[mapguide-dev] problems initializing web tier
Traian Stanev traian.stanev at autodesk.com
Mon Apr 24 09:13:48 EDT 2006
OK that looks fine. It is probably still worth it to check with the dll
dependecy tool -- available at http://www.dependencywalker.com/
Another thing... Can you run "set" form a command line and tell me if
the environment variables GDAL_DATA and PROJ_LIB are defined and what
their values are?
Traian
-----Original Message-----
From: alucas at srtec.com [mailto:alucas at srtec.com]
Sent: Monday, April 24, 2006 8:59 AM
To: dev at mapguide.osgeo.org
Cc: dev at mapguide.osgeo.org
Subject: RE: [mapguide-dev] problems initializing web tier
You're right Traian, but all dll's are builded as debug. I've omitted
this
detail because I read this in the pdf. Excuse me this mistake.
So, all Webtier.sln and Oem.sln have been compiled in debug mode, all
dll's have 'd' character at the end:
ACEd.dll
MapGuideDotNetApid.dll
I've attached a screeenshot.
> One thing bothers me here. The exception message says it is attempting
> to load MapGuideDotNetApid.dll, which is a debug build of the API dll
> (notice the d). The debug dll expects to find other debug dlls like
> MgCommond.dll and ACEd.dll. The list you give me has no 'd', which
leads
> me to believe these are release dlls. You need either all debug or all
> release builds of the dlls.
> Traian
> Sent: Monday, April 24, 2006 8:40 AM
> Hi Traian,
> I was thinking this, for this reason, I was put all dll's generated
with
> WebTier.sln in the same directory that exe file. So, the directory
> contains:
> ACE.dll
> All Api dll's : MapGuideJavaApi.dll ...
> MapguideUnmanagedApi.dll
> MgCommon.dll
> MgCoordinateSystem.dll
> I don't know nothing about dependency tool. I never have used it. I
will
> search in the net.
>> Could it be that it is looking for the dll that contains
>> MgInitializeWebTier (or one of its dependencies) and not finding it?
> Do
>> you have the dependency tool (depends.exe). Could you run it against
>> MapGuideDotNetApid.dll and see which dlls it depends on and is not
>> finding?
>> For example, when you add a managed dependency, if that dll has
>> unmanaged dependencies (like MgCommond.dll in our case), the
unmanaged
>> dependencies will not get automatically copied to the .exe directory
> and
>> you will need to do it by hand.
>> Traian
>> Sent: Monday, April 24, 2006 7:18 AM
>> Subject: [mapguide-dev] problems initializing web tier
>> Hello list,
>> When I try to connect to the server in .NET, I get the exception:
>> 'An unhandled exception of type
> 'OSGeo.MapGuide.MgFileNotFoundException'
>> occurred in MapGuideDotNetApid.dll'
>> I've added as a reference 'MapGuideDotNetApi.dll' in the project.
>> The sample code to establish my conenction is:
>> // This is a sample windows form application in C#.
>> // I've tried with @"c:\pathtofile\webconfig.ini".
>> // Here, the file is in the same directory that .exe
>> // I've changed the IP address in the webconfig.ini
>> // Here, I get the exception
>> MapGuideApi.MgInitializeWebTier("webconfig.ini");
>> // I've tried several paths and combinations but
>> // always get the same exception.
>> MgUserInformation userInfo = new
>> MgUserInformation("Administrator","admin");
>> MgSiteConnection siteConn = new MgSiteConnection();
>> siteConn.Open(userInfo);
>> Antonio Lucas
>> Software Engineer
>> SER&TEC S.L
>> Phone: +34 96 395 95 13
>> www.srtec.com
>> Valencia (Spain)
>> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: dev-help at mapguide.osgeo.org
> Antonio Lucas
> Software Engineer
> SER&TEC S.L
> www.srtec.com
> Valencia (Spain)
Antonio Lucas
Software Engineer
SER&TEC S.L
www.srtec.com
Valencia (Spain)
More information about the Mapguide-internals mailing list
