[mapguide-dev] problems initializing web tier
Traian Stanev
traian.stanev at autodesk.com
Mon Apr 24 09:49:06 EDT 2006
The msjava should not be an issue. I'm all out of ideas, may be someone
else will come up with something... By the way, are you running from
inside the debugger? Did you try running the .exe directly by clicking
on it from explorer?
Traian
-----Original Message-----
From: alucas at srtec.com [mailto:alucas at srtec.com]
Sent: Monday, April 24, 2006 9:44 AM
To: dev at mapguide.osgeo.org
Cc: dev at mapguide.osgeo.org
Subject: RE: [mapguide-dev] problems initializing web tier
Well,
I set this variables in order to build Web Extensions:
PROJ_LIB=C:\Documents and Settings\alucas\Mis
documentos\mapguide-1.0.0\Oem\proj-4.4.9\nad
GDAL_DATA=c:\Documents and Settings\alucas\Mis
documentos\mapguide-1.0.0\Oem\gdal-1.3.0\data
I've depends.exe and have been executed selecting
MapGuideDotNetApid.dll,
I'm not an expert using this tool but, the only problem I see is with
MSJAVA.dll. I attach screenshot of the result.
> OK that looks fine. It is probably still worth it to check with the
dll
> dependecy tool -- available at http://www.dependencywalker.com/
> Another thing... Can you run "set" form a command line and tell me if
> the environment variables GDAL_DATA and PROJ_LIB are defined and what
> their values are?
> Traian
> Sent: Monday, April 24, 2006 8:59 AM
> You're right Traian, but all dll's are builded as debug. I've omitted
> this
> detail because I read this in the pdf. Excuse me this mistake.
> So, all Webtier.sln and Oem.sln have been compiled in debug mode, all
> dll's have 'd' character at the end:
> ACEd.dll
> I've attached a screeenshot.
>> One thing bothers me here. The exception message says it is
attempting
>> to load MapGuideDotNetApid.dll, which is a debug build of the API dll
>> (notice the d). The debug dll expects to find other debug dlls like
>> MgCommond.dll and ACEd.dll. The list you give me has no 'd', which
> leads
>> me to believe these are release dlls. You need either all debug or
all
>> release builds of the dlls.
>> Traian
>> Sent: Monday, April 24, 2006 8:40 AM
>> Hi Traian,
>> I was thinking this, for this reason, I was put all dll's generated
> with
>> WebTier.sln in the same directory that exe file. So, the directory
>> contains:
>> ACE.dll
>> All Api dll's : MapGuideJavaApi.dll ...
>> MapguideUnmanagedApi.dll
>> MgCommon.dll
>> MgCoordinateSystem.dll
>> I don't know nothing about dependency tool. I never have used it. I
> will
>> search in the net.
>>> Could it be that it is looking for the dll that contains
>>> MgInitializeWebTier (or one of its dependencies) and not finding it?
>> Do
>>> you have the dependency tool (depends.exe). Could you run it against
>>> MapGuideDotNetApid.dll and see which dlls it depends on and is not
>>> finding?
>>> For example, when you add a managed dependency, if that dll has
>>> unmanaged dependencies (like MgCommond.dll in our case), the
> unmanaged
>>> dependencies will not get automatically copied to the .exe directory
>> and
>>> you will need to do it by hand.
>>> Traian
>>> Sent: Monday, April 24, 2006 7:18 AM
>>> Subject: [mapguide-dev] problems initializing web tier
>>> Hello list,
>>> When I try to connect to the server in .NET, I get the exception:
>>> 'An unhandled exception of type
>> 'OSGeo.MapGuide.MgFileNotFoundException'
>>> occurred in MapGuideDotNetApid.dll'
>>> I've added as a reference 'MapGuideDotNetApi.dll' in the project.
>>> The sample code to establish my conenction is:
>>> // This is a sample windows form application in C#.
>>> // I've tried with @"c:\pathtofile\webconfig.ini".
>>> // Here, the file is in the same directory that .exe
>>> // I've changed the IP address in the webconfig.ini
>>> // Here, I get the exception
>>> MapGuideApi.MgInitializeWebTier("webconfig.ini");
>>> // I've tried several paths and combinations but
>>> // always get the same exception.
>>> MgUserInformation userInfo = new
>>> MgUserInformation("Administrator","admin");
>>> MgSiteConnection siteConn = new MgSiteConnection();
>>> siteConn.Open(userInfo);
>>> Antonio Lucas
>>> Software Engineer
>>> SER&TEC S.L
>>> Phone: +34 96 395 95 13
>>> www.srtec.com
>>> Valencia (Spain)
>>> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: dev-help at mapguide.osgeo.org
>> Antonio Lucas
>> Software Engineer
>> SER&TEC S.L
>> www.srtec.com
>> Valencia (Spain)
> Antonio Lucas
> Software Engineer
> SER&TEC S.L
> www.srtec.com
> Valencia (Spain)
Antonio Lucas
Software Engineer
SER&TEC S.L
www.srtec.com
Valencia (Spain)
More information about the Mapguide-internals
