[mapguide-commits] r9363 - in trunk/MgDev: Common/MapGuideCommon/Resources Common/PlatformBase/Services Server/src/UnitTesting
svn_mapguide at osgeo.org
Tue Mar 6 06:52:05 PST 2018
Author: jng
Date: 2018-03-06 06:52:05 -0800 (Tue, 06 Mar 2018)
New Revision: 9363
trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
trunk/MgDev/Common/PlatformBase/Services/ResourceIdentifier.cpp
trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
trunk/MgDev/Server/src/UnitTesting/TestMisc.h
Include bad identifier in exception message if "new MgResourceIdentifier()" throws.
Fixes #2582
Modified: trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2018-03-06 14:27:16 UTC (rev 9362)
+++ trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res 2018-03-06 14:52:05 UTC (rev 9363)
@@ -160,6 +160,7 @@
[ErrorDescription]
MgArgumentsMismatch = The arguments needed do not match the arguments provided.
MgArgumentOutOfRange = Argument out of range [%1, %2]: %3
+MgBadResourceIdentifer = Bad Resource Identifier: %1
MgClassWOIdentity = A class definition has no identity property.
MgCannotResolveFeatureSourceFromWfsTypeName = Could not resolve the Feature Source from the given WFS Type Name: %1
MgCollectionEmpty = The collection cannot be empty.
Modified: trunk/MgDev/Common/PlatformBase/Services/ResourceIdentifier.cpp
--- trunk/MgDev/Common/PlatformBase/Services/ResourceIdentifier.cpp 2018-03-06 14:27:16 UTC (rev 9362)
+++ trunk/MgDev/Common/PlatformBase/Services/ResourceIdentifier.cpp 2018-03-06 14:52:05 UTC (rev 9363)
@@ -451,8 +451,10 @@
else
+ MgStringCollection args;
+ args.Add(resource);
throw new MgInvalidRepositoryTypeException(
- L"MgResourceIdentifier.ParseIdentifier", __LINE__, __WFILE__, NULL, L"", NULL);
+ L"MgResourceIdentifier.ParseIdentifier", __LINE__, __WFILE__, NULL, L"MgBadResourceIdentifer", &args);
Validate();
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2018-03-06 14:27:16 UTC (rev 9362)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2018-03-06 14:52:05 UTC (rev 9363)
@@ -752,4 +752,23 @@
throw;
+void TestMisc::TestCase_BadResourceIdentifier()
+ try
+ Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"I'm a baaaaad id");
+ CPPUNIT_FAIL("This should've thrown");
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_ASSERT(message.find(L"I'm a baaaaad id") != STRING::npos);
+ catch (...)
+ throw;
\ No newline at end of file
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.h
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2018-03-06 14:27:16 UTC (rev 9362)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2018-03-06 14:52:05 UTC (rev 9363)
@@ -33,6 +33,7 @@
CPPUNIT_TEST(TestCase_ApiVersionCheck);
CPPUNIT_TEST(TestCase_DoubleToStringWithDecimals);
CPPUNIT_TEST(TestCase_TryParseDouble);
+ CPPUNIT_TEST(TestCase_BadResourceIdentifier);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -55,6 +56,7 @@
void TestCase_ApiVersionCheck();
void TestCase_DoubleToStringWithDecimals();
void TestCase_TryParseDouble();
+ void TestCase_BadResourceIdentifier();
private:
Ptr<MgSiteConnection> m_siteConnection;
More information about the mapguide-commits
