
svn_mapguide at osgeo.org
Sat Mar 3 05:25:04 PST 2018
Author: jng
Date: 2018-03-03 05:25:04 -0800 (Sat, 03 Mar 2018)
New Revision: 9345
Added:
trunk/MgDev/setenvironment.bat
Bring back setenvironment.bat. Though we will no longer build 32-bit MapGuide for windows, we may still want to build 32-bit mg-desktop for Windows where this script will still be needed.
Copied: trunk/MgDev/setenvironment.bat (from rev 9333, trunk/MgDev/setenvironment.bat)
--- trunk/MgDev/setenvironment.bat (rev 0)
+++ trunk/MgDev/setenvironment.bat 2018-03-03 13:25:04 UTC (rev 9345)
@@ -0,0 +1,165 @@
+ at echo off
+rem ==================================================
+rem setenvironment.bat
+rem
+rem Sets the required environment variables for the
+rem build.bat script
+rem
+rem This script must be run from the VS2012 command prompt
+rem Top-level vars
+SET OLDPATH=%PATH%
+SET TYPEACTION=build
+SET TYPECOMPONENT=all
+SET TYPEBUILD=unknown
+SET CONFIGURATION=unknown
+SET PLATFORM=unknown
+SET PLATFORM_CLR=unknown
+SET PCONF=release
+if not "%1" == "" set PCONF=%1
+if "%PCONF%"=="debug" (
+SET TYPEBUILD=Debug
+SET CONFIGURATION=Debug
+SET PLATFORM=Win32
+SET PLATFORM_CLR=x86
+IF "%PCONF%"=="release" (
+SET TYPEBUILD=Release
+SET CONFIGURATION=Release
+SET PLATFORM=Win32
+if "%TYPEBUILD%"=="unknown" (
+ echo Unknown configuration: %PCONF%
+ goto help_show
+rem MapGuide vars
+SET MG_DEV=%CD%
+SET MG_OEM=%MG_DEV%\Oem
+SET MG_OEM_DBXML=dbxml
+SET MG_OEM_DB=db-4.8.26
+SET MG_FDO_BIN=%MG_OEM%\FDO\Bin\%TYPEBUILD%
+SET MG_FDO_INC=%MG_OEM%\FDO\Inc
+SET MG_FDO_LIB=%MG_OEM%\FDO\Lib
+SET MG_COMMON=%MG_DEV%\Common
+SET MG_SERVER=%MG_DEV%\Server
+SET MG_WEB=%MG_DEV%\Web
+SET MG_WEB_SRC=%MG_WEB%\src
+SET MG_WEB_BIN=%MG_WEB%\bin
+SET MG_UNIT_TEST=%MG_DEV%\UnitTest
+SET MG_FUSION=%MG_OEM%\Fusion
+SET MG_DOC=%MG_DEV%\Doc
+SET MG_DOC_OUTPUT=%MG_DOC%\MgOpensource_WebAPIReference
+SET MG_DOC_DEVGUIDE_SAMPLES=%MG_DOC%\samples
+SET MG_BUILD_TEMP=%MG_DEV%\BuildTemp
+rem === Intermediate build vars ===
+SET MG_BUILD_DBXML_EXE_PATH=%MG_OEM%\%MG_OEM_DBXML%\bin\%CONFIGURATION%
+SET MG_BUILD_SQLITE_PHP_API=%MG_OEM%\SQLite\bin\%TYPEBUILD%\php_SQLitePhpApi.dll
+SET MG_BUILD_SQLITE_DOTNET_API=%MG_OEM%\SQLite\bin\%TYPEBUILD%\SQLiteDotNet.dll
+SET MG_BUILD_MAPAGENT_PATH=%MG_WEB_SRC%\mapagent
+SET MG_BUILD_MAPAGENT=%MG_BUILD_MAPAGENT_PATH%\mod_mgmapagent.so
+SET MG_OUTPUT=%MG_DEV%\%TYPEBUILD%
+SET MG_OUTPUT_SERVER=%MG_OUTPUT%\Server
+SET MG_OUTPUT_WEB=%MG_OUTPUT%\Web
+SET MG_OUTPUT_CSMAP=%MG_OUTPUT%\CS-Map
+SET MG_OUTPUT_TEST=%MG_OUTPUT%\Test
+SET MG_BUILD_COMPONENT=
+SET MG_DEFAULT_INSTALLDIR=C:\Program Files\MapGuideOpenSource2.0
+SET MG_ERROR=0
+rem Extra tool paths
+rem
+rem Your paths may be different, adjust accordingly or
+rem set the appropriate environment variables before
+rem running
+IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files (x86)\Java\jdk1.7.0_80
+IF "%DOXYGEN%" == "" SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
+IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files (x86)\GnuWin32\bin
+IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
+IF "%ANT_HOME%" == "" SET ANT_HOME=C:\apache-ant
+SET PATH=%PATH%;%DOXYGEN%;%GNUWIN32%;%SEVENZ%;%ANT_HOME%\bin
+rem PHP/httpd env vars for Visual Studio
+rem Comment out this line if you intend to build against a different version of PHP/httpd
+rem Be sure to change the paths below as well if that's the case
+call prepare_webtier_components.bat
+rem Set the env vars that VS will reference
+SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.6.23
+SET PHP_LIB=%MG_OEM%\php\Release_TS
+SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.18
+SET HTTPD_LIB=%MG_OEM%\httpd\lib
+rem Sanity checks
+if not exist "%PHP_SRC%" echo Environment variable PHP_SRC does not point to a valid directory (%PHP_SRC%). Please edit setenvironment64.bat to ensure PHP_SRC points to a valid directory
+if not exist "%PHP_LIB%\php5ts.lib" echo Environment variable PHP_LIB does not point to a valid directory (%PHP_LIB%). Could not find php5ts.lib in this directory. Please edit setenvironment64.bat to ensure PHP_LIB points to a valid directory
+if not exist "%HTTPD_SRC%" echo Environment variable HTTPD_SRC does not point to a valid directory (%HTTPD_SRC%). Please edit setenvironment64.bat to ensure HTTPD_SRC points to a valid directory
+if not exist "%HTTPD_LIB%\libhttpd.lib" echo Environment variable HTTPD_LIB does not point to a valid directory (%HTTPD_LIB%). Could not find libhttpd.lib in this directory. Please edit setenvironment64.bat to ensure HTTPD_LIB points to a valid directory
+if not exist "%HTTPD_LIB%\libapr-1.lib" echo Environment variable HTTPD_LIB does not point to a valid directory (%HTTPD_LIB%). Could not find libapr-1.lib in this directory. Please edit setenvironment64.bat to ensure HTTPD_LIB points to a valid directory
+if not exist "%HTTPD_LIB%\libaprutil-1.lib" echo Environment variable HTTPD_LIB does not point to a valid directory (%HTTPD_LIB%). Could not find libaprutil-1.lib in this directory. Please edit setenvironment64.bat to ensure HTTPD_LIB points to a valid directory
+rem MSBuild Settings
+rem If the NUMBER_OF_PROCESSORS environment variable is wrong for any reason. Change this value.
+SET CPU_CORES=%NUMBER_OF_PROCESSORS%
+rem Uncomment the line below to enable msbuild logging
+rem SET MSBUILD_LOG=/l:FileLogger,Microsoft.Build.Engine;logfile=Build.log;verbosity=diagnostic
+SET MSBUILD_VERBOSITY=/v:n
+rem Command aliases
+SET XCOPY=xcopy /E /Y /I /Q /H
+SET XCOPY_SINGLE=xcopy /Y /I /Q
+SET MSBUILD=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
+SET MSBUILD_CLR=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM_CLR% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
+SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM% /t:Clean %MSBUILD_VERBOSITY%
+SET MSBUILD_CLEAN_CLR=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%CONFIGURATION% /p:Platform=%PLATFORM_CLR% /t:Clean %MSBUILD_VERBOSITY%
+SET ANT=ant
+echo ======== Environment Variable Summary =============
+echo PHP_SRC = %PHP_SRC%
+echo PHP_LIB = %PHP_LIB%
+echo HTTPD_SRC = %HTTPD_SRC%
+echo HTTPD_LIB = %HTTPD_LIB%
+echo Configuration is [%TYPEBUILD%, "%CONFIGURATION%|%PLATFORM%"]
+echo Deployment Directory for Server: %MG_OUTPUT_SERVER%
+echo Deployment Directory for Web: %MG_OUTPUT_WEB%
+echo CPU cores: %CPU_CORES%
+echo =================== FDO ===========================
+echo Binaries: %MG_FDO_BIN%
+echo Headers: %MG_FDO_INC%
+echo Libs: %MG_FDO_LIB%
+echo =================== Oem ===========================
+echo DBXML executables: %MG_BUILD_DBXML_EXE_PATH%
+echo SQLite PHP API: %MG_BUILD_SQLITE_PHP_API%
+echo mod_mgmapagent.so: %MG_BUILD_MAPAGENT%
+echo ===================================================
+echo Type build.bat to build MapGuide
+goto done
+:help_show
+echo ************************************************************************
+echo Usage: setenvironment.bat [debug|release]
+echo If unspecified, configuration will default to release
+:done
\ No newline at end of file
More information about the mapguide-commits
