[mapguide-dev] sources docs
Traian Stanev
traian.stanev at autodesk.com
Wed Apr 19 10:10:56 EDT 2006
What do you mean by the "maps server" component. Do you mean the code
that generates images for maps for requests like GETMAPIMAGE and the
AJAX viewer and DWFs for the DWF viewer?
Traian
-----Original Message-----
From: alucas at srtec.com [mailto:alucas at srtec.com]
Sent: Monday, April 17, 2006 7:45 PM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] sources docs
Hello list,
I've a question. I've downloaded mapguide 1.0.0 source code for try to
understand it. It's very difficult to understand internal
functionalities
without any documentation or software engineering docs. I'd like to
study
all his compoments in detail, but between the getting started guide and
the source code there are not documents about the internal architecture
for understand all components and their relations. For example, if I'd
like to analyze the maps server component, I open with VS 2005 the
server
solution and it has several projects with several classes. Without any
documentation, I will spend long time to understand this code.
I've looked for in mapguide.osgeo.org but there is nothing (there are
some
api guides for viewer and installation).
So, the question is, there is any documentation about this?
Thanks.
Antonio Lucas
Software Engineer
SER&TEC S.L
Phone: +34 96 395 95 13
www.srtec.com
Valencia (Spain)
To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide-internals
