[mapguide-commits] r9390 - in trunk/MgDev: . Web/src
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 7 08:00:09 PDT 2018
Author: jng
Date: 2018-05-07 08:00:09 -0700 (Mon, 07 May 2018)
New Revision: 9390
   trunk/MgDev/
   trunk/MgDev/Web/src/webconfig.ini
Merged revision(s) 9389 from branches/3.1/MgDev:
#2780: Add MentorUserDictionaryPath to default webconfig.ini so users are aware that this property is now available.
Index: trunk/MgDev
--- trunk/MgDev	2018-05-07 14:59:22 UTC (rev 9389)
+++ trunk/MgDev	2018-05-07 15:00:09 UTC (rev 9390)
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
## -1,7 +1,7 ##
 /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
 /branches/2.6/MgDev:8276-8286,8288-8292,8297,8299,8301,8303,8314-8315,8318,8335,8340,8354-8355,8365,8373
 /branches/3.0/MgDev:8658,8705,8710
-/branches/3.1/MgDev:9026,9058-9059,9067-9068,9322-9323,9329,9377-9378,9382,9387
+/branches/3.1/MgDev:9026,9058-9059,9067-9068,9322-9323,9329,9377-9378,9382,9387,9389
 /sandbox/VC140:8684-8759
 /sandbox/adsk/2.6l:8727
 /sandbox/adsk/3.0m:8563,8584,8607,8625,8694-8695
Modified: trunk/MgDev/Web/src/webconfig.ini
--- trunk/MgDev/Web/src/webconfig.ini	2018-05-07 14:59:22 UTC (rev 9389)
+++ trunk/MgDev/Web/src/webconfig.ini	2018-05-07 15:00:09 UTC (rev 9390)
@@ -41,6 +41,7 @@
 # LogsPath                         Path where log files are stored
 # MentorDictionaryPath             The path where the CS-Map Coordinate System Dictionaries are installed
+# MentorUserDictionaryPath         The path where user defined CS-Map Coordinate System Dictionaries are stored
 # ResourcesPath                    Path where the localization resource files are stored
 # TcpIpMtu                         The TCP/IP maximum transmission unit
 #                                       0 < Value <= 65535
@@ -59,6 +60,7 @@
 DefaultMessageLocale               = en
 LogsPath                           = Logs/
 MentorDictionaryPath               =
+MentorUserDictionaryPath           =
 ResourcesPath                      = Resources/
 TcpIpMtu                           = 1460
 TempPath                           = Temp/
More information about the mapguide-commits mailing list
